Now that we are doing the locking correctly, we need to grab the
i_completed_io_lock() twice per end_io. We can clean this up by
removing the structure from the i_complted_io_list, and use this as
the locking mechanism to prevent ext4_flush_completed_IO() racing
against ext4_end_io_work(), instead of clearing the
EXT4_IO_END_UNWRITTEN in io->flag.
In addition, if the ext4_convert_unwritten_extents() returns an error,
we no longer keep the end_io structure on the linked list. This
doesn't help, because it tends to lock up the file system and wedges
the system. That's one way to call attention to the problem, but it
doesn't help the overall robustness of the system.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
The usage of waitqueue_active() is not necessary, and introduces (I
believe) a hard-to-hit race.
We must hold i_completed_io_lock when manipulating anything on the
i_completed_io_list linked list. This includes io->lock, which we
were checking in ext4_end_io_nolock().
So move this check to ext4_end_io_work(). This also has the bonus of
avoiding extra work if it is already done without needing to take the
mutex.
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
Ceph users reported that when using Ceph on ext4, the filesystem
would often become corrupted, containing inodes with incorrect
i_blocks counters.
I managed to reproduce this with a very hacked-up "streamtest"
binary from the Ceph tree.
Ceph is doing a lot of xattr writes, to out-of-inode blocks.
There is also another thread which does sync_file_range and close,
of the same files. The problem appears to happen due to this race:
sync/flush thread xattr-set thread
do_writepages ext4_xattr_set
ext4_da_writepages ext4_xattr_set_handle
mpage_da_map_blocks ext4_xattr_block_set
set DELALLOC_RESERVE
ext4_new_meta_blocks
ext4_mb_new_blocks
if (!i_delalloc_reserved_flag)
vfs_dq_alloc_block
ext4_get_blocks
down_write(i_data_sem)
set i_delalloc_reserved_flag
up_write(i_data_sem)
if (i_delalloc_reserved_flag)
vfs_dq_alloc_block_nofail
In other words, the sync/flush thread pops in and sets
i_delalloc_reserved_flag on the inode, which makes the xattr thread
think that it's in a delalloc path in ext4_new_meta_blocks(),
and add the block for a second time, after already having added
it once in the !i_delalloc_reserved_flag case in ext4_mb_new_blocks
The real problem is that we shouldn't be using the DELALLOC_RESERVED
state flag, and instead we should be passing
EXT4_GET_BLOCKS_DELALLOC_RESERVE down to ext4_map_blocks() instead of
using an inode state flag. We'll fix this for now with using
i_data_sem to prevent this race, but this is really not the right way
to fix things.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Cc: stable@kernel.org
When ext4_ext_map_blocks() is called by punch_hole, trace should
trace blocks punched out.
Signed-off-by: Yongqiang Yang <xiaoqiangnk@gmail.com>
The tmp_inode should have same uid/gid as the original inode.
Otherwise new metadata blocks will be accounted to wrong quota-id,
which will result in a quota leak after the inode migration is
completed.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
This patch cleanup code a bit, actual logic not changed
- Move current block pointer to migrate_structure, let's all
walk info will be in one structure.
- Get rid of usless null ind-block ptr checks, caller already
does that check.
Rearrange the fields in struct inode so that on an x86_64 system,
fields that require 8-byte alignment don't end up causing 4-byte holes
in the structure. It reduces the size of struct inode from 568 bytes
to 552 bytes.
Also move the fields protected by i_lock (i_blocks, i_bytes, and
i_size) into the same cache line as i_lock.
ext4_ext_insert_extent() (respectively ext4_ext_insert_index())
was using EXT_MAX_EXTENT() (resp. EXT_MAX_INDEX()) to determine
how many entries needed to be moved beyond the insertion point.
In practice this means that (320 - I) * 24 bytes were memmove()'d
when I is the insertion point, rather than (#entries - I) * 24 bytes.
This patch uses EXT_LAST_EXTENT() (resp. EXT_LAST_INDEX()) instead
to only move existing entries. The code flow is also simplified
slightly to highlight similarities and reduce code duplication in
the insertion logic.
This patch reduces system CPU consumption by over 25% on a 4kB
synchronous append DIO write workload when used with the
pre-2.6.39 x86_64 memmove() implementation. With the much faster
2.6.39 memmove() implementation we still see a decrease in
system CPU usage between 2% and 7%.
Note that the ext_debug() output changes with this patch, splitting
some log information between entries. Users of the ext_debug() output
should note that the "move %d" units changed from reporting the number
of bytes moved to reporting the number of entries moved.
