We must mask out the CPU_TASKS_FROZEN bit so that reset_ctrl_regs is
also called on a secondary CPU during s2ram resume, where only the boot
CPU will receive the PM_EXIT notification.
Signed-off-by: Dietmar Eggemann <dietmar.eggemann@arm.com>
The ARM ARM requires branch predictor maintenance if, for a given ASID,
the instructions at a specific virtual address appear to change.
From the kernel's point of view, that means:
- Changing the kernel's view of memory (e.g. switching to the
identity map)
- ASID rollover (since ASIDs will be re-allocated to new tasks)
This patch adds explicit branch predictor maintenance when either of the
two conditions above are met.
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
The ARM architecture requires explicit branch predictor maintenance
when updating an instruction stream for a given virtual address. In
reality, this isn't so much of a burden because the branch predictor
is flushed during the cache maintenance required to make the new
instructions visible to the I-side of the processor.
However, there are still some cases where explicit flushing is required,
so add a local_bp_flush_all operation to deal with this.
mm->context.id is updated under asid_lock when a new ASID is allocated
to an mm_struct. However, it is also read without the lock when a task
is being scheduled and checking whether or not the current ASID
generation is up-to-date.
If two threads of the same process are being scheduled in parallel and
the bottom bits of the generation in their mm->context.id match the
current generation (that is, the mm_struct has not been used for ~2^24
rollovers) then the non-atomic, lockless access to mm->context.id may
yield the incorrect ASID.
This patch fixes this issue by making mm->context.id and atomic64_t,
ensuring that the generation is always read consistently. For code that
only requires access to the ASID bits (e.g. TLB flushing by mm), then
the value is accessed directly, which GCC converts to an ldrb.
Cc: <stable@vger.kernel.org> # 3.8
If a thread triggers an ASID rollover, other threads of the same process
must be made to wait until the mm->context.id for the shared mm_struct
has been updated to new generation and associated book-keeping (e.g.
TLB invalidation) has ben performed.
However, there is a *tiny* window where both mm->context.id and the
relevant active_asids entry are updated to the new generation, but the
TLB flush has not been performed, which could allow another thread to
return to userspace with a dirty TLB, potentially leading to data
corruption. In reality this will never occur because one CPU would need
to perform a context-switch in the time it takes another to do a couple
of atomic test/set operations but we should plug the race anyway.
This patch moves the active_asids update until after the potential TLB
flush on context-switch.
The LPAE page table format uses 64-bit descriptors, so we need to take
endianness into account when populating the swapper and idmap tables
during early initialisation.
This patch ensures that we store the two words making up each page table
entry in the correct order when running big-endian.
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
When booting a SMP build kernel with nosmp on kernel cmdline, the
following fat warning will be hit.
WARNING: at arch/arm/kernel/smp_twd.c:345
twd_local_timer_of_register+0x7c/0x90()
twd_local_timer_of_register failed (-6)
Modules linked in:
Backtrace:
[<80011f14>] (dump_backtrace+0x0/0x10c) from [<8044dd30>]
(dump_stack+0x18/0x1c)
r7:805e9f58 r6:805ba84c r5:80539331 r4:00000159
[<8044dd18>] (dump_stack+0x0/0x1c) from [<80020fbc>]
(warn_slowpath_common+0x54/0x6c)
[<80020f68>] (warn_slowpath_common+0x0/0x6c) from [<80021078>]
(warn_slowpath_fmt+0x38/0x40)
r9:412fc09a r8:8fffffff r7:ffffffff r6:00000001 r5:80633b8c
r4:80b32da8
[<80021040>] (warn_slowpath_fmt+0x0/0x40) from [<805ba84]
(twd_local_timer_of_register+0x7c/0x90)
r3:fffffffa r2:8053934b
[<805ba7d0>] (twd_local_timer_of_register+0x0/0x90) from [<805c0bec>]
(imx6q_timer_init+0x18/0x4c)
r5:80633800 r4:8053b701
[<805c0bd4>] (imx6q_timer_init+0x0/0x4c) from [<805ba4e8>]
(time_init+0x28/0x38)
r5:80633800 r4:805dc0f4
[<805ba4c0>] (time_init+0x0/0x38) from [<805b6854>]
(start_kernel+0x1a0/0x310)
[<805b66b4>] (start_kernel+0x0/0x310) from [<10008044>] (0x10008044)
r8:1000406a r7:805f3f8c r6:805dc0c4 r5:805f0518 r4:10c5387d
---[ end trace 1b75b31a2719ed1c ]---
Check (!is_smp() || !setup_max_cpus) in twd_local_timer_of_register()
to make it be a no-op for the conditions, thus avoid above warning.
