2009-06-10nilfs2: move get block functions in bmap.c into btree codesRyusuke Konishi
Two get block function for btree nodes, nilfs_bmap_get_block() and nilfs_bmap_get_new_block(), are called only from the btree codes. This relocation will increase opportunities of compiler optimization. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove nilfs_bmap_delete_blockRyusuke Konishi
nilfs_bmap_delete_block() is a wrapper function calling nilfs_btnode_delete(). This removes it for simplicity. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove nilfs_bmap_put_blockRyusuke Konishi
nilfs_bmap_put_block() is a wrapper function calling brelse(). This eliminates the wrapper for simplicity. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove header file for segment list operationsRyusuke Konishi
This will eliminate obsolete list operations of nilfs_segment_entry structure which has been used to handle mutiple segment numbers. The patch ("nilfs2: remove list of freeing segments") removed use of the structure from the segment constructor code, and this patch simplifies the remaining code by integrating it into recovery.c. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: eliminate removal list of segmentsRyusuke Konishi
This will clean up the removal list of segments and the related functions from segment.c and ioctl.c, which have hurt code readability. This elimination is applied by using nilfs_sufile_updatev() previously introduced in the patch ("nilfs2: add sufile function that can modify multiple segment usages"). Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: add sufile function that can modify multiple segment usagesRyusuke Konishi
This is a preparation for the later cleanup patch ("nilfs2: remove list of freeing segments"). This adds nilfs_sufile_updatev() to sufile, which can modify multiple segment usages at a time. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: unify bmap operations starting use of indirect block addressRyusuke Konishi
This simplifies some low level functions of bmap. Three bmap pointer operations, nilfs_bmap_start_v(), nilfs_bmap_commit_v(), and nilfs_bmap_abort_v(), are unified into one nilfs_bmap_start_v() function. And the related indirect function calls are replaced with it. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove nilfs_dat_prepare_free functionRyusuke Konishi
This function is unused. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-09Linux 2.6.30v2.6.30Linus Torvalds
2009-06-09char: mxser, fix ISA board lookupPeter Botha
There's a bug in the mxser kernel module that still appears in the 2.6.29.4 kernel. mxser_get_ISA_conf takes a ioaddress as its first argument, by passing the not of the ioaddr, you're effectively passing 0 which means it won't be able to talk to an ISA card. I have tested this, and removing the ! fixes the problem. Cc: "Peter Botha" <peterb@goldcircle.co.za> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-09jbd: fix race in buffer processing in commit codeJan Kara
In commit code, we scan buffers attached to a transaction. During this scan, we sometimes have to drop j_list_lock and then we recheck whether the journal buffer head didn't get freed by journal_try_to_free_buffers(). But checking for buffer_jbd(bh) isn't enough because a new journal head could get attached to our buffer head. So add a check whether the journal head remained the same and whether it's still at the same transaction and list. This is a nasty bug and can cause problems like memory corruption (use after free) or trigger various assertions in JBD code (observed). Signed-off-by: Jan Kara <jack@suse.cz> Cc: <stable@kernel.org> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-09autofs4: remove hashed check in validate_wait()Ian Kent
The recent ->lookup() deadlock correction required the directory inode mutex to be dropped while waiting for expire completion. We were concerned about side effects from this change and one has been identified. I saw several error messages. They cause autofs to become quite confused and don't really point to the actual problem. Things like: handle_packet_missing_direct:1376: can't find map entry for (43,1827932) which is usually totally fatal (although in this case it wouldn't be except that I treat is as such because it normally is). do_mount_direct: direct trigger not valid or already mounted /test/nested/g3c/s1/ss1 which is recoverable, however if this problem is at play it can cause autofs to become quite confused as to the dependencies in the mount tree because mount triggers end up mounted multiple times. It's hard to accurately check for this over mounting case and automount shouldn't need to if the kernel module is doing its job. There was one other message, similar in consequence of this last one but I can't locate a log example just now. When checking if a mount has already completed prior to adding a new mount request to the wait queue we check if the dentry is hashed and, if so, if it is a mount point. But, if a mount successfully completed while we slept on the wait queue mutex the dentry must exist for the mount to have completed so the test is not really needed. Mounts can also be done on top of a global root dentry, so for the above case, where a mount request completes and the wait queue entry has already been removed, the hashed test returning false can cause an incorrect callback to the daemon. Also, d_mountpoint() is not sufficient to check if a mount has completed for the multi-mount case when we don't have a real mount at the base of the tree. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-09shm: fix unused warnings on nommuMike Frysinger
