2006-10-11[PATCH] ext4: errors behaviour fixDmitry Mishin
Current error behaviour for ext2 and ext3 filesystems does not fully correspond to the documentation and should be fixed. According to man 8 mount, ext2 and ext3 file systems allow to set one of 3 different on-errors behaviours: ---- start of quote man 8 mount ---- errors=continue / errors=remount-ro / errors=panic Define the behaviour when an error is encountered. (Either ignore errors and just mark the file system erroneous and continue, or remount the file system read-only, or panic and halt the system.) The default is set in the filesystem superblock, and can be changed using tune2fs(8). ---- end of quote ---- However EXT3_ERRORS_CONTINUE is not read from the superblock, and thus ERRORS_CONT is not saved on the sbi->s_mount_opt. It leads to the incorrect handle of errors on ext3. Then we've checked corresponding code in ext2 and discovered that it is buggy as well: - EXT2_ERRORS_CONTINUE is not read from the superblock (the same); - parse_option() does not clean the alternative values and thus something like (ERRORS_CONT|ERRORS_RO) can be set; - if options are omitted, parse_option() does not set any of these options. Therefore it is possible to set any combination of these options on the ext2: - none of them may be set: EXT2_ERRORS_CONTINUE on superblock / empty mount options; - any of them may be set using mount options; - 2 any options may be set: by using EXT2_ERRORS_RO/EXT2_ERRORS_PANIC on the superblock and other value in mount options; - and finally all three options may be set by adding third option in remount. Currently ext2 uses these values only in ext2_error() and it is not leading to any noticeable troubles. However somebody may be discouraged when he will try to workaround EXT2_ERRORS_PANIC on the superblock by using errors=continue in mount options. This patch: EXT4_ERRORS_CONTINUE should be taken from the superblock as default value for error behaviour. Signed-off-by: Dmitry Mishin <dim@openvz.org> Acked-by: Vasily Averin <vvs@sw.ru> Acked-by: Kirill Korotaev <dev@openvz.org> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: rename logic_sb_blockAndrew Morton
I assume this means "logical sb block". So call it that. I still don't understand the name though. A block is a block. What's different about this one? Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4 64 bit divide fixAndrew Morton
With CONFIG_LBD=n, sector_div() expands to a plain old divide. But ext4 is _not_ passing in a sector_t as the first argument, so... fs/built-in.o: In function `ext4_get_group_no_and_offset': fs/ext4/balloc.c:39: undefined reference to `__umoddi3' fs/ext4/balloc.c:41: undefined reference to `__udivdi3' fs/built-in.o: In function `find_group_orlov': fs/ext4/ialloc.c:278: undefined reference to `__udivdi3' fs/built-in.o: In function `ext4_fill_super': fs/ext4/super.c:1488: undefined reference to `__udivdi3' fs/ext4/super.c:1488: undefined reference to `__umoddi3' fs/ext4/super.c:1594: undefined reference to `__udivdi3' fs/ext4/super.c:1601: undefined reference to `__umoddi3' Fix that up by calling do_div() directly. Also cast the arg to u64. do_div() is only defined on u64, and ext4_fsblk_t is supposed to be opaque. Note especially the changes to find_group_orlov(). It was attempting to do do_div(int, unsigned long long); which is royally screwed up. Switched it to plain old divide. Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4 uninline ext4_get_group_no_and_offset()Andrew Morton
Way too big to inline. Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: move block number hi bitsAlexandre Ratchov
move '_hi' bits of block numbers in the larger part of the block group descriptor structure Signed-off-by: Alexandre Ratchov <alexandre.ratchov@bull.net> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: allow larger descriptor sizeAlexandre Ratchov
make block group descriptor larger. Signed-off-by: Alexandre Ratchov <alexandre.ratchov@bull.net> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: switch blks_type from sector_t to ullMingming Cao
Similar to ext4, change blocks in JBD2 from sector_t to unsigned long long. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: removesector_t bits checkMingming Cao
Previously when in-kernel ext4 block type is sector_t, it's only 4 bits long under some 32bit arch (when CONFIG_LBD is not on). So we need to check the size of sector_t before we read 48bit long on-disk blocks to in-kernel blocks. These checks are unnecessary now as we changed the in-kernel blocks to unsigned longlong. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: blk_type from sector_t to unsigned long longMingming Cao
Change ext4 in-kernel block type (ext4_fsblk_t) from sector_t to unsigned long long. Remove ext4 block type string micro E3FSBLK, replaced with "%llu" [akpm@osdl.org: build fix] Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: 64bit metadataLaurent Vivier
In-kernel super block changes to support >32 bit free blocks numbers. Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Alexandre Ratchov <alexandre.ratchov@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: 48bit i_file_aclBadari Pulavarty
