2013-02-04Merge branch 'for-rmk/broadcast' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/will/linux into devel-stable
2013-02-04Merge branch 'for-rmk/virt/kvm/core' of ↵Russell King
2013-02-01Merge branch 'clocks/broadcast-arm' of git://linux-arm.org/linux-mr into ↵Will Deacon
for-rmk/broadcast
2013-02-01Merge branch 'timers/for-arm' of ↵Will Deacon
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into for-rmk/broadcast
2013-02-01arm: Add generic timer broadcast supportMark Rutland
Implement timer_broadcast for the arm architecture, allowing for the use of clock_event_device_drivers decoupled from the timer tick broadcast mechanism. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
2013-02-01arm: Use generic timer broadcast receiverMark Rutland
Currently, the ARM backend must maintain a redundant list of timers for the purpose of centralising timer broadcast functionality. This prevents sharing timer drivers across architectures. This patch moves the pain of dealing with timer broadcasts to the core clockevents tick broadcast code, which already maintains its own list of timers. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
2013-01-31clockevents: Add generic timer broadcast functionMark Rutland
Currently, the timer broadcast mechanism is defined by a function pointer on struct clock_event_device. As the fundamental mechanism for broadcast is architecture-specific, this means that clock_event_device drivers cannot be shared across multiple architectures. This patch adds an (optional) architecture-specific function for timer tick broadcast, allowing drivers which may require broadcast functionality to be shared across multiple architectures. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: linux-arm-kernel@lists.infradead.org Cc: nico@linaro.org Cc: Will.Deacon@arm.com Cc: Marc.Zyngier@arm.com Cc: john.stultz@linaro.org Link: http://lkml.kernel.org/r/1358183124-28461-3-git-send-email-mark.rutland@arm.com Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-01-31clockevents: Add generic timer broadcast receiverMark Rutland
Currently the broadcast mechanism used for timers is abstracted by a function pointer on struct clock_event_device. As the fundamental mechanism for broadcast is architecture-specific, this ties each clock_event_device driver to a single architecture, even where the driver is otherwise generic. This patch adds a standard path for the receipt of timer broadcasts, so drivers and/or architecture backends need not manage redundant lists of timers for the purpose of routing broadcast timer ticks. [tglx: Made the implementation depend on the config switch as well ] Signed-off-by: Mark Rutland <mark.rutland@arm.com> Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Cc: linux-arm-kernel@lists.infradead.org Cc: nico@linaro.org Cc: Will.Deacon@arm.com Cc: Marc.Zyngier@arm.com Cc: john.stultz@linaro.org Link: http://lkml.kernel.org/r/1358183124-28461-2-git-send-email-mark.rutland@arm.com Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-01-31Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 EFI fixes from Peter Anvin: "This is a collection of fixes for the EFI support. The controversial bit here is a set of patches which bumps the boot protocol version as part of fixing some serious problems with the EFI handover protocol, used when booting under EFI using a bootloader as opposed to directly from EFI. These changes should also make it a lot saner to support cross-mode 32/64-bit EFI booting in the future. Getting these changes into 3.8 means we avoid presenting an inconsistent ABI to bootloaders. Other changes are display detection and fixing efivarfs." * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, efi: remove attribute check from setup_efi_pci x86, build: Dynamically find entry points in compressed startup code x86, efi: Fix PCI ROM handing in EFI boot stub, in 32-bit mode x86, efi: Fix 32-bit EFI handover protocol entry point x86, efi: Fix display detection in EFI boot stub x86, boot: Define the 2.12 bzImage boot protocol x86/boot: Fix minor fd leakage in tools/relocs.c x86, efi: Set runtime_version to the EFI spec revision x86, efi: fix 32-bit warnings in setup_efi_pci() efivarfs: Delete dentry from dcache in efivarfs_file_write() efivarfs: Never return ENOENT from firmware efi, x86: Pass a proper identity mapping in efi_call_phys_prelog efivarfs: Drop link count of the right inode