The massive nommu update (8feae131) resulted in these warnings: ipc/shm.c: In function `sys_shmdt': ipc/shm.c:974: warning: unused variable `size' ipc/shm.c:972: warning: unused variable `next' Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: kvm: fix kvm reboot crash when MAXSMP is used cpumask: alloc zeroed cpumask for static cpumask_var_ts cpumask: introduce zalloc_cpumask_var
2009-06-09Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: bsg: setting rq->bio to NULL
2009-06-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: cls_cgroup: Fix oops when user send improperly 'tc filter add' request r8169: fix crash when large packets are received
2009-06-09Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md/raid5: fix bug in reshape code when chunk_size decreases. md/raid5 - avoid deadlocks in get_active_stripe during reshape md/raid5: use conf->raid_disks in preference to mddev->raid_disk
2009-06-09bsg: setting rq->bio to NULLFUJITA Tomonori
Due to commit 1cd96c242a829d52f7a5ae98f554ca9775429685 ("block: WARN in __blk_put_request() for potential bio leak"), BSG SMP requests get the false warnings: WARNING: at block/blk-core.c:1068 __blk_put_request+0x52/0xc0() This sets rq->bio to NULL to avoid that false warnings. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-09kvm: fix kvm reboot crash when MAXSMP is usedAvi Kivity
one system was found there is crash during reboot then kvm/MAXSMP Sending all processes the KILL signal... done Please stand by while rebooting the system... [ 1721.856538] md: stopping all md devices. [ 1722.852139] kvm: exiting hardware virtualization [ 1722.854601] BUG: unable to handle kernel NULL pointer dereference at (null) [ 1722.872219] IP: [<ffffffff8102c6b6>] hardware_disable+0x4c/0xb4 [ 1722.877955] PGD 0 [ 1722.880042] Oops: 0000 [#1] SMP [ 1722.892548] last sysfs file: /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/host0/target0:2:0/0:2:0:0/vendor [ 1722.900977] CPU 9 [ 1722.912606] Modules linked in: [ 1722.914226] Pid: 0, comm: swapper Not tainted 2.6.30-rc7-tip-01843-g2305324-dirty #299 ... [ 1722.932589] RIP: 0010:[<ffffffff8102c6b6>] [<ffffffff8102c6b6>] hardware_disable+0x4c/0xb4 [ 1722.942709] RSP: 0018:ffffc900010b6ed8 EFLAGS: 00010046 [ 1722.956121] RAX: 0000000000000000 RBX: ffffc9000e253140 RCX: 0000000000000009 [ 1722.972202] RDX: 000000000000b020 RSI: ffffc900010c3220 RDI: ffffffffffffd790 [ 1722.977399] RBP: ffffc900010b6f08 R08: 0000000000000000 R09: 0000000000000000 [ 1722.995149] R10: 00000000000004b8 R11: 966912b6c78fddbd R12: 0000000000000009 [ 1723.011551] R13: 000000000000b020 R14: 0000000000000009 R15: 0000000000000000 [ 1723.019898] FS: 0000000000000000(0000) GS:ffffc900010b3000(0000) knlGS:0000000000000000 [ 1723.034389] CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b [ 1723.041164] CR2: 0000000000000000 CR3: 0000000001001000 CR4: 00000000000006e0 [ 1723.056192] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 1723.072546] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 1723.080562] Process swapper (pid: 0, threadinfo ffff88107e464000, task ffff88047e5a2550) [ 1723.096144] Stack: [ 1723.099071] 0000000000000046 ffffc9000e253168 966912b6c78fddbd ffffc9000e253140 [ 1723.115471] ffff880c7d4304d0 ffffc9000e253168 ffffc900010b6f28 ffffffff81011022 [ 1723.132428] ffffc900010b6f48 966912b6c78fddbd ffffc900010b6f48 ffffffff8100b83b [ 1723.141973] Call Trace: [ 1723.142981] <IRQ> <0> [<ffffffff81011022>] kvm_arch_hardware_disable+0x26/0x3c [ 1723.158153] [<ffffffff8100b83b>] hardware_disable+0x3f/0x55 [ 1723.172168] [<ffffffff810b95f6>] generic_smp_call_function_interrupt+0x76/0x13c [ 1723.178836] [<ffffffff8104cbea>] smp_call_function_interrupt+0x3a/0x5e [ 1723.194689] [<ffffffff81035bf3>] call_function_interrupt+0x13/0x20 [ 1723.199750] <EOI> <0> [<ffffffff814ad3b4>] ? acpi_idle_enter_c1+0xd3/0xf4 [ 1723.217508] [<ffffffff814ad3ae>] ? acpi_idle_enter_c1+0xcd/0xf4 [ 1723.232172] [<ffffffff814ad4bc>] ? acpi_idle_enter_bm+0xe7/0x2ce [ 1723.235141] [<ffffffff81a8d93f>] ? __atomic_notifier_call_chain+0x0/0xac [ 1723.253381] [<ffffffff818c3dff>] ? menu_select+0x58/0xd2 [ 1723.258179] [<ffffffff818c2c9d>] ? cpuidle_idle_call+0xa4/0xf3 [ 1723.272828] [<ffffffff81034085>] ? cpu_idle+0xb8/0x101 [ 1723.277085] [<ffffffff81a80163>] ? start_secondary+0x1bc/0x1d7 [ 1723.293708] Code: b0 00 00 65 48 8b 04 25 28 00 00 00 48 89 45 e0 31 c0 48 8b 04 cd 30 ee 27 82 49 89 cc 49 89 d5 48 8b 04 10 48 8d b8 90 d7 ff ff <48> 8b 87 70 28 00 00 48 8d 98 90 d7 ff ff eb 16 e8 e9 fe ff ff [ 1723.335524] RIP [<ffffffff8102c6b6>] hardware_disable+0x4c/0xb4 [ 1723.342076] RSP <ffffc900010b6ed8> [ 1723.352021] CR2: 0000000000000000 [ 1723.354348] ---[ end trace e2aec53dae150aa1 ]--- it turns out that we need clear cpus_hardware_enabled in that case. Reported-and-tested-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-09cpumask: alloc zeroed cpumask for static cpumask_var_tsYinghai Lu