Reported-by: Dirk Behme <dirk.behme@de.bosch.com>
Fix missing use of the asid macro when getting the ASID from the mm->context.id field.
Signed-off-by: Ben Dooks <ben.dooks@codethink.co.uk>
The Netx IRQs offset from zero, which is illegal, since Linux
IRQ 0 is NO_IRQ.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
Reviewed-by: Jamie Iles <jamie@jamieiles.com>
Pull more VFS bits from Al Viro:
"Unfortunately, it looks like xattr series will have to wait until the
next cycle ;-/
This pile contains 9p cleanups and fixes (races in v9fs_fid_add()
etc), fixup for nommu breakage in shmem.c, several cleanups and a bit
more file_inode() work"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
constify path_get/path_put and fs_struct.c stuff
fix nommu breakage in shmem.c
cache the value of file_inode() in struct file
9p: if v9fs_fid_lookup() gets to asking server, it'd better have hashed dentry
9p: make sure ->lookup() adds fid to the right dentry
9p: untangle ->lookup() a bit
9p: double iput() in ->lookup() if d_materialise_unique() fails
9p: v9fs_fid_add() can't fail now
v9fs: get rid of v9fs_dentry
9p: turn fid->dlist into hlist
9p: don't bother with private lock in ->d_fsdata; dentry->d_lock will do just fine
more file_inode() open-coded instances
selinux: opened file can't have NULL or negative ->f_path.dentry
(In the meantime, the hlist traversal macros have changed, so this
required a semantic conflict fixup for the newly hlistified fid->dlist)
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixup from Chris Mason:
"Geert and James both sent this one in, sorry guys"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
btrfs/raid56: Add missing #include <linux/vmalloc.h>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull second set of s390 patches from Martin Schwidefsky:
"The main part of this merge are Heikos uaccess patches. Together with
commit 09884964335e ("mm: do not grow the stack vma just because of an
overrun on preceding vma") the user string access is hopefully fixed
for good.
In addition some bug fixes and two cleanup patches."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/module: fix compile warning
qdio: remove unused parameters
s390/uaccess: fix kernel ds access for page table walk
s390/uaccess: fix strncpy_from_user string length check
input: disable i8042 PC Keyboard controller for s390
s390/dis: Fix invalid array size
s390/uaccess: remove pointless access_ok() checks
s390/uaccess: fix strncpy_from_user/strnlen_user zero maxlen case
s390/uaccess: shorten strncpy_from_user/strnlen_user
s390/dasd: fix unresponsive device after all channel paths were lost
s390/mm: ignore change bit for vmemmap
s390/page table dumper: add support for change-recording override bit
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull second round of PARISC updates from Helge Deller:
"The most important fix in this branch is the switch of io_setup,
io_getevents and io_submit syscalls to use the available compat
syscalls when running 32bit userspace on 64bit kernel. Other than
that it's mostly removal of compile warnings."
