2015-04-22timerqueue: Let timerqueue_add/del return informationThomas Gleixner
The hrtimer code is interested whether the added timer is the first one to expire and whether the removed timer was the last one in the tree. The add/del routines have that information already. So we can return it right away instead of reevaluating it at the call site. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/20150414203501.579063647@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Align the hrtimer clock bases as wellThomas Gleixner
We don't use cacheline_align here because that might waste lot of space on 32bit machine with 64 bytes cachelines and on 64bit machines with 128 bytes cachelines. The size of struct hrtimer_clock_base is 64byte on 64bit and 32byte on 32bit machines. So we utilize the cache lines proper. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203501.498165771@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Cache line align the hrtimer cpu baseThomas Gleixner
We really want that data structure to start at a cache line boundary. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203501.417597627@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Use cpu_base->active_base for hotpath iteratorsThomas Gleixner
The active_bases field is guaranteed to be in sync with the timerqueue of the corresponding clock base. So we can use it for iterating over the clock bases. This allows to break out early if no more active clock bases are available and avoids touching the cache lines of inactive clock bases. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203501.322887675@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Use bits for various boolean indicatorsThomas Gleixner
No point in wasting 12 byte storage space. Generates better code as well. Text size reduction: x8664 -64, i386 -16, ARM -132, ARM64 -0, power64 -48 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203501.227955358@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Make offset update smarterThomas Gleixner
On every tick/hrtimer interrupt we update the offset variables of the clock bases. That's silly because these offsets change very seldom. Add a sequence counter to the time keeping code which keeps track of the offset updates (clock_was_set()). Have a sequence cache in the hrtimer cpu bases to evaluate whether the offsets must be updated or not. This allows us later to avoid pointless cacheline pollution. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/20150414203501.132820245@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org>
2015-04-22hrtimer: Get rid of softirq timeThomas Gleixner
The softirq time field in the clock bases is an optimization from the early days of hrtimers. It provides a coarse "jiffies" like time mostly for self rearming timers. But that comes with a price: - Larger code size - Extra storage space - Duplicated functions with really small differences The benefit of this is optimization is marginal for contemporary systems. Consolidate everything on the high resolution timer implementation. This makes further optimizations possible. Text size reduction: x8664 -95, i386 -356, ARM -148, ARM64 -40, power64 -16 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203501.039977424@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Make the statistics fields smallerThomas Gleixner
No point in having usigned long for /proc/timer_list statistics. Make them unsigned int. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203500.959773467@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Get rid of hrtimer_get_res()Thomas Gleixner
The resolution is directly accessible now. So its simpler just to fill in the values of the timespec and be done with it. Text size reduction (combined with "hrtimer: Get rid of the resolution field in hrtimer_clock_base"): x8664 -61, i386 -221, ARM -60, power64 -48 Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203500.879888080@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22sound: Use hrtimer_resolution instead of hrtimer_get_res()Thomas Gleixner
No point in converting a timespec now that the value is directly accessible. Get rid of the null check while at it. Resolution is guaranteed to be > 0. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: alsa-devel@alsa-project.org Link: http://lkml.kernel.org/r/20150414203500.799133359@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22net: sched: Use hrtimer_resolution instead of hrtimer_get_res()Thomas Gleixner
No point in converting a timespec now that the value is directly accessible. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jamal Hadi Salim <jhs@mojatatu.com> Link: http://lkml.kernel.org/r/20150414203500.720623028@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Get rid of the resolution field in hrtimer_clock_baseThomas Gleixner
The field has no value because all clock bases have the same resolution. The resolution only changes when we switch to high resolution timer mode. We can evaluate that from a single static variable as well. In the !HIGHRES case its simply a constant. Export the variable, so we can simplify the usage sites. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20150414203500.645454122@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Update active_bases before calling hrtimer_force_reprogram()Viresh Kumar
