Every now and then someone proposes a new flink syscall, and this spawns
a long discussion of whether it would be a security problem. I think
that this is missing the point: flink is *already* allowed without
privilege as long as /proc is mounted -- it's called AT_SYMLINK_FOLLOW.
Now that O_TMPFILE is here, the ability to create a file with O_TMPFILE,
write it, and link it in is very convenient. The only problem is that
it requires that /proc be mounted so that you can do:
linkat(AT_FDCWD, "/proc/self/fd/<tmpfd>", dfd, path, AT_SYMLINK_NOFOLLOW)
This sucks -- it's much nicer to do:
linkat(tmpfd, "", dfd, path, AT_EMPTY_PATH)
Let's allow it.
If this turns out to be excessively scary, it we could instead require
that the inode in question be I_LINKABLE, but this seems pointless given
the /proc situation
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
O_TMPFILE, like O_CREAT, should respect the requested mode and should
create regular files.
This fixes two bugs: O_TMPFILE required privilege (because the mode
ended up as 000) and it produced bogus inodes with no type.
Since remove_proc_entry() started to wait for IO in progress (i.e.
since 2007 or so), the locking in fs/reiserfs/proc.c became wrong;
if procfs read happens between the moment when umount() locks the
victim superblock and removal of /proc/fs/reiserfs/<device>/*,
we'll get a deadlock - read will wait for s_umount (in sget(),
called by r_start()), while umount will wait in remove_proc_entry()
for that read to finish, holding s_umount all along.
Fortunately, the same change allows a much simpler race avoidance -
all we need to do is remove the procfs entries in the very beginning
of reiserfs ->kill_sb(); that'll guarantee that pointer to superblock
will remain valid for the duration for procfs IO, so we don't need
sget() to keep the sucker alive. As the matter of fact, we can
get rid of the home-grown iterator completely, and use single_open()
instead.
Pull dmaengine fixes from Vinod Koul:
"Two fixes for slave dmaengine. The first fixes cyclic dma transfers
for pl330 and the second one makes us return the correct error code on
probe"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dma: pl330: Fix cyclic transfers
pch_dma: fix error return code in pch_dma_probe()
Pull drm fix from Dave Airlie:
"Just a quick fix that a few people have reported, be nice to have in
asap"
The drm tree seems to be very confused about 64-bit divides. Here it
uses a slow 64-by-64 bit divide to divide by a small constant. Oh well.
Doesn't look performance-critical, just stupid.
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/radeon: fix 64 bit divide in SI spm code
Commit 46a1c2c7ae53 ("vfs: export lseek_execute() to modules") broke the
tmpfs SEEK_DATA/SEEK_HOLE implementation, because vfs_setpos() converts
the carefully prepared -ENXIO to -EINVAL. Other filesystems avoid it in
error cases: do the same in tmpfs.
Cc: Jie Liu <jeff.liu@oracle.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"All small regression or small fixes, nothing surprising at this stage.
- regression fix for intel Mac Mini quirk
- compress ioctl error fix
- ASoC fixes for control change notifications, some UI fixes,
driver-specific fixes (resource leak, build errors, etc)"
* tag 'sound-3.11' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Fix missing fixup for Mac Mini with STAC9221
ASoC: wm0010: Fix resource leak
ASoC: au1x: Fix build
ASoC: bf5xx-ac97: Fix compile error with SND_BF5XX_HAVE_COLD_RESET
ASoC: bfin-ac97: Fix prototype error following AC'97 refactoring
ALSA: compress: fix the return value for SNDRV_COMPRESS_VERSION
ASoC: dapm: Fix return value of snd_soc_dapm_put_{volsw,enum_virt}()
Forgot to use the appropriate math64 function.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Dave Airlie <airlied@gmail.com>
Pull networking fixes from David Miller:
1) Don't ignore user initiated wireless regulatory settings on cards
with custom regulatory domains, from Arik Nemtsov.
2) Fix length check of bluetooth information responses, from Jaganath
Kanakkassery.
3) Fix misuse of PTR_ERR in btusb, from Adam Lee.