These are defined as static cpumask_var_t so if MAXSMP is not used, they are cleared already. Avoid surprises when MAXSMP is enabled. Signed-off-by: Yinghai Lu <yinghai.lu@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-09cpumask: introduce zalloc_cpumask_varYinghai Lu
So can get cpumask_var with cpumask_clear Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-09cls_cgroup: Fix oops when user send improperly 'tc filter add' requestMinoru Usui
I found a bug in cls_cgroup_change() in cls_cgroup.c. cls_cgroup_change() expected tca[TCA_OPTIONS] was set from user space properly, but tc in iproute2-2.6.29-1 (which I used) didn't set it. In the current source code of tc in git, it set tca[TCA_OPTIONS]. git://git.kernel.org/pub/scm/linux/kernel/git/shemminger/iproute2.git If we always use a newest iproute2 in git when we use cls_cgroup, we don't face this oops probably. But I think, kernel shouldn't panic regardless of use program's behaviour. Signed-off-by: Minoru Usui <usui@mxm.nes.nec.co.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09r8169: fix crash when large packets are receivedEric Dumazet
Michael Tokarev reported receiving a large packet could crash a machine with RTL8169 NIC. ( original thread at http://lkml.org/lkml/2009/6/8/192 ) Problem is this driver tells that NIC frames up to 16383 bytes can be received but provides skb to rx ring allocated with smaller sizes (1536 bytes in case standard 1500 bytes MTU is used) When a frame larger than what was allocated by driver is received, dma transfert can occurs past the end of buffer and corrupt kernel memory. Fix is to tell to NIC what is the maximum size a frame can be. This bug is very old, (before git introduction, linux-2.6.10), and should be backported to stable versions. Reported-by: Michael Tokarev <mjt@tls.msk.ru> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Michael Tokarev <mjt@tls.msk.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09md/raid5: fix bug in reshape code when chunk_size decreases.NeilBrown
Now that we support changing the chunksize, we calculate "reshape_sectors" to be the max of number of sectors in old and new chunk size. However there is one please where we still use 'chunksize' rather than 'reshape_sectors'. This causes a reshape that reduces the size of chunks to freeze. Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-09md/raid5 - avoid deadlocks in get_active_stripe during reshapeNeilBrown
md has functionality to 'quiesce' and array so that all pending IO completed and no new IO starts. This is used to achieve a stable state before making internal changes. Currently this quiescing applies equally to normal IO, resync IO, and reshape IO. However there is a problem with applying it to reshape IO. Reshape can have multiple 'stripe_heads' that must be active together. If the quiesce come between allocating the first and the last of such a collection, then we deadlock, as the last will not be allocated until the quiesce is lifted, the quiesce will not be lifted until the first (which has been allocated) gets used, and that first cannot be used until the last is allocated. It is not necessary to inhibit reshape IO when a quiesce is requested. Those places in the code that require a full quiesce will ensure the reshape thread is not running at all. So allow reshape requests to get access to new stripe_heads without being blocked by a 'quiesce'. This only affects in-place reshapes (i.e. where the array does not grow or shrink) and these are only newly supported. So this patch is not needed in earlier kernels. Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-09md/raid5: use conf->raid_disks in preference to mddev->raid_diskNeilBrown
mddev->raid_disks can be changed and any time by a request from user-space. It is a suggestion as to what number of raid_disks is desired. conf->raid_disks can only be changed by the raid5 module with suitable locks in place. It is a statement as to the current number of raid_disks. There are two places where the latter should be used, but the former is used. This can lead to a crash when reshaping an array. This patch changes to mddev-> to conf-> Signed-off-by: NeilBrown <neilb@suse.de>
