2014-01-12Merge branch 'linus' into timers/coreIngo Molnar
Pick up the latest fixes and refresh the branch. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Famouse last words: "final pull request" :-) I'm sending this because Jason Wang's fixes are pretty important 1) Add missing per-cpu stats initialization to ip6_vti. Otherwise lockdep spits out a call trace. From Li RongQing. 2) Fix NULL oops in wireless hwsim, from Javier Lopez 3) TIPC deferred packet queue unlink must NULL out skb->next to avoid crashes. From Erik Hugne 4) Fix access to uninitialized buffer in nf_nat netfilter code, from Daniel Borkmann 5) Fix lifetime of ipv6 loopback and SIT tunnel addresses, otherwise they basically timeout immediately. From Hannes Frederic Sowa 6) Fix DMA unmapping of TSO packets in bnx2x driver, from Michal Schmidt 7) Do not allow L2 forwarding offload via macvtap device, the way things are now it will not end up being forwaded at all. From Jason Wang 8) Fix transmit queue selection via ndo_dfwd_start_xmit(), fixing things like applying NETIF_F_LLTX to the wrong device (!!) and eliding the proper transmit watchdog handling 9) qlcnic driver was not updating tx statistics at all, from Manish Chopra" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: qlcnic: Fix ethtool statistics length calculation qlcnic: Fix bug in TX statistics net: core: explicitly select a txq before doing l2 forwarding macvlan: forbid L2 fowarding offload for macvtap bnx2x: fix DMA unmapping of TSO split BDs ipv6: add link-local, sit and loopback address with INFINITY_LIFE_TIME bnx2x: prevent WARN during driver unload tipc: correctly unlink packets from deferred packet queue ipv6: pcpu_tstats.syncp should be initialised in ip6_vti.c netfilter: only warn once on wrong seqadj usage netfilter: nf_nat: fix access to uninitialized buffer in IRC NAT helper NFC: Fix target mode p2p link establishment iwlwifi: add new devices for 7265 series mac80211: move "bufferable MMPDU" check to fix AP mode scan mac80211_hwsim: Fix NULL pointer dereference
2014-01-11Merge tag 'xfs-for-linus-v3.13-rc8' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs bugfixes from Ben Myers: "Here we have a bugfix for an off-by-one in the remote attribute verifier that results in a forced shutdown which you can hit with v5 superblock by creating a 64k xattr, and a fix for a missing destroy_work_on_stack() in the allocation worker. It's a bit late, but they are both fairly straightforward" * tag 'xfs-for-linus-v3.13-rc8' of git://oss.sgi.com/xfs/xfs: xfs: Calling destroy_work_on_stack() to pair with INIT_WORK_ONSTACK() xfs: fix off-by-one error in xfs_attr3_rmt_verify
2014-01-11Merge branch 'leds-fixes-for-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED fix from Bryan Wu: "Pali Rohár and Pavel Machek reported the LED of Nokia N900 doesn't work with our latest 3.13-rc6 kernel. Milo fixed the regression here" * 'leds-fixes-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: leds: lp5521/5523: Remove duplicate mutex
2014-01-11Merge tag 'pm+acpi-3.13-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: - Recent commits modifying the lists of C-states in the intel_idle driver introduced bugs leading to crashes on some systems. Two fixes from Jiang Liu. - The ACPI AC driver should receive all types of notifications, but recent change made it ignore some of them. Fix from Alexander Mezin. - intel_pstate's validity checks for MSRs it depends on are not sufficient to catch the lack of support in nested KVM setups, so they are extended to cover that case. From Dirk Brandewie. - NEC LZ750/LS has a botched up _BIX method in its ACPI tables, so our ACPI battery driver needs a quirk for it. From Lan Tianyu. - The tpm_ppi driver sometimes leaks memory allocated by acpi_get_name(). Fix from Jiang Liu. * tag 'pm+acpi-3.13-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: intel_idle: close avn_cstates array with correct marker Revert "intel_idle: mark states tables with __initdata tag" ACPI / Battery: Add a _BIX quirk for NEC LZ750/LS intel_pstate: Add X86_FEATURE_APERFMPERF to cpu match parameters. ACPI / TPM: fix memory leak when walking ACPI namespace ACPI / AC: change notification handler type to ACPI_ALL_NOTIFY
2014-01-11Merge tag 'mfd-fixes-3.13-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes Pull MFD fix from Samuel Ortiz: "This is the 2nd MFD pull request for 3.13 It only contains one fix for the rtsx_pcr driver. Without it we see a kernel panic on some machines, when resuming from suspend to RAM" * tag 'mfd-fixes-3.13-2' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-fixes: mfd: rtsx_pcr: Disable interrupts before cancelling delayed works
2014-01-10leds: lp5521/5523: Remove duplicate mutexMilo Kim
It can be a problem when a pattern is loaded via the firmware interface. LP55xx common driver has already locked the mutex in 'lp55xx_firmware_loaded()'. So it should be deleted. On the other hand, locks are required in store_engine_load() on updating program memory. Reported-by: Pali Rohár <pali.rohar@gmail.com> Reported-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Milo Kim <milo.kim@ti.com> Signed-off-by: Bryan Wu <cooloney@gmail.com> Cc: <stable@vger.kernel.org>
2014-01-10xfs: Calling destroy_work_on_stack() to pair with INIT_WORK_ONSTACK()Chuansheng Liu
