git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big USB patchset for 4.2-rc1. As is normal these days, the
majority of changes are in the gadget drivers, with a bunch of other
small driver changes.
All of these have been in linux-next with no reported issues"
* tag 'usb-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (175 commits)
usb: dwc3: Use ASCII space in Kconfig
usb: chipidea: add work-around for Marvell HSIC PHY startup
usb: chipidea: allow multiple instances to use default ci_default_pdata
dt-bindings: Consolidate ChipIdea USB ci13xxx bindings
phy: add Marvell HSIC 28nm PHY
phy: Add Marvell USB 2.0 OTG 28nm PHY
dt-bindings: Add Marvell PXA1928 USB and HSIC PHY bindings
USB: ssb: use devm_kzalloc
USB: ssb: fix error handling in ssb_hcd_create_pdev()
usb: isp1760: check for null return from kzalloc
cdc-acm: Add support of ATOL FPrint fiscal printers
usb: chipidea: usbmisc_imx: Remove unneeded semicolon
USB: usbtmc: add device quirk for Rigol DS6104
USB: serial: mos7840: Use setup_timer
phy: twl4030-usb: add ABI documentation
phy: twl4030-usb: remove incorrect pm_runtime_get_sync() in probe function.
phy: twl4030-usb: remove pointless 'suspended' test in 'suspend' callback.
phy: twl4030-usb: make runtime pm more reliable.
drivers:usb:fsl: Fix compilation error for fsl ehci drv
usb: renesas_usbhs: Don't disable the pipe if Control write status stage
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial driver updates from Greg KH:
"Here's the tty and serial driver patches for 4.2-rc1.
A number of individual driver updates, some code cleanups, and other
minor things, full details in the shortlog.
All have been in linux-next for a while with no reported issues"
* tag 'tty-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (152 commits)
Doc: serial-rs485.txt: update RS485 driver interface
Doc: tty.txt: remove mention of the BKL
MAINTAINERS: tty: add serial docs directory
serial: sprd: check for NULL after calling devm_clk_get
serial: 8250_pci: Correct uartclk for xr17v35x expansion chips
serial: 8250_pci: Add support for 12 port Exar boards
serial: 8250_uniphier: add bindings document for UniPhier UART
serial: core: cleanup in uart_get_baud_rate()
serial: stm32-usart: Add STM32 USART Driver
tty/serial: kill off set_irq_flags usage
tty: move linux/gsmmux.h to uapi
doc: dt: add documentation for nxp,lpc1850-uart
serial: 8250: add LPC18xx/43xx UART driver
serial: 8250_uniphier: add UniPhier serial driver
serial: 8250_dw: support ACPI platforms with integrated DMA engine
serial: of_serial: check the return value of clk_prepare_enable()
serial: of_serial: use devm_clk_get() instead of clk_get()
serial: earlycon: Add support for big-endian MMIO accesses
serial: sirf: use hrtimer for data rx
serial: sirf: correct the fifo empty_bit
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver updates from Greg KH:
"Here's the big, really big, staging tree patches for 4.2-rc1.
Loads of stuff in here, almost all just coding style fixes / churn,
and a few new drivers as well, one of which I just disabled from the
build a few minutes ago due to way too many build warnings.
Other than the one "disable this driver" patch, all of these have been
in linux-next for quite a while with no reported issues"
* tag 'staging-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1163 commits)
staging: wilc1000: disable driver due to build warnings
Staging: rts5208: fix CHANGE_LINK_STATE value
Staging: sm750fb: ddk750_swi2c.c: Insert spaces before parenthesis
Staging: sm750fb: ddk750_swi2c.c: Place braces on correct lines
Staging: sm750fb: ddk750_swi2c.c: Insert spaces around operators
Staging: sm750fb: ddk750_swi2c.c: Replace spaces with tabs
Staging: sm750fb: ddk750_swi2c.h: Shorten lines to under 80 characters
Staging: sm750fb: ddk750_swi2c.h: Replace spaces with tabs
Staging: sm750fb: modedb.h: Shorten lines to under 80 characters
Staging: sm750fb: modedb.h: Replace spaces with tabs
staging: comedi: addi_apci_3120: rename 'this_board' variables
staging: comedi: addi_apci_1516: rename 'this_board' variables
staging: comedi: ni_atmio: cleanup ni_getboardtype()
staging: comedi: vmk80xx: sanity check context used to get the boardinfo
staging: comedi: vmk80xx: rename 'boardinfo' variables
staging: comedi: dt3000: rename 'this_board' variables
staging: comedi: adv_pci_dio: rename 'this_board' variables
staging: comedi: cb_pcidas64: rename 'thisboard' variables
staging: comedi: cb_pcidas: rename 'thisboard' variables
staging: comedi: me4000: rename 'thisboard' variables
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here is the driver core / firmware changes for 4.2-rc1.
A number of small changes all over the place in the driver core, and
in the firmware subsystem. Nothing really major, full details in the
shortlog. Some of it is a bit of churn, given that the platform
driver probing changes was found to not work well, so they were
reverted.
All of these have been in linux-next for a while with no reported
issues"
* tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits)
Revert "base/platform: Only insert MEM and IO resources"
Revert "base/platform: Continue on insert_resource() error"
Revert "of/platform: Use platform_device interface"
Revert "base/platform: Remove code duplication"
firmware: add missing kfree for work on async call
fs: sysfs: don't pass count == 0 to bin file readers
base:dd - Fix for typo in comment to function driver_deferred_probe_trigger().
firmware: use const for remaining firmware names
firmware: fix possible use after free on name on asynchronous request
firmware: check for file truncation on direct firmware loading
firmware: fix __getname() missing failure check
drivers: of/base: move of_init to driver_init
drivers/base: cacheinfo: fix annoying typo when DT nodes are absent
sysfs: disambiguate between "error code" and "failure" in comments
driver-core: fix build for !CONFIG_MODULES
driver-core: make __device_attach() static
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver pull request for 4.2-rc1.
