2013-05-18drivers/rtc: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Stephen Warren <swarren@nvidia.com>
2013-05-18drivers/pwm: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-18drivers/pinctrl: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-18drivers/net/ethernet/renesas: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-18drivers/mtd/nand: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-18drivers/misc: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-18drivers/mfd: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-18drivers/memory: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-18drivers/i2c/busses: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Barry Song <Baohua.Song@csr.com>
2013-05-18drivers/gpu/host1x/drm: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-18drivers/gpu/drm/exynos: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-18drivers/gpio: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-18drivers/dma: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-18drivers/cpufreq: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
2013-05-12drivers/char/hw_random: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-12drivers/ata: don't check resource with devm_ioremap_resourceWolfram Sang
2013-05-11Linux 3.10-rc1v3.10-rc1Linus Torvalds
2013-05-11Merge tag 'trace-fixes-v3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing/kprobes update from Steven Rostedt: "The majority of these changes are from Masami Hiramatsu bringing kprobes up to par with the latest changes to ftrace (multi buffering and the new function probes). He also discovered and fixed some bugs in doing so. When pulling in his patches, I also found a few minor bugs as well and fixed them. This also includes a compile fix for some archs that select the ring buffer but not tracing. I based this off of the last patch you took from me that fixed the merge conflict error, as that was the commit that had all the changes I needed for this set of changes." * tag 'trace-fixes-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing/kprobes: Support soft-mode disabling tracing/kprobes: Support ftrace_event_file base multibuffer tracing/kprobes: Pass trace_probe directly from dispatcher tracing/kprobes: Increment probe hit-count even if it is used by perf tracing/kprobes: Use bool for retprobe checker ftrace: Fix function probe when more than one probe is added ftrace: Fix the output of enabled_functions debug file ftrace: Fix locking in register_ftrace_function_probe() tracing: Add helper function trace_create_new_event() to remove duplicate code tracing: Modify soft-mode only if there's no other referrer tracing: Indicate enabled soft-mode in enable file tracing/kprobes: Fix to increment return event probe hit-count ftrace: Cleanup regex_lock and ftrace_lock around hash updating ftrace, kprobes: Fix a deadlock on ftrace_regex_lock ftrace: Have ftrace_regex_write() return either read or error tracing: Return error if register_ftrace_function_probe() fails for event_enable_func() tracing: Don't succeed if event_enable_func did not register anything ring-buffer: Select IRQ_WORK
2013-05-11Merge tag 'stable/for-linus-3.10-rc0-tag-two' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen bug-fixes from Konrad Rzeszutek Wilk: - More fixes in the vCPU PVHVM hotplug path. - Add more documentation. - Fix various ARM related issues in the Xen generic drivers. - Updates in the xen-pciback driver per Bjorn's updates. - Mask the x2APIC feature for PV guests. * tag 'stable/for-linus-3.10-rc0-tag-two' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/pci: Used cached MSI-X capability offset xen/pci: Use PCI_MSIX_TABLE_BIR, not PCI_MSIX_FLAGS_BIRMASK xen: clear IRQ_NOAUTOEN and IRQ_NOREQUEST xen: mask x2APIC feature in PV xen: SWIOTLB is only used on x86 xen/spinlock: Fix check from greater than to be also be greater or equal to. xen/smp/pvhvm: Don't point per_cpu(xen_vpcu, 33 and larger) to shared_info xen/vcpu: Document the xen_vcpu_info and xen_vcpu xen/vcpu/pvhvm: Fix vcpu hotplugging hanging.
