2013-08-29spi: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-29Merge remote-tracking branch 'spi/topic/xilinx' into spi-pdataMark Brown
2013-08-22spi: bfin-v3: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure. Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-17spi/xilinx: signedness issue checking platform_get_irq()Dan Carpenter
In xilinx_spi_probe() we use xspi->irq to store negative error codes so it has to be signed. We weren't going to use the upper bit any way so this is fine. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Simplify irq allocationMichal Simek
Use devm_request_irq() for irq allocation which simplify driver code. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Use of_property_read_u32 for reading value from nodeMichal Simek
It simplifies driver probing. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Clean ioremap callingMichal Simek
devm_ioremap_resource() automatically checks that struct resource is initialized. Also group platform_get_resource() and devm_ioremap_resource() together. And remove mem resource from struct xilinx_spi. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Remove CONFIG_OF from the driverMichal Simek
dev.of_node is in struct device all the time. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Refer to platform device as pdev in probe() and remove()Mark Brown
This is a more traditional name and makes things a bit clearer when referring to actual struct devices as we do frequently during probe(). Signed-off-by: Mark Brown <broonie@linaro.org> Acked-by: Michal Simek <michal.simek@xilinx.com>
2013-07-15spi/xilinx: Remove remains of of_platform device registrationMark Brown
In the past there used to be a separate platform device type for device tree systems so the probe and removal functions were split into generic and bus sections. Since this is no longer the case simplify the code (and remove some unprototyped exports) by factoring everything into the bus probe() and remove(). Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi/xilinx: Convert to devm_ioremap_resource()Mark Brown
Saves code and reduces the possibility of error. Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-15spi: add spi controller v3 master driver for BlackfinScott Jiang
New spi controller(version 3) is integrated into Blackfin 60x processor. Comparing to bf5xx spi controller, we support 32 bits word size and independent receive and transmit DMA channels now. Also mode 0 and 2 (CPHA = 0) can get fully supported becasue cs line may be controlled by the software. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-07-14Linux 3.11-rc1v3.11-rc1Linus Torvalds
2013-07-14Merge branch 'slab/for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux Pull slab update from Pekka Enberg: "Highlights: - Fix for boot-time problems on some architectures due to init_lock_keys() not respecting kmalloc_caches boundaries (Christoph Lameter) - CONFIG_SLUB_CPU_PARTIAL requested by RT folks (Joonsoo Kim) - Fix for excessive slab freelist draining (Wanpeng Li) - SLUB and SLOB cleanups and fixes (various people)" I ended up editing the branch, and this avoids two commits at the end that were immediately reverted, and I instead just applied the oneliner fix in between myself. * 'slab/for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux slub: Check for page NULL before doing the node_match check mm/slab: Give s_next and s_stop slab-specific names slob: Check for NULL pointer before calling ctor() slub: Make cpu partial slab support configurable slab: add kmalloc() to kernel API documentation slab: fix init_lock_keys slob: use DIV_ROUND_UP where possible slub: do not put a slab to cpu partial list when cpu_partial is 0 mm/slub: Use node_nr_slabs and node_nr_objs in get_slabinfo mm/slub: Drop unnecessary nr_partials mm/slab: Fix /proc/slabinfo unwriteable for slab mm/slab: Sharing s_next and s_stop between slab and slub mm/slab: Fix drain freelist excessively slob: Rework #ifdeffery in slab.h mm, slab: moved kmem_cache_alloc_node comment to correct place
2013-07-14slub: Check for page NULL before doing the node_match checkSteven Rostedt