Signed-off-by: Eric Gouriou <egouriou@google.com>
This patch introduces a fast path in ext4_ext_convert_to_initialized()
for the case when the conversion can be performed by transferring
the newly initialized blocks from the uninitialized extent into
an adjacent initialized extent. Doing so removes the expensive
invocations of memmove() which occur during extent insertion and
the subsequent merge.
In practice this should be the common case for clients performing
append writes into files pre-allocated via
fallocate(FALLOC_FL_KEEP_SIZE). In such a workload performed via
direct IO and when using a suboptimal implementation of memmove()
(x86_64 prior to the 2.6.39 rewrite), this patch reduces kernel CPU
consumption by 32%.
Two new trace points are added to ext4_ext_convert_to_initialized()
to offer visibility into its operations. No exit trace point has
been added due to the multiplicity of return points. This can be
revisited once the upstream cleanup is backported.
The state bits and the lock functions of jbd and jbd2 are
identical. Share them.
Fix build error when CONFIG_BUG is not enabled:
fs/jbd2/transaction.c:1175:3: error: implicit declaration of function '__WARN'
by changing __WARN() to WARN_ON(), as suggested by
Arnaud Lacombe <lacombar@gmail.com>.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Cc: Arnaud Lacombe <lacombar@gmail.com>
When we want to convert the unitialized extent in direct write, we can
either do it in ext4_end_io_nolock(AIO case) or in
ext4_ext_direct_IO(non AIO case) and EXT4_I(inode)->cur_aio_dio is a
guard for ext4_ext_map_blocks to find the right case. In e9e3bcecf,
we mistakenly change it by:
- if (io)
+ if (io && !(io->flag & EXT4_IO_END_UNWRITTEN)) {
io->flag = EXT4_IO_END_UNWRITTEN;
- else
+ atomic_inc(&EXT4_I(inode)->i_aiodio_unwritten);
+ } else
ext4_set_inode_state(inode,
EXT4_STATE_DIO_UNWRITTEN);
So now if we map 2 blocks, and the first one set the
EXT_IO_END_UNWRITTEN, the 2nd mapping will set inode state because of
the check for the flag. This is wrong.
Cc: Eric Sandeen <sandeen@redhat.com>
The comment says the bit should be 0, but the after code assert the
bit to be 1. This makes people confused, so fix it.
Signed-off-by: Robin Dong <sanbai@taobao.com>
The variable 'ord' in function mb_find_extent() is redundant, so
remove it.
The variable 'count' in function ext4_mb_generate_from_pa() looks
useless, so remove it.
The kernel will crash on
ext4_mb_mark_diskspace_used:
BUG_ON(ac->ac_b_ex.fe_len <= 0);
after we set /sys/fs/ext4/sda/mb_group_prealloc to zero and create new files in an ext4 filesystem.
The reason is: ac_b_ex.fe_len also set to zero(mb_group_prealloc) in ext4_mb_normalize_group_request
because the ac_flags contains EXT4_MB_HINT_GROUP_ALLOC.
I think when someone set mb_group_prealloc to zero, it means DO NOT USE GROUP PREALLOCATION,
so we should set alloc-strategy to STREAM in this case.
The started journal handle should be stopped in failure case.
Acked-by: Jan Kara <jack@suse.cz>
In ext4_ext_next_allocated_block(), the path[depth] might
have a p_ext that is NULL -- see ext4_ext_binsearch(). In
such a case, dereferencing it will crash the machine.
This patch checks for p_ext == NULL in
ext4_ext_next_allocated_block() before dereferencinging it.
Tested using a hand-crafted an inode with eh_entries == 0 in
an extent block, verified that running FIEMAP on it crashes
without this patch, works fine with it.
Signed-off-by: Curt Wohlgemuth <curtw@google.com>
When allocated is unsigned it breaks the error handling at the end
of the function when we call:
allocated = ext4_split_extent(...);
if (allocated < 0)
err = allocated;
I've made it a signed int instead of unsigned.
ext4_mark_iloc_dirty() says:
* The caller must have previously called ext4_reserve_inode_write().
* Give this, we know that the caller already has write access to iloc->bh.
ext4_xattr_set_handle, however, just open-codes it. May as well use
the helper function for consistency.
No bug here, just tidiness.
(Note: on cleanup path, ext4_reserve_inode_write sets
the bh to NULL if it returns an error, and brelse() of
a null bh is handled gracefully).
If a directory with more than EXT4_LINK_MAX subdirectories, the nlink
count is set to 1. Subsequently, if any subdirectories are deleted,
ext4_dec_count() decrements the i_nlink count, which may go to 0
temporarily before being incremented back to 1.
While this is done under i_mutex, which prevents races for directory
and inode operations that check i_nlink, the temporary i_nlink == 0
case is exposed to userspace via stat() and similar calls that do not
hold i_mutex.
