For a while now, we've postponed CRC-checking of data nodes to be done
by the GC thread, instead of being done while the user is waiting for
mount to finish. The GC thread would iterate through all the inodes on
the system and check each of their data nodes. It would skip over inodes
which had already been used or were already being read in by
read_inode(), because their data nodes would have been examined anyway.
However, we could sometimes reach the end of the for-each-inode loop and
still have some unchecked space left, if an inode we'd skipped was
_still_ in the process of being read. This fixes that race by actually
waiting for read_inode() to finish rather than just moving on.
Thanks to Ladislav Michl for coming up with a reproducible test case and
helping to track it down.
Fix printk format warnings in jffs2.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Fix printk format warning:
drivers/mtd/devices/m25p80.c:189: warning: format '%zd' expects type
'signed size_t', but argument 6 has type 'u_int32_t'
I just hit the following error and warning :
drivers/mtd/maps/nettel.c: In function `nettel_init':
drivers/mtd/maps/nettel.c:418: error: `ROOT_DEV' undeclared (first use in this function)
drivers/mtd/maps/nettel.c:418: error: (Each undeclared identifier is reported only once
drivers/mtd/maps/nettel.c:418: error: for each function it appears in.)
drivers/mtd/maps/nettel.c:418: warning: implicit declaration of function `MKDEV'
make[3]: *** [drivers/mtd/maps/nettel.o] Error 1
make[2]: *** [drivers/mtd/maps] Error 2
make[1]: *** [drivers/mtd] Error 2
The patch fixes the missing ROOT_DEV declaration by including linux/root_dev.h
and fixes the implicit declaration of MKDEV by including linux/kdev_t.h .
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Commit e56d090310d7625ecb43a1eeebd479f04affb48b
[PATCH] RCU signal handling
made this BUG_ON() unsafe. This code runs under ->siglock,
while switch_exec_pids() takes tasklist_lock.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild:
kconfig: fix typo in change count initialization
kconfig: recenter menuconfig
kconfig: revert conf behaviour change
kconfig: fix default value for choice input
kbuild: fix NULL dereference in scripts/mod/modpost.c
kbuild: fix mode of checkstack.pl and other files.
kbuild: rebuild initramfs if content of initramfs changes
kbuild: properly pass options to hostcc when doing make O=..
kbuild: modules_install for external modules must not remove existing modules
kbuild: fix make dir/
ver_linux: don't print reiser4progs version if none found
kbuild: mips: fix sed regexp to generate asm-offset.h
kbuild: fix building single targets with make O=.. single-target
kbuild: use relative path to -I
kbuild: fix unneeded rebuilds in drivers/net/chelsio after moving source tree
kbuild: fix unneeded rebuilds in drivers/media/video after moving source tree
kbuild: fix garbled text in modules.txt
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] Prefetch mmap_sem in ia64_do_page_fault()
[IA64] Failure to resume after INIT in user space
[IA64] Pass more data to the MCA/INIT notify_die hooks
[IA64] always map VGA framebuffer UC, even if it supports WB
[IA64] fix bug in ia64 __mutex_fastpath_trylock
[IA64] for_each_possible_cpu: ia64
[IA64] update HP CSR space discovery via ACPI
[IA64] Wire up new syscalls {set,get}_robust_list
[IA64] 'msg' may be used uninitialized in xpc_initiate_allocate()
[IA64] Wire up new syscall sync_file_range()
In vsyscall function do_vgettimeofday(), some functions are declared as
inlined, which is a hint for gcc to compile the function inlined but it
not forced. Sometimes compiler does not compile the function as
inlined, so here inline is replaced by __always_inline prefix.
It does not happen in gcc compiler actually, but it possibly happens.
Signed-off-by: bibo mao <bibo.mao@intel.com>
Surprising that it still worked at all with this - yes it was
tested.
Signed-off-by: Andi Kleen <ak@suse.de>
Nobody should pass NULL here. Could in theory make it a BUG,
but the NULL pointer oops will do as well.
It's not actually needed and would break non power of two number
of cores.
Follows similar earlier x86-64 patch.
Commit c818a18146997d1356a4840b0c01f1168c16c8a4 didn't do the expected
thing. This fix will remove the additional sync(cpuid) before RDTSC on
Intel platforms..
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
As pointed out by Linus it is useless now because entry.S should
handle it correctly in all cases.
When nolapic was passed or the local APIC was disabled
for another reason ACPI would still parse the IO-APICs
until these were explicitely disabled with noapic.
Usually this resulted in a non booting configuration unless
"nolapic noapic" was used.
I also disabled the local APIC parsing in this case, although
that's only cosmetic (suppresses a few printks)
This hopefully makes nolapic work in all cases.
