2015-06-05Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Misc fixes: - early_idt_handlers[] fix that fixes the build with bleeding edge tooling - build warning fix on GCC 5.1 - vm86 fix plus self-test to make it harder to break it again" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/asm/irq: Stop relying on magic JMP behavior for early_idt_handlers x86/asm/entry/32, selftests: Add a selftest for kernel entries from VM86 mode x86/boot: Add CONFIG_PARAVIRT_SPINLOCKS quirk to arch/x86/boot/compressed/misc.h x86/asm/entry/32: Really make user_mode() work correctly for VM86 mode
2015-06-05Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "The biggest chunk of the changes are two regression fixes: a HT workaround fix and an event-group scheduling fix. It's been verified with 5 days of fuzzer testing. Other fixes: - eBPF fix - a BIOS breakage detection fix - PMU driver fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/intel/pt: Fix a refactoring bug perf/x86: Tweak broken BIOS rules during check_hw_exists() perf/x86/intel/pt: Untangle pt_buffer_reset_markers() perf: Disallow sparse AUX allocations for non-SG PMUs in overwrite mode perf/x86: Improve HT workaround GP counter constraint perf/x86: Fix event/group validation perf: Fix race in BPF program unregister
2015-06-05Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Just two small fixes: one radeon, one amdkfd" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/amdkfd: fix topology bug with capability attr. drm/radeon: use proper ACR regisiter for DCE3.2
2015-06-05Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c bug fixes from Wolfram Sang: "Two small bugfixes for I2C" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: s3c2410: fix oops in suspend callback for non-dt platforms i2c: hix5hd2: Fix modalias to make module auto-loading work
2015-06-04compat: cleanup coding in compat_get_bitmap() and compat_put_bitmap()Helge Deller
In the functions compat_get_bitmap() and compat_put_bitmap() the variable nr_compat_longs stores how many compat_ulong_t words should be copied in a loop. The copy loop itself is this: if (nr_compat_longs-- > 0) { if (__get_user(um, umask)) return -EFAULT; } else { um = 0; } Since nr_compat_longs gets unconditionally decremented in each loop and since it's type is unsigned this could theoretically lead to out of bounds accesses to userspace if nr_compat_longs wraps around to (unsigned)(-1). Although the callers currently do not trigger out-of-bounds accesses, we should better implement the loop in a safe way to completely avoid such warp-arounds. Signed-off-by: Helge Deller <deller@gmx.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk>
2015-06-04Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine fixes from Vinod Koul: "We have two small fixes: - pl330 termination hang fix by Krzysztof - hsu memory leak fix by Peter" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: dmaengine: hsu: Fix memory leak when stopping a running transfer dmaengine: pl330: Fix hang on dmaengine_terminate_all on certain boards
2015-06-04perf/x86/intel/pt: Fix a refactoring bugAlexander Shishkin
Commit 066450be41 ("perf/x86/intel/pt: Clean up the control flow in pt_pmu_hw_init()") changed attribute initialization so that only the first attribute gets initialized using sysfs_attr_init(), which upsets lockdep. This patch fixes the glitch so that all allocated attributes are properly initialized thus fixing the lockdep warning reported by Tvrtko and Imre. Reported-by: Tvrtko Ursulin <tvrtko.ursulin@linux.intel.com> Reported-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: <linux-kernel@vger.kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-04Merge tag 'drm-amdkfd-fixes-2015-06-03' of ↵Dave Airlie
git://people.freedesktop.org/~gabbayo/linux into drm-fixes One minor fix for last -rc of 4.1. The fix moves the update of an attribute in topology to *after* it is actually initialized. * tag 'drm-amdkfd-fixes-2015-06-03' of git://people.freedesktop.org/~gabbayo/linux: drm/amdkfd: fix topology bug with capability attr.