Lots of mei, extcon, coresight, uio, mic, and other driver updates in
here. Full details in the shortlog. All of these have been in
linux-next for some time with no reported problems"
* tag 'char-misc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (176 commits)
mei: me: wait for power gating exit confirmation
mei: reset flow control on the last client disconnection
MAINTAINERS: mei: add mei_cl_bus.h to maintained file list
misc: sram: sort and clean up included headers
misc: sram: move reserved block logic out of probe function
misc: sram: add private struct device and virt_base members
misc: sram: report correct SRAM pool size
misc: sram: bump error message level on unclean driver unbinding
misc: sram: fix device node reference leak on error
misc: sram: fix enabled clock leak on error path
misc: mic: Fix reported static checker warning
misc: mic: Fix randconfig build error by including errno.h
uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from config
uio: pruss: Add CONFIG_HAS_IOMEM dependence
uio: pruss: Include <linux/sizes.h>
extcon: Redefine the unique id of supported external connectors without 'enum extcon' type
char:xilinx_hwicap:buffer_icap - change 1/0 to true/false for bool type variable in function buffer_icap_set_configuration().
Drivers: hv: vmbus: Allocate ring buffer memory in NUMA aware fashion
parport: check exclusive access before register
w1: use correct lock on error in w1_seq_show()
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"This patch series contains several clean ups and even a new trace
clock "monitonic raw". Also some enhancements to make the ring buffer
even faster. But the biggest and most noticeable change is the
renaming of the ftrace* files, structures and variables that have to
deal with trace events.
Over the years I've had several developers tell me about their
confusion with what ftrace is compared to events. Technically,
"ftrace" is the infrastructure to do the function hooks, which include
tracing and also helps with live kernel patching. But the trace
events are a separate entity altogether, and the files that affect the
trace events should not be named "ftrace". These include:
include/trace/ftrace.h -> include/trace/trace_events.h
include/linux/ftrace_event.h -> include/linux/trace_events.h
Also, functions that are specific for trace events have also been renamed:
ftrace_print_*() -> trace_print_*()
(un)register_ftrace_event() -> (un)register_trace_event()
ftrace_event_name() -> trace_event_name()
ftrace_trigger_soft_disabled() -> trace_trigger_soft_disabled()
ftrace_define_fields_##call() -> trace_define_fields_##call()
ftrace_get_offsets_##call() -> trace_get_offsets_##call()
Structures have been renamed:
ftrace_event_file -> trace_event_file
ftrace_event_{call,class} -> trace_event_{call,class}
ftrace_event_buffer -> trace_event_buffer
ftrace_subsystem_dir -> trace_subsystem_dir
ftrace_event_raw_##call -> trace_event_raw_##call
ftrace_event_data_offset_##call-> trace_event_data_offset_##call
ftrace_event_type_funcs_##call -> trace_event_type_funcs_##call
And a few various variables and flags have also been updated.
This has been sitting in linux-next for some time, and I have not
heard a single complaint about this rename breaking anything. Mostly
because these functions, variables and structures are mostly internal
to the tracing system and are seldom (if ever) used by anything
external to that"
* tag 'trace-v4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (33 commits)
ring_buffer: Allow to exit the ring buffer benchmark immediately
ring-buffer-benchmark: Fix the wrong type
ring-buffer-benchmark: Fix the wrong param in module_param
ring-buffer: Add enum names for the context levels
ring-buffer: Remove useless unused tracing_off_permanent()
ring-buffer: Give NMIs a chance to lock the reader_lock
ring-buffer: Add trace_recursive checks to ring_buffer_write()
ring-buffer: Allways do the trace_recursive checks
ring-buffer: Move recursive check to per_cpu descriptor
ring-buffer: Add unlikelys to make fast path the default
tracing: Rename ftrace_get_offsets_##call() to trace_event_get_offsets_##call()
tracing: Rename ftrace_define_fields_##call() to trace_event_define_fields_##call()
tracing: Rename ftrace_event_type_funcs_##call to trace_event_type_funcs_##call
tracing: Rename ftrace_data_offset_##call to trace_event_data_offset_##call
tracing: Rename ftrace_raw_##call event structures to trace_event_raw_##call
tracing: Rename ftrace_trigger_soft_disabled() to trace_trigger_soft_disabled()
tracing: Rename FTRACE_EVENT_FL_* flags to EVENT_FILE_FL_*
tracing: Rename struct ftrace_subsystem_dir to trace_subsystem_dir
tracing: Rename ftrace_event_name() to trace_event_name()
tracing: Rename FTRACE_MAX_EVENT to TRACE_EVENT_TYPE_MAX
Pull tracing fixes from Steven Rostedt:
"This isn't my 4.2 pull request (yet). I found a few more bugs that I
would have sent to fix 4.1, but since 4.1 is already out, I'm sending
this before sending my 4.2 request (which is ready to go).
After fixing the previous filter issue reported by Vince Weaver, I
could not come up with a situation where the operand counter (cnt)
could go below zero, so I added a WARN_ON_ONCE(cnt < 0). Vince was
able to trigger that warn on with his fuzzer test, but didn't have a
filter input that caused it.
Later, Sasha Levin was able to trigger that same warning, and was able
to give me the filter string that triggered it. It was simply a
single operation ">".
I wrapped the filtering code in a userspace program such that I could
single step through the logic. With a single operator the operand
counter can legitimately go below zero, and should be reported to the
user as an error, but should not produce a kernel warning. The
WARN_ON_ONCE(cnt < 0) should be just a "if (cnt < 0) break;" and the
code following it will produce the error message for the user.
While debugging this, I found that there was another bug that let the
pointer to the filter string go beyond the filter string. This too
was fixed.
Finally, there was a typo in a stub function that only gets compiled
if trace events is disabled but tracing is enabled (I'm not even sure
that's possible)"
* tag 'trace-fixes-4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Fix typo from "static inlin" to "static inline"
tracing/filter: Do not allow infix to exceed end of string
tracing/filter: Do not WARN on operand count going below zero
Pull drm updates from Dave Airlie:
"This is the main drm pull request for v4.2.
I've one other new driver from freescale on my radar, it's been posted
and reviewed, I'd just like to get someone to give it a last look, so
maybe I'll send it or maybe I'll leave it.
There is no major nouveau changes in here, Ben was working on
something big, and we agreed it was a bit late, there wasn't anything
else he considered urgent to merge.
There might be another msm pull for some bits that are waiting on
arm-soc, I'll see how we time it.
