This patch removes an unused parameter (addr_len) from tcp_recv_urg()
method in net/ipv4/tcp.c.
Signed-off-by: Rami Rosen <ramirose@gmail.com>
Fix the behavior of allowing both sysctl and addrconf_dad_failure()
to set the disable_ipv6 parameter without any bad side-effects.
If DAD fails and accept_dad > 1, we will still set disable_ipv6=1,
but then instead of allowing an RA to add an address then
immediately fail DAD, we simply don't allow the address to be
added in the first place. This also lets the user set this flag
and disable all IPv6 addresses on the interface, or on the entire
system.
Signed-off-by: Brian Haley <brian.haley@hp.com>
Remove unnecessary check (skb_padto does the same check)
Remove unnecessary duplicate variable
Remove unnecessary clearing of padded part of skb.
Signed-off-by: Dave Jones <davej@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
drivers/net/igb/igb_main.c
drivers/net/qlge/qlge_main.c
drivers/net/wireless/ath9k/ath9k.h
drivers/net/wireless/ath9k/core.h
drivers/net/wireless/ath9k/hw.c
Fix following warnings, by using integer firmware types.
drivers/net/netxen/netxen_nic_hw.c: In function 'netxen_load_firmware':
drivers/net/netxen/netxen_nic_hw.c:1146: warning: comparison with string literal results in unspecified behavior
drivers/net/netxen/netxen_nic_hw.c:1159: warning: comparison with string literal results in unspecified behavior
Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
On the legacy netif_rx path, I incorrectly tried to optimise
the napi_complete call by using __napi_complete before we reenable
IRQs. This simply doesn't work since we need to flush the held
GRO packets first.
This patch fixes it by doing the obvious thing of reenabling
IRQs first and then calling napi_complete.
Reported-by: Frank Blaschka <blaschka@linux.vnet.ibm.com>
Jarek Poplawski pointed out that my previous fix is broken for
VLAN+netpoll as if netpoll is enabled we'd end up in the normal
receive path instead of the VLAN receive path.
This patch fixes it by calling the VLAN receive hook.
user needs to see this message even if debugging disabled
Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
hopefully the register contents will guide us to why this failure occured
iwl_clear_station_table will be called every time rxon called.
In this function ucode_key_table is set to 0 even though a static
WEP security is set. This will cause in many warning and might be
an issue if dynamic WEP is set. This patch make sure we keep track
of all existing static WEP when this function is called.
Signed-off-by: Mohamed Abbas <mohamed.abbas@intel.com>
During preparation of TX we create DMA mapping to TX command as part of
preparing the TFD. This mapping needs to be cleared at the time TFD is
freed.
iwl3945 uses iwl_tx_cmd_complete to reclaim the unused buffers of the queue.
iwl_tx_cmd_complete in turn call the iwl_hcmd_queue_reclaim which will
unmap the dma mapping to tx_cmd and frees the memory.
Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com>
Patch fixes the bug 1900 at
http://www.intellinuxwireless.org/bugzilla/show_bug.cgi?id=1900
Issues:
Throughput and success ratio calculations were not done properly.
Number of retries were exceeding 16.
Fix:
Patch fixes above issues by doing window calculations inline with iwlwifi
Patch adds sanity check to limit number of retries to 16.
Acked-by: Mohamed Abbas <mohamed.abbas@intel.com>
3945 can now use iwl_led's structure from iwlwifi.
Patch also removes CONFIG_IWL3945_LEDS flag from Kconfig as 3945's led
support will now be enabled if user selects CONFIG_IWLWIFI_LEDS.
error is:
iwl3945-base.c:545:5: warning: symbol 'iwl3945_set_dynamic_key' was not
declared. Should it be static?
When iwlwifi driver receive fixed rate debugfs command, validate the
antenna selection, if the selection is invalid, report the valid antenna
choice and do not set the rate scale table to fixed rate. Otherwise, set
the entire rate scale table to the fixed rate request by the user. this
validation can prevent sysassert happen in uCode
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
when perform rate scaling, in tx status function, checking for
IEEE80211_TX_STAT_AMPDU flag instead of IEEE_TX_CTL_AMPDU flag to perform
AMPDU rate scaling operation.
IEEE80211_TX_CTL_AMPDU was set by mac80211 for aggregation pkt. But when
iwlwifi receive the tx status reply, it reset the flag to following
info->flags = IEEE80211_TX_STAT_ACK;
info->flags |= IEEE80211_TX_STAT_AMPDU;
it causes the rate-scaling to not work for aggregation pkt if we checking
for IEEE80211_TX_CTL_AMPDU flag.
