acpi_bus_get_device() returns int not acpi_status.
The patch change not to apply ACPI_FAILURE() to the return value of
acpi_bus_get_device().
Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com>
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"It turns out that we had two crc bugs when running fsx-linux in a
loop. Many thanks to Josef, Miao Xie, and Dave Sterba for nailing it
all down. Miao also has a new OOM fix in this v2 pull as well.
Ilya fixed a regression Liu Bo found in the balance ioctls for pausing
and resuming a running balance across drives.
Josef's orphan truncate patch fixes an obscure corruption we'd see
during xfstests.
Arne's patches address problems with subvolume quotas. If the user
destroys quota groups incorrectly the FS will refuse to mount.
The rest are smaller fixes and plugs for memory leaks."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (30 commits)
Btrfs: fix repeated delalloc work allocation
Btrfs: fix wrong max device number for single profile
Btrfs: fix missed transaction->aborted check
Btrfs: Add ACCESS_ONCE() to transaction->abort accesses
Btrfs: put csums on the right ordered extent
Btrfs: use right range to find checksum for compressed extents
Btrfs: fix panic when recovering tree log
Btrfs: do not allow logged extents to be merged or removed
Btrfs: fix a regression in balance usage filter
Btrfs: prevent qgroup destroy when there are still relations
Btrfs: ignore orphan qgroup relations
Btrfs: reorder locks and sanity checks in btrfs_ioctl_defrag
Btrfs: fix unlock order in btrfs_ioctl_rm_dev
Btrfs: fix unlock order in btrfs_ioctl_resize
Btrfs: fix "mutually exclusive op is running" error code
Btrfs: bring back balance pause/resume logic
btrfs: update timestamps on truncate()
btrfs: fix btrfs_cont_expand() freeing IS_ERR em
Btrfs: fix a bug when llseek for delalloc bytes behind prealloc extents
Btrfs: fix off-by-one in lseek
Pull cifs fixes from Steve French:
"Two small cifs fixes"
* 'for-next' of git://git.samba.org/sfrench/cifs-2.6:
fs/cifs/cifs_dfs_ref.c: fix potential memory leakage
cifs: fix srcip_matches() for ipv6
Pull kvm fixlet from Marcelo Tosatti.
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: PPC: Emulate dcbf
Pull ARM fixes from Russell King:
"A number of fixes:
Patrik found a problem with preempt counting in the VFP assembly
functions which can cause the preempt count to be upset.
Nicolas fixed a problem with the parsing of the DT when it straddles a
1MB boundary.
Subhash Jadavani reported a problem with sparsemem and our highmem
support for cache maintanence for DMA areas, and TI found a bug in
their strongly ordered memory mapping type.
Also, three fixes by way of Will Deacon's tree from Dave Martin for
instruction compatibility and Marc Zyngier to fix hypervisor boot mode
issues."
* 'fixes' of git://git.linaro.org/people/rmk/linux-arm:
ARM: 7629/1: mm: Fix missing XN flag for for MT_MEMORY_SO
ARM: DMA: Fix struct page iterator in dma_cache_maint() to work with sparsemem
ARM: 7628/1: head.S: map one extra section for the ATAG/DTB area
ARM: 7627/1: Predicate preempt logic on PREEMP_COUNT not PREEMPT alone
ARM: virt: simplify __hyp_stub_install epilog
ARM: virt: boot secondary CPUs through the right entry point
ARM: virt: Avoid bx instruction for compatibility with <=ARMv4
Pull ARM SoC fixes from Olof Johansson:
"Here's a long-pending fixes pull request for arm-soc (I didn't send
one in the -rc4 cycle).
The larger deltas are from:
- A fixup of error paths in the mvsdio driver
- Header file move for a driver that hadn't been properly converted
to multiplatform on i.MX, which was causing build failures when
included
- Device tree updates for at91 dealing mostly with their new pinctrl
setup merged in 3.8 and mistakes in those initial configs
The rest are the normal mix of small fixes all over the place; sunxi,
omap, imx, mvebu, etc, etc."