Cc: Len Brown <len.brown@intel.com>
* 'splice' of git://brick.kernel.dk/data/git/linux-2.6-block:
[PATCH] vfs: add splice_write and splice_read to documentation
[PATCH] Remove sys_ prefix of new syscalls from __NR_sys_*
[PATCH] splice: warning fix
[PATCH] another round of fs/pipe.c cleanups
[PATCH] splice: comment styles
[PATCH] splice: add Ingo as addition copyright holder
[PATCH] splice: unlikely() optimizations
[PATCH] splice: speedups and optimizations
[PATCH] pipe.c/fifo.c code cleanups
[PATCH] get rid of the PIPE_*() macros
[PATCH] splice: speedup __generic_file_splice_read
[PATCH] splice: add direct fd <-> fd splicing support
[PATCH] splice: add optional input and output offsets
[PATCH] introduce a "kernel-internal pipe object" abstraction
[PATCH] splice: be smarter about calling do_page_cache_readahead()
[PATCH] splice: optimize the splice buffer mapping
[PATCH] splice: cleanup __generic_file_splice_read()
[PATCH] splice: only call wake_up_interruptible() when we really have to
[PATCH] splice: potential !page dereference
[PATCH] splice: mark the io page as accessed
Since the arrays are declared as in_urbs[N_IN_URB]
and out_urbs[N_OUT_URB], both for loops go one
over the end of the array. This fixes coverity id #555.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de>
Signed-Off-By: Linus Torvalds <torvalds@osdl.org>
Since the visual STATIC_PSEUDOCOLOR has a read-only colormap, use logos
with 16 colors only since these logos use the console palette. This has a
higher likelihood that the logo will display correctly.
Signed-of-by: Antonino Daplas <adaplas@pol.net>
Bugzilla Bug 6299:
A pixel size of 8 bits produces wrong logo colors in x86_64.
The driver has 2 methods for setting the color map, using the protected
mode interface provided by the video BIOS and directly writing to the VGA
registers. The former is not supported in x86_64 and the latter is enabled
only in i386.
Fix by enabling the latter method in x86_64 only if supported by the BIOS.
If both methods are unsupported, change the visual of vesafb to
STATIC_PSEUDOCOLOR.
Signed-off-by: Antonino Daplas <adaplas@pol.net>
sparc32 lacks vga.h, so lots of fbdev drivers won't compile. There are no
sparc32 systems with PCI slots, so it's a bit moot.
The patch gives sparc32 a copy of the sparc64 vga.h. It fixes sparc32
allmodconfig without mucking up fbdev Kconfig and gives us wider compile
coverage.
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Acked-by: "David S. Miller" <davem@davemloft.net>
Heaps of build errors - disable it to keep sparc32 allmodconfig happy.
Fix an obvious of-by-one error spotted by the Coverity checker.
Keep unused openowners around for at least one lease period, to avoid the need
for as many open confirmations and to allow handing out more delegations.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
Signed-off-by: Neil Brown <neilb@suse.de>
It's very easy for the server to DOS itself by just giving out too many
delegations.
For now we just solve the problem with a dumb hard limit. Eventually we'll
want a smarter policy.
We should be shutting down rpciod for the callback channel when we shut down
the server.
Also note that we do rpciod_up() and create the callback client *before*
setting cb_set--the cb_set only determines whether the initial null was
succesful. So cb_set is not a reliable determiner of whether we need to clean
up, only cb_client is.
Some obvious cleanup.
We need to make sure the laundromat work doesn't reschedule itself just when
we try to cancel it. Also, we shouldn't be waiting for it to finish running
while holding the state lock, as that's a potential deadlock.
Every caller of svc_take_page ignores its return value and assumes it
succeeded. So just WARN() instead of returning an ignored error. This would
have saved some time debugging a recent nfsd4 problem.
If there are still failure cases here, then the result is probably that we
overwrite an earlier part of the reply while xdr-encoding.
While the corrupted reply is a nasty bug, it would be worse to panic here and
create the possibility of a remote DOS; hence WARN() instead of BUG().
Cc: Ingo Oeser <ioe-lkml@rameria.de>
We're using svc_take_page here to get another page for the tail in case one
wasn't already allocated. But there isn't always guaranteed to be another
page available.
Also fix a typo that made us check the tail buffer for space when we meant to
be checking the head buffer.
Fix corruption on readdir encoding with 64k pages.
In v4 we grab an extra page just for the padding of returned data. The
formula that the rpc server uses to allocate pages for the response doesn't
take into account this extra page.
Instead of adjusting those formulae, we adopt the same solution as v2 and v3,
and put the "tail" data in the same page as the "head" data.
Since nfsd_setuser() is already called from any operation that uses the
current filehandle (because it's called from fh_verify), there's no reason to
call it from putrootfh.
Signed-off-by: Andy Adamson <andros@citi.umich.edu>
In addition to setting the processes filesystem id's, nfsd_setuser also
modifies the value of the rq_cred which stores the id's that originally came
from the rpc call, for example to reflect root squashing.
