2011-07-22asm-generic: add MMU variants of io.h functionsJonas Bonn
Some of the implementations, in particular the ioremap variants, in asm-generic/io.h are for systems without an MMU. In order to be able to use the generic header file for systems with an MMU, this patch wraps these implementations in checks for CONFIG_MMU. Tested on OpenRISC. Signed-off-by: Jonas Bonn <jonas@southpole.se> Cc: liqin.chen@sunplusct.com Cc: gxt@mprc.pku.edu.cn Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-07-22asm-generic: move archictures to common delay.hJonas Bonn
This patch moves the in-tree architectures that were using the 'generic' delay.h over to using the header file in asm-generic. This is not done using the generic-y mechanism as none of these arch's have started using that mechanism yet. This is a trivial change to make later when the arch begins using generic-y. Note the subtle change to the avr32 and SH architectures where the argument to __const_udelay was previously using the rounded down constant value instead of the rounded up value. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
2011-07-22asm-generic: delay.h fix udelay and ndelay for 8 bit argsAndrew Morton
With a non-constant 8-bit argument, a call to udelay() generates a warning: drivers/gpu/drm/radeon/atom.c: In function 'atom_op_delay': drivers/gpu/drm/radeon/atom.c:654: warning: comparison is always false due to limited range of data type The code looks like it works OK with an 8-bit arg, and the calling code is doing nothing wrong, so udelay() needs fixing. Fixing it was rather tricky. Simply typecasting `n' in the comparison with 20000 didn't change anything. Hence the divide-by-20000 trick. Using a do{}while loop didn't work because udelay() is used in ?: statements, hence the ({...}) construct. While I was there I replaced the brain-bending ?:?:?: mess with nice if/else code. Probably other architectures are generating the same warning and can use a similar change. [Taken from the x86 tree and moved to asm-generic by Jonas Bonn] Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jonas Bonn <jonas@southpole.se>
2011-07-07asm-generic: adapt delay.h to common implementationJonas Bonn
Several architectures are using a common delay.h implementation that appears to have originated with the x86 architecture. This common implementation is a bit fuller than the current asm-generic version and has some compile-time checks that should be interesting for all architectures. This patch takes the common delay.h version and replaces the rather trivial asm-generic version with it. As no architecture was actually using asm-generic/delay.h, this change is rather innocuous; it will, however, allow us to switch at least four architectures over to using the asm-generic version. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-06-27Linux 3.0-rc5v3.0-rc5Linus Torvalds
2011-06-27drm/i915: more struct_mutex lockingHugh Dickins
When auditing the locking in i915_gem.c (for a prospective change which I then abandoned), I noticed two places where struct_mutex is not held across GEM object manipulations that would usually require it. Since one is in initial setup and the other in driver unload, I'm guessing the mutex is not required for either; but post a patch in case it is. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Keith Packard <keithp@keithp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drm/i915: use shmem_truncate_rangeHugh Dickins
The interface to ->truncate_range is changing very slightly: once "tmpfs: take control of its truncate_range" has been applied, this can be applied. For now there is only a slight inefficiency while this remains unapplied, but it will soon become essential for managing shmem's use of swap. Change i915_gem_object_truncate() to use shmem_truncate_range() directly: which should also spare i915 later change if we switch from inode_operations->truncate_range to file_operations->fallocate. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Keith Packard <keithp@keithp.com> Cc: Dave Airlie <airlied@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drm/i915: use shmem_read_mapping_pageHugh Dickins
Soon tmpfs will stop supporting ->readpage and read_cache_page_gfp(): once "tmpfs: add shmem_read_mapping_page_gfp" has been applied, this patch can be applied to ease the transition. Make i915_gem_object_get_pages_gtt() use shmem_read_mapping_page_gfp() in the one place it's needed; elsewhere use shmem_read_mapping_page(), with the mapping's gfp_mask properly initialized. Forget about __GFP_COLD: since tmpfs initializes its pages with memset, asking for a cold page is counter-productive. Include linux/shmem_fs.h also in drm_gem.c: with shmem_file_setup() now declared there too, we shall remove the prototype from linux/mm.h later. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Keith Packard <keithp@keithp.com> Cc: Dave Airlie <airlied@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drm/ttm: use shmem_read_mapping_pageHugh Dickins
