2005-11-14[PATCH] powerpc: vdso fixes (take #2)Benjamin Herrenschmidt
This fixes various errors in the new functions added in the vDSO's, I've now verified all functions on both 32 and 64 bits vDSOs. It also fix a sign extension bug getting the initial time of day at boot that could cause the monotonic clock value to be completely on bogus for 64 bits applications (with either the vDSO or the syscall) on powermacs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-14[PATCH] powerpc: Always rebuild arch/powerpc/include/asm symlinkBenjamin Herrenschmidt
This patch uses a FORCE dependency on the arch/powerpc/include/asm symlink so that it always gets rebuilt, thus avoiding all sort of funny errors if the .config is changed between 32 and 64 bits. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-14[PATCH] powerpc: Export htab start/end via device treeMichael Ellerman
The userspace kexec-tools need to know the location of the htab on non-lpar machines, as well as the end of the kernel. Export via the device tree. NB. This patch has been updated to use "linux,x" property names. You may need to update your kexec-tools to match. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-14[PATCH] powerpc: Turn cpu_irq_down into kexec_cpu_downMichael Ellerman
We currently have a ppc_md member called cpu_irq_down, which disables IRQs for the cpu in question. The only caller of cpu_irq_down is the kexec code. On pSeries we need to do more than just teardown IRQs at kexec time, so rename the ppc_md member to kexec_cpu_down and expand it. The pSeries code needs to know, and other platforms might too, whether we're doing a crash shutdown (ie. panicking) or a regular kexec, so add a flag for that. The pSeries implementation of kexec_cpu_down does an unregister VPA call, which tells the Hypervisor to stop writing stuff into our pacas. Without this we can get weird memory corruption bugs when we kexec, caused by the Hypervisor writing into the first kernel's pacas which happens to be somewhere interesting in the second kernel's memory. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-14[PATCH] powerpc: Merge page.hMichael Ellerman
Merge asm-ppc/page.h and asm-ppc64/page.h into asm-powerpc/page.h, asm-powerpc/page_32.h and asm-powerpc/page_64.h Built for PPC (common_defconfig), with ARCH=powerpc, mostly built with ARCH=ppc (other things break the build). Built and booted on P5 LPAR for PPC64 with ARCH=ppc/powerpc (pseries_defconfig). Mostly built for iSeries powerpc. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-fixes-2.6Linus Torvalds
2005-11-13Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-11-13Merge master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
2005-11-13Merge master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
2005-11-13[PATCH] DocBook: revert xmlto use for .ps and .pdf documentationMartin Waitz
As xmlto doesn't work for print documentation, we need docbook-utils again for these targets. This patch allows the user to choose the method he wants to use. (I'm still hoping that someone will fix passivetex ;-) Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] DocBook: comment about paper typeMartin Waitz
Add a comment showing how to change paper type. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] DocBook: include printk documentationMartin Waitz
Add printk documentation to kernel-api. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] DocBook: allow to mark structure members privateMartin Waitz
Many structures contain both an internal part and one which is part of the API to other modules. With this patch it is possible to only include these public members in the kernel documentation. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] make vesafb build without CONFIG_MTRRJan Beulich
vesafb did not build without CONFIG_MTRR. Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: 976: ensure consistent v4l firmware prefixesHans Verkuil
Ensure consistent v4l firmware prefixes. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: 977: fix broken dependency needed for sa7134 moduleMauro Carvalho Chehab
2005-11-13[PATCH] v4l: 975: apply saa7134-alsa fixesRicardo Cerqueira
Merged parts of a patch from Takashi Iwai for an older version of the module. This patch was adapted and tested by Ricardo Cerqueira. Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: 974: saa7134 shouldn't DEPEND on SND_PCM_OSS. Instead, SELECT it.Michael Krufky
saa7134 shouldn't DEPEND on SND_PCM_OSS. Instead, SELECT it. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: saa711x driver doesn't need segment.hDave Jones
This breaks compilation on non-x86 architectures, and isn't even used. Signed-off-by: Dave Jones <davej@redhat.com> Acked-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: prevent saa7134 alsa undefined warningsMike Krufky
Prevent the following build warnings: *** Warning: "snd_card_free" *** Warning: "snd_card_register" *** Warning: "snd_device_new" *** Warning: "snd_card_new" *** Warning: "snd_ctl_add" *** Warning: "snd_ctl_new1" *** Warning: "snd_pcm_set_ops" *** Warning: "snd_pcm_new" *** Warning: "snd_pcm_lib_ioctl" *** Warning: "snd_pcm_hw_constraint_integer" *** Warning: "snd_pcm_stop" *** Warning: "snd_pcm_period_elapsed" [drivers/media/video/saa7134/saa7134-alsa.ko] undefined! Signed-off-by: Michael Krufky <mkrufky@m1k.net> Acked-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (966.1) Removes Obsoleted i2c-compat.h from newer driversMauro Carvalho Chehab
Removed obsoleted i2c-compat.h file from cx25840, saa7115 and saa7127 drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (966) Authorship fixes for new ModulesHans Verkuil
Fixes Module Author macros Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (948) adds support for saa7115 video decoderHans Verkuil
- Adds support for saa7115 video decoder. Driver Authors: Hans Verkuil, Chris Kennedy, Kevin Thayer Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Chris Kennedy <c@groovy.org> Signed-off-by: Kevin Thayer <nufan_wfk@yahoo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (963.1) hybrid v4l/dvb: remove duplicated codeMichael Krufky