In case CONFIG_DEBUG_OBJECTS_WORK is defined, it is needed to call destroy_work_on_stack() which frees the debug object to pair with INIT_WORK_ONSTACK(). Signed-off-by: Liu, Chuansheng <chuansheng.liu@intel.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 6f96b3063cdd473c68664a190524ed966ac0cd92)
2014-01-10xfs: fix off-by-one error in xfs_attr3_rmt_verifyJie Liu
With CRC check is enabled, if trying to set an attributes value just equal to the maximum size of XATTR_SIZE_MAX would cause the v3 remote attr write verification procedure failure, which would yield the back trace like below: <snip> XFS (sda7): Internal error xfs_attr3_rmt_write_verify at line 191 of file fs/xfs/xfs_attr_remote.c <snip> Call Trace: [<ffffffff816f0042>] dump_stack+0x45/0x56 [<ffffffffa0d99c8b>] xfs_error_report+0x3b/0x40 [xfs] [<ffffffffa0d96edd>] ? _xfs_buf_ioapply+0x6d/0x390 [xfs] [<ffffffffa0d99ce5>] xfs_corruption_error+0x55/0x80 [xfs] [<ffffffffa0dbef6b>] xfs_attr3_rmt_write_verify+0x14b/0x1a0 [xfs] [<ffffffffa0d96edd>] ? _xfs_buf_ioapply+0x6d/0x390 [xfs] [<ffffffffa0d97315>] ? xfs_bdstrat_cb+0x55/0xb0 [xfs] [<ffffffffa0d96edd>] _xfs_buf_ioapply+0x6d/0x390 [xfs] [<ffffffff81184cda>] ? vm_map_ram+0x31a/0x460 [<ffffffff81097230>] ? wake_up_state+0x20/0x20 [<ffffffffa0d97315>] ? xfs_bdstrat_cb+0x55/0xb0 [xfs] [<ffffffffa0d9726b>] xfs_buf_iorequest+0x6b/0xc0 [xfs] [<ffffffffa0d97315>] xfs_bdstrat_cb+0x55/0xb0 [xfs] [<ffffffffa0d97906>] xfs_bwrite+0x46/0x80 [xfs] [<ffffffffa0dbfa94>] xfs_attr_rmtval_set+0x334/0x490 [xfs] [<ffffffffa0db84aa>] xfs_attr_leaf_addname+0x24a/0x410 [xfs] [<ffffffffa0db8893>] xfs_attr_set_int+0x223/0x470 [xfs] [<ffffffffa0db8b76>] xfs_attr_set+0x96/0xb0 [xfs] [<ffffffffa0db13b2>] xfs_xattr_set+0x42/0x70 [xfs] [<ffffffff811df9b2>] generic_setxattr+0x62/0x80 [<ffffffff811e0213>] __vfs_setxattr_noperm+0x63/0x1b0 [<ffffffff81307afe>] ? evm_inode_setxattr+0xe/0x10 [<ffffffff811e0415>] vfs_setxattr+0xb5/0xc0 [<ffffffff811e054e>] setxattr+0x12e/0x1c0 [<ffffffff811c6e82>] ? final_putname+0x22/0x50 [<ffffffff811c708b>] ? putname+0x2b/0x40 [<ffffffff811cc4bf>] ? user_path_at_empty+0x5f/0x90 [<ffffffff811bdfd9>] ? __sb_start_write+0x49/0xe0 [<ffffffff81168589>] ? vm_mmap_pgoff+0x99/0xc0 [<ffffffff811e07df>] SyS_setxattr+0x8f/0xe0 [<ffffffff81700c2d>] system_call_fastpath+0x1a/0x1f Tests: setfattr -n user.longxattr -v `perl -e 'print "A"x65536'` testfile This patch fix it to check the remote EA size is greater than the XATTR_SIZE_MAX rather than more than or equal to it, because it's valid if the specified EA value size is equal to the limitation as per VFS setxattr interface. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reviewed-by: Mark Tinguely <tinguely@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com> (cherry picked from commit 85dd0707f0cad26d60f2dc574d17a5ab948d10f7)
2014-01-10qlcnic: Fix ethtool statistics length calculationShahed Shaikh
o Consider number of Tx queues while calculating the length of Tx statistics as part of ethtool stats. o Calculate statistics lenght properly for 82xx and 83xx adapter Signed-off-by: Shahed Shaikh <shahed.shaikh@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-10qlcnic: Fix bug in TX statisticsManish Chopra
o Driver was not updating TX stats so it was not populating statistics in `ifconfig` command output. Signed-off-by: Manish Chopra <manish.chopra@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-10net: core: explicitly select a txq before doing l2 forwardingJason Wang
Currently, the tx queue were selected implicitly in ndo_dfwd_start_xmit(). The will cause several issues: - NETIF_F_LLTX were removed for macvlan, so txq lock were done for macvlan instead of lower device which misses the necessary txq synchronization for lower device such as txq stopping or frozen required by dev watchdog or control path. - dev_hard_start_xmit() was called with NULL txq which bypasses the net device watchdog. - dev_hard_start_xmit() does not check txq everywhere which will lead a crash when tso is disabled for lower device. Fix this by explicitly introducing a new param for .ndo_select_queue() for just selecting queues in the case of l2 forwarding offload. netdev_pick_tx() was also extended to accept this parameter and dev_queue_xmit_accel() was used to do l2 forwarding transmission. With this fixes, NETIF_F_LLTX could be preserved for macvlan and there's no need to check txq against NULL in dev_hard_start_xmit(). Also there's no need to keep a dedicated ndo_dfwd_start_xmit() and we can just reuse the code of dev_queue_xmit() to do the transmission. In the future, it was also required for macvtap l2 forwarding support since it provides a necessary synchronization method. Cc: John Fastabend <john.r.fastabend@intel.com> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: e1000-devel@lists.sourceforge.net Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-10macvlan: forbid L2 fowarding offload for macvtapJason Wang
