2009-04-01mm: reintroduce and deprecate rlimit based access for SHM_HUGETLBRavikiran G Thirumalai
Allow non root users with sufficient mlock rlimits to be able to allocate hugetlb backed shm for now. Deprecate this though. This is being deprecated because the mlock based rlimit checks for SHM_HUGETLB is not consistent with mmap based huge page allocations. Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Reviewed-by: Mel Gorman <mel@csn.ul.ie> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Adam Litke <agl@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: fix SHM_HUGETLB to work with users in hugetlb_shm_groupRavikiran G Thirumalai
Fix hugetlb subsystem so that non root users belonging to hugetlb_shm_group can actually allocate hugetlb backed shm. Currently non root users cannot even map one large page using SHM_HUGETLB when they belong to the gid in /proc/sys/vm/hugetlb_shm_group. This is because allocation size is verified against RLIMIT_MEMLOCK resource limit even if the user belongs to hugetlb_shm_group. This patch 1. Fixes hugetlb subsystem so that users with CAP_IPC_LOCK and users belonging to hugetlb_shm_group don't need to be restricted with RLIMIT_MEMLOCK resource limits 2. This patch also disables mlock based rlimit checking (which will be reinstated and marked deprecated in a subsequent patch). Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org> Reviewed-by: Mel Gorman <mel@csn.ul.ie> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Adam Litke <agl@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01vfs: add/use account_page_dirtied()Edward Shishkin
Add a helper function account_page_dirtied(). Use that from two callsites. reiser4 adds a function which adds a third callsite. Signed-off-by: Edward Shishkin<edward.shishkin@gmail.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01vmscan: respect higher order in zone_reclaim()Johannes Weiner
During page allocation, there are two stages of direct reclaim that are applied to each zone in the preferred list. The first stage using zone_reclaim() reclaims unmapped file backed pages and slab pages if over defined limits as these are cheaper to reclaim. The caller specifies the order of the target allocation but the scan control is not being correctly initialised. The impact is that the correct number of pages are being reclaimed but that lumpy reclaim is not being applied. This increases the chances of a full direct reclaim via try_to_free_pages() is required. This patch initialises the order field of the scan control as requested by the caller. [mel@csn.ul.ie: rewrote changelog] Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Rik van Riel <riel@redhat.com> Cc: Andy Whitcroft <apw@shadowen.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: add comment why mark_page_accessed() would be better than pte_mkyoung() ↵KOSAKI Motohiro
in follow_page() At first look, mark_page_accessed() in follow_page() seems a bit strange. It seems pte_mkyoung() would be better consistent with other kernel code. However, it is intentional. The commit log said: ------------------------------------------------ commit 9e45f61d69be9024a2e6bef3831fb04d90fac7a8 Author: akpm <akpm> Date: Fri Aug 15 07:24:59 2003 +0000 [PATCH] Use mark_page_accessed() in follow_page() Touching a page via follow_page() counts as a reference so we should be either setting the referenced bit in the pte or running mark_page_accessed(). Altering the pte is tricky because we haven't implemented an atomic pte_mkyoung(). And mark_page_accessed() is better anyway because it has more aging state: it can move the page onto the active list. BKrev: 3f3c8acbplT8FbwBVGtth7QmnqWkIw ------------------------------------------------ The atomic issue is still true nowadays. adding comment help to understand code intention and it would be better. [akpm@linux-foundation.org: clarify text] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01vmscan: clip swap_cluster_max in shrink_all_memory()Johannes Weiner
