There's nothing in percpu.h that requires an explicit inclusion of
string.h.
Following an experimental deletion of the unnecessary directive
#include <linux/slab.h>
from the header file <linux/percpu.h>, these files under kernel/ were exposed
as needing to include one of <linux/slab.h> or <linux/gfp.h>, so explicit
includes were added where necessary.
This can be triggered with root help only, but...
Register the ":text:E::txt::/root/cat.txt:' rule in binfmt_misc (by root) and
try launching the cat.txt file (by anyone) :) The result is - the endless
recursion in the load_misc_binary -> open_exec -> load_misc_binary chain and
stack overflow.
There's a similar problem with binfmt_script, and there's a sh_bang memner on
linux_binprm structure to handle this, but simply raising this in binfmt_misc
may break some setups when the interpreter of some misc binaries is a script.
So the proposal is to turn sh_bang into a bit, add a new one (the misc_bang)
and raise it in load_misc_binary. After this, even if we set up the misc ->
script -> misc loop for binfmts one of them will step on its own bang and
exit.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
From the POV of synchronization, there should be no need to call
wake_up_process() with the 'kthread_create_lock' being held.
Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Andy Whitcroft <apw@shadowen.org>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
powerpc:
fs/coda/coda_linux.c: In function 'coda_iattr_to_vattr':
fs/coda/coda_linux.c:137: warning: large integer implicitly truncated to unsigned type
Cc: Jan Harkes <jaharkes@cs.cmu.edu>
module_init&module_exit
Replace init_module and cleanup_module with static functions and
module_init/module_exit.
Signed-off-by: Jon Schindler <jkschind@gmail.com>
SysRQ-P is not always useful on SMP systems, since it usually ends up showing
the backtrace of a CPU that is doing just fine, instead of the backtrace of
the CPU that is having problems.
This patch adds SysRQ show-all-cpus(L), which shows the backtrace of every
active CPU in the system. It skips idle CPUs because some SMP systems are
just too large and we already know what the backtrace of the idle task looks
like.
Signed-off-by: Rik van Riel <riel@redhat.com>
Randy Dunlap <randy.dunlap@oracle.com>
Cc: <lwoodman@redhat.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Doug Warzecha <Douglas_Warzecha@dell.com>
Cc: Matt Domsch <Matt_Domsch@dell.com>
Add a proper extern for late_time_init in include/linux/init.h
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: john stultz <johnstul@us.ibm.com>
I noticed that 2.6.24.2 calculates bprm->argv_len at do_execve(). But it
doesn't update bprm->argv_len after "remove_arg_zero() +
copy_strings_kernel()" at load_script() etc.
audit_bprm() is called from search_binary_handler() and
search_binary_handler() is called from load_script() etc. Thus, I think the
condition check
if (bprm->argv_len > (audit_argv_kb << 10))
return -E2BIG;
in audit_bprm() might return wrong result when strlen(removed_arg) !=
strlen(spliced_args). Why not update bprm->argv_len at load_script() etc. ?
By the way, 2.6.25-rc3 seems to not doing the condition check. Is the field
bprm->argv_len no longer needed?
Cc: Ollie Wild <aaw@google.com>
Remove the macro get_personality, use ->personality instead.
Cc: Christoph Hellwig <hch@infradead.org
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Bryan Wu <bryan.wu@analog.com>
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
Make it consistent with the rest of the header.
Signed-off-by: jan sonnek <xsonnek@gmail.com>
Cc: Jiri Slaby <jirislaby@gmail.com>
Return ERR even if there are pending data, but hw is not running. Do not
decrement count in poll, do it in ioctl, where data are actually read.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Openhaptics uses pointers in _IOC() macros, implement compat for them. Also
add _IOC alternatives which are not 32/64 bit dependent (structures
passed through aren't yet) -- libphantom will use them.
Add a proper prototype for __do_softirq() in include/linux/interrupt.h
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no
side-effects to allow a definition of BUG_ON that drops the code completely.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@ disable unlikely @ expression E,f; @@
if (<... f(...) ...>) { BUG(); }
- if (unlikely(E)) { BUG(); }
+ BUG_ON(E);
@@ expression E,f; @@
- if (E) { BUG(); }
+ BUG_ON(E);
// </smpl>
Cc: Roman Zippel <zippel@linux-m68k.org>
Almost all implementations of pci_iomap() in the kernel, including the generic
lib/iomap.c one, copies the content of a struct resource into unsigned long's
which will break on 32 bits platforms with 64 bits resources.
This fixes all definitions of pci_iomap() to use resource_size_t. I also
"fixed" the 64bits arch for consistency.