2015-06-04Merge branch 'drm-fixes-4.1' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-fixes One more small r7xx audio regression fix for 4.1 * 'drm-fixes-4.1' of git://people.freedesktop.org/~agd5f/linux: drm/radeon: use proper ACR regisiter for DCE3.2
2015-06-03Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "Sending this off now, as I'm not aware of other current bugs, nor do I expect further fixes before 4.1 final. This contains two fixes: - a fix for a bdi unregister warning that gets spewed on md, due to a regression introduced earlier in this cycle. From Neil Brown. - a fix for a compile warning for NVMe on 32-bit platforms, also a regression introduced in this cycle. From Arnd Bergmann" * 'for-linus' of git://git.kernel.dk/linux-block: NVMe: fix type warning on 32-bit block: discard bdi_unregister() in favour of bdi_destroy()
2015-06-03MAINTAINERS - remove OSDL referenceStephen Hemminger
OSDL has been gone for many years, looks like there still was one reference to it. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-03drm/amdkfd: fix topology bug with capability attr.Alexey Skidanov
This patch fixes a bug where the number of watch points was shown before it was actually calculated Signed-off-by: Alexey Skidanov <Alexey.Skidanov@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Oded Gabbay <oded.gabbay@gmail.com>
2015-06-03lib: Clarify the return value of strnlen_user()Jan Kara
strnlen_user() can return a number in a range 0 to count + sizeof(unsigned long) - 1. Clarify the comment at the top of the function so that users don't think the function returns at most count+1. Signed-off-by: Jan Kara <jack@suse.cz> [ Also added commentary about preferably not using this function ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-02Merge tag 'please-pull-rusty' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull ia64 fix from Tony Luck: "Fix some build warnings for ia64 - cpu_callin_map doesn't need to be volatile" * tag 'please-pull-rusty' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: ia64: make cpu_callin_map non-volatile.
2015-06-02vfs: read file_handle only once in handle_to_pathSasha Levin
We used to read file_handle twice. Once to get the amount of extra bytes, and once to fetch the entire structure. This may be problematic since we do size verifications only after the first read, so if the number of extra bytes changes in userspace between the first and second calls, we'll have an incoherent view of file_handle. Instead, read the constant size once, and copy that over to the final structure without having to re-read it again. Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-02lib: Fix strnlen_user() to not touch memory after specified maximumJan Kara
If the specified maximum length of the string is a multiple of unsigned long, we would load one long behind the specified maximum. If that happens to be in a next page, we can hit a page fault although we were not expected to. Fix the off-by-one bug in the test whether we are at the end of the specified range. Signed-off-by: Jan Kara <jack@suse.cz> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-02ia64: make cpu_callin_map non-volatile.Rusty Russell
cpumask_test_cpu() doesn't take volatile, unlike the obsoleted cpu_isset. The only place ia64 really cares is the spin waiting for a bit; udelay() is probably a barrier but insert barrier() to be sure. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Tony Luck <tony.luck@intel.com>
2015-06-02dmaengine: hsu: Fix memory leak when stopping a running transferPeter Ujfalusi
The vd->node is removed from the lists when the transfer started so the vchan_get_all_descriptors() will not find it. This results memory leak. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> [andy: fix the typo to prevent a compilation error] Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2015-06-02x86/asm/irq: Stop relying on magic JMP behavior for early_idt_handlersAndy Lutomirski