2009-06-08async: Fix lack of boot-time console due to insufficient synchronizationLinus Torvalds
Our async work synchronization was broken by "async: make sure independent async domains can't accidentally entangle" (commit d5a877e8dd409d8c702986d06485c374b705d340), because it would report the wrong lowest active async ID when there was both running and pending async work. This caused things like no being able to read the root filesystem, resulting in missing console devices and inability to run 'init', causing a boot-time panic. This fixes it by properly returning the lowest pending async ID: if there is any running async work, that will have a lower ID than any pending work, and we should _not_ look at the pending work list. There were alternative patches from Jaswinder and James, but this one also cleans up the code by removing the pointless 'ret' variable and the unnecesary testing for an empty list around 'for_each_entry()' (if the list is empty, the for_each_entry() thing just won't execute). Fixes-bug: http://bugzilla.kernel.org/show_bug.cgi?id=13474 Reported-and-tested-by: Chris Clayton <chris2553@googlemail.com> Cc: Jaswinder Singh Rajput <jaswinder@kernel.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-08Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: MIPS: Outline udelay and fix a few issues. MIPS: ioctl.h: Fix headers_check warnings MIPS: Cobalt: PCI bus is always required to obtain the board ID MIPS: Kconfig: Remove "Support for" from Cavium system type MIPS: Sibyte: Honor CONFIG_CMDLINE SSB: BCM47xx: Export ssb_watchdog_timer_set
2009-06-08pata_netcell: Fix typoAlan Cox
The previous patch submission had a I typo I didn't catch but Bartlomiej noted. Guess this proves the point about any patch being risky late in an rc Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-08Merge branch 'kvm-updates/2.6.30' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.30' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: Explicity initialize cpus_hardware_enabled
2009-06-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: pdc202xx_old: fix resetproc() method pdc202xx_old: fix 'pdc20246_dma_ops'
2009-06-08MIPS: Outline udelay and fix a few issues.Ralf Baechle
Outlining fixes the issue were on certain CPUs such as the R10000 family the delay loop would need an extra cycle if it overlaps a cacheline boundary. The rewrite also fixes build errors with GCC 4.4 which was changed in way incompatible with the kernel's inline assembly. Relying on pure C for computation of the delay value removes the need for explicit. The price we pay is a slight slowdown of the computation - to be fixed on another day. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-08MIPS: ioctl.h: Fix headers_check warningsJaswinder Singh Rajput
Make ioctl.h compatible with asm-generic/ioctl.h and userspace fix the following 'make headers_check' warning: usr/include/asm-mips/ioctl.h:64: extern's make no sense in userspace Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-08MIPS: Cobalt: PCI bus is always required to obtain the board IDYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-08MIPS: Kconfig: Remove "Support for" from Cavium system typeYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-08MIPS: Sibyte: Honor CONFIG_CMDLINERalf Baechle
Original patch by Imre Kaloz <kaloz@openwrt.org>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-08SSB: BCM47xx: Export ssb_watchdog_timer_setMatthieu Castet
this patch export ssb_watchdog_timer_set to allow to use it in a Linux watchdog driver. Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Acked-by : Michael Buesch <mb@bu3sch.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-08Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 5543/1: arm: serial amba: add missing declaration in serial.h [ARM] pxa: fix pxa27x_udc default pullup GPIO [ARM] pxa/imote2: fix UCAM sensor board ADC model number mx[23]: don't put clock lookups in __initdata fix oops when using console=ttymxcN with N > 0 [ARM] ARMv7 errata: only apply fixes when running on applicable CPU [ARM] 5534/1: kmalloc must return a cache line aligned buffer
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: sdhci-of: Fix the wrong accessor to HOSTVER register mvsdio: fix config failure with some high speed SDHC cards mvsdio: ignore high speed timing requests from the core mmc/omap: Use disable_irq_nosync() from within irq handlers. sdhci-of: Add fsl,esdhc as a valid compatible to bind against mvsdio: allow automatic loading when modular mxcmmc: Fix missing return value checking in DMA setup code. mxcmmc : Reset the SDHC hardware if software timeout occurs. omap_hsmmc: Trivial fix for a typo in comment mxcmmc: decrease minimum frequency to make MMC cards work
2009-06-08KVM: Explicity initialize cpus_hardware_enabledAvi Kivity