In the -rt kernel (mrg), we hit the following dump: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff811573f1>] kmem_cache_alloc_node+0x51/0x180 PGD a2d39067 PUD b1641067 PMD 0 Oops: 0000 [#1] PREEMPT SMP Modules linked in: sunrpc cpufreq_ondemand ipv6 tg3 joydev sg serio_raw pcspkr k8temp amd64_edac_mod edac_core i2c_piix4 e100 mii shpchp ext4 mbcache jbd2 sd_mod crc_t10dif sr_mod cdrom sata_svw ata_generic pata_acpi pata_serverworks radeon ttm drm_kms_helper drm hwmon i2c_algo_bit i2c_core dm_mirror dm_region_hash dm_log dm_mod CPU 3 Pid: 20878, comm: hackbench Not tainted 3.6.11-rt25.14.el6rt.x86_64 #1 empty empty/Tyan Transport GT24-B3992 RIP: 0010:[<ffffffff811573f1>] [<ffffffff811573f1>] kmem_cache_alloc_node+0x51/0x180 RSP: 0018:ffff8800a9b17d70 EFLAGS: 00010213 RAX: 0000000000000000 RBX: 0000000001200011 RCX: ffff8800a06d8000 RDX: 0000000004d92a03 RSI: 00000000000000d0 RDI: ffff88013b805500 RBP: ffff8800a9b17dc0 R08: ffff88023fd14d10 R09: ffffffff81041cbd R10: 00007f4e3f06e9d0 R11: 0000000000000246 R12: ffff88013b805500 R13: ffff8801ff46af40 R14: 0000000000000001 R15: 0000000000000000 FS: 00007f4e3f06e700(0000) GS:ffff88023fd00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000000 CR3: 00000000a2d3a000 CR4: 00000000000007e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process hackbench (pid: 20878, threadinfo ffff8800a9b16000, task ffff8800a06d8000) Stack: ffff8800a9b17da0 ffffffff81202e08 ffff8800a9b17de0 000000d001200011 0000000001200011 0000000001200011 0000000000000000 0000000000000000 00007f4e3f06e9d0 0000000000000000 ffff8800a9b17e60 ffffffff81041cbd Call Trace: [<ffffffff81202e08>] ? current_has_perm+0x68/0x80 [<ffffffff81041cbd>] copy_process+0xdd/0x15b0 [<ffffffff810a2125>] ? rt_up_read+0x25/0x30 [<ffffffff8104369a>] do_fork+0x5a/0x360 [<ffffffff8107c66b>] ? migrate_enable+0xeb/0x220 [<ffffffff8100b068>] sys_clone+0x28/0x30 [<ffffffff81527423>] stub_clone+0x13/0x20 [<ffffffff81527152>] ? system_call_fastpath+0x16/0x1b Code: 89 fc 89 75 cc 41 89 d6 4d 8b 04 24 65 4c 03 04 25 48 ae 00 00 49 8b 50 08 4d 8b 28 49 8b 40 10 4d 85 ed 74 12 41 83 fe ff 74 27 <48> 8b 00 48 c1 e8 3a 41 39 c6 74 1b 8b 75 cc 4c 89 c9 44 89 f2 RIP [<ffffffff811573f1>] kmem_cache_alloc_node+0x51/0x180 RSP <ffff8800a9b17d70> CR2: 0000000000000000 ---[ end trace 0000000000000002 ]--- Now, this uses SLUB pretty much unmodified, but as it is the -rt kernel with CONFIG_PREEMPT_RT set, spinlocks are mutexes, although they do disable migration. But the SLUB code is relatively lockless, and the spin_locks there are raw_spin_locks (not converted to mutexes), thus I believe this bug can happen in mainline without -rt features. The -rt patch is just good at triggering mainline bugs ;-) Anyway, looking at where this crashed, it seems that the page variable can be NULL when passed to the node_match() function (which does not check if it is NULL). When this happens we get the above panic. As page is only used in slab_alloc() to check if the node matches, if it's NULL I'm assuming that we can say it doesn't and call the __slab_alloc() code. Is this a correct assumption? Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs stuff from Al Viro: "O_TMPFILE ABI changes, Oleg's fput() series, misc cleanups, including making simple_lookup() usable for filesystems with non-NULL s_d_op, which allows us to get rid of quite a bit of ugliness" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: sunrpc: now we can just set ->s_d_op cgroup: we can use simple_lookup() now efivarfs: we can use simple_lookup() now make simple_lookup() usable for filesystems that set ->s_d_op configfs: don't open-code d_alloc_name() __rpc_lookup_create_exclusive: pass string instead of qstr rpc_create_*_dir: don't bother with qstr llist: llist_add() can use llist_add_batch() llist: fix/simplify llist_add() and llist_add_batch() fput: turn "list_head delayed_fput_list" into llist_head fs/file_table.c:fput(): add comment Safer ABI for O_TMPFILE
2013-07-14sunrpc: now we can just set ->s_d_opAl Viro
2013-07-14cgroup: we can use simple_lookup() nowAl Viro
2013-07-14efivarfs: we can use simple_lookup() nowAl Viro
2013-07-14make simple_lookup() usable for filesystems that set ->s_d_opAl Viro
2013-07-14configfs: don't open-code d_alloc_name()Al Viro
2013-07-14__rpc_lookup_create_exclusive: pass string instead of qstrAl Viro
... and use d_hash_and_lookup() instead of open-coding it, for fsck sake... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-14rpc_create_*_dir: don't bother with qstrAl Viro
just pass the name Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-13Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform driver updates from Matthew Garrett: "Nothing overly exciting here - a couple of new drivers that don't do a great deal, along with some miscellaneous fixes and a couple of small feature enablement patches" * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: x86 platform drivers: fix gpio leak toshiba_acpi: Add dependency on SERIO_I8042 asus-nb-wmi: set wapf=4 for ASUSTeK COMPUTER INC. 1015E/U Add trivial driver to disable Intel Smart Connect Add support driver for Intel Rapid Start Technology hp-wmi: add supports for POST code error asus-wmi: control wlan-led only if wapf == 4 drivers/platform/x86/intel_ips: Convert to module_pci_driver asus-nb-wmi: ignore ALS notification key code asus-wmi: append newline to messages x86: asus-laptop: fix invalid point access x86: msi-laptop: fix memleak amilo-rfkill: Add dependency on SERIO_I8042 dell-laptop: fix error return code in dell_init() hp-wmi: Enable hotkeys on some systems