The early_idt_handlers asm code generates an array of entry points spaced nine bytes apart. It's not really clear from that code or from the places that reference it what's going on, and the code only works in the first place because GAS never generates two-byte JMP instructions when jumping to global labels. Clean up the code to generate the correct array stride (member size) explicitly. This should be considerably more robust against screw-ups, as GAS will warn if a .fill directive has a negative count. Using '. =' to advance would have been even more robust (it would generate an actual error if it tried to move backwards), but it would pad with nulls, confusing anyone who tries to disassemble the code. The new scheme should be much clearer to future readers. While we're at it, improve the comments and rename the array and common code. Binutils may start relaxing jumps to non-weak labels. If so, this change will fix our build, and we may need to backport this change. Before, on x86_64: 0000000000000000 <early_idt_handlers>: 0: 6a 00 pushq $0x0 2: 6a 00 pushq $0x0 4: e9 00 00 00 00 jmpq 9 <early_idt_handlers+0x9> 5: R_X86_64_PC32 early_idt_handler-0x4 ... 48: 66 90 xchg %ax,%ax 4a: 6a 08 pushq $0x8 4c: e9 00 00 00 00 jmpq 51 <early_idt_handlers+0x51> 4d: R_X86_64_PC32 early_idt_handler-0x4 ... 117: 6a 00 pushq $0x0 119: 6a 1f pushq $0x1f 11b: e9 00 00 00 00 jmpq 120 <early_idt_handler> 11c: R_X86_64_PC32 early_idt_handler-0x4 After: 0000000000000000 <early_idt_handler_array>: 0: 6a 00 pushq $0x0 2: 6a 00 pushq $0x0 4: e9 14 01 00 00 jmpq 11d <early_idt_handler_common> ... 48: 6a 08 pushq $0x8 4a: e9 d1 00 00 00 jmpq 120 <early_idt_handler_common> 4f: cc int3 50: cc int3 ... 117: 6a 00 pushq $0x0 119: 6a 1f pushq $0x1f 11b: eb 03 jmp 120 <early_idt_handler_common> 11d: cc int3 11e: cc int3 11f: cc int3 Signed-off-by: Andy Lutomirski <luto@kernel.org> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Cc: Binutils <binutils@sourceware.org> Cc: Borislav Petkov <bp@alien8.de> Cc: H.J. Lu <hjl.tools@gmail.com> Cc: Jan Beulich <JBeulich@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/ac027962af343b0c599cbfcf50b945ad2ef3d7a8.1432336324.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Various VTI tunnel (mark handling, PMTU) bug fixes from Alexander Duyck and Steffen Klassert. 2) Revert ethtool PHY query change, it wasn't correct. The PHY address selected by the driver running the PHY to MAC connection decides what PHY address GET ethtool operations return information from. 3) Fix handling of sequence number bits for encryption IV generation in ESP driver, from Herbert Xu. 4) UDP can return -EAGAIN when we hit a bad checksum on receive, even when there are other packets in the receive queue which is wrong. Just respect the error returned from the generic socket recv datagram helper. From Eric Dumazet. 5) Fix BNA driver firmware loading on big-endian systems, from Ivan Vecera. 6) Fix regression in that we were inheriting the congestion control of the listening socket for new connections, the intended behavior always was to use the default in this case. From Neal Cardwell. 7) Fix NULL deref in brcmfmac driver, from Arend van Spriel. 8) OTP parsing fix in iwlwifi from Liad Kaufman. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (26 commits) vti6: Add pmtu handling to vti6_xmit. Revert "net: core: 'ethtool' issue with querying phy settings" bnx2x: Move statistics implementation into semaphores xen: netback: read hotplug script once at start of day. xen: netback: fix printf format string warning Revert "netfilter: ensure number of counters is >0 in do_replace()" net: dsa: Properly propagate errors from dsa_switch_setup_one tcp: fix child sockets to use system default congestion control if not set udp: fix behavior of wrong checksums sfc: free multiple Rx buffers when required bna: fix soft lock-up during firmware initialization failure bna: remove unreasonable iocpf timer start bna: fix firmware loading on big-endian machines bridge: fix br_multicast_query_expired() bug via-rhine: Resigning as maintainer brcmfmac: avoid null pointer access when brcmf_msgbuf_get_pktid() fails mac80211: Fix mac80211.h docbook comments iwlwifi: nvm: fix otp parsing in 8000 hw family iwlwifi: pcie: fix tracking of cmd_in_flight ip_vti/ip6_vti: Preserve skb->mark after rcv_cb call ...