'active_bases' indicates which clock-base have active timer. The intention of this bit field was to avoid evaluating inactive bases. It was introduced with the introduction of the BOOTTIME and TAI clock bases, but it was never brought into full use. We want to use it now, but in __remove_hrtimer() the update happens after the calling hrtimer_force_reprogram() which has to evaluate all clock bases for the next expiring timer. So in case the last timer of a clock base got removed we still see the active bit and therefor evaluate the clock base for no value. There are further optimizations possible when active_bases is updated in the right place. Move the update before the call to hrtimer_force_reprogram() [ tglx: Massaged changelog ] Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: linaro-kernel@lists.linaro.org Link: http://lkml.kernel.org/r/20150414203500.533438642@linutronix.de Link: http://lkml.kernel.org/r/c7c8ebcd9ed88bb09d76059c745a1fafb48314e7.1428039899.git.viresh.kumar@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22hrtimer: Document hrtimer_forward[_now]() properThomas Gleixner
Document the calling context conditions. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20150413210035.178751779@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22timekeeping: Remove stale function prototypeThomas Gleixner
commit 61edec81d260 "timekeeping: Simplify timekeeping_clocktai()" implemented timekeeping_clocktai() as an inline function, but left the old extern prototype in the header file. Remove it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22time: Remove nonexistent function prototypeYingjoe Chen
The function clocksource_get_next() was removed in commit 75c5158f70 (timekeeping: Update clocksource with stop_machine), but the prototype was not removed with it. Remove the prototype. Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Cc: <linux-arm-kernel@lists.infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <srv_heupstream@mediatek.com> Cc: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/1428674150-1780-1-git-send-email-yingjoe.chen@mediatek.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-22timer_list: Reduce SEQ_printf footprintJoe Perches
This macro can be converted to a static function to reduce object size. (x86-64 defconfig) $ size kernel/time/timer_list.o* text data bss dec hex filename 6583 8 0 6591 19bf kernel/time/timer_list.o.old 4647 8 0 4655 122f kernel/time/timer_list.o.new Signed-off-by: Joe Perches <joe@perches.com> Cc: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/1429295958.2850.104.camel@perches.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-04-20Merge tag 'remoteproc-4.1-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc Pull remoteproc update from Ohad Ben-Cohen: "Suman Anna is adding remoteproc support for processors not behind IOMMUs" * tag 'remoteproc-4.1-next' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc: remoteproc: add IOMMU hardware capability flag
2015-04-20Merge branch 'misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull misc kbuild updates: "This is the remaining part of kbuild stuff for v4.1-rc1: - One wew coccinelle script and a clarification of the proposed fix in bugon.coccinelle - CONFIG_KERNEL_LZ4 support for extract-ikconfig" * 'misc' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/coccinelle/misc/bugon.cocci: update bug_on conversion warning scripts/extract-ikconfig: Support LZ4-compressed images. irqf_oneshot.cocci: add check of devm_request_threaded_irq()
2015-04-20Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull SCSI fixes from James Bottomley: "I'd like to say these were a set of regressions for the recent merge window code. Unfortunately, they all predate the merge window code (stable cc'd). There are two fixes for data integrity (mostly only showing up on module removal), an mvsas crash with expander attached SATA devices which goes back to the dawn of the driver but is only just being picked up as sas expanders become a standard item in low end server hardware, an am53c974 one because the interrupt data isn't fully initialised before the line is and a megaraid_sas one because it uses smp_processor_id() to select MSI-X queues and that now triggers a WARN_ON()" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: mvsas: fix panic on expander attached SATA devices am53c974: Fix crash during modprobe megaraid_sas: use raw_smp_processor_id() sd: Fix missing ATO tag check sd: Unregister integrity profile
2015-04-20Merge tag 'fbdev-4.1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux Pull fbdev updates from Tomi Valkeinen: "Small fixes and improvements to various fbdev drivers" * tag 'fbdev-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tomba/linux: (24 commits) omapdss: extend pm notifier to handle hibernation OMAPDSS: Correct video ports description file path in DT binding doc OMAPDSS: disable VT switch fbdev: sh_mobile_lcdc: Fix destruction of uninitialized mutex video: fbdev: sh_mobile_lcdcfb: Fix ROP3 sysfs attribute parsing fbdev: pm3fb: cleanup some confusing indenting hyperv: hyperv_fb: match wait_for_completion_timeout return type video: fbdev: use msecs_to_jiffies for time conversions fbdev: via/via_clock: fix sparse warning video: fbdev: make of_device_id array const fbdev: sm501fb: use memset_io OMAPDSS: workaround for MFLAG + NV12 issue OMAPDSS: Add support for MFLAG OMAPDSS: setup default fifo thresholds OMAPDSS: DISPC: lock access to DISPC_CONTROL & DISPC_CONFIG OMAPDSS: DISPC: fix div by zero issue in overlay scaling OMAPDSS: DISPC: change sync_pclk_edge default value OMAPDSS: change signal_level & signal_edge enum values OMAPDSS: DISPC: explicit handling for sync and de levels OMAPDSS: DISPC: remove OMAPDSS_DRIVE_SIG_OPPOSITE_EDGES ...
