2011-03-23m68k: remove inline asm from minix_find_first_zero_bitAkinobu Mita
As a preparation for moving minix bit operations from asm/bitops.h to architecture independent code in minix filesystem, this removes inline asm from minix_find_first_zero_bit() for m68k. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23dm: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Alasdair Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23md: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23ufs: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23udf: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23reiserfs: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23nilfs2: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23ocfs2: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Joel Becker <joel.becker@oracle.com> Cc: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23ext4: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23ext3: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rds: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Andy Grover <andy.grover@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23kvm: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23asm-generic: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce little-endian bitops for most architecturesAkinobu Mita
Introduce little-endian bit operations to the big-endian architectures which do not have native little-endian bit operations and the little-endian architectures. (alpha, avr32, blackfin, cris, frv, h8300, ia64, m32r, mips, mn10300, parisc, sh, sparc, tile, x86, xtensa) These architectures can just include generic implementation (asm-generic/bitops/le.h). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23m68knommu: introduce little-endian bitopsAkinobu Mita
Introduce little-endian bit operations by renaming native ext2 bit operations. The ext2 bit operations are kept as wrapper macros using little-endian bit operations to maintain bisectability until the conversions are finished. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: introduce CONFIG_GENERIC_FIND_BIT_LEAkinobu Mita
This introduces CONFIG_GENERIC_FIND_BIT_LE to tell whether to use generic implementation of find_*_bit_le() in lib/find_next_bit.c or not. For now we select CONFIG_GENERIC_FIND_BIT_LE for all architectures which enable CONFIG_GENERIC_FIND_NEXT_BIT. But m68knommu wants to define own faster find_next_zero_bit_le() and continues using generic find_next_{,zero_}bit(). (CONFIG_GENERIC_FIND_NEXT_BIT and !CONFIG_GENERIC_FIND_BIT_LE) Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23m68k: introduce little-endian bitopsAkinobu Mita
Introduce little-endian bit operations by renaming native ext2 bit operations and changing find_*_bit_le() to take a "void *". The ext2 bit operations are kept as wrapper macros using little-endian bit operations to maintain bisectability until the conversions are finished. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23arm: introduce little-endian bitopsAkinobu Mita
Introduce little-endian bit operations by renaming native ext2 bit operations. The ext2 and minix bit operations are kept as wrapper macros using little-endian bit operations to maintain bisectability until the conversions are finished. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23s390: introduce little-endian bitopsAkinobu Mita
Introduce little-endian bit operations by renaming native ext2 bit operations. The ext2 bit operations are kept as wrapper macros using little-endian bit operations to maintain bisectability until the conversions are finished. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23powerpc: introduce little-endian bitopsAkinobu Mita
Introduce little-endian bit operations by renaming existing powerpc native little-endian bit operations and changing them to take any pointer types. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23asm-generic: change little-endian bitops to take any pointer typesAkinobu Mita
This makes the little-endian bitops take any pointer types by changing the prototypes and adding casts in the preprocessor macros. That would seem to at least make all the filesystem code happier, and they can continue to do just something like #define ext2_set_bit __test_and_set_bit_le (or whatever the exact sequence ends up being). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Zankel <chris@zankel.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23asm-generic: rename generic little-endian bitops functionsAkinobu Mita
As a preparation for providing little-endian bitops for all architectures, This renames generic implementation of little-endian bitops. (remove "generic_" prefix and postfix "_le") s/generic_find_next_le_bit/find_next_bit_le/ s/generic_find_next_zero_le_bit/find_next_zero_bit_le/ s/generic_find_first_zero_le_bit/find_first_zero_bit_le/ s/generic___test_and_set_le_bit/__test_and_set_bit_le/ s/generic___test_and_clear_le_bit/__test_and_clear_bit_le/ s/generic_test_le_bit/test_bit_le/ s/generic___set_le_bit/__set_bit_le/ s/generic___clear_le_bit/__clear_bit_le/ s/generic_test_and_set_le_bit/test_and_set_bit_le/ s/generic_test_and_clear_le_bit/test_and_clear_bit_le/ Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: merge little and big endian definisions in asm-generic/bitops/le.hAkinobu Mita