* 'fixes-for-3.9-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: fix redefinition of SET_PERSONALITY
parisc: do not install modules when installing kernel
parisc: fix compile warnings triggered by atomic_sub(sizeof(),v)
parisc: check return value of down_interruptible() in hp_sdc_rtc.c
parisc: avoid unitialized variable warning in pa_memcpy()
parisc: remove unused variable 'compat_val'
parisc: switch to compat_functions of io_setup, io_getevents and io_submit
parisc: select ARCH_WANT_FRAME_POINTERS
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag
Pull new ImgTec Meta architecture from James Hogan:
"This adds core architecture support for Imagination's Meta processor
cores, followed by some later miscellaneous arch/metag cleanups and
fixes which I kept separate to ease review:
- Support for basic Meta 1 (ATP) and Meta 2 (HTP) core architecture
- A few fixes all over, particularly for symbol prefixes
- A few privilege protection fixes
- Several cleanups (setup.c includes, split out a lot of
metag_ksyms.c)
- Fix some missing exports
- Convert hugetlb to use vm_unmapped_area()
- Copy device tree to non-init memory
- Provide dma_get_sgtable()"
* tag 'metag-v3.9-rc1-v4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (61 commits)
metag: Provide dma_get_sgtable()
metag: prom.h: remove declaration of metag_dt_memblock_reserve()
metag: copy devicetree to non-init memory
metag: cleanup metag_ksyms.c includes
metag: move mm/init.c exports out of metag_ksyms.c
metag: move usercopy.c exports out of metag_ksyms.c
metag: move setup.c exports out of metag_ksyms.c
metag: move kick.c exports out of metag_ksyms.c
metag: move traps.c exports out of metag_ksyms.c
metag: move irq enable out of irqflags.h on SMP
genksyms: fix metag symbol prefix on crc symbols
metag: hugetlb: convert to vm_unmapped_area()
metag: export clear_page and copy_page
metag: export metag_code_cache_flush_all
metag: protect more non-MMU memory regions
metag: make TXPRIVEXT bits explicit
metag: kernel/setup.c: sort includes
perf: Enable building perf tools for Meta
metag: add boot time LNKGET/LNKSET check
metag: add __init to metag_cache_probe()
Pull late ARM updates from Russell King:
"Here is the late set of ARM updates for this merge window; in here is:
- The ARM parts of the broadcast timer support, core parts merged
through tglx's tree. This was left over from the previous merge to
allow the dependency on tglx's tree to be resolved.
- A fix to the VFP code which shows up on Raspberry Pi's, as well as
fixing the fallout from a previous commit in this area.
- A number of smaller fixes scattered throughout the ARM tree"
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm:
ARM: Fix broken commit 0cc41e4a21d43 corrupting kernel messages
ARM: fix scheduling while atomic warning in alignment handling code
ARM: VFP: fix emulation of second VFP instruction
ARM: 7656/1: uImage: Error out on build of multiplatform without LOADADDR
ARM: 7640/1: memory: tegra_ahb_enable_smmu() depends on TEGRA_IOMMU_SMMU
ARM: 7654/1: Preserve L_PTE_VALID in pte_modify()
ARM: 7653/2: do not scale loops_per_jiffy when using a constant delay clock
ARM: 7651/1: remove unused smp_timer_broadcast #define
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc patch from Greg Kroah-Hartman:
"Here is one remaining patch for 3.9-rc1. It is for the hyper-v
drivers, and had to wait until some other patches went in through the
x86 tree."
* tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
Drivers: hv: vmbus: Use the new infrastructure for delivering VMBUS interrupts
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB patch revert from Greg Kroah-Hartman:
"Here is one remaining USB patch for 3.9-rc1, it reverts a 3.8 patch
that has caused a lot of regressions for some VIA EHCI controllers."
* tag 'usb-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
USB: EHCI: revert "remove ASS/PSS polling timeout"
Pull watchdog updates from Wim Van Sebroeck:
"This contains:
- fixes and improvements
- devicetree bindings
- conversion to watchdog generic framework of the following drivers:
- booke_wdt
- bcm47xx_wdt.c
- at91sam9_wdt
- Removal of old STMP3xxx driver
- Addition of following new drivers:
- new driver for STMP3xxx and i.MX23/28
- Retu watchdog driver"
* git://www.linux-watchdog.org/linux-watchdog: (30 commits)
watchdog: sp805_wdt depends on ARM
watchdog: davinci_wdt: update to devm_* API
watchdog: davinci_wdt: use devm managed clk get
watchdog: at91rm9200: add DT support
watchdog: add timeout-sec property binding
watchdog: at91sam9_wdt: Convert to use the watchdog framework
watchdog: omap_wdt: Add option nowayout
watchdog: core: dt: add support for the timeout-sec dt property
watchdog: bcm47xx_wdt.c: add hard timer
watchdog: bcm47xx_wdt.c: rename wdt_time to timeout
watchdog: bcm47xx_wdt.c: rename ops methods
watchdog: bcm47xx_wdt.c: use platform device
watchdog: bcm47xx_wdt.c: convert to watchdog core api
watchdog: Convert BookE watchdog driver to watchdog infrastructure
watchdog: s3c2410_wdt: Use devm_* functions
watchdog: remove old STMP3xxx driver
watchdog: add new driver for STMP3xxx and i.MX23/28
rtc: stmp3xxx: add wdt-accessor function
watchdog: introduce retu_wdt driver
watchdog: intel_scu_watchdog: fix Kconfig dependency
Pull second set of slave-dmaengine updates from Vinod Koul:
"Arnd's patch moves the dw_dmac to use generic DMA binding. I agreed
to merge this late as it will avoid the conflicts between trees.