L2 fowarding offload will bypass the rx handler of real device. This will make the packet could not be forwarded to macvtap device. Another problem is the dev_hard_start_xmit() called for macvtap does not have any synchronization. Fix this by forbidding L2 forwarding for macvtap. Cc: John Fastabend <john.r.fastabend@intel.com> Cc: Neil Horman <nhorman@tuxdriver.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: John Fastabend <john.r.fastabend@intel.com.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-10Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless John W. Linville says: ==================== For the mac80211 bits, Johannes says: "I have a fix from Javier for mac80211_hwsim when used with wmediumd userspace, and a fix from Felix for buffering in AP mode." For the NFC bits, Samuel says: "This pull request only contains one fix for a regression introduced with commit e29a9e2ae165620d. Without this fix, we can not establish a p2p link in target mode. Only initiator mode works." For the iwlwifi bits, Emmanuel says: "It only includes new device IDs so it's not vital. If you have a pull request to net.git anyway, I'd happy to have this in." ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-10bnx2x: fix DMA unmapping of TSO split BDsMichal Schmidt
bnx2x triggers warnings with CONFIG_DMA_API_DEBUG=y: WARNING: CPU: 0 PID: 2253 at lib/dma-debug.c:887 check_unmap+0xf8/0x920() bnx2x 0000:28:00.0: DMA-API: device driver frees DMA memory with different size [device address=0x00000000da2b389e] [map size=1490 bytes] [unmap size=66 bytes] The reason is that bnx2x splits a TSO BD into two BDs (headers + data) using one DMA mapping for both, but it uses only the length of the first BD when unmapping. This patch fixes the bug by unmapping the whole length of the two BDs. Signed-off-by: Michal Schmidt <mschmidt@redhat.com> Reviewed-by: Eric Dumazet <edumazet@google.com> Acked-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-10Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock fixes from Mike Turquette: "Late fixes for clock drivers. All of these fixes are for user-visible regressions, typically boot failures or other unsafe system configuration that causes badness" * tag 'clk-fixes-for-linus' of git://git.linaro.org/people/mike.turquette/linux: clk: clk-divider: fix divisor > 255 bug clk: exynos: File scope reg_save array should depend on PM_SLEEP clk: samsung: exynos5250: Add CLK_IGNORE_UNUSED flag for the sysreg clock ARM: dts: exynos5250: Fix MDMA0 clock number clk: samsung: exynos5250: Add MDMA0 clocks clk: samsung: exynos5250: Fix ACP gate register offset clk: exynos5250: fix sysmmu_mfc{l,r} gate clocks clk: samsung: exynos4: Correct SRC_MFC register
2014-01-10Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A few fixes for Renesas platforms to fixup DMA masks (this started causing errors once the DMA API added checks for valid masks in 3.13)" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: shmobile: mackerel: Fix coherent DMA mask ARM: shmobile: kzm9g: Fix coherent DMA mask ARM: shmobile: armadillo: Fix coherent DMA mask
2014-01-09ipv6: add link-local, sit and loopback address with INFINITY_LIFE_TIMEHannes Frederic Sowa
In the past the IFA_PERMANENT flag indicated, that the valid and preferred lifetime where ignored. Since change fad8da3e085ddf ("ipv6 addrconf: fix preferred lifetime state-changing behavior while valid_lft is infinity") we honour at least the preferred lifetime on those addresses. As such the valid lifetime gets recalculated and updated to 0. If loopback address is added manually this problem does not occur. Also if NetworkManager manages IPv6, those addresses will get added via inet6_rtm_newaddr and thus will have a correct lifetime, too. Reported-by: François-Xavier Le Bail <fx.lebail@yahoo.com> Reported-by: Damien Wyart <damien.wyart@gmail.com> Fixes: fad8da3e085ddf ("ipv6 addrconf: fix preferred lifetime state-changing behavior while valid_lft is infinity") Cc: Yasushi Asano <yasushi.asano@jp.fujitsu.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-09bnx2x: prevent WARN during driver unloadYuval Mintz
Starting with commit 80c33dd "net: add might_sleep() call to napi_disable" bnx2x fails the might_sleep tests causing a stack trace to appear whenever the driver is unloaded, as local_bh_disable() is being called before napi_disable(). This changes the locking schematics related to CONFIG_NET_RX_BUSY_POLL, preventing the need for calling local_bh_disable() and thus eliminating the issue. Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Ariel Elior <ariele@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-10Merge branch 'pm-cpuidle'Rafael J. Wysocki
* pm-cpuidle: intel_idle: close avn_cstates array with correct marker Revert "intel_idle: mark states tables with __initdata tag"
2014-01-10intel_idle: close avn_cstates array with correct markerJiang Liu
Close avn_cstates array with correct marker to avoid overflow in function intel_idle_cpu_init(). [rjw: The problem was introduced when commit 22e580d07f65 was merged on top of eba682a5aeb6 (intel_idle: shrink states tables).] Fixes: 22e580d07f65 (intel_idle: Fixed C6 state on Avoton/Rangeley processors) Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-01-09Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2014-01-09Revert "intel_idle: mark states tables with __initdata tag"Jiang Liu