2013-01-31Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "This is a collection of miscellaneous fixes, the most important one is the fix for the Samsung laptop bricking issue (auto-blacklisting the samsung-laptop driver); the efi_enabled() changes you see below are prerequisites for that fix. The other issues fixed are booting on OLPC XO-1.5, an UV fix, NMI debugging, and requiring CAP_SYS_RAWIO for MSR references, just as with I/O port references." * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: samsung-laptop: Disable on EFI hardware efi: Make 'efi_enabled' a function to query EFI facilities smp: Fix SMP function call empty cpu mask race x86/msr: Add capabilities check x86/dma-debug: Bump PREALLOC_DMA_DEBUG_ENTRIES x86/olpc: Fix olpc-xo1-sci.c build errors arch/x86/platform/uv: Fix incorrect tlb flush all issue x86-64: Fix unwind annotations in recent NMI changes x86-32: Start out cr0 clean, disable paging before modifying cr3/4
2013-01-31Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull console lockdep checking revert from Dave Airlie. The lockdep splat this showed was interesting, but it's very very old, and we won't be fixing it until 3.9. In the meantime, undo the lockdep annotation so that we don't generate the (known) console lockdep issue, and then possibly hide any potential other (unknown) lockdep problems that got disabled by the first one that triggered. * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: Revert "console: implement lockdep support for console_lock"
2013-01-31Revert "console: implement lockdep support for console_lock"Dave Airlie
This reverts commit daee779718a319ff9f83e1ba3339334ac650bb22. I'll requeue this after the console locking fixes, so lockdep is useful again for people until fbcon is fixed. Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-01-30Merge tag 'efi-for-3.8' into x86/efiH. Peter Anvin
Various urgent EFI fixes and some warning cleanups for v3.8 * EFI boot stub fix for Macbook Pro's from Maarten Lankhorst * Fix an oops in efivarfs from Lingzhu Xiang * 32-bit warning cleanups from Jan Beulich * Patch to Boot on >512GB RAM systems from Nathan Zimmer * Set efi.runtime_version correctly * efivarfs updates Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-01-30samsung-laptop: Disable on EFI hardwareMatt Fleming
It has been reported that running this driver on some Samsung laptops with EFI can cause those machines to become bricked as detailed in the following report, https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 There have also been reports of this driver causing Machine Check Exceptions on recent EFI-enabled Samsung laptops, https://bugzilla.kernel.org/show_bug.cgi?id=47121 So disable it if booting from EFI since this driver relies on grovelling around in the BIOS memory map which isn't going to work. Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Colin Ian King <colin.king@canonical.com> Cc: Steve Langasek <steve.langasek@canonical.com> Cc: <stable@vger.kernel.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-01-30efi: Make 'efi_enabled' a function to query EFI facilitiesMatt Fleming
Originally 'efi_enabled' indicated whether a kernel was booted from EFI firmware. Over time its semantics have changed, and it now indicates whether or not we are booted on an EFI machine with bit-native firmware, e.g. 64-bit kernel with 64-bit firmware. The immediate motivation for this patch is the bug report at, https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557 which details how running a platform driver on an EFI machine that is designed to run under BIOS can cause the machine to become bricked. Also, the following report, https://bugzilla.kernel.org/show_bug.cgi?id=47121 details how running said driver can also cause Machine Check Exceptions. Drivers need a new means of detecting whether they're running on an EFI machine, as sadly the expression, if (!efi_enabled) hasn't been a sufficient condition for quite some time. Users actually want to query 'efi_enabled' for different reasons - what they really want access to is the list of available EFI facilities. For instance, the x86 reboot code needs to know whether it can invoke the ResetSystem() function provided by the EFI runtime services, while the ACPI OSL code wants to know whether the EFI config tables were mapped successfully. There are also checks in some of the platform driver code to simply see if they're running on an EFI machine (which would make it a bad idea to do BIOS-y things). This patch is a prereq for the samsung-laptop fix patch. Cc: David Airlie <airlied@linux.ie> Cc: Corentin Chary <corentincj@iksaif.net> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Dave Jiang <dave.jiang@intel.com> Cc: Olof Johansson <olof@lixom.net> Cc: Peter Jones <pjones@redhat.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Steve Langasek <steve.langasek@canonical.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Konrad Rzeszutek Wilk <konrad@kernel.org> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: <stable@vger.kernel.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-01-30Merge tag 'edac_for_3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bpLinus Torvalds