2015-04-20Merge branch 'drm-next-merged' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Highlights: Core: - Virtual GEM layer merged, this has been around for a long time, and it provides a software backed device that allows userspace to use it as a GEM shared memory handler. This makes it a lot easier to do certain things when you have no GPU but still have to deal with DRI expectations. - atomic helper updates. - framebuffer modifier interface added. - i2c over auxch displayport fixes. - fb width/height confusion fixes. - new driver for ps8622/ps8625 bridge chips - lots of new panels i915: - more plane atomic conversion - vGPU guest support for XenGT - Skylake workarounds and fixes - Y-tiling support - work on dynamic pagetable allocation - EU count report param for gen9+ - CHV fixes (no longer prelim) - remove ilk rc6 - frontbuffer tracking for fbc - Displayport link rate refactoring - sprite colorkey refactor radeon: - Displayport MST support (not enabled by default) - non-ATOM native hw auxch support (DCE5+) - output csc support - new queries for userspace debug support - new VCE packet nouveau: - gk20a iommu support - gm107 graphics support - more gm20x bringup (waiting on signed nvidia fw). amdkfd: - multiple kgd instance support - use 64-bit time accessors msm: - stolen memory support - DSI and dual-DSI support - snapdragon 410 support exynos: - cleanups for atomic and pageflip imx-drm: - more media-bus formats - TV output prep - drm panel support tegra: - hw vblank counter using host1x syncpoints omap: - universal plane support - prep work for atomic modesetting rcar-du: - ported to atomic modesetting atmel-hlcdc: - ported to atomic modesetting - added suspend/resume support sti: - ported to atomic modesetting dwhdmi: - more compliant audio support - update rockchip phy support tda998x: - DT probing for attached crtcs - simplified EDID reading rockchip: - fixes adv7511: - fixes" * 'drm-next-merged' of git://people.freedesktop.org/~airlied/linux: (689 commits) media-bus: Fixup RGB444_1X12, RGB565_1X16, and YUV8_1X24 media bus format drm/i915: Dont enable CS_PARSER_ERROR interrupts at all drm/i915: Move drm_framebuffer_unreference out of struct_mutex for takeover drm: fix trivial typo mistake drm: Make integer overflow checking cover universal cursor updates (v2) drm/nouveau/bios: fix fetching from acpi on certain systems drm/nouveau/gr/gm206: initial init+ctx code drm/nouveau/ce/gm206: enable support via gm204 code drm/nouveau/fifo/gm206: enable support via gm204 code drm/nouveau/gr/gm204: initial init+ctx code drm/nouveau: support for buffer moves via MaxwellDmaCopyA drm/nouveau/ce/gm204: initial support drm/nouveau: add support for gm20x fifo channels drm/nouveau/fifo/gm204: initial support drm/nouveau/gr/gk104-: prevent reading non-existent regs in intr handler drm/nouveau/gr/gm107: very slightly demagic part of attrib cb setup drm/nouveau/gr/gk104-: correct crop/zrop num_active_fbps setting drm/nouveau/gr/gf100-: add symbolic names for classes drm/nouveau/gr/gm107: support tpc "strand" ctxsw in gpccs ucode drm/nouveau/gr/gf100-: support mmio access with gpc offset from gpccs ucode ...
