This #include is not required.
It's all good.
This changes the type of variable "i" in rtl8169_init_one()
from "unsigned int" to "int". "i" is checked for < 0 later,
which can never happen for "unsigned". This results in broken
error handling.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 3943/1: share declaration of struct pxa2xx_udc_mach_info between multiple platforms
[ARM] Export smp_call_function()
[ARM] Add PM_LEGACY defaults
multiple platforms
Move declaration of struct pxa2xx_udc_mach_info from
include/asm-arm/arch-pxa/udc.h to new file
include/asm-arm/mach/udc_pxa2xx.h.
This allow us to use this structure with
multiple platforms - pxa and ixp4xx. USB
device controller used in pxa25x is the same
as controller used in ixp4xx.
Signed-off-by: Milan Svoboda <msvoboda@ra.rockwell.com>
Otherwise CPU 0 doesn't show up in sysfs which breaks some software.
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[NET]: Fix MAX_HEADER setting.
[NETFILTER]: ipt_REJECT: fix memory corruption
[NETFILTER]: conntrack: fix refcount leak when finding expectation
[NETFILTER]: ctnetlink: fix reference count leak
[NETFILTER]: nf_conntrack: fix the race on assign helper to new conntrack
[NETFILTER]: nfctnetlink: assign helper to newly created conntrack
MAX_HEADER is either set to LL_MAX_HEADER or LL_MAX_HEADER + 48, and
this is controlled by a set of CONFIG_* ifdef tests.
It is trying to use LL_MAX_HEADER + 48 when any of the tunnels are
enabled which set hard_header_len like this:
dev->hard_header_len = LL_MAX_HEADER + sizeof(struct xxx);
The correct set of tunnel drivers which do this are:
ipip
ip_gre
ip6_tunnel
sit
so make the ifdef test match.
Noticed by Patrick McHardy and with help from Herbert Xu.
On devices with hard_header_len > LL_MAX_HEADER ip_route_me_harder()
reallocates the skb, leading to memory corruption when using the stale
tcph pointer to update the checksum.
All users of __{ip,nf}_conntrack_expect_find() don't expect that
it increments the reference count of expectation.
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
When NFA_NEST exceeds the skb size the protocol reference is leaked.
The found helper cannot be assigned to conntrack after unlocking
nf_conntrack_lock. This tries to find helper to assign again.
This fixes the bug which doesn't assign helper to newly created
conntrack via nf_conntrack_netlink.
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev:
[PATCH] libata: Fixup ata_sas_queuecmd to handle __ata_scsi_queuecmd failure
[PATCH] ahci: AHCI mode SATA patch for Intel ICH9
[PATCH] libata: don't schedule EH on wcache on/off if old EH
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6:
selinux: fix dentry_open() error check
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6:
[PATCH] x86-64: Use stricter in process stack check for unwinder
[PATCH] i386: Fix compilation with UP genericarch
[PATCH] x86-64: Fix warning in io_apic.c
[PATCH] x86-64: work around gcc4 issue with -Os in Dwarf2 stack unwind
[PATCH] x86_64: Align data segment to PAGE_SIZE boundary
* 'linus' of master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa:
[ALSA] version 1.0.13
[ALSA] snd-emu10k1: Fix capture for one variant.
[ALSA] Fix hang-up at disconnection of usb-audio
[ALSA] hda: fix typo for xw4400 PCI sub-ID
[ALSA] hda: fix sigmatel dell system detection
[ALSA] Enable stereo line input for TAS codec
[ALSA] rtctimer: handle RTC interrupts with a tasklet
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus:
[MIPS] Fix Bonito bootup message.
include/scsi/libsas.h:479: error: field 'smp_req' has incomplete type
include/scsi/libsas.h:480: error: field 'smp_resp' has incomplete type
Signed-off-by: Dave Jones <davej@redhat.com>
The return value of crypto_alloc_blkcipher() should be checked by IS_ERR().
Cc: Mike Halcrow <mhalcrow@us.ibm.com>
Cc: Phillip Hellewell <phillip@hellewell.homeip.net>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
The return value of create_write_pipe()/create_read_pipe() should be
When we sleep and wait for a suspended operation to be resumed, go
back and check until it's ready -- don't just continue after the first
time we're woken. This can cause file system corruption.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Make sure to properly clamp maxnum to avoid overflow
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Acked-by: Eugene Teo <eteo@redhat.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Even when enabling Bonito IOBC coherence the kernel would actually claim
it was disabling it.
Previously it would check for alignment only, which could break
if the stack pointer was unaligned. Now explicitely check if the
stack pointer is in the stack page of the current process.
Ported from i386.