2015-06-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull Sparc fixes from David Miller: 1) Setup the core/threads/sockets bitmaps correctly so that 'lscpus' and friends operate properly. Frtom Chris Hyser. 2) The bit that normally means "Cached Virtually" on sun4v systems, actually changes meaning in M7 and later chips. Fix from Khalid Aziz. 3) One some PCI-E systems we need to probe different OF properties to fill in the PCI slot information properly, from Eric Snowberg. 4) Kill an extraneous memset after kzalloc(), from Christophe Jaillet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc: Resolve conflict between sparc v9 and M7 on usage of bit 9 of TTE sparc64: pci slots information is not populated in sysfs sparc: kernel: GRPCI2: Remove a useless memset sparc64: Setup sysfs to mark LDOM sockets, cores and threads correctly
2015-06-01drm/radeon: use proper ACR regisiter for DCE3.2Alex Deucher
Using the DCE2 one by accident afer the audio rework. Bug: https://bugs.freedesktop.org/show_bug.cgi?id=90777 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2015-06-01Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio fix from Michael Tsirkin: "Last-minute virtio fix for 4.1 This tweaks an exported user-space header to fix build breakage for userspace using it" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: include/uapi/linux/virtio_balloon.h: include linux/virtio_types.h
2015-06-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter fix for net The following patch reverts the ebtables chunk that enforces counters that was introduced in the recently applied d26e2c9ffa38 ('Revert "netfilter: ensure number of counters is >0 in do_replace()"') since this breaks ebtables. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-01Merge tag 'wireless-drivers-for-davem-2015-06-01' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers Kalle Valo says: ==================== iwlwifi: * fix OTP parsing 8260 * fix powersave handling for 8260 brcmfmac: * fix null pointer crash ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-01vti6: Add pmtu handling to vti6_xmit.Steffen Klassert
We currently rely on the PMTU discovery of xfrm. However if a packet is localy sent, the PMTU mechanism of xfrm tries to to local socket notification what might not work for applications like ping that don't check for this. So add pmtu handling to vti6_xmit to report MTU changes immediately. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-01Revert "net: core: 'ethtool' issue with querying phy settings"David S. Miller
This reverts commit f96dee13b8e10f00840124255bed1d8b4c6afd6f. It isn't right, ethtool is meant to manage one PHY instance per netdevice at a time, and this is selected by the SET command. Therefore by definition the GET command must only return the settings for the configured and selected PHY. Reported-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-01bnx2x: Move statistics implementation into semaphoresYuval Mintz
Commit dff173de84958 ("bnx2x: Fix statistics locking scheme") changed the bnx2x locking around statistics state into using a mutex - but the lock is being accessed via a timer which is forbidden. [If compiled with CONFIG_DEBUG_MUTEXES, logs show a warning about accessing the mutex in interrupt context] This moves the implementation into using a semaphore [with size '1'] instead. Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: Ariel Elior <Ariel.Elior@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-01xen: netback: read hotplug script once at start of day.Ian Campbell
When we come to tear things down in netback_remove() and generate the uevent it is possible that the xenstore directory has already been removed (details below). In such cases netback_uevent() won't be able to read the hotplug script and will write a xenstore error node. A recent change to the hypervisor exposed this race such that we now sometimes lose it (where apparently we didn't ever before). Instead read the hotplug script configuration during setup and use it for the lifetime of the backend device. The apparently more obvious fix of moving the transition to state=Closed in netback_remove() to after the uevent does not work because it is possible that we are already in state=Closed (in reaction to the guest having disconnected as it shutdown). Being already in Closed means the toolstack is at liberty to start tearing down the xenstore directories. In principal it might be possible to arrange to unregister the device sooner (e.g on transition to Closing) such that xenstore would still be there but this state machine is fragile and prone to anger... A modern Xen system only relies on the hotplug uevent for driver domains, when the backend is in the same domain as the toolstack it will run the necessary setup/teardown directly in the correct sequence wrt xenstore changes. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Wei Liu <wei.liu2@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-01xen: netback: fix printf format string warningIan Campbell