The second patch from Matt adding a dma_request_slave_channel_compat
API was supposed to be picked up, but somehow never got picked up.
Some patches dependent on this are already in -next :("
* 'next' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: dw_dmac: move to generic DMA binding
dmaengine: add dma_request_slave_channel_compat()
Pull x86 platform driver updates from Matthew Garrett:
"Mostly relatively small updates, along with some hardware enablement
for Sony hardware and a pile of updates to Google's Chromebook driver"
* 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: (49 commits)
ideapad-laptop: Depend on BACKLIGHT_CLASS_DEVICE instead of selecting it
ideapad: depends on backlight subsystem and update comment
Platform: x86: chromeos_laptop - add i915 gmbuses to adapter names
Platform: x86: chromeos_laptop - Add isl light sensor for Pixel
Platform: x86: chromeos_laptop - Add a more general add_i2c_device
Platform: x86: chromeos_laptop - Add Pixel Touchscreen
Platform: x86: chromeos_laptop - Add support for probing devices
Platform: x86: chromeos_laptop - Add Pixel Trackpad
hp-wmi: fix handling of platform device
sony-laptop: leak in error handling sony_nc_lid_resume_setup()
hp-wmi: Add support for SMBus hotkeys
asus-wmi: Fix unused function build warning
acer-wmi: avoid the warning of 'devices' may be used uninitialized
drivers/platform/x86/thinkpad_acpi.c: Handle HKEY event 0x6040
Platform: x86: chromeos_laptop - Add HP Pavilion 14
Platform: x86: chromeos_laptop - Add Taos tsl2583 device
Platform: x86: chromeos_laptop - Add Taos tsl2563 device
Platform: x86: chromeos_laptop - Add Acer C7 trackpad
Platform: x86: chromeos_laptop - Rename setup_lumpy_tp to setup_cyapa_smbus_tp
asus-laptop: always report brightness key events
tilegx_defconfig:
fs/btrfs/raid56.c: In function 'btrfs_alloc_stripe_hash_table':
fs/btrfs/raid56.c:206:3: error: implicit declaration of function 'vzalloc' [-Werror=implicit-function-declaration]
fs/btrfs/raid56.c:206:9: warning: assignment makes pointer from integer without a cast [enabled by default]
fs/btrfs/raid56.c:226:4: error: implicit declaration of function 'vfree' [-Werror=implicit-function-declaration]
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 bug fixes from Ted Ts'o:
"Various bug fixes for ext4. The most important is a fix for the new
extent cache's slab shrinker which can cause significant, user-visible
pauses when the system is under memory pressure."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: enable quotas before orphan cleanup
ext4: don't allow quota mount options when quota feature enabled
ext4: fix a warning from sparse check for ext4_dir_llseek
ext4: convert number of blocks to clusters properly
ext4: fix possible memory leak in ext4_remount()
jbd2: fix ERR_PTR dereference in jbd2__journal_start
ext4: use percpu counter for extent cache count
ext4: optimize ext4_es_shrink()
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull sigprocmask compat fix from Al Viro:
"generic compat_sys_rt_sigprocmask() had a very dumb braino; I'd spent
quite a while staring at the offending commit before finally managing
to spot the idiocy ;-/"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
fix compat_sys_rt_sigprocmask()
Converting bitmask to 32bit granularity is fine, but we'd better
_do_ something with the result. Such as "copy it to userland"...