4) Handle rfkill properly while iwlwifi devices are offline, from
Emmanuel Grumbach.
5) Fix r815x devices DMA'ing to stack buffers, from Hayes Wang.
6) Kernel info leak in ATM packet scheduler, from Dan Carpenter.
7) 8139cp doesn't check for DMA mapping errors, from Neil Horman.
8) Fix bridge multicast code to not snoop when no querier exists,
otherwise mutlicast traffic is lost. From Linus Lüssing.
9) Avoid soft lockups in fib6_run_gc(), from Michal Kubecek.
10) Fix races in automatic address asignment on ipv6, which can result
in incorrect lifetime assignments. From Jiri Benc.
11) Cure build bustage when CONFIG_NET_LL_RX_POLL is not set and rename
it CONFIG_NET_RX_BUSY_POLL to eliminate the last reference to the
original naming of this feature. From Cong Wang.
12) Fix crash in TIPC when server socket creation fails, from Ying Xue.
13) macvlan_changelink() silently succeeds when it shouldn't, from
Michael S Tsirkin.
14) HTB packet scheduler can crash due to sign extension, fix from
Stephen Hemminger.
15) With the cable unplugged, r8169 prints out a message every 10
seconds, make it netif_dbg() instead of netif_warn(). From Peter
Wu.
16) Fix memory leak in rtm_to_ifaddr(), from Daniel Borkmann.
17) sis900 gets spurious TX queue timeouts due to mismanagement of link
carrier state, from Denis Kirjanov.
18) Validate somaxconn sysctl to make sure it fits inside of a u16.
From Roman Gushchin.
19) Fix MAC address filtering on qlcnic, from Shahed Shaikh.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (68 commits)
qlcnic: Fix for flash update failure on 83xx adapter
qlcnic: Fix link speed and duplex display for 83xx adapter
qlcnic: Fix link speed display for 82xx adapter
qlcnic: Fix external loopback test.
qlcnic: Removed adapter series name from warning messages.
qlcnic: Free up memory in error path.
qlcnic: Fix ingress MAC learning
qlcnic: Fix MAC address filter issue on 82xx adapter
net: ethernet: davinci_emac: drop IRQF_DISABLED
netlabel: use domain based selectors when address based selectors are not available
net: check net.core.somaxconn sysctl values
sis900: Fix the tx queue timeout issue
net: rtm_to_ifaddr: free ifa if ifa_cacheinfo processing fails
r8169: remove "PHY reset until link up" log spam
net: ethernet: cpsw: drop IRQF_DISABLED
htb: fix sign extension bug
macvlan: handle set_promiscuity failures
macvlan: better mode validation
tipc: fix oops when creating server socket fails
net: rename CONFIG_NET_LL_RX_POLL to CONFIG_NET_RX_BUSY_POLL
Flash update routine was improperly checking register read API return value.
Modify register read API and perform proper error check.
Signed-off-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
o Set link speed and duplex to unknown when link is not up.
Signed-off-by: Rajesh Borundia <rajesh.borundia@qlogic.com>
Signed-off-by: Shahed Shaikh <shahed.shaikh@qlogic.com>
o Do not obtain link speed from register when adapter
link is down.
Driver was not handling external loopback diagnostic
test request.
Signed-off-by: Pratik Pujar <pratik.pujar@qlogic.com>
o Delete MAC address from the adapter's filter table
if the source MAC address of ingress packet matches.
Driver was passing the address of a pointer instead of
the pointer itself.
IRQF_DISABLED is a no-op by now and should be removed.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Pull nfsd bugfixes from Bruce Fields:
"Most of this is due to a screwup on my part -- some gss-proxy crashes
got fixed before the merge window but somehow never made it out of a
temporary git repo on my laptop...."
* 'for-3.11' of git://linux-nfs.org/~bfields/linux:
svcrpc: set cr_gss_mech from gss-proxy as well as legacy upcall
svcrpc: fix kfree oops in gss-proxy code
svcrpc: fix gss-proxy xdr decoding oops
svcrpc: fix gss_rpc_upcall create error
NFSD/sunrpc: avoid deadlock on TCP connection due to memory pressure.
