Previously, OLPC support for the mic extensions was only enabled in the
ALSA driver if CONFIG_OLPC and CONFIG_MGEODE_LX were both set. This was
because the old geode GPIO code was written in a manner that assumed
CONFIG_MGEODE_LX. With the new cs553x-gpio driver, this is no longer the
case; as such, we can drop the requirement on CONFIG_MGEODE_LX and instead
include a requirement on GPIOLIB.
We use the generic GPIO API rather than the cs553x-specific API.
Signed-off-by: Andres Salomon <dilinger@collabora.co.uk>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Jordan Crouse <jordan@cosmicpenguin.net>
Cc: David Brownell <david-b@pacbell.net>
Changed number of gpio pins to 32 (according to datasheet)
Added mask to disable some pins
Added gpio_request for checking mask and disabling special pin functions
Added pin names
[dilinger@collabora.co.uk: make printk usage consistent]
Signed-off-by: Tobias Mueller <Tobias_Mueller@twam.info>
Cc: Alessandro Zummo <alessandro.zummo@towertech.it>
This creates a CS5535/CS5536 GPIO driver which uses a gpio_chip backend
(allowing GPIO users to use the generic GPIO API if desired) while also
allowing architecture-specific users directly (via the cs5535_gpio_*
functions).
Tested on an OLPC machine. Some Leemotes also use CS5536 (with a mips
cpu), which is why this is in drivers/gpio rather than arch/x86.
Currently, it conflicts with older geode GPIO support; once MFGPT support
is reworked to also be more generic, the older geode code will be removed.
Reviewed-by: Alessandro Zummo <a.zummo@towertech.it>
allocation
Use DECLARE_BITMAP(), find_first_zero_bit(), set_bit() and clear_bit()
instead of rewriting code to do it with the minor number dynamic
allocation bitmap.
We need to invert the bit position to keep the code behaviour of using the
last minor numbers first, since we don't have a find_last_zero_bit.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
register fails
If there's a failure creating the device (because there's already one with
the same name, for example), the current implementation does not clear the
bit for the allocated minor and that number is lost for future
allocations.
Second, the test currently in misc_deregister is broken, since it does not
test for the 0 minor.
There are quite a few instances in the kernel of checks of pointers both
against NULL and against the errno range, handling both cases identically.
This additional helper function would simplify such code.
[akpm@linux-foundation.org: build fix]
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Two IOC3 and IOC4 drivers have broken error paths on registration. Fix
them.
Cc: Pat Gefre <pfg@sgi.com>
Several IOC3 and IOC4 drivers misuse the __devinit and __devexit section
markers. Use __init and __exit instead as appropriate, then add __devinit
and __devexit where they really belong for PCI drivers.
Also make ioc4_serial_init static.
journal_info in task_struct is used in journaling file system only. So
introduce CONFIG_FS_JOURNAL_INFO and make it conditional.
Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
It's easy to lose useful DEBUG_BUGVERBOSE by switching EMBEDDED left and right.
Add a printk_ratelimited statement expression macro that uses a per-call
ratelimit_state so that multiple subsystems output messages are not
suppressed by a global __ratelimit state.
[akpm@linux-foundation.org: s/_rl/_ratelimited/g]
Cc: Naohiro Ooiwa <nooiwa@miraclelinux.com>
Cc: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com>
Commit 8c8709334cec803368a432a33e0f2e116d48fe07 has removed the
pmu_device_init call from misc_init, but unlike other similar commits,
has not removed its declaration.
noise
do_each_thread/while_each_thread wrap a block of code that is in this format:
for (...)
do
while
If curly braces do not surround the inner loop the following warning is
generated by sparse:
warning: do-while statement is not a compound statement
Fix the warning by adding the braces.
According to feature-removal-schedule.txt, it is the time to remove
print_fn_descriptor_symbol().
And a quick grep shows that it no longer has any callers.