shrink_inactive_list() scans in sc->swap_cluster_max chunks until it hits the scan limit it was passed. shrink_inactive_list() { do { isolate_pages(swap_cluster_max) shrink_page_list() } while (nr_scanned < max_scan); } This assumes that swap_cluster_max is not bigger than the scan limit because the latter is checked only after at least one iteration. In shrink_all_memory() sc->swap_cluster_max is initialized to the overall reclaim goal in the beginning but not decreased while reclaim is making progress which leads to subsequent calls to shrink_inactive_list() reclaiming way too much in the one iteration that is done unconditionally. Set sc->swap_cluster_max always to the proper goal before doing shrink_all_zones() shrink_list() shrink_inactive_list(). While the current shrink_all_memory() happily reclaims more than actually requested, this patch fixes it to never exceed the goal: unpatched wanted=10000 reclaimed=13356 wanted=10000 reclaimed=19711 wanted=10000 reclaimed=10289 wanted=10000 reclaimed=17306 wanted=10000 reclaimed=10700 wanted=10000 reclaimed=10004 wanted=10000 reclaimed=13301 wanted=10000 reclaimed=10976 wanted=10000 reclaimed=10605 wanted=10000 reclaimed=10088 wanted=10000 reclaimed=15000 patched wanted=10000 reclaimed=10000 wanted=10000 reclaimed=9599 wanted=10000 reclaimed=8476 wanted=10000 reclaimed=8326 wanted=10000 reclaimed=10000 wanted=10000 reclaimed=10000 wanted=10000 reclaimed=9919 wanted=10000 reclaimed=10000 wanted=10000 reclaimed=10000 wanted=10000 reclaimed=10000 wanted=10000 reclaimed=10000 wanted=10000 reclaimed=9624 wanted=10000 reclaimed=10000 wanted=10000 reclaimed=10000 wanted=8500 reclaimed=8092 wanted=316 reclaimed=316 Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: MinChan Kim <minchan.kim@gmail.com> Acked-by: Nigel Cunningham <ncunningham@crca.org.au> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: shrink_all_memory(): use sc.nr_reclaimedMinChan Kim
Commit a79311c14eae4bb946a97af25f3e1b17d625985d "vmscan: bail out of direct reclaim after swap_cluster_max pages" moved the nr_reclaimed counter into the scan control to accumulate the number of all reclaimed pages in a reclaim invocation. shrink_all_memory() can use the same mechanism. it increase code consistency and redability. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: MinChan Kim <minchan.kim@gmail.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: don't call mark_page_accessed() in do_swap_page()KOSAKI Motohiro
commit bf3f3bc5e734706730c12a323f9b2068052aa1f0 (mm: don't mark_page_accessed in fault path) only remove the mark_page_accessed() in filemap_fault(). Therefore, swap-backed pages and file-backed pages have inconsistent behavior. mark_page_accessed() should be removed from do_swap_page(). Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: introduce for_each_populated_zone() macroKOSAKI Motohiro
Impact: cleanup In almost cases, for_each_zone() is used with populated_zone(). It's because almost function doesn't need memoryless node information. Therefore, for_each_populated_zone() can help to make code simplify. This patch has no functional change. [akpm@linux-foundation.org: small cleanup] Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01vmscan: rename sc.may_swap to may_unmapJohannes Weiner
sc.may_swap does not only influence reclaiming of anon pages but pages mapped into pagetables in general, which also includes mapped file pages. In shrink_page_list(): if (!sc->may_swap && page_mapped(page)) goto keep_locked; For anon pages, this makes sense as they are always mapped and reclaiming them always requires swapping. But mapped file pages are skipped here as well and it has nothing to do with swapping. The real effect of the knob is whether mapped pages are unmapped and reclaimed or not. Rename it to `may_unmap' to have its name match its actual meaning more precisely. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: MinChan Kim <minchan.kim@gmail.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01get_mm_hiwater_xxx: trivial, s/define/inline/Oleg Nesterov
Andrew pointed out get_mm_hiwater_xxx() evaluate "mm" argument thrice/twice, make them inline. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Hugh Dickins <hugh@veritas.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01oom_kill: don't call for int_sqrt(0)Cyrill Gorcunov
There is no need to call for int_sqrt if argument is 0. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Christoph Lameter <cl@linux-foundation.org> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01vmap: remove needless lock and list in vmapMinChan Kim