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fix from Guenter Roeck:
"Fix chip initialization/configuration in MAX6697 driver"
* tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (max6697) fix MAX6581 ideality
Pull arm fixes fixes from Russell King:
"This fixes a couple of problems with commit 48be69a026b2 ("ARM: move
signal handlers into a vdso-like page"), one of which was originally
discovered via my testing originally, but the fix for it was never
actually committed.
The other shows up on noMMU builds, and such platforms are extremely
rare and as such are not part of my nightly testing"
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: fix nommu builds with 48be69a02 (ARM: move signal handlers into a vdso-like page)
ARM: fix a cockup in 48be69a02 (ARM: move signal handlers into a vdso-like page)
Without this patch, the values for ideality (register 0x4b) and ideality
selection mask (register 0x4c) are inverted.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Cc: stable@vger.kernel.org # 3.9+
vdso-like page)
Olof reports that noMMU builds error out with:
arch/arm/kernel/signal.c: In function 'setup_return':
arch/arm/kernel/signal.c:413:25: error: 'mm_context_t' has no member named 'sigpage'
This shows one of the evilnesses of IS_ENABLED(). Get rid of it here
and replace it with #ifdef's - and as no noMMU platform can make use
of sigpage, depend on CONIFG_MMU not CONFIG_ARM_MPU.
Reported-by: Olof Johansson <olof@lixom.net>
Unfortunately, I never committed the fix to a nasty oops which can
occur as a result of that commit:
kernel BUG at /home/olof/work/batch/include/linux/mm.h:414!
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 490 Comm: killall5 Not tainted 3.11.0-rc3-00288-gabe0308 #53
task: e90acac0 ti: e9be8000 task.ti: e9be8000
PC is at special_mapping_fault+0xa4/0xc4
LR is at __do_fault+0x68/0x48c
This doesn't show up unless you do quite a bit of testing; a simple
boot test does not do this, so all my nightly tests were passing fine.
The reason for this is that install_special_mapping() expects the
page array to stick around, and as this was only inserting one page
which was stored on the kernel stack, that's why this was blowing up.
Tested-by: Olof Johansson <olof@lixom.net>
available
NetLabel has the ability to selectively assign network security labels
to outbound traffic based on either the LSM's "domain" (different for
each LSM), the network destination, or a combination of both. Depending
on the type of traffic, local or forwarded, and the type of traffic
selector, domain or address based, different hooks are used to label the
traffic; the goal being minimal overhead.
Unfortunately, there is a bug such that a system using NetLabel domain
based traffic selectors does not correctly label outbound local traffic
that is not assigned to a socket. The issue is that in these cases
the associated NetLabel hook only looks at the address based selectors
and not the domain based selectors. This patch corrects this by
checking both the domain and address based selectors so that the correct
labeling is applied, regardless of the configuration type.
In order to acomplish this fix, this patch also simplifies some of the
NetLabel domainhash structures to use a more common outbound traffic
mapping type: struct netlbl_dommap_def. This simplifies some of the code
in this patch and paves the way for further simplifications in the
future.
Signed-off-by: Paul Moore <pmoore@redhat.com>
It's possible to assign an invalid value to the net.core.somaxconn
sysctl variable, because there is no checks at all.
The sk_max_ack_backlog field of the sock structure is defined as
unsigned short. Therefore, the backlog argument in inet_listen()
shouldn't exceed USHRT_MAX. The backlog argument in the listen() syscall
is truncated to the somaxconn value. So, the somaxconn value shouldn't
exceed 65535 (USHRT_MAX).
Also, negative values of somaxconn are meaningless.
before:
$ sysctl -w net.core.somaxconn=256
net.core.somaxconn = 256
$ sysctl -w net.core.somaxconn=65536
net.core.somaxconn = 65536
$ sysctl -w net.core.somaxconn=-100
net.core.somaxconn = -100
after:
error: "Invalid argument" setting key "net.core.somaxconn"
Based on a prior patch from Changli Gao.