There's no real reason to do that--the only case where rqstp->rq_cred is
actually used later on is in the NFSv4 SETCLIENTID/SETCLIENTID_CONFIRM
operations, and there the results are the opposite of what we want--those two
operations don't deal with the filesystem at all, they only record the
credentials used with the rpc call for later reference (so that we may require
the same credentials be used on later operations), and the credentials
shouldn't vary just because there was or wasn't a previous operation in the
compound that referred to some export
This fixes a bug which caused mounts from Solaris clients to fail.
Export a directory that does not exist:
exportfs -orw,fsid=0,insecure,no_subtree_check client:/home/NFS4
Try to mount from client with nfs4. Mount hangs (I'm not sure why -
that's another issue).
While client is hung, back on server
mkdir /home/NFS4
The server panics in dput. I traced the problem back to svc_export_parse()
calling path_release() even though path_lookup() failed (it happens to fill in
the nameidata structure with a negative dentry - so the test after out:
succeeds).
After patching, an recreating the problem, the client mount still takes some
time before finally exiting with a message "couldn't read superblock".
Here is a simple patch to resolve this issue:
Signed-off-by: Frank Filz <ffilzlnx@us.ibm.com>
We should be using the length from the second vfs_getxattr, in case it
changed. (Note: there's still a small race here; we could end up returning
-ENOMEM if the length increased between the first and second call. I don't
know whether it's worth spending a lot of effort to fix that.)
This makes XFS ACLs usable on NFS exports, which they currently aren't, since
XFS appears to be returning a too-large value for vfs_getxattr() when it's
passed a NULL buffer. So there's probably an XFS bug here too, though since
getxattr with a NULL buffer is usually used to decide how much memory to
allocate, it may be a fairly harmless bug in most cases.
We're returning -1 in a few places in the NFSv4<->POSIX acl translation code
where we could return a reasonable error.
Also allows some minor simplification elsewhere.
this fixes coverity id #3. Coverity detected dead code, since the == -1
comparison only returns 0 or 1 to error. Therefore the if ( error < 0 )
statement was always false. Seems that this was an if( error = nfs4... )
statement some time ago, which got broken during cleanup.
Cc: Marc Eshel <eshel@almaden.ibm.com>
Cc: Andy Adamson <andros@citi.umich.edu>
Cc: J. Bruce Fields <bfields@citi.umich.edu>
Cc: Neil Brown <neilb@suse.de>
Use the fl_lmops field to identify which locks are ours, instead of trying to
look them up in our private hash. This is safer and more efficient.
Earlier versions of this patch used a lock flag instead, but Trond pointed out
that adding a new flag for each lock manager wasn't going to scale well, and
suggested this approach instead; a separate patch converts lockd to using
fl_lmops in the same way.
In the NFSv4 case this looks like a bit of a hack, since the NFSv4 server
isn't currently actually defining a lock_manager_operations struct, so we end
up defining one *just* to serve as a cookie to identify our locks.
But it works, and we actually do expect to start using the
lock_manager_operations at some point anyway.
Signed-off-by: Marc Eshel <eshel@almaden.ibm.com>
NFSd makes sure there is enough space to hold the maximum possible reply
before accepting a request. The units for this maximum is (4byte) words.
However in three places, particularly for read request, the number given is
a number of bytes.
This means too much space is reserved which is slightly wasteful.
This is the sort of patch that could uncover a deeper bug, and it is not
critical, so it would be best for it to spend a while in -mm before going
in to mainline.
(akpm: target 2.6.17-rc2, 2.6.16.3 (approx))
Discovered-by: "Eivind Sarto" <ivan@kasenna.com>
Cc: <stable@kernel.org>
CRC_CCITT is an internal helper function that should be select'ed.
Acked-by: Tilman Schmidt <tilman@imap.cc>
Fix a memory leak spotted by the Coverity checker if
(!try_module_get(owner)).
- make the needlessly global gigaset_get_cs_by_tty() static
- remove the unused EXPORT_SYMBOL_GPL(gigaset_debugdrivers)
With Hansjoerg Lipp <hjlipp@web.de>
Replace some atomic_t variables in the Gigaset drivers by non-atomic ones,
using spinlocks instead to assure atomicity, as proposed in discussions on the
linux-kernel mailing list.
Signed-off-by: Hansjoerg Lipp <hjlipp@web.de>
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
Cc: Karsten Keil <kkeil@suse.de>
Add a README file for the Siemens Gigaset drivers to the Documentation/isdn
directory.
Remove four unnecessary forward function declarations and an obsolete E-mail
address from the Siemens Gigaset drivers.
__skb_put()
Remove the private version of __skb_put() from the Siemens Gigaset drivers.
Convert the semaphores used by the Gigaset drivers to mutexes.
Eliminate the from_user argument from a debugging function, thus easing the
job of sparse.
Uninline a function which was slightly too big to warrant inlining.