Instead, change the code to not decrement i_nlink count for any
directories that do not already have i_nlink larger than 2.
Reported-by: Cliff White <cliffw@whamcloud.com>
Reviewed-by: Johann Lombardi <johann@whamcloud.com>
Signed-off-by: Andreas Dilger <adilger@whamcloud.com>
In ext4_file_open, the filesystem records the mountpoint of the first
file that is opened after mounting the filesystem. It does this by
allocating a 64-byte stack buffer, calling d_path() to grab the mount
point through which this file was accessed, and then memcpy()ing 64
bytes into the superblock's s_last_mounted field, starting from the
return value of d_path(), which is stored as "cp". However, if cp >
buf (which it frequently is since path components are prepended
starting at the end of buf) then we can end up copying stack data into
the superblock.
Writing stack variables into the superblock doesn't sound like a great
idea, so use strlcpy instead. Andi Kleen suggested using strlcpy
instead of strncpy.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
EOFBLOCK_FL should be updated if called w/o FALLOCATE_FL_KEEP_SIZE
Currently it happens only if new extent was allocated.
TESTCASE:
fallocate test_file -n -l4096
fallocate test_file -l4096
Last fallocate cmd has updated size, but keept EOFBLOCK_FL set. And
fsck will complain about that.
Also remove ping pong in ext4_fallocate() in case of new extents,
where ext4_ext_map_blocks() clear EOFBLOCKS bit, and later
ext4_falloc_update_inode() restore it again.
- Both callers(truncate and punch_hole) already aligned left end point
so we no longer need split logic here.
- Remove dead duplicated code.
- Call ext4_ext_dirty only after we have updated eh_entries, otherwise
we'll loose entries update. Regression caused by d583fb87a3ff0
266'th testcase in xfstests (http://patchwork.ozlabs.org/patch/120872)
Currently code make an impression what grow procedure is very complicated
and some mythical paths, blocks are involved. But in fact grow in depth
it relatively simple procedure:
1) Just create new meta block and copy root data to that block.
2) Convert root from extent to index if old depth == 0
3) Update root block pointer
This patch does:
- Reorganize code to make it more self explanatory
- Do not pass path parameter to new_meta_block() in order to
provoke allocation from inode's group because top-level block
should site closer to it's inode, but not to leaf data block.
[ This happens anyway, due to logic in mballoc; we should drop
the path parameter from new_meta_block() entirely. -- tytso ]
Quota file is fs's metadata, so it is reasonable to permit use
root resevation if necessary. This patch fix 265'th xfstest failure
If ext4_jbd2_file_inode() in mpage_da_map_and_submit() fails due to
journal abort, this function returns to caller without unlocking the
page. It leads to the deadlock, and the patch fixes this issue by
calling mpage_da_submit_io().
Signed-off-by: Kazuya Mio <k-mio@sx.jp.nec.com>
If ext4_jbd2_file_inode() in ext4_ordered_write_end() fails for some
reasons, this function returns to caller without unlocking the page.
It leads to the deadlock, and the patch fixes this issue.
Signed-off-by: Akira Fujita <a-fujita@rs.jp.nec.com>
The third parameter to ext4_free_blocks is a struct buffer_head *. This
parameter should be NULL not 0.
This quiets the sparse noise:
warning: Using plain integer as NULL pointer
warning: incorrect type in argument 2 (different address spaces)
expected void const [noderef] <asn:1>*from
got struct fstrim_range *<noident>
warning: incorrect type in argument 1 (different address spaces)
expected void [noderef] <asn:1>*to
The function declarations in ext4.h are already marked extern, so it's
not necessary to do so in the .c files.
warning: function 'ext4_flush_completed_IO' with external linkage has definition
warning: function 'ext4_init_inode_table' with external linkage has definition
Add block plug for ext4 .writepages. Though ext4 .writepages
already handles request merge very well, block plug is still
helpful to reduce block lock contention.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
As part of startup, the MMP initialization code does this:
mmp->mmp_seq = seq = cpu_to_le32(mmp_new_seq());
Next, mmp->mmp_seq is written out to disk, a delay happens, and then
the MMP block is read back in and the sequence value is tested:
if (seq != le32_to_cpu(mmp->mmp_seq)) {
/* fail the mount */
On a LE system such as x86, the *le32* functions do nothing and this
works. Unfortunately, on a BE system such as ppc64, this comparison
becomes:
if (cpu_to_le32(new_seq) != le32_to_cpu(cpu_to_le32(new_seq)) {
Except for a few palindromic sequence numbers, this test always causes
the mount to fail, which makes MMP filesystems generally unmountable
on ppc64. The attached patch fixes this situation.
