2011-07-14x86-64: Move vread_tsc and vread_hpet into the vDSOAndy Lutomirski
The vsyscall page now consists entirely of trap instructions. Cc: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andy Lutomirski <luto@mit.edu> Link: http://lkml.kernel.org/r/637648f303f2ef93af93bae25186e9a1bea093f5.1310639973.git.luto@mit.edu Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-13clocksource: Replace vread with generic arch dataAndy Lutomirski
The vread field was bloating struct clocksource everywhere except x86_64, and I want to change the way this works on x86_64, so let's split it out into per-arch data. Cc: x86@kernel.org Cc: Clemens Ladisch <clemens@ladisch.de> Cc: linux-ia64@vger.kernel.org Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andy Lutomirski <luto@mit.edu> Link: http://lkml.kernel.org/r/3ae5ec76a168eaaae63f08a2a1060b91aa0b7759.1310563276.git.luto@mit.edu Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-13x86-64: Add --no-undefined to vDSO buildAndy Lutomirski
This gives much nicer diagnostics when something goes wrong. It's supported at least as far back as binutils 2.15. Signed-off-by: Andy Lutomirski <luto@mit.edu> Link: http://lkml.kernel.org/r/de0b50920469ff6359c529526e7639fdd36fa83c.1310563276.git.luto@mit.edu Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-13x86-64: Allow alternative patching in the vDSOAndy Lutomirski
This code is short enough and different enough from the module loader that it's not worth trying to share anything. Signed-off-by: Andy Lutomirski <luto@mit.edu> Link: http://lkml.kernel.org/r/e73112e4381fff29e31b882c2d0856822edaea53.1310563276.git.luto@mit.edu Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-13x86: Make alternative instruction pointers relativeAndy Lutomirski
This save a few bytes on x86-64 and means that future patches can apply alternatives to unrelocated code. Signed-off-by: Andy Lutomirski <luto@mit.edu> Link: http://lkml.kernel.org/r/ff64a6b9a1a3860ca4a7b8b6dc7b4754f9491cd7.1310563276.git.luto@mit.edu Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-13x86-64: Improve vsyscall emulation CS and RIP handlingAndy Lutomirski
Three fixes here: - Send SIGSEGV if called from compat code or with a funny CS. - Don't BUG on impossible addresses. - Add a missing local_irq_disable. This patch also removes an unused variable. Signed-off-by: Andy Lutomirski <luto@mit.edu> Link: http://lkml.kernel.org/r/6fb2b13ab39b743d1e4f466eef13425854912f7f.1310563276.git.luto@mit.edu Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-06-07x86-64: Emulate legacy vsyscallsAndy Lutomirski
There's a fair amount of code in the vsyscall page. It contains a syscall instruction (in the gettimeofday fallback) and who knows what will happen if an exploit jumps into the middle of some other code. Reduce the risk by replacing the vsyscalls with short magic incantations that cause the kernel to emulate the real vsyscalls. These incantations are useless if entered in the middle. This causes vsyscalls to be a little more expensive than real syscalls. Fortunately sensible programs don't use them. The only exception is time() which is still called by glibc through the vsyscall - but calling time() millions of times per second is not sensible. glibc has this fixed in the development tree. This patch is not perfect: the vread_tsc and vread_hpet functions are still at a fixed address. Fixing that might involve making alternative patching work in the vDSO. Signed-off-by: Andy Lutomirski <luto@mit.edu> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: richard -rw- weinberger <richard.weinberger@gmail.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Cc: Andi Kleen <andi@firstfloor.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: Valdis.Kletnieks@vt.edu Cc: pageexec@freemail.hu Link: http://lkml.kernel.org/r/e64e1b3c64858820d12c48fa739efbd1485e79d5.1307292171.git.luto@mit.edu [ Removed the CONFIG option - it's simpler to just do it unconditionally. Tidied up the code as well. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-06x86-64: Fill unused parts of the vsyscall page with 0xccAndy Lutomirski