Pull EDAC fixlets from Borislav Petkov: "Two minor correctness fixlets from Dan Carpenter and Joe Perches each." * tag 'edac_for_3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: EDAC: Fix kcalloc argument order EDAC: Test correct variable in ->store function
2013-01-30Merge tag 'sound-3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: - A collection of small ASoC driver fixes (error path fixes, register correction, regulator bypass mode fix, etc) - A few regression fixes and quirks of HD-audio (wrong page attributes for SG-buffer, Poulsbo/Oaktrail controller fix, digital mic fix for Acer, etc) - A fix for USB-audio UAC2 devices wrt FU length check * tag 'sound-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Fix non-snoop page handling ALSA: hda - Enable LPIB delay count for Poulsbo / Oaktrail ALSA: hda - fix inverted internal mic on Acer AOA150/ZG5 ALSA: usb-audio: fix invalid length check for RME and other UAC 2 devices ALSA: hda - Add a fixup for Packard-Bell desktop with ALC880 ASoC: wm_adsp: Release firmware on error ASoC: wm_adsp: Use GFP_DMA for things that may be DMAed ASoC: arizona: Use actual rather than desired BCLK when calculating LRCLK ASoC: wm2200: correct mixer values and text ASoC: MAINTAINERS: Update email address. ASoC: wm5110: Correct AEC loopback mask ASoC: wm5102: Correct AEC loopback mask ASoC: dapm: Fix sense of regulator bypass mode ASoC: fsl: fix multiple definition of init_module ASoC: arizona: Disable free-running mode on FLL1
2013-01-30EDAC: Fix kcalloc argument orderJoe Perches
First number, then size. Signed-off-by: Joe Perches <joe@perches.com> Cc: <stable@vger.kernel.org> Signed-off-by: Borislav Petkov <bp@suse.de>
2013-01-30EDAC: Test correct variable in ->store functionDan Carpenter
We're testing for ->show but calling ->store(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: stable@vger.kernel.org Signed-off-by: Borislav Petkov <bp@suse.de>
2013-01-30Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Intel, radeon and exynos fixes. Nothing too major or wierd: one dmar fix and a radeon cursor corruption, along with misc exynos fixes." * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (21 commits) drm/exynos: add check for the device power status drm/exynos: Make 'drm_hdmi_get_edid' static drm/exynos: fimd and ipp are broken on multiplatform drm/exynos: don't include plat/gpio-cfg.h drm/exynos: Remove "internal" interrupt handling drm/exynos: Add missing static specifiers in exynos_drm_rotator.c drm/exynos: Replace mdelay with usleep_range drm/exynos: Make ipp_handle_cmd_work static drm/exynos: Make g2d_userptr_get_dma_addr static drm/exynos: consider DMA_NONE flag to dmabuf import drm/exynos: free sg object if dma_map_sg is failed drm/exynos: added validation of edid for vidi connection drm/exynos: let drm handle edid allocations drm/radeon: Enable DMA_IB_SWAP_ENABLE on big endian hosts. drm/radeon: fix a rare case of double kfree radeon_display: Use pointer return error codes drm/radeon: fix cursor corruption on DCE6 and newer drm/i915: dump UTS_RELEASE into the error_state iommu/intel: disable DMAR for g4x integrated gfx drm/i915: GFX_MODE Flush TLB Invalidate Mode must be '1' for scanline waits ...
2013-01-30Merge tag 'for-linus-v3.8-rc6' of git://oss.sgi.com/xfs/xfsLinus Torvalds
Pull xfs bugfixes from Ben Myers: "Here are fixes for returning EFSCORRUPTED on probe of a non-xfs filesystem, the stack switch in xfs_bmapi_allocate, a crash in _xfs_buf_find, speculative preallocation as the filesystem nears ENOSPC, an unmount hang, a race with AIO, and a regression with xfs_fsr: - fix return value when filesystem probe finds no XFS magic, a regression introduced in 9802182. - fix stack switch in __xfs_bmapi_allocate by moving the check for stack switch up into xfs_bmapi_write. - fix oops in _xfs_buf_find by validating that the requested block is within the filesystem bounds. - limit speculative preallocation near ENOSPC. - fix an unmount hang in xfs_wait_buftarg by freeing the xfs_buf_log_item in xfs_buf_item_unlock. - fix a possible use after free with AIO. - fix xfs_swap_extents after removal of xfs_flushinval_pages, a regression introduced in commit fb59581404a." * tag 'for-linus-v3.8-rc6' of git://oss.sgi.com/xfs/xfs: xfs: Fix xfs_swap_extents() after removal of xfs_flushinval_pages() xfs: Fix possible use-after-free with AIO xfs: fix shutdown hang on invalid inode during create xfs: limit speculative prealloc near ENOSPC thresholds xfs: fix _xfs_buf_find oops on blocks beyond the filesystem end xfs: pull up stack_switch check into xfs_bmapi_write xfs: Do not return EFSCORRUPTED when filesystem probe finds no XFS magic
2013-01-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull one s390 fix from Martin Schwidefsky: "Another transparent huge page fix, we need to define a s390 variant for pmdp_set_wrprotect to flush the TLB for the huge page correctly." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/thp: implement pmdp_set_wrprotect()