drivers/net/xen-netback/netback.c: In function ‘xenvif_tx_build_gops’: drivers/net/xen-netback/netback.c:1253:8: warning: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 5 has type ‘int’ [-Wformat=] (txreq.offset&~PAGE_MASK) + txreq.size); ^ PAGE_MASK's type can vary by arch, so a cast is needed. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> ---- v2: Cast to unsigned long, since PAGE_MASK can vary by arch. Acked-by: Wei Liu <wei.liu2@citrix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-01Revert "netfilter: ensure number of counters is >0 in do_replace()"Bernhard Thaler
This partially reverts commit 1086bbe97a07 ("netfilter: ensure number of counters is >0 in do_replace()") in net/bridge/netfilter/ebtables.c. Setting rules with ebtables does not work any more with 1086bbe97a07 place. There is an error message and no rules set in the end. e.g. ~# ebtables -t nat -A POSTROUTING --src 12:34:56:78:9a:bc -j DROP Unable to update the kernel. Two possible causes: 1. Multiple ebtables programs were executing simultaneously. The ebtables userspace tool doesn't by default support multiple ebtables programs running Reverting the ebtables part of 1086bbe97a07 makes this work again. Signed-off-by: Bernhard Thaler <bernhard.thaler@wvnet.at> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-06-01include/uapi/linux/virtio_balloon.h: include linux/virtio_types.hMikko Rapeli
Fixes userspace compilation error: error: unknown type name ‘__virtio16’ __virtio16 tag; Signed-off-by: Mikko Rapeli <mikko.rapeli@iki.fi> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2015-05-31sparc: Resolve conflict between sparc v9 and M7 on usage of bit 9 of TTEKhalid Aziz
sparc: Resolve conflict between sparc v9 and M7 on usage of bit 9 of TTE Bit 9 of TTE is CV (Cacheable in V-cache) on sparc v9 processor while the same bit 9 is MCDE (Memory Corruption Detection Enable) on M7 processor. This creates a conflicting usage of the same bit. Kernel sets TTE.cv bit on all pages for sun4v architecture which works well for sparc v9 but enables memory corruption detection on M7 processor which is not the intent. This patch adds code to determine if kernel is running on M7 processor and takes steps to not enable memory corruption detection in TTE erroneously. Signed-off-by: Khalid Aziz <khalid.aziz@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31sparc64: pci slots information is not populated in sysfsEric Snowberg
Add PCI slot numbers within sysfs for PCIe hardware. Larger PCIe systems with nested PCI bridges and slots further down on these bridges were not being populated within sysfs. This will add ACPI style PCI slot numbers for these systems since the OF 'slot-names' information is not available on all PCIe platforms. Signed-off-by: Eric Snowberg <eric.snowberg@oracle.com> Reviewed-by: Bob Picco <bob.picco@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31sparc: kernel: GRPCI2: Remove a useless memsetChristophe Jaillet
grpci2priv is allocated using kzalloc, so there is no need to memset it. Signed-off-by: Christophe Jaillet <christophe.jaillet@wanadoo.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31net: dsa: Properly propagate errors from dsa_switch_setup_oneFlorian Fainelli
While shuffling some code around, dsa_switch_setup_one() was introduced, and it was modified to return either an error code using ERR_PTR() or a NULL pointer when running out of memory or failing to setup a switch. This is a problem for its caler: dsa_switch_setup() which uses IS_ERR() and expects to find an error code, not a NULL pointer, so we still try to proceed with dsa_switch_setup() and operate on invalid memory addresses. This can be easily reproduced by having e.g: the bcm_sf2 driver built-in, but having no such switch, such that drv->setup will fail. Fix this by using PTR_ERR() consistently which is both more informative and avoids for the caller to use IS_ERR_OR_NULL(). Fixes: df197195a5248 ("net: dsa: split dsa_switch_setup into two functions") Reported-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Florian Fainelli <f.fainelli@gmail.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31tcp: fix child sockets to use system default congestion control if not setNeal Cardwell