Pull NFS client bugfixes from Trond Myklebust:
"We've just concluded another Connectathon interoperability testing
week, and so here are the fixes for the bugs that were discovered:
- Don't allow NFS silly-renamed files to be deleted
- Don't start the retransmission timer when out of socket space
- Fix a couple of pnfs-related Oopses.
- Fix one more NFSv4 state recovery deadlock
- Don't loop forever when LAYOUTGET returns NFS4ERR_LAYOUTTRYLATER"
* tag 'nfs-for-3.9-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
SUNRPC: One line comment fix
NFSv4.1: LAYOUTGET EDELAY loops timeout to the MDS
SUNRPC: add call to get configured timeout
PNFS: set the default DS timeout to 60 seconds
NFSv4: Fix another open/open_recovery deadlock
nfs: don't allow nfs_find_actor to match inodes of the wrong type
NFSv4.1: Hold reference to layout hdr in layoutget
pnfs: fix resend_to_mds for directio
SUNRPC: Don't start the retransmission timer when out of socket space
NFS: Don't allow NFS silly-renamed files to be deleted, no signal
Pull btrfs update from Chris Mason:
"The biggest feature in the pull is the new (and still experimental)
raid56 code that David Woodhouse started long ago. I'm still working
on the parity logging setup that will avoid inconsistent parity after
a crash, so this is only for testing right now. But, I'd really like
to get it out to a broader audience to hammer out any performance
issues or other problems.
scrub does not yet correct errors on raid5/6 either.
Josef has another pass at fsync performance. The big change here is
to combine waiting for metadata with waiting for data, which is a big
latency win. It is also step one toward using atomics from the
hardware during a commit.
Mark Fasheh has a new way to use btrfs send/receive to send only the
metadata changes. SUSE is using this to make snapper more efficient
at finding changes between snapshosts.
Snapshot-aware defrag is also included.
Otherwise we have a large number of fixes and cleanups. Eric Sandeen
wins the award for removing the most lines, and I'm hoping we steal
this idea from XFS over and over again."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (118 commits)
btrfs: fixup/remove module.h usage as required
Btrfs: delete inline extents when we find them during logging
btrfs: try harder to allocate raid56 stripe cache
Btrfs: cleanup to make the function btrfs_delalloc_reserve_metadata more logic
Btrfs: don't call btrfs_qgroup_free if just btrfs_qgroup_reserve fails
Btrfs: remove reduplicate check about root in the function btrfs_clean_quota_tree
Btrfs: return ENOMEM rather than use BUG_ON when btrfs_alloc_path fails
Btrfs: fix missing deleted items in btrfs_clean_quota_tree
btrfs: use only inline_pages from extent buffer
Btrfs: fix wrong reserved space when deleting a snapshot/subvolume
Btrfs: fix wrong reserved space in qgroup during snap/subv creation
Btrfs: remove unnecessary dget_parent/dput when creating the pending snapshot
btrfs: remove a printk from scan_one_device
Btrfs: fix NULL pointer after aborting a transaction
Btrfs: fix memory leak of log roots
Btrfs: copy everything if we've created an inline extent
btrfs: cleanup for open-coded alignment
Btrfs: do not change inode flags in rename
Btrfs: use reserved space for creating a snapshot
clear chunk_alloc flag on retryable failure
Pull MTD update from David Woodhouse:
"Fairly unexciting MTD merge for 3.9:
- misc clean-ups in the MTD command-line partitioning parser
(cmdlinepart)
- add flash locking support for STmicro chips serial flash chips, as
well as for CFI command set 2 chips.