2013-05-11Merge tag 'scsi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull second SCSI update from James "Jaj B" Bottomley: "This is the final round of SCSI patches for the merge window. It consists mostly of driver updates (bnx2fc, ibmfc, fnic, lpfc, be2iscsi, pm80xx, qla4x and ipr). There's also the power management updates that complete the patches in Jens' tree, an iscsi refcounting problem fix from the last pull, some dif handling in scsi_debug fixes, a few nice code cleanups and an error handling busy bug fix." * tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (92 commits) [SCSI] qla2xxx: Update firmware link in Kconfig file. [SCSI] iscsi class, qla4xxx: fix sess/conn refcounting when find fns are used [SCSI] sas: unify the pointlessly separated enums sas_dev_type and sas_device_type [SCSI] pm80xx: thermal, sas controller config and error handling update [SCSI] pm80xx: NCQ error handling changes [SCSI] pm80xx: WWN Modification for PM8081/88/89 controllers [SCSI] pm80xx: Changed module name and debug messages update [SCSI] pm80xx: Firmware flash memory free fix, with addition of new memory region for it [SCSI] pm80xx: SPC new firmware changes for device id 0x8081 alone [SCSI] pm80xx: Added SPCv/ve specific hardware functionalities and relevant changes in common files [SCSI] pm80xx: MSI-X implementation for using 64 interrupts [SCSI] pm80xx: Updated common functions common for SPC and SPCv/ve [SCSI] pm80xx: Multiple inbound/outbound queue configuration [SCSI] pm80xx: Added SPCv/ve specific ids, variables and modify for SPC [SCSI] lpfc: fix up Kconfig dependencies [SCSI] Handle MLQUEUE busy response in scsi_send_eh_cmnd [SCSI] sd: change to auto suspend mode [SCSI] sd: use REQ_PM in sd's runtime suspend operation [SCSI] qla4xxx: Fix iocb_cnt calculation in qla4xxx_send_mbox_iocb() [SCSI] ufs: Correct the expected data transfersize ...
2013-05-11Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull idle update from Len Brown: "Add support for new Haswell-ULT CPU idle power states" * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: intel_idle: initial C8, C9, C10 support tools/power turbostat: display C8, C9, C10 residency
2013-05-11Merge git://git.infradead.org/users/eparis/auditLinus Torvalds
Pull audit changes from Eric Paris: "Al used to send pull requests every couple of years but he told me to just start pushing them to you directly. Our touching outside of core audit code is pretty straight forward. A couple of interface changes which hit net/. A simple argument bug calling audit functions in namei.c and the removal of some assembly branch prediction code on ppc" * git://git.infradead.org/users/eparis/audit: (31 commits) audit: fix message spacing printing auid Revert "audit: move kaudit thread start from auditd registration to kaudit init" audit: vfs: fix audit_inode call in O_CREAT case of do_last audit: Make testing for a valid loginuid explicit. audit: fix event coverage of AUDIT_ANOM_LINK audit: use spin_lock in audit_receive_msg to process tty logging audit: do not needlessly take a lock in tty_audit_exit audit: do not needlessly take a spinlock in copy_signal audit: add an option to control logging of passwords with pam_tty_audit audit: use spin_lock_irqsave/restore in audit tty code helper for some session id stuff audit: use a consistent audit helper to log lsm information audit: push loginuid and sessionid processing down audit: stop pushing loginid, uid, sessionid as arguments audit: remove the old depricated kernel interface audit: make validity checking generic audit: allow checking the type of audit message in the user filter audit: fix build break when AUDIT_DEBUG == 2 audit: remove duplicate export of audit_enabled Audit: do not print error when LSMs disabled ...
