2014-07-14[media] si2157: Add support for Si2158 chipOlli Salonen
Add support for Si2158 A20 chip. Signed-off-by: Olli Salonen <olli.salonen@iki.fi> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-14[media] si2157: Move chip initialization to si2157_initOlli Salonen
Move chip initialization related code from si2157_set_params to si2157_init. Signed-off-by: Olli Salonen <olli.salonen@iki.fi> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-14[media] si2168: Add support for chip revision Si2168 A30Olli Salonen
Add handling for different chip revisions and firmwares. Signed-off-by: Olli Salonen <olli.salonen@iki.fi> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-14[media] si2168: Small typo fix (SI2157 -> SI2168)Olli Salonen
2014-07-14[media] si2168: receive 4 bytes reply from cmd 0x14Antti Palosaari
Command 0x14 returns 4 bytes as a reply. It is used for setting key/value pairs to firmware and it returns 4 bytes back including old value. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-14[media] si2168: do not set values which are already on defaultAntti Palosaari
No need to set explicitly value that are already defaulted same. Setting new value returns old value. Firmware default values can be found just looking returned value. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-14[media] si2168: remove duplicate commandAntti Palosaari
Same command was executed twice, but different value. Remove redundant command. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-14[media] si2157: add read data support for fw cmd funcAntti Palosaari
We want also read data from firmware. Add support for it. Copied from si2168 driver. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-14[media] si2168: implement CNR statisticAntti Palosaari
Implement CNR statistic. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-14[media] si2168: set cmd args using memcpyAntti Palosaari
Use memcpy for set cmd buffer in order to keep style in line with rest of file. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-14[media] si2168: implement sleepAntti Palosaari
Implement sleep for power-management. Signed-off-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-14[media] si2157: implement sleepAntti Palosaari
2014-07-07[media] dib8000: improve the message that reports per-layer locksMauro Carvalho Chehab
The message is currently highly encoded: [70299.863521] DiB8000: Mpeg locks [ L0 : 0 | L1 : 1 | L2 : 0 ] And doesn't properly reflect that some problems might have happened. Instead, display it as: [75160.822321] DiB8000: Not all ISDB-T layers locked in 32 ms: Layer A NOT LOCKED, Layer B locked, Layer C not enabled In order to better reflect what's happening with layer locking. Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib8000: improve debug messagesMauro Carvalho Chehab
When debug is enabled: - Report when frontend gets restarted; - Be coherent on the displayed lines; - Show the transmission mode; - Hide unused layers. No functional changes (except at the printk's). Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib8000: Update the ADC gain tableMauro Carvalho Chehab
This table doesn't match the new one. Update it. Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib8000: use jifies instead of current_kernel_time()Mauro Carvalho Chehab
Instead of doing the tuning delays and timeouts using current_kernel_time(), use jiffies. That consumes less CPU cycles, and it is monotonic. Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib0090: Fix the sleep time at the state machineMauro Carvalho Chehab
msleep() is not too precise: its precision depends on the HZ config. As the driver selects precise timings for the state machine, change it to usleep_range(). Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib8000: Fix the sleep time at the state machineMauro Carvalho Chehab
2014-07-07[media] dib0700: better document struct initMauro Carvalho Chehab
Instead of using anonymous initialization for dib0896 structs, identify each field by name. That helps to understand what's being initialized. No functional changes. Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib8000: Restart sad during dib8000_resetMauro Carvalho Chehab
Just like the Windows driver, restart SAD during reset Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib8000: In auto-search, try first with partial reception enabledMauro Carvalho Chehab
TV broadcasters generally use partial reception. So, enable it by default in auto-search mode. The driver will latter detect if the transmission is on some other mode. Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib8000: remove a double call for dib8000_get_symbol_duration()Mauro Carvalho Chehab