* tag 'fixes-for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
mfd: vexpress-sysreg: Don't skip initialization on probe
ARM: vexpress: Enable A7 cores in V2P-CA15_A7's Device Tree
ARM: vexpress: extend the MPIDR range used for pen release check
ARM: at91/dts: correct comment in at91sam9x5.dtsi for mii
ARM: at91/at91_dt_defconfig: add at91sam9n12 SoC to DT defconfig
ARM: at91/at91_dt_defconfig: remove memory specification to cmdline
ARM: at91/dts: add macb mii pinctrl config for kizbox
ARM: at91: rm9200: remake the BGA as default version
ARM: at91: fix gpios on i2c-gpio for RM9200 DT
ARM: at91/at91sam9x5 DTS: add SCK USART pins
ARM: at91/at91sam9x5 DTS: correct wrong PIO BANK values on u(s)arts
ARM: at91/at91-pinctrl documentation: fix typo and add some details
ARM: kirkwood: fix missing #interrupt-cells property
mmc: mvsdio: use devm_ API to simplify/correct error paths.
clk: mvebu/clk-cpu.c: fix memory leakage
ARM: OMAP2+: omap4-panda: add UART2 muxing for WiLink shared transport
ARM: OMAP2+: DT node Timer iteration fix
ARM: OMAP2+: Fix section warning for omap_init_ocp2scp()
ARM: OMAP2+: fix build break for omapdrm
ARM: OMAP2: Fix missing omap2xxx_clkt_vps_late_init function calls
Pull ACPI and power management fixes from Rafael Wysocki:
- Two cpuidle initialization fixes from Konrad Rzeszutek Wilk.
- cpufreq regression fixes for AMD processors from Borislav Petkov,
Stefan Bader, and Matthew Garrett.
- ACPI cpufreq fix from Thomas Schlichter.
- cpufreq and devfreq fixes related to incorrect usage of operating
performance points (OPP) framework and RCU from Nishanth Menon.
- APEI workaround for incorrect BIOS information from Lans Zhang.
* tag 'pm+acpi-for-3.8-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpufreq: Add module aliases for acpi-cpufreq
ACPI: Check MSR valid bit before using P-state frequencies
PM / devfreq: exynos4_bus: honor RCU lock usage
PM / devfreq: add locking documentation for recommended_opp
cpufreq: cpufreq-cpu0: use RCU locks around usage of OPP
cpufreq: OMAP: use RCU locks around usage of OPP
ACPI, APEI: Fixup incorrect 64-bit access width firmware bug
ACPI / processor: Get power info before updating the C-states
powernow-k8: Add a kconfig dependency on acpi-cpufreq
ACPI / cpuidle: Fix NULL pointer issues when cpuidle is disabled
intel_idle: Don't register CPU notifier if we are not running.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap fixes from Mark Brown:
"One more oversight in the debugfs code was reported and fixed, plus a
documentation fix."
* tag 'regmap-fix-3.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: fix small typo in regmap_bulk_write comment
regmap: debugfs: Fix seeking from the cache
Pull slave-dmaengine fixes from Vinod Koul:
"A few fixes on slave dmanengine. There are trivial fixes in imx-dma,
tegra-dma & ioat driver"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dma: tegra: implement flags parameters for cyclic transfer
dmaengine: imx-dma: Disable use of hw_chain to fix sg_dma transfers.
ioat: Fix DMA memory sync direction correct flag
git://git.pengutronix.de/git/wsa/linux
Pill i2c fixes from Wolfram Sang:
"Here are a few, typical driver fixes for the I2C subsystem"
* 'i2c-embedded/for-current' of git://git.pengutronix.de/git/wsa/linux:
i2c-designware: add missing MODULE_LICENSE
i2c: omap: fix draining irq handling
i2c: omap: errata i462: fix incorrect ack for arbitration lost interrupt
i2c: muxes: fix wrong use of sizeof(ptr)
i2c: sirf: register i2c_client from dt child-nodes in probe entry
i2c: mxs: Fix type of error code
i2c: mxs: Fix misuse init_completion
btrfs_start_delalloc_inodes() locks the delalloc_inodes list, fetches the
first inode, unlocks the list, triggers btrfs_alloc_delalloc_work/
btrfs_queue_worker for this inode, and then it locks the list, checks the
head of the list again. But because we don't delete the first inode that it
deals with before, it will fetch the same inode. As a result, this function
allocates a huge amount of btrfs_delalloc_work structures, and OOM happens.