This touches some "of" stuff, acks are in place except for the fixes
to the build in various configs,t hat I just applied.
Summary:
New drivers:
- virtio-gpu:
KMS only pieces of driver for virtio-gpu in qemu.
This is just the first part of this driver, enough to run
unaccelerated userspace on. As qemu merges more we'll start
adding the 3D features for the virgl 3d work.
- amdgpu:
a new driver from AMD to driver their newer GPUs. (VI+)
It contains a new cleaner userspace API, and is a clean
break from radeon moving forward, that AMD are going to
concentrate on. It also contains a set of register headers
auto generated from AMD internal database.
core:
- atomic modesetting API completed, enabled by default now.
- Add support for mode_id blob to atomic ioctl to complete interface.
- bunch of Displayport MST fixes
- lots of misc fixes.
panel:
- new simple panels
- fix some long-standing build issues with bridge drivers
radeon:
- VCE1 support
- add a GPU reset counter for userspace
- lots of fixes.
amdkfd:
- H/W debugger support module
- static user-mode queues
- support killing all the waves when a process terminates
- use standard DECLARE_BITMAP
i915:
- Add Broxton support
- S3, rotation support for Skylake
- RPS booting tuning
- CPT modeset sequence fixes
- ns2501 dither support
- enable cmd parser on haswell
- cdclk handling fixes
- gen8 dynamic pte allocation
- lots of atomic conversion work
exynos:
- Add atomic modesetting support
- Add iommu support
- Consolidate drm driver initialization
- and MIC, DECON and MIPI-DSI support for exynos5433
omapdrm:
- atomic modesetting support (fixes lots of things in rewrite)
tegra:
- DP aux transaction fixes
- iommu support fix
msm:
- adreno a306 support
- various dsi bits
- various 64-bit fixes
- NV12MT support
rcar-du:
- atomic and misc fixes
sti:
- fix HDMI timing complaince
tilcdc:
- use drm component API to access tda998x driver
- fix module unloading
qxl:
- stability fixes"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (872 commits)
drm/nouveau: Pause between setting gpu to D3hot and cutting the power
drm/dp/mst: close deadlock in connector destruction.
drm: Always enable atomic API
drm/vgem: Set unique to "vgem"
of: fix a build error to of_graph_get_endpoint_by_regs function
drm/dp/mst: take lock around looking up the branch device on hpd irq
drm/dp/mst: make sure mst_primary mstb is valid in work function
of: add EXPORT_SYMBOL for of_graph_get_endpoint_by_regs
ARM: dts: rename the clock of MIPI DSI 'pll_clk' to 'sclk_mipi'
drm/atomic: Don't set crtc_state->enable manually
drm/exynos: dsi: do not set TE GPIO direction by input
drm/exynos: dsi: add support for MIC driver as a bridge
drm/exynos: dsi: add support for Exynos5433
drm/exynos: dsi: make use of array for clock access
drm/exynos: dsi: make use of driver data for static values
drm/exynos: dsi: add macros for register access
drm/exynos: dsi: rename pll_clk to sclk_clk
drm/exynos: mic: add MIC driver
of: add helper for getting endpoint node of specific identifiers
drm/exynos: add Exynos5433 decon driver
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper fixes from Mike Snitzer:
"Apologies for not pressing this request-based DM partial completion
issue further, it was an oversight on my part. We'll have to get it
fixed up properly and revisit for a future release.
- Revert block and DM core changes the removed request-based DM's
ability to handle partial request completions -- otherwise with the
current SCSI LLDs these changes could lead to silent data
corruption.
- Fix two DM version bumps that were missing from the initial 4.2 DM
pull request (enabled userspace lvm2 to know certain changes have
been made)"
* tag 'dm-4.2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm cache policy smq: fix "default" version to be 1.4.0
dm: bump the ioctl version to 4.32.0
Revert "block, dm: don't copy bios for request clones"
Revert "dm: do not allocate any mempools for blk-mq request-based DM"
Pull crypto fixes from Herbert Xu:
"This fixes the following issues:
- move -O0 jitterentropy code into its own file instead of using gcc
pragma magic.
- kill testmgr warning for gcm-aes-aesni.
- fix build failure in old rsa.
Other minor fixes:
- ignore asn1 files generated by new rsa.
- remove unnecessary kzfree NULL checks in jitterentropy.
- typo fix in akcipher"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: rsa - add .gitignore for crypto/*.-asn1.[ch] files
crypto: asymmetric_keys/rsa - Use non-conflicting variable name
crypto: testmgr - don't print info about missing test for gcm-aes-aesni
crypto: jitterentropy - Delete unnecessary checks before the function call "kzfree"
crypto: akcipher - fix spelling cihper -> cipher
crypto: jitterentropy - avoid compiler warnings
Pull ARM updates from Russell King:
"Bigger items included in this update are:
- A series of updates from Arnd for ARM randconfig build failures
- Updates from Dmitry for StrongARM SA-1100 to move IRQ handling to
drivers/irqchip/
- Move ARMs SP804 timer to drivers/clocksource/
- Perf updates from Mark Rutland in preparation to move the ARM perf
code into drivers/ so it can be shared with ARM64.
- MCPM updates from Nicolas
- Add support for taking platform serial number from DT
- Re-implement Keystone2 physical address space switch to conform to
architecture requirements
- Clean up ARMv7 LPAE code, which goes in hand with the Keystone2
changes.
- L2C cleanups to avoid unlocking caches if we're prevented by the
secure support to unlock.
- Avoid cleaning a potentially dirty cache containing stale data on
CPU initialisation
- Add ARM-only entry point for secondary startup (for machines that
can only call into a Thumb kernel in ARM mode). Same thing is also
done for the resume entry point.
- Provide arch_irqs_disabled via asm-generic
- Enlarge ARMv7M vector table
- Always use BFD linker for VDSO, as gold doesn't accept some of the
options we need.
- Fix an incorrect BSYM (for Thumb symbols) usage, and convert all
BSYM compiler macros to a "badr" (for branch address).
- Shut up compiler warnings provoked by our cmpxchg() implementation.