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
Reported-by: Changli Gao <xiaosuo@gmail.com>
Suggested-by: Eric Dumazet <edumazet@google.com>
[ 198.720048] ------------[ cut here ]------------
[ 198.720108] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:255 dev_watchdog+0x229/0x240()
[ 198.720118] NETDEV WATCHDOG: eth0 (sis900): transmit queue 0 timed out
[ 198.720125] Modules linked in: bridge stp llc dmfe sundance 3c59x sis900 mii
[ 198.720159] CPU: 0 PID: 0 Comm: swapper Not tainted 3.11.0-rc3+ #12
[ 198.720167] Hardware name: System Manufacturer System Name/TUSI-M, BIOS ASUS TUSI-M ACPI BIOS
Revision 1013 Beta 001 12/14/2001
[ 198.720175] 000000ff c13fa6b9 c169ddcc c12208d6 c169ddf8 c1031e4d c1664a84 c169de24
[ 198.720197] 00000000 c165f5ea 000000ff c13fa6b9 00000001 000000ff c1664a84 c169de10
[ 198.720217] c1031f13 00000009 c169de08 c1664a84 c169de24 c169de50 c13fa6b9 c165f5ea
[ 198.720240] Call Trace:
[ 198.720257] [<c13fa6b9>] ? dev_watchdog+0x229/0x240
[ 198.720274] [<c12208d6>] dump_stack+0x16/0x20
[ 198.720306] [<c1031e4d>] warn_slowpath_common+0x7d/0xa0
[ 198.720318] [<c13fa6b9>] ? dev_watchdog+0x229/0x240
[ 198.720330] [<c1031f13>] warn_slowpath_fmt+0x33/0x40
[ 198.720342] [<c13fa6b9>] dev_watchdog+0x229/0x240
[ 198.720357] [<c103f158>] call_timer_fn+0x78/0x150
[ 198.720369] [<c103f0e0>] ? internal_add_timer+0x40/0x40
[ 198.720381] [<c13fa490>] ? dev_init_scheduler+0xa0/0xa0
[ 198.720392] [<c103f33f>] run_timer_softirq+0x10f/0x200
[ 198.720412] [<c103954f>] ? __do_softirq+0x6f/0x210
[ 198.720424] [<c13fa490>] ? dev_init_scheduler+0xa0/0xa0
[ 198.720435] [<c1039598>] __do_softirq+0xb8/0x210
[ 198.720467] [<c14b54d2>] ? _raw_spin_unlock+0x22/0x30
[ 198.720484] [<c1003245>] ? handle_irq+0x25/0xd0
[ 198.720496] [<c1039c0c>] irq_exit+0x9c/0xb0
[ 198.720508] [<c14bc9d7>] do_IRQ+0x47/0x94
[ 198.720534] [<c1056078>] ? hrtimer_start+0x28/0x30
[ 198.720564] [<c14bc8b1>] common_interrupt+0x31/0x38
[ 198.720589] [<c1008692>] ? default_idle+0x22/0xa0
[ 198.720600] [<c10083c7>] arch_cpu_idle+0x17/0x30
[ 198.720631] [<c106d23d>] cpu_startup_entry+0xcd/0x180
[ 198.720643] [<c14ae30a>] rest_init+0xaa/0xb0
[ 198.720654] [<c14ae260>] ? reciprocal_value+0x50/0x50
[ 198.720668] [<c17044e0>] ? repair_env_string+0x60/0x60
[ 198.720679] [<c1704bda>] start_kernel+0x29a/0x350
[ 198.720690] [<c17044e0>] ? repair_env_string+0x60/0x60
[ 198.720721] [<c1704269>] i386_start_kernel+0x39/0xa0
[ 198.720729] ---[ end trace 81e0a6266f5c73a8 ]---
[ 198.720740] eth0: Transmit timeout, status 00000204 00000000
timer routine checks the link status and if it's up calls
netif_carrier_on() allowing upper layer to start the tx queue
even if the auto-negotiation process is not finished.