The symbol duration was already obtained at CT_DEMOD_START. No need to do it again at CT_DEMOD_STEP_3. Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib8000: Fix: add missing 4K FFT modeMauro Carvalho Chehab
Without that, tuning may fail on 4K FFT mode, as the transmission parameter cache will be initialized with a wrong value. Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib8000: Fix alignments at dib8000_tune()Mauro Carvalho Chehab
There are two tabs instead of one aligning this struct. Worse than that, on some places, the alignment is wrong. Fix it. No functional changes. Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib8000: Fix ADC OFF settingsMauro Carvalho Chehab
The ADC OFF values are wrong. This causes troubles on detecting weak signals. Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-07[media] dib8000: Fix handling of interleave bigger than 2Mauro Carvalho Chehab
If interleave is bigger than 2, the code will set it to 0, as dib8000 registers use a log2(). So, change the code to handle it accordingly. Acked-By: Patrick Boettcher <pboettcher@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] media: Documentation: remove V4L2_FL_USE_FH_PRIO flagRamakrishnan Muthukrishnan
The V4L2_FL_USE_FH_PRIO has been removed from the code, now remove it from the documentation. Signed-off-by: Ramakrishnan Muthukrishnan <ramakrmu@cisco.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] media: v4l2-dev.h: remove V4L2_FL_USE_FH_PRIO flagRamakrishnan Muthukrishnan
Since none of the drivers are using it, this flag can be removed. Signed-off-by: Ramakrishnan Muthukrishnan <ramakrmu@cisco.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] media: remove the setting of the flag V4L2_FL_USE_FH_PRIORamakrishnan Muthukrishnan
Since all the drivers that use `struct v4l2_fh' use the core priority checking, the setting of the flag in the drivers can be removed. Signed-off-by: Ramakrishnan Muthukrishnan <ramakrmu@cisco.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] media: v4l2-core: remove the use of V4L2_FL_USE_FH_PRIO flagRamakrishnan Muthukrishnan
Since all the drivers that use `struct v4l2_fh' use the core priority checking instead of doing it themselves, this flag can be removed. This patch removes the usage of the flag from v4l2-core. Signed-off-by: Ramakrishnan Muthukrishnan <ramakrmu@cisco.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] adv7604: Update recommended writes for the adv7611Lars-Peter Clausen
Update the recommended writes to those mentioned in the Rev 1.5 version of the ADV7611 Register Settings Recommendations document released by Analog Devices. The document does not mention why the recommended settings have been updated, but presumably those are more fine tuned settings that can enhance performance in some cases. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] videobuf2-dma-contig: allow to vmap contiguous dma buffersPhilipp Zabel
This allows drivers to vmap contiguous dma buffers so they can inspect the buffer contents with the CPU. This will be needed for the CODA driver's JPEG handling. On CODA960, the header parsing has to be done on the CPU. The hardware modules can only process the entropy coded segment after all registers and tables are set up. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] mem2mem: make queue lock in v4l2_m2m_poll interruptiblePhilipp Zabel
This patch makes the queue lock taken in v4l2_m2m_poll interruptible. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] staging: solo6x10: fix for sparse warning messageAnthony DeStefano
Define jpeg_dqt as static. Signed-off-by: Anthony DeStefano <adx@fastmail.fm> Signed-off-by: Ismael Luceno <ismael.luceno@corp.bluecherry.net> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] sn9c102: remove deprecated driverHans Verkuil
During the media summit meeting in Edinburgh it was decided to move this driver to staging as the first step to removing it altogether. Most webcams covered by this driver are now supported by gspca. Nobody has the hardware or is willing to convert the remaining devices to gspca. This driver needs a major overhaul to have it conform to the latest frameworks and compliancy tests. Without hardware, however, this is next to impossible. Given the fact that this driver seems to be pretty much unused (it has been removed from Fedora several versions ago and nobody complained about that), we decided to drop this driver. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: Luca Risolia <luca.risolia@studio.unibo.it> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] cx18: remove duplicate CX18_ALSA_DBGFLG_WARN defineDan Carpenter