2013-07-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull second round of input updates from Dmitry Torokhov: "An update to Elantech driver to support hardware v7, fix to the new cyttsp4 driver to use proper addressing, ads7846 device tree support and nspire-keypad got a small cleanup." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: nspire-keypad - replace magic offset with define Input: elantech - fix for newer hardware versions (v7) Input: cyttsp4 - use 16bit address for I2C/SPI communication Input: ads7846 - add device tree bindings Input: ads7846 - make sure we do not change platform data
2013-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Just a bunch of small fixes and tidy ups: 1) Finish the "busy_poll" renames, from Eliezer Tamir. 2) Fix RCU stalls in IFB driver, from Ding Tianhong. 3) Linearize buffers properly in tun/macvtap zerocopy code. 4) Don't crash on rmmod in vxlan, from Pravin B Shelar. 5) Spinlock used before init in alx driver, from Maarten Lankhorst. 6) A sparse warning fix in bnx2x broke TSO checksums, fix from Dmitry Kravkov. 7) Dummy and ifb driver load failure paths can oops, fixes from Tan Xiaojun and Ding Tianhong. 8) Correct MTU calculations in IP tunnels, from Alexander Duyck. 9) Account all TCP retransmits in SNMP stats properly, from Yuchung Cheng. 10) atl1e and via-rhine do not handle DMA mapping failures properly, from Neil Horman. 11) Various equal-cost multipath route fixes in ipv6 from Hannes Frederic Sowa" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (36 commits) ipv6: only static routes qualify for equal cost multipathing via-rhine: fix dma mapping errors atl1e: fix dma mapping warnings tcp: account all retransmit failures usb/net/r815x: fix cast to restricted __le32 usb/net/r8152: fix integer overflow in expression net: access page->private by using page_private net: strict_strtoul is obsolete, use kstrtoul instead drivers/net/ieee802154: don't use devm_pinctrl_get_select_default() in probe drivers/net/ethernet/cadence: don't use devm_pinctrl_get_select_default() in probe drivers/net/can/c_can: don't use devm_pinctrl_get_select_default() in probe net/usb: add relative mii functions for r815x net/tipc: use %*phC to dump small buffers in hex form qlcnic: Adding Maintainers. gre: Fix MTU sizing check for gretap tunnels pkt_sched: sch_qfq: remove forward declaration of qfq_update_agg_ts pkt_sched: sch_qfq: improve efficiency of make_eligible gso: Update tunnel segmentation to support Tx checksum offload inet: fix spacing in assignment ifb: fix oops when loading the ifb failed ...
2013-07-13Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull final round of SCSI updates from James Bottomley: "This is the remaining set of SCSI patches for the merge window. It's mostly driver updates (scsi_debug, qla2xxx, storvsc, mp3sas). There are also several bug fixes in fcoe, libfc, and megaraid_sas. We also have a couple of core changes to try to make device destruction more deterministic" * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (46 commits) [SCSI] scsi constants: command, sense key + additional sense strings fcoe: Reduce number of sparse warnings fcoe: Stop fc_rport_priv structure leak libfcoe: Fix meaningless log statement libfc: Differentiate echange timer cancellation debug statements libfc: Remove extra space in fc_exch_timer_cancel definition fcoe: fix the link error status block sparse warnings fcoe: Fix smatch warning in fcoe_fdmi_info function libfc: Reject PLOGI from nodes with incompatible role [SCSI] enable destruction of blocked devices which fail LUN scanning [SCSI] Fix race between starved list and device removal [SCSI] megaraid_sas: fix a bug for 64 bit arches [SCSI] scsi_debug: reduce duplication between prot_verify_read and prot_verify_write [SCSI] scsi_debug: simplify offset calculation for dif_storep [SCSI] scsi_debug: invalidate protection info for unmapped region [SCSI] scsi_debug: fix NULL pointer dereference with parameters dif=0 dix=1 [SCSI] scsi_debug: fix incorrectly nested kmap_atomic() [SCSI] scsi_debug: fix invalid address passed to kunmap_atomic() [SCSI] mpt3sas: Bump driver version to v02.100.00.00 [SCSI] mpt3sas: when async scanning is enabled then while scanning, devices are removed but their transport layer entries are not removed ...