During rate scaling, checking for 0 retry count before decrement
the count by 1, this can avoid the retry count to become 255 (0xff),
which will cause the rate to drop faster than what we expect during good
condition (receive 0 retry packet). also change the algorithm to make
the rate not drop faster than what we like.
After the MLME handshaking complete and tx aggregation started for the
tid. Do not send unnecessary turn on aggregation request to mac80211.
Adding more Radio information when displaying
rate_scale_table. This can help to understand how many antenna and the
current RF condition such as SISO, MIMO2, MIMO3.
when display rate_scale_table debugfs information, also display valid tx
antenna information, this will help user to select correct antenna when
issue fixed rate debugfs command
Acked-by: Ben Cahill <ben.m.cahill@intel.com>
Before: 1099 errors, 93 warnings, 2854 lines checked
After: 19 errors, 47 warnings, 2976 lines checked
The big bulk of this is code indent and over 80 character lines
(Lindent did this part) Other changes are foo * bar spacing, and
trailing whitespace.
v2: Cleans up ill-indented comments. Subsequently, this reduces the
number of warnings, too. Thanks to Joe Perches for pointing this out!
v3: Ran the whole file through Lindent first... which does most of
the work for me. :) Again, thanks to Joe Perches for this.
This is my final answer!
Signed-off-by: John Daiker <daikerjohn@gmail.com>
Add a driver for Marvell 88w8xxx TOPDOG PCI/PCIe wireless parts.
This initial version supports the 88w8687 802.11b/g PCIe part on
channels 1-11, and only STA mode is currently implemented.
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
We must not disable ACK sending in this case since it would break
normal station operations. In addition, clarify the comment about AP
mode to make more sense.
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
Signed-off-by: Sujith <Sujith.Manoharan@atheros.com>
This fixes the sparse complaints:
drivers/net/wireless/ath9k/eeprom.c:1407:5: warning: symbol
'ath9k_hw_4k_get_spur_channel' was not declared. Should it be static?
drivers/net/wireless/ath9k/eeprom.c:1436:19: warning: symbol
'eep_4k_ops' was not declared. Should it be static?
drivers/net/wireless/ath9k/eeprom.c:2808:5: warning: symbol
'ath9k_hw_def_get_spur_channel' was not declared. Should it be static?
drivers/net/wireless/ath9k/eeprom.c:2837:19: warning: symbol
'eep_def_ops' was not declared. Should it be static?
CC [M] drivers/net/wireless/ath9k/eeprom.o
CHECK drivers/net/wireless/ath9k/mac.c
CC [M] drivers/net/wireless/ath9k/mac.o
CHECK drivers/net/wireless/ath9k/calib.c
drivers/net/wireless/ath9k/calib.c:883:6: warning: symbol 'ar9285_clc'
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
This is not a fatal message, hitting it simply means we're
going to tell the upper layers to slow their horses down but
as we make more descriptors available we let the show continue
by waking up the queues in ath_wake_mac80211_queue().
We downgrade this as otherwise we fill up your kernel log with
messages which can be common under heavy traffic.
Cc: stable@kernel.org
This adds a module parameter for mac80211_hwsim regulatory testing.
This module parameter is designed specifically to help test the
different possible types of driver specific regulatory requests
and also helps to test world roaming, all without any hardware.
If you want to just simply test different alpha2s just use the userspace
regulatory request as this won't buy you anything new.
This allows us to send to userspace "regulatory" events.
For now we just send an event when we change regulatory domains.
We also notify userspace when devices are using their own custom
world roaming regulatory domains.
We do this so we can later inform userspace who set the
regulatory domain and provide details of the request.
This is not used as we can always just assume the first
regulatory domain set will _always_ be a static regulatory
domain. REGDOM_SET_BY_CORE will be the first request from
cfg80211 for a regdomain and that then populates the first
regulatory request.
Even after commit "mac80211: deauth when interface is marked down"
(e327b847 on Linus tree), userspace still isn't notified when interface
goes down. There isn't a problem with this commit, but because of other
code changes it doesn't work on kernels >= 2.6.28 (works if same/similar
change applied on 2.6.27 for example).