The CX18_ALSA_DBGFLG_WARN is cut and pasted twice and we can delete the second instance. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] staging/media/rtl2832u_sdr: fix coding style problems by adding ↵Ovidiu Toader
blank lines This minor patch fixes all WARNING:SPACING style warnings in rtl2832_sdr.c The new version of the file pleases checkpatch.pl when run with "--ignore LONG_LINE". Signed-off-by: Ovidiu Toader <ovi@phas.ubc.ca> Acked-by: Antti Palosaari <crope@iki.fi> Reviewed-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] dm644x_ccdc: remove check for CONFIG_DM644X_VIDEO_PORT_ENABLEPaul Bolle
A check for CONFIG_DM644X_VIDEO_PORT_ENABLE was added in v2.6.32. The related Kconfig symbol was never added so this check has always evaluated to false. Remove that check. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] staging: rtl2832_sdr: fixup checkpatch/style issuesAnthony DeStefano
rtl2832_sdr.c: fixup checkpatch issues about long lines Aligned stuff under the ( for this version. Signed-off-by: Anthony DeStefano <adx@fastmail.fm> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] tlg2300: fix leak at failure path in poseidon_probe()Alexey Khoroshilov
Error handling code in poseidon_probe() misses usb_put_intf() and usb_put_dev(). Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] DocBook media: fix small typoHans Verkuil
know -> known Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] update reference, kerneltrap.org no longer worksPranith Kumar
kerneltrap.org no longer works, update to a working reference Signed-off-by: Pranith Kumar <bobby.prani@gmail.com> Acked-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] media: usb: dvb-usb-v2: mxl111sf.c: Cleaning up uninitialized variablesRickard Strandqvist
There is a risk that the variable will be used without being initialized. This was largely found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] drivers/media: Remove useless return variablesPeter Senna Tschudin
This patch remove variables that are initialized with a constant, are never updated, and are only used as parameter of return. Return the constant instead of using a variable. Verified by compilation only. The coccinelle script that find and fixes this issue is: // <smpl> @@ type T; constant C; identifier ret; @@ - T ret = C; ... when != ret when strict return - ret + C ; // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] drivers/media/usb/usbvision/usbvision-core.c: Remove useless return ↵Peter Senna Tschudin
variables This patch remove variables that are initialized with a constant, are never updated, and are only used as parameter of return. Return the constant instead of using a variable. Verified by compilation only. The coccinelle script that find and fixes this issue is: // <smpl> @@ type T; constant C; identifier ret; @@ - T ret = C; ... when != ret when strict return - ret + C ; // </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] em28xx: add MSI Digivox Trio supportHans Verkuil
Add support for the MSI Digivox Trio device. Signed-off-by: P. van Gaans <w3ird_n3rd@gmx.net> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] drx-j: Use kmemdup instead of kmalloc + memcpyBenoit Taine
This issue was reported by coccicheck using the semantic patch at scripts/coccinelle/api/memdup.cocci Signed-off-by: Benoit Taine <benoit.taine@lip6.fr> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] dvb-frontends: Add staticAlan
Add static to tda m_* variables in the header. They don't need to be global. With some cleanup they could probably even be marked const. Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=68191 Reported-by: Christian Schneider <christian@ch-sc.de> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] rc: add sunxi-ir driverAlexander Bersenev
This patch adds driver for sunxi IR controller. It is based on Alexsey Shestacov's work based on the original driver supplied by Allwinner. Signed-off-by: Alexander Bersenev <bay@hackerdom.ru> Signed-off-by: Alexsey Shestacov <wingrime@linux-sunxi.org> [hdegoede@redhat.com: Changed compatible to sun4i-a10-ir] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-07-04[media] dt: bindings: Add binding documentation for sunxi IR controllerAlexander Bersenev
This patch adds documentation for Device-Tree bindings for sunxi IR controller. Signed-off-by: Alexander Bersenev <bay@hackerdom.ru> Signed-off-by: Alexsey Shestacov <wingrime@linux-sunxi.org> [hdegoede@redhat.com: Changed compatible to sun4i-a10-ir] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