2015-04-20Merge tag 'iommu-updates-v4.1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU updates from Joerg Roedel: "Not much this time, but the changes include: - moving domain allocation into the iommu drivers to prepare for the introduction of default domains for devices - fixing the IO page-table code in the AMD IOMMU driver to correctly encode large page sizes - extension of the PCI support in the ARM-SMMU driver - various fixes and cleanups" * tag 'iommu-updates-v4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (34 commits) iommu/amd: Correctly encode huge pages in iommu page tables iommu/amd: Optimize amd_iommu_iova_to_phys for new fetch_pte interface iommu/amd: Optimize alloc_new_range for new fetch_pte interface iommu/amd: Optimize iommu_unmap_page for new fetch_pte interface iommu/amd: Return the pte page-size in fetch_pte iommu/amd: Add support for contiguous dma allocator iommu/amd: Don't allocate with __GFP_ZERO in alloc_coherent iommu/amd: Ignore BUS_NOTIFY_UNBOUND_DRIVER event iommu/amd: Use BUS_NOTIFY_REMOVED_DEVICE iommu/tegra: smmu: Compute PFN mask at runtime iommu/tegra: gart: Set aperture at domain initialization time iommu/tegra: Setup aperture iommu: Remove domain_init and domain_free iommu_ops iommu/fsl: Make use of domain_alloc and domain_free iommu/rockchip: Make use of domain_alloc and domain_free iommu/ipmmu-vmsa: Make use of domain_alloc and domain_free iommu/shmobile: Make use of domain_alloc and domain_free iommu/msm: Make use of domain_alloc and domain_free iommu/tegra-gart: Make use of domain_alloc and domain_free iommu/tegra-smmu: Make use of domain_alloc and domain_free ...
2015-04-20Merge tag 'cpumask-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull final removal of deprecated cpus_* cpumask functions from Rusty Russell: "This is the final removal (after several years!) of the obsolete cpus_* functions, prompted by their mis-use in staging. With these function removed, all cpu functions should only iterate to nr_cpu_ids, so we finally only allocate that many bits when cpumasks are allocated offstack" * tag 'cpumask-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (25 commits) cpumask: remove __first_cpu / __next_cpu cpumask: resurrect CPU_MASK_CPU0 linux/cpumask.h: add typechecking to cpumask_test_cpu cpumask: only allocate nr_cpumask_bits. Fix weird uses of num_online_cpus(). cpumask: remove deprecated functions. mips: fix obsolete cpumask_of_cpu usage. x86: fix more deprecated cpu function usage. ia64: remove deprecated cpus_ usage. powerpc: fix deprecated CPU_MASK_CPU0 usage. CPU_MASK_ALL/CPU_MASK_NONE: remove from deprecated region. staging/lustre/o2iblnd: Don't use cpus_weight staging/lustre/libcfs: replace deprecated cpus_ calls with cpumask_ staging/lustre/ptlrpc: Do not use deprecated cpus_* functions blackfin: fix up obsolete cpu function usage. parisc: fix up obsolete cpu function usage. tile: fix up obsolete cpu function usage. arm64: fix up obsolete cpu function usage. mips: fix up obsolete cpu function usage. x86: fix up obsolete cpu function usage. ...