This patch series introduces little-endian bit operations in asm/bitops.h for all architectures and converts all ext2 non-atomic and minix bit operations to use little-endian bit operations. It enables us to remove ext2 non-atomic and minix bit operations from asm/bitops.h. The reason they should be removed from asm/bitops.h is as follows: For ext2 non-atomic bit operations, they are used for little-endian byte order bitmap access by some filesystems and modules. But using ext2_*() functions on a module other than ext2 filesystem makes some feel strange. For minix bit operations, they are only used by minix filesystem and are useless by other modules. Because byte order of inode and block bitmap is This patch: In order to make the forthcoming changes smaller, this merges macro definisions in asm-generic/bitops/le.h for big-endian and little-endian as much as possible. This also removes unused BITOP_WORD macro. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23rds: stop including asm-generic/bitops/le.h directlyAkinobu Mita
asm-generic/bitops/le.h is only intended to be included directly from asm-generic/bitops/ext2-non-atomic.h or asm-generic/bitops/minix-le.h which implements generic ext2 or minix bit operations. This stops including asm-generic/bitops/le.h directly and use ext2 non-atomic bit operations instead. It seems odd to use ext2_*_bit() on rds, but it will replaced with __{set,clear,test}_bit_le() after introducing little endian bit operations for all architectures. This indirect step is necessary to maintain bisectability for some architectures which have their own little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Andy Grover <andy.grover@oracle.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23kvm: stop including asm-generic/bitops/le.h directlyAkinobu Mita
asm-generic/bitops/le.h is only intended to be included directly from asm-generic/bitops/ext2-non-atomic.h or asm-generic/bitops/minix-le.h which implements generic ext2 or minix bit operations. This stops including asm-generic/bitops/le.h directly and use ext2 non-atomic bit operations instead. It seems odd to use ext2_set_bit() on kvm, but it will replaced with __set_bit_le() after introducing little endian bit operations for all architectures. This indirect step is necessary to maintain bisectability for some architectures which have their own little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23fs/adfs/adfs.h: fix unsigned comparisonAndrew Morton
fs/adfs/adfs.h: In function 'append_filetype_suffix': fs/adfs/adfs.h:115: warning: comparison is always false due to limited range of data type Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Stuart Swales <stuart.swales.croftnuisk@gmail.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23ia64: fix build breakage in asm/thread_info.hLuck, Tony
In commit 504f52b5439aaf26d3e2c1d45ec10fce38c8dd27 mm: NUMA aware alloc_task_struct_node() Eric Dumazet forgot a "\". Add it. Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23Revert "drm/i915: Don't save/restore hardware status page address register"Chris Wilson
This reverts commit a7a75c8f70d6f6a2f16c9f627f938bbee2d32718. There are two different variations on how Intel hardware addresses the "Hardware Status Page". One as a location in physical memory and the other as an offset into the virtual memory of the GPU, used in more recent chipsets. (The HWS itself is a cacheable region of memory which the GPU can write to without requiring CPU synchronisation, used for updating various details of hardware state, such as the position of the GPU head in the ringbuffer, the last breadcrumb seqno, etc). These two types of addresses were updated in different locations of code - one inline with the ringbuffer initialisation, and the other during device initialisation. (The HWS page is logically associated with the rings, and there is one HWS page per ring.) During resume, only the ringbuffers were being re-initialised along with the virtual HWS page, leaving the older physical address HWS untouched. This then caused a hang on the older gen3/4 (915GM, 945GM, 965GM) the first time we tried to synchronise the GPU as the breadcrumbs were never being updated. Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org> Reported-by: Jan Niehusmann <jan@gondor.com> Reported-by: Justin P. Mattock <justinmattock@gmail.com> Reported-and-tested-by: Michael "brot" Groh <brot@minad.de> Cc: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: HDA: Realtek: Avoid unnecessary volume control index on Surround/Side ASoC: Support !REGULATOR build for sgtl5000 ALSA: hda - VIA: Fix VT1708 can't build up Headphone control issue ALSA: hda - VIA: Correct stream names for VT1818S ALSA: hda - VIA: Fix codec type for VT1708BCE at the right timing ALSA: hda - VIA: Fix invalid A-A path volume adjust issue ALSA: hda - VIA: Add missing support for VT1718S in A-A path ALSA: hda - VIA: Fix independent headphone no sound issue ALSA: hda - VIA: Fix stereo mixer recording no sound issue ALSA: hda - Set EAPD for Realtek ALC665 ALSA: usb - Remove trailing spaces from USB card name strings sound: read i_size with i_size_read() ASoC: Remove bogus check for register validity in debugfs write ASoC: mini2440: Fix uda134x codec problem.
