Use ctl_set_bit instead of the smp_ctl_set_bit (likewise for clear bit)
to prevent the following build error for !CONFIG_SMP:
CC arch/s390/oprofile/hwsampler.o
arch/s390/oprofile/hwsampler.c: In function ‘hwsampler_deallocate’:
arch/s390/oprofile/hwsampler.c:1012: error: implicit declaration of function ‘smp_ctl_clear_bit’
arch/s390/oprofile/hwsampler.c: In function ‘hwsampler_start_all’:
arch/s390/oprofile/hwsampler.c:1201: error: implicit declaration of function ‘smp_ctl_set_bit’
CC kernel/seccomp.o
make[1]: *** [arch/s390/oprofile/hwsampler.o] Error 1
make: *** [arch/s390/oprofile] Error 2
Signed-off-by: Jan Glauber <jang@linux.vnet.ibm.com>
The counter for requested interrupts should be incremented if the
program-request-alert bit is set and not the invalid-address-entry
bit.
Remove unsused includes from arch/s390/kernel/process.c.
Provide sysfs attributes that contain the CPC name and the HMC network
name of the machine the operating system is running on. This information
is retrieved with the operation communication parameters (OCF) sclp
interface.
Move gds vector/subvector find functions to the sclp header file.
Simplify event buffer dissection in sclp tty code.
Update affected channel path descriptors when receiving channel path
availability information.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
Rework the architecture page table functions to access the bits in the
page table extension array (pgste). There are a number of changes:
1) Fix missing pgste update if the attach_count for the mm is <= 1.
2) For every operation that affects the invalid bit in the pte or the
rcp byte in the pgste the pcl lock needs to be acquired. The function
pgste_get_lock gets the pcl lock and returns the current pgste value
for a pte pointer. The function pgste_set_unlock stores the pgste
and releases the lock. Between these two calls the bits in the pgste
can be shuffled.
3) Define two software bits in the pte _PAGE_SWR and _PAGE_SWC to avoid
calling SetPageDirty and SetPageReferenced from pgtable.h. If the
host reference backup bit or the host change backup bit has been
set the dirty/referenced state is transfered to the pte. The common
code will pick up the state from the pte.
4) Add ptep_modify_prot_start and ptep_modify_prot_commit for mprotect.
5) Remove pgd_populate_kernel, pud_populate_kernel, pmd_populate_kernel
pgd_clear_kernel, pud_clear_kernel, pmd_clear_kernel and ptep_invalidate.
6) Rename kvm_s390_test_and_clear_page_dirty to
ptep_test_and_clear_user_dirty and add ptep_test_and_clear_user_young.
7) Define mm_exclusive() and mm_has_pgste() helper to improve readability.
The page_clear_dirty primitive always sets the default storage key
which resets the access control bits and the fetch protection bit.
That will surprise a KVM guest that sets non-zero access control
bits or the fetch protection bit. Merge page_test_dirty and
page_clear_dirty back to a single function and only clear the
dirty bit from the storage key.
In addition move the function page_test_and_clear_dirty and
page_test_and_clear_young to page.h where they belong. This
requires to change the parameter from a struct page * to a page
frame number.
Prevent the following compile warning for !CONFIG_64BIT:
CC drivers/s390/cio/qdio_main.o
drivers/s390/cio/qdio_main.c: In function ‘handle_outbound’:
drivers/s390/cio/qdio_main.c:1449: warning: ‘state’ may be used uninitialized in this function
The sendmask check is not needed. Remove it.
Adapt new API.
Small code cleanup.
On cpu hot remove a PFAULT CANCEL command is sent to the hypervisor
which in turn will cancel all outstanding pfault requests that have
been issued on that cpu (the same happens with a SIGP cpu reset).
The result is that we end up with uninterruptible processes where
the interrupt that would wake up these processes never arrives.
In order to solve this all processes which wait for a pfault
completion interrupt get woken up after a cpu hot remove. The worst
case that could happen is that they fault again and in turn need to
wait again.
Add missing __noreturn attribute to cpu_die():
arch/s390/kernel/smp.c:691:6: error: symbol 'cpu_die' redeclared with different type
Implement arch specific irqsafe_cpu ops. The arch specific ops do not
disable/enable interrupts since that is an expensive operation. Instead
we disable preemption and perform a compare and swap loop.
Since on server distros (the ones we care about) preemption is disabled
the preempt_disable()/preempt_enable() pair is a nop.
In the end this code should be faster than the generic one.
The concepts of VDSO and gcov-based profiling don't mix: the former
includes kernel-provided code running in userspace, the latter adds
instructions that modify counters in kernel data segments. On s390
this has not been a problem so far due to VDSO code being written in
all-assembler which is exempt from gcov-based profiling. This could
change in the future, so disable profiling excplicitly for VDSO code.
Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
The registration of an ap device will be skipped, if the device type
probing fails.
Add names of current crypto adapters to the Kconfig help.