This reverts commit 9d046ccb98085f1d437585f84748c783a04ba240. Commit 9d046ccb98085 marks all state tables with __initdata, but the state table may be accessed when doing CPU online, which then causing system crash as below: [ 204.188841] BUG: unable to handle kernel paging request at ffffffff8227cce8 [ 204.196844] IP: [<ffffffff814aa1c0>] intel_idle_cpu_init+0x40/0x130 [ 204.203996] PGD 1e11067 PUD 1e12063 PMD 455859063 PTE 800000000227c062 [ 204.211638] Oops: 0000 [#1] SMP DEBUG_PAGEALLOC [ 204.216975] Modules linked in: x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel aes_x86_64 lrw gf128mul glue_helper ablk_helper cryptd gpio_ich microcode joydev sb_edac edac_core ipmi_si lpc_ich ipmi_msghandler lp tpm_tis parport wmi mac_hid acpi_pad hid_generic ixgbe isci usbhid dca hid libsas ptp ahci libahci scsi_transport_sas megaraid_sas pps_core mdio [ 204.262815] CPU: 11 PID: 1489 Comm: bash Not tainted 3.13.0-rc7+ #48 [ 204.269993] Hardware name: Intel Corporation BRICKLAND/BRICKLAND, BIOS BRIVTIN1.86B.0047.L09.1312061514 12/06/2013 [ 204.281646] task: ffff8804303a24a0 ti: ffff880440fac000 task.ti: ffff880440fac000 [ 204.290311] RIP: 0010:[<ffffffff814aa1c0>] [<ffffffff814aa1c0>] intel_idle_cpu_init+0x40/0x130 [ 204.300184] RSP: 0018:ffff880440fadd28 EFLAGS: 00010286 [ 204.306192] RAX: ffffffff8227cca0 RBX: ffffe8fff1a03400 RCX: 0000000000000007 [ 204.314244] RDX: ffff88045f400000 RSI: 0000000000000009 RDI: 0000000000001120 [ 204.322296] RBP: ffff880440fadd38 R08: 0000000000000000 R09: 0000000000000001 [ 204.330411] R10: 0000000000000001 R11: 0000000000000000 R12: 000000000000001e [ 204.338482] R13: 00000000ffffffdb R14: 0000000000000001 R15: 0000000000000000 [ 204.346743] FS: 00007f64f7b0c740(0000) GS:ffff88045ce00000(0000) knlGS:0000000000000000 [ 204.355919] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 204.362449] CR2: ffffffff8227cce8 CR3: 0000000444ab0000 CR4: 00000000001407e0 [ 204.370520] Stack: [ 204.372853] 000000000000001e ffffffff81f10240 ffff880440fadd50 ffffffff814aa307 [ 204.381519] ffffffff81ea80e0 ffff880440fadda0 ffffffff8185a230 0000000000000000 [ 204.390196] 000000000000001e 0000000000000002 0000000000000002 0000000000000000 [ 204.398856] Call Trace: [ 204.401683] [<ffffffff814aa307>] cpu_hotplug_notify+0x57/0x70 [ 204.408638] [<ffffffff8185a230>] notifier_call_chain+0x100/0x150 [ 204.415553] [<ffffffff810a7dae>] __raw_notifier_call_chain+0xe/0x10 [ 204.422772] [<ffffffff81072163>] cpu_notify+0x23/0x50 [ 204.428616] [<ffffffff810723b2>] _cpu_up+0x132/0x1a0 [ 204.434361] [<ffffffff8107249d>] cpu_up+0x7d/0xa0 [ 204.439819] [<ffffffff81836c9c>] cpu_subsys_online+0x3c/0x90 [ 204.446345] [<ffffffff81554625>] device_online+0x45/0xa0 [ 204.452471] [<ffffffff815546ce>] online_store+0x4e/0x80 [ 204.458511] [<ffffffff815519a8>] dev_attr_store+0x18/0x30 [ 204.464744] [<ffffffff812a68f1>] sysfs_write_file+0x151/0x1c0 [ 204.471681] [<ffffffff81217ef1>] vfs_write+0xe1/0x160 [ 204.477524] [<ffffffff8121889c>] SyS_write+0x4c/0x90 [ 204.483270] [<ffffffff8185f2ed>] system_call_fastpath+0x1a/0x1f [ 204.490081] Code: 41 54 41 89 fc 8b 3d 48 25 85 01 53 48 8b 1d 30 25 85 01 48 03 1c c5 40 90 fb 81 48 8b 05 19 25 85 01 c7 43 0c 01 00 00 00 66 90 <48> 83 78 48 00 74 4f 41 83 c0 01 41 39 f0 7e 10 48 c7 c7 38 79 [ 204.515723] RIP [<ffffffff814aa1c0>] intel_idle_cpu_init+0x40/0x130 [ 204.522996] RSP <ffff880440fadd28> [ 204.526976] CR2: ffffffff8227cce8 [ 204.530766] ---[ end trace 336f56cc3d1cfc8c ]--- Fixes: 9d046ccb98085 (intel_idle: mark states tables with __initdata tag) Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-01-09Merge branch 'parisc-3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc fix from Helge Deller: "This patch fixes the kmap/kunmap implementation on parisc and finally makes AIO work on parisc" * 'parisc-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: Ensure full cache coherency for kmap/kunmap
2014-01-09Merge branch 'for-3.13-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata fixes from Tejun Heo: "Late fixes for libata. Nothing too interesting. Adding missing PM callbacks to satat_sis and an additional PCI ID for ahci" * 'for-3.13-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: sata_sis: missing PM support ahci: add PCI ID for Marvell 88SE9170 SATA controller
2014-01-08parisc: Ensure full cache coherency for kmap/kunmapJohn David Anglin
Helge Deller noted a few weeks ago problems with the AIO support on parisc. This change is the result of numerous iterations on how best to deal with this problem. The solution adopted here is to provide full cache coherency in a uniform manner on all parisc systems. This involves calling flush_dcache_page() on kmap operations and flush_kernel_dcache_page() on kunmap operations. As a result, the copy_user_page() and clear_user_page() functions can be removed and the overall code is simpler. The change ensures that both userspace and kernel aliases to a mapped page are invalidated and flushed. This is necessary for the correct operation of PA8800 and PA8900 based systems which do not support inequivalent aliases. With this change, I have observed no cache related issues on c8000 and rp3440. It is now possible for example to do kernel builds with "-j64" on four way systems. On systems using XFS file systems, the patch recently posted by Mikulas Patocka to "fix crash using XFS on loopback" is needed to avoid a hang caused by an uninitialized lock passed to flush_dcache_page() in the page struct. Signed-off-by: John David Anglin <dave.anglin@bell.net> Cc: stable@vger.kernel.org # v3.9+ Signed-off-by: Helge Deller <deller@gmx.de>
2014-01-08Merge tag 'nfc-fixes-3.13-1' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/nfc-fixes Samuel Ortiz <sameo@linux.intel.com> says: "This is the first NFC fixes pull request for 3.13. It only contains one fix for a regression introduced with commit e29a9e2ae165620d. Without this fix, we can not establish a p2p link in target mode. Only initiator mode works." Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-01-08clk: clk-divider: fix divisor > 255 bugJames Hogan