Fix this problem by splice this delalloc list.
Reported-by: Alex Lyakas <alex.btrfs@zadarastorage.com>
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
The max device number of single profile is 1, not 0 (0 means 'as many as
possible'). Fix it.
Cc: Liu Bo <bo.li.liu@oracle.com>
Reviewed-by: Liu Bo <bo.li.liu@oracle.com>
First, though the current transaction->aborted check can stop the commit early
and avoid unnecessary operations, it is too early, and some transaction handles
don't end, those handles may set transaction->aborted after the check.
Second, when we commit the transaction, we will wake up some worker threads to
flush the space cache and inode cache. Those threads also allocate some transaction
handles and may set transaction->aborted if some serious error happens.
So we need more check for ->aborted when committing the transaction. Fix it.
We may access and update transaction->aborted on the different CPUs without
lock, so we need ACCESS_ONCE() wrapper to prevent the compiler from creating
unsolicited accesses and make sure we can get the right value.
I noticed a WARN_ON going off when adding csums because we were going over
the amount of csum bytes that should have been allowed for an ordered
extent. This is a leftover from when we used to hold the csums privately
for direct io, but now we use the normal ordered sum stuff so we need to
make sure and check if we've moved on to another extent so that the csums
are added to the right extent. Without this we could end up with csums for
bytenrs that don't have extents to cover them yet. Thanks,
For compressed extents, the range of checksum is covered by disk length,
and the disk length is different with ram length, so we need to use disk
length instead to get us the right checksum.
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
A user reported a BUG_ON(ret) that occured during tree log replay. Ret was
-EAGAIN, so what I think happened is that we removed an extent that covered
a bitmap entry and an extent entry. We remove the part from the bitmap and
return -EAGAIN and then search for the next piece we want to remove, which
happens to be an entire extent entry, so we just free the sucker and return.
The problem is ret is still set to -EAGAIN so we trip the BUG_ON(). The
user used btrfs-zero-log so I'm not 100% sure this is what happened so I've
added a WARN_ON() to catch the other possibility. Thanks,
Reported-by: Jan Steffens <jan.steffens@gmail.com>
We drop the extent map tree lock while we're logging extents, so somebody
could come in and merge another extent into this one and screw up our
logging, or they could even remove us from the list which would keep us from
logging the extent or freeing our ref on it, so we need to make sure to not
clear LOGGING until after the extent is logged, and then we can merge it to
adjacent extents. Thanks,
into fixes
From Pawel Moll:
- makes the V2P-CA15_A7 (a.k.a. TC2) work with 3.8 kernels
- improves vexpress-sysreg.c behaviour on arm64 platforms
* 'vexpress/fixes' of git://git.linaro.org/people/pawelmoll/linux:
From Nicolas Ferre:
Here are fixes for AT91 that are mainly related to device tree.
One RM9200 setup option is the only C code change.
Some documentation changes can clarify the pinctrl use.
Then, some defconfig modifications are allowing the affected platforms
to boot.
* tag 'at91-fixes' of git://github.com/at91linux/linux-at91:
The vexpress-sysreg driver does not have to be initialized
early, when the platform doesn't require this. Unfortunately
in such case it wasn't initialized correctly - master site
lookup and config bridge registration were missing. Fixed now.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
As the kernel is able to cope with multiple clusters,
uncomment the A7 cores in the Device Tree for V2P-CA15_A7
tile, making all 5 cores available to the user.
In ARM multi-cluster systems the MPIDR affinity level 0 cannot be used as a
single cpu identifier, affinity levels 1 and 2 must be taken into account as
well.
This patch extends the MPIDR usage to affinity levels 1 and 2 in versatile
secondary cores start up code in order to compare the passed pen_release
value with the full-blown affinity mask.