The issue is as follows: after commit "mac80211: restructure disassoc/deauth
flows" in 2.6.28, the call to ieee80211_sta_deauthenticate added by
commit e327b847 will not work: because we do sta_info_flush(local, sdata)
inside ieee80211_stop (iface.c), all stations in interface are cleared, so
when calling ieee80211_sta_deauthenticate->ieee80211_set_disassoc (mlme.c),
inside ieee80211_set_disassoc we have this in the beginning:
sta = sta_info_get(local, ifsta->bssid);
if (!sta) {
The !sta check triggers, thus the function returns early and
ieee80211_sta_send_apinfo(sdata, ifsta) later isn't called, so
wpa_supplicant/userspace isn't notified with SIOCGIWAP.
This commit moves deauthentication to before flushing STA info
(sta_info_flush), thus the above can't happen and userspace is really
notified when interface goes down.
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
If cfg80211 requests a scan it awaits either a return code != 0 from
the scan function or the cfg80211_scan_done to be called. In case of
a STA mac80211's scan function ever returns 0 and queues the scan request.
If ieee80211_sta_work is executed and ieee80211_start_scan fails for
some reason cfg80211_scan_done will never be called but cfg80211 still
thinks the scan was triggered successfully and will refuse any future
scan requests due to drv->scan_req not being cleaned up.
If a scan is triggered from within the MLME a similar problem appears. If
ieee80211_start_scan returns an error, local->scan_req will not be reset
and mac80211 will refuse any future scan requests.
Hence, in both cases call ieee80211_scan_failed (which notifies cfg80211
and resets local->scan_req) if ieee80211_start_scan returns an error.
Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com>
Before: 881 errors, 265 warnings, 4507 lines checked
After: 114 errors, 273 warnings, 4548 lines checked
This was mostly "space required after that ',' (ctx:VxV)".
Also a fair number of whitespace, code indent, and C99 comment cleanups.
New warnings introduced are all "line over 80 character"
md5sums are identical, as I skipped any fixes which may have altered the resulting binary.
The rate table would not have been chosen before the interface
has been brought up. Reading 'rcstat' in this case would result
in an oops, fix this.
mac80211 expects the driver to fill in the starting
sequence number of an ADDBA request to initiate TX aggregation.
IEEE80211_TX_CTL_AMPDU would be set for frames only after a
successful ADDBA exchange, but we have to increment the
internal sequence counter for the normal(non-AMPDU) data frames proerly.
ANI was not being initialized correctly for all HW variants.
This patch fixes it.
This patch adds support for Acer Ferrari 5000, and also specifies
the subsystem device ids for previously reported e-machines e510 and
Acer Aspire One A150.
Signed-off-by: Bob Copeland <me@bobcopeland.com>
Put the device id-to-gpio mapping in a table to make it easier to add
new devices. The list of supported devices is unchanged.
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Move LED code out of base.c for clarity.
Changes-licensed-under: 3-Clause-BSD
Do not touch mac parameter passed to ath5k_eeprom_read_mac unless
we are sure we have correct address. I.e. when returning error, do
not change it.
While at it, use '= {}' compiler trick for memsetting mac_d.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Acked-by: Nick Kossifidis <mickflemm@gmail.com>
Cc: Luis R. Rodriguez <lrodriguez@atheros.com>
Acked-by: Bob Copeland <me@bobcopeland.com>
Make some structures const to place them in .rodata, since we won't
change them.
Most important parts of objdump -h:
- 0 .text 00011170
+ 0 .text 00011140
- 5 .rodata 0000828e
+ 5 .rodata 0000895e
- 13 .data 00000560
+ 13 .data 00000110
- 14 .devinit.data 00000260
Cc: Bob Copeland <me@bobcopeland.com>
device name was changed from 100 to 1000
Signed-off-by: Jay Sternberg <jay.e.sternberg@linux.intel.com>
Add check for new association to ease reading.
Passing frames with a bad FCS to the user is an optional feature.
However it doesn't work reliable and strangely not in the native monitor mode?!
Signed-off-by: Christian Lamparter <chunkeey@web.de>
Hopefully nothing controversial here, since the driver hasn't been touched in a while!
Before: 36 errors, 6 warnings, 482 lines checked
After: 0 errors, 3 warnings, 485 lines checked
This was nearly all trailing whitespace, * and parenthesis spacing, and code indent changes.
md5sum of object file before and after are identical.
This patch improves range and connection stability in AR9285.
Signed-off-by: Vasanthakumar Thiagarajan <vasanth@atheros.com>