2013-07-13Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fix from Thomas Gleixner: "Fix a potential deadlock versus hrtimers" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix HRTICK
2013-07-13Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq updates from Thomas Gleixner: - core fix for missing round up in the generic irq chip implementation - new irq chip for MOXA SoCs - a few fixes and cleanups in the irqchip drivers * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip: Add support for MOXA ART SoCs genirq: generic chip: Use DIV_ROUND_UP to calculate numchips irqchip: nvic: Fix wrong num_ct argument for irq_alloc_domain_generic_chips() irqchip: sun4i: Staticize sun4i_irq_ack() irqchip: vt8500: Staticize local symbols
2013-07-13Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: - watchdog fixes for full dynticks - improved debug output for full dynticks - remove an obsolete full dynticks check - two ARM SoC clocksource drivers for sharing across SoCs - tick broadcast fix for CPU hotplug * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tick: broadcast: Check broadcast mode on CPU hotplug clocksource: arm_global_timer: Add ARM global timer support clocksource: Add Marvell Orion SoC timer nohz: Remove obsolete check for full dynticks CPUs to be RCU nocbs watchdog: Boot-disable by default on full dynticks watchdog: Rename confusing state variable watchdog: Register / unregister watchdog kthreads on sysctl control nohz: Warn if the machine can not perform nohz_full
2013-07-13Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Thomas Gleixner: - fix for do_div() abuse on x86 - locking fix in perf core - a pile of (build) fixes and cleanups in perf tools * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) perf/x86: Fix incorrect use of do_div() in NMI warning perf: Fix perf_lock_task_context() vs RCU perf: Remove WARN_ON_ONCE() check in __perf_event_enable() for valid scenario perf: Clone child context from parent context pmu perf script: Fix broken include in Context.xs perf tools: Fix -ldw/-lelf link test when static linking perf tools: Revert regression in configuration of Python support perf tools: Fix perf version generation perf stat: Fix per-socket output bug for uncore events perf symbols: Fix vdso list searching perf evsel: Fix missing increment in sample parsing perf tools: Update symbol_conf.nr_events when processing attribute events perf tools: Fix new_term() missing free on error path perf tools: Fix parse_events_terms() segfault on error path perf evsel: Fix count parameter to read call in event_format__new perf tools: fix a typo of a Power7 event name perf tools: Fix -x/--exclude-other option for report command perf evlist: Enhance perf_evlist__start_workload() perf record: Remove -f/--force option perf record: Remove -A/--append option ...
2013-07-13Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking updates from Thomas Gleixner: "Header cleanup as requested by Linus" (This is the "don't include support for ww_mutex in a header file that everybody wants, when almost nobody wants the ww part" change) * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: mutex: Move ww_mutex definitions to ww_mutex.h
2013-07-13Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "This is our first set of fixes from arm-soc for 3.11. - A handful of build and warning fixes from Arnd - A collection of OMAP fixes - defconfig updates to make the default configs more useful for real use (and testing) out of the box on hardware And a couple of other small fixes. Some of these have been recently applied but it's normally how we deal with fixes, with less bake time in -next needed" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (32 commits) arm: multi_v7_defconfig: Tweaks for omap and sunxi arm: multi_v7_defconfig: add i.MX options and NFS root ARM: omap2: add select of TI_PRIV_EDMA ARM: exynos: select PM_GENERIC_DOMAINS only when used ARM: ixp4xx: avoid circular header dependency ARM: OMAP: omap_common_late_init may be unused ARM: sti: move DEBUG_STI_UART into alphabetical order ARM: OMAP: build mach-omap code only if needed ARM: zynq: use DT_MACHINE_START ARM: omap5: omap5 has SCU and TWD ARM: OMAP2+: omap2plus_defconfig: Enable appended DTB support ARM: OMAP2+: Enable TI_EDMA in omap2plus_defconfig ARM: OMAP2+: omap2plus_defconfig: enable DRA752 thermal support by default ARM: OMAP2+: omap2plus_defconfig: enable TI bandgap driver ARM: OMAP2+: devices: remove duplicated include from devices.c ARM: OMAP3: igep0020: Set DSS pins in correct mux mode. ARM: OMAP2+: N900: enable N900-specific drivers even if device tree is enabled ARM: OMAP2+: Cocci spatch "ptr_ret.spatch" ARM: OMAP2+: Remove obsolete Makefile line ARM: OMAP5: Enable Cortex A15 errata 798181 ...