Soon tmpfs will stop supporting ->readpage and read_mapping_page(): once "tmpfs: add shmem_read_mapping_page_gfp" has been applied, this patch can be applied to ease the transition. ttm_tt_swapin() and ttm_tt_swapout() use shmem_read_mapping_page() in place of read_mapping_page(), since their swap_space has been created with shmem_file_setup(). Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Thomas Hellstrom <thellstrom@vmware.com> Cc: Dave Airlie <airlied@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/tty/serial/8250_pci.c: fix warningAndrew Morton
Fis the warning drivers/tty/serial/8250_pci.c:1457: warning: initialization from incompatible pointer type Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/misc/ioc4.c: fix section mismatch / race conditionRalf Baechle
Fix this section mismatch: WARNING: drivers/misc/ioc4.o(.data+0x144): Section mismatch in reference from the variable ioc4_load_modules_work to the function .devinit.text:ioc4_load_modules() The variable ioc4_load_modules_work references the function __devinit ioc4_load_modules() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console This one is potentially fatal; by the time ioc4_load_modules is invoked it may already have been freed. For that reason ioc4_load_modules_work can't be turned to __devinitdata but also because it's referenced in ioc4_exit. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Brent Casavant <bcasavan@sgi.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/leds/leds-lp5523.c: fix section mismatchesRalf Baechle
Fix this section mismatch: WARNING: drivers/leds/leds-lp5523.o(.text+0x12f4): Section mismatch in reference from the function lp5523_probe() to the function .init.text:lp5523_init_led() The function lp5523_probe() references the function __init lp5523_init_led(). This is often because lp5523_probe lacks a __init annotation or the annotation of lp5523_init_led is wrong. Fixing this one triggers one more mismatch, fix that one as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/leds/leds-lp5521.c: fix section mismatchesRalf Baechle
Fix this section mismatch: WARNING: drivers/leds/leds-lp5521.o(.text+0xf2c): Section mismatch in reference from the function lp5521_probe() to the function .init.text:lp5521_init_led() The function lp5521_probe() references the function __init lp5521_init_led(). This is often because lp5521_probe lacks a __init annotation or the annotation of lp5521_init_led is wrong. Fixing this mismatch triggers one more mismatch, fix that one as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27memcg: fix direct softlimit reclaim to be called in limit pathKAMEZAWA Hiroyuki
Commit d149e3b25d7c ("memcg: add the soft_limit reclaim in global direct reclaim") adds a softlimit hook to shrink_zones(). By this, soft limit is called as try_to_free_pages() do_try_to_free_pages() shrink_zones() mem_cgroup_soft_limit_reclaim() Then, direct reclaim is memcg softlimit hint aware, now. But, the memory cgroup's "limit" path can call softlimit shrinker. try_to_free_mem_cgroup_pages() do_try_to_free_pages() shrink_zones() mem_cgroup_soft_limit_reclaim() This will cause a global reclaim when a memcg hits limit. This is bug. soft_limit_reclaim() should be called when scanning_global_lru(sc) == true. And the commit adds a variable "total_scanned" for counting softlimit scanned pages....it's not "total". This patch removes the variable and update sc->nr_scanned instead of it. This will affect shrink_slab()'s scan condition but, global LRU is scanned by softlimit and I think this change makes sense. TODO: avoid too much scanning of a zone when softlimit did enough work. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Ying Han <yinghan@google.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27taskstats: don't allow duplicate entries in listener modeVasiliy Kulikov
Currently a single process may register exit handlers unlimited times. It may lead to a bloated listeners chain and very slow process terminations. Eg after 10KK sent TASKSTATS_CMD_ATTR_REGISTER_CPUMASKs ~300 Mb of kernel memory is stolen for the handlers chain and "time id" shows 2-7 seconds instead of normal 0.003. It makes it possible to exhaust all kernel memory and to eat much of CPU time by triggerring numerous exits on a single CPU. The patch limits the number of times a single process may register itself on a single CPU to one. One little issue is kept unfixed - as taskstats_exit() is called before exit_files() in do_exit(), the orphaned listener entry (if it was not explicitly deregistered) is kept until the next someone's exit() and implicit deregistration in send_cpu_listeners(). So, if a process registered itself as a listener exits and the next spawned process gets the same pid, it would inherit taskstats attributes. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm: fix assertion mapping->nrpages == 0 in end_writeback()Jan Kara