- Ensure bad xchg sizes fail to link"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (75 commits)
ARM: Fix build if CLKDEV_LOOKUP is not configured
ARM: fix new BSYM() usage introduced via for-arm-soc branch
ARM: 8383/1: nommu: avoid deprecated source register on mov
ARM: 8391/1: l2c: add options to overwrite prefetching behavior
ARM: 8390/1: irqflags: Get arch_irqs_disabled from asm-generic
ARM: 8387/1: arm/mm/dma-mapping.c: Add arm_coherent_dma_mmap
ARM: 8388/1: tcm: Don't crash when TCM banks are protected by TrustZone
ARM: 8384/1: VDSO: force use of BFD linker
ARM: 8385/1: VDSO: group link options
ARM: cmpxchg: avoid warnings from macro-ized cmpxchg() implementations
ARM: remove __bad_xchg definition
ARM: 8369/1: ARMv7M: define size of vector table for Vybrid
ARM: 8382/1: clocksource: make ARM_TIMER_SP804 depend on GENERIC_SCHED_CLOCK
ARM: 8366/1: move Dual-Timer SP804 driver to drivers/clocksource
ARM: 8365/1: introduce sp804_timer_disable and remove arm_timer.h inclusion
ARM: 8364/1: fix BE32 module loading
ARM: 8360/1: add secondary_startup_arm prototype in header file
ARM: 8359/1: correct secondary_startup_arm mode
ARM: proc-v7: sanitise and document registers around errata
ARM: proc-v7: clean up MIDR access
Pull ARM SoC defconfig updates from Kevin Hilman:
"We keep collecting defconfig updates in a separate branch mostly to
encourage people to handle them separately and avoid conflicts between
different topics.
Most of these are enablement of new SoCs, boards or drivers that have
come in, or minor config refreshes due to reorderings in Kconfig
files, etc. I.e. mostly minor churn of various kinds"
* tag 'armsoc-defconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (55 commits)
ARM: multi_v7_defconfig: remove duplicate CONFIG_COMMON_CLK_QCOM=y
ARM: multi_v7_defconfig: Enable display on Trats2 board
ARM64: add GPIO keys to the defconfig
ARM: keystone: defconfig: enable netcp driver by default
ARM: exynos_defconfig: Enable CONFIG_SENSORS_INA2XX for Odroid-XU3
ARM: exynos_defconfig: Enable CONFIG_SENSORS_PWM_FAN for Odroid-XU3
ARM: omap2plus_defconfig: Enable TOUCHSCREEN_PIXCIR
ARM: omap2plus_defconfig: Add dm816x USB PHY as a loadable module
ARM: omap2plus_defconifg: Enable DM9000 in omap2plus_defconfig
ARM: lpc18xx: remove DEBUG_LL_UART_8250 from defconfig
ARM: multi_v7_defconfig: Make media support modular
ARM: multi_v7_defconfig: Make sound support modular
ARM: multi_v7_defconfig: Enable shmobile r8a7778/bockw platform
ARM: exynos_defconfig: savedefconfig
ARM: exynos_defconfig: Enable display on Trats2 board
ARM: multi_v7_defconfig: Enable OHCI on exynos SoCs
ARM: multi_v7_defconfig: Enable TMU for exynos SoCs
ARM: multi_v7_defconfig: Enable PMIC and MUIC drivers for exynos
ARM: multi_v7_defconfig: Enable CPU idle for exynos SoCs
ARM: multi_v7_defconfig: Enable Cypress APA I2C Trackpad support
The wilc1000 has just too many build warnings to be able to enable it
for the 4.2 release. Given that there have not been any patches
submitted to properly fix these obvious errors, I'm going to disable it
for now. I will enable it back when the build warning fixes are
submitted, or, if that never happens, I will remove it from the tree.
Cc: Johnny Kim <johnny.kim@atmel.com>
Cc: Rachel Kim <rachel.kim@atmel.com>
Cc: Dean Lee <dean.lee@atmel.com>
Cc: Chris Park <chris.park@atmel.com>
Pull ARM SoC driver updates from Kevin Hilman:
"Some of these are for drivers/soc, where we're now putting
SoC-specific drivers these days. Some are for other driver subsystems
where we have received acks from the appropriate maintainers.
Some highlights:
- simple-mfd: document DT bindings and misc updates
- migrate mach-berlin to simple-mfd for clock, pinctrl and reset
- memory: support for Tegra132 SoC
- memory: introduce tegra EMC driver for scaling memory frequency
- misc. updates for ARM CCI and CCN busses"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits)
drivers: soc: sunxi: Introduce SoC driver to map SRAMs
arm-cci: Add aliases for PMU events
arm-cci: Add CCI-500 PMU support
arm-cci: Sanitise CCI400 PMU driver specific code
arm-cci: Abstract handling for CCI events
arm-cci: Abstract out the PMU counter details
arm-cci: Cleanup PMU driver code
arm-cci: Do not enable CCI-400 PMU by default
firmware: qcom: scm: Add HDCP Support
ARM: berlin: add an ADC node for the BG2Q
ARM: berlin: remove useless chip and system ctrl compatibles
clk: berlin: drop direct of_iomap of nodes reg property
ARM: berlin: move BG2Q clock node
ARM: berlin: move BG2CD clock node
ARM: berlin: move BG2 clock node
clk: berlin: prepare simple-mfd conversion
pinctrl: berlin: drop SoC stub provided regmap
ARM: berlin: move pinctrl to simple-mfd nodes
pinctrl: berlin: prepare to use regmap provided by syscon
reset: berlin: drop arch_initcall initialization
Pull ARM SoC DT updates from Kevin Hilman:
"As usual, quite a few device-tree updates in ARM land. There was one
minor churn in DTs due to relicensing under a dual-license, and lots
of little additions of new peripherals, features etc, but nothing
really exciting to call to your attention. Some higlights, focsuing
on support for new SoCs and boards:
- AT91: new boards: Overkiz, Acme Systems' Arietta G25
- tegra: HDA support
- bcm: new platforms: Buffalo WXR-1900DHP, SmartRG SR400ac, ASUS
RT-AC87U
- mvebu: new platforms: Compulab CM-A510, Armada 385-based Linksys
boards, DLink DNS-327L
- OMAP: new platforms: Baltos IR5221, LogicPD Torpedo, Toby-Churchill
SL50
- ARM: added support for Juno r1 board
- sunxi: A33 SoC support; new boards: A23 EVB, SinA33, GA10H-A33,