2013-01-30Merge tag 'pinctrl-fixes-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pinctrl fixes from Linus Walleij: "This is a late pinctrl fix pull request, we had to revert out the pinctrl-single GPIO backend, because of, well, design issues. We're cooking a better thing for the next cycle. - Revert gpio request/free backend, new patch set in the works, will be for v3.9. Get this old cruft out before anyone hurts himself on it. - Kconfig buzz - Various compile warnings - MPP6 value for the Kirkwood" * tag 'pinctrl-fixes-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: pinctrl: nomadik: nmk_prcm_gpiocr_get_mode may be unused pinctrl: exynos: don't mark probing functions as __init Revert "pinctrl: single: support gpio request and free" pinctrl: mvebu: fix MPP6 value for kirkwood driver pinctrl: mvebu: Fix compiler warnings pinctrl: pinctrl-mxs: Fix variables' definition type pinctrl: samsung: removing duplicated condition for PINCTRL_SAMSUNG
2013-01-29pinctrl: nomadik: nmk_prcm_gpiocr_get_mode may be unusedArnd Bergmann
nmk_prcm_gpiocr_get_mode is only needed for debugfs output at the moment, which can be compile-time disabled. Marking the function __maybe_unused still gives us compile-time coverage, but avoids a gcc warning. Without this patch, building nhk8815_defconfig results in: drivers/pinctrl/pinctrl-nomadik.c:676:12: warning: 'nmk_prcm_gpiocr_get_mode' defined but not used [-Wunused-function] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Jean-Nicolas Graux <jean-nicolas.graux@stericsson.com> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-29pinctrl: exynos: don't mark probing functions as __initArnd Bergmann
Functions called from a driver probe() method must not be marked __init, because they may get called after the init phase is done, when the device shows up late, or because of deferred probing. Without this patch, building exynos_defconfig results in multiple warnings like: WARNING: drivers/pinctrl/built-in.o(.text+0x51bc): Section mismatch in reference from the function exynos5440_pinctrl_probe() to the function .init.text:exynos5440_gpiolib_register() The function exynos5440_pinctrl_probe() references the function __init exynos5440_gpiolib_register(). This is often because exynos5440_pinctrl_probe lacks a __init annotation or the annotation of exynos5440_gpiolib_register is wrong. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Tomasz Figa <t.figa@samsung.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-29x86, efi: remove attribute check from setup_efi_pciMaarten Lankhorst
It looks like the original commit that copied the rom contents from efi always copied the rom, and the fixup in setup_efi_pci from commit 886d751a2ea99a160 ("x86, efi: correct precedence of operators in setup_efi_pci") broke that. This resulted in macbook pro's no longer finding the rom images, and thus not being able to use the radeon card any more. The solution is to just remove the check for now, and always copy the rom if available. Reported-by: Vitaly Budovski <vbudovski+news@gmail.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Seth Forshee <seth.forshee@canonical.com> Acked-by: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2013-01-29ALSA: hda - Fix non-snoop page handlingTakashi Iwai
For non-snoop mode, we fiddle with the page attributes of CORB/RIRB and the position buffer, but also the ring buffers. The problem is that the current code blindly assumes that the buffer is contiguous. However, the ring buffers may be SG-buffers, thus a wrong vmapped address is passed there, leading to Oops. This patch fixes the handling for SG-buffers. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=800701 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-01-29ALSA: hda - Enable LPIB delay count for Poulsbo / OaktrailTakashi Iwai
Currently we use LPIB forcibly for both playback and capture for Poulsbo and Oaktrail devices, and this seems rather problematic. The recent fix for LPIB delay count seems working well with these devices, so let's enable it instead. Reported-by: Martin Weishart <martin.weishart@telosalliance.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-01-28Merge tag 'regulator-3.8-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator fixes from Mark Brown: "Fairly small stuff - a build failure fix for ST platforms, an error checking fix and an update to the MAINTAINERS file for Liam." * tag 'regulator-3.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: regulator: tps80031: Use IS_ERR to check return value of regulator_register() regulators: db8500: Fix compile failure for drivers/regulator/dbx500-prcmu.c regulator: MAINTAINERS: update email address
