2012-11-28get rid of pt_regs argument of do_execve()Al Viro
2012-11-28make compat_do_execve() static, lose pt_regs argumentAl Viro
2012-11-28kill stray kernel_thread() garbageAl Viro
2012-11-28audit: no nested contexts anymore...Al Viro
2012-11-28consolidate sys_execve() prototypeAl Viro
2012-11-28Merge branches 'no-rebases', 'arch-avr32', 'arch-blackfin', 'arch-cris', ↵Al Viro
'arch-h8300', 'arch-m32r', 'arch-mn10300', 'arch-score', 'arch-sh' and 'arch-powerpc' into for-next
2012-11-28generic sys_fork / sys_vfork / sys_cloneAl Viro
... and get rid of idiotic struct pt_regs * in asm-generic/syscalls.h prototypes of the same, while we are at it. Eventually we want those in linux/syscalls.h, of course, but that'll have to wait a bit. Note that there are *three* variants of sys_clone() order of arguments. Braindamage galore... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28alpha: reorganize copy_process(), prepare to saner fork_idle()Al Viro
2012-11-28alpha: don't pass useless arguments to do_{,rt_},sigreturn()Al Viro
2012-11-28alpha: simplify fork and friendsAl Viro
* no need to restore everything from switch_stack when we only need $26 * no need to pass current_pt_regs() manually, we can just as easily calculate it in alpha_clone/alpha_vfork ($8 + constant) * interpretation of zero usp as "use the parent's" is simpler in copy_thread(); let fork and vfork just pass 0. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28um: don't bother looking at regs in copy_thread() - current_pt_regs() is ↵Al Viro
what we'll get Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28um: don't bother with passing sp to do_fork() for fork(2)/vfork(2)Al Viro
copy_thread() on um will do the right thing when getting 0 for sp... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28kill daemonize()Al Viro
2012-11-28microblaze: rt_sigreturn is too trigger-happy about sigaltstack errorsAl Viro
2012-11-28score: do_sigaltstack() expects a userland pointer...Al Viro
2012-11-28sh64: fix altstack switching on sigreturnAl Viro
incidentally, declaring a local variable as __user (!) to make sparse STFU is really sick. Especially since sparse had been 100% right - it *is* a bug. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28openrisk: fix altstack switching on sigreturnAl Viro
do_sigaltstack() expects _userland_ address, TYVM... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28um: get_safe_registers() should be done in flush_thread(), not start_thread()Al Viro
... or we'll end up buggering the results of ELF_PLAT_INIT() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28Merge branch 'arch-tile' into no-rebasesAl Viro
2012-11-28tile: compat rt_sigreturn gets too enthusiastic about sigaltstack errorsAl Viro
2012-11-25Linux 3.7-rc7v3.7-rc7Linus Torvalds
2012-11-25Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc EEH bugfixes from Benjamin Herrenschmidt. Two one-liner fixes for the new EEH code. * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/eeh: Do not invalidate PE properly powerpc/pseries: Fix oops with MSIs when missing EEH PEs
2012-11-25Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "Three issues fixed accross the field: - Some functions that were recently outlined as part of a preemption fix were causing problems with function tracing. - The recently merged in-kernel MPI library uses very outdated headers that contain MIPS-specific code which won't build on with gcc 4.4 or newer. - The MIPS non-NUMA memory initialization was making only a very half-baked attempt at merging adjacent memory ranges. This kept the code simple enough but is now causing issues with kexec." * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MPI: Fix compilation on MIPS with GCC 4.4 and newer MIPS: Fix crash that occurs when function tracing is enabled MIPS: Merge overlapping bootmem ranges
2012-11-26powerpc/eeh: Do not invalidate PE properlyGavin Shan
While the EEH does recovery on the specific PE that has PCI errors, the PCI devices belonging to the PE will be removed and the PE will be marked as invalid since we still need the information stored in the PE. We only invalidate the PE when it doesn't have associated EEH devices and valid child PEs. However, the code used to check that is wrong. The patch fixes that. Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-11-24Merge tag 'sound-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound build error fix from Takashi Iwai: "Only a single commit for fixing the build error without CONFIG_PM in hda driver." * tag 'sound-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - Fix build without CONFIG_PM