Mele A1000G
- imx: i.MX7D SoC support; new boards: Armadeus Systems APF6,
Gateworks GW5510, and aristainetos2 boards
- hisilicon: hi6220 SoC support; new boards: 96boards hikey"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (462 commits)
ARM: hisi: revert changes from hisi/hip04-dt branch
ARM: nomadik: set proper compatible for accelerometer
ARM64: juno: add GPIO keys
ARM: at91/dt: sama5d4: fix dma conf for aes, sha and tdes nodes
ARM: dts: Introduce STM32F429 MCU
ARM: socfpga: dts: enable ethernet for Arria10 devkit
ARM: dts: k2l: fix the netcp range size
ARM: dts: k2e: fix the netcp range size
ARM: dts: k2hk: fix the netcp range size
ARM: dts: k2l-evm: Add device bindings for netcp driver
ARM: dts: k2e-evm: Add device bindings for netcp driver
ARM: dts: k2hk-evm: Add device bindings for netcp driver
ARM: BCM5301X: Add DT for Asus RT-AC87U
ARM: BCM5301X: add IRQ numbers for PCIe controller
ARM: BCM5301X: add NAND flash chip description
arm64: dts: Add dts files for Hisilicon Hi6220 SoC
clk: hi6220: Document devicetree bindings for hi6220 clock
arm64: hi6220: Document devicetree bindings for Hisilicon hi6220 SoC
ARM: at91/dt: sama5d4ek: mci0 uses slot 0
ARM: at91/dt: kizbox: fix mismatch LED PWM device
Pull ARM SoC platform support updates from Kevin Hilman:
"Our SoC branch usually contains expanded support for new SoCs and
other core platform code. Some highlights from this round:
- sunxi: SMP support for A23 SoC
- socpga: big-endian support
- pxa: conversion to common clock framework
- bcm: SMP support for BCM63138
- imx: support new I.MX7D SoC
- zte: basic support for ZX296702 SoC"
* tag 'armsoc-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (134 commits)
ARM: zx: Add basic defconfig support for ZX296702
ARM: dts: zx: add an initial zx296702 dts and doc
clk: zx: add clock support to zx296702
dt-bindings: Add #defines for ZTE ZX296702 clocks
ARM: socfpga: fix build error due to secondary_startup
MAINTAINERS: ARM64: EXYNOS: Extend entry for ARM64 DTS
ARM: ep93xx: simone: support for SPI-based MMC/SD cards
MAINTAINERS: update Shawn's email to use kernel.org one
ARM: socfpga: support suspend to ram
ARM: socfpga: add CPU_METHOD_OF_DECLARE for Arria 10
ARM: socfpga: use CPU_METHOD_OF_DECLARE for socfpga_cyclone5
ARM: EXYNOS: register power domain driver from core_initcall
ARM: EXYNOS: use PS_HOLD based poweroff for all supported SoCs
ARM: SAMSUNG: Constify platform_device_id
ARM: EXYNOS: Constify irq_domain_ops
ARM: EXYNOS: add coupled cpuidle support for Exynos3250
ARM: EXYNOS: add exynos_get_boot_addr() helper
ARM: EXYNOS: add exynos_set_boot_addr() helper
ARM: EXYNOS: make exynos_core_restart() less verbose
ARM: EXYNOS: fix exynos_boot_secondary() return value on timeout
Pull ARM SoC cleanups from Kevin Hilman:
"A relatively small setup of cleanups this time around, and similar to
last time the bulk of it is removal of legacy board support:
- OMAP: removal of legacy (non-DT) booting for several platforms
- i.MX: remove some legacy board files"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (36 commits)
ARM: fix EFM32 build breakage caused by cpu_resume_arm
ARM: 8389/1: Add cpu_resume_arm() for firmwares that resume in ARM state
ARM: v7 setup function should invalidate L1 cache
mach-omap2: Remove use of deprecated marco, PTR_RET in devices.c
ARM: OMAP2+: Remove calls to deprecacted marco,PTR_RET in the files,fb.c and pmu.c
ARM: OMAP2+: Constify irq_domain_ops
ARM: OMAP2+: use symbolic defines for console loglevels instead of numbers
ARM: at91: remove useless Makefile.boot
ARM: at91: remove at91rm9200_sdramc.h
ARM: at91: remove mach/at91_ramc.h and mach/at91rm9200_mc.h
ARM: at91/pm: use the atmel-mc syscon defines
pcmcia: at91_cf: Use syscon to configure the MC/smc
ARM: at91: declare the at91rm9200 memory controller as a syscon
mfd: syscon: Add Atmel MC (Memory Controller) registers definition
ARM: at91: drop sam9_smc.c
ata: at91: use syscon to configure the smc
ARM: ux500: delete static resource defines
ARM: ux500: rename ux500_map_io
ARM: ux500: look up PRCMU resource from DT
ARM: ux500: kill off L2CC static map
Merge second patchbomb from Andrew Morton:
- most of the rest of MM
- lots of misc things
- procfs updates
- printk feature work
- updates to get_maintainer, MAINTAINERS, checkpatch
- lib/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits)
exit,stats: /* obey this comment */
coredump: add __printf attribute to cn_*printf functions
coredump: use from_kuid/kgid when formatting corename
fs/reiserfs: remove unneeded cast
NILFS2: support NFSv2 export
fs/befs/btree.c: remove unneeded initializations
fs/minix: remove unneeded cast
init/do_mounts.c: add create_dev() failure log
kasan: remove duplicate definition of the macro KASAN_FREE_PAGE
fs/efs: femove unneeded cast
checkpatch: emit "NOTE: <types>" message only once after multiple files
checkpatch: emit an error when there's a diff in a changelog
checkpatch: validate MODULE_LICENSE content
checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY
checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr()
checkpatch: fix processing of MEMSET issues
checkpatch: suggest using ether_addr_equal*()
checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files
checkpatch: remove local from codespell path
checkpatch: add --showfile to allow input via pipe to show filenames
Commit bccab6a0 ("dm cache: switch the "default" cache replacement
policy from mq to smq") should've incremented the "default" policy's
version number to 1.4.0 rather than reverting to version 1.0.0.