Jumping to 0x00 might do something depending on the following bytes. Jumping to 0xcc is a trap. So fill the unused parts of the vsyscall page with 0xcc to make it useless for exploits to jump there. Signed-off-by: Andy Lutomirski <luto@mit.edu> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: richard -rw- weinberger <richard.weinberger@gmail.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Cc: Andi Kleen <andi@firstfloor.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: Valdis.Kletnieks@vt.edu Cc: pageexec@freemail.hu Link: http://lkml.kernel.org/r/ed54bfcfbe50a9070d20ec1edbe0d149e22a4568.1307292171.git.luto@mit.edu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-06x86-64: Remove vsyscall number 3 (venosys)Andy Lutomirski
It just segfaults since April 2008 (a4928cff), so I'm pretty sure that nothing uses it. And having an empty section makes the linker script a bit fragile. Signed-off-by: Andy Lutomirski <luto@mit.edu> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: richard -rw- weinberger <richard.weinberger@gmail.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Cc: Andi Kleen <andi@firstfloor.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: Valdis.Kletnieks@vt.edu Cc: pageexec@freemail.hu Link: http://lkml.kernel.org/r/4a4abcf47ecadc269f2391a313576fe6d06acef7.1307292171.git.luto@mit.edu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-05x86-64: Map the HPET NXAndy Lutomirski
Currently the HPET mapping is a user-accessible syscall instruction at a fixed address some of the time. A sufficiently determined hacker might be able to guess when. Signed-off-by: Andy Lutomirski <luto@mit.edu> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: richard -rw- weinberger <richard.weinberger@gmail.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Cc: Andi Kleen <andi@firstfloor.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: Valdis.Kletnieks@vt.edu Cc: pageexec@freemail.hu Link: http://lkml.kernel.org/r/ab41b525a4ca346b1ca1145d16fb8d181861a8aa.1307292171.git.luto@mit.edu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-05x86-64: Remove kernel.vsyscall64 sysctlAndy Lutomirski
It's unnecessary overhead in code that's supposed to be highly optimized. Removing it allows us to remove one of the two syscall instructions in the vsyscall page. The only sensible use for it is for UML users, and it doesn't fully address inconsistent vsyscall results on UML. The real fix for UML is to stop using vsyscalls entirely. Signed-off-by: Andy Lutomirski <luto@mit.edu> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: richard -rw- weinberger <richard.weinberger@gmail.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Cc: Andi Kleen <andi@firstfloor.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: Valdis.Kletnieks@vt.edu Cc: pageexec@freemail.hu Link: http://lkml.kernel.org/r/973ae803fe76f712da4b2740e66dccf452d3b1e4.1307292171.git.luto@mit.edu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-05x86-64: Give vvars their own pageAndy Lutomirski
Move vvars out of the vsyscall page into their own page and mark it NX. Without this patch, an attacker who can force a daemon to call some fixed address could wait until the time contains, say, 0xCD80, and then execute the current time. Signed-off-by: Andy Lutomirski <luto@mit.edu> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: richard -rw- weinberger <richard.weinberger@gmail.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Cc: Andi Kleen <andi@firstfloor.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: Valdis.Kletnieks@vt.edu Cc: pageexec@freemail.hu Link: http://lkml.kernel.org/r/b1460f81dc4463d66ea3f2b5ce240f58d48effec.1307292171.git.luto@mit.edu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-05x86-64: Document some of entry_64.SAndy Lutomirski
Signed-off-by: Andy Lutomirski <luto@mit.edu> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: richard -rw- weinberger <richard.weinberger@gmail.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Cc: Andi Kleen <andi@firstfloor.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: Valdis.Kletnieks@vt.edu Cc: pageexec@freemail.hu Link: http://lkml.kernel.org/r/fc134867cc550977cc996866129e11a16ba0f9ea.1307292171.git.luto@mit.edu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-05x86-64: Fix alignment of jiffies variableAndy Lutomirski