2013-07-13Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "A few fixes for ARM, mostly just one liners with the exception of the missing section specification. We decided not to rely on .previous to fix this but to explicitly state the section we want the code to be in." * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7778/1: smp_twd: twd_update_frequency need be run on all online CPUs ARM: 7782/1: Kconfig: Let ARM_ERRATA_364296 not depend on CONFIG_SMP ARM: mm: fix boot on SA1110 Assabet ARM: 7781/1: mmu: Add debug_ll_io_init() mappings to early mappings ARM: 7780/1: add missing linker section markup to head-common.S
2013-07-13Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: "MIPS updates: - All the things that didn't make 3.10. - Removes the Windriver PPMC platform. Nobody will miss it. - Remove a workaround from kernel/irq/irqdomain.c which was there exclusivly for MIPS. Patch by Grant Likely. - More small improvments for the SEAD 3 platform - Improvments on the BMIPS / SMP support for the BCM63xx series. - Various cleanups of dead leftovers. - Platform support for the Cavium Octeon-based EdgeRouter Lite. Two large KVM patchsets didn't make it for this pull request because their respective authors are vacationing" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (124 commits) MIPS: Kconfig: Add missing MODULES dependency to VPE_LOADER MIPS: BCM63xx: CLK: Add dummy clk_{set,round}_rate() functions MIPS: SEAD3: Disable L2 cache on SEAD-3. MIPS: BCM63xx: Enable second core SMP on BCM6328 if available MIPS: BCM63xx: Add SMP support to prom.c MIPS: define write{b,w,l,q}_relaxed MIPS: Expose missing pci_io{map,unmap} declarations MIPS: Malta: Update GCMP detection. Revert "MIPS: make CAC_ADDR and UNCAC_ADDR account for PHYS_OFFSET" MIPS: APSP: Remove <asm/kspd.h> SSB: Kconfig: Amend SSB_EMBEDDED dependencies MIPS: microMIPS: Fix improper definition of ISA exception bit. MIPS: Don't try to decode microMIPS branch instructions where they cannot exist. MIPS: Declare emulate_load_store_microMIPS as a static function. MIPS: Fix typos and cleanup comment MIPS: Cleanup indentation and whitespace MIPS: BMIPS: support booting from physical CPU other than 0 MIPS: Only set cpu_has_mmips if SYS_SUPPORTS_MICROMIPS MIPS: GIC: Fix gic_set_affinity infinite loop MIPS: Don't save/restore OCTEON wide multiplier state on syscalls. ...
2013-07-13Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: - lots of devm_ conversions and cleanup - platform_set_drvdata cleanups - s3c2410: dev_err/dev_info + dev_pm_ops - watchdog_core: don't try to stop device if not running fix - wdrtas: use print_hex_dump - xilinx cleanups - orion_wdt fixes - softdog cleanup - hpwdt: check on UEFI bits - deletion of mpcore_wdt driver - addition of broadcom BCM2835 watchdog timer driver - addition of MEN A21 watcdog devices * git://www.linux-watchdog.org/linux-watchdog: (38 commits) watchdog: hpwdt: Add check for UEFI bits watchdog: softdog: remove replaceable ping operation watchdog: New watchdog driver for MEN A21 watchdogs Watchdog: fix clearing of the watchdog interrupt Watchdog: allow orion_wdt to be built for Dove watchdog: Add Broadcom BCM2835 watchdog timer driver watchdog: delete mpcore_wdt driver watchdog: xilinx: Setup the origin compatible string watchdog: xilinx: Fix driver header watchdog: wdrtas: don't use custom version of print_hex_dump watchdog: core: don't try to stop device if not running watchdog: jz4740: Pass device to clk_get watchdog: twl4030: Remove redundant platform_set_drvdata() watchdog: mpcore: Remove redundant platform_set_drvdata() watchdog: da9055: use platform_{get,set}_drvdata() watchdog: da9052: use platform_{get,set}_drvdata() watchdog: cpwd: use platform_{get,set}_drvdata() watchdog: s3c2410_wdt: convert s3c2410wdt to dev_pm_ops watchdog: s3c2410_wdt: use dev_err()/dev_info() instead of pr_err()/pr_info() watchdog: wm831x: use platform_{get,set}_drvdata() ...