2013-01-29Merge remote-tracking branch 'regulator/fix/lrg' into tmpMark Brown
2013-01-29Merge remote-tracking branch 'regulator/fix/tps80031' into tmpMark Brown
2013-01-29Merge remote-tracking branch 'regulator/fix/db8500' into tmpMark Brown
2013-01-28Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc fixes from Benjamin Herrenschmidt: "Whenever you have a chance between two dives, you might want to consider pulling my merge branch to pickup a few fixes for 3.8 that have been accumulating for the last couple of weeks (I was myself travelling then on vacation). Nothing major, just a handful of powerpc bug fixes that I consider worth getting in before 3.8 goes final." And I'll have everybody know that I'm not diving for several days yet. Snif. * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Max next_tb to prevent from replaying timer interrupt powerpc: kernel/kgdb.c: Fix memory leakage powerpc/book3e: Disable interrupt after preempt_schedule_irq powerpc/oprofile: Fix error in oprofile power7_marked_instr_event() function powerpc/pasemi: Fix crash on reboot powerpc: Fix MAX_STACK_TRACE_ENTRIES too low warning for ppc32
2013-01-29powerpc: Max next_tb to prevent from replaying timer interruptTiejun Chen
With lazy interrupt, we always call __check_irq_replaysome with decrementers_next_tb to check if we need to replay timer interrupt. So in hotplug case we also need to set decrementers_next_tb as MAX to make sure __check_irq_replay don't replay timer interrupt when return as we expect, otherwise we'll trap here infinitely. Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-01-29powerpc: kernel/kgdb.c: Fix memory leakageCong Ding
the variable backup_current_thread_info isn't freed before existing the function. Signed-off-by: Cong Ding <dinggnu@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-01-29powerpc/book3e: Disable interrupt after preempt_schedule_irqTiejun Chen
In preempt case current arch_local_irq_restore() from preempt_schedule_irq() may enable hard interrupt but we really should disable interrupts when we return from the interrupt, and so that we don't get interrupted after loading SRR0/1. Signed-off-by: Tiejun Chen <tiejun.chen@windriver.com> CC: <stable@vger.kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-01-29powerpc/oprofile: Fix error in oprofile power7_marked_instr_event() functionCarl E. Love
The calculation for the left shift of the mask OPROFILE_PM_PMCSEL_MSK has an error. The calculation is should be to shift left by (max_cntrs - cntr) times the width of the pmsel field width. However, the #define OPROFILE_MAX_PMC_NUM was used instead of OPROFILE_PMSEL_FIELD_WIDTH. This patch fixes the calculation. Signed-off-by: Carl Love <cel@us.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-01-29powerpc/pasemi: Fix crash on rebootSteven Rostedt
commit f96972f2dc "kernel/sys.c: call disable_nonboot_cpus() in kernel_restart()" added a call to disable_nonboot_cpus() on kernel_restart(), which tries to shutdown all the CPUs except the first one. The issue with the PA Semi, is that it does not support CPU hotplug. When the call is made to __cpu_down(), it calls the notifiers CPU_DOWN_PREPARE, and then tries to take the CPU down. One of the notifiers to the CPU hotplug code, is the cpufreq. The DOWN_PREPARE will call __cpufreq_remove_dev() which calls cpufreq_driver->exit. The PA Semi exit handler unmaps regions of I/O that is used by an interrupt that goes off constantly (system_reset_common, but it goes off during normal system operations too). I'm not sure exactly what this interrupt does. Running a simple function trace, you can see it goes off quite a bit: # tracer: function # # TASK-PID CPU# TIMESTAMP FUNCTION # | | | | | <idle>-0 [001] 1558.859363: .pasemi_system_reset_exception <-.system_reset_exception <idle>-0 [000] 1558.860112: .pasemi_system_reset_exception <-.system_reset_exception <idle>-0 [000] 1558.861109: .pasemi_system_reset_exception <-.system_reset_exception <idle>-0 [001] 1558.861361: .pasemi_system_reset_exception <-.system_reset_exception <idle>-0 [000] 1558.861437: .pasemi_system_reset_exception <-.system_reset_exception When the region is unmapped, the system crashes with: Disabling non-boot CPUs ... Error taking CPU1 down: -38 Unable to handle kernel paging request for data at address 0xd0000800903a0100 Faulting instruction address: 0xc000000000055fcc Oops: Kernel access of bad area, sig: 11 [#1] PREEMPT SMP NR_CPUS=64 NUMA PA Semi PWRficient Modules linked in: shpchp NIP: c000000000055fcc LR: c000000000055fb4 CTR: c0000000000df1fc REGS: c0000000012175d0 TRAP: 0300 Not tainted (3.8.0-rc4-test-dirty) MSR: 9000000000009032 <SF,HV,EE,ME,IR,DR,RI> CR: 24000088 XER: 00000000 SOFTE: 0 DAR: d0000800903a0100, DSISR: 42000000 TASK = c0000000010e9008[0] 'swapper/0' THREAD: c000000001214000 CPU: 0 GPR00: d0000800903a0000 c000000001217850 