It's declared __attribute__((aligned(16)) but it's explicitly not aligned. This is probably harmless but it's a bit embarrassing. Signed-off-by: Andy Lutomirski <luto@mit.edu> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Jan Beulich <JBeulich@novell.com> Cc: richard -rw- weinberger <richard.weinberger@gmail.com> Cc: Mikael Pettersson <mikpe@it.uu.se> Cc: Andi Kleen <andi@firstfloor.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Louis Rilling <Louis.Rilling@kerlabs.com> Cc: Valdis.Kletnieks@vt.edu Cc: pageexec@freemail.hu Link: http://lkml.kernel.org/r/5f3bc5542e9aaa9382d53f153f54373165cdef89.1307292171.git.luto@mit.edu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] Fix oops caused by queue refcounting failure
2011-06-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits) tg3: Fix tg3_skb_error_unmap() net: tracepoint of net_dev_xmit sees freed skb and causes panic drivers/net/can/flexcan.c: add missing clk_put net: dm9000: Get the chip in a known good state before enabling interrupts drivers/net/davinci_emac.c: add missing clk_put af-packet: Add flag to distinguish VID 0 from no-vlan. caif: Fix race when conditionally taking rtnl lock usbnet/cdc_ncm: add missing .reset_resume hook vlan: fix typo in vlan_dev_hard_start_xmit() net/ipv4: Check for mistakenly passed in non-IPv4 address iwl4965: correctly validate temperature value bluetooth l2cap: fix locking in l2cap_global_chan_by_psm ath9k: fix two more bugs in tx power cfg80211: don't drop p2p probe responses Revert "net: fix section mismatches" drivers/net/usb/catc.c: Fix potential deadlock in catc_ctrl_run() sctp: stop pending timers and purge queues when peer restart asoc drivers/net: ks8842 Fix crash on received packet when in PIO mode. ip_options_compile: properly handle unaligned pointer iwlagn: fix incorrect PCI subsystem id for 6150 devices ...
2011-06-04Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-block: block: Use hlist_entry() for io_context.cic_list.first cfq-iosched: Remove bogus check in queue_fail path xen/blkback: potential null dereference in error handling xen/blkback: don't call vbd_size() if bd_disk is NULL block: blkdev_get() should access ->bd_disk only after success CFQ: Fix typo and remove unnecessary semicolon block: remove unwanted semicolons Revert "block: Remove extra discard_alignment from hd_struct." nbd: adjust 'max_part' according to part_shift nbd: limit module parameters to a sane value nbd: pass MSG_* flags to kernel_recvmsg() block: improve the bio_add_page() and bio_add_pc_page() descriptions
2011-06-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: Blackfin: strncpy: fix handling of zero lengths
2011-06-04Merge branch 'stable' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile * 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: asm-generic/unistd.h: support sendmmsg syscall tile: enable CONFIG_BUGVERBOSE
2011-06-04Merge branch 'linux-next' of git://git.infradead.org/ubifs-2.6Linus Torvalds
* 'linux-next' of git://git.infradead.org/ubifs-2.6: UBIFS: fix-up free space earlier UBIFS: intialize LPT earlier UBIFS: assert no fixup when writing a node UBIFS: fix clean znode counter corruption in error cases UBIFS: fix memory leak on error path UBIFS: fix shrinker object count reports UBIFS: fix recovery broken by the previous recovery fix UBIFS: amend ubifs_recover_leb interface UBIFS: introduce a "grouped" journal head flag UBIFS: supress false error messages
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-ktest: ktest: Ignore unset values of the minconfig in config_bisect ktest: Fix result of rebooting the kernel ktest: Fix off-by-one in config bisect result
2011-06-04Merge branch 'rmobile-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'rmobile-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: ARM: mach-shmobile: add DMAC clock definitions on SH7372 ARM: arch-shmobile: support SDHI card detection on mackerel, using a GPIO sh_mobile_meram: MERAM platform data for LCDC
2011-06-04Merge branch 'sh-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: dmaengine: shdma: fix a regression: initialise DMA channels for memcpy dmaengine: shdma: Fix up fallout from runtime PM changes. Revert "clocksource: sh_cmt: Runtime PM support" Revert "clocksource: sh_tmu: Runtime PM support" sh: Fix up asm-generic/ptrace.h fallout. sh64: Move from P1SEG to CAC_ADDR for consistent sync. sh64: asm/pgtable.h needs asm/mmu.h sh: asm/tlb.h needs linux/swap.h sh: mark DMA slave ID 0 as invalid sh: Update shmin to reflect PIO dependency. sh: arch/sh/kernel/process_32.c needs linux/prefetch.h. sh: add MMCIF runtime PM support on ecovec sh: switch ap325rxa to dynamically manage the platform camera