Current logic would print an error message only once, and then
'failed_writes' would stay at 1. Rework the loop to increment
'failed_writes' and print the error message every
s_mmp_update_interval * 60 seconds, as intended according to the
comment.
Signed-off-by: Nikitas Angelinas <nikitas_angelinas@xyratex.com>
Signed-off-by: Andrew Perepechko <andrew_perepechko@xyratex.com>
Acked-by: Andreas Dilger <adilger@dilger.ca>
sysname holds "Linux" by default, i.e. what appears when doing a "uname
-s"; nodename should be used to print the machine's hostname, i.e. what
is returned when doing a "uname -n" or "hostname", and what
gethostname(2)/sethostname(2) manipulate, in order to notify the
administrator of the node which is contending to mount the filesystem.
Add a sanity check to make sure ix hasn't gone beyond the valid bounds
of the extent block.
This fixes a bug which was introduced in dd68314ccf3fb. The problem
came from the test of the return value of proc_mkdir which is always
false without procfs, and this would initialization of ext4.
Signed-off-by: Fabrice Jouhaud <yargil@free.fr>
ext4_extent_idx.e_block is __le32, so use le32_to_cpu() in
ext4_ext_search_left().
There are no users of the EXT4_IOC_WAIT_FOR_READONLY ioctl, and it is
also broken. No one sets the set_ro_timer, no one wakes up us and our
state is set to TASK_INTERRUPTIBLE not RUNNING. So remove it.
The comment describing what ext4_ext_search_right() does is incorrect.
We return 0 in *phys when *logical is the 'largest' allocated block,
not smallest.
Fix a few other typos while we're at it.
Cc: "Theodore Ts'o" <tytso@mit.edu>
For a long time now orlov is the default block allocator in the
ext4. It performs better than the old one and no one seems to claim
otherwise so we can safely drop it and make oldalloc and orlov mount
option deprecated.
This is a part of the effort to reduce number of ext4 options hence the
test matrix.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Acl and user_xattr mount options are no longer needed since those
features are enabled by default if configured in (seee commit
ea6633369458992241599c9d9ebadffaeddec164). We can not easily deprecate
mount options itself (since it is probably too early), but we can
remove it from documentation first.
Some of the error path in ext4_fill_super don't release the
resouces properly. So this patch just try to release them
in the right way.
In commit 79a77c5ac, we move ext4_mb_init_backend after the allocation
of s_locality_group to avoid memory leak in error path, but there are
still some other error paths in ext4_mb_init that need to do the same
work. So this patch adds all the error patch for ext4_mb_init. And all
the pointers are reset to NULL in case the caller may double free them.
Currently, there exists a race between delayed allocated writes and
the writeback when bigalloc feature is in use. The race was because we
wanted to determine what blocks in a cluster are under delayed
allocation and we were using buffer_delayed(bh) check for it. But, the
writeback codepath clears this bit without any synchronization which
resulted in a race and an ext4 warning similar to:
EXT4-fs (ram1): ext4_da_update_reserve_space: ino 13, used 1 with only 0
reserved data blocks
The race existed in two places.
(1) between ext4_find_delalloc_range() and ext4_map_blocks() when called from
writeback code path.
(2) between ext4_find_delalloc_range() and ext4_da_get_block_prep() (where
buffer_delayed(bh) is set.
To fix (1), this patch introduces a new buffer_head state bit -
BH_Da_Mapped. This bit is set under the protection of
EXT4_I(inode)->i_data_sem when we have actually mapped the delayed
allocated blocks during the writeout time. We can now reliably check
for this bit inside ext4_find_delalloc_range() to determine whether
the reservation for the blocks have already been claimed or not.
To fix (2), it was necessary to set buffer_delay(bh) under the
protection of i_data_sem. So, I extracted the very beginning of
ext4_map_blocks into a new function - ext4_da_map_blocks() - and
performed the required setting of bh_delay bit and the quota
reservation under the protection of i_data_sem. These two fixes makes
the checking of buffer_delay(bh) and buffer_da_mapped(bh) consistent,
thus removing the race.
Tested: I was able to reproduce the problem by running 'dd' and
'fsync' in parallel. Also, xfstests sometimes used to reproduce this
race. After the fix both my test and xfstests were successful and no
race (warning message) was observed.
Google-Bug-Id: 4997027
Signed-off-by: Aditya Kali <adityakali@google.com>
This patch adds some tracepoints in ext4/extents.c and updates a tracepoint in
ext4/inode.c.
Tested: Built and ran the kernel and verified that these tracepoints work.
Also ran xfstests.
Rename the function so it is more clear what is going on. Also rename
the various variables so it's clearer what's happening.
Also fix a missing blocks to cluster conversion when reading the
number of reserved blocks for root.