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
rwsem_is_locked() tests ->activity without locks, so we should always keep
->activity consistent. However, the code in __rwsem_do_wake() breaks this
rule, it updates ->activity after _all_ readers waken up, this may give
some reader a wrong ->activity value, thus cause rwsem_is_locked() behaves
wrong.
Quote from Andrew:
- we have one or more processes sleeping in down_read(), waiting for access.
- we wake one or more processes up without altering ->activity
- they start to run and they do rwsem_is_locked(). This incorrectly
returns "false", because the waker process is still crunching away in
__rwsem_do_wake().
- the waker now alters ->activity, but it was too late.
So we need get a spinlock to protect this. And rwsem_is_locked() should
not block, thus we use spin_trylock_irqsave().
[akpm@linux-foundation.org: simplify code]
Reported-by: Brian Behlendorf <behlendorf1@llnl.gov>
Cc: Ben Woodard <bwoodard@llnl.gov>
These functions need not to be exported, since no drivers should use them.
__init_rwsem() is an exception, because init_rwsem(), which is a macro,
is used.
Don't initialize __print_once. Invert the test to reduce initialized
data.
defconfig before: $size vmlinux
6976022 679572 1359668 9015262 898fde vmlinux
defconfig after: $size vmlinux
6976006 679508 1359700 9015214 898fae vmlinux
The symbol 'call' is a static symbol used for initcall_debug. This same
symbol name is used locally by a couple functions and produces the
following sparse warnings:
warning: symbol 'call' shadows an earlier one
Fix this noise by renaming the local symbols.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: "H Hartley Sweeten" <hartleys@visionengravers.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Use smp_processor_id() instead of get_cpu() and put_cpu() in
generic_smp_call_function_interrupt(), It's no need to disable preempt,
because we must call generic_smp_call_function_interrupt() with interrupts
disabled.
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
This driver supports the non-volatile digital potentiometers via I2C:
AD5258, AD5259, AD5251, AD5252, AD5253, AD5254, and AD5255
It provides a sysfs interface to each device for reading/writing which
is documented in Documentation/misc-devices/ad525x_dpot.txt.
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com>
Signed-off-by: Chris Verges <chrisv@cyberswitching.com>
Cc: Jean Delvare <khali@linux-fr.org>
If CONFIG_DYNAMIC_DEBUG is enabled and a source file has:
#define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
#include <linux/kernel.h>
dynamic_debug.h will duplicate KBUILD_MODNAME
in the output string.
Remove the use of KBUILD_MODNAME from the
output format string generated by dynamic_debug.h
If CONFIG_DYNAMIC_DEBUG is not enabled, no compile-time
check is done to printk/dev_printk arguments.
Add it.
Cc: Jason Baron <jbaron@redhat.com>
Commit 70867453092297be9afb2249e712a1f960ec0a09 ("printk_once(): use bool
for boolean flag") changed printk_once() to use bool instead of int for
its guard variable. Do the same change to WARN_ONCE() and WARN_ON_ONCE(),
for the same reasons.
This resulted in a reduction of 1462 bytes on a x86-64 defconfig:
8101271 1207116 992764 10301151 9d2edf vmlinux.before
8100553 1207148 991988 10299689 9d2929 vmlinux.after
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Daniel Walker <dwalker@fifo99.com>
Convert code away from ->read_proc/->write_proc interfaces. Switch to
proc_create()/proc_create_data() which make addition of proc entries
reliable wrt NULL ->proc_fops, NULL ->data and so on.
Problem with ->read_proc et al is described here commit
786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in
/proc entries"
Cc: Jeff Dike <jdike@addtoit.com>
gcc is not convinced that the floppy.c ioctl has sufficient bound checks:
In function `copy_from_user',
inlined from `fd_copyin' at drivers/block/floppy.c:3080,
inlined from `fd_ioctl' at drivers/block/floppy.c:3503:
arch/x86/include/asm/uaccess_32.h:211:
warning: call to `copy_from_user_overflow' declared with attribute
warning: copy_from_user buffer size is not provably correct
And frankly, as a human I have a hard time proving the same more or less
(the size comes from the ioctl argument. humpf. maybe. the code isn't
very nice)
This patch adds an explicit check to make 100% sure it's safe, better than
finding out later that there indeed was a gap.