2013-05-10Merge branch 'for-3.10' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd fixes from Bruce Fields: "Small fixes for two bugs and two warnings" * 'for-3.10' of git://linux-nfs.org/~bfields/linux: nfsd: fix oops when legacy_recdir_name_error is passed a -ENOENT error SUNRPC: fix decoding of optional gss-proxy xdr fields SUNRPC: Refactor gssx_dec_option_array() to kill uninitialized warning nfsd4: don't allow owner override on 4.1 CLAIM_FH opens
2013-05-10Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform drivers from Matthew Garrett: "Small set of updates, mainly trivial bugfixes and some small updates to deal with newer hardware. There's also a new driver that allows qemu guests to notify the hypervisor that they've just paniced, which seems useful." * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: Add support for fan button on Ideapad Z580 pvpanic: pvpanic device driver asus-nb-wmi: set wapf=4 for ASUSTeK COMPUTER INC. X75A drivers: platform: x86: Use PTR_RET function sony-laptop: SVS151290S kbd backlight and gfx switch support hp-wmi: add more definitions for new event_id's dell-laptop: Fix krealloc() misuse in parse_da_table() hp_accel: Ignore the error from lis3lv02d_poweron() at resume dell: add new dell WMI format for the AIO machines
2013-05-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull stray syscall bits from Al Viro: "Several syscall-related commits that were missing from the original" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: switch compat_sys_sysctl to COMPAT_SYSCALL_DEFINE unicore32: just use mmap_pgoff()... unify compat fanotify_mark(2), switch to COMPAT_SYSCALL_DEFINE x86, vm86: fix VM86 syscalls: use SYSCALL_DEFINEx(...)
2013-05-10Merge tag 'ecryptfs-3.10-rc1-ablkcipher' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull eCryptfs update from Tyler Hicks: "Improve performance when AES-NI (and most likely other crypto accelerators) is available by moving to the ablkcipher crypto API. The improvement is more apparent on faster storage devices. There's no noticeable change when hardware crypto is not available" * tag 'ecryptfs-3.10-rc1-ablkcipher' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: Use the ablkcipher crypto API
2013-05-10Merge tag 'for-linus-20130509' of git://git.infradead.org/~dwmw2/random-2.6Linus Torvalds
Pull misc fixes from David Woodhouse: "This is some miscellaneous cleanups that don't really belong anywhere else (or were ignored), that have been sitting in linux-next for some time. Two of them are fixes resulting from my audit of krealloc() usage that don't seem to have elicited any response when I posted them, and the other three are patches from Artem removing dead code." * tag 'for-linus-20130509' of git://git.infradead.org/~dwmw2/random-2.6: pcmcia: remove RPX board stuff m68k: remove rpxlite stuff pcmcia: remove Motorola MBX860 support params: Fix potential memory leak in add_sysfs_param() dell-laptop: Fix krealloc() misuse in parse_da_table()
2013-05-10Merge tag 'kvm-3.10-2' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm fixes from Gleb Natapov: "Most of the fixes are in the emulator since now we emulate more than we did before for correctness sake we see more bugs there, but there is also an OOPS fixed and corruption of xcr0 register." * tag 'kvm-3.10-2' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: emulator: emulate SALC KVM: emulator: emulate XLAT KVM: emulator: emulate AAM KVM: VMX: fix halt emulation while emulating invalid guest sate KVM: Fix kvm_irqfd_init initialization KVM: x86: fix maintenance of guest/host xcr0 state
2013-05-10Merge tag 'dm-3.10-changes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm Pull device-mapper updates from Alasdair Kergon: "Allow devices that hold metadata for the device-mapper thin provisioning target to be extended easily; allow WRITE SAME on multipath devices; an assortment of little fixes and clean-ups." * tag 'dm-3.10-changes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/agk/linux-dm: (21 commits) dm cache: set config value dm cache: move config fns dm thin: generate event when metadata threshold passed dm persistent metadata: add space map threshold callback dm persistent data: add threshold callback to space map dm thin: detect metadata device resizing dm persistent data: support space map resizing dm thin: open dev read only when possible dm thin: refactor data dev resize dm cache: replace memcpy with struct assignment dm cache: fix typos in comments dm cache policy: fix description of lookup fn dm: document iterate_devices dm persistent data: fix error message typos dm cache: tune migration throttling dm mpath: enable WRITE SAME support dm table: fix write same support dm bufio: avoid a possible __vmalloc deadlock dm snapshot: fix error return code in snapshot_ctr dm cache: fix error return code in cache_create ...
