Complete moving arch/ppc64/kernel/mpic.h,
include/asm-ppc/reg.h, include/asm-ppc64/kdebug.h
and include/asm-ppc64/kprobes.h
Add arch/powerpc/platforms/Makefile and use it from
arch/powerpc/Makefile
Introduce OLDARCH temporarily so we can point back to
the originating architecture
This creates the directory structure under arch/powerpc and a bunch
of Kconfig files. It does a first-cut merge of arch/powerpc/mm,
arch/powerpc/lib and arch/powerpc/platforms/powermac. This is enough
to build a 32-bit powermac kernel with ARCH=powerpc.
For now we are getting some unmerged files from arch/ppc/kernel and
arch/ppc/syslib, or arch/ppc64/kernel. This makes some minor changes
to files in those directories and files outside arch/powerpc.
The boot directory is still not merged. That's going to be interesting.
powerpc: Merge semaphore.h
Adopted the ppc64 version of semaphore.h. The 32-bit version used
smp_wmb(), but recent updates to atomic.h mean this is no longer required.
The 64-bit version made use of unlikely(), which has been retained in the
combined version.
This patch requires the recent atomic.h patch.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
Merge asm-ppc*/rwsem.h into include/asm-powerpc.
Removed smp_*mb() memory barriers from the ppc32 code
as they are now burried in the atomic_*() functions as
suggested by Paul, implemented by Arnd, and pushed out
by Becky. I am not the droid you are looking for.
This patch depends on Becky's atomic.h merge patch.
powerpc: Merge atomic.h and memory.h into powerpc
Merged atomic.h into include/powerpc. Moved asm-style HMT_ defines from
memory.h into ppc_asm.h, where there were already HMT_defines; moved c-style
HMT_ defines to processor.h. Renamed memory.h to synch.h to better reflect
its contents.
Signed-off-by: Jon Loeliger <linuxppc@jdl.com>
Merge asm-ppc*/seccomp.h. Drop TIF_32BIT check.
The spinlock_types.h merge renamed the structure for raw_spinlock_t to
match ppc64. In doing so some of the spinlock macros/functions needed to
be updated to match. Apparently, this seems to only be caught when
building power3.
The wwitch bitmap was added to input_device_id structure and we should
check it when matching handlers and input devices.
Add 'volatile' to the __iomem pointers for these functions as
per x86.
ucb1x00-ts declared a couple of one-bit 'int' bitfields.
Make them unsigned.
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
This is one of those workarounds sucked over from sk98lin driver.
The skge driver needs to detect the Yukon-Lite A0 chip properly,
and turn of Rx FIFO Flush.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
We accidentally corrupted the TLS value when clearing out the ARMv6
exclusive monitor. Avoid doing so.
As davem points out, this wasn't such a great idea. There may be some code
which does:
size = 1024*1024;
while (kmalloc(size, ...) == 0)
size /= 2;
which will now explode.
Cc: Christoph Lameter <christoph@lameter.com>
Signed-off-by: Harald Welte <laforge@netfilter.org>
I found an inconsistent spin_lock usage in ipmi_smi_msg_received.
Signed-off-by: Hironobu Ishii <hishii@soft.fujitsu.com>
Cc: Corey Minyard <minyard@acm.org>
Current kernel has a couple of sneaky bugs in the ppc64 hugetlb code that
cause huge pages to be potentially left stale in the hash table and TLBs
(improperly invalidated), with all the nasty consequences that can have.
One is that we forgot to set the "secondary" bit in the hash PTEs when
hashing a huge page in the secondary bucket (fortunately very rare).
The other one is on non-LPAR machines (like Apple G5s), flush_hash_range()
which is used to flush a batch of PTEs simply did not work for huge pages.
Historically, our huge page code didn't batch, but this was changed without
fixing this routine. This patch fixes both.
- fix this:
drivers/video/aty/xlinit.c: In function `atyfb_xl_init':
drivers/video/aty/xlinit.c:256: warning: ISO C90 forbids mixed declarations and code
- repair some kooky coding style
- Use ARRAY_SIZE()
Cc: Tom 'spot' Callaway <tcallawa@redhat.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
usb_unlink_urb is always async now, so URB_ASYNC_UNLINK was removed from
core USB and we must do as well.
Signed-off-by: Karsten Keil <kkeil@suse.de>
Cc: Greg KH <greg@kroah.com>
Bhavesh P. Davda <bhavesh@avaya.com> noticed that SIGKILL wouldn't
properly kill a process under just the right cicumstances: a stopped
task that already had another signal queued would get the SIGKILL
queued onto the shared queue, and there it would remain until SIGCONT.
This simplifies the signal acceptance logic, and fixes the bug in the
process.
Losely based on an earlier patch by Bhavesh.
cifsd had been preventing software suspend from completing.
Signed-off-by: pavel@suse.de
Signed-off-by: Steve French <sfrench@us.ibm.com> lightly modified
I believe the change that broke things is introduction of
pci_fixup_parent_subordinate_busnr().
The patch here does two things:
- hunk #1 should fix the problems you've seen when you boot without
additional "pci" kernel options;
- hunk #2 supposedly fixes boot with "pci=assign-busses" option which
otherwise hangs Acer TM81xx machines as reported.