[akpm@linux-foundation.org: add WARN_ON()]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
It does not seem possible that ldev can be NULL, so drop the unnecessary
test. If ldev can somehow be NULL, then the initialization of last_idx
should be moved below the test.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
// <smpl>
@match exists@
expression x, E;
identifier fld;
* x->fld
... when != \(x = E\|&x\)
* x == NULL
// </smpl>
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
/proc entries"
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Setting a thread's comm to be something unique is a very useful ability
and is helpful for debugging complicated threaded applications. However
currently the only way to set a thread name is for the thread to name
itself via the PR_SET_NAME prctl.
However, there may be situations where it would be advantageous for a
thread dispatcher to be naming the threads its managing, rather then
having the threads self-describe themselves. This sort of behavior is
available on other systems via the pthread_setname_np() interface.
This patch exports a task's comm via proc/pid/comm and
proc/pid/task/tid/comm interfaces, and allows thread siblings to write to
these values.
[akpm@linux-foundation.org: cleanups]
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Mike Fulton <fultonm@ca.ibm.com>
Cc: Sean Foley <Sean_Foley@ca.ibm.com>
Cc: Darren Hart <dvhltc@us.ibm.com>
On no-MMU systems, sizes reported in /proc/n/statm have units of bytes.
Per Documentation/filesystems/proc.txt, these values should be in pages.
Signed-off-by: Steven J. Magnani <steve@digidescorp.com>
Cc: Greg Ungerer <gerg@snapgear.com>
The NOMMU code currently clears all anonymous mmapped memory. While this
is what we want in the default case, all memory allocation from userspace
under NOMMU has to go through this interface, including malloc() which is
allowed to return uninitialized memory. This can easily be a significant
performance penalty. So for constrained embedded systems were security is
irrelevant, allow people to avoid clearing memory unnecessarily.
This also alters the ELF-FDPIC binfmt such that it obtains uninitialised
memory for the brk and stack region.
Signed-off-by: Jie Zhang <jie.zhang@analog.com>
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Greg Ungerer <gerg@snapgear.com>
This patch enables extraction of the pfn of a hugepage from
/proc/pid/pagemap in an architecture independent manner.
Details
My test program (leak_pagemap) works as follows:
- creat() and mmap() a file on hugetlbfs (file size is 200MB == 100 hugepages,)
- read()/write() something on it,
- call page-types with option -p,
- munmap() and unlink() the file on hugetlbfs
Without my patches
$ ./leak_pagemap
flags page-count MB symbolic-flags long-symbolic-flags
0x0000000000000000 1 0 __________________________________
0x0000000000000804 1 0 __R________M______________________ referenced,mmap
0x000000000000086c 81 0 __RU_lA____M______________________ referenced,uptodate,lru,active,mmap
0x0000000000005808 5 0 ___U_______Ma_b___________________ uptodate,mmap,anonymous,swapbacked
0x0000000000005868 12 0 ___U_lA____Ma_b___________________ uptodate,lru,active,mmap,anonymous,swapbacked
0x000000000000586c 1 0 __RU_lA____Ma_b___________________ referenced,uptodate,lru,active,mmap,anonymous,swapbacked
total 101 0
The output of page-types don't show any hugepage.