Linux 3.17 and earlier are explicitly engineered so that if the app doesn't specifically request a CC module on a listener before the SYN arrives, then the child gets the system default CC when the connection is established. See tcp_init_congestion_control() in 3.17 or earlier, which says "if no choice made yet assign the current value set as default". The change ("net: tcp: assign tcp cong_ops when tcp sk is created") altered these semantics, so that children got their parent listener's congestion control even if the system default had changed after the listener was created. This commit returns to those original semantics from 3.17 and earlier, since they are the original semantics from 2007 in 4d4d3d1e8 ("[TCP]: Congestion control initialization."), and some Linux congestion control workflows depend on that. In summary, if a listener socket specifically sets TCP_CONGESTION to "x", or the route locks the CC module to "x", then the child gets "x". Otherwise the child gets current system default from net.ipv4.tcp_congestion_control. That's the behavior in 3.17 and earlier, and this commit restores that. Fixes: 55d8694fa82c ("net: tcp: assign tcp cong_ops when tcp sk is created") Cc: Florian Westphal <fw@strlen.de> Cc: Daniel Borkmann <dborkman@redhat.com> Cc: Glenn Judd <glenn.judd@morganstanley.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31udp: fix behavior of wrong checksumsEric Dumazet
We have two problems in UDP stack related to bogus checksums : 1) We return -EAGAIN to application even if receive queue is not empty. This breaks applications using edge trigger epoll() 2) Under UDP flood, we can loop forever without yielding to other processes, potentially hanging the host, especially on non SMP. This patch is an attempt to make things better. We might in the future add extra support for rt applications wanting to better control time spent doing a recv() in a hostile environment. For example we could validate checksums before queuing packets in socket receive queue. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31Linux 4.1-rc6v4.1-rc6Linus Torvalds
2015-05-31sfc: free multiple Rx buffers when requiredDaniel Pieczko
When Rx packet data must be dropped, all the buffers associated with that Rx packet must be freed. Extend and rename efx_free_rx_buffer() to efx_free_rx_buffers() and loop through all the fragments. By doing so this patch fixes a possible memory leak. Signed-off-by: Shradha Shah <sshah@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fix from Al Viro: "Off-by-one in d_walk()/__dentry_kill() race fix. It's very hard to hit; possible in the same conditions as the original bug, except that you need the skipped branch to contain all the remaining evictables, so that the d_walk()-calling loop in d_invalidate() decides there's nothing more to do and doesn't go for another pass - otherwise that next pass will sweep the sucker. So it's not too urgent, but seeing that the fix is obvious and the original commit has spread into all -stable branches..." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: d_walk() might skip too much
2015-05-31Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "Three fixes this time around: - fix a memory leak which occurs when probing performance monitoring unit interrupts - fix handling of non-PMD aligned end of RAM causing boot failures - fix missing syscall trace exit path with syscall tracing enabled causing a kernel oops in the audit code" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8357/1: perf: fix memory leak when probing PMU PPIs ARM: fix missing syscall trace exit ARM: 8356/1: mm: handle non-pmd-aligned end of RAM
2015-05-31Merge branch 'upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ralf/linux Pull MIPS fixes from Ralf Baechle: "MIPS fixes for 4.1 all across the tree" * 'upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/ralf/linux: MIPS: strnlen_user.S: Fix a CPU_DADDI_WORKAROUNDS regression MIPS: BMIPS: Fix bmips_wr_vec() MIPS: ath79: fix build problem if CONFIG_BLK_DEV_INITRD is not set MIPS: Fuloong 2E: Replace CONFIG_USB_ISP1760_HCD by CONFIG_USB_ISP1760 MIPS: irq: Use DECLARE_BITMAP ttyFDC: Fix to use native endian MMIO reads MIPS: Fix CDMM to use native endian MMIO reads