Commit 6d9252bd9a4bb (clk: Add support for power of two type dividers) merged in v3.6 added the _get_val function to convert a divisor value to a register field value depending on the flags. However it used the type u8 for the div field, causing divisors larger than 255 to be masked and the resultant clock rate to be too high. E.g. in my case an 11bit divider was supposed to divide 24.576 MHz down to 32.768KHz. The divisor was correctly calculated as 750 (0x2ee). This was masked to 238 (0xee) resulting in a frequency of 103.26KHz. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Rajendra Nayak <rnayak@ti.com> Cc: linux-arm-kernel@lists.infradead.org Cc: stable@vger.kernel.org Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-01-08Merge branch 'drm-nouveau-next' of ↵Dave Airlie
git://anongit.freedesktop.org/nouveau/linux-2.6 into drm-fixes misc fixes for nouveau, one more msi rearm, regression fix for old bioses crash and leak fixes. * 'drm-nouveau-next' of git://anongit.freedesktop.org/nouveau/linux-2.6: drm/nouveau/nouveau: fix memory leak in nouveau_crtc_page_flip() drm/nouveau/bios: fix offset calculation for BMPv1 bioses drm/nouveau: return offset of allocated notifier drm/nouveau/bios: make jump conditional drm/nvce/mc: fix msi rearm on GF114 drm/nvc0/gr: fix mthd data submission drm/nouveau: populate master subdev pointer only when fully constructed
2014-01-08Merge tag 'drm-intel-fixes-2014-01-08' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-fixes Just a revert (gen4 backlight seems a lost cause) and a tlb coherency fix for bdw, plus the patch to sign up Jani for co-maintainer. Thanks to Ben for taking care of -fixes while I've enjoyed a bit of vacation. * tag 'drm-intel-fixes-2014-01-08' of git://people.freedesktop.org/~danvet/drm-intel: MAINTAINERS: Updates for drm/i915 Revert "drm/i915: assume all GM45 Acer laptops use inverted backlight PWM" drm/i915/bdw: Flush system agent on gen8 also
2014-01-08drm/nouveau/nouveau: fix memory leak in nouveau_crtc_page_flip()Christian Engelmayer
Fix a memory leak in the nouveau_crtc_page_flip() error handling path. Signed-off-by: Christian Engelmayer <cengelma@gmx.at> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2014-01-08drm/nouveau/bios: fix offset calculation for BMPv1 biosesIlia Mirkin
The only BIOS on record that needs the 14 offset has a bios major version 2 but BMP version 1.01. Another bunch of BIOSes that need the 18 offset have BMP version 2.01 or 5.01 or higher. So instead of looking at the bios major version, look at the BMP version. BIOSes with BMP version 0 do not contain a detectable script, so always return 0 for them. See https://bugs.freedesktop.org/show_bug.cgi?id=68835 Reported-by: Mauro Molinari <mauromol@tiscali.it> Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2014-01-07Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== The following patchset contains two patches: * fix the IRC NAT helper which was broken when adding (incomplete) IPv6 support, from Daniel Borkmann. * Refine the previous bugtrap that Jesper added to catch problems for the usage of the sequence adjustment extension in IPVs in Dec 16th, it may spam messages in case of finding a real bug. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-07tipc: correctly unlink packets from deferred packet queueErik Hugne
When we pull a received packet from a link's 'deferred packets' queue for processing, its 'next' pointer is not cleared, and still refers to the next packet in that queue, if any. This is incorrect, but caused no harm before commit 40ba3cdf542a469aaa9083fa041656e59b109b90 ("tipc: message reassembly using fragment chain") was introduced. After that commit, it may sometimes lead to the following oops: general protection fault: 0000 [#1] SMP DEBUG_PAGEALLOC Modules linked in: tipc CPU: 4 PID: 0 Comm: swapper/4 Tainted: G W 3.13.0-rc2+ #6 Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007 task: ffff880017af4880 ti: ffff880017aee000 task.ti: ffff880017aee000 RIP: 0010:[<ffffffff81710694>] [<ffffffff81710694>] skb_try_coalesce+0x44/0x3d0 RSP: 0018:ffff880016603a78 EFLAGS: 00010212 RAX: 6b6b6b6bd6d6d6d6 RBX: ffff880013106ac0 RCX: ffff880016603ad0 RDX: ffff880016603ad7 RSI: ffff88001223ed00 RDI: ffff880013106ac0 RBP: ffff880016603ab8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffff88001223ed00 R13: ffff880016603ad0 R14: 000000000000058c R15: ffff880012297650 FS: 0000000000000000(0000) GS:ffff880016600000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 000000000805b000 CR3: 0000000011f5d000 CR4: 00000000000006e0 Stack: ffff880016603a88 ffffffff810a38ed ffff880016603aa8 ffff88001223ed00 0000000000000001 ffff880012297648 ffff880016603b68 ffff880012297650 ffff880016603b08 ffffffffa0006c51 ffff880016603b08 00ffffffa00005fc Call Trace: <IRQ> [<ffffffff810a38ed>] ? trace_hardirqs_on+0xd/0x10 [<ffffffffa0006c51>] tipc_link_recv_fragment+0xd1/0x1b0 [tipc] [<ffffffffa0007214>] tipc_recv_msg+0x4e4/0x920 [tipc] [<ffffffffa00016f0>] ? tipc_l2_rcv_msg+0x40/0x250 [tipc] [<ffffffffa000177c>] tipc_l2_rcv_msg+0xcc/0x250 [tipc] [<ffffffffa00016f0>] ? tipc_l2_rcv_msg+0x40/0x250 [tipc] [<ffffffff8171e65b>] __netif_receive_skb_core+0x80b/0xd00 [<ffffffff8171df94>] ? __netif_receive_skb_core+0x144/0xd00 [<ffffffff8171eb76>] __netif_receive_skb+0x26/0x70 [<ffffffff8171ed6d>] netif_receive_skb+0x2d/0x200 [<ffffffff8171fe70>] napi_gro_receive+0xb0/0x130 [<ffffffff815647c2>] e1000_clean_rx_irq+0x2c2/0x530 [<ffffffff81565986>] e1000_clean+0x266/0x9c0 [<ffffffff81985f7b>] ? notifier_call_chain+0x2b/0x160 [<ffffffff8171f971>] net_rx_action+0x141/0x310 [<ffffffff81051c1b>] __do_softirq+0xeb/0x480 [<ffffffff819817bb>] ? _raw_spin_unlock+0x2b/0x40 [<ffffffff810b8c42>] ? handle_fasteoi_irq+0x72/0x100 [<ffffffff81052346>] irq_exit+0x96/0xc0 [<ffffffff8198cbc3>] do_IRQ+0x63/0xe0 [<ffffffff81981def>] common_interrupt+0x6f/0x6f <EOI> This happens when the last fragment of a message has passed through the the receiving link's 'deferred packets' queue, and at least one other packet was added to that queue while it was there. After the fragment chain with the complete message has been successfully delivered to the receiving socket, it is released. Since 'next' pointer of the last fragment in the released chain now is non-NULL, we get the crash shown above. We fix this by clearing the 'next' pointer of all received packets, including those being pulled from the 'deferred' queue, before they undergo any further processing. Fixes: 40ba3cdf542a4 ("tipc: message reassembly using fragment chain") Signed-off-by: Erik Hugne <erik.hugne@ericsson.com> Reported-by: Ying Xue <ying.xue@windriver.com> Reviewed-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jon Maloy <jon.maloy@ericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-07ipv6: pcpu_tstats.syncp should be initialised in ip6_vti.cLi RongQing
initialise pcpu_tstats.syncp to kill the calltrace [ 11.973950] Call Trace: [ 11.973950] [<819bbaff>] dump_stack+0x48/0x60 [ 11.973950] [<819bbaff>] dump_stack+0x48/0x60 [ 11.973950] [<81078dcf>] __lock_acquire.isra.22+0x1bf/0xc10 [ 11.973950] [<81078dcf>] __lock_acquire.isra.22+0x1bf/0xc10 [ 11.973950] [<81079fa7>] lock_acquire+0x77/0xa0 [ 11.973950] [<81079fa7>] lock_acquire+0x77/0xa0 [ 11.973950] [<817ca7ab>] ? dev_get_stats+0xcb/0x130 [ 11.973950] [<817ca7ab>] ? dev_get_stats+0xcb/0x130 [ 11.973950] [<8183862d>] ip_tunnel_get_stats64+0x6d/0x230 [ 11.973950] [<8183862d>] ip_tunnel_get_stats64+0x6d/0x230 [ 11.973950] [<817ca7ab>] ? dev_get_stats+0xcb/0x130 [ 11.973950] [<817ca7ab>] ? dev_get_stats+0xcb/0x130 [ 11.973950] [<811cf8c1>] ? __nla_reserve+0x21/0xd0 [ 11.973950] [<811cf8c1>] ? __nla_reserve+0x21/0xd0 [ 11.973950] [<817ca7ab>] dev_get_stats+0xcb/0x130 [ 11.973950] [<817ca7ab>] dev_get_stats+0xcb/0x130 [ 11.973950] [<817d5409>] rtnl_fill_ifinfo+0x569/0xe20 [ 11.973950] [<817d5409>] rtnl_fill_ifinfo+0x569/0xe20 [ 11.973950] [<810352e0>] ? kvm_clock_read+0x20/0x30 [ 11.973950] [<810352e0>] ? kvm_clock_read+0x20/0x30 [ 11.973950] [<81008e38>] ? sched_clock+0x8/0x10 [ 11.973950] [<81008e38>] ? sched_clock+0x8/0x10 [ 11.973950] [<8106ba45>] ? sched_clock_local+0x25/0x170 [ 11.973950] [<8106ba45>] ? sched_clock_local+0x25/0x170 [ 11.973950] [<810da6bd>] ? __kmalloc+0x3d/0x90 [ 11.973950] [<810da6bd>] ? __kmalloc+0x3d/0x90 [ 11.973950] [<817b8c10>] ? __kmalloc_reserve.isra.41+0x20/0x70 [ 11.973950] [<817b8c10>] ? __kmalloc_reserve.isra.41+0x20/0x70 [ 11.973950] [<810da81a>] ? slob_alloc_node+0x2a/0x60 [ 11.973950] [<810da81a>] ? slob_alloc_node+0x2a/0x60 [ 11.973950] [<817b919a>] ? __alloc_skb+0x6a/0x2b0 [ 11.973950] [<817b919a>] ? __alloc_skb+0x6a/0x2b0 [ 11.973950] [<817d8795>] rtmsg_ifinfo+0x65/0xe0 [ 11.973950] [<817d8795>] rtmsg_ifinfo+0x65/0xe0 [ 11.973950] [<817cbd31>] register_netdevice+0x531/0x5a0 [ 11.973950] [<817cbd31>] register_netdevice+0x531/0x5a0 [ 11.973950] [<81892b87>] ? ip6_tnl_get_cap+0x27/0x90 [ 11.973950] [<81892b87>] ? ip6_tnl_get_cap+0x27/0x90 [ 11.973950] [<817cbdb6>] register_netdev+0x16/0x30 [ 11.973950] [<817cbdb6>] register_netdev+0x16/0x30 [ 11.973950] [<81f574a6>] vti6_init_net+0x1c4/0x1d4 [ 11.973950] [<81f574a6>] vti6_init_net+0x1c4/0x1d4 [ 11.973950] [<81f573af>] ? vti6_init_net+0xcd/0x1d4 [ 11.973950] [<81f573af>] ? vti6_init_net+0xcd/0x1d4 [ 11.973950] [<817c16df>] ops_init.constprop.11+0x17f/0x1c0 [ 11.973950] [<817c16df>] ops_init.constprop.11+0x17f/0x1c0 [ 11.973950] [<817c1779>] register_pernet_operations.isra.9+0x59/0x90 [ 11.973950] [<817c1779>] register_pernet_operations.isra.9+0x59/0x90 [ 11.973950] [<817c18d1>] register_pernet_device+0x21/0x60 [ 11.973950] [<817c18d1>] register_pernet_device+0x21/0x60 [ 11.973950] [<81f574b6>] ? vti6_init_net+0x1d4/0x1d4 [ 11.973950] [<81f574b6>] ? vti6_init_net+0x1d4/0x1d4 [ 11.973950] [<81f574c7>] vti6_tunnel_init+0x11/0x68 [ 11.973950] [<81f574c7>] vti6_tunnel_init+0x11/0x68 [ 11.973950] [<81f572a1>] ? mip6_init+0x73/0xb4 [ 11.973950] [<81f572a1>] ? mip6_init+0x73/0xb4 [ 11.973950] [<81f0cba4>] do_one_initcall+0xbb/0x15b [ 11.973950] [<81f0cba4>] do_one_initcall+0xbb/0x15b [ 11.973950] [<811a00d8>] ? sha_transform+0x528/0x1150 [ 11.973950] [<811a00d8>] ? sha_transform+0x528/0x1150 [ 11.973950] [<81f0c544>] ? repair_env_string+0x12/0x51 [ 11.973950] [<81f0c544>] ? repair_env_string+0x12/0x51 [ 11.973950] [<8105c30d>] ? parse_args+0x2ad/0x440 [ 11.973950] [<8105c30d>] ? parse_args+0x2ad/0x440 [ 11.973950] [<810546be>] ? __usermodehelper_set_disable_depth+0x3e/0x50 [ 11.973950] [<810546be>] ? __usermodehelper_set_disable_depth+0x3e/0x50 [ 11.973950] [<81f0cd27>] kernel_init_freeable+0xe3/0x182 [ 11.973950] [<81f0cd27>] kernel_init_freeable+0xe3/0x182 [ 11.973950] [<81f0c532>] ? do_early_param+0x7a/0x7a [ 11.973950] [<81f0c532>] ? do_early_param+0x7a/0x7a [ 11.973950] [<819b5b1b>] kernel_init+0xb/0x100 [ 11.973950] [<819b5b1b>] kernel_init+0xb/0x100 [ 11.973950] [<819cebf7>] ret_from_kernel_thread+0x1b/0x28 [ 11.973950] [<819cebf7>] ret_from_kernel_thread+0x1b/0x28 [ 11.973950] [<819b5b10>] ? rest_init+0xc0/0xc0 [ 11.973950] [<819b5b10>] ? rest_init+0xc0/0xc0 Before 469bdcefdc ("ipv6: fix the use of pcpu_tstats in ip6_vti.c"), the pcpu_tstats.syncp is not used to pretect the 64bit elements of pcpu_tstats, so not appear this calltrace. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Li RongQing <roy.qing.li@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-07MAINTAINERS: Updates for drm/i915Daniel Vetter
Jani for co-maintainer! Jani has been a really active bug-scrubber in the past few months. I've asked him whether he wants to do this in a more official capacity and he agreed. I've already chatted with Dave and Jesse and they support this. Note that everyone can't now just relax because "Jani will do all the bug scrubbing" - au contraire expect more nagging and poking now that we have more bandwidth. Longer-term the plan is to share more of the maintainer duties, but we need to fix up the infrastructure a bit first (like moving the git repo to a common location). While at it also add the newly set-up patchwork instance. Cc: Dave Airlie <airlied@gmail.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Jani Nikula <jani.nikula@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-01-07drm/nouveau: return offset of allocated notifierBob Gleitsmann
2014-01-07drm/nouveau/bios: make jump conditionalIlia Mirkin
This fixes a hang in VBIOS scripts of the form "condition; jump". The jump used to always be executed, while now it will only be executed if the condition is true. See https://bugs.freedesktop.org/show_bug.cgi?id=72943 Reported-by: Darcy Brás da Silva <dardevelin@cidadecool.com> Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu> Cc: stable@vger.kernel.org
2014-01-07drm/nvce/mc: fix msi rearm on GF114Sid Boyce
2014-01-07drm/nvc0/gr: fix mthd data submissionKelly Doran
If the initial data element is 0, it will never be written, even though the value from the previous method may be there. Signed-off-by: Kelly Doran <kel.p.doran@gmail.com> Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2014-01-07drm/nouveau: populate master subdev pointer only when fully constructedBen Skeggs
2014-01-07Merge tag 'ext4_for_linus_stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 bugfix from Ted Ts'o: "Fix a regression introduced in v3.13-rc6" * tag 'ext4_for_linus_stable' of http://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: fix bigalloc regression
2014-01-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "I'm hoping this is the very last batch of networking fixes for 3.13, here goes nothing: 1) Fix crashes in VLAN's header_ops passthru. 2) Bridge multicast code needs to use BH spinlocks to prevent deadlocks with timers. From Curt Brune. 3) ipv6 tunnels lack proper synchornization when updating percpu statistics. From Li RongQing. 4) Fixes to bnx2x driver from Yaniv Rosner, Dmitry Kravkov and Michal Kalderon. 5) Avoid undefined operator evaluation order in llc code, from Daniel Borkmann. 6) Error paths in various GSO offload paths do not unwind properly, in particular they must undo any modifications they have made to the SKB. From Wei-Chun Chao. 7) Fix RX refill races during restore in virtio-net, from Jason Wang. 8) Fix SKB use after free in LLC code, from Daniel Borkmann. 9) Missing unlock and OOPS in netpoll code when VLAN tag handling fails. 10) Fix vxlan device attachment wrt ipv6, from Fan Du. 11) Don't allow creating infiniband links to non-infiniband devices, from Hangbin Liu. 12) Revert FEC phy reset active low change, it breaks things. From Fabio Estevam. 13) Fix header pointer handling in 6lowpan header building code, from Daniel Borkmann. 14) Fix RSS handling in be2net driver, from Vasundhara Volam. 15) Fix modem port indexing in HSO driver, from Dan Williams" * http://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (38 commits) bridge: use spin_lock_bh() in br_multicast_set_hash_max ipv6: don't install anycast address for /128 addresses on routers hso: fix handling of modem port SERIAL_STATE notifications isdn: Drop big endian cpp checks from telespci and hfc_pci drivers be2net: fix max_evt_qs calculation for BE3 in SR-IOV config be2net: increase the timeout value for loopback-test FW cmd be2net: disable RSS when number of RXQs is reduced to 1 via set-channels xen-netback: Include header for vmalloc net: 6lowpan: fix lowpan_header_create non-compression memcpy call fec: Revert "fec: Do not assume that PHY reset is active low" bnx2x: fix VLAN configuration for VFs. bnx2x: fix AFEX memory overflow bnx2x: Clean before update RSS arrives bnx2x: Correct number of MSI-X vectors for VFs bnx2x: limit number of interrupt vectors for 57711 qlcnic: Fix bug in Tx completion path infiniband: make sure the src net is infiniband when create new link {vxlan, inet6} Mark vxlan_dev flags with VXLAN_F_IPV6 properly cxgb4: allow large buffer size to have page size netpoll: Fix missing TXQ unlock and and OOPS. ...