With my patches
$ ./leak_pagemap
0x0000000000030000 51100 199 ________________TG________________ compound_tail,huge
0x0000000000028018 100 0 ___UD__________H_G________________ uptodate,dirty,compound_head,huge
0x000000000000080c 1 0 __RU_______M______________________ referenced,uptodate,mmap
0x000000000000086c 80 0 __RU_lA____M______________________ referenced,uptodate,lru,active,mmap
0x0000000000005808 4 0 ___U_______Ma_b___________________ uptodate,mmap,anonymous,swapbacked
total 51300 200
The output of page-types shows 51200 pages contributing to hugepages,
containing 100 head pages and 51100 tail pages as expected.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Andy Whitcroft <apw@canonical.com>
Most callers of pmd_none_or_clear_bad() check whether the target page is
in a hugepage or not, but walk_page_range() do not check it. So if we
read /proc/pid/pagemap for the hugepage on x86 machine, the hugepage
memory is leaked as shown below. This patch fixes it.
Details
- call page-types with option -p (walk around the page tables),
Without my patches
$ cat /proc/meminfo |grep "HugePage"
HugePages_Total: 1000
HugePages_Free: 1000
HugePages_Rsvd: 0
HugePages_Surp: 0
$ ./leak_pagemap
[snip output]
HugePages_Free: 900
HugePages_Rsvd: 0
HugePages_Surp: 0
$ ls /hugetlbfs/
100 hugepages are accounted as used while there is no file on hugetlbfs.
With my patches
HugePages_Rsvd: 0
HugePages_Surp: 0
$ ./leak_pagemap
[snip output]
HugePages_Rsvd: 0
HugePages_Surp: 0
$ ls /hugetlbfs
No memory leaks.
Cc: <stable@kernel.org>
in a hugepage or not, but mincore() and walk_page_range() do not check it.
So if we use mincore() on a hugepage on x86 machine, the hugepage memory
is leaked as shown below. This patch fixes it by extending mincore()
system call to support hugepages.
Details
My test program (leak_mincore) works as follows:
- call mincore() for first ten pages and printf() the values of *vec
Without my patch
$ cat /proc/meminfo| grep "HugePage"
HugePages_Rsvd: 0
HugePages_Surp: 0
$ ./leak_mincore
vec[0] 0
vec[1] 0
vec[2] 0
vec[3] 0
vec[4] 0
vec[5] 0
vec[6] 0
vec[7] 0
vec[8] 0
vec[9] 0
HugePages_Free: 999
HugePages_Rsvd: 0
HugePages_Surp: 0
$ ls /hugetlbfs/
Return values in *vec from mincore() are set to 0, while the hugepage
should be in memory, and 1 hugepage is still accounted as used while
With my patch
HugePages_Rsvd: 0
HugePages_Surp: 0
$ ./leak_mincore
vec[0] 1
vec[1] 1
vec[2] 1
vec[3] 1
vec[4] 1
vec[5] 1
vec[6] 1
vec[7] 1
vec[8] 1
vec[9] 1
HugePages_Rsvd: 0
HugePages_Surp: 0
$ ls /hugetlbfs/
Return value in *vec set to 1 and no memory leaks.
[akpm@linux-foundation.org: cleanup]
If a user asks for a hugepage pool resize but specified a large number,
the machine can begin trashing. In response, they might hit ctrl-c but
signals are ignored and the pool resize continues until it fails an
allocation. This can take a considerable amount of time so this patch
aborts a pool resize if a signal is pending.
Suggested by Dave Hansen.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cleanup stale comments on munlock_vma_page().
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
unevictable_migrate_page() in mm/internal.h is a relic of the since
removed UNEVICTABLE_LRU Kconfig option. This patch removes the function
and open codes the test in migrate_page_copy().
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
When the owner of a mapping fails COW because a child process is holding a
reference, the children VMAs are walked and the page is unmapped. The
i_mmap_lock is taken for the unmapping of the page but not the walking of
the prio_tree. In theory, that tree could be changing if the lock is not
held. This patch takes the i_mmap_lock properly for the duration of the
prio_tree walk.