2015-05-31Merge branch 'turbostat' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull turbostat tool fixes from Len Brown: "Just one minor kernel dependency in this batch -- added a #define to msr-index.h" * 'turbostat' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: tools/power turbostat: update version number to 4.7 tools/power turbostat: allow running without cpu0 tools/power turbostat: correctly decode of ENERGY_PERFORMANCE_BIAS tools/power turbostat: enable turbostat to support Knights Landing (KNL) tools/power turbostat: correctly display more than 2 threads/core
2015-05-31Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull SCSI target fixes from Nicholas Bellinger: "These are mostly minor fixes, with the exception of the following that address fall-out from recent v4.1-rc1 changes: - regression fix related to the big fabric API registration changes and configfs_depend_item() usage, that required cherry-picking one of HCH's patches from for-next to address the issue for v4.1 code. - remaining TCM-USER -v2 related changes to enforce full CDB passthrough from Andy + Ilias. Also included is a target_core_pscsi driver fix from Andy that addresses a long standing issue with a Scsi_Host reference being leaked on PSCSI device shutdown" * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: iser-target: Fix error path in isert_create_pi_ctx() target: Use a PASSTHROUGH flag instead of transport_types target: Move passthrough CDB parsing into a common function target/user: Only support full command pass-through target/user: Update example code for new ABI requirements target/pscsi: Don't leak scsi_host if hba is VIRTUAL_HOST target: Fix se_tpg_tfo->tf_subsys regression + remove tf_subsystem target: Drop signal_pending checks after interruptible lock acquire target: Add missing parentheses target: Fix bidi command handling target/user: Disallow full passthrough (pass_level=0) ISCSI: fix minor memory leak
2015-05-31Merge tag 'hwmon-for-linus-v4.1-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon fixes from Guenter Roeck: "Some late hwmon patches, all headed for -stable - fix sysfs attribute initialization in nct6775 and nct6683 drivers - do not attempt to auto-detect tmp435 on I2C address 0x37 - ensure iio channel is of type IIO_VOLTAGE in ntc_thermistor driver" * tag 'hwmon-for-linus-v4.1-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (nct6683) Add missing sysfs attribute initialization hwmon: (nct6775) Add missing sysfs attribute initialization hwmon: (tmp401) Do not auto-detect chip on I2C address 0x37 hwmon: (ntc_thermistor) Ensure iio channel is of type IIO_VOLTAGE
2015-05-30Merge branch 'bna-fixes'David S. Miller
Ivan Vecera says: ==================== bna: misc bugfixes These patches fix several bugs found during device initialization debugging. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-30bna: fix soft lock-up during firmware initialization failureIvan Vecera
Bug in the driver initialization causes soft-lockup if firmware initialization timeout is reached. Polling function bfa_ioc_poll_fwinit() incorrectly calls bfa_nw_iocpf_timeout() when the timeout is reached. The problem is that bfa_nw_iocpf_timeout() calls again bfa_ioc_poll_fwinit()... etc. The bfa_ioc_poll_fwinit() should directly send timeout event for iocpf and the same should be done if firmware download into HW fails. Cc: Rasesh Mody <rasesh.mody@qlogic.com> Signed-off-by: Ivan Vecera <ivecera@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-30bna: remove unreasonable iocpf timer startIvan Vecera
Driver starts iocpf timer prior bnad_ioceth_enable() call and this is unreasonable. This piece of code probably originates from Brocade/Qlogic out-of-box driver during initial import into upstream. This driver uses only one timer and queue to implement multiple timers and this timer is started at this place. The upstream driver uses multiple timers instead of this. Cc: Rasesh Mody <rasesh.mody@qlogic.com> Signed-off-by: Ivan Vecera <ivecera@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-30bna: fix firmware loading on big-endian machinesIvan Vecera
Firmware required by bna is stored in appropriate files as sequence of LE32 integers. After loading by request_firmware() they need to be byte-swapped on big-endian arches. Without this conversion the NIC is unusable on big-endian machines. Cc: Rasesh Mody <rasesh.mody@qlogic.com> Signed-off-by: Ivan Vecera <ivecera@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