2013-07-13Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull InfiniBand/RDMA changes from Roland Dreier: - AF_IB (native IB addressing) for CMA from Sean Hefty - new mlx5 driver for Mellanox Connect-IB adapters (including post merge request fixes) - SRP fixes from Bart Van Assche (including fix to first merge request) - qib HW driver updates - resurrection of ocrdma HW driver development - uverbs conversion to create fds with O_CLOEXEC set - other small changes and fixes * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: (66 commits) mlx5: Return -EFAULT instead of -EPERM IB/qib: Log all SDMA errors unconditionally IB/qib: Fix module-level leak mlx5_core: Adjust hca_cap.uar_page_sz to conform to Connect-IB spec IB/srp: Let srp_abort() return FAST_IO_FAIL if TL offline IB/uverbs: Use get_unused_fd_flags(O_CLOEXEC) instead of get_unused_fd() mlx5_core: Fixes for sparse warnings IB/mlx5: Make profile[] static in main.c mlx5: Fix parameter type of health_handler_t mlx5: Add driver for Mellanox Connect-IB adapters IB/core: Add reserved values to enums for low-level driver use IB/srp: Bump driver version and release date IB/srp: Make HCA completion vector configurable IB/srp: Maintain a single connection per I_T nexus IB/srp: Fail I/O fast if target offline IB/srp: Skip host settle delay IB/srp: Avoid skipping srp_reset_host() after a transport error IB/srp: Fix remove_one crash due to resource exhaustion IB/qib: New transmitter tunning settings for Dell 1.1 backplane IB/core: Fix error return code in add_port() ...
2013-07-13Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: "This series contain: - new i2c video drivers: ml86v7667 (video decoder), ths8200 (video encoder) - a new video driver for EasyCap cards based on Fushicai USBTV007 - Improved support for OF and embedded systems, with V4L2 async initialization and a better support for clocks - API cleanups on the ioctls used by the v4l2 debug tool - Lots of cleanups - As usual, several driver improvements and new cards additions - Revert two changesets that change the minimal symbol rate for stv0399, as request by Manu - Update MAINTAINERS and other files to point to my new e-mail" * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (378 commits) MAINTAINERS & ABI: Update to point to my new email [media] stb0899: restore minimal rate to 5Mbauds [media] exynos4-is: Correct colorspace handling at FIMC-LITE [media] exynos4-is: Set valid initial format on FIMC.n subdevs [media] exynos4-is: Set valid initial format on FIMC-IS-ISP subdev pads [media] exynos4-is: Fix format propagation on FIMC-IS-ISP subdev [media] exynos4-is: Set valid initial format at FIMC-LITE [media] exynos4-is: Fix format propagation on FIMC-LITE.n subdevs [media] MAINTAINERS: Update S5P/Exynos FIMC driver entry [media] Documentation: Update driver's directory in video4linux/fimc.txt [media] exynos4-is: Change fimc-is firmware file names [media] exynos4-is: Add support for Exynos5250 MIPI-CSIS [media] exynos4-is: Add Exynos5250 SoC support to fimc-lite driver [media] exynos4-is: Drop drvdata handling in fimc-lite for non-dt platforms [media] media: i2c: tvp514x: remove manual setting of subdev name [media] media: i2c: tvp7002: remove manual setting of subdev name [media] mem2mem: set missing v4l2_dev pointer [media] wl128x: add missing struct v4l2_device [media] tvp514x: Fix init seqeunce [media] saa7134: Fix sparse warnings by adding __user annotation ...