Under heavy memory and filesystem load, users observe the assertion mapping->nrpages == 0 in end_writeback() trigger. This can be caused by page reclaim reclaiming the last page from a mapping in the following race: CPU0 CPU1 ... shrink_page_list() __remove_mapping() __delete_from_page_cache() radix_tree_delete() evict_inode() truncate_inode_pages() truncate_inode_pages_range() pagevec_lookup() - finds nothing end_writeback() mapping->nrpages != 0 -> BUG page->mapping = NULL mapping->nrpages-- Fix the problem by doing a reliable check of mapping->nrpages under mapping->tree_lock in end_writeback(). Analyzed by Jay <jinshan.xiong@whamcloud.com>, lost in LKML, and dug out by Miklos Szeredi <mszeredi@suse.de>. Cc: Jay <jinshan.xiong@whamcloud.com> Cc: Miklos Szeredi <mszeredi@suse.de> Signed-off-by: Jan Kara <jack@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm/memory-failure.c: fix spinlock vs mutex orderPeter Zijlstra
We cannot take a mutex while holding a spinlock, so flip the order and fix the locking documentation. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/misc/lkdtm.c: fix race when crashpoint is hit multiple times before ↵Josh Hunt
checking count We observed the crash point count going negative in cases where the crash point is hit multiple times before the check of "count == 0" is done. Because of this we never call lkdtm_do_action(). This patch just adds a spinlock to protect count. Reported-by: Tapan Dhimant <tdhimant@akamai.com> Signed-off-by: Josh Hunt <johunt@akamai.com> Acked-by: Ankita Garg <ankita@in.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27include/linux/compat.h: declare compat_sys_sendmmsg()Chris Metcalf
This is required for tilegx to be able to use the compat unistd.h header where compat_sys_sendmmsg() is now mentioned. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27romfs: fix romfs_get_unmapped_area() argument checkBob Liu
romfs_get_unmapped_area() checks argument `len' without considering PAGE_ALIGN which will cause do_mmap_pgoff() return -EINVAL error after commit f67d9b1576c ("nommu: add page_align to mmap"). Fix the check by changing it in same way ramfs_nommu_get_unmapped_area() was changed in ramfs/file-nommu.c. Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: Greg Ungerer <gerg@snapgear.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27um: add asm/percpu.hRichard Weinberger
To make SLUB work on UML we need this_cpu_cmpxchg from asm-generic/percpu.h. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/rtc/rtc-ds1307.c: add support for RTC device pt7c4338Priyanka Jain
PT7C4338 chip is being manufactured by Pericom Technology Inc. It is a serial real-time clock which provides: 1) Low-power clock/calendar. 2) Programmable square-wave output. It has 56 bytes of nonvolatile RAM. Its register set is same as that of rtc device: DS1307. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Acked-by: Timur Tabi <timur@freescale.com> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27tmpfs: add shmem_read_mapping_page_gfpHugh Dickins
Although it is used (by i915) on nothing but tmpfs, read_cache_page_gfp() is unsuited to tmpfs, because it inserts a page into pagecache before calling the filesystem's ->readpage: tmpfs may have pages in swapcache which only it knows how to locate and switch to filecache. At present tmpfs provides a ->readpage method, and copes with this by copying pages; but soon we can simplify it by removing its ->readpage. Provide shmem_read_mapping_page_gfp() now, ready for that transition, Export shmem_read_mapping_page_gfp() and add it to list in shmem_fs.h, with shmem_read_mapping_page() inline for the common mapping_gfp case. (shmem_read_mapping_page_gfp or shmem_read_cache_page_gfp? Generally the read_mapping_page functions use the mapping's ->readpage, and the read_cache_page functions use the supplied filler, so I think read_cache_page_gfp was slightly misnamed.) Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27tmpfs: take control of its truncate_rangeHugh Dickins