2011-06-04Revert "ASoC: Update cx20442 for TTY API change"Linus Torvalds
This reverts commit ed0bd2333cffc3d856db9beb829543c1dfc00982. Since we reverted the TTY API change, we should revert the ASoC update to it too. Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-04Revert "tty: make receive_buf() return the amout of bytes received"Linus Torvalds
This reverts commit b1c43f82c5aa265442f82dba31ce985ebb7aa71c. It was broken in so many ways, and results in random odd pty issues. It re-introduced the buggy schedule_work() in flush_to_ldisc() that can cause endless work-loops (see commit a5660b41af6a: "tty: fix endless work loop when the buffer fills up"). It also used an "unsigned int" return value fo the ->receive_buf() function, but then made multiple functions return a negative error code, and didn't actually check for the error in the caller. And it didn't actually work at all. BenH bisected down odd tty behavior to it: "It looks like the patch is causing some major malfunctions of the X server for me, possibly related to PTYs. For example, cat'ing a large file in a gnome terminal hangs the kernel for -minutes- in a loop of what looks like flush_to_ldisc/workqueue code, (some ftrace data in the quoted bits further down). ... Some more data: It -looks- like what happens is that the flush_to_ldisc work queue entry constantly re-queues itself (because the PTY is full ?) and the workqueue thread will basically loop forver calling it without ever scheduling, thus starving the consumer process that could have emptied the PTY." which is pretty much exactly the problem we fixed in a5660b41af6a. Milton Miller pointed out the 'unsigned int' issue. Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Reported-by: Milton Miller <miltonm@bga.com> Cc: Stefan Bigler <stefan.bigler@keymile.com> Cc: Toby Gray <toby.gray@realvnc.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-03Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into for-davem
2011-06-03UBIFS: fix-up free space earlierBen Gardiner
The free space fixup is currently initiated during mount after the call to ubifs_write_master() which results in a write to PEBs; this has been observed with the patch 'assert no fixup when writing a node' applied: Move the free space fixup on mount to before the calls to ubifs_recover_inl_heads() and ubifs_write_master(). This results in no assertions with the previously mentioned patch applied. Artem: tweaked the patch a bit Signed-off-by: Ben Gardiner <bengardiner@nanometrics> Reviewed-by: Matthew L. Creech <mlcreech@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-06-03UBIFS: intialize LPT earlierBen Gardiner
The current 'mount_ubifs()' implementation does not initialize the LPT until the the master node is marked dirty. Move the LPT initialization to before marking the master node dirty. This is a preparation for the next patch which will move the free-space-fixup check to before marking the master node dirty, because we have to fix-up the free space before doing any writes. Artem: massaged the patch and commit message. Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Reviewed-by: Matthew L. Creech <mlcreech@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-06-03UBIFS: assert no fixup when writing a nodeBen Gardiner
The current free space fixup can result in some writing to the UBI volume when the space_fixup flag is set. To catch instances where UBIFS is writing to the NAND while the space_fixup flag is set, add an assert to ubifs_write_node(). Artem: tweaked the patch, added similar assertion to the write buffer write path. Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca> Reviewed-by: Matthew L. Creech <mlcreech@gmail.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-06-03UBIFS: fix clean znode counter corruption in error casesArtem Bityutskiy