As we are planning to support 48-bit block numbers for ext4, we need to support 48-bit block numbers for extended attributes. In the short term, we can do this by reuse (on-disk) 16-bit padding (linux2.i_pad1 currently used only by "hurd") as high order bits for xattr. This patch basically does that. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: sector_t conversionMingming Cao
JBD layer in-kernel block varibles type fixes to support >32 bit block number and convert to sector_t type. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] 64-bit jbd2 coreZach Brown
Here is the patch to JBD to handle 64 bit block numbers, originally from Zach Brown. This patch is useful only after adding support for 64-bit block numbers in the filesystem. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: clean up comments in ext4-extents patchRandy Dunlap
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: uninitialised extent handlingSuparna Bhattacharya
Make it possible to add file preallocation support in future as an RO_COMPAT feature by recognizing uninitialized extents as holes and limiting extent length to keep the top bit of ee_len free for marking uninitialized extents. Signed-off-by: Suparna Bhattacharya <suparna@in.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: 48bit physical block number support in extentsAlex Tomas
Signed-off-by: Alex Tomas <alex@clusterfs.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: switch fsblk to sector_tMingming Cao
Redefine ext3 in-kernel filesystem block type (ext3_fsblk_t) from unsigned long to sector_t, to allow kernel to handle >32 bit ext3 blocks. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext3: add extent map supportAlex Tomas
On disk extents format: /* * this is extent on-disk structure * it's used at the bottom of the tree */ struct ext3_extent { __le32 ee_block; /* first logical block extent covers */ __le16 ee_len; /* number of blocks covered by extent */ __le16 ee_start_hi; /* high 16 bits of physical block */ __le32 ee_start; /* low 32 bigs of physical block */ }; Signed-off-by: Alex Tomas <alex@clusterfs.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: cleanup ext4_jbd.hDave Kleikamp
To allow ext4 to build during the transition from jbd to jbd2, we have both ext4_jbd.h and ext4_jbd2.h in the tree. We no longer need the former. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: enable building of jbd2 and have ext4 use it rather than jbdMingming Cao
Reworked from a patch by Mingming Cao and Randy Dunlap Signed-off-By: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: rename slabJohann Lombardi
jbd and jbd2 currently use the same slab names which must be unique. The patch below just renames jbd2's slabs. Signed-off-by: Johann Lombardi <johann.lombardi@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: rename jbd2 symbols to avoid duplication of jbd symbolsMingming Cao
Mingming Cao originally did this work, and Shaggy reproduced it using some scripts from her. Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: initial copy of files from jbdDave Kleikamp
This is a simple copy of the files in fs/jbd to fs/jbd2 and /usr/incude/linux/[ext4_]jbd.h to /usr/include/[ext4_]jbd2.h Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: enable building of ext4Mingming Cao
Originally part of a patch from Mingming Cao and Randy Dunlap. Reorganized by Shaggy. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: rename ext4 symbols to avoid duplication of ext3 symbolsMingming Cao
2006-10-11[PATCH] ext4: initial copy of files from ext3Dave Kleikamp
Start of the ext4 patch series. See Documentation/filesystems/ext4.txt for details. This is a simple copy of the files in fs/ext3 to fs/ext4 and /usr/incude/linux/ext3* to /usr/include/ex4* Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] hugetlb: fix linked list corruption in unmap_hugepage_range()Chen, Kenneth W
commit fe1668ae5bf0145014c71797febd9ad5670d5d05 causes kernel to oops with libhugetlbfs test suite. The problem is that hugetlb pages can be shared by multiple mappings. Multiple threads can fight over page->lru in the unmap path and bad things happen. We now serialize __unmap_hugepage_range to void concurrent linked list manipulation. Such serialization is also needed for shared page table page on hugetlb area. This patch will fixed the bug and also serve as a prepatch for shared page table. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] swsusp: Use suspend_consoleRafael J. Wysocki
Add suspend_console() and resume_console() to the suspend-to-disk code paths so that the users of netconsole can use swsusp with it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Disable DETECT_SOFTLOCKUP for s390Heiko Carstens
We got several false bug reports because of enabled CONFIG_DETECT_SOFTLOCKUP. Disable soft lockup detection on s390, since it doesn't work on a virtualized architecture. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] use struct irq_chip instead of struct hw_interrupt_typeAneesh Kumar K.V
hw_interrupt_type is deprecated in favour of struct irq_chip. [mingo@elte.hu: do x86_64 too] Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] Fix menuconfig build failure due to missing stdbool.hLuca Tettamanti