2.6.35's new truncate convention gave tmpfs the opportunity to control its file truncation, no longer enforced from outside by vmtruncate(). We shall want to build upon that, to handle pagecache and swap together. Slightly redefine the ->truncate_range interface: let it now be called between the unmap_mapping_range()s, with the filesystem responsible for doing the truncate_inode_pages_range() from it - just as the filesystem is nowadays responsible for doing that from its ->setattr. Let's rename shmem_notify_change() to shmem_setattr(). Instead of calling the generic truncate_setsize(), bring that code in so we can call shmem_truncate_range() - which will later be updated to perform its own variant of truncate_inode_pages_range(). Remove the punch_hole unmap_mapping_range() from shmem_truncate_range(): now that the COW's unmap_mapping_range() comes after ->truncate_range, there is no need to call it a third time. Export shmem_truncate_range() and add it to the list in shmem_fs.h, so that i915_gem_object_truncate() can call it explicitly in future; get this patch in first, then update drm/i915 once this is available (until then, i915 will just be doing the truncate_inode_pages() twice). Though introduced five years ago, no other filesystem is implementing ->truncate_range, and its only other user is madvise(,,MADV_REMOVE): we expect to convert it to fallocate(,FALLOC_FL_PUNCH_HOLE,,) shortly, whereupon ->truncate_range can be removed from inode_operations - shmem_truncate_range() will help i915 across that transition too. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm: move shmem prototypes to shmem_fs.hHugh Dickins
Before adding any more global entry points into shmem.c, gather such prototypes into shmem_fs.h. Remove mm's own declarations from swap.h, but for now leave the ones in mm.h: because shmem_file_setup() and shmem_zero_setup() are called from various places, and we should not force other subsystems to update immediately. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm: move vmtruncate_range to truncate.cHugh Dickins
You would expect to find vmtruncate_range() next to vmtruncate() in mm/truncate.c: move it there. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27Fix some kernel-doc warningsVitaliy Ivanov
Fix 'make htmldocs' warnings: Warning(/include/linux/hrtimer.h:153): No description found for parameter 'clockid' Warning(/include/linux/device.h:604): Excess struct/union/enum/typedef member 'of_match' description in 'device' Warning(/include/net/sock.h:349): Excess struct/union/enum/typedef member 'sk_rmem_alloc' description in 'sock' Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: queue: bring discard_granularity/alignment into line with SCSI mmc: queue: append partition subname to queue thread name mmc: core: make erase timeout calculation allow for gated clock mmc: block: switch card to User Data Area when removing the block driver mmc: sdio: reset card during power_restore mmc: cb710: fix #ifdef HAVE_EFFICIENT_UNALIGNED_ACCESS mmc: sdhi: DMA slave ID 0 is invalid mmc: tmio: fix regression in TMIO_MMC_WRPROTECT_DISABLE handling mmc: omap_hsmmc: use original sg_len for dma_unmap_sg mmc: omap_hsmmc: fix ocr mask usage mmc: sdio: fix runtime PM path during driver removal mmc: Add PCI fixup quirks for Ricoh 1180:e823 reader mmc: sdhi: fix module unloading mmc: of_mmc_spi: add NO_IRQ define to of_mmc_spi.c mmc: vub300: fix null dereferences in error handling
2011-06-27Fix node_start/end_pfn() definition for mm/page_cgroup.cKAMEZAWA Hiroyuki
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end of nodes. But, it's not defined in linux/mmzone.h but defined in /arch/???/include/mmzone.h which is included only under CONFIG_NEED_MULTIPLE_NODES=y. Then, we see mm/page_cgroup.c: In function 'page_cgroup_init': mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn' mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn' So, fixiing page_cgroup.c is an idea... But node_start_pfn()/node_end_pfn() is a very generic macro and should be implemented in the same manner for all archs. (m32r has different implementation...) This patch removes definitions of node_start/end_pfn() in each archs and defines a unified one in linux/mmzone.h. It's not under CONFIG_NEED_MULTIPLE_NODES, now. A result of macro expansion is here (mm/page_cgroup.c) for !NUMA start_pfn = ((&contig_page_data)->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); for NUMA (x86-64) start_pfn = ((node_data[nid])->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); Changelog: - fixed to avoid using "nid" twice in node_end_pfn() macro. Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-and-tested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: btrfs: fix inconsonant inode information Btrfs: make sure to update total_bitmaps when freeing cache V3 Btrfs: fix type mismatch in find_free_extent() Btrfs: make sure to record the transid in new inodes
2011-06-27Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: prevent bogus assert when trying to remove non-existent attribute xfs: clear XFS_IDIRTY_RELEASE on truncate down xfs: reset inode per-lifetime state when recycling it