2013-07-13Merge tag 'for-linus-v3.11-rc1-2' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull more xfs updates from Ben Myers: "Here are a fix for xfs_fsr, a cleanup in bulkstat, a cleanup in xfs_open_by_handle, updated mount options documentation, a cleanup in xfs_bmapi_write, a fix for the size of dquot log reservations, a fix for sgid inheritance when acls are in use, a fix for cleaning up quotainfo structures, and some more of the work which allows group and project quotas to be used together. We had a few more in this last quota category that we might have liked to get in, but it looks there are still a few items that need to be addressed. - fix for xfs_fsr returning -EINVAL - cleanup in xfs_bulkstat - cleanup in xfs_open_by_handle - update mount options documentation - clean up local format handling in xfs_bmapi_write - fix dquot log reservations which were too small - fix sgid inheritance for subdirectories when default acls are in use - add project quota fields to various structures - fix teardown of quotainfo structures when quotas are turned off" * tag 'for-linus-v3.11-rc1-2' of git://oss.sgi.com/xfs/xfs: xfs: Fix the logic check for all quotas being turned off xfs: Add pquota fields where gquota is used. xfs: fix sgid inheritance for subdirectories inheriting default acls [V3] xfs: dquot log reservations are too small xfs: remove local fork format handling from xfs_bmapi_write() xfs: update mount options documentation xfs: use get_unused_fd_flags(0) instead of get_unused_fd() xfs: clean up unused codes at xfs_bulkstat() xfs: use XFS_BMAP_BMDR_SPACE vs. XFS_BROOT_SIZE_ADJ
2013-07-13Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull cifs fixes from Steve French: "Fixes for 4 cifs bugs, including a reconnect problem, a problem parsing responses to SMB2 open request, and setting nlink incorrectly to some servers which don't report it properly on the wire. Also improves data integrity on reconnect with series from Pavel which adds durable handle support for SMB2." * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: CIFS: Fix a deadlock when a file is reopened CIFS: Reopen the file if reconnect durable handle failed [CIFS] Fix minor endian error in durable handle patch series CIFS: Reconnect durable handles for SMB2 CIFS: Make SMB2_open use cifs_open_parms struct CIFS: Introduce cifs_open_parms struct CIFS: Request durable open for SMB2 opens CIFS: Simplify SMB2 create context handling CIFS: Simplify SMB2_open code path CIFS: Respect create_options in smb2_open_file CIFS: Fix lease context buffer parsing [CIFS] use sensible file nlink values if unprovided Limit allocation of crypto mechanisms to dialect which requires
2013-07-13llist: llist_add() can use llist_add_batch()Oleg Nesterov
llist_add(new, head) can simply use llist_add_batch(new, new, head), no need to duplicate the code. This obviously uninlines llist_add() and to me this is a win. But we can make llist_add_batch() inline if this is desirable, in this case gcc can notice that new_first == new_last if the caller is llist_add(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrey Vagin <avagin@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: David Howells <dhowells@redhat.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-13llist: fix/simplify llist_add() and llist_add_batch()Oleg Nesterov
1. This is mostly theoretical, but llist_add*() need ACCESS_ONCE(). Otherwise it is not guaranteed that the first cmpxchg() uses the same value for old_entry and new_last->next. 2. These helpers cache the result of cmpxchg() and read the initial value of head->first before the main loop. I do not think this makes sense. In the likely case cmpxchg() succeeds, otherwise it doesn't hurt to reload head->first. I think it would be better to simplify the code and simply read ->first before cmpxchg(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrey Vagin <avagin@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: David Howells <dhowells@redhat.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-13fput: turn "list_head delayed_fput_list" into llist_headOleg Nesterov
fput() and delayed_fput() can use llist and avoid the locking. This is unlikely path, it is not that this change can improve the performance, but this way the code looks simpler. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrey Vagin <avagin@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: David Howells <dhowells@redhat.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-13fs/file_table.c:fput(): add commentAndrew Morton
A missed update to "fput: task_work_add() can fail if the caller has passed exit_task_work()". Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andrey Vagin <avagin@openvz.org> Cc: David Howells <dhowells@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-13Safer ABI for O_TMPFILEAl Viro
[suggested by Rasmus Villemoes] make O_DIRECTORY | O_RDWR part of O_TMPFILE; that will fail on old kernels in a lot more cases than what I came up with. And make sure O_CREAT doesn't get there... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-12arm: multi_v7_defconfig: Tweaks for omap and sunxiOlof Johansson
OMAP recently changed how the platforms are configured, so OMAP2/3/4 SoC support is no longer enabled by default. Add them back. Enable new ethernet driver for sunxi. The i.MX console options moved due to resorting, no functional change. Signed-off-by: Olof Johansson <olof@lixom.net>
2013-07-12Merge branch 'next' into for-linusDmitry Torokhov
Bring in second round of updates for 3.11.
2013-07-13Merge tag 'fcoe' into for-linusJames Bottomley
A short series of fixes to libfc, libfcoe and fcoe. Most patches fix formatting problems, one changes the behavior of which discovered ports can/will be logged into and another fixes a memory leak.