Cc: <linux-arch@vger.kernel.org>
print_fn_descriptor_symbol() prints the address if we don't have a symbol, so
no need to print both.
Also, combine printing return value with elapsed time. Changes this:
Calling initcall 0xc05b7a70: pci_mmcfg_late_insert_resources+0x0/0x50()
initcall 0xc05b7a70: pci_mmcfg_late_insert_resources+0x0/0x50() returned 1.
initcall 0xc05b7a70 ran for 0 msecs: pci_mmcfg_late_insert_resources+0x0/0x50()
initcall at 0xc05b7a70: pci_mmcfg_late_insert_resources+0x0/0x50(): returned with error code 1
to this:
calling pci_mmcfg_late_insert_resources+0x0/0x50()
initcall pci_mmcfg_late_insert_resources+0x0/0x50() returned 1 after 0 msecs
initcall pci_mmcfg_late_insert_resources+0x0/0x50() returned with error code 1
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
lib/inflate.c (inflate_dynamic): Don't deref NULL upon failed malloc.
Signed-off-by: Jim Meyering <meyering@redhat.com>
fs/hfsplus/options.c (hfsplus_parse_options): Handle match_strdup failure.
fs/hfs/super.c (parse_options): Handle match_strdup failure, twice.
fs/affs/super.c (parse_options): Remove useless initialization. Handle
struct char_device_struct::fops is no longer used: remove it.
Signed-off-by: Jiri Olsa <olsajiri@gmail.com>
Cc: Greg KH <greg@kroah.com>
Remove unused leftovers of debugging functions. 2.6.25 material.
Reported-by: Adrian Bunk <bunk@kernel.org>
fs/autofs4/root.c:536:23: warning: symbol 'ino' shadows an earlier one
fs/autofs4/root.c:510:22: originally declared here
There is no need to redeclare, we are at the end of the loop and in
the next iteration of the loop, ino will be reset.
Acked-by: Ian Kent <raven@themaw.net>
Remove the no longer used mca_is_adapter_used().
Cc: James Bottomley <James.Bottomley@steeleye.com>
I have not yet seen anyone saying he has a reasonable use case for using
BINFMT_FLAT modular on his embedded device.
Considering that fs/binfmt_flat.c even lacks a MODULE_LICENSE() I really doubt
there is any, and this patch therefore makes BINFMT_FLAT a bool.
Acked-by: Bryan Wu <cooloney.lkml@gmail.com>
cont_expand_zero() can become static.
Remove the obsolete and no longer used generic_commit_write().
Every file should include the headers containing the prototypes for its global
functions (in this case for sys_timerfd_*()).
Cc: Davide Libenzi <davidel@xmailserver.org>
16 kB is often no longer enough for a normal boot of an UP system.
And even less when people e.g. use suspend.
17 seems to be a more reasonable default for current kernels on current
hardware (it's just the default, anyone who is memory limited can still lower
it).
Make the following needlessly global functions static:
- __put_ioctx()
- lookup_ioctx()
- io_submit_one()
Cc: Zach Brown <zach.brown@oracle.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Cc: Badari Pulavarty <pbadari@us.ibm.com>
- drop_pagecache()
- drop_slab()
- writeback_acquire()
- writeback_release()
Make the needlessly global vfs_ioctl() static.
Acked-by: Christoph Hellwig <hch@infradead.org>
Make the needlessly global __put_super() static.
Move the extern declarations of several structs to vxfs_extern.h
Add proper extern declarations for two structs in fs/hfsplus/hfsplus_fs.h
- internal.h shouldn't duplicate the extern declaration for
ramfs_file_operations already in include/linux/ramfs.h
- file-mmu.c needs two #include's for seeing the extern declarations
of it's global struct's
Fix following warnings:
WARNING: vmlinux.o(.text+0xc60): Section mismatch in reference from the function kvm_init() to the function .cpuinit.text:register_cpu_notifier()
WARNING: vmlinux.o(.text+0x33869a): Section mismatch in reference from the function xfs_icsb_init_counters() to the function .cpuinit.text:register_cpu_notifier()
WARNING: vmlinux.o(.text+0x5556a1): Section mismatch in reference from the function acpi_processor_install_hotplug_notify() to the function .cpuinit.text:register_cpu_notifier()
WARNING: vmlinux.o(.text+0xfe6b28): Section mismatch in reference from the function cpufreq_register_driver() to the function .cpuinit.text:register_cpu_notifier()
register_cpu_notifier() are only really defined when HOTPLUG_CPU is enabled.
So references to the function are OK.
Annotate it with __ref so we do not get warnings from callers and do not get
warnings for the functions/data used by register_cpu_notifier().