2011-03-23sys_swapon: fix inode lockingCesar Eduardo Barros
A conflict between 52c50567d8ab ("mm: swap: unlock swapfile inode mutex before closing file on bad swapfiles") and 83ef99befc32 ("sys_swapon: remove did_down variable") caused a double unlock of the inode mutex (once in bad_swap: before the filp_close, once at the end just before returning). The patch which added the extra unlock cleared did_down to avoid unlocking twice, but the other patch removed the did_down variable. To fix, set inode to NULL after the first unlock, since it will be used after that point only for the final unlock. While checking this patch, I found a path which could unlock without locking, in case the same inode was added as a swapfile twice. To fix, move the setting of the inode variable further down, to just before claim_swapfile, which will lock the inode before doing anything else. Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Eric B Munson <emunson@mgebm.net> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23smp: add missing init.h includeHeiko Carstens
Commit 34db18a054c6 ("smp: move smp setup functions to kernel/smp.c") causes this build error on s390 because of a missing init.h include: CC arch/s390/kernel/asm-offsets.s In file included from /home2/heicarst/linux-2.6/arch/s390/include/asm/spinlock.h:14:0, from include/linux/spinlock.h:87, from include/linux/seqlock.h:29, from include/linux/time.h:8, from include/linux/timex.h:56, from include/linux/sched.h:57, from arch/s390/kernel/asm-offsets.c:10: include/linux/smp.h:117:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'setup_nr_cpu_ids' include/linux/smp.h:118:20: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'smp_init' Fix it by adding the include statement. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: WANG Cong <amwang@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-03-23ALSA: HDA: Realtek: Avoid unnecessary volume control index on Surround/SideDavid Henningsson
Similar to commit 7e59e097c09b82760bb0fe08b0fa2b704d76c3f4, this patch avoids unnecessary volume control indices for more Realtek auto-parsers, e g the ALC66x family, on the "Surround" and "Side" controls. These indices cause these volume controls to be ignored by PulseAudio and vmaster and should be removed whenever possible. Cc: stable@kernel.org Reported-by: Jan Losinski <losinski@wh2.tu-dresden.de> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-22Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (66 commits) avr32: at32ap700x: fix typo in DMA master configuration dmaengine/dmatest: Pass timeout via module params dma: let IMX_DMA depend on IMX_HAVE_DMA_V1 instead of an explicit list of SoCs fsldma: make halt behave nicely on all supported controllers fsldma: reduce locking during descriptor cleanup fsldma: support async_tx dependencies and automatic unmapping fsldma: fix controller lockups fsldma: minor codingstyle and consistency fixes fsldma: improve link descriptor debugging fsldma: use channel name in printk output fsldma: move related helper functions near each other dmatest: fix automatic buffer unmap type drivers, pch_dma: Fix warning when CONFIG_PM=n. dmaengine/dw_dmac fix: use readl & writel instead of __raw_readl & __raw_writel avr32: at32ap700x: Specify DMA Flow Controller, Src and Dst msize dw_dmac: Setting Default Burst length for transfers as 16. dw_dmac: Allow src/dst msize & flow controller to be configured at runtime dw_dmac: Changing type of src_master and dest_master to u8. dw_dmac: Pass Channel Priority from platform_data dw_dmac: Pass Channel Allocation Order from platform_data ...