vmap's dirty_list is unused. It's for optimizing flushing. but Nick didn't write the code yet. so, we don't need it until time as it is needed. This patch removes vmap_block's dirty_list and codes related to it. Signed-off-by: MinChan Kim <minchan.kim@gmail.com> Acked-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01mm: mminit_validate_memmodel_limits(): remove redundant testCyrill Gorcunov
In case if start_pfn overlap the upper bound no need to test end_pfn again since we have it already trimmed. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01proc tty: remove struct tty_operations::read_procAlexey Dobriyan
struct tty_operations::proc_fops took it's place and there is one less create_proc_read_entry() user now! Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01proc tty: switch xtensa iss console to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch ia64 simserial to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch amiserial to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch ircomm to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch usb-serial to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch serial_core to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch sdio_uart to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch synclinkmp to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch synclink_gt to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch synclink to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch stallion to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch synclink_cs to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch istallion to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch ip2 to ->proc_fopsAlexey Dobriyan
2009-04-01proc tty: switch cyclades to ->proc_fopsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01proc tty: add struct tty_operations::proc_fopsAlexey Dobriyan
Used for gradual switch of TTY drivers from using ->read_proc which helps with gradual switch from ->read_proc for the whole tree. As side effect, fix possible race condition when ->data initialized after PDE is hooked into proc tree. ->proc_fops takes precedence over ->read_proc. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: wireless: remove duplicated .ndo_set_mac_address netfilter: xtables: fix IPv6 dependency in the cluster match tg3: Add GRO support. niu: Add GRO support. ucc_geth: Fix use-after-of_node_put() in ucc_geth_probe(). gianfar: Fix use-after-of_node_put() in gfar_of_init(). kernel: remove HIPQUAD() netpoll: store local and remote ip in net-endian netfilter: fix endian bug in conntrack printks dmascc: fix incomplete conversion to network_device_ops gso: Fix support for linear packets skbuff.h: fix missing kernel-doc ni5010: convert to net_device_ops
2009-03-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Fix reset hangs on Niagara systems. cpumask: use mm_cpumask() wrapper: sparc cpumask: remove dangerous CPU_MASK_ALL_PTR, &CPU_MASK_ALL.: sparc cpumask: remove the now-obsoleted pcibus_to_cpumask(): sparc cpumask: remove cpu_coregroup_map: sparc cpumask: prepare for iterators to only go to nr_cpu_ids/nr_cpumask_bits.: sparc cpumask: prepare for iterators to only go to nr_cpu_ids/nr_cpumask_bits.: sparc64 cpumask: Use accessors code.: sparc64 cpumask: Use accessors code: sparc cpumask: arch_send_call_function_ipi_mask: sparc cpumask: Use smp_call_function_many(): sparc64
2009-03-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumaskLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-cpumask: oprofile: Thou shalt not call __exit functions from __init functions cpumask: remove the now-obsoleted pcibus_to_cpumask(): generic cpumask: remove cpumask_t from core cpumask: convert rcutorture.c cpumask: use new cpumask_ functions in core code. cpumask: remove references to struct irqaction's mask field. cpumask: use mm_cpumask() wrapper: kernel/fork.c cpumask: use set_cpu_active in init/main.c cpumask: remove node_to_first_cpu cpumask: fix seq_bitmap_*() functions. cpumask: remove dangerous CPU_MASK_ALL_PTR, &CPU_MASK_ALL
2009-03-30Merge ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-lguest-and-virtio * git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-lguest-and-virtio: lguest: barrier me harder lguest: use bool instead of int lguest: use KVM hypercalls lguest: wire up pte_update/pte_update_defer lguest: fix spurious BUG_ON() on invalid guest stack. virtio: more neatening of virtio_ring macros. virtio: fix BAD_RING, START_US and END_USE macros