scripts/kconfig/lxdialog/util.c fails to build because it uses true/false without including stdbool.h: kronos:~/src/linux-2.6$ make O=../linux-build-git menuconfig GEN /home/kronos/src/linux-build/Makefile HOSTCC scripts/kconfig/lxdialog/util.o /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c: In function 'set_classic_theme': /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:68: error: 'true' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:68: error: (Each undeclared identifier is reported only once /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:68: error: for each function it appears in.) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:70: error: 'false' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c: In function 'set_blackbg_theme': /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:101: error: 'true' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:102: error: 'false' undeclared (first use in this function) /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c: In function 'set_bluetitle_theme': /home/kronos/src/linux-2.6/scripts/kconfig/lxdialog/util.c:144: error: 'true' undeclared (first use in this function) make[2]: *** [scripts/kconfig/lxdialog/util.o] Error 1 make[1]: *** [menuconfig] Error 2 make: *** [menuconfig] Error 2 Add <stdbool.h> to dialog.h to fix the breakage. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] mm: remove memmap_zone_idx()Mel Gorman
memmap_zone_idx() is not used anymore. It was required by an earlier version of account-for-memmap-and-optionally-the-kernel-image-as-holes.patch but not any more. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] mm: use symbolic names instead of indices for zone initialisationMel Gorman
Arch-independent zone-sizing is using indices instead of symbolic names to offset within an array related to zones (max_zone_pfns). The unintended impact is that ZONE_DMA and ZONE_NORMAL is initialised on powerpc instead of ZONE_DMA and ZONE_HIGHMEM when CONFIG_HIGHMEM is set. As a result, the the machine fails to boot but will boot with CONFIG_HIGHMEM turned off. The following patch properly initialises the max_zone_pfns[] array and uses symbolic names instead of indices in each architecture using arch-independent zone-sizing. Two users have successfully booted their powerpcs with it (one an ibook G4). It has also been boot tested on x86, x86_64, ppc64 and ia64. Please merge for 2.6.19-rc2. Credit to Benjamin Herrenschmidt for identifying the bug and rolling the first fix. Additional credit to Johannes Berg and Andreas Schwab for reporting the problem and testing on powerpc. Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] IRQ: Fix AVR32 breakageHaavard Skinnemoen
Make the necessary changes to AVR32 required by the irq regs stuff. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] null dereference in fs/jbd/journal.cEric Sesterhenn
Since commit d1807793e1e7e502e3dc047115e9dbc3b50e4534 we dereference a NULL pointer. Coverity id #1432. We set journal to NULL, and use it directly afterwards. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] revert "nvidiafb: use generic ddc reading"Andrew Morton
Olaf reports that this gave him a black screen. Cc: Olaf Hering <olaf@aepfle.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10ACPI: Allow setting SCI_EN bit in PM1_CONTROL registerLinus Torvalds
This is needed by at least the Mac Mini's, which (incorrectly) come back from suspend with SCI_EN clear. Thanks to Frédéric Riss for hunting this down. Acked-by: Frédéric Riss <frederic.riss@gmail.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Len Brown <len.brown@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] firmware/dcdbas: fix bug in error cleanupJeff Garzik
The error path path mistakenly called sysfs_create_group() rather than sysfs_remove_group(). They take the same arguments, so it's easy to cut-n-paste such a bug. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] irda: donauboe fixes, cleanupsJeff Garzik
- fix: toshoboe_invalid_dev() was recently removed, but not all callers were updated, causing the obvious linker error. Remove caller, because the check (like the one removed) isn't used. - fix: propagate request_irq() return value - cleanup: remove void* casts - cleanup: remove impossible ASSERTs Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Fix windfarm platform device usage [POWERPC] Fix i2c-powermac platform device usage [POWERPC] Fix secondary CPU startup on old "powersurge" SMP powermacs [POWERPC] ARCH=ppc pt_regs fixes [POWERPC] Update maple defconfig [POWERPC] Fix Maple secondary IDE interrupt [POWERPC] Make U4 PCIe work on maple [POWERPC] cell: fix default zImage build target [POWERPC] Fix boot wrapper invocation if CROSS_COMPILE contains spaces [POWERPC] Fix xmon IRQ handler for pt_regs removal
2006-10-10[PATCH] endianness annotations in s2ioAl Viro
2006-10-10[PATCH] ufs endianness annotationsAl Viro
2006-10-10[PATCH] fs/partitions endianness annotationsAl Viro
2006-10-10[PATCH] Finish annotations of struct vlan_ethhdrAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] isofs endianness annotationsAl Viro
2006-10-10[PATCH] smbfs endianness annotationsAl Viro
2006-10-10[PATCH] hpfs endianness annotationsAl Viro
2006-10-10[PATCH] fs/fat endianness annotationsAl Viro
2006-10-10[PATCH] befs: endianness annotationsAl Viro
split the data structures that exist in host- and disk-endian variants, annotate the fields of disk-endian ones, propagate changes. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-10[PATCH] befs: missing fs32_to_cpu() in debug.cAl Viro
inode->mode is disk-endian Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