Please try this with and without "pci=assign-busses". If it boots,
I'd like to see 'lspci -vvx' for both cases.
master.kernel.org:/pub/scm/linux/kernel/git/shaggy/jfs-2.6
While this is true, E8390_CMD is zero on i386, and thus there should be no
effect for these machines. Machines like Mac, Amiga etc. which use Alan's
clever register mapping may have a non-zero E8390_CMD and result in bogus
"transmitter busy" type messages from this bug.
Fixes BUG# 3991.
Fix to allow SCTP_SHUTDOWN notifications to be received on 1-1 style
SCTP SOCK_STREAM sockets.
Add SCTP_SHUTDOWN notification to the receive queue before updating
the state of the association.
Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
This patch fixes a number of bugs. It cannot be reasonably split up in
multiple fixes, since all bugs interact with each other and affect the same
function:
Bug #1:
The event cache code cannot be called while a lock is held. Therefore, the
call to ip_conntrack_event_cache() within ip_ct_refresh_acct() needs to be
moved outside of the locked section. This fixes a number of 2.6.14-rcX
oops and deadlock reports.
Bug #2:
We used to call ct_add_counters() for unconfirmed connections without
holding a lock. Since the add operations are not atomic, we could race
with another CPU.
Bug #3:
ip_ct_refresh_acct() lost REFRESH events in some cases where refresh
(and the corresponding event) are desired, but no accounting shall be
performed. Both, evenst and accounting implicitly depended on the skb
parameter bein non-null. We now re-introduce a non-accounting
"ip_ct_refresh()" variant to explicitly state the desired behaviour.
As noted by Alexey Dobriyan, the DEBUGP statement prints the wrong
callID.
Signed-off-by: Vlad Drukker <vlad@storewiz.com>
Acked-by: Stephen Hemminger <shemminger@osdl.org>
Since the introduction of TSO pcount a year ago, it has been possible
for tcp_fragment() to cause packets_out to decrease. Prior to that,
tcp_retrans_try_collapse() was the only way for that to happen on the
retransmission path.
When this happens with Reno, it is possible for sasked_out to become
invalid because it is only an estimate and not tied to any particular
packet on the retransmission queue.
Therefore we need to adjust sacked_out as well as left_out in the Reno
case. The following patch does exactly that.
This bug is pretty difficult to trigger in practice though since you
need a SACKless peer with a retransmission that occurs just as the
cached MTU value expires.
I've recently discovered the real functionality of device-mapper snapshots,
and since they are not well known, I've decided to write some docs for
them.
Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
nfs_readpage_release() causes an oops while accessing a file with NFS
debugging turned on (echo 32767 > /proc/sys/sunrpc/nfs_debug) and a kernel
built with CONFIG_DEBUG_SLAB.
This patch moves the debugging statement above nfs_release_request() to
avoid accessing freed memory.
Signed-off-by: Nick Wilson <njw@osdl.org>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Problem: In some circumstances, bd_claim() is returning the wrong error
code.
If we try to swapon an unused block device that isn't swap formatted, we
get -EINVAL. But if that same block device is already mounted, we instead
get -EBUSY, even though it still isn't a valid swap device.
This issue came up on the busybox list trying to get the error message
from "swapon -a" right. If a swap device is already enabled, we get -EBUSY,
and we shouldn't report this as an error. But we can't distinguish the two
-EBUSY conditions, which are very different errors.
In the code, bd_claim() returns either 0 or -EBUSY, but in this case busy
means "somebody other than sys_swapon has already claimed this", and
_that_ means this block device can't be a valid swap device. So return
-EINVAL there.
Signed-off-by: Rob Landley <rob@landley.net>
Fix some warnings and a build error when EXT3_DEBUG is enabled.
It's deprecated. Use "%s", __FUNCTION__ instead.
Signed-off-by: Clemens Buchacher <drizzd@aon.at>
Signed-off-by: Maximilian Attems <janitor@sternwelten.at>
Signed-off-by: Domen Puncer <domen@coderock.org>
Remove io_remap_page_range() from all of Linux 2.6.x (as requested and
suggested by Randy Dunlap) and minor clean-ups.
Signed-off-by: Chris Zankel <chris@zankel.net>
failure
User get *a lot* confused when consoles don't work but we don't report
anything. And, as reported in the comment, using printk to report "your
console doesn't work" isn't likely to go that far.
Fix the problem on the base of this: stack consumption by host printf(). Use
kernel sprintf() and os_write_file, using a wild guess that one page will be
enough for the message, to preallocate the buffer with kmalloc().
Cc: Jeff Dike <jdike@addtoit.com>
setup_initial_poll is only called with sigio_lock() held, so use appropriate
allocation.
Also, parse_chan() can also be called when holding a spinlock (see line_open()
-> parse_chan_pair()).
I have sporadic problems (spinlock taken twice, with spinlock debugging on UP)
which could be caused by a sequence like "take spinlock, alloc and go to
sleep, take again the spinlock in the other thread".
GFP_ATOMIC | GFP_KERNEL is meaningless and won't work. Actually it never
worked, even in 2.4.
Following i386, we should maybe refuse trying to fault in pages when we're
doing atomic operations, because to handle the fault we could need to take
already taken spinlocks.
Also, if we're doing an atomic operation (in the sense of in_atomic()) we're
surely in kernel mode and we're surely going to handle adequately the failed
fault, so it's safe to behave this way.
Currently, on UML SMP is rarely used, and we don't support PREEMPT, so this is
unlikely to create problems right now, but it might in the future.