2009-03-30Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: hwmon: (fschmd) Add support for the FSC Hades IC hwmon: (fschmd) Add support for the FSC Syleus IC i2c-i801: Instantiate FSC hardware montioring chips dmi: Let dmi_walk() users pass private data hwmon: Define a standard interface for chassis intrusion detection Move the pcf8591 driver to hwmon hwmon: (w83627ehf) Only expose in6 or temp3 on the W83667HG hwmon: (w83627ehf) Add support for W83667HG hwmon: (w83627ehf) Invert fan pin variables logic hwmon: (hdaps) Fix Thinkpad X41 axis inversion hwmon: (hdaps) Allow inversion of separate axis hwmon: (ds1621) Clean up documentation hwmon: (ds1621) Avoid unneeded register access hwmon: (ds1621) Clean up register access hwmon: (ds1621) Reorder code statements
2009-03-30Merge branch 'locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (33 commits) lockdep: fix deadlock in lockdep_trace_alloc lockdep: annotate reclaim context (__GFP_NOFS), fix SLOB lockdep: annotate reclaim context (__GFP_NOFS), fix lockdep: build fix for !PROVE_LOCKING lockstat: warn about disabled lock debugging lockdep: use stringify.h lockdep: simplify check_prev_add_irq() lockdep: get_user_chars() redo lockdep: simplify get_user_chars() lockdep: add comments to mark_lock_irq() lockdep: remove macro usage from mark_held_locks() lockdep: fully reduce mark_lock_irq() lockdep: merge the !_READ mark_lock_irq() helpers lockdep: merge the _READ mark_lock_irq() helpers lockdep: simplify mark_lock_irq() helpers #3 lockdep: further simplify mark_lock_irq() helpers lockdep: simplify the mark_lock_irq() helpers lockdep: split up mark_lock_irq() lockdep: generate usage strings lockdep: generate the state bit definitions ...
2009-03-30Merge branch 'proc-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc * 'proc-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc: Revert "proc: revert /proc/uptime to ->read_proc hook" proc 2/2: remove struct proc_dir_entry::owner proc 1/2: do PDE usecounting even for ->read_proc, ->write_proc proc: fix sparse warnings in pagemap_read() proc: move fs/proc/inode-alloc.txt comment into a source file
2009-03-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PCI PM: Make pci_prepare_to_sleep() disable wake-up if needed radeonfb: Use __pci_complete_power_transition() PCI PM: Introduce __pci_[start|complete]_power_transition() (rev. 2) PCI PM: Restore config spaces of all devices during early resume PCI PM: Make pci_set_power_state() handle devices with no PM support PCI PM: Put devices into low power states during late suspend (rev. 2) PCI PM: Move pci_restore_standard_config to pci-driver.c PCI PM: Use pci_set_power_state during early resume PCI PM: Consistently use variable name "error" for pm call return values kexec: Change kexec jump code ordering PM: Change hibernation code ordering PM: Change suspend code ordering PM: Rework handling of interrupts during suspend-resume PM: Introduce functions for suspending and resuming device interrupts
2009-03-30dma-debug: fix printk formats (i386)Randy Dunlap
Fix printk format warnings in dma-debug: lib/dma-debug.c:645: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' lib/dma-debug.c:662: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' lib/dma-debug.c:676: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' lib/dma-debug.c:686: warning: format '%016llx' expects type 'long long unsigned int', but argument 6 has type 'dma_addr_t' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: xattr_create is unused with xattrs disabledJeff Mahoney
This patch ifdefs xattr_create when xattrs aren't enabled. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: fix build breakageAlexander Beregalov
Fix this build error when REISERFS_FS_POSIX_ACL is not set: fs/reiserfs/inode.c: In function 'reiserfs_new_inode': fs/reiserfs/inode.c:1919: warning: passing argument 1 of 'reiserfs_inherit_default_acl' from incompatible pointer type fs/reiserfs/inode.c:1919: warning: passing argument 2 of 'reiserfs_inherit_default_acl' from incompatible pointer type fs/reiserfs/inode.c:1919: warning: passing argument 3 of 'reiserfs_inherit_default_acl' from incompatible pointer type fs/reiserfs/inode.c:1919: error: too many arguments to function 'reiserfs_inherit_default_acl' due to a missing transaction-handle argument in the non-acl compatibility function. Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30lockdep: fix deadlock in lockdep_trace_allocPeter Zijlstra