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Cc: Gautham R Shenoy <ego@in.ibm.com>
WARNING: vmlinux.o(.text+0x75c8d): Section mismatch in reference from the function take_cpu_down() to the variable .cpuinit.data:cpu_chain
WARNING: vmlinux.o(.text+0x75d2a): Section mismatch in reference from the function _cpu_down() to the variable .cpuinit.data:cpu_chain
WARNING: vmlinux.o(.text+0x75d4d): Section mismatch in reference from the function _cpu_down() to the variable .cpuinit.data:cpu_chain
WARNING: vmlinux.o(.text+0x75de4): Section mismatch in reference from the function _cpu_down() to the variable .cpuinit.data:cpu_chain
WARNING: vmlinux.o(.text+0x75e33): Section mismatch in reference from the function _cpu_down() to the variable .cpuinit.data:cpu_chain
cpu_down is only used from code surrounded by HOTPLUG_CPU so any references to
__cpuinit is OK.
Add a few __ref to tech modpost to ignore the references.
This is just papering over the fact that the cpu hotplug code is fragile with
respect to use of HOTPLUG_CPU and in many cases rely on __cpuinit to get rid
of code when HOTPLUG_CPU is not enabled. For now this is the least invasive
change.
Fix following warning:
WARNING: vmlinux.o(.text+0x75f4e): Section mismatch in reference from the function unregister_cpu_notifier() to the variable .cpuinit.data:cpu_chain
We know that unregister_cpu_notifier is using HOTPLUG_CPU
stuff - so ignore these references.
Annotating unregister_cpu_notifier had been another option
but this caused far more warnings since not all callers were
annotated __cpuinit.
WARNING: vmlinux.o(.data+0x5020): Section mismatch in reference from the variable cpu_vsyscall_notifier_nb.12876 to the function .cpuinit.text:cpu_vsyscall_notifier()
WARNING: vmlinux.o(.data+0x9ce0): Section mismatch in reference from the variable profile_cpu_callback_nb.17654 to the function .devinit.text:profile_cpu_callback()
WARNING: vmlinux.o(.data+0xd380): Section mismatch in reference from the variable workqueue_cpu_callback_nb.15004 to the function .devinit.text:workqueue_cpu_callback()
WARNING: vmlinux.o(.data+0x11d00): Section mismatch in reference from the variable relay_hotcpu_callback_nb.19626 to the function .cpuinit.text:relay_hotcpu_callback()
WARNING: vmlinux.o(.data+0x12970): Section mismatch in reference from the variable cpu_callback_nb.24694 to the function .devinit.text:cpu_callback()
WARNING: vmlinux.o(.data+0x3fee0): Section mismatch in reference from the variable percpu_counter_hotcpu_callback_nb.10903 to the function .cpuinit.text:percpu_counter_hotcpu_callback()
WARNING: vmlinux.o(.data+0x74ce0): Section mismatch in reference from the variable topology_cpu_callback_nb.12506 to the function .cpuinit.text:topology_cpu_callback()
Functions used as argument are by definition only used in HOTPLUG_CPU
situations so thay are annotated __cpuinit. Annotate the static variable used
by hotcpu_register with __cpuinitdata to match this definition.
Use link as the variable name to avoid shadowing the arg.
fs/befs/linuxvfs.c:492:8: warning: symbol 'p' shadows an earlier one
fs/befs/linuxvfs.c:488:77: originally declared here
Cc: "Sergey S. Kostyliov" <rathamahata@php4.ru>
coda_unlink, coda_rmdir, coda_readdir can all be static, the forward
declarations already were.
Add the RUSAGE_THREAD option for the getrusage system call. This is
essentially Roland's patch from http://lkml.org/lkml/2008/1/18/589, but the
line about RUSAGE_LWP line has been removed, as suggested by Ulrich and
Christoph.
Signed-off-by: Roland McGrath <roland@redhat.com>
Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Ulrich Drepper <drepper@redhat.com>
fs/adfs/dir_f.c:126:4: warning: do-while statement is not a compound statement
The kernel is sent to tainted within the warn_on_slowpath() function, and
whenever a warning occurs the new taint flag 'W' is set. This is useful to
know if a warning occurred before a BUG by preserving the warning as a flag
in the taint state.
This does not work on architectures where WARN_ON has its own definition.
These archs are:
1. s390
2. superh
3. avr32
4. parisc
The maintainers of these architectures have been added in the Cc: list
in this email to alert them to the situation.
The documentation in oops-tracing.txt has been updated to include the
new flag.
Signed-off-by: Nur Hussein <nurhussein@gmail.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
They're defined later on in the same file with bodies and nothing in
between needs them.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Jan Harkes <jaharkes@cs.cmu.edu>