Reported-by: Alasdair G Kergon <agk@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
This fix enables userspace to detect that the dm-stats changes from the
4.2 merge are in place.
This reverts commit 5f1b670d0bef508a5554d92525f5f6d00d640b38.
Justification for revert as reported in this dm-devel post:
https://www.redhat.com/archives/dm-devel/2015-June/msg00160.html
this change should not be pushed to mainline yet.
Firstly, Christoph has a newer version of the patch that fixes silent
data corruption problem:
https://www.redhat.com/archives/dm-devel/2015-May/msg00229.html
And the new version still depends on LLDDs to always complete requests
to the end when error happens, while block API doesn't enforce such a
requirement. If the assumption is ever broken, the inconsistency between
request and bio (e.g. rq->__sector and rq->bio) will cause silent data
corruption:
https://www.redhat.com/archives/dm-devel/2015-June/msg00022.html
Reported-by: Junichi Nomura <j-nomura@ce.jp.nec.com>
This reverts commit cbc4e3c1350beb47beab8f34ad9be3d34a20c705.
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux
Pull RTC updates from Alexandre Belloni:
"Core:
- Coding style and whitespace fixes (interface, Makefile and Kconfig)
- New rtc_tm_sub() helper
- New CONFIG_RTC_SYSTOHC_DEVICE option
- Removed rtc_set_mmss()
New drivers:
- Mediatek MT6397
- Cortina Gemini
Drivers:
- Year 2106 fixes for isl1208, pcf8563 and sunxi
- update author email for at32ap700x and efi
- ds1307: alarm fix
- efi: use correct EFI 'epoch'
- hym8563: make irq optional
- imxdi: cleanups and better handling of the security/tamper monitoring
- snvs: fix wakealarm
- Compilation fixes or warning removal for gemini, mt6397, palmas, pfc8563
- Trivial cleanups for ab8500, ds1216, ds1286, ds1672, ep93xx,
hid-sensor-time, max6900, max8998, max77686, max77802, mc13xxx, mv,
mxc, s3c, spear, v3020
- Kconfig fixes for stmp3xxx and xgene"
* tag 'rtc-v4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (48 commits)
rtc: remove useless I2C dependencies
rtc: whitespace fixes
rtc: Properly sort Makefile
MAINTAINERS: Add RTC subsystem repository
rtc: pfc8563: fix uninitialized variable warning
rtc: ds1307: Enable the mcp794xx alarm after programming time
rtc: hym8563: make the irq optional
rtc: gemini: fix cocci warnings
rtc: mv: correct 24 hour error message
rtc: mv: use BIT()
rtc: efi: use correct EFI 'epoch'
rtc: interface: Remove rtc_set_mmss()
sparc: time: Replace update_persistent_clock() with CONFIG_RTC_SYSTOHC
rtc: NTP: Add CONFIG_RTC_SYSTOHC_DEVICE for NTP synchronization
rtc: sunxi: Replace deprecated rtc_tm_to_time()
rtc: isl1208: Replace deprecated rtc_tm_to_time()
rtc: Introduce rtc_tm_sub() helper function
rtc: pcf8563: Replace deprecated rtc_time_to_tm() and rtc_tm_to_time()
rtc: palmas: Initialise bb_charging flag before using it
rtc: simplify use of devm_ioremap_resource
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux
Pull i2c updates from Wolfram Sang:
"Highlights:
- new drivers for Mediatek I2C, APM X-Gene, Broadcom Settop
- major updates to at91, davinci
- bugfixes to the mux infrastructure when dealing with the new quirk
mechanism
- more users for the bus recovery feature
- further improvements to the slave framework
Plus the usual bunch of smaller driver and core improvements and
fixes.
There is one patch removing old code from an ARM platform. This has
been acked by the sh_mobile maintainer Simon Horman"
* 'i2c/for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (48 commits)
i2c: busses: i2c-bcm2835: limits cdiv to allowed values
i2c: sh_mobile: use proper type for timeout
i2c: sh_mobile: use adapter default for timeout
i2c: rcar: use proper type for timeout
i2c: rcar: use adapter default for timeout
i2c: designware: Make sure the device is suspended before disabling runtime PM
i2c: tegra: apply size limit quirk
i2c: tegra: don't advertise SMBUS_QUICK
i2c: octeon: remove unused signal handling
i2c: davinci: Optimize SCL generation
i2c: mux: pca954x: Use __i2c_transfer because of quirks
i2c: mux: Use __i2c_transfer() instead of calling parent's master_xfer()
i2c: use parent adapter quirks in mux
i2c: bcm2835: clear reserved bits in S-Register
ARM: shmobile: r8a7740: remove I2C errata handling
i2c: sh_mobile: add errata workaround
i2c: at91: fix code checker warnings
i2c: busses: xgene-slimpro: fix incorrect __init declation for probe
i2c: davinci: Avoid sending to own address
i2c: davinci: Refactor i2c_davinci_wait_bus_not_busy()
git://git.linaro.org/landing-teams/working/fujitsu/integration
Pull mailbox updates from Jassi Brar.
* 'mailbox-for-next' of git://git.linaro.org/landing-teams/working/fujitsu/integration:
mailbox/bcm2835: Fix mailbox full detection.
dt: mailbox: Remove 'mbox-names property is discouraged' message from binding
mailbox: Add ability for clients to request channels by name
mailbox: Enable BCM2835 mailbox support
dt/bindings: Add binding for the BCM2835 mailbox driver
mailbox: Fix up error handling in mbox_request_channel()
mailbox: Make mbox_chan_ops const
mailbox: altera: Add dependency on HAS_IOMEM
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac
Pull edac updates from Mauro Carvalho Chehab:
"Some fixes and additions to the EDAC driver used on modern Intel x86
CPUs. It includes support for Broadwell EP/EX platforms and fixes for
motherboards with more than 2 CPU sockets"
* tag 'edac/v4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac:
sb_edac: support for Broadwell -EP and -EX
sb_edac: Fix support for systems with two home agents per socket
sb_edac: Fix a typo and a thinko in address handling for Haswell
EDAC: Remove arbitrary limit on number of channels
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- Lots of improvements at the DVB API DocBook documentation. Now, the
frontend and the network APIs are fully in sync with the Kernel and
looks more like the rest of the media documentation;
- New frontend driver: cx24120
- New driver for a PCI device: cobalt. This driver is actually not
sold in the market, but it is a good example of a multi-HDMI input
device;
- The dt3155 driver were promoted from staging;
- The mantis driver got remote controller support;
- New V4L2 driver for ST bdisp SoC chipsets;
- Make sparse and smatch happier: several bugs were solved by fixing
the issues reported by those static code analyzers.