2012-11-24ALSA: hda - Fix build without CONFIG_PMTakashi Iwai
I forgot this again... codec->in_pm is in #ifdef CONFIG_PM Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-23Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 arch fixes from Peter Anvin: "Here is a collection of fixes for 3.7-rc7. This is a superset of tglx' earlier pull request." * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86-64: Fix ordering of CFI directives and recent ASM_CLAC additions x86, microcode, AMD: Add support for family 16h processors x86-32: Export kernel_stack_pointer() for modules x86-32: Fix invalid stack address while in softirq x86, efi: Fix processor-specific memcpy() build error x86: remove dummy long from EFI stub x86, mm: Correct vmflag test for checking VM_HUGETLB x86, amd: Disable way access filter on Piledriver CPUs x86/mce: Do not change worker's running cpu in cmci_rediscover(). x86/ce4100: Fix PCI configuration register access for devices without interrupts x86/ce4100: Fix reboot by forcing the reboot method to be KBD x86/ce4100: Fix pm_poweroff MAINTAINERS: Update email address for Robert Richter x86, microcode_amd: Change email addresses, MAINTAINERS entry MAINTAINERS: Change Boris' email address EDAC: Change Boris' email address x86, AMD: Change Boris' email address
2012-11-23Merge tag 'for-linus-20121123' of git://git.infradead.org/mtd-2.6Linus Torvalds
Pull MTD fixes from David Woodhouse: "The most important part of this is that it fixes a regression in Samsung NAND chip detection, introduced by some rework which went into 3.7. The initial fix wasn't quite complete, so it's in two parts. In fact the first part is committed twice (Artem committed his own copy of the same patch) and I've merged Artem's tree into mine which already had that fix. I'd have recommitted that to make it somewhat cleaner, but figured by this point in the release cycle it was better to merge *exactly* the commits which have been in linux-next. If I'd recommitted, I'd also omit the sparse warning fix. But it's there, and it's harmless — just marking one function as 'static' in onenand code. This also includes a couple more fixes for stable: an AB-BA deadlock in JFFS2, and an invalid range check in slram." * tag 'for-linus-20121123' of git://git.infradead.org/mtd-2.6: mtd: nand: fix Samsung SLC detection regression mtd: nand: fix Samsung SLC NAND identification regression jffs2: Fix lock acquisition order bug in jffs2_write_begin mtd: onenand: Make flexonenand_set_boundary static mtd: slram: invalid checking of absolute end address mtd: ofpart: Fix incorrect NULL check in parse_ofoldpart_partitions() mtd: nand: fix Samsung SLC NAND identification regression
2012-11-23Merge tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
Pull device tree regression fix from Grant Likely: "Simple build regression fix for DT device drivers on Sparc. An earlier change had masked out the of_iomap() helper on SPARC." * tag 'devicetree-for-linus' of git://git.secretlab.ca/git/linux-2.6: of/address: sparc: Declare of_iomap as an extern function for sparc again
2012-11-23Merge tag 'pm-for-3.7-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management update from Rafael Wysocki: "Fix for an incorrect error condition check in device PM QoS code that may lead to an Oops from Guennadi Liakhovetski." * tag 'pm-for-3.7-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / QoS: fix wrong error-checking condition
2012-11-23Merge tag 'md-3.7-fixes' of git://neil.brown.name/mdLinus Torvalds
Pull md fixes from NeilBrown: "Several bug fixes for md in 3.7: - raid5 discard has problems - raid10 replacement devices have problems - bad block lock seqlock usage has problems - dm-raid doesn't free everything" * tag 'md-3.7-fixes' of git://neil.brown.name/md: md/raid10: decrement correct pending counter when writing to replacement. md/raid10: close race that lose writes lost when replacement completes. md/raid5: Make sure we clear R5_Discard when discard is finished. md/raid5: move resolving of reconstruct_state earlier in stripe_handle. md/raid5: round discard alignment up to power of 2. md: make sure everything is freed when dm-raid stops an array. md: Avoid write invalid address if read_seqretry returned true. md: Reassigned the parameters if read_seqretry returned true in func md_is_badblock.