c0000000012167e0 0000000000000000 GPR04: 0000000000000000 0000000000000724 0000000000000724 0000000000000000 GPR08: 0000000000000000 0000000000000000 0000000000000001 0000000000a70000 GPR12: 0000000024000080 c00000000fff0000 ffffffffffffffff 000000003ffffae0 GPR16: ffffffffffffffff 0000000000a21198 0000000000000060 0000000000000000 GPR20: 00000000008fdd35 0000000000a21258 000000003ffffaf0 0000000000000417 GPR24: 0000000000a226d0 c000000000000000 0000000000000000 0000000000000000 GPR28: c00000000138b358 0000000000000000 c000000001144818 d0000800903a0100 NIP [c000000000055fcc] .set_astate+0x5c/0xa4 LR [c000000000055fb4] .set_astate+0x44/0xa4 Call Trace: [c000000001217850] [c000000000055fb4] .set_astate+0x44/0xa4 (unreliable) [c0000000012178f0] [c00000000005647c] .restore_astate+0x2c/0x34 [c000000001217980] [c000000000054668] .pasemi_system_reset_exception+0x6c/0x88 [c000000001217a00] [c000000000019ef0] .system_reset_exception+0x48/0x84 [c000000001217a80] [c000000000001e40] system_reset_common+0x140/0x180 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-01-28Merge tag 'md-3.8-fixes' of git://neil.brown.name/mdLinus Torvalds
Pull dmraid fix from NeilBrown: "Just one fix for md in 3.8 dmraid assess redundancy and replacements slightly inaccurately which could lead to some degraded arrays failing to assemble." * tag 'md-3.8-fixes' of git://neil.brown.name/md: DM-RAID: Fix RAID10's check for sufficient redundancy
2013-01-29powerpc: Fix MAX_STACK_TRACE_ENTRIES too low warning for ppc32Li Zhong
This patch fixes MAX_STACK_TRACE_ENTRIES too low warning for ppc32, which is similar to commit 12660b17. Reported-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com> Tested-by: Christian Kujau <lists@nerdbynature.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-01-28xfs: Fix xfs_swap_extents() after removal of xfs_flushinval_pages()Torsten Kaiser
Commit fb59581404ab7ec5075299065c22cb211a9262a9 removed xfs_flushinval_pages() and changed its callers to use filemap_write_and_wait() and truncate_pagecache_range() directly. But in xfs_swap_extents() this change accidental switched the argument for 'tip' to 'ip'. This patch switches it back to 'tip' Signed-off-by: Torsten Kaiser <just.for.lkml@googlemail.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixesLinus Torvalds
Pull GFS2 fix from Steven Whitehouse. * git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes: GFS2: fix skip unlock condition
2013-01-28Merge tag 'iommu-fixes-v3.8-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU fix from Joerg Roedel: "One fix for the AMD IOMMU driver to work around broken BIOSes found in the field. Some BIOSes forget to enable a workaround for a hardware problem which might cause the IOMMU to stop working under high load conditions. The fix makes sure this workaround is enabled." * tag 'iommu-fixes-v3.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: IOMMU, AMD Family15h Model10-1Fh erratum 746 Workaround
2013-01-28Merge tag 'mfd-for-linus-3.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD fixes from Samuel Ortiz: "This is the first pull request for MFD fixes for 3.8 We have some build failure fixes (twl4030, vexpress, abx500 and tps65910), some actual runtime oops and lockup fixes (rtsx, da9052), and some more hypothetical NULL pointers dereferences fixes for pcf50633 and max776xx. Then we also have additional rtsx fixes for a correct switch output voltage and clock divider correctness for rtl8411 (rtsx driver), and irqdomain fix for db8550-prcmu, and some more cosmetic fixes for arizona and wm5102." * tag 'mfd-for-linus-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: mfd: rtsx: Fix oops when rtsx_pci_sdmmc is not probed mfd: wm5102: Fix definition of WM5102_MAX_REGISTER mfd: twl4030: Don't warn about uninitialized return code mfd: da9052/53 lockup fix mfd: rtsx: Add clock divider hook mmc: rtsx: Call MFD hook to switch output voltage mfd: rtsx: Add output voltage switch hook mfd: Fix compile errors and warnings when !CONFIG_AB8500_BM mfd: vexpress: Export global functions to fix build error mfd: arizona: Check errors from regcache_sync() mfd: tc3589x: Use simple irqdomain mfd: pcf50633: Init pcf->dev before using it mfd: max77693: Init max77693->dev before using it mfd: max77686: Init max77686->dev before using it mfd: db8500-prcmu: Fix irqdomain usage mfd: tps65910: Select REGMAP_IRQ in Kconfig to fix build error mfd: arizona: Disable control interface reporting for WM5102 and WM5110