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: hid-multitouch: add support for a new Lumio dual-touch panel HID: hid-multitouch: correct VID for Stantum panels HID: hid-multitouch: ensure slots are initialized
2011-06-27Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: pm: ensure ARMv7 CPUs save and restore the TLS register ARM: pm: proc-v7: fix missing struct processor pointers for suspend code ARM: 6969/1: plat-iop: fix build error ARM: 6961/1: zImage: Add build-time check for correctly-sized proc_type entries ARM: SMP: wait for CPU to be marked active ARM: 6963/1: Thumb-2: Relax relocation requirements for non-function symbols ARM: 6962/1: mach-h720x: fix build error ARM: 6959/1: SMP build fix for entry-macro-multi.S
2011-06-27Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] allow setting of upper 32 bit in smp_ctl_set_bit [S390] hwsampler: Set a sane default sampling rate [S390] s390: enforce HW limits for the initial sampling rate [S390] kvm-s390: fix kconfig dependencies
2011-06-27btrfs: fix inconsonant inode informationMiao Xie
When iputting the inode, We may leave the delayed nodes if they have some delayed items that have not been dealt with. So when the inode is read again, we must look up the relative delayed node, and use the information in it to initialize the inode. Or we will get inconsonant inode information, it may cause that the same directory index number is allocated again, and hit the following oops: [ 5447.554187] err add delayed dir index item(name: pglog_0.965_0) into the insertion tree of the delayed node(root id: 262, inode id: 258, errno: -17) [ 5447.569766] ------------[ cut here ]------------ [ 5447.575361] kernel BUG at fs/btrfs/delayed-inode.c:1301! [SNIP] [ 5447.790721] Call Trace: [ 5447.793191] [<ffffffffa0641c4e>] btrfs_insert_dir_item+0x189/0x1bb [btrfs] [ 5447.800156] [<ffffffffa0651a45>] btrfs_add_link+0x12b/0x191 [btrfs] [ 5447.806517] [<ffffffffa0651adc>] btrfs_add_nondir+0x31/0x58 [btrfs] [ 5447.812876] [<ffffffffa0651d6a>] btrfs_create+0xf9/0x197 [btrfs] [ 5447.818961] [<ffffffff8111f840>] vfs_create+0x72/0x92 [ 5447.824090] [<ffffffff8111fa8c>] do_last+0x22c/0x40b [ 5447.829133] [<ffffffff8112076a>] path_openat+0xc0/0x2ef [ 5447.834438] [<ffffffff810c58e2>] ? __perf_event_task_sched_out+0x24/0x44 [ 5447.841216] [<ffffffff8103ecdd>] ? perf_event_task_sched_out+0x59/0x67 [ 5447.847846] [<ffffffff81121a79>] do_filp_open+0x3d/0x87 [ 5447.853156] [<ffffffff811e126c>] ? strncpy_from_user+0x43/0x4d [ 5447.859072] [<ffffffff8111f1f5>] ? getname_flags+0x2e/0x80 [ 5447.864636] [<ffffffff8111f179>] ? do_getname+0x14b/0x173 [ 5447.870112] [<ffffffff8111f1b7>] ? audit_getname+0x16/0x26 [ 5447.875682] [<ffffffff8112b1ab>] ? spin_lock+0xe/0x10 [ 5447.880882] [<ffffffff81112d39>] do_sys_open+0x69/0xae [ 5447.886153] [<ffffffff81112db1>] sys_open+0x20/0x22 [ 5447.891114] [<ffffffff813b9aab>] system_call_fastpath+0x16/0x1b Fix it by reusing the old delayed node. Reported-by: Jim Schutt <jaschut@sandia.gov> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Tested-by: Jim Schutt <jaschut@sandia.gov> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-06-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: mark CONFIG_CIFS_NFSD_EXPORT as BROKEN cifs: free blkcipher in smbhash
2011-06-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: cifs: propagate errors from cifs_get_root() to mount(2) cifs: tidy cifs_do_mount() up a bit cifs: more breakage on mount failures cifs: close sget() races cifs: pull freeing mountdata/dropping nls/freeing cifs_sb into cifs_umount() cifs: move cifs_umount() call into ->kill_sb() cifs: pull cifs_mount() call up sanitize cifs_umount() prototype cifs: initialize ->tlink_tree in cifs_setup_cifs_sb() cifs: allocate mountdata earlier cifs: leak on mount if we share superblock cifs: don't pass superblock to cifs_mount() cifs: don't leak nls on mount failure cifs: double free on mount failure take bdi setup/destruction into cifs_mount/cifs_umount Acked-by: Steve French <smfrench@gmail.com>
2011-06-25mmc: queue: bring discard_granularity/alignment into line with SCSIAdrian Hunter
SCSI defines discard alignment as the offset to the first optimal discard. In the case of SD/MMC, that is always zero which is the default. SCSI defines discard granularity as a hint of a optimal discard size. That is much better expressed by the MMC "preferred erase size" (pref_erase) field. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-06-25mmc: queue: append partition subname to queue thread nameAdrian Hunter
For example, an eMMC with 2 boot partitions will have 3 threads. The names change from: 40 ? 00:00:00 mmcqd/0 41 ? 00:00:00 mmcqd/0 42 ? 00:00:00 mmcqd/0 to: 40 ? 00:00:00 mmcqd/0 41 ? 00:00:00 mmcqd/0boot0 42 ? 00:00:00 mmcqd/0boot1 Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Andrei Warkentin <andreiw@motorola.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-06-25mmc: core: make erase timeout calculation allow for gated clockAdrian Hunter
