2008-08-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (46 commits) tcp: MD5: Fix IPv6 signatures skbuff: add missing kernel-doc for do_not_encrypt net/ipv4/route.c: fix build error tcp: MD5: Fix MD5 signatures on certain ACK packets ipv6: Fix ip6_xmit to send fragments if ipfragok is true ipvs: Move userspace definitions to include/linux/ip_vs.h netdev: Fix lockdep warnings in multiqueue configurations. netfilter: xt_hashlimit: fix race between htable_destroy and htable_gc netfilter: ipt_recent: fix race between recent_mt_destroy and proc manipulations netfilter: nf_conntrack_tcp: decrease timeouts while data in unacknowledged irda: replace __FUNCTION__ with __func__ nsc-ircc: default to dongle type 9 on IBM hardware bluetooth: add quirks for a few hci_usb devices hysdn: remove the packed attribute from PofTimStamp_tag isdn: use the common ascii hex helpers tg3: adapt tg3 to use reworked PCI PM code atm: fix direct casts of pointers to u32 in the InterPhase driver atm: fix const assignment/discard warnings in the ATM networking driver net: use the common ascii hex helpers random32: seeding improvement ...
2008-08-01Merge branch 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6Linus Torvalds
* 'release' of git://lm-sensors.org/kernel/mhoffman/hwmon-2.6: hwmon: needs new maintainer hwmon: (lm85) Simplify device initialization function hwmon: (lm85) Misc cleanups hwmon: (lm85) Don't write back cached values hwmon: (lm85) Drop dead code hwmon: (lm85) Coding-style cleanups hwmon: (lm75) add new-style driver binding hwmon: (lm75) cleanup/reorg hwmon: (adt7473) clarify an awkward bit of code hwmon: (adt7473) Remove unused defines hwmon: (dme1737) fix voltage scaling hwmon: (dme1737) probe all addresses hwmon: (dme1737) demacrofy for readability
2008-08-01Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: [MTD] [NAND] drivers/mtd/nand/nandsim.c: fix printk warnings [MTD] [NAND] Blackfin NFC Driver: Cleanup the error exit path of bf5xx_nand_probe function [MTD] [NAND] Blackfin NFC Driver: use standard dev_err() rather than printk() [MTD] [NAND] Blackfin NFC Driver: enable Blackfin nand HWECC support by default [MTD] [NAND] Blackfin NFC Driver: add proper devinit/devexit markings to probe/remove functions [MTD] [NAND] Blackfin NFC Driver: add support for the ECC layout the Blackfin bootrom uses [MTD] [NAND] Blackfin NFC Driver: fix bug - hw ecc calc by making sure we extract 11 bits from each register instead of 10 [MTD] [NAND] Blackfin NFC Driver: fix bug - do not clobber the status from the first 256 bytes if operating on 512 pages [MTD] [NAND] diskonchip.c fix sparse endian warnings [MTD] [NAND] drivers/mtd/nand/nandsim.c needs div64.h [JFFS2] Fix allocation of summary buffer Fix rename of at91_nand -> atmel_nand [MTD] [NOR] drivers/mtd/chips/jedec_probe.c: fix Am29DL800BB device ID [MTD] MTD_DEBUG always does compile-time typechecks [MTD] DataFlash: bugfix, binary page sizes now handled [MTD] [NAND] fsl_elbc_nand.c: fix printk warning [MTD] [NAND] nandsim: support random page read command [MTD] [NAND] fix subpage read for small page NAND
2008-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] pass struct path * to do_add_mount() [PATCH] switch mtd and dm-table to lookup_bdev() [patch 3/4] vfs: remove unused nameidata argument of may_create() [PATCH] devpts: switch to IDA [PATCH 2/2] proc: switch inode number allocation to IDA [PATCH 1/2] proc: fix inode number bogorithmetic [PATCH] fix bdev leak in block_dev.c do_open() [PATCH] fix races and leaks in vfs_quota_on() users [PATCH] clean dup2() up a bit [PATCH] merge locate_fd() and get_unused_fd() [PATCH] ipv4_static_sysctl_init() should be under CONFIG_SYSCTL Re: BUG at security/selinux/avc.c:883 (was: Re: linux-next: Tree
2008-08-01Merge branch 'audit.b54' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b54' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: [PATCH] Fix the bug of using AUDIT_STATUS_RATE_LIMIT when set fail, no error output. [PATCH] Fix the kernel panic of audit_filter_task when key field is set Re: [PATCH] the loginuid field should be output in all AUDIT_CONFIG_CHANGE audit messages kernel/audit.c control character detection is off-by-one [PATCH] Audit: Collect signal info when SIGUSR2 is sent to auditd