Heiko reported that we grab the graph lock with irqs enabled. Fix this by providng the same wrapper as all other lockdep entry functions have. Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <npiggin@suse.de> LKML-Reference: <1237544000.24626.52.camel@twins> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31Revert "proc: revert /proc/uptime to ->read_proc hook"Alexey Dobriyan
This reverts commit 6c87df37dcb9c6c33923707fa5191e0a65874d60. proc files implemented through seq_file do pread(2) now. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-31proc 1/2: do PDE usecounting even for ->read_proc, ->write_procAlexey Dobriyan
struct proc_dir_entry::owner is going to be removed. Now it's only necessary to protect PDEs which are using ->read_proc, ->write_proc hooks. However, ->owner assignments are racy and make it very easy for someone to switch ->owner on live PDE (as some subsystems do) without fixing refcounts and so on. http://bugzilla.kernel.org/show_bug.cgi?id=12454 So, ->owner is on death row. Proxy file operations exist already (proc_file_operations), just bump usecount when necessary. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-31proc: fix sparse warnings in pagemap_read()Milind Arun Choudhary
fs/proc/task_mmu.c:696:12: warning: cast removes address space of expression fs/proc/task_mmu.c:696:9: warning: incorrect type in assignment (different address spaces) fs/proc/task_mmu.c:696:9: expected unsigned long long [noderef] [usertype] <asn:1>*out fs/proc/task_mmu.c:696:9: got unsigned long long [usertype] *<noident> fs/proc/task_mmu.c:697:12: warning: cast removes address space of expression fs/proc/task_mmu.c:697:9: warning: incorrect type in assignment (different address spaces) fs/proc/task_mmu.c:697:9: expected unsigned long long [noderef] [usertype] <asn:1>*end fs/proc/task_mmu.c:697:9: got unsigned long long [usertype] *<noident> fs/proc/task_mmu.c:723:12: warning: cast removes address space of expression fs/proc/task_mmu.c:723:26: error: subtraction of different types can't work (different address spaces) fs/proc/task_mmu.c:725:24: error: subtraction of different types can't work (different address spaces) Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-31proc: move fs/proc/inode-alloc.txt comment into a source fileRandy Dunlap
so that people will realize that it exists and can update it as needed. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-03-30lockdep: annotate reclaim context (__GFP_NOFS), fix SLOBIngo Molnar
Impact: build fix fix typo in mm/slob.c: mm/slob.c:469: error: ‘flags’ undeclared (first use in this function) mm/slob.c:469: error: (Each undeclared identifier is reported only once mm/slob.c:469: error: for each function it appears in.) Cc: Nick Piggin <npiggin@suse.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20090128135457.350751756@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-30Merge branch 'drm-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (53 commits) drm: detect hdmi monitor by hdmi identifier (v3) drm: drm_fops.c unlock missing on error path drm: reorder struct drm_ioctl_desc to save space on 64 bit builds radeon: add some new pci ids drm: read EDID extensions from monitor drm: Use a little stash on the stack to avoid kmalloc in most DRM ioctls. drm/radeon: add regs required for occlusion queries support drm/i915: check the return value from the copy from user drm/radeon: fix logic in r600_page_table_init() to match ati_gart drm/radeon: r600 ptes are 64-bit, cleanup cleanup function. drm/radeon: don't call irq changes on r600 suspend/resume drm/radeon: fix r600 writeback across suspend/resume drm/radeon: fix r600 writeback setup. drm: fix warnings about new mappings in info code. drm/radeon: NULL noise: drivers/gpu/drm/radeon/radeon_*.c drm/radeon: fix r600 pci mapping calls. drm/radeon: r6xx/r7xx: fix possible oops in r600_page_table_cleanup() radeon: call the correct idle function, logic got inverted. drm/radeon: RS600: fix interrupt handling drm/r600: fix rptr address along lines of previous fixes to radeon. ...