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Liviu Dudau <liviu.dudau@arm.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
git://git.linaro.org/people/shawnguo/linux-2.6 into fixes
From Shawn Guo:
This is yet another critical imxfb fixes held off by absence of FB
maintainer for some time.
* tag 'imx-fixes-3.8-3' of git://git.linaro.org/people/shawnguo/linux-2.6:
video: imxfb: Do not crash on reboot
git://git.infradead.org/users/jcooper/linux into fixes
From Jason Cooper:
mvebu fixes for v3.8-rc5
- fix memory leak in mvebu/clk-cpu.c
- use devm_ to correct/simplify error paths in mvsdio
- add missing #interrupt-cells property in kirkwood
* tag 'mvebu_fixes_for_v3.8-rc5' of git://git.infradead.org/users/jcooper/linux:
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull more USB fixes from Greg Kroah-Hartman:
"Here are some more USB fixes for the 3.8-rc4 tree.
Some gadget driver fixes, and finally resolved the ehci-mxc driver
build issues (it's just some code moving around and being deleted)."
* tag 'usb-3.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
USB: EHCI: fix build error in ehci-mxc
USB: EHCI: add a name for the platform-private field
USB: EHCI: fix incorrect configuration test
USB: EHCI: Move definition of EHCI_STATS to ehci.h
USB: UHCI: fix IRQ race during initialization
usb: gadget: FunctionFS: Fix missing braces in parse_opts
usb: dwc3: gadget: fix ep->maxburst for ep0
ARM: i.MX clock: Change the connection-id for fsl-usb2-udc
usb: gadget: fsl_mxc_udc: replace MX35_IO_ADDRESS to ioremap
usb: gadget: fsl-mxc-udc: replace cpu_is_xxx() with platform_device_id
usb: musb: cppi_dma: drop '__init' annotation
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull drivers/misc fix from Greg Kroah-Hartman:
"Here is a single revert for the ti-st misc driver, fixing problem that
was introduced in 3.7-rc1 that has been bothering people."
* tag 'char-misc-3.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc:
Revert "drivers/misc/ti-st: remove gpio handling"
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull a TTY maintainer patch from Greg Kroah-Hartman:
"Just a MAINTAINERS update, now that Alan has left for a bit, I'll
continue to watch over the serial drivers."
* tag 'tty-3.8-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty:
MAINTAINERS: Someone needs to watch over the serial drivers
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
- gspca: add needed delay for I2C traffic for sonixb/sonixj cameras
- gspca: add one missing Kinect USB ID
- usbvideo: some regression fixes
- omap3isp: fix some build issues
- videobuf2: fix video output handling
- exynos s5p/m5mols: a few regression fixes.
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] uvcvideo: Set error_idx properly for S_EXT_CTRLS failures
[media] uvcvideo: Cleanup leftovers of partial revert
[media] uvcvideo: Return -EACCES when trying to set a read-only control
[media] omap3isp: Don't include <plat/cpu.h>
[media] s5p-mfc: Fix interrupt error handling routine
[media] s5p-fimc: Fix return value of __fimc_md_create_flite_source_links()
[media] m5mols: Fix typo in get_fmt callback
[media] v4l: vb2: Set data_offset to 0 for single-plane output buffers
[media] [FOR,v3.8] omap3isp: Don't include deleted OMAP plat/ header files
[media] gspca_sonixj: Add a small delay after i2c_w1
[media] gspca_sonixb: Properly wait between i2c writes
[media] gspca_kinect: add Kinect for Windows USB id
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull m68k fixes from Geert Uytterhoeven:
"The asm-generic changeset has been ack'ed by Arnd."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k: Wire up finit_module
asm-generic/dma-mapping-broken.h: Provide dma_alloc_attrs()/dma_free_attrs()
m68k: Provide dma_alloc_attrs()/dma_free_attrs()
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64
Pull arm64 fixes from Catalin Marinas:
- ELF coredump fix (more registers dumped than what user space expects)
- SUBARCH name generation (s/aarch64/arm64/)
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64:
arm64: makefile: fix uname munging when setting ARCH on native machine
arm64: elf: fix core dumping to match what glibc expects
This patch (as1643b) fixes a build error in ehci-hcd when compiling for
ARM with allmodconfig:
drivers/usb/host/ehci-hcd.c:1285:0: warning: "PLATFORM_DRIVER" redefined [enabled by default]
drivers/usb/host/ehci-hcd.c:1255:0: note: this is the location of the previous definition
drivers/usb/host/ehci-mxc.c:280:31: warning: 'ehci_mxc_driver' defined but not used [-Wunused-variable]
The fix is to convert ehci-mxc over to the new "ehci-hcd is a library"
scheme so that it can coexist peacefully with the ehci-platform
driver. As part of the conversion the ehci_mxc_priv data structure,
which was allocated dynamically, is now placed where it belongs: in
the private area at the end of struct ehci_hcd.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound fixes from Takashi Iwai:
"Only a few small HD-audio fixes:
- Addition of new Conexant codec IDs
- Two one-liners to add fixups for Realtek codecs
- A last-minute regression fix for auto-mute with power-saving mode
(regressed since 3.8-rc1)"
* tag 'sound-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound:
ALSA: hda - Fix inconsistent pin states after resume
ALSA: hda - Add Conexant CX20755/20756/20757 codec IDs
ALSA: hda - Add fixup for Acer AO725 laptop
ALSA: hda - Fix mute led for another HP machine
Signed-off-by: Alan Cox <alan@linux.intel.com>
The commit [26a6cb6c: ALSA: hda - Implement a poll loop for jacks as a
module parameter] introduced the polling jack detection code, but it
also moved the call of snd_hda_jack_set_dirty_all() in the resume path
after resume/init ops call. This caused a regression when the jack
state has been changed during power-down (e.g. in the power save
mode). Since the driver doesn't probe the new jack state but keeps
using the cached value due to no dirty flag, the pin state remains
also as if the jack is still plugged.
The fix is simply moving snd_hda_jack_set_dirty_all() to the original
position.
Reported-by: Manolo Díaz <diaz.manolo@gmail.com>
Concerning pinctrl_macb0_rmii_mii, values were okay, but not comments.
Signed-off-by: Douglas Gilbert <dgilbert@interlog.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Reported-by: Josh Wu <josh.wu@atmel.com>
No need for this cmdline option as we are using DT.
Moreover this defconfig is targeted to multiple SoC/boards: this option
was nonsense.
This patch overrides default macb pinctrl config defined in
at91sam9260.dtsi (pinctrl_macb_rmii) with kizbox board config
(pinctrl_macb_rmii + pinctrl_macb_rmii_mii_alt).
Signed-off-by: Boris BREZILLON <linux-arm@overkiz.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Make BGA as the default version as we are supposed to just have
to specify when we use the PQFP version.
Issue was existing since commit:
3e90772 (ARM: at91: fix at91rm9200 soc subtype handling).
Cc: stable <stable@vger.kernel.org> [v3.3]
Signed-off-by: Joachim Eastwood <manabian@gmail.com>
The SCK pins where missing in usarts pinctrl.
Signed-off-by: Richard Genoud <richard.genoud@gmail.com>
The PIN_BANK 3 is for PDxx pins, not PCxx pins.
And PIN_BANK 1 is for PBxx, not PIN_BANK 0.
The relation between PIN_BANK numbers and pio letters wasn't made very
clear.
When it goes to error through line 144, the memory allocated to *devname is
not freed, and the caller doesn't free it either in line 250. So we free the
memroy of *devname in function cifs_compose_mount_options() when it goes to
error.
Signed-off-by: Cong Ding <dinggnu@gmail.com>
CC: stable <stable@kernel.org>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <smfrench@gmail.com>
This reverts commit eccf2979b2c034b516e01b8a104c3739f7ef07d1.
The reason is that it broke TI WiLink shared transport on Panda.
Also, callback functions should not be added to board files anymore,
so revert to implementing the power functions in the driver itself.
Additionally, changed a variable name ('status' to 'err') so that this
revert compiles properly.
Cc: stable <stable@vger.kernel.org> [3.7]
Signed-off-by: Luciano Coelho <coelho@ti.com>