2015-04-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull more s390 updates from Martin Schwidefsky: "The big thing in this second merge for s390 is the new eBPF JIT from Michael which replaces the old 32-bit backend. The remaining commits are bug fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/pci: add locking for fmb access s390/pci: extract software counters from fmb s390/dasd: Fix unresumed device after suspend/resume having no paths s390/dasd: fix unresumed device after suspend/resume s390/dasd: fix inability to set a DASD device offline s390/mm: Fix memory hotplug for unaligned standby memory s390/bpf: Add s390x eBPF JIT compiler backend s390: Use bool function return values of true/false not 1/0
2015-04-20Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu Pull m68k fixes from Greg Ungerer: "Nothing big, spelling fixes and fix/cleanup for ColdFire eth device setup" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68knommu: fix fec setup warning for ColdFire 5271 builds m68knommu: ColdFire 5271 only has a single FEC controller m68k: Fix trivial typos in comments
2015-04-20smp: don't use 16-bit words for atomic accessesLinus Torvalds
Yes, it should work, but it's a bad idea. Not only did ARM64 not have the 16-bit access code (there's a separate patch to add it), it's just not a good atomic type. Some architectures fundamentally don't do atomic accesses in them (alpha), and it's not like it saves any space here anyway because of structure packing issues. We normally should aim for flags to be "unsigned int" or "unsigned long". And if space is at a premium, use a single byte (although that causes problems on alpha again). There might be very special cases where a 16-byte entity is really wanted, but this is not one of them. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-20Merge omapdss topic branch for fbdev 4.1Tomi Valkeinen
2015-04-20omapdss: extend pm notifier to handle hibernationGrygorii Strashko
Add handling of missed events in omap_dss_pm_notif which are needed to support hibernation (suspend to disk). Signed-off-by: Grygorii Strashko <Grygorii.Strashko@linaro.org> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-04-20OMAPDSS: Correct video ports description file path in DT binding docJavier Martinez Canillas
The doc refers to Documentation/devicetree/bindings/video/video-ports.txt which does not exist. The documentation seems to be outdated and wants to refer to Documentation/devicetree/bindings/graph.txt instead. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
2015-04-20OMAPDSS: disable VT switchTomi Valkeinen
We don't need VT switch when suspending/resuming, so disable it. This speeds up suspend/resume. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: NeilBrown <neil@brown.name>
2015-04-20Merge Linus master into drm-nextDave Airlie
The merge is clean, but the arm build fails afterwards, due to API changes in the regulator tree. I've included the patch into the merge to fix the build. Signed-off-by: Dave Airlie <airlied@redhat.com>
2015-04-20media-bus: Fixup RGB444_1X12, RGB565_1X16, and YUV8_1X24 media bus formatPhilipp Zabel
Change the constant values for RGB444_1X12, RGB565_1X16, and YUV8_1X24 media bus formats in anticipation of a merge conflict with the media tree, where the old values are already taken by RBG888_1X24, RGB888_1X32_PADHI, and VUY8_1X24, respectively. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2015-04-19Merge branch 'turbostat' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull turbostat update from Len Brown: "Updates to the turbostat utility. Just one kernel dependency in this batch -- added a #define to msr-index.h" * 'turbostat' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: tools/power turbostat: correct dumped pkg-cstate-limit value tools/power turbostat: calculate TSC frequency from CPUID(0x15) on SKL tools/power turbostat: correct DRAM RAPL units on recent Xeon processors tools/power turbostat: Initial Skylake support tools/power turbostat: Use $(CURDIR) instead of $(PWD) and add support for O= option in Makefile tools/power turbostat: modprobe msr, if needed tools/power turbostat: dump MSR_TURBO_RATIO_LIMIT2 tools/power turbostat: use new MSR_TURBO_RATIO_LIMIT names x86 msr-index: define MSR_TURBO_RATIO_LIMIT,1,2 tools/power turbostat: label base frequency tools/power turbostat: update PERF_LIMIT_REASONS decoding tools/power turbostat: simplify default output
2015-04-19Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "A few bug fixes and add support for file-system level encryption in ext4" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (31 commits) ext4 crypto: enable encryption feature flag ext4 crypto: add symlink encryption ext4 crypto: enable filename encryption ext4 crypto: filename encryption modifications ext4 crypto: partial update to namei.c for fname crypto ext4 crypto: insert encrypted filenames into a leaf directory block ext4 crypto: teach ext4_htree_store_dirent() to store decrypted filenames ext4 crypto: filename encryption facilities ext4 crypto: implement the ext4 decryption read path ext4 crypto: implement the ext4 encryption write path ext4 crypto: inherit encryption policies on inode and directory create ext4 crypto: enforce context consistency ext4 crypto: add encryption key management facilities ext4 crypto: add ext4 encryption facilities ext4 crypto: add encryption policy and password salt support ext4 crypto: add encryption xattr support ext4 crypto: export ext4_empty_dir() ext4 crypto: add ext4 encryption Kconfig ext4 crypto: reserve codepoints used by the ext4 encryption feature ext4 crypto: add ext4_mpage_readpages() ...