- new driver for the ELM error correction HW module found in various
TI chips, enable the OMAP NAND driver to use the ELM HW error
correction
- added number of new serial flash IDs
- various fixes and improvements in the gpmi NAND driver
- bcm47xx NAND driver improvements
- make the mtdpart module actually removable"
* tag 'for-linus-20130301' of git://git.infradead.org/linux-mtd: (45 commits)
mtd: map: BUG() in non handled cases
mtd: bcm47xxnflash: use pr_fmt for module prefix in messages
mtd: davinci_nand: Use managed resources
mtd: mtd_torturetest can cause stack overflows
mtd: physmap_of: Convert device allocation to managed devm_kzalloc()
mtd: at91: atmel_nand: for PMECC, add code to check the ONFI parameter ECC requirement.
mtd: atmel_nand: make pmecc-cap, pmecc-sector-size in dts is optional.
mtd: atmel_nand: avoid to report an error when lookup table offset is 0.
mtd: bcm47xxsflash: adjust names of bus-specific functions
mtd: bcm47xxpart: improve probing of nvram partition
mtd: bcm47xxpart: add support for other erase sizes
mtd: bcm47xxnflash: register this as normal driver
mtd: bcm47xxnflash: fix message
mtd: bcm47xxsflash: register this as normal driver
mtd: bcm47xxsflash: write number of written bytes
mtd: gpmi: add sanity check for the ECC
mtd: gpmi: set the Golois Field bit for mx6q's BCH
mtd: devices: elm: Removes <xx> literals in elm DT node
mtd: gpmi: fix a dereferencing freed memory error
mtd: fix the wrong timeo for panic_nand_wait()
Reported-by: Weston Andros Adamson <dros@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
When using quota feature we need to enable quotas before orphan cleanup
so that changes happening during it are properly reflected in quota
accounting.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
So far we silently ignored when quota mount options were set while quota
feature was enabled. But this can create confusion in userspace when
mount options are set but silently ignored and also creates opportunities
for bugs when we don't properly test all quota types. Actually
ext4_mark_dquot_dirty() forgets to test for quota feature so it was
dependent on journaled quota options being set. OTOH ext4_orphan_cleanup()
tries to enable journaled quota when quota options are specified which is
wrong when quota feature is enabled.
ext4_dir_llseek is only used as a callback function, and no one calls
it directly. So make it as a static function in order to remove a
warning message from sparse check.
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
We're using macro EXT4_B2C() to convert number of blocks to number of
clusters for bigalloc file systems. However, we should be using
EXT4_NUM_B2C().
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Cc: stable@vger.kernel.org
'orig_data' is malloced in ext4_remount() and should be freed
before leaving from the error handling cases, otherwise it will
cause memory leak.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
If start_this_handle() failed handle will be initialized
to ERR_PTR() and can not be dereferenced.
paging request at fffffffffffffff6
IP: [<ffffffff813c073f>] jbd2__journal_start+0x18f/0x290
PGD 200e067 PUD 200f067 PMD 0
Oops: 0000 [#1] SMP
Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod
CPU 0 journal commit I/O error
Pid: 2694, comm: fio Not tainted 3.8.0-rc3+ #79 /DQ67SW
RIP: 0010:[<ffffffff813c073f>] [<ffffffff813c073f>] jbd2__journal_start+0x18f/0x290
RSP: 0018:ffff880233b8ba58 EFLAGS: 00010292
RAX: 00000000ffffffe2 RBX: ffffffffffffffe2 RCX: 0000000000000006
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffffffff82128f48
RBP: ffff880233b8ba98 R08: 0000000000000000 R09: ffff88021440a6e0
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
metag/allmodconfig:
drivers/media/v4l2-core/videobuf2-dma-contig.c: In function 'vb2_dc_get_base_sgt':
drivers/media/v4l2-core/videobuf2-dma-contig.c:387: error: implicit declaration of function 'dma_get_sgtable'
For architectures using dma_map_ops, dma_get_sgtable() is provided in
<asm-generic/dma-mapping-common.h>.
Metag does not use dma_map_ops yet, hence it should implement it as an
inline stub using dma_common_get_sgtable().
Signed-off-by: James Hogan <james.hogan@imgtec.com>
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Metag doesn't have a metag_dt_memblock_reserve() function so remove the
declaration from asm/prom.h.