- Lots of new device additions, new features, improvements and cleanups
at the existing drivers.
* tag 'media/v4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (553 commits)
[media] lmedm04: fix the range for relative measurements
[media] lmedm04: use u32 instead of u64 for relative stats
[media] omap3isp: remove unused var
[media] saa7134: fix page size on some archs
[media] use CONFIG_PM_SLEEP for suspend/resume
[media] tuner-i2c: be consistent with I2C declaration
[media] si470x: cleanup define namespace
[media] bdisp: prevent compiling on random arch
[media] vb2: Don't WARN when v4l2_buffer.bytesused is 0 for multiplanar buffers
[media] MAINTAINERS: Add entry for the Renesas VSP1 driver
[media] videodev2.h: fix copy-and-paste error in V4L2_MAP_XFER_FUNC_DEFAULT
[media] Revert "[media] vb2: Push mmap_sem down to memops"
[media] mantis: cleanup a warning
[media] bdisp-debug: don't try to divide by s64
[media] cx88: don't declare restart_video_queue if not used
[media] au0828: move dev->boards atribuition to happen earlier
[media] lmedm04: implement dvb v5 statistics
[media] bdisp: remove unused var
[media] bdisp: remove needless check
ts2020: fix compilation on i386
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management updates from Zhang Rui:
"Specifics:
- enhance Thermal Framework with several new capabilities:
* use power estimates
* compute weights with relative integers instead of percentages
* allow governors to have private data in thermal zones
* export thermal zone parameters through sysfs
Thanks to the ARM thermal team (Javi, Punit, KP).
- introduce a new thermal governor: power allocator. First in kernel
closed loop PI(D) controller for thermal control. Thanks to ARM
thermal team.
- enhance OF thermal to allow thermal zones to have sustainable power
HW specification. Thanks to Punit.
- introduce thermal driver for Intel Quark SoC x1000platform. Thanks
to Ong, Boon Leong.
- introduce QPNP PMIC temperature alarm driver. Thanks to Ivan T. I.
- introduce thermal driver for Hisilicon hi6220. Thanks to
kongxinwei.
- enhance Exynos thermal driver to handle Exynos5433 TMU. Thanks to
Chanwoo C.
- TI thermal driver now has a better implementation for EOCZ bit.
From Pavel M.
- add id for Skylake processors in int340x processor thermal driver.
- a couple of small fixes and cleanups."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (36 commits)
thermal: hisilicon: add new hisilicon thermal sensor driver
dt-bindings: Document the hi6220 thermal sensor bindings
thermal: of-thermal: add support for reading coefficients property
thermal: support slope and offset coefficients
thermal: power_allocator: round the division when divvying up power
thermal: exynos: Add the support for Exynos5433 TMU
thermal: cpu_cooling: Fix power calculation when CPUs are offline
thermal: cpu_cooling: Remove cpu_dev update on policy CPU update
thermal: export thermal_zone_parameters to sysfs
thermal: cpu_cooling: Check memory allocation of power_table
ti-soc-thermal: request temperature periodically if hw can't do that itself
ti-soc-thermal: implement eocz bit to make driver useful on omap3
cleanup ti-soc-thermal
thermal: remove stale THERMAL_POWER_ACTOR select
thermal: Default OF created trip points to writable
thermal: core: Add Kconfig option to enable writable trips
thermal: x86_pkg_temp: drop const for thermal_zone_parameters
of: thermal: Introduce sustainable power for a thermal zone
thermal: add trace events to the power allocator governor
thermal: introduce the Power Allocator governor
On the MacBook Pro, power of the gpu is cut by a gmux chip. Sometimes
the gpu gets stuck in powersaving mode and refuses to wake up
("Refused to change power state, currently in D3"). Inserting a
delay between setting the gpu to D3hot and cutting the power seems
to help (most of the time). This issue and its (partial) remediation
by the patch was observed with an Nvidia GT650M (NVE7 / GK107).
Signed-off-by: Lukas Wunner <lukas@wunner.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"It was a busy development cycle at this time, as you can see a wide
range of changes in diffstat. There are no big changes but many
refactoring and improvements. Here we go some highlights:
ALSA core:
- Procfs codes were cleaned up to use seq_file
- Procfs can be opt out via Kconfig (only for EXPERT)
- Two types of jack API were unified finally; now both kctl and input
jack devs are handled via a single function call.
HD-audio:
- Continued code restructuring for the future ASoC driver; now HDA
controller driver is split to a core helper module.
- Preliminary codes for Skylake audio support in HDA core.
- Proper i915 gfx power well management for SKL & co
- Enabled runtime PM as default for Intel HDMI/DP codecs
- Newer Tegra chip supports
- More quirks for Dell headsets, Alienware (with CA0132), etc.