Signed-off-by: Andi Kleen <ak@suse.de>
Fix
arch/i386/mach-generic/built-in.o: In function `apicid_to_node':
summit.c:(.text+0x2f): undefined reference to `apicid_2_node'
with CONFIG_GENERICH_ARCH and !CONFIG_SMP
This fixes a problem with gcc4 mis-compiling the stack unwind code under
-Os, which resulted in 'stuck' messages whenever an assembly routine was
encountered.
(The second hunk is trivial cleanup.)
Signed-off-by: Jan Beulich <jbeulich@novell.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
Commit 2c8c0e6b8d7700a990da8d24eff767f9ca223b96 ("[PATCH] Convert x86-64
to early param") broke the earlyprintk=...,keep feature.
This restores that functionality. Tested on x86_64. Must-have for
v2.6.19, no risk.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Fixes ALSA bug#324
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
Fix hang-up at disconnection of usb-audio devices while accessing PCM.
Don't handle PCM operations any more after shutdown flag is set.
The PCI sub-device ID for the HP xw4400 is actually 0x280c.
Fixes Dell system detection on 9200 codecs. The support
to detect certain Dell machines was merged in the
9205 table where it will be unused on the various Dell
9200-based codec systems. This moves the subsystem IDs
to the correct 9200 table.
Signed-off-by: Matt Porter <mporter@embeddedalley.com>
Despite what the data sheet says in one place, to get stereo input
from input A (line in), we have to clear the 'input B monaural' bit in
the ACR.
The calls to rtc_control() from inside the interrupt handler can upset
the RTC code, so move our interrupt handling code to a tasklet.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
Fixes ata_sas_queuecmd to properly handle a failure from
__ata_scsi_queuecmd.
Signed-off-by: Brian King <brking@us.ibm.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
This patch adds the Intel ICH9 AHCI controller DID's for SATA support.
Signed-off-by: Jason Gaston <jason.d.gaston@intel.com>
Do not schedule EH for revalidation on wcache on/off if old EH. Old
EH cannot handle it and will result in WARN_ON()'s and oops.
This closes bug #7412.
Signed-off-by: Tejun Heo <htejun@gmail.com>
The return value of dentry_open() shoud be checked by IS_ERR().
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Signed-off-by: James Morris <jmorris@namei.org>
You wouldn't think that doing an ALIGN() macro that aligns something up
to a power-of-two boundary would be likely to have bugs, would you?
But hey, in the wonderful world of mixing integer types, you have to be
careful. This just makes sure that the alignment is interpreted in the
same type as the thing to be aligned.
Thanks to Roland Dreier, who noticed that the amso1100 driver got broken
by the previous fix (that just extended the mask to "unsigned long", but
was still broken in "unsigned long long" - it just happened to be the
same on 64-bit architectures).
See commit 4c8bd7eeee4c8f157fb61fb64b57500990b42e0e for the history of
bugs here...
Acked-by: Roland Dreier <rdreier@cisco.com>
Cc: Andrew Morton <akpm@osdl.org>
I still think using BUILD_BUG_ON() is unacceptable, especially given how
vague the error message was.
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
[ And I already removed gthe BUILD_BUG_ON() in the previous commit ]
This reverts commit ee3ce191e8eaa4cc15c51a28b34143b36404c4f5, since it
broke on at least ARM, MIPS and PA-RISC due to complicated header file
dependencies.
Conflicts in include/linux/spinlock.h (due to the "nested" variety
fixes) fixed up by hand.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Kyle McMartin <kyle@parisc-linux.org>
Cc: Russell King <rmk+lkml@arm.linux.org.uk>
[XFRM] STATE: Fix to respond error to get operation if no matching entry exists.
[NET]: Re-fix of doc-comment in sock.h
[6PACK]: Masking bug in 6pack driver.
[NET]: Fix kfifo_alloc() error check.
[UDP]: Make udp_encap_rcv use pskb_may_pull
[NETFILTER]: H.323 conntrack: fix crash with CONFIG_IP_NF_CT_ACCT
smp_call_function() will be used with the MP/core oprofile support
patch. Export it as _GPL.
Eliminate two warnings:
kernel/power/pm.c:205: warning: 'pm_register' is deprecated (declared at kernel/power/pm.c:64)
kernel/power/pm.c:206: warning: 'pm_send_all' is deprecated (declared at kernel/power/pm.c:180)
by updating defconfig files to contain a sensible PM_LEGACY default.
The tda10086 causes an oops (divide by zero) if a zero symbol rate is used;
this prevents this.
Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
The old code would accept any device on the same i2c address as the
saa711x chips as an saa711x. However, this fails with saa717x chips,
which use that same address and so are misdetected as a saa7111. Now
check whether the chip is really a saa711x model.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