The following patch caused some duplicated code in cx88-dvb.c: [PATCH] v4l: 634: implemented tuner set standby on cx88 init The cx88-dvb.c portion of this patch was already applied in an earlier patch, entitled: [PATCH] v4l: fixup on cx88_dvb for Dvico HDTV5 Gold I love quilt and all, but AFAIK, no tool is 100% perfect for catching oversights like this. The non-overlapping portions of each of these patches are still needed, and must not be discarded, so rather than reverting old patches, please just apply this fixup patch to remove the duplicated code. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (963) em28xx IR fixupMauro Carvalho Chehab
Removed the code that avoids repeating events when pressing IR keys. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (962) Added new saa7134 card (MSI TV@anywhere plus)Ricardo Cerqueira
Added new saa7134 card (MSI TV@anywhere plus) Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (958) Make cx25840 use firmware image named 'cx25840.fw'Tyler Trafford
Change default filename of firmware image to 'cx25840.fw' Signed-off-by: Tyler Trafford <tatrafford@comcast.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (951) Make saa7134-oss as a stand-alone moduleRicardo Cerqueira
- saa7134-oss is now a standalone module as well - remaining DMA sound code has been removed from core the module - Lots of small cleanups and variable renames to get more consistency between the OSS and ALSA drivers - Fixed saa7134-alsa spinlock bug - Added missing #include in saa7134-oss Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (950) Added compiler options for cx25840 saa7115 and saa7127Mauro Carvalho Chehab
Added compiler options for cx25840, saa7115 and saa7127 Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (949) Added support for secam l'Hartmut Hackmann
Added support for SECAM L' Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t.online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (946) adds support for cx25840 video decoderHans Verkuil
Adds support for cx25840 video decoder. Driver authors: Hans Verkuil, Chris Kennedy, Tyler Trafford, Ulf Eklund. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Chris Kennedy <c@groovy.org> Signed-off-by: Tyler Trafford <tatrafford@comcast.net> Thanks-to: Ulf Eklund <ivtv@eklund.to>. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (945) adds a new include for internal v4l2 ioctls and apiHans Verkuil
Adds a new include for internal V4L2 ioctls and API Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l-944-added-driver-for-saa7127-video-tidyAndrew Morton
Remove unneeded (and undesirable) casts. Cc: Hans Verkuil <hverkuil@xs4all.nl> Cc: Chris Kennedy <c@groovy.org> Cc: Kevin Thayer <nufan_wfk@yahoo.com> Cc: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (944) added driver for saa7127 video decoderHans Verkuil
- Added driver for saa7127 video decoder. Driver authors:Hans Verkuil, Chris Kennedy, Kevin Thayer Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Chris Kennedy <c@groovy.org> Signed-off-by: Kevin Thayer <nufan_wfk@yahoo.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (939) Support for nebula rc5 based gpio remoteMark Weaver
Support for Nebula rc5-based gpio remote. Signed-off-by: Mark Weaver <mark-clist@npsl.co.uk> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (937) Included missing interrupt.h at saa7134-alsa.cNickolay V. Shmyrev
Included missing interrupt.h at saa7134-alsa.c Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l:: (936) Support for sabrent bt848 versionBill Pechter
Support for Sabrent bt848 version. Signed-off-by: Bill Pechter <pechter@gmail.com> Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (935) Moved common IR stuff to ir-common.cRicardo Cerqueira
- The pinnacle handler & remote are common to saa7134 PCI boards and em28xx USB boards, so the keymap was moved to ir-common and the keyhandler is back to ir-kbd-i2c - request_module("ir-kbd-i2c") is no longer necessary at saa7134-core since saa7134.ko now depends on ir-kbd-i2c.ko to get the keyhandler Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (943) added secam l video standardMauro Carvalho Chehab
- Added SECAM L' video standard - SECAM L' is a Secam variant that requires special config. This patch adds support on V4L core. Requires aditional patches on tuners to support. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (930) Alsa fixes and improvementsRicardo Cerqueira
- Fix nasty IRQ hook bug. - Fix multiple board support in saa7134-alsa - Minor comment updates - SAA7134/ALSA IRQ management improvements - Removed superfluous stop_dma() from saa7134-alsa IRQ handler Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (926.1) Added compiling options for wm8775 and cs53l32a chipsMauro Carvalho Chehab
Added compiling options for wm8775 and cs53l32a chips. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] README: add info about -stable to README and point at ↵Jesper Juhl
applying-patches.txt Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] timespec: normalize off by one errorsGeorge Anzinger
It would appear that the timespec normalize code has an off by one error. Found in three places. Thanks to Ben for spotting. Signed-off-by: George Anzinger<george@mvista.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] tpm: locking fixKylene Jo Hall
Use schedule_work() to avoid down()-in-timer-handler problem. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] tpm: dev_mask handling fixKylene Jo Hall
- Use ~, not ! - Remove unneeded cast Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] tpm: updates for new hardwareKylene Jo Hall
This is the patch to support TPMs on power ppc hardware. It has been reworked as requested to remove the need for messing with the io page mask by just using ioremap. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] tpm: necessary PPC64 function exportsKylene Jo Hall
Some work is needed in the tpm device driver to discover the TPM out of the device tree rather than based on set address on Power PPC. This patch exports a couple of functions for the parsing. Signed-off-by: Kylene Hall <kjhall@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] oops-tracing: mention digital photosDiego Calleja
2005-11-13[PATCH] fix leaks in request_firmware_nowaitmatthieu castet
Wasn't checking return error and forgot to free in some case. Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] acct.h needs jiffies.hAndrew Morton
allnoconfig: In file included from fs/super.c:28: include/linux/acct.h:173: warning: `TICK_NSEC' is not defined Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