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: au1xmmc: raise segment size limit. mmc_block: use proper sg iterators mmc: properly iterate over sg list in debug check mmc_test: Revert "mmc_test: test oversized sg lists" sdhci: check correct return value sdhci: disable DMA for req, not completely sdhci: handle bug in JMB38x for sizes < 4 bytes
2008-08-01Merge branch 'reg-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'reg-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: regulator: TI bq24022 Li-Ion Charger driver regulator: maintainers - add maintainers for regulator framework. regulator: documentation - ABI regulator: documentation - machine regulator: documentation - regulator driver regulator: documentation - consumer interface regulator: documentation - overview regulator: core kbuild files regulator: regulator test harness regulator: add support for fixed regulators. regulator: regulator framework core regulator: fixed regulator interface regulator: machine driver interface regulator: regulator driver interface regulator: consumer device interface
2008-08-01Merge branch 'hotfixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'hotfixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: SELinux: /proc/mounts should show what it can
2008-08-01Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: power_supply: Sharp SL-6000 (tosa) batteries support power_supply: fix up CHARGE_COUNTER output to be more precise power_supply: add CHARGE_COUNTER property and olpc_battery support for it power_supply: bump EC version check that we refuse to run with in olpc_battery power_supply: cleanup of the OLPC battery driver power_supply: add eeprom dump file to olpc_battery's sysfs power_supply: Support serial number in olpc_battery
2008-08-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (28 commits) mm/hugetlb.c must #include <asm/io.h> video: Fix up hp6xx driver build regressions. sh: defconfig updates. sh: Kill off stray mach-rsk7203 reference. serial: sh-sci: Fix up SH7760/SH7780/SH7785 early printk regression. sh: Move out individual boards without mach groups. sh: Make sure AT_SYSINFO_EHDR is exposed to userspace in asm/auxvec.h. sh: Allow SH-3 and SH-5 to use common headers. sh: Provide common CPU headers, prune the SH-2 and SH-2A directories. sh/maple: clean maple bus code sh: More header path fixups for mach dir refactoring. sh: Move out the solution engine headers to arch/sh/include/mach-se/ sh: I2C fix for AP325RXA and Migo-R sh: Shuffle the board directories in to mach groups. sh: dma-sh: Fix up dreamcast dma.h mach path. sh: Switch KBUILD_DEFCONFIG to shx3_defconfig. sh: Add ARCH_DEFCONFIG entries for sh and sh64. sh: Fix compile error of Solution Engine sh: Proper __put_user_asm() size mismatch fix. sh: Stub in a dummy ENTRY_OFFSET for uImage offset calculation. ...
2008-08-01Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: generic, x86: fix add iommu_num_pages helper function x86: remove stray <6> in BogoMIPS printk x86: move dma32_reserve_bootmem() after reserve_crashkernel()
2008-08-01Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] qeth: avoid use of include/asm-s390 [S390] dont use kthread for smp_rescan_cpus(). [S390] virtio console: fix section mismatch warning. [S390] cio: Include linux/string.h in schid.h. [S390] qdio: fix section mismatch bug. [S390] stp: fix section mismatch warning. [S390] Remove diag 0x260 call from memory detection. [S390] qdio: make sure qdr is aligned to page size [S390] Add support for memory hot-remove. [S390] Wire up new syscalls. [S390] cio: Memory allocation for idset changed. [S390] qeth: preallocated qeth header for hiper socket [S390] Optimize storage key operations for anon pages [S390] nohz/sclp: disable timer on synchronous waits. [S390] ipl: Reboot from alternate device does not work when booting from file [S390] dasd: Add support for enhanced VM UID [S390] Remove last P390 trace.