UBIFS maintains per-filesystem and global clean znode counters ('c->clean_zn_cnt' and 'ubifs_clean_zn_cnt'). It is important to maintain correct values there since the shrinker relies on 'ubifs_clean_zn_cnt'. However, in case of failures during commit the counters were corrupted. E.g., if a failure happens in the middle of 'write_index()', then some nodes in the commit list ('c->cnext') are marked as clean, and some are marked as dirty. And the 'ubifs_destroy_tnc_subtree()' frees does not retrun correct count, and we end up with non-zero 'c->clean_zn_cnt' when unmounting. This means that if we have 2 file-sytem and one of them fails, and we unmount it, 'ubifs_clean_zn_cnt' stays incorrect and confuses the shrinker. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-06-03UBIFS: fix memory leak on error pathArtem Bityutskiy
UBIFS leaks memory on error path in 'ubifs_jnl_update()' in case of write failure because it forgets to free the 'struct ubifs_dent_node *dent' object. Although the object is small, the alignment can make it large - e.g., 2KiB if the min. I/O unit is 2KiB. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: stable@kernel.org
2011-06-03UBIFS: fix shrinker object count reportsArtem Bityutskiy
Sometimes VM asks the shrinker to return amount of objects it can shrink, and we return the ubifs_clean_zn_cnt in that case. However, it is possible that this counter is negative for a short period of time, due to the way UBIFS TNC code updates it. And I can observe the following warnings sometimes: shrink_slab: ubifs_shrinker+0x0/0x2b7 [ubifs] negative objects to delete nr=-8541616642706119788 This patch makes sure UBIFS never returns negative count of objects. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: stable@kernel.org
2011-06-03Blackfin: strncpy: fix handling of zero lengthsSteven Miao
The jump to 4f will cause the NUL padding loop to run at least one time, so if string length is zero just jump to the end. Otherwise we wrongly write one NUL byte when size==0. Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-03tg3: Fix tg3_skb_error_unmap()Matt Carlson
This function attempts to free one fragment beyond the number of fragments that were actually mapped. This patch brings back the limit to the correct spot. Signed-off-by: Matt Carlson <mcarlson@broadcom.com> Tested-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02net: tracepoint of net_dev_xmit sees freed skb and causes panicKoki Sanagi
Because there is a possibility that skb is kfree_skb()ed and zero cleared after ndo_start_xmit, we should not see the contents of skb like skb->len and skb->dev->name after ndo_start_xmit. But trace_net_dev_xmit does that and causes panic by NULL pointer dereference. This patch fixes trace_net_dev_xmit not to see the contents of skb directly. If you want to reproduce this panic, 1. Get tracepoint of net_dev_xmit on 2. Create 2 guests on KVM 2. Make 2 guests use virtio_net 4. Execute netperf from one to another for a long time as a network burden 5. host will panic(It takes about 30 minutes) Signed-off-by: Koki Sanagi <sanagi.koki@jp.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02asm-generic/unistd.h: support sendmmsg syscallChris Metcalf
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-02ktest: Ignore unset values of the minconfig in config_bisectSteven Rostedt
By ignoring the unset values of the minconfig in deciding what to test in the config_bisect can cause the problem config from being tested too. Just do not test the configs that are set in the minconfig. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-02ktest: Fix result of rebooting the kernelSteven Rostedt
The command that is called that reboots the kernel may fail but the return code is not passed back to the ktest.pl script. This is because a ';' is used between the two commands and if the second command fails, only the first command's return code is returned. Using a '&&' between the two commands fixes this. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-02ktest: Fix off-by-one in config bisect resultSteven Rostedt
Because in perl the array size returned by $#arr, is the last index and not the actually size of the array, we end the config bisect early, thinking there is only one config left when there are in fact two. Thus the result has a 50% chance of picking the correct config that caused the problem. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-02Merge branch 'for-jens/xen-blkback.fixes' of ↵Jens Axboe
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen into for-linus
2011-06-02block: Use hlist_entry() for io_context.cic_list.firstPaul Bolle