2011-03-22bloat-o-meter: include read-only data section in reportJean Delvare
I'm not sure why the read-only data section is excluded from the report, it seems as relevant as the other data sections (b and d). I've stripped the symbols starting with __mod_ as they can have their names dynamically generated and thus comparison between binaries is not possible. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22zlib: slim down zlib_deflate() workspace when possibleJim Keniston
Instead of always creating a huge (268K) deflate_workspace with the maximum compression parameters (windowBits=15, memLevel=8), allow the caller to obtain a smaller workspace by specifying smaller parameter values. For example, when capturing oops and panic reports to a medium with limited capacity, such as NVRAM, compression may be the only way to capture the whole report. In this case, a small workspace (24K works fine) is a win, whether you allocate the workspace when you need it (i.e., during an oops or panic) or at boot time. I've verified that this patch works with all accepted values of windowBits (positive and negative), memLevel, and compression level. Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Miller <davem@davemloft.net> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22fs/devpts/inode.c: correctly check d_alloc_name() return code in ↵Andrey Vagin
devpts_pty_new() d_alloc_name return NULL in case error, but we expect errno in devpts_pty_new. Addresses http://bugzilla.openvz.org/show_bug.cgi?id=1758 Signed-off-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22aio: wake all waiters when destroying ctxRoland Dreier
The test program below will hang because io_getevents() uses add_wait_queue_exclusive(), which means the wake_up() in io_destroy() only wakes up one of the threads. Fix this by using wake_up_all() in the aio code paths where we want to make sure no one gets stuck. // t.c -- compile with gcc -lpthread -laio t.c #include <libaio.h> #include <pthread.h> #include <stdio.h> #include <unistd.h> static const int nthr = 2; void *getev(void *ctx) { struct io_event ev; io_getevents(ctx, 1, 1, &ev, NULL); printf("io_getevents returned\n"); return NULL; } int main(int argc, char *argv[]) { io_context_t ctx = 0; pthread_t thread[nthr]; int i; io_setup(1024, &ctx); for (i = 0; i < nthr; ++i) pthread_create(&thread[i], NULL, getev, ctx); sleep(1); io_destroy(ctx); for (i = 0; i < nthr; ++i) pthread_join(thread[i], NULL); return 0; } Signed-off-by: Roland Dreier <roland@purestorage.com> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22pps: remove unreachable codeAlexander Gordeev
Remove code enabled only when CONFIG_PREEMPT_RT is turned on because it is not used in the vanilla kernel. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Cc: john stultz <johnstul@us.ibm.com> Cc: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22adfs: add hexadecimal filetype suffix optionStuart Swales
ADFS (FileCore) storage complies with the RISC OS filetype specification (12 bits of file type information is stored in the file load address, rather than using a file extension). The existing driver largely ignores this information and does not present it to the end user. It is desirable that stored filetypes be made visible to the end user to facilitate a precise copy of data and metadata from a hard disc (or image thereof) into a RISC OS emulator (such as RPCEmu) or to a network share which can be accessed by real Acorn systems. This patch implements a per-mount filetype suffix option (use -o ftsuffix=1) to present any filetype as a ,xyz hexadecimal suffix on each file. This type suffix is compatible with that used by RISC OS systems that access network servers using NFS client software and by RPCemu's host filing system. Signed-off-by: Stuart Swales <stuart.swales.croftnuisk@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22adfs: improve timestamp precisionStuart Swales
ADFS (FileCore) storage complies with the RISC OS timestamp specification (40-bit centiseconds since 01 Jan 1900 00:00:00). It is desirable that stored timestamp precision be maintained to facilitate a precise copy of data and metadata from a hard disc (or image thereof) into a RISC OS emulator (such as RPCEmu). This patch implements a full-precision conversion from ADFS to Unix timestamp as the existing driver, for ease of calculation with old 32-bit compilers, uses the common trick of shifting the 40-bits representing centiseconds around into 32-bits representing seconds thereby losing precision. Signed-off-by: Stuart Swales<stuart.swales.croftnuisk@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22adfs: fix E+/F+ dir size > 2048 crashing kernelStuart Swales