- A couple of DRM ELD helper API functions
ASoC:
- Support for loading ASoC topology maps from firmware, intended to
be used to allow self-describing DSP firmware images to be built
which can map controls added by the DSP to userspace without the
kernel needing to know about individual DSP firmwares
- Lots of refactoring to avoid direct access to snd_soc_codec where
it's not needed supporting future refactoring
- Big refactoring, cleanup and enhancement for the Wolfson ADSP
driver
- Cleanup series for TI TAS2552 and R-CAR drivers
- Fixes and improvements on RT56xx codecs
- Support for TI TAS571x power amplifiers
- Support for Qualcomm APQ8016 and ZTE ZX296702 SoCs
- Support for x86 systems with RT5650 and Qualcomm Storm
- Support for Mediatek AFE (Audio Front End) unit
- Other various small fixes to ASoC codec drivers
Firewire:
- Enhanced to allow non-blocking streams to use timestamp
synchronization
- Improve support for DM1500 and BeBoBv3
Misc:
- Cleanup of old pci API functions over all PCI sound drivers
- Fix long-standing regression of the old powermac i2c setup"
* tag 'sound-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (533 commits)
ALSA: pcm: Fix pcm_class sysfs output
ALSA: hda-beep: Update authors dead email address
ASoC: wm_adsp: Move DSP Rate controls into the codec
ASoC: wm8995: Fix setting sysclk for WM8995_SYSCLK_MCLK2 case
ALSA: hda: provide default bus io ops extended hdac
ALSA: hda: add hda link cleanup routine
ALSA: hda: add hdac_ext stream creation and cleanup routines
ASoC: rsrc-card: remove unused ret
ALSA: HDAC: move SND_HDA_PREALLOC_SIZE to core
ASoC: mediatek: Add machine driver for rt5650 rt5676 codec
ASoC: mediatek: Add machine driver for MAX98090 codec
ASoC: mediatek: Add AFE platform driver
ASoC: rsnd: remove io from rsnd_mod
ASoC: rsnd: move rsnd_mod_is_working() to rsnd_io_is_working()
ASoC: rsnd: don't use rsnd_mod_to_io() on snd_kcontrol
ASoC: rsnd: don't use rsnd_mod_to_io() on rsnd_src_xxx()
ASoC: rsnd: don't use rsnd_mod_to_io() on rsnd_ssi_xxx()
ASoC: rsnd: don't use rsnd_mod_to_io() on rsnd_dma_xxx()
ASoC: rsnd: don't use rsnd_mod_to_io() on rsnd_get_adinr()
ASoC: rsnd: add common interrupt handler for SSI/SRC/DMA
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
Pull DMI updates from Jean Delvare:
"The most important change is the new sysfs interface to the DMI table,
which will let user-space tools (such as dmidecode) access the table
without relying on /dev/mem"
* 'dmi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
firmware: dmi: struct dmi_header should be packed
firmware: dmi_scan: Coding style cleanups
Documentation: ABI: sysfs-firmware-dmi: add -entries suffix to file name
firmware: dmi_scan: add SBMIOS entry and DMI tables
firmware: dmi_scan: Trim DMI table length before exporting it
firmware: dmi_scan: Rename dmi_table to dmi_decode_table
firmware: dmi: List my quilt tree
firmware: dmi_scan: Only honor end-of-table for 64-bit tables
There is a helpful comment in do_exit() that states we sync the mm's RSS
info before statistics gathering.
The function that does the statistics gathering is called right above that
comment.
Change the code to obey the comment.
Signed-off-by: Rik van Riel <riel@redhat.com>
This allows detecting improper format string at build time, like:
fs/coredump.c:225:5: warning: format '%ld' expects argument of type 'long int', but argument 3 has type 'int' [-Wformat=]
err = cn_printf(cn, "%ld", cprm->siginfo->si_signo);
As si_signo is always an int, the format should be %d here.
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
When adding __printf attribute to cn_printf, gcc reports some issues:
fs/coredump.c:213:5: warning: format '%d' expects argument of type
'int', but argument 3 has type 'kuid_t' [-Wformat=]
err = cn_printf(cn, "%d", cred->uid);
fs/coredump.c:217:5: warning: format '%d' expects argument of type
'int', but argument 3 has type 'kgid_t' [-Wformat=]
err = cn_printf(cn, "%d", cred->gid);
These warnings come from the fact that the value of uid/gid needs to be
extracted from the kuid_t/kgid_t structure before being used as an
integer. More precisely, cred->uid and cred->gid need to be converted to
either user-namespace uid/gid or to init_user_ns uid/gid.
Use init_user_ns in order not to break existing ABI, and document this in
Documentation/sysctl/kernel.txt.
While at it, format uid and gid values with %u instead of %d because
uid_t/__kernel_uid32_t and gid_t/__kernel_gid32_t are unsigned int.
kmem_cache_alloc() returns void*.
Signed-off-by: Firo Yang <firogm@gmail.com>
The "fh_len" passed to ->fh_to_* is not guaranteed to be that same as that
returned by encode_fh - it may be larger.
With NFSv2, the filehandle is fixed length, so it may appear longer than
expected and be zero-padded.
So we must test that fh_len is at least some value, not exactly equal to
it.
Signed-off-by: NeilBrown <neilb@suse.de>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
bh, od_sup and this_node are unconditionally initialized in
befs_bt_read_super() and befs_btree_find()
Signed-off-by: Fabian Frederick <fabf@skynet.be>
If create_dev() function fails to create the root mount device
(/dev/root), then it goes to panic as root device not found but there is
no printk in this case. So I have added the log in case it fails to
create the root device. It will help in debugging.
[akpm@linux-foundation.org: simplify printk(), use pr_emerg(), display errno]
Signed-off-by: Vishnu Pratap Singh <vishnu.ps@samsung.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Dan Ehrenberg <dehrenberg@chromium.org>
Cc: Miklos Szeredi <mszeredi@suse.cz>
Remove duplicate definition of the macro KASAN_FREE_PAGE in
mm/kasan/kasan.h
Signed-off-by: Wang Long <long.wanglong@huawei.com>
Acked-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Make this message similar to the "false positives" message and emit it
only once when scanning multiple files instead of after each file scanned.
Cc: Andy Whitcroft <apw@canonical.com>
People often put diff snippets in changelogs. This causes problems
when one tries to apply a file containing both the changelog and the
diff because patch(1) tries to apply the diff which it found in the
changelog.
Warn once when what seems to be a diff snippet in the changelog exists.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
There is a well defined list of expected values for MODULE_LICENSE so warn
the user upon usage of unknown values.
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Cc: Joe Perches <joe@perches.com>
Handle multi-line memcpy() properly.
Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Acked-by: Joe Perches <joe@perches.com>
Suggest using eth_zero_addr() or eth_broadcast_addr() instead of memset().
Remove 's' modifier to avoid reporting the same warning several times.
Check if memcmp() is used to compare ethernet addresses and suggest using
ether_addr_equal() or ether_addr_equal_unaligned()
Make an exception for the "Does not appear to be a unified-diff" error
when scanning what appears to be git generated cover letters.
Suggested-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
local is typically used for manually installed apps.
For apps installed from distro the right path is /usr/share.
Signed-off-by: Maxim Uvarov <maxim.uvarov@linaro.org>