Also remove ugly auto-negotiation check from the sis900_start_xmit()
CC: Duan Fugang <B38611@freescale.com>
CC: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Denis Kirjanov <kda@linux-powerpc.org>
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband/rdma fixes from Roland Dreier:
- Fixes for the newly merged mlx5 hardware driver
- Stack info leak fixes from Dan Carpenter
- Fixes for pkey table handling with SR-IOV
- A few other small things
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IPoIB: Fix pkey change flow for virtualization environments
IPoIB: Make sure child devices use valid/proper pkeys
IB/core: Create QP1 using the pkey index which contains the default pkey
mlx5_core: Variable may be used uninitialized
mlx5_core: Implement new initialization sequence
mlx5_core: Fix use after free in mlx5_cmd_comp_handler()
IB/mlx5: Fix stack info leak in mlx5_ib_alloc_ucontext()
IB/mlx5: Fix error return code in init_one()
IB/mlx4: Use default pkey when creating tunnel QPs
RDMA/cma: Only call cma_save_ib_info() for CM REQs
RDMA/cma: Fix accessing invalid private data for UD
RDMA/cma: Fix gcc warning
Revert "RDMA/nes: Fix compilation error when nes_debug is enabled"
IB/qib: Add err_decode() call for ring dump
RDMA/cxgb3: Fix stack info leak in iwch_create_cq()
RDMA/nes: Fix info leaks in nes_create_qp() and nes_create_cq()
RDMA/ocrdma: Fix several stack info leaks
RDMA/cxgb4: Fix stack info leak in c4iw_create_qp()
RDMA/ocrdma: Remove unused include
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO fixes from Linus Walleij:
"Yet another GPIO pull request, fixing the fix from the last one. It
turns out that fixing the boot path for device tree boots on OMAP
breaks out antique systems (such as OMAP1) and we need to find a
better way. So we're reverting that "fix" for the moment and thinking
about something better.
Also fixing a build issue on the MSM driver"
* tag 'gpio-for-v3.11-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio:
gpio_msm: Fix build error due to missing err.h
Revert "gpio/omap: don't create an IRQ mapping for every GPIO on DT"
Revert "gpio/omap: auto request GPIO as input if used as IRQ via DT"
Revert "gpio/omap: fix build error when OF_GPIO is not defined."
Commit 5c766d642 ("ipv4: introduce address lifetime") leaves the ifa
resource that was allocated via inet_alloc_ifa() unfreed when returning
the function with -EINVAL. Thus, free it first via inet_free_ifa().
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Reviewed-by: Jiri Pirko <jiri@resnulli.us>
This message was added in commit a7154cb8 (June 2004, [PATCH] r8169:
link handling and phy reset rework) and is printed every ten seconds
when no cable is connected and runtime power management is disabled.
(Before that commit, "Reset RTL8169s PHY" would be printed instead.)
Signed-off-by: Peter Wu <lekensteyn@gmail.com>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
removed.
Signed-off-by: Felipe Balbi <balbi@ti.com>
Acked-by: Mugunthan V N <mugunthanvnm@ti.com>
When userspace passes a large priority value
the assignment of the unsigned value hopt->prio
to signed int cl->prio causes cl->prio to become negative and the
comparison is with TC_HTB_NUMPRIO is always false.
The result is that HTB crashes by referencing outside
the array when processing packets. With this patch the large value
wraps around like other values outside the normal range.
See: https://bugzilla.kernel.org/show_bug.cgi?id=60669
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc fixes from Ben Herrenschmidt:
"Here is not quite a handful of powerpc fixes for rc3.
The windfarm fix is a regression fix (though not a new one), the PMU
interrupt rename is not a fix per-se but has been submitted a long
time ago and I kept forgetting to put it in (it puts us back in sync
with x86), the other perf bit is just about putting an API/ABI bit
definition in the right place for userspace to consume, and finally,
we have a fix for the VPHN (Virtual Partition Home Node) feature
(notification that the hypervisor is moving nodes around) which could
cause lockups so we may as well fix it now"
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/windfarm: Fix noisy slots-fan on Xserve (rm31)
powerpc: VPHN topology change updates all siblings
powerpc/perf: Export PERF_EVENT_CONFIG_EBB_SHIFT to userspace
powerpc: Rename PMU interrupts from CNT to PMI
Pull ARM fixes from Russell King:
"I've thought long and hard about what to say for this pull request,
and I really can't work out anything sane to say to summarise much of
these commits. The problem is, for most of these are, yet again, lots
of small bits scattered around the place without any real overall
theme to them"
Most notable is probably the kuser page helper improvements.