2012-11-23Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "Distilled down version of bug fixes for 3.7. The patches have been well tested. If you notice that commit dates are from today, it's because I pulled less important bits out and shuffled them into the 3.8 mix. Apart from that, no changes, base still the same. It contains: - Fix for aoe, don't run request_fn while it's plugged. - Fix for a regression in floppy since 3.6, which causes problems if no floppy is found. - Stable fix for blk_exec(), don't touch a request after it has been sent to the scheduler (and the device as well). - Five fixes for various nasties in mtip32xx." * 'for-linus' of git://git.kernel.dk/linux-block: block: Don't access request after it might be freed mtip32xx: Fix padding issue aoe: avoid running request handler on plugged queue mtip32xx: fix potential NULL pointer dereference in mtip_timeout_function() mtip32xx: fix shift larger than type warning mtip32xx: Fix incorrect mask used for erase mode mtip32xx: Fix to make lba address correct in big-endian systems mtip32xx: fix potential crash on SEC_ERASE_UNIT dm: fix deadlock with request based dm and queue request_fn recursion floppy: destroy floppy workqueue before cleaning up the queue
2012-11-23of/address: sparc: Declare of_iomap as an extern function for sparc againAndreas Larsson
This bug-fix makes sure that of_iomap is defined extern for sparc so that the sparc-specific implementation of_iomap is once again used when including include/linux/of_address.h in a sparc context. OF_GPIO that is now available for sparc relies on this. The bug was inadvertently introduced in a850a75, "of/address: add empty static inlines for !CONFIG_OF", that added a static dummy inline for of_iomap when !CONFIG_OF_ADDRESS. However, CONFIG_OF_ADDRESS is never defined for sparc, but there is a sparc-specific implementation /arch/sparc/kernel/of_device_common.c. This fix takes the same approach as 0bce04b that solved the equivalent problem for of_address_to_resource. Signed-off-by: Andreas Larsson <andreas@gaisler.com> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2012-11-23Merge tag 'omapdss-for-3.7-rc' of git://gitorious.org/linux-omap-dss2/linuxLinus Torvalds
Pull omapdss fixes from Tomi Valkeinen: "Here are a few OMAPDSS fixes for the next -rc. I'm sending these directly to you, and quite late, as the fbdev tree maintainer (Florian) has been busy with his work and hasn't had time to manage the fb patches." * tag 'omapdss-for-3.7-rc' of git://gitorious.org/linux-omap-dss2/linux: OMAPDSS: do not fail if dpll4_m4_ck is missing OMAPFB: Fix possible null pointer dereferencing OMAPDSS: HDMI: fix missing unlock on error in hdmi_dump_regs() omapdss: dss: Fix clocks on OMAP363x OMAPDSS: DSI: fix dsi_get_dsidev_from_id()
2012-11-23Merge branch 'i2c-embedded/for-current' of ↵Linus Torvalds
git://git.pengutronix.de/git/wsa/linux Pull i2c fixes from Wolfram Sang: "Bugfixes for the i2c subsystem. Except for a few one-liners, there is mainly one revert because of an overlooked dependency. Since there is no linux-next at the moment, I did some extra testing, and all was fine for me." * 'i2c-embedded/for-current' of git://git.pengutronix.de/git/wsa/linux: i2c: mxs: Handle i2c DMA failure properly i2c: s3c2410: Fix code to free gpios i2c: omap: ensure writes to dev->buf_len are ordered Revert "ARM: OMAP: convert I2C driver to PM QoS for MPU latency constraints" i2c: at91: fix SMBus quick command
2012-11-23Merge tag 'sound-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "The highlight of this update is the fixes for ASoC kirkwood by Russell. In addition to that, a couple of regression fixes for HD-audio due to the runtime PM support on 3.7, and other driver- specific regression fixes like USB MIDI on non-standard USB audio drivers." * tag 'sound-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: snd-usb: properly initialize the sync endpoint ALSA: hda - Cirrus: Correctly clear line_out_pins when moving to speaker ALSA: hda - Add support for Realtek ALC292 ASoC: kirkwood-i2s: more pause-mode fixes ASoC: kirkwood-i2s: fix DMA underruns ASoC: kirkwood-i2s: fix DCO lock detection ASoC: kirkwood-dma: don't ignore other irq causes on error ASoC: kirkwood-dma: fix use of virt_to_phys() ALSA: hda - Limit runtime PM support only to known Intel chips ALSA: hda - Fix recursive suspend/resume call ALSA: ua101, usx2y: fix broken MIDI output ASoC: arizona: Fix typo - Swap value in 48k_rates[] and 44k1_rates[] ASoC: bells: Fix up git patch application failure ASoC: cs4271: free allocated GPIO
2012-11-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networkign fixes from David Miller: "Networking bug fixes, Cacio e Pepe edition: 1) BNX2X accidently accesses chip rev specific registers without an appropriate guard, fix from Ariel Elior. 2) When we removed the routing cache, we set ip_rt_max_size to ~0 just to keep reporting a value to userspace via sysfs. But the ipv4 IPSEC layer was using this to tune itself which is completely bogus to now do. Fix from Steffen Klassert. 3) Missing initialization in netfilter ipset code from Jozsef Kadlecsik. 4) Check CTA_TIMEOUT_NAME length properly in netfilter cttimeout code, fix from Florian Westphal. 5) After removing the routing cache, we inadvertantly are caching multicast routes that end up looping back locally, we cannot do that legitimately any more. Fix from Julian Anastasov. 6) Revert a race fix for 8139cp qemu/kvm that doesn't actually work properly on real hardware. From Francois Romieu. 7) Fixup errors in example command lines in VXLAN device docs." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: bnx2x: remove redundant warning log vxlan: fix command usage in its doc 8139cp: revert "set ring address before enabling receiver" ipv4: do not cache looped multicasts netfilter: cttimeout: fix buffer overflow netfilter: ipset: Fix range bug in hash:ip,port,net xfrm: Fix the gc threshold value for ipv4