[hugh.dickins@tiscali.co.uk: Spotted the problem in the first place]
Jan Engelhardt reported we have this problem:
setting max_map_count to a value large enough results in programs dying at
first try. This is on 2.6.31.6:
15:59 borg:/proc/sys/vm # echo $[1<<31-1] >max_map_count
15:59 borg:/proc/sys/vm # cat max_map_count
1073741824
15:59 borg:/proc/sys/vm # echo $[1<<31] >max_map_count
Killed
This is because we have a chance to make 'max_map_count' negative. but
it's meaningless. Make it only accept non-negative values.
Reported-by: Jan Engelhardt <jengelh@medozas.de>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
The check code for CONFIG_SWAP is redundant, because there is a
non-CONFIG_SWAP version for PageSwapCache() which just returns 0.
Signed-off-by: Huang Shijie <shijie8@gmail.com>
Modify the generic mmap() code to keep the cache attribute in
vma->vm_page_prot regardless if writenotify is enabled or not. Without
this patch the cache configuration selected by f_op->mmap() is overwritten
if writenotify is enabled, making it impossible to keep the vma uncached.
Needed by drivers such as drivers/video/sh_mobile_lcdcfb.c which uses
deferred io together with uncached memory.
Signed-off-by: Magnus Damm <damm@opensource.se>
Cc: Jaya Kumar <jayakumar.lkml@gmail.com>
Simplify the code for shrink_inactive_list().
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
In AIM7 runs, recent kernels start swapping out anonymous pages well
before they should. This is due to shrink_list falling through to
shrink_inactive_list if !inactive_anon_is_low(zone, sc), when all we
really wanted to do is pre-age some anonymous pages to give them extra
time to be referenced while on the inactive list.
The obvious fix is to make sure that shrink_list does not fall through to
scanning/reclaiming inactive pages when we called it to scan one of the
active lists.
This change should be safe because the loop in shrink_zone ensures that we
will still shrink the anon and file inactive lists whenever we should.
[kosaki.motohiro@jp.fujitsu.com: inactive_file_is_low() should be inactive_anon_is_low()]
Reported-by: Larry Woodman <lwoodman@redhat.com>
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Tomasz Chmielewski <mangoo@wpkg.org>
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Nodemasks should not be allocated on the stack for large systems (when it
is larger than 256 bytes) since there is a threat of overflow.
This patch causes the unregister_mem_sect_under_nodes() nodemask to be
allocated on the stack for smaller systems and be allocated by slab for
larger systems.
GFP_KERNEL is used since remove_memory_block() can block.
Cc: Gary Hade <garyhade@us.ibm.com>
Cc: Badari Pulavarty <pbadari@us.ibm.com>
Cc: Alex Chiang <achiang@hp.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
SWAP_MLOCK mean "We marked the page as PG_MLOCK, please move it to
unevictable-lru". So, following code is easy confusable.
if (vma->vm_flags & VM_LOCKED) {
ret = SWAP_MLOCK;
goto out_unmap;
Plus, if the VMA doesn't have VM_LOCKED, We don't need to check
the needed of calling mlock_vma_page().
Also, add some commentary to try_to_unmap_one().
__free_pages_bootmem() is a __meminit function - which has been called
from put_pages_bootmem thus causes a section mismatch warning.
We were warned by the following warning:
LD mm/built-in.o
WARNING: mm/built-in.o(.text+0x26b22): Section mismatch in reference
from the function put_page_bootmem() to the function
.meminit.text:__free_pages_bootmem()
The function put_page_bootmem() references
the function __meminit __free_pages_bootmem().
This is often because put_page_bootmem lacks a __meminit
annotation or the annotation of __free_pages_bootmem is wrong.
Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com>
Cc: Yasunori Goto <y-goto@jp.fujitsu.com>
fails
hugetlb_fault() takes the mm->page_table_lock spinlock then calls
hugetlb_cow(). If the alloc_huge_page() in hugetlb_cow() fails due to an
insufficient huge page pool it calls unmap_ref_private() with the
mm->page_table_lock held. unmap_ref_private() then calls
unmap_hugepage_range() which tries to acquire the mm->page_table_lock.