2013-01-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking updates from David Miller: "Much more accumulated than I would have liked due to an unexpected bout with a nasty flu: 1) AH and ESP input don't set ECN field correctly because the transport head of the SKB isn't set correctly, fix from Li RongQing. 2) If netfilter conntrack zones are disabled, we can return an uninitialized variable instead of the proper error code. Fix from Borislav Petkov. 3) Fix double SKB free in ath9k driver beacon handling, from Felix Feitkau. 4) Remove bogus assumption about netns cleanup ordering in nf_conntrack, from Pablo Neira Ayuso. 5) Remove a bogus BUG_ON in the new TCP fastopen code, from Eric Dumazet. It uses spin_is_locked() in it's test and is therefore unsuitable for UP. 6) Fix SELINUX labelling regressions added by the tuntap multiqueue changes, from Paul Moore. 7) Fix CRC errors with jumbo frame receive in tg3 driver, from Nithin Nayak Sujir. 8) CXGB4 driver sets interrupt coalescing parameters only on first queue, rather than all of them. Fix from Thadeu Lima de Souza Cascardo. 9) Fix regression in the dispatch of read/write registers in dm9601 driver, from Tushar Behera. 10) ipv6_append_data miscalculates header length, from Romain KUNTZ. 11) Fix PMTU handling regressions on ipv4 routes, from Steffen Klassert, Timo Teräs, and Julian Anastasov. 12) In 3c574_cs driver, add necessary parenthesis to "x << y & z" expression. From Nickolai Zeldovich. 13) macvlan_get_size() causes underallocation netlink message space, fix from Eric Dumazet. 14) Avoid division by zero in xfrm_replay_advance_bmp(), from Nickolai Zeldovich. Amusingly the zero check was already there, we were just performing it after the modulus :-) 15) Some more splice bug fixes from Eric Dumazet, which fix things mostly eminating from how we now more aggressively use high-order pages in SKBs. 16) Fix size calculation bug when freeing hash tables in the IPSEC xfrm code, from Michal Kubecek. 17) Fix PMTU event propagation into socket cached routes, from Steffen Klassert. 18) Fix off by one in TX buffer release in netxen driver, from Eric Dumazet. 19) Fix rediculous memory allocation requirements introduced by the tuntap multiqueue changes, from Jason Wang. 20) Remove bogus AMD platform workaround in r8169 driver that causes major problems in normal operation, from Timo Teräs. 21) virtio-net set affinity and select queue don't handle discontiguous cpu numbers properly, fix from Wanlong Gao. 22) Fix a route refcounting issue in loopback driver, from Eric Dumazet. There's a similar fix coming that we might add to the macvlan driver as well. 23) Fix SKB leaks in batman-adv's distributed arp table code, from Matthias Schiffer. 24) r8169 driver gives descriptor ownership back the hardware before we're done reading the VLAN tag out of it, fix from Francois Romieu. 25) Checksums not calculated properly in GRE tunnel driver fix from Pravin B Shelar. 26) Fix SCTP memory leak on namespace exit." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (101 commits) dm9601: support dm9620 variant SCTP: Free the per-net sysctl table on net exit. v2 net: phy: icplus: fix broken INTR pin settings net: phy: icplus: Use the RGMII interface mode to configure clock delays IP_GRE: Fix kernel panic in IP_GRE with GRE csum. sctp: set association state to established in dupcook_a handler ip6mr: limit IPv6 MRT_TABLE identifiers r8169: fix vlan tag read ordering. net: cdc_ncm: use IAD provided by the USB core batman-adv: filter ARP packets with invalid MAC addresses in DAT batman-adv: check for more types of invalid IP addresses in DAT batman-adv: fix skb leak in batadv_dat_snoop_incoming_arp_reply() net: loopback: fix a dst refcounting issue virtio-net: reset virtqueue affinity when doing cpu hotplug virtio-net: split out clean affinity function virtio-net: fix the set affinity bug when CPU IDs are not consecutive can: pch_can: fix invalid error codes can: ti_hecc: fix invalid error codes can: c_can: fix invalid error codes r8169: remove the obsolete and incorrect AMD workaround ...
2013-01-28xfs: Fix possible use-after-free with AIOJan Kara
Running AIO is pinning inode in memory using file reference. Once AIO is completed using aio_complete(), file reference is put and inode can be freed from memory. So we have to be sure that calling aio_complete() is the last thing we do with the inode. CC: xfs@oss.sgi.com CC: Ben Myers <bpm@sgi.com> CC: stable@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28xfs: fix shutdown hang on invalid inode during createDave Chinner