Under CONFIG_MAXSMP, cpus_hardware_enabled is allocated from the heap and not statically initialized. This causes a crash on reboot when kvm thinks vmx is enabled on random nonexistent cpus and accesses nonexistent percpu lists. Fix by explicitly clearing the variable. Cc: stable@kernel.org Reported-and-tested-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-07[ARM] 5543/1: arm: serial amba: add missing declaration in serial.hAlessandro Rubini
This header is sometimes included in the uncompress stage to get register values, but no <linux/amba/bus.h> can be included there. So declare "struct amba_device" here before using it in a prototype. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-07pdc202xx_old: fix resetproc() methodSergei Shtylyov
pdc202xx_reset() calls pdc202xx_reset_host() twice, for both channels, while that function actually twiddles the single, shared software reset bit -- the net effect is a duplicated reset and horrendous 4 second delay happening not only on a channel reset but also when dma_lost_irq() and dma_clear() methods are called. Fold pdc202xx_reset_host() into pdc202xx_reset(), fix printk(), and move it before the actual reset... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-07pdc202xx_old: fix 'pdc20246_dma_ops'Sergei Shtylyov
Commit ac95beedf8bc97b24f9540d4da9952f07221c023 (ide: add struct ide_port_ops (take 2)) erroneously converted the driver's dma_timeout() and dma_lost_irq() methods to call the driver's resetproc() method regardless of whether it was defined for this specific controller while it hadn't been defined and hence called for PDC20246. So the dma_clear() method, the successor of dma_timeout(), shouldn't exist and the dma_lost_irq() method should be standard for PDC20246. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-06-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: x86/pci: fix mmconfig detection with 32bit near 4g PCI: use fixed-up device class when configuring device
2009-06-06integrity: fix IMA inode leakHugh Dickins
CONFIG_IMA=y inode activity leaks iint_cache and radix_tree_node objects until the system runs out of memory. Nowhere is calling ima_inode_free() a.k.a. ima_iint_delete(). Fix that by calling it from destroy_inode(). Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: ext3/4 with synchronous writes gets wedged by Postfix Fix nobh_truncate_page() to not pass stack garbage to get_block()
2009-06-06Merge branch 'upstream-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] pata_ali: Use IGN_SIMPLEX
2009-06-06ext3/4 with synchronous writes gets wedged by PostfixAl Viro
OK, that's probably the easiest way to do that, as much as I don't like it... Since iget() et.al. will not accept I_FREEING (will wait to go away and restart), and since we'd better have serialization between new/free on fs data structures anyway, we can afford simply skipping I_FREEING et.al. in insert_inode_locked(). We do that from new_inode, so it won't race with free_inode in any interesting ways and it won't race with iget (of any origin; nfsd or in case of fs corruption a lookup) since both still will wait for I_LOCK. Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Jan Kara <jack@suse.cz> Tested-by: David Watson <dbwatson@ukfsn.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-06Fix nobh_truncate_page() to not pass stack garbage to get_block()Theodore Ts'o
The nobh_truncate_page() function is used by ext2, exofs, and jfs. Of these three, only ext2 and jfs's get_block() function pays attention to bh->b_size --- which is normally always the filesystem blocksize except when the get_block() function is called by either mpage_readpage(), mpage_readpages(), or the direct I/O routines in fs/direct_io.c. Unfortunately, nobh_truncate_page() does not initialize map_bh before calling the filesystem-supplied get_block() function. So ext2 and jfs will try to calculate the number of blocks to map by taking stack garbage and shifting it left by inode->i_blkbits. This should be *mostly* harmless (except the filesystem will do some unnneeded work) unless the stack garbage is less than filesystem's blocksize, in which case maxblocks will be zero, and the attempt to find out whether or not the filesystem has a hole at a given logical block will fail, and the page cache entry might not get zero'ed out. Also if the stack garbage in in map_bh->state happens to have the BH_Mapped bit set, there could be an attempt to call readpage() on a non-existent page, which could cause nobh_truncate_page() to return an error when it should not. Fix this by initializing map_bh->state and map_bh->size. Fortunately, it's probably fairly unlikely that ext2 and jfs users mount with nobh these days. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-05[libata] pata_ali: Use IGN_SIMPLEXAlan Cox
Some ALi devices report simplex if they have been disabled and re-enabled, and restoring the byte does not work. Ignore it - the needed supporting logic is already present for the SATA ULi ports. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