2013-07-12ipv6: only static routes qualify for equal cost multipathingHannes Frederic Sowa
Static routes in this case are non-expiring routes which did not get configured by autoconf or by icmpv6 redirects. To make sure we actually get an ecmp route while searching for the first one in this fib6_node's leafs, also make sure it matches the ecmp route assumptions. v2: a) Removed RTF_EXPIRE check in dst.from chain. The check of RTF_ADDRCONF already ensures that this route, even if added again without RTF_EXPIRES (in case of a RA announcement with infinite timeout), does not cause the rt6i_nsiblings logic to go wrong if a later RA updates the expiration time later. v3: a) Allow RTF_EXPIRES routes to enter the ecmp route set. We have to do so, because an pmtu event could update the RTF_EXPIRES flag and we would not count this route, if another route joins this set. We now filter only for RTF_GATEWAY|RTF_ADDRCONF|RTF_DYNAMIC, which are flags that don't get changed after rt6_info construction. Cc: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-12via-rhine: fix dma mapping errorsNeil Horman
this bug: https://bugzilla.redhat.com/show_bug.cgi?id=951695 Reported a dma debug backtrace: WARNING: at lib/dma-debug.c:937 check_unmap+0x47d/0x930() Hardware name: To Be Filled By O.E.M. via-rhine 0000:00:12.0: DMA-API: device driver failed to check map error[device address=0x0000000075a837b2] [size=90 bytes] [mapped as single] Modules linked in: ip6_tables gspca_spca561 gspca_main videodev media snd_hda_codec_realtek snd_hda_intel i2c_viapro snd_hda_codec snd_hwdep snd_seq ppdev mperf via_rhine coretemp snd_pcm mii microcode snd_page_alloc snd_timer snd_mpu401 snd_mpu401_uart snd_rawmidi snd_seq_device snd soundcore parport_pc parport shpchp ata_generic pata_acpi radeon i2c_algo_bit drm_kms_helper ttm drm pata_via sata_via i2c_core uinput Pid: 295, comm: systemd-journal Not tainted 3.9.0-0.rc6.git2.1.fc20.x86_64 #1 Call Trace: <IRQ> [<ffffffff81068dd0>] warn_slowpath_common+0x70/0xa0 [<ffffffff81068e4c>] warn_slowpath_fmt+0x4c/0x50 [<ffffffff8137ec6d>] check_unmap+0x47d/0x930 [<ffffffff810ace9f>] ? local_clock+0x5f/0x70 [<ffffffff8137f17f>] debug_dma_unmap_page+0x5f/0x70 [<ffffffffa0225edc>] ? rhine_ack_events.isra.14+0x3c/0x50 [via_rhine] [<ffffffffa02275f8>] rhine_napipoll+0x1d8/0xd80 [via_rhine] [<ffffffff815d3d51>] ? net_rx_action+0xa1/0x380 [<ffffffff815d3e22>] net_rx_action+0x172/0x380 [<ffffffff8107345f>] __do_softirq+0xff/0x400 [<ffffffff81073925>] irq_exit+0xb5/0xc0 [<ffffffff81724cd6>] do_IRQ+0x56/0xc0 [<ffffffff81719ff2>] common_interrupt+0x72/0x72 <EOI> [<ffffffff8170ff57>] ? __slab_alloc+0x4c2/0x526 [<ffffffff811992e0>] ? mmap_region+0x2b0/0x5a0 [<ffffffff810d5807>] ? __lock_is_held+0x57/0x80 [<ffffffff811992e0>] ? mmap_region+0x2b0/0x5a0 [<ffffffff811bf1bf>] kmem_cache_alloc+0x2df/0x360 [<ffffffff811992e0>] mmap_region+0x2b0/0x5a0 [<ffffffff811998e6>] do_mmap_pgoff+0x316/0x3d0 [<ffffffff81183ca0>] vm_mmap_pgoff+0x90/0xc0 [<ffffffff81197d6c>] sys_mmap_pgoff+0x4c/0x190 [<ffffffff81367d7e>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff8101eb42>] sys_mmap+0x22/0x30 [<ffffffff81722fd9>] system_call_fastpath+0x16/0x1b Usual problem with the usual fix, add the appropriate calls to dma_mapping_error where appropriate Untested, as I don't have hardware, but its pretty straightforward Signed-off-by: Neil Horman <nhorman@tuxdriver.com> CC: David S. Miller <davem@davemloft.net> CC: Roger Luethi <rl@hellgate.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