When the new inode verify in xfs_iread() fails, the create transaction is aborted and a shutdown occurs. The subsequent unmount then hangs in xfs_wait_buftarg() on a buffer that has an elevated hold count. Debug showed that it was an AGI buffer getting stuck: [ 22.576147] XFS (vdb): buffer 0x2/0x1, hold 0x2 stuck [ 22.976213] XFS (vdb): buffer 0x2/0x1, hold 0x2 stuck [ 23.376206] XFS (vdb): buffer 0x2/0x1, hold 0x2 stuck [ 23.776325] XFS (vdb): buffer 0x2/0x1, hold 0x2 stuck The trace of this buffer leading up to the shutdown (trimmed for brevity) looks like: xfs_buf_init: bno 0x2 nblks 0x1 hold 1 caller xfs_buf_get_map xfs_buf_get: bno 0x2 len 0x200 hold 1 caller xfs_buf_read_map xfs_buf_read: bno 0x2 len 0x200 hold 1 caller xfs_trans_read_buf_map xfs_buf_iorequest: bno 0x2 nblks 0x1 hold 1 caller _xfs_buf_read xfs_buf_hold: bno 0x2 nblks 0x1 hold 1 caller xfs_buf_iorequest xfs_buf_rele: bno 0x2 nblks 0x1 hold 2 caller xfs_buf_iorequest xfs_buf_iowait: bno 0x2 nblks 0x1 hold 1 caller _xfs_buf_read xfs_buf_ioerror: bno 0x2 len 0x200 hold 1 caller xfs_buf_bio_end_io xfs_buf_iodone: bno 0x2 nblks 0x1 hold 1 caller _xfs_buf_ioend xfs_buf_iowait_done: bno 0x2 nblks 0x1 hold 1 caller _xfs_buf_read xfs_buf_hold: bno 0x2 nblks 0x1 hold 1 caller xfs_buf_item_init xfs_trans_read_buf: bno 0x2 len 0x200 hold 2 recur 0 refcount 1 xfs_trans_brelse: bno 0x2 len 0x200 hold 2 recur 0 refcount 1 xfs_buf_item_relse: bno 0x2 nblks 0x1 hold 2 caller xfs_trans_brelse xfs_buf_rele: bno 0x2 nblks 0x1 hold 2 caller xfs_buf_item_relse xfs_buf_unlock: bno 0x2 nblks 0x1 hold 1 caller xfs_trans_brelse xfs_buf_rele: bno 0x2 nblks 0x1 hold 1 caller xfs_trans_brelse xfs_buf_trylock: bno 0x2 nblks 0x1 hold 2 caller _xfs_buf_find xfs_buf_find: bno 0x2 len 0x200 hold 2 caller xfs_buf_get_map xfs_buf_get: bno 0x2 len 0x200 hold 2 caller xfs_buf_read_map xfs_buf_read: bno 0x2 len 0x200 hold 2 caller xfs_trans_read_buf_map xfs_buf_hold: bno 0x2 nblks 0x1 hold 2 caller xfs_buf_item_init xfs_trans_read_buf: bno 0x2 len 0x200 hold 3 recur 0 refcount 1 xfs_trans_log_buf: bno 0x2 len 0x200 hold 3 recur 0 refcount 1 xfs_buf_item_unlock: bno 0x2 len 0x200 hold 3 flags DIRTY liflags ABORTED xfs_buf_unlock: bno 0x2 nblks 0x1 hold 3 caller xfs_buf_item_unlock xfs_buf_rele: bno 0x2 nblks 0x1 hold 3 caller xfs_buf_item_unlock And that is the AGI buffer from cold cache read into memory to transaction abort. You can see at transaction abort the bli is dirty and only has a single reference. The item is not pinned, and it's not in the AIL. Hence the only reference to it is this transaction. The problem is that the xfs_buf_item_unlock() call is dropping the last reference to the xfs_buf_log_item attached to the buffer (which holds a reference to the buffer), but it is not freeing the xfs_buf_log_item. Hence nothing will ever release the buffer, and the unmount hangs waiting for this reference to go away. The fix is simple - xfs_buf_item_unlock needs to detect the last reference going away in this case and free the xfs_buf_log_item to release the reference it holds on the buffer. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28xfs: limit speculative prealloc near ENOSPC thresholdsDave Chinner
There is a window on small filesytsems where specualtive preallocation can be larger than that ENOSPC throttling thresholds, resulting in specualtive preallocation trying to reserve more space than there is space available. This causes immediate ENOSPC to be triggered, prealloc to be turned off and flushing to occur. One the next write (i.e. next 4k page), we do exactly the same thing, and so effective drive into synchronous 4k writes by triggering ENOSPC flushing on every page while in the window between the prealloc size and the ENOSPC prealloc throttle threshold. Fix this by checking to see if the prealloc size would consume all free space, and throttle it appropriately to avoid premature ENOSPC... Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28xfs: fix _xfs_buf_find oops on blocks beyond the filesystem endDave Chinner
When _xfs_buf_find is passed an out of range address, it will fail to find a relevant struct xfs_perag and oops with a null dereference. This can happen when trying to walk a filesystem with a metadata inode that has a partially corrupted extent map (i.e. the block number returned is corrupt, but is otherwise intact) and we try to read from the corrupted block address. In this case, just fail the lookup. If it is readahead being issued, it will simply not be done, but if it is real read that fails we will get an error being reported. Ideally this case should result in an EFSCORRUPTED error being reported, but we cannot return an error through xfs_buf_read() or xfs_buf_get() so this lookup failure may result in ENOMEM or EIO errors being reported instead. Signed-off-by: Dave Chinner <dchinner@redhat.com> Reviewed-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Ben Myers <bpm@sgi.com> Signed-off-by: Ben Myers <bpm@sgi.com>
2013-01-28xfs: pull up stack_switch check into xfs_bmapi_writeBrian Foster
The stack_switch check currently occurs in __xfs_bmapi_allocate, which means the stack switch only occurs when xfs_bmapi_allocate() is called in a loop. Pull the check up before the loop in xfs_bmapi_write() such that the first iteration of the loop has consistent behavior. Signed-off-by: Brian Foster <bfoster@redhat.com> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Ben Myers <bpm@sgi.com>