2008-08-01au1xmmc: raise segment size limit.Manuel Lauss
Raise the DMA block size limit from 2048 bytes to the maximum supported by the DMA controllers on the chip (64KB on Au1100, 4MB on Au1200). This gives a very small performance boost and apparently fixes an oops when MMC-DMA and network traffic are active at the same time. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-08-01mmc_block: use proper sg iteratorsPierre Ossman
2008-08-01mmc: properly iterate over sg list in debug checkPierre Ossman
2008-08-01mmc_test: Revert "mmc_test: test oversized sg lists"Pierre Ossman
This reverts commit 48b5352ea1891455eb8e824cf7d92f66931a090f. Oversized sg lists are not allowed anymore, and the core even checks for them in debug mode, so this test is entirely incorrect. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-08-01sdhci: check correct return valuePierre Ossman
Fix a copy-and-paste error. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-08-01sdhci: disable DMA for req, not completelyPierre Ossman
The wrong flag was manipulated when an invalid sg list was given, turning off DMA on the next (and all subsequent) request instead of the current one. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-08-01sdhci: handle bug in JMB38x for sizes < 4 bytesPierre Ossman
2008-08-01[PATCH] Fix the bug of using AUDIT_STATUS_RATE_LIMIT when set fail, no error ↵zhangxiliang
output. When the "status_get->mask" is "AUDIT_STATUS_RATE_LIMIT || AUDIT_STATUS_BACKLOG_LIMIT". If "audit_set_rate_limit" fails and "audit_set_backlog_limit" succeeds, the "err" value will be greater than or equal to 0. It will miss the failure of rate set. Signed-off-by: Zhang Xiliang <zhangxiliang@cn.fujitsu.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[PATCH] Fix the kernel panic of audit_filter_task when key field is setzhangxiliang
When calling audit_filter_task(), it calls audit_filter_rules() with audit_context is NULL. If the key field is set, the result in audit_filter_rules() will be set to 1 and ctx->filterkey will be set to key. But the ctx is NULL in this condition, so kernel will panic. Signed-off-by: Zhang Xiliang <zhangxiliang@cn.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01Re: [PATCH] the loginuid field should be output in all AUDIT_CONFIG_CHANGE ↵zhangxiliang
audit messages > shouldn't these be using the "audit_get_loginuid(current)" and if we > are going to output loginuid we also should be outputting sessionid Thanks for your detailed explanation. I have made a new patch for outputing "loginuid" and "sessionid" by audit_get_loginuid(current) and audit_get_sessionid(current). If there are some deficiencies, please give me your indication. Signed-off-by: Zhang Xiliang <zhangxiliang@cn.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01kernel/audit.c control character detection is off-by-oneVesa-Matti J Kari
Hello, According to my understanding there is an off-by-one bug in the function: audit_string_contains_control() in: kernel/audit.c Patch is included. I do not know from how many places the function is called from, but for example, SELinux Access Vector Cache tries to log untrusted filenames via call path: avc_audit() audit_log_untrustedstring() audit_log_n_untrustedstring() audit_string_contains_control() If audit_string_contains_control() detects control characters, then the string is hex-encoded. But the hex=0x7f dec=127, DEL-character, is not detected. I guess this could have at least some minor security implications, since a user can create a filename with 0x7f in it, causing logged filename to possibly look different when someone reads it on the terminal. Signed-off-by: Vesa-Matti Kari <vmkari@cc.helsinki.fi> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[PATCH] Audit: Collect signal info when SIGUSR2 is sent to auditdEric Paris
Makes the kernel audit subsystem collect information about the sending process when that process sends SIGUSR2 to the userspace audit daemon. SIGUSR2 is a new interesting signal to auditd telling auditd that it should try to start logging to disk again and the error condition which caused it to stop logging to disk (usually out of space) has been rectified. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[PATCH] pass struct path * to do_add_mount()Al Viro
2008-08-01[PATCH] switch mtd and dm-table to lookup_bdev()Al Viro
No need to open-code it... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[patch 3/4] vfs: remove unused nameidata argument of may_create()Miklos Szeredi
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[PATCH] devpts: switch to IDAAlexey Dobriyan
Devpts code wants just numbers for tty indexes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[PATCH 2/2] proc: switch inode number allocation to IDAAlexey Dobriyan
proc doesn't use "associate pointer with id" feature of IDR, so switch to IDA. NOTE, NOTE, NOTE: Do not apply if release_inode_number() still mantions MAX_ID_MASK! Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[PATCH 1/2] proc: fix inode number bogorithmeticAlexey Dobriyan
Id which proc gets from IDR for inode number and id which proc removes from IDR do not match. E.g. 0x11a transforms into 0x8000011a. Which stayed unnoticed for a long time because, surprise, idr_remove() masks out that high bit before doing anything. All of this due to "| ~MAX_ID_MASK" in release_inode_number(). I still don't understand how it's supposed to work, because "| ~MASK" is not an inversion for "& MAX" operation. So, use just one nice, working addition. Make start offset unsigned int, while I'm at it. It's longness is not used anywhere. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[PATCH] fix bdev leak in block_dev.c do_open()Al Viro
Callers expect it to drop reference to bdev on all failure exits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[PATCH] fix races and leaks in vfs_quota_on() usersAl Viro