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID fixes from Jiri Kosina: - fix usage of sleeping lock in atomic context from Jiri Kosina - build fix for hid-steelseries under certain .config setups by Simon Wood - simple mismerge fix from Fernando Luis Vázquez Cao * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: debug: fix RCU preemption issue HID: hid-steelseries fix led class build issue HID: reintroduce fix-up for certain Sony RF receivers
2013-05-10Merge branch 'postmerge' into for-linusJames Bottomley
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10Merge branch 'misc' into for-linusJames Bottomley
2013-05-10Merge tag 'sound-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "This contains small fixes since the previous pull request: - A few regression fixes and small updates of HD-audio - Yet another fix for Haswell HDMI audio - A copule of trivial fixes in ASoC McASP, DPAM and WM8994" * tag 'sound-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: Revert "ALSA: hda - Don't set up active streams twice" ALSA: Add comment for control TLV API ALSA: hda - Apply pin-enablement workaround to all Haswell HDMI codecs ALSA: HDA: Fix Oops caused by dereference NULL pointer ALSA: mips/sgio2audio: Remove redundant platform_set_drvdata() ALSA: mips/hal2: Remove redundant platform_set_drvdata() ALSA: hda - Fix 3.9 regression of EAPD init on Conexant codecs sound: Fix make allmodconfig on MIPS ALSA: hda - Fix system panic when DMA > 40 bits for Nvidia audio controllers ALSA: atmel: Remove redundant platform_set_drvdata() ASoC: McASP: Fix receive clock polarity in DAIFMT_NB_NF mode. ASoC: wm8994: missing break in wm8994_aif3_hw_params() ASoC: McASP: Add pins output direction for rx clocks when configured in CBS_CFS format ASoC: dapm: use clk_prepare_enable and clk_disable_unprepare
2013-05-10Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: - More work on DT support for various platforms - Various fixes that were to late to make it straight into 3.9 - Improved platform support, in particular the Netlogic XLR and BCM63xx, and the SEAD3 and Malta eval boards. - Support for several Ralink SOC families. - Complete support for the microMIPS ASE which basically reencodes the existing MIPS32/MIPS64 ISA to use non-constant size instructions. - Some fallout from LTO work which remove old cruft and will generally make the MIPS kernel easier to maintain and resistant to compiler optimization, even in absence of LTO. - KVM support. While MIPS has announced hardware virtualization extensions this KVM extension uses trap and emulate mode for virtualization of MIPS32. More KVM work to add support for VZ hardware virtualizaiton extensions and MIPS64 will probably already be merged for 3.11. Most of this has been sitting in -next for a long time. All defconfigs have been build or run time tested except three for which fixes are being sent by other maintainers. Semantic conflict with kvm updates done as per Ralf * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (118 commits) MIPS: Add new GIC clockevent driver. MIPS: Formatting clean-ups for clocksources. MIPS: Refactor GIC clocksource code. MIPS: Move 'gic_frequency' to common location. MIPS: Move 'gic_present' to common location. MIPS: MIPS16e: Add unaligned access support. MIPS: MIPS16e: Support handling of delay slots. MIPS: MIPS16e: Add instruction formats. MIPS: microMIPS: Optimise 'strnlen' core library function. MIPS: microMIPS: Optimise 'strlen' core library function. MIPS: microMIPS: Optimise 'strncpy' core library function. MIPS: microMIPS: Optimise 'memset' core library function. MIPS: microMIPS: Add configuration option for microMIPS kernel. MIPS: microMIPS: Disable LL/SC and fix linker bug. MIPS: microMIPS: Add vdso support. MIPS: microMIPS: Add unaligned access support. MIPS: microMIPS: Support handling of delay slots. MIPS: microMIPS: Add support for exception handling. MIPS: microMIPS: Floating point support. MIPS: microMIPS: Fix macro naming in micro-assembler. ...