list_entry() and hlist_entry() are both simply aliases for container_of(), but since io_context.cic_list.first is an hlist_node one should at least use the correct alias. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-02cfq-iosched: Remove bogus check in queue_fail pathPaul Bolle
queue_fail can only be reached if cic is NULL, so its check for cic must be bogus. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-02[SCSI] Fix oops caused by queue refcounting failureJames Bottomley
In certain circumstances, we can get an oops from a torn down device. Most notably this is from CD roms trying to call scsi_ioctl. The root cause of the problem is the fact that after scsi_remove_device() has been called, the queue is fully torn down. This is actually wrong since the queue can be used until the sdev release function is called. Therefore, we add an extra reference to the queue which is released in sdev->release, so the queue always exists. Reported-by: Parag Warudkar <parag.lkml@gmail.com> Cc: stable@kernel.org Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-06-02drivers/net/can/flexcan.c: add missing clk_putJulia Lawall
The failed_get label is used after the call to clk_get has succeeded, so it should be moved up above the call to clk_put. The failed_req labels doesn't do anything different than failed_get, so delete it. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression e1,e2; statement S; @@ e1 = clk_get@p1(...); ... when != e1 = e2 when != clk_put(e1) when any if (...) { ... when != clk_put(e1) when != if (...) { ... clk_put(e1) ... } * return@p3 ...; } else S // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02ARM: mach-shmobile: add DMAC clock definitions on SH7372Guennadi Liakhovetski
These definitions are needed to let the runtime PM subsystem turn off DMAC clocks, when it is suspended by the driver. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-02dmaengine: shdma: fix a regression: initialise DMA channels for memcpyGuennadi Liakhovetski
A recent patch has introduced a regression, where repeating a memcpy DMA test with shdma module unloading between them skips the DMA channel configuration. Fix this regression by always configuring the channel during its allocation. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-06-01net: dm9000: Get the chip in a known good state before enabling interruptsMark Brown
Currently the DM9000 driver requests the primary interrupt before it resets the chip and puts it into a known good state. This means that if the chip is asserting interrupt for some reason we can end up with a screaming IRQ that the interrupt handler is unable to deal with. Avoid this by only requesting the interrupt after we've reset the chip so we know what state it's in. This started manifesting itself on one of my boards in the past month or so, I suspect as a result of some core infrastructure changes removing some form of mitigation against bad behaviour here, even when things boot it seems that the new code brings the interface up more quickly. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01drivers/net/davinci_emac.c: add missing clk_putJulia Lawall
Go to existing error handling code at the end of the function that calls clk_put. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ expression e1,e2; statement S; @@ e1 = clk_get@p1(...); ... when != e1 = e2 when != clk_put(e1) when any if (...) { ... when != clk_put(e1) when != if (...) { ... clk_put(e1) ... } * return@p3 ...; } else S // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Kevin Hilman <khilman@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01af-packet: Add flag to distinguish VID 0 from no-vlan.Ben Greear
Currently, user-space cannot determine if a 0 tcp_vlan_tci means there is no VLAN tag or the VLAN ID was zero. Add flag to make this explicit. User-space can check for TP_STATUS_VLAN_VALID || tp_vlan_tci > 0, which will be backwards compatible. Older could would have just checked for tp_vlan_tci, so it will work no worse than before. Signed-off-by: Ben Greear <greearb@candelatech.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-01caif: Fix race when conditionally taking rtnl locksjur.brandeland@stericsson.com
Take the RTNL lock unconditionally when calling dev_close. Taking the lock conditionally may cause race conditions. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