The erase timeout calculation may depend on clock rate which is zero if the clock is gated, so use mmc_host_clk_rate() which allows for that case. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-06-25mmc: block: switch card to User Data Area when removing the block driverAdrian Hunter
The MMC block driver and other drivers (e.g. mmc-test) will expect the card to be switched to the User Data Area eMMC partition when they start. Hence the MMC block driver should ensure it is that way when it is removed. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Andrei Warkentin <andreiw@motorola.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-06-25mmc: sdio: reset card during power_restoreDaniel Drake
mmc_sdio_power_restore() skips some steps that are performed in other power-related codepaths which are necessary to fully reset the card. Without this, runtime PM fails for SD8686 SDIO wifi on OLPC XO-1.5. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-06-25mmc: cb710: fix #ifdef HAVE_EFFICIENT_UNALIGNED_ACCESSJames Hogan
HAVE_EFFICIENT_UNALIGNED_ACCESS is a config option, therefore it needs the CONFIG_ before it when used by the preprocessor. Signed-off-by: James Hogan <james@albanarts.com> Acked-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-06-25mmc: sdhi: DMA slave ID 0 is invalidGuennadi Liakhovetski
Don't try to allocate DMA resources if the platform didn't specify positive DMA slave IDs. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-06-25mmc: tmio: fix regression in TMIO_MMC_WRPROTECT_DISABLE handlingGuennadi Liakhovetski
Commit b6147490e6aac82 ("mmc: tmio: split core functionality, DMA and MFD glue") broke handling of the TMIO_MMC_WRPROTECT_DISABLE flag by the tmio-mmc driver. This patch restores the original behaviour. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: <stable@kernel.org> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-06-25mmc: omap_hsmmc: use original sg_len for dma_unmap_sgPer Forlin
Don't use the returned sg_len from dma_map_sg() as inparameter to dma_unmap_sg(). Use the original sg_len for both dma_map_sg and dma_unmap_sg according to the documentation in DMA-API.txt. Signed-off-by: Per Forlin <per.forlin@linaro.org> Reviewed-by: Venkatraman S <svenkatr@ti.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-06-25mmc: omap_hsmmc: fix ocr mask usageAnand Gadiyar
The OMAP HSMMC driver uses an ocr_mask to determine the list of voltages supported by the card. It populates this mask based on the list of voltages supported by the regulator that supplies the voltage. Commit 64be97822b (omap4 hsmmc: Update ocr mask for MMC2 for regulator to use) passed a fixed ocr_mask from the OMAP4 SDP board file to limit the voltage to 2.9-3.0 Volts, and updated the driver to use this mask if provided, instead of using the regulator's supported voltages. However the commit is buggy - the ocr_mask is overridden by the regulator's capabilities anyway. Fix this. (The bug shows up when a system-wide suspend is attempted on the OMAP4 SDP/Blaze platforms. The eMMC card comes up at 3V, but drops to 1.65V after the system resumes). Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Acked-by: Balaji T K <balajitk@ti.com> Acked-by: Venkatraman S <svenkatr@ti.com> Tested-by: Kishore Kadiyala <kishore.kadiyala@ti.com> Signed-off-by: Sourav Poddar <sourav.poddar@ti.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-06-25mmc: sdio: fix runtime PM path during driver removalOhad Ben-Cohen
After commit e1866b3 "PM / Runtime: Rework runtime PM handling during driver removal" was introduced, the driver core stopped incrementing the runtime PM usage counter of the device during the invocation of the ->remove() callback. This indirectly broke SDIO's runtime PM path during driver removal, because no one calls _put_sync() anymore after ->remove() completes. This means that the power of runtime-PM-managed SDIO cards is kept high after their driver is removed (even if it was powered down beforehand). Fix that by directly calling _put_sync() when the last usage counter is downref'ed by the SDIO bus. Reported-and-tested-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-06-25Merge branch 'master' of /pub/scm/linux/kernel/git/torvalds/linux-2.6Steve French
2011-06-25Merge branch 'timer-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timer-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rtc: vt8500: Fix build error & cleanup rtc_class_ops->update_irq_enable() alarmtimers: Return -ENOTSUPP if no RTC device is present alarmtimers: Handle late rtc module loading