2013-05-10[SCSI] qla2xxx: Update firmware link in Kconfig file.Chad Dupuis
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com> Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] iscsi class, qla4xxx: fix sess/conn refcounting when find fns are usedMike Christie
This fixes a bug where the iscsi class/driver did not do a put_device when a sess/conn device was found. This also simplifies the interface by not having to pass in some arguments that were duplicated and did not need to be exported. Reported-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Acked-by: Vikas Chaudhary <vikas.chaudhary@qlogic.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] sas: unify the pointlessly separated enums sas_dev_type and ↵James Bottomley
sas_device_type These enums have been separate since the dawn of SAS, mainly because the latter is a procotol only enum and the former includes additional state for libsas. The dichotomy causes endless confusion about which one you should use where and leads to pointless warnings like this: drivers/scsi/mvsas/mv_sas.c: In function 'mvs_update_phyinfo': drivers/scsi/mvsas/mv_sas.c:1162:34: warning: comparison between 'enum sas_device_type' and 'enum sas_dev_type' [-Wenum-compare] Fix by eliminating one of them. The one kept is effectively the sas.h one, but call it sas_device_type and make sure the enums are all properly namespaced with the SAS_ prefix. Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: thermal, sas controller config and error handling updateSakthivel K
Modified thermal configuration to happen after interrupt registration Added SAS controller configuration during initialization Added error handling logic to handle I_T_Nexus errors and variants [jejb: fix up tabs and spaces issues] Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: NCQ error handling changesSakthivel K
Handled NCQ errors in the low level driver as the FW is not providing the faulty tag for NCQ errors for libsas to recover. [jejb: fix checkpatch issues] Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: WWN Modification for PM8081/88/89 controllersSakthivel K
Individual WWN read operations based on controller. PM8081 - Read WWN from Flash VPD. PM8088/89 - Read WWN from EEPROM. PM8001 - Read WWN from NVM. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Changed module name and debug messages updateSakthivel K
Changed name in driver to pm80xx. Updated debug messages. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Firmware flash memory free fix, with addition of new memory ↵Sakthivel K
region for it Performing pci_free_consistent in tasklet had result in a core dump. So allocated a new memory region for it. Fix for passing proper address and operation in firmware flash update. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: SPC new firmware changes for device id 0x8081 aloneSakthivel K
Additional bar shift for new SPC firmware, applicable to device id 0x8081 only. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Added SPCv/ve specific hardware functionalities and relevant ↵Sakthivel K
changes in common files Implementation of SPCv/ve specific hardware functionality and macros. Changing common functionalities wrt SPCv/ve operations. Conditional checks for SPC specific operations. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: MSI-X implementation for using 64 interruptsSakthivel K
Implementation of interrupt handlers and tasklets to support upto 64 interrupt for the device. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Updated common functions common for SPC and SPCv/veSakthivel K
Update of function prototype for common function to SPC and SPCv/ve. Multiple queues implementation for IO. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Multiple inbound/outbound queue configurationSakthivel K
Memory allocation and configuration of multiple inbound and outbound queues. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] pm80xx: Added SPCv/ve specific ids, variables and modify for SPCSakthivel K
Updated pci id table with device, vendor, subdevice and subvendor ids for 8081, 8088, 8089 SAS/SATA controllers. Added SPCv/ve related macros. Updated macros, hba info structure and other structures for SPCv/ve. Update of structure and variable names for SPC hardware functionalities. Signed-off-by: Sakthivel K <Sakthivel.SaravananKamalRaju@pmcs.com> Signed-off-by: Anand Kumar S <AnandKumar.Santhanam@pmcs.com> Acked-by: Jack Wang <jack_wang@usish.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] lpfc: fix up Kconfig dependenciesJames Bottomley
lpfc uses the generic checksum as well as the T10DIF one from the lib/ directory, so make sure they're selected. Reported-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2013-05-10[SCSI] Handle MLQUEUE busy response in scsi_send_eh_cmndHannes Reinecke
scsi_send_eh_cmnd() is calling queuecommand() directly, so it needs to check the return value here. The only valid return codes for queuecommand() are 'busy' states, so we need to wait for a bit to allow the LLDD to recover. Based on an earlier patch from Wen Xiong. [jejb: fix confusion between msec and jiffies values and other issues] [bvanassche: correct stall_for interval] Cc: Wen Xiong <wenxiong@linux.vnet.ibm.com> Cc: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