[<ffffffff810928c3>] print_circular_bug_tail+0x80/0x9f
[<ffffffff8109280b>] ? check_noncircular+0xb0/0xe8
[<ffffffff810935e0>] __lock_acquire+0x956/0xc0e
[<ffffffff81093986>] lock_acquire+0xee/0x12e
[<ffffffff8111a7a6>] ? unmap_hugepage_range+0x3e/0x84
[<ffffffff814c348d>] _spin_lock+0x40/0x89
[<ffffffff8111afee>] ? alloc_huge_page+0x218/0x318
[<ffffffff8111a7a6>] unmap_hugepage_range+0x3e/0x84
[<ffffffff8111b2d0>] hugetlb_cow+0x1e2/0x3f4
[<ffffffff8111b935>] ? hugetlb_fault+0x453/0x4f6
[<ffffffff8111b962>] hugetlb_fault+0x480/0x4f6
[<ffffffff8111baee>] follow_hugetlb_page+0x116/0x2d9
[<ffffffff814c31a7>] ? _spin_unlock_irq+0x3a/0x5c
[<ffffffff81107b4d>] __get_user_pages+0x2a3/0x427
[<ffffffff81107d0f>] get_user_pages+0x3e/0x54
[<ffffffff81040b8b>] get_user_pages_fast+0x170/0x1b5
[<ffffffff81160352>] dio_get_page+0x64/0x14a
[<ffffffff8116112a>] __blockdev_direct_IO+0x4b7/0xb31
[<ffffffff8115ef91>] blkdev_direct_IO+0x58/0x6e
[<ffffffff8115e0a4>] ? blkdev_get_blocks+0x0/0xb8
[<ffffffff810ed2c5>] generic_file_aio_read+0xdd/0x528
[<ffffffff81219da3>] ? avc_has_perm+0x66/0x8c
[<ffffffff81132842>] do_sync_read+0xf5/0x146
[<ffffffff8107da00>] ? autoremove_wake_function+0x0/0x5a
[<ffffffff81211857>] ? security_file_permission+0x24/0x3a
[<ffffffff81132fd8>] vfs_read+0xb5/0x126
[<ffffffff81133f6b>] ? fget_light+0x5e/0xf8
[<ffffffff81133131>] sys_read+0x54/0x8c
[<ffffffff81011e42>] system_call_fastpath+0x16/0x1b
This can be fixed by dropping the mm->page_table_lock around the call to
unmap_ref_private() if alloc_huge_page() fails, its dropped right below in
the normal path anyway. However, earlier in the that function, it's also
possible to call into the page allocator with the same spinlock held.
What this patch does is drop the spinlock before the page allocator is
potentially entered. The check for page allocation failure can be made
without the page_table_lock as well as the copy of the huge page. Even if
the PTE changed while the spinlock was held, the consequence is that a
huge page is copied unnecessarily. This resolves both the double taking
of the lock and sleeping with the spinlock held.
[mel@csn.ul.ie: Cover also the case where process can sleep with spinlock]
Signed-off-by: Larry Woodman <lwooman@redhat.com>
Acked-by: Adam Litke <agl@us.ibm.com>
Cc: Andy Whitcroft <apw@shadowen.org>
Cc: David Gibson <david@gibson.dropbear.id.au>
It has no references outside memory_hotplug.c.
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Now that ksm pages are swappable, and the known holes plugged, remove
mention of unswappable kernel pages from KSM documentation and comments.
Remove the totalram_pages/4 initialization of max_kernel_pages. In fact,
remove max_kernel_pages altogether - we can reinstate it if removal turns
out to break someone's script; but if we later want to limit KSM's memory
usage, limiting the stable nodes would not be an effective approach.
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Izik Eidus <ieidus@redhat.com>
Cc: Chris Wright <chrisw@redhat.com>