2015-04-19hexdump: avoid warning in test functionLinus Torvalds
The test_data_1_le[] array is a const array of const char *. To avoid dropping any const information, we need to use "const char * const *", not just "const char **". I'm not sure why the different test arrays end up having different const'ness, but let's make the pointer we use to traverse them as const as possible, since we modify neither the array of pointers _or_ the pointers we find in the array. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-19fs: take i_mutex during prepare_binprm for set[ug]id executablesJann Horn
This prevents a race between chown() and execve(), where chowning a setuid-user binary to root would momentarily make the binary setuid root. This patch was mostly written by Linus Torvalds. Signed-off-by: Jann Horn <jann@thejh.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-19smp: Fix error case handling in smp_call_function_*()Linus Torvalds
Commit 8053871d0f7f ("smp: Fix smp_call_function_single_async() locking") fixed the locking for the asynchronous smp-call case, but in the process of moving the lock handling around, one of the error cases ended up not unlocking the call data at all. This went unnoticed on x86, because this is a "caller is buggy" case, where the caller is trying to call a non-existent CPU. But apparently ARM does that (at least under qemu-arm). Bindly doing cross-cpu calls to random CPU's that aren't even online seems a bit fishy, but the error handling was clearly not correct. Simply add the missing "csd_unlock()" to the error path. Reported-and-tested-by: Guenter Roeck <linux@roeck-us.net> Analyzed-by: Rabin Vincent <rabin@rab.in> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-19cpumask: remove __first_cpu / __next_cpuRusty Russell
They were for use by the deprecated first_cpu() and next_cpu() wrappers, but sparc used them directly. They're now replaced by cpumask_first / cpumask_next. And __next_cpu_nr is completely obsolete. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: David S. Miller <davem@davemloft.net>
2015-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fixes from David Miller "Unfortunately, I brown paper bagged the generic iommu pool allocator by applying the wrong revision of the patch series. This reverts the bad one, and puts the right one in" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: iommu-common: Fix PARISC compile-time warnings sparc: Make LDC use common iommu poll management functions sparc: Make sparc64 use scalable lib/iommu-common.c functions Break up monolithic iommu table/lock into finer graularity pools and lock sparc: Revert generic IOMMU allocator.
2015-04-18Merge tag 'for-linus-4.1-merge-window' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs Pull 9pfs updates from Eric Van Hensbergen: "Some accumulated cleanup patches for kerneldoc and unused variables as well as some lock bug fixes and adding privateport option for RDMA" * tag 'for-linus-4.1-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: net/9p: add a privport option for RDMA transport. fs/9p: Initialize status in v9fs_file_do_lock. net/9p: Initialize opts->privport as it should be. net/9p: use memcpy() instead of snprintf() in p9_mount_tag_show() 9p: use unsigned integers for nwqid/count 9p: do not crash on unknown lock status code 9p: fix error handling in v9fs_file_do_lock 9p: remove unused variable in p9_fd_create() 9p: kerneldoc warning fixes
2015-04-18Merge branch 'iommu-generic-allocator'David S. Miller
Sowmini Varadhan says: ==================== Generic IOMMU pooled allocator Investigation of network performance on Sparc shows a high degree of locking contention in the IOMMU allocator, and it was noticed that the PowerPC code has a better locking model. This patch series tries to extract the generic parts of the PowerPC code so that it can be shared across multiple PCI devices and architectures. v10: resend patchv9 without RFC tag, and a new mail Message-Id, (previous non-RFC attempt did not show up on the patchwork queue?) Full revision history below: v2 changes: - incorporate David Miller editorial comments: sparc specific fields moved from iommu-common into sparc's iommu_64.h - make the npools value an input parameter, for the case when the iommu map size is not very large - cookie_to_index mapping, and optimizations for span-boundary check, for use case such as LDC. v3: eliminate iommu_sparc, rearrange the ->demap indirection to be invoked under the pool lock. v4: David Miller review changes: - s/IOMMU_ERROR_CODE/DMA_ERROR_CODE - page_table_map_base and page_table_shift