* new helper: vfs_quota_on_path(); equivalent of vfs_quota_on() sans the pathname resolution. * callers of vfs_quota_on() that do their own pathname resolution and checks based on it are switched to vfs_quota_on_path(); that way we avoid the races. * reiserfs leaked dentry/vfsmount references on several failure exits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[PATCH] clean dup2() up a bitAl Viro
2008-08-01[PATCH] merge locate_fd() and get_unused_fd()Al Viro
New primitive: alloc_fd(start, flags). get_unused_fd() and get_unused_fd_flags() become wrappers on top of it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[PATCH] ipv4_static_sysctl_init() should be under CONFIG_SYSCTLAl Viro
2008-08-01Re: BUG at security/selinux/avc.c:883 (was: Re: linux-next: TreeStephen Smalley
for July 17: early crash on x86-64) SELinux needs MAY_APPEND to be passed down to the security hook. Otherwise, we get permission denials when only append permission is granted by policy even if the opening process specified O_APPEND. Shows up as a regression in the ltp selinux testsuite, fixed by this patch. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-01[MTD] [NAND] drivers/mtd/nand/nandsim.c: fix printk warningsAndrew Morton
Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-01[MTD] [NAND] Blackfin NFC Driver: Cleanup the error exit path of ↵Bryan Wu
bf5xx_nand_probe function Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-01[MTD] [NAND] Blackfin NFC Driver: use standard dev_err() rather than printk()Mike Frysinger
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-01[MTD] [NAND] Blackfin NFC Driver: enable Blackfin nand HWECC support by defaultMike Frysinger
2008-08-01[MTD] [NAND] Blackfin NFC Driver: add proper devinit/devexit markings to ↵Mike Frysinger
probe/remove functions Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-01[MTD] [NAND] Blackfin NFC Driver: add support for the ECC layout the ↵Mike Frysinger
Blackfin bootrom uses Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-01[MTD] [NAND] Blackfin NFC Driver: fix bug - hw ecc calc by making sure we ↵Mike Frysinger
extract 11 bits from each register instead of 10 Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-01[MTD] [NAND] Blackfin NFC Driver: fix bug - do not clobber the status from ↵Mike Frysinger
the first 256 bytes if operating on 512 pages Singed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-08-01[S390] qeth: avoid use of include/asm-s390Martin Schwidefsky
The planned move of include/asm-s390 to arch/s390/include/asm requires that all includes for asm headers use include/asm and not include/asm-s390. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-01[S390] dont use kthread for smp_rescan_cpus().Heiko Carstens
Since git commit 3da1c84c00c7e5fa8348336bd8c342f9128b0f14 "workqueues: make get_online_cpus() useable for work->func()" it is safe to call get_online_cpus() from workqueue context. So remove the kthread workaround again. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-01[S390] virtio console: fix section mismatch warning.Heiko Carstens
Fix these two false positive warnings: WARNING: vmlinux.o(.text+0x2e1cc4): Section mismatch in reference from the function s390_virtio_console_init() to the function .init.text:early_put_chars() The function s390_virtio_console_init() references the function __init early_put_chars(). This is often because s390_virtio_console_init lacks a __init annotation or the annotation of early_put_chars is wrong. WARNING: vmlinux.o(.text+0x2e1cd0): Section mismatch in reference from the function s390_virtio_console_init() to the function .init.text:virtio_cons_early_init() The function s390_virtio_console_init() references the function __init virtio_cons_early_init(). This is often because s390_virtio_console_init lacks a __init annotation or the annotation of virtio_cons_early_init is wrong. Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-01[S390] cio: Include linux/string.h in schid.h.Cornelia Huck
schid.h needs string.h for memset and memcmp. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-01[S390] qdio: fix section mismatch bug.Heiko Carstens
Fix the two section mismatch warnings below. This fixes two real bugs since the code which has __exit annotations may already be gone when it is called. WARNING: vmlinux.o(.init.text+0x1cc4a): Section mismatch in reference from the function init_QDIO() to the function .exit.text:qdio_setup_exit() The function __init init_QDIO() references a function __exit qdio_setup_exit(). This is often seen when error handling in the init function uses functionality in the exit path. The fix is often to remove the __exit annotation of qdio_setup_exit() so it may be used outside an exit section. WARNING: vmlinux.o(.init.text+0x1cc7a): Section mismatch in reference from the function init_QDIO() to the function .exit.text:qdio_remove_perf_stats() The function __init init_QDIO() references a function __exit qdio_remove_perf_stats(). This is often seen when error handling in the init function uses functionality in the exit path. The fix is often to remove the __exit annotation of qdio_remove_perf_stats() so it may be used outside an exit section. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-08-01[S390] stp: fix section mismatch warning.Heiko Carstens
Fix these two (false positive) warnings by adding an __init annoation: WARNING: vmlinux.o(.text+0x7e6a): Section mismatch in reference from the function stp_reset() to the function .init.text:__alloc_bootmem() The function stp_reset() references the function __init __alloc_bootmem(). This is often because stp_reset lacks a __init annotation or the annotation of __alloc_bootmem is wrong. WARNING: vmlinux.o(.text+0x7ece): Section mismatch in reference from the function stp_reset() to the function .init.text:free_bootmem() The function stp_reset() references the function __init free_bootmem(). This is often because stp_reset lacks a __init annotation or the annotation of free_bootmem is wrong. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