Make a copy of the device tree blob in non-init memory. It is required
when using built-in device tree files that the platform code copies the
blob to non-init memory prior to calling unflatten_device_tree(),
otherwise the strings that the device tree refer to will get poisoned
and potentially reused, breaking later reading of the device tree
post-init (such as compatible matching in modules, debugfs, and the
procfs interface).
Reviewed-by: Vineet Gupta <vgupta@synopsys.com>
Minimise metag_ksyms.c includes to directly include the <asm/*.h> files
that declare a particular symbol, and not include any unnecessary ones.
It's less error prone to have function symbols exported immediately
after the function rather than in metag_ksyms.c. Move each EXPORT_SYMBOL
in metag_ksyms.c for symbols defined in mm/init.c into mm/init.c.
in metag_ksyms.c for symbols defined in usercopy.c into usercopy.c
in metag_ksyms.c for symbols defined in setup.c into setup.c
in metag_ksyms.c for symbols defined in kick.c into kick.c
in metag_ksyms.c for symbols defined in traps.c into traps.c
The SMP version of arch_local_irq_enable() uses preempt_disable(), but
<asm/irqflags.h> doesn't include <linux/preempt.h> causing the following
errors on SMP when pstore/ftrace is enabled (caught by buildbot smp
allyesconfig):
In file included from include/linux/irqflags.h:15,
from fs/pstore/ftrace.c:16:
arch/metag/include/asm/irqflags.h: In function 'arch_local_irq_enable':
arch/metag/include/asm/irqflags.h:84: error: implicit declaration of function 'preempt_disable'
arch/metag/include/asm/irqflags.h:86: error: implicit declaration of function 'preempt_enable_no_resched'
However <linux/preempt.h> cannot be easily included from
<asm/irqflags.h> as it can cause circular include dependencies in the
!SMP case, and potentially in the SMP case in the future. Therefore move
the SMP implementation of arch_local_irq_enable() into traps.c and use
an inline version of get_trigger_mask() which is also defined in traps.c
for SMP.
This adds an extra layer of function call / stack push when
preempt_disable needs to call other functions, however in the
non-preemptive SMP case it should be about as fast, as it was already
calling the get_trigger_mask() function which is now used inline.
Meta uses symbol prefixes, so add "metag" to the list of architectures
to set the mod_prefix to "_" for. This fixes __crc_* symbols to add the
extra underscore to match _CRC_SYMBOL macro in <linux/export.h> and so
that modpost finds them.
Convert hugetlb_get_unmapped_area_new_pmd() to use vm_unmapped_area()
rather than searching the virtual address space itself. This fixes the
following errors in linux-next due to the specified members being
removed after other architectures have already been converted:
arch/metag/mm/hugetlbpage.c: In function 'hugetlb_get_unmapped_area_new_pmd':
arch/metag/mm/hugetlbpage.c:199: error: 'struct mm_struct' has no member named 'cached_hole_size'
arch/metag/mm/hugetlbpage.c:200: error: 'struct mm_struct' has no member named 'free_area_cache'
arch/metag/mm/hugetlbpage.c:215: error: 'struct mm_struct' has no member named 'cached_hole_size'
Acked-by: Michel Lespinasse <walken@google.com>
Various file systems use clear_page() and copy_page(), so when they're
built as modules we get build errors like the following:
ERROR: "clear_page" [fs/ntfs/ntfs.ko] undefined!
ERROR: "copy_page" [fs/nilfs2/nilfs2.ko] undefined!
Therefore export these functions to modules from metag_ksyms.c to fix
the errors. This was hit by a randconfig build.
Various file systems indirectly use metag_code_cache_flush_all(), so
when they're built as modules we get build errors like the following:
ERROR: "metag_code_cache_flush_all" [fs/xfs/xfs.ko] undefined!
Therefore export this function to modules to fix the errors. This was
Rename setup_txprivext() to setup_priv() and add initialisation of some
more per-thread privilege protection registers:
- TxPRIVSYSR: 0x04400000-0x047fffff
0x05000000-0x07ffffff
0x84000000-0x87ffffff
- TxPIOREG: 0x02000000-0x02ffffff
0x04800000-0x048fffff
- TxSYREG: 0x04000000-0x04000fff (except write fetch system event)