are unsigned long, not u32. v5: removed ->cookie_to_index and ->demap indirection from the iommu_tbl_ops The caller needs to call these functions as needed, before invoking the generic arena allocator functions. Added the "skip_span_boundary" argument to iommu_tbl_pool_init() for those callers like LDC which do no care about span boundary checks. v6: removed iommu_tbl_ops, and instead pass the ->flush_all as an indirection to iommu_tbl_pool_init(); only invoke ->flush_all when there is no large_pool, based on the assumption that large-pool usage is infrequently encountered v7: moved pool_hash initialization to lib/iommu-common.c and cleaned up code duplication from sun4v/sun4u/ldc. v8: Addresses BenH comments with one exception: I've left the IOMMU_POOL_HASH as is, so that powerpc can tailor it to their convenience. Discard trylock for simple spin_lock to acquire pool v9: Addresses latest BenH comments: need_flush checks, add support for dma mask and align_order. v10: resend without RFC tag, and new mail Message-Id. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-18iommu-common: Fix PARISC compile-time warningsSowmini Varadhan
Fixes warnings due to - no DMA_ERROR_CODE on PARISC, - sizeof (unsigned long) == 4 bytes on PARISC. Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-18sparc: Make LDC use common iommu poll management functionsSowmini Varadhan
Note that this conversion is only being done to consolidate the code and ensure that the common code provides the sufficient abstraction. It is not expected to result in any noticeable performance improvement, as there is typically one ldc_iommu per vnet_port, and each one has 8k entries, with a typical request for 1-4 pages. Thus LDC uses npools == 1. Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-18sparc: Make sparc64 use scalable lib/iommu-common.c functionsSowmini Varadhan
In iperf experiments running linux as the Tx side (TCP client) with 10 threads results in a severe performance drop when TSO is disabled, indicating a weakness in the software that can be avoided by using the scalable IOMMU arena DMA allocation. Baseline numbers before this patch: with default settings (TSO enabled) : 9-9.5 Gbps Disable TSO using ethtool- drops badly: 2-3 Gbps. After this patch, iperf client with 10 threads, can give a throughput of at least 8.5 Gbps, even when TSO is disabled. Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-18Break up monolithic iommu table/lock into finer graularity pools and lockSowmini Varadhan
Investigation of multithreaded iperf experiments on an ethernet interface show the iommu->lock as the hottest lock identified by lockstat, with something of the order of 21M contentions out of 27M acquisitions, and an average wait time of 26 us for the lock. This is not efficient. A more scalable design is to follow the ppc model, where the iommu_map_table has multiple pools, each stretching over a segment of the map, and with a separate lock for each pool. This model allows for better parallelization of the iommu map search. This patch adds the iommu range alloc/free function infrastructure. Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-18sparc: Revert generic IOMMU allocator.David S. Miller
I applied the wrong version of this patch series, V4 instead of V10, due to a patchwork bundling snafu. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-18tools/power turbostat: correct dumped pkg-cstate-limit valueLen Brown
HSW expanded MSR_PKG_CST_CONFIG_CONTROL.Package-C-State-Limit, from bits[2:0] used by previous implementations, to [3:0]. The value 1000b is unlimited, and is used by BDW and SKL too. Signed-off-by: Len Brown <len.brown@intel.com>
2015-04-18tools/power turbostat: calculate TSC frequency from CPUID(0x15) on SKLLen Brown
turbostat --debug ... CPUID(0x15): eax_crystal: 2 ebx_tsc: 100 ecx_crystal_hz: 0 TSC: 1200 MHz (24000000 Hz * 100 / 2 / 1000000) Signed-off-by: Len Brown <len.brown@intel.com>
2015-04-18tools/power turbostat: correct DRAM RAPL units on recent Xeon processorsAndrey Semin
While not yet documented in the Software Developer's Manual, the data-sheet for modern Xeon states that DRAM RAPL ENERGY units are fixed at 15.3 uJ, rather than being discovered via MSR. Before this patch, DRAM energy on these products is over-stated by turbostat because the RAPL units are 4x larger. ref: "Xeon E5-2600 v3/E5-1600 v3 Datasheet Volume 2" http://www.intel.com/content/dam/www/public/us/en/documents/datasheets/xeon-e5-v3-datasheet-vol-2.pdf Signed-off-by: Andrey Semin <andrey.semin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