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm: (22 commits)
ARM: Add .text annotations where required after __CPUINIT removal
ARM: 7803/1: Fix deadlock scenario with smp_send_stop()
ARM: make vectors page inaccessible from userspace
ARM: allow kuser helpers to be removed from the vector page
ARM: update FIQ support for relocation of vectors
ARM: use linker magic for vectors and vector stubs
ARM: move vector stubs
ARM: poison memory between kuser helpers
ARM: poison the vectors page
ARM: 7801/1: v6: prevent gcc 4.5 from reordering extended CP15 reads above is_smp() test
ARM: 7800/1: ARMv7-M: Fix name of NVIC handler function
ARM: Fix sorting of machine- initializers
ARM: 7791/1: a.out: remove partial a.out support
ARM: 7790/1: Fix deferred mm switch on VIVT processors
ARM: 7789/1: Do not run dummy_flush_tlb_a15_erratum() on non-Cortex-A15
ARM: 7787/1: virt: ensure visibility of __boot_cpu_mode
ARM: 7788/1: elf: fix lpae hwcap feature reporting in proc/cpuinfo
ARM: 7786/1: hyp: fix macro parameterisation
ARM: 7785/1: mm: restrict early_alloc to section-aligned memory
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux
Pull parisc updates from Helge Deller:
"The majority of lines changed are due the addition of a defconfig for
the C8000 machine. Even the fix in parisc/kernel/cache.c file is
actually ony a 10-line fix, but the change became bigger (and much
nicer) to avoid errors of the checkpatch script.
Here is the short-changelog:
This round of parisc updates includes mostly fixes for the C8000
workstation. We have a new defconfig file for this machine, as well
as fixes for it's serial port, the AGP driver and the cache routines
to cope with the vmas of the FireGL card in a C8000. The sys32.h
header file was not used and as such it's now gone"
* 'parisc-3.11-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux:
parisc: Fix interrupt routing for C8000 serial ports
parisc: Remove arch/parisc/kernel/sys32.h header
parisc: add defconfig for c8000 machine
parisc: agp/parisc-agp: allow binding of user memory to the AGP GART
parisc: Fix cache routines to ignore vma's with an invalid pfn
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID fixes from Jiri Kosina:
- fix hid-sony PS3 sixaxxis breakage from Benjamin Tissories
- fix hidraw race condition from Yonghua Zheng
- fix/bandaid for rare device enumeration problems of Logitech Unifying
receivers from Nestor Lopez Casado
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: hidraw: fix improper mutex release
HID: sony: fix HID mapping for PS3 sixaxis controller
HID: hid-logitech-dj: querying_devices was never set
HID: Revert "Revert "HID: Fix logitech-dj: missing Unifying device issue""
git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras
Pull MCE fix from Tony Luck:
"Fix a regression in mce-severity.c"
* tag 'please-pull-fix-mce-regression' of git://git.kernel.org/pub/scm/linux/kernel/git/ras/ras:
x86/mce: Fix mce regression from recent cleanup
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI fixes from Bjorn Helgaas:
"Yinghai fixed a couple regressions: one resource assignment problem
introduced in v3.10 that showed up with SR-IOV on powerpc, and another
SR-IOV hot-remove issue related to refcounting changes we merged for
v3.11.
Yinghai is still working on another SR-IOV-related fix or two, which
will be simpler if pciehp is non-modular, so I included the Kconfig
changes now to get them in earlier.