Kernel crashes in fs/adfs module when accessing directories with a large number of objects on mounted Acorn ADFS E+/F+ format discs (or images) as the existing code writes off the end of the fixed array of struct buffer_head pointers. Additionally, each directory access that didn't crash would leak a buffer as nr_buffers was not adjusted correctly for E+/F+ discs (was always left as one less than required). The patch fixes this by allocating a dynamically-sized set of struct buffer_head pointers if necessary for the E+/F+ case (many directories still do in fact fit in 2048 bytes) and sets the correct nr_buffers so that all buffers are released. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=26072 Tested by tar'ing the contents of my RISC PC's E+ format 20Gb HDD which contains a number of large directories that previously crashed the kernel. Signed-off-by: Stuart Swales <stuart.swales.croftnuisk@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Documentation/vm/page-types.c: auto debugfs mount for hwpoison operationChen Gong
page-types.c doesn't supply a way to specify the debugfs path and the original debugfs path is not usual on most machines. This patch supplies a way to auto mount debugfs if needed. This patch is heavily inspired by tools/perf/utils/debugfs.c [akpm@linux-foundation.org: make functions static] [akpm@linux-foundation.org: fix debugfs_mount() signature] Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Documentation/Changes: minor correctionsChristian Kujau
I noticed the 'mcelog' program had no comment and then ended up "fixing" a few more things: * reiserfsck -V does not print "reiserfsprogs" (any more?) * is "udevinfo" still shipped? udevd certainly is * grub2 doesn't have a 'grub' binary * add a "# how to get the mcelog version" comment Signed-off-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Documentation/CodingStyle: flesh out if-else examplesHarry Wei
There is a missing case for "Chapter 3: Placing Braces and Spaces". We often know we should not use braces where a single statement. The first case is: if (condition) action(); Another case is: if (condition) do_this(); else do_that(); However, I can not find a description of the second case. Signed-off-by: Harry Wei <harryxiyou@gmail.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22codafs: fix compile warning when CONFIG_SYSCTL=nRakib Mullick
When CONFIG_SYSCTL=n, we get the following warning: fs/coda/sysctl.c:18: warning: `coda_tabl' defined but not used Fix the warning by making sure coda_table and it's callee function are in the same context. Also clean up the code by removing extra #ifdef. [akpm@linux-foundation.org: remove unneeded stub macros] Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22x86: allow CONFIG_ISA_DMA_API to be disabledDavid Rientjes
Not all 64-bit systems require ISA-style DMA, so allow it to be configurable. x86 utilizes the generic ISA DMA allocator from kernel/dma.c, so require it only when CONFIG_ISA_DMA_API is enabled. Disabling CONFIG_ISA_DMA_API is dependent on x86_64 since those machines do not have ISA slots and benefit the most from disabling the option (and on CONFIG_EXPERT as required by H. Peter Anvin). When disabled, this also avoids declaring claim_dma_lock(), release_dma_lock(), request_dma(), and free_dma() since those interfaces will no longer be provided. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22x86: only compile floppy driver if CONFIG_ISA_DMA_API is enabledDavid Rientjes
The generic floppy disk driver utilizies the interface provided by CONFIG_ISA_DMA_API, specifically claim_dma_lock(), release_dma_lock(), request_dma(), and free_dma(). Thus, there's a strict dependency on the config option and the driver should only be loaded if the kernel supports ISA-style DMA. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22x86: only compile 8237A if CONFIG_ISA_DMA_API is enabledDavid Rientjes
8237A utilizes the interface provided by CONFIG_ISA_DMA_API, specifically claim_dma_lock() and release_dma_lock(). Thus, there's a strict dependency on the config option and the module should only be loaded if the kernel supports ISA-style DMA. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