2014-01-06Merge branches 'acpi-battery' and 'pm-cpufreq'Rafael J. Wysocki
* acpi-battery: ACPI / Battery: Add a _BIX quirk for NEC LZ750/LS * pm-cpufreq: intel_pstate: Add X86_FEATURE_APERFMPERF to cpu match parameters.
2014-01-06bridge: use spin_lock_bh() in br_multicast_set_hash_maxCurt Brune
br_multicast_set_hash_max() is called from process context in net/bridge/br_sysfs_br.c by the sysfs store_hash_max() function. br_multicast_set_hash_max() calls spin_lock(&br->multicast_lock), which can deadlock the CPU if a softirq that also tries to take the same lock interrupts br_multicast_set_hash_max() while the lock is held . This can happen quite easily when any of the bridge multicast timers expire, which try to take the same lock. The fix here is to use spin_lock_bh(), preventing other softirqs from executing on this CPU. Steps to reproduce: 1. Create a bridge with several interfaces (I used 4). 2. Set the "multicast query interval" to a low number, like 2. 3. Enable the bridge as a multicast querier. 4. Repeatedly set the bridge hash_max parameter via sysfs. # brctl addbr br0 # brctl addif br0 eth1 eth2 eth3 eth4 # brctl setmcqi br0 2 # brctl setmcquerier br0 1 # while true ; do echo 4096 > /sys/class/net/br0/bridge/hash_max; done Signed-off-by: Curt Brune <curt@cumulusnetworks.com> Signed-off-by: Scott Feldman <sfeldma@cumulusnetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06ipv6: don't install anycast address for /128 addresses on routersHannes Frederic Sowa
It does not make sense to create an anycast address for an /128-prefix. Suppress it. As 32019e651c6fce ("ipv6: Do not leave router anycast address for /127 prefixes.") shows we also may not leave them, because we could accidentally remove an anycast address the user has allocated or got added via another prefix. Cc: François-Xavier Le Bail <fx.lebail@yahoo.com> Cc: Thomas Haller <thaller@redhat.com> Cc: Jiri Pirko <jiri@resnulli.us> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06hso: fix handling of modem port SERIAL_STATE notificationsDan Williams
The existing serial state notification handling expected older Option devices, having a hardcoded assumption that the Modem port was always USB interface #2. That isn't true for devices from the past few years. hso_serial_state_notification is a local cache of a USB Communications Interface Class SERIAL_STATE notification from the device, and the USB CDC specification (section 6.3, table 67 "Class-Specific Notifications") defines wIndex as the USB interface the event applies to. For hso devices this will always be the Modem port, as the Modem port is the only port which is set up to receive them by the driver. So instead of always expecting USB interface #2, instead validate the notification with the actual USB interface number of the Modem port. Signed-off-by: Dan Williams <dcbw@redhat.com> Tested-by: H. Nikolaus Schaller <hns@goldelico.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06ACPI / Battery: Add a _BIX quirk for NEC LZ750/LSLan Tianyu
The AML method _BIX of NEC LZ750/LS returns a broken package which skips the first member "Revision" (ACPI 5.0, Table 10-234). Add a quirk for this machine to skip member "Revision" during parsing the package returned by _BIX. Reference: https://bugzilla.kernel.org/show_bug.cgi?id=67351 Reported-and-tested-by: Francisco Castro <fcr@adinet.com.uy> Cc: 3.8+ <stable@vger.kernel.org> " 3.8+ Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-01-06intel_pstate: Add X86_FEATURE_APERFMPERF to cpu match parameters.Dirk Brandewie
KVM environments do not support APERF/MPERF MSRs. intel_pstate cannot operate without these registers. The previous validity checks in intel_pstate_msrs_not_valid() are insufficent in nested KVMs. References: https://bugzilla.redhat.com/show_bug.cgi?id=1046317 Signed-off-by: Dirk Brandewie <dirk.j.brandewie@intel.com> Cc: All applicable <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-01-06isdn: Drop big endian cpp checks from telespci and hfc_pci driversGuenter Roeck
With arm:allmodconfig, building the Teles PCI driver fails with telespci.c:294:2: error: #error "not running on big endian machines now" Similar, building the driver for HFC PCI-Bus cards fails with hfc_pci.c:1647:2: error: #error "not running on big endian machines now" Remove the big endian cpp check from both drivers to fix the build errors. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: David S. Miller <davem@davemloft.net>