Finally, a minor fix for the ARM Marvell EBU host bridge driver that
was merged for v3.11
Hotplug:
PCI: pciehp: Fix null pointer deref when hot-removing SR-IOV device
PCI: hotplug: Convert to be builtin only, not modular
PCI: pciehp: Convert pciehp to be builtin only, not modular
Resource allocation:
PCI: Retry allocation of only the resource type that failed
ARM:
PCI: mvebu: Disable prefetchable memory support in PCI-to-PCI bridge"
* tag 'pci-v3.11-fixes-1' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci:
Pull ACPI and power management fixes from Rafael Wysocki:
- Revert two cpuidle commits added during the 3.8 development cycle
that turn out to have introduced a significant performance regression
as requested by Jeremy Eder.
- The recent patches that made the freezer less heavy-weight introduced
a regression causing user-space-driven hibernation using the ioctl()
interface to block indefinitely when the hibernate process executes
try_to_freeze(). Fix from Colin Cross addresses this by adding a
process flag to mark the hibernate/suspend process to inform the
freezer that that process should be ignored.
- One of the recent cpufreq reverts uncovered a problem in the core
causing the cpufreq driver module refcount to become negative after a
system suspend-resume cycle. Fix from Rafael J Wysocki.
- The evaluation of the ACPI battery _BIX method has never worked
correctly, because the commit that added support for it forgot to
take the "Revision" field in the return package into account. As a
result, the reading of battery info doesn't work at all on some
systems, which is addressed by a fix from Lan Tianyu.
* tag 'pm+acpi-3.11-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
freezer: set PF_SUSPEND_TASK flag on tasks that call freeze_processes
ACPI / battery: Fix parsing _BIX return value
cpufreq: Fix cpufreq driver module refcount balance after suspend/resume
Revert "cpuidle: Quickly notice prediction failure for repeat mode"
Revert "cpuidle: Quickly notice prediction failure in general case"
A fixup for Apple Mac Mini was lost during the adaption to the generic
parser because the fallback for the generic ID 8384:7680 was dropped,
and it resulted in the silence output (and maybe other problems).
Unfortunately, just adding the missing subsystem ID wasn't enough, in
this case. The subsystem ID of this machine is 0000:0100 (what Apple
thought...?), and since snd_hda_pick_fixup() doesn't take the vendor
id zero into account, the driver ignored this entry. Now it's fixed
to regard the vendor id zero as a valid value.
Reported-and-tested-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: <stable@vger.kernel.org> [v3.9+]
It's quite unlikely that dev_set_promiscuity will fail,
but worth checking just in case.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
macvlan passthrough mode is special: it's not possible to switch to or
from it through a netlink command.
But if you try, the command will succeed, which is
confusing.
Validate input and return error to user.
Cc: Sridhar Samudrala <sri@us.ibm.com>
When creation of TIPC internal server socket fails,
we get an oops with the following dump:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
IP: [<ffffffffa0011f49>] tipc_close_conn+0x59/0xb0 [tipc]
PGD 13719067 PUD 12008067 PMD 0
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
Modules linked in: tipc(+)
CPU: 4 PID: 4340 Comm: insmod Not tainted 3.10.0+ #1
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2007
task: ffff880014360000 ti: ffff88001374c000 task.ti: ffff88001374c000
RIP: 0010:[<ffffffffa0011f49>] [<ffffffffa0011f49>] tipc_close_conn+0x59/0xb0 [tipc]
RSP: 0018:ffff88001374dc98 EFLAGS: 00010292
RAX: 0000000000000000 RBX: ffff880012ac09d8 RCX: 0000000000000000
RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffff880014360000
RBP: ffff88001374dcb8 R08: 0000000000000001 R09: 0000000000000001
R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffa0016fa0
R13: ffffffffa0017010 R14: ffffffffa0017010 R15: ffff880012ac09d8
FS: 0000000000000000(0000) GS:ffff880016600000(0063) knlGS:00000000f76668d0
CS: 0010 DS: 002b ES: 002b CR0: 000000008005003b
CR2: 0000000000000020 CR3: 0000000012227000 CR4: 00000000000006e0
Stack:
ffff88001374dcb8 ffffffffa0016fa0 0000000000000000 0000000000000001
ffff88001374dcf8 ffffffffa0012922 ffff88001374dce8 00000000ffffffea
ffffffffa0017100 0000000000000000 ffff8800134241a8 ffffffffa0017150
Call Trace:
[<ffffffffa0012922>] tipc_server_stop+0xa2/0x1b0 [tipc]
[<ffffffffa0009995>] tipc_subscr_stop+0x15/0x20 [tipc]
[<ffffffffa00130f5>] tipc_core_stop+0x1d/0x33 [tipc]
[<ffffffffa001f0d4>] tipc_init+0xd4/0xf8 [tipc]
[<ffffffffa001f000>] ? 0xffffffffa001efff
[<ffffffff8100023f>] do_one_initcall+0x3f/0x150
[<ffffffff81082f4d>] ? __blocking_notifier_call_chain+0x7d/0xd0
[<ffffffff810cc58a>] load_module+0x11aa/0x19c0
[<ffffffff810c8d60>] ? show_initstate+0x50/0x50
[<ffffffff8190311c>] ? retint_restore_args+0xe/0xe
[<ffffffff810cce79>] SyS_init_module+0xd9/0x110
[<ffffffff8190dc65>] sysenter_dispatch+0x7/0x1f
Code: 6c 24 70 4c 89 ef e8 b7 04 8f e1 8b 73 04 4c 89 e7 e8 7c 9e 32 e1 41 83 ac 24
b8 00 00 00 01 4c 89 ef e8 eb 0a 8f e1 48 8b 43 08 <4c> 8b 68 20 4d 8d a5 48 03 00
00 4c 89 e7 e8 04 05 8f e1 4c 89
RIP [<ffffffffa0011f49>] tipc_close_conn+0x59/0xb0 [tipc]
RSP <ffff88001374dc98>
---[ end trace b02321f40e4269a3 ]---
We have the following call chain:
tipc_core_start()
ret = tipc_subscr_start()
ret = tipc_server_start(){
server->enabled = 1;
ret = tipc_open_listening_sock()
I.e., the server->enabled flag is unconditionally set to 1, whatever
the return value of tipc_open_listening_sock().
This causes a crash when tipc_core_start() tries to clean up
resources after a failed initialization:
if (ret == failed)
tipc_subscr_stop()
tipc_server_stop(){
if (server->enabled)
tipc_close_conn(){
NULL reference of con->sock-sk
OOPS!
To avoid this, tipc_server_start() should only set server->enabled
to 1 in case of a succesful socket creation. In case of failure, it
should release all allocated resources before returning.
Problem introduced in commit c5fa7b3cf3cb22e4ac60485fc2dc187fe012910f
("tipc: introduce new TIPC server infrastructure") in v3.11-rc1.
Note that it won't be seen often; it takes a module load under memory
constrained conditions in order to trigger the failure condition.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Signed-off-by: Jon Maloy <jon.maloy@ericsson.com>
Eliezer renames several *ll_poll to *busy_poll, but forgets
CONFIG_NET_LL_RX_POLL, so in case of confusion, rename it too.
Cc: Eliezer Tamir <eliezer.tamir@linux.intel.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
When CONFIG_NET_LL_RX_POLL is not set, I got:
net/socket.c: In function ‘sock_poll’:
net/socket.c:1165:4: error: implicit declaration of function ‘sk_busy_loop’ [-Werror=implicit-function-declaration]
Fix this by adding a nop when !CONFIG_NET_LL_RX_POLL.
Slaves get the 64B CQE/EQE state from QUERY_HCA, not from the module parameter.
If the parameter is set to zero, the slave outputs an incorrect/irrelevant
warning message that 64B CQEs/EQEs are supported but not enabled (even if the
hypervisor has enabled 64B CQEs/EQEs).
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
If the user has not assigned a MAC address to a VM, then don't give it MAC which
is based on the PF one. The current derivation scheme is wrong and leads to VM
MAC collisions when the number of cards/hypervisors becomes big enough.
Instead, just give it zeros and let them figure out what to do with that.