2012-11-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc fix from David Miller: "Bug fix from Al Viro" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: sparc64: not any error from do_sigaltstack() should fail rt_sigreturn()
2012-11-23Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull one more ARM SoC fix from Olof Johansson: "I missed one pull request from Samsung with one fix in the previous batch. Here it is -- a dma driver fix for an early version of silicon that they still support." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: EXYNOS: PL330 MDMA1 fix for revision 0 of Exynos4210 SOC
2012-11-23PM / QoS: fix wrong error-checking conditionGuennadi Liakhovetski
dev_pm_qos_add_request() can return 0, 1, or a negative error code, therefore the correct error test is "if (error < 0)." Checking just for non-zero return code leads to erroneous setting of the req->dev pointer to NULL, which then leads to a repeated call to dev_pm_qos_add_ancestor_request() in st1232_ts_irq_handler(). This in turn leads to an Oops, when the I2C host adapter is unloaded and reloaded again because of the inconsistent state of its QoS request list. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: <stable@vger.kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-11-23bnx2x: remove redundant warning logAriel Elior
fix bug where a register which was only meant to be read in 578xx/57712 devices causes a bogus error message to be logged when read from other devices. Signed-off-by: Ariel Elior <ariele@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-23vxlan: fix command usage in its docZhi Yong Wu
Some commands don't work in its example doc. The patch will fix it. Signed-off-by: Zhi Yong Wu <wuzhy@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-238139cp: revert "set ring address before enabling receiver"françois romieu
This patch reverts b01af4579ec41f48e9b9c774e70bd6474ad210db. The original patch was tested with emulated hardware. Real hardware chokes. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=47041 Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-23MPI: Fix compilation on MIPS with GCC 4.4 and newerManuel Lauss
Since 4.4 GCC on MIPS no longer recognizes the "h" constraint, leading to this build failure: CC lib/mpi/generic_mpih-mul1.o lib/mpi/generic_mpih-mul1.c: In function 'mpihelp_mul_1': lib/mpi/generic_mpih-mul1.c:50:3: error: impossible constraint in 'asm' This patch updates MPI with the latest umul_ppm implementations for MIPS. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Cc: James Morris <jmorris@namei.org> Patchwork: https://patchwork.linux-mips.org/patch/4612/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-11-23MIPS: Fix crash that occurs when function tracing is enabledAl Cooper
A recent patch changed some irq routines from inlines to functions. These routines are called by the tracer code. Now that they're functions, if they are compiled for function tracing they will call the tracer and crash the system due to infinite recursion. The fix disables tracing in these functions by using "notrace" in the function definition. Signed-off-by: Al Cooper <alcooperx@gmail.com> Reviewed-by: David Daney <david.daney@cavium.com> Pathchwork: https://patchwork.linux-mips.org/patch/4564/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-11-23MIPS: Merge overlapping bootmem rangesRalf Baechle
Without this, we may end up with something like this in /proc/iomem: 01100000-014fffff : System RAM 01100000-013bf48f : Kernel code 013bf490-0149e01f : Kernel data 01500000-0c0fffff : System RAM but the two System RAM ranges should be one single range. This particular case will result in kexec failure on Octeon systems if the kernel being loaded by kexec is bigger than the already running kernel. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-11-23block: Don't access request after it might be freedRoland Dreier
After we've done __elv_add_request() and __blk_run_queue() in blk_execute_rq_nowait(), the request might finish and be freed immediately. Therefore checking if the type is REQ_TYPE_PM_RESUME isn't safe afterwards, because if it isn't, rq might be gone. Instead, check beforehand and stash the result in a temporary. This fixes crashes in blk_execute_rq_nowait() I get occasionally when running with lots of memory debugging options enabled -- I think this race is usually harmless because the window for rq to be reallocated is so small. Signed-off-by: Roland Dreier <roland@purestorage.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-11-23mtip32xx: Fix padding issueSelvan Mani
Hi Jens, Another tiny patch. Removed __packed before the struct smart_attr and added __packed at end of the structure to fix padding issue. Signed-off-by: Selvan Mani <smani@micron.com> Signed-off-by: Asai Thambi S P <asamymuthupa@micron.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-11-23aoe: avoid running request handler on plugged queueEd Cashin
Calling the request handler directly on a plugged queue defeats the performance improvements provided by the plugging mechanism. Use the __blk_run_queue function instead of calling the request handler directly, so that we don't interfere with the block layer's ability to plug the queue. Signed-off-by: Ed Cashin <ecashin@coraid.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-11-23mtip32xx: fix potential NULL pointer dereference in mtip_timeout_function()Wei Yongjun
The dereference to port should be moved below the NULL test. dpatch engine is used to auto generate this patch. (https://github.com/weiyj/dpatch) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Jens Axboe <axboe@kernel.dk>