Signed-off-by: Holger Dengler <hd@linux.vnet.ibm.com>
Get rid of these:
arch/s390/mm/extmem.c: In function 'segment_modify_shared':
arch/s390/mm/extmem.c:622:3: warning: 'end_addr' may be used uninitialized in this function [-Wuninitialized]
arch/s390/mm/extmem.c:627:18: warning: 'start_addr' may be used uninitialized in this function [-Wuninitialized]
arch/s390/mm/extmem.c: In function 'segment_load':
arch/s390/mm/extmem.c:481:11: warning: 'end_addr' may be used uninitialized in this function [-Wuninitialized]
arch/s390/mm/extmem.c:480:18: warning: 'start_addr' may be used uninitialized in this function [-Wuninitialized]
Return codes are on purpose not handled or used. So remove them.
Acked-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Fix return code handling within monwrite_new_hdr(). Return code handling
is everwhere implemented, the return code of the diagnose function was
just not passed.
Check return value of itcw_add_dcw() for error code and return it.
Remove trivially unused variables as detected with -Wunused-but-set-variable.
Remove the tape block device driver. It's not of real use but has
already created some confusion when users wanted to access tape devices
and used the block device nodes instead of the character device nodes.
Also remove the whole tape documentation since it's completely outdated
and we have the device drivers book which is the place where everything
is properly documented.
The noexec support on s390 does not rely on a bit in the page table
entry but utilizes the secondary space mode to distinguish between
memory accesses for instructions vs. data. The noexec code relies
on the assumption that the cpu will always use the secondary space
page table for data accesses while it is running in the secondary
space mode. Up to the z9-109 class machines this has been the case.
Unfortunately this is not true anymore with z10 and later machines.
The load-relative-long instructions lrl, lgrl and lgfrl access the
memory operand using the same addressing-space mode that has been
used to fetch the instruction.
This breaks the noexec mode for all user space binaries compiled
with march=z10 or later. The only option is to remove the current
noexec support.
In ccw_device_set_online we basically start path verification and
wait for the device to reach a final state. If it turns out that the
device has no useable path we schedule the deregistration of the
device (which is still in an non-final state) and wake up the waiting
process. The deregistration process will set a final state, but if
the wake up happens to be prior to this, the device will hang forever
in ccw_device_set_online.
To fix this just set the final NOT_OPER state prior to the scheduled
deregistration of the device.
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2:
nilfs2: use mark_buffer_dirty to mark btnode or meta data dirty
nilfs2: always set back pointer to host inode in mapping->host
nilfs2: get rid of NILFS_I_NILFS
nilfs2: use list_first_entry
nilfs2: use empty_aops for gc-inodes
nilfs2: implement resize ioctl
nilfs2: add truncation routine of segment usage file
nilfs2: add routine to move secondary super block
nilfs2: add ioctl which limits range of segment to be allocated
nilfs2: zero fill unused portion of super root block
nilfs2: super root size should change depending on inode size
nilfs2: get rid of private page allocator
nilfs2: merge list_del()/list_add_tail() to list_move_tail()
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/ide-2.6:
ide/ide-scan-pci.c: Use for_each_pci_dev().
ide: Use linux/mutex.h
IDE: ide-floppy, remove unnecessary NULL check
drivers/ide/pmac.c: Remove unnecessary casts of pci_get_drvdata
ide: fix use after free in ide-acpi
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-next-2.6: (28 commits)
sparc32: fix build, fix missing cpu_relax declaration
SCHED_TTWU_QUEUE is not longer needed since sparc32 now implements IPI
sparc32,leon: Remove unnecessary page_address calls in LEON DMA API.
sparc: convert old cpumask API into new one
sparc32, sun4d: Implemented SMP IPIs support for SUN4D machines
sparc32, sun4m: Implemented SMP IPIs support for SUN4M machines
sparc32,leon: Implemented SMP IPIs for LEON CPU
sparc32: implement SMP IPIs using the generic functions
sparc32,leon: SMP power down implementation
sparc32,leon: added some SMP comments
sparc: add {read,write}*_be routines
sparc32,leon: don't rely on bootloader to mask IRQs
sparc32,leon: operate on boot-cpu IRQ controller registers
sparc32: always define boot_cpu_id
sparc32: removed unused code, implemented by generic code
sparc32: avoid build warning at mm/percpu.c:1647
sparc32: always register a PROM based early console
sparc32: probe for cpu info only during startup
sparc: consolidate show_cpuinfo in cpu.c
sparc32,leon: implement genirq CPU affinity
* 'for-linus' of git://neil.brown.name/md:
md: allow resync_start to be set while an array is active.
md/raid10: reformat some loops with less indenting.
md/raid10: remove unused variable.
md/raid10: make more use of 'slot' in raid10d.
md/raid10: some tidying up in fix_read_error
md/raid1: improve handling of pages allocated for write-behind.
md/raid1: try fix_sync_read_error before process_checks.
md/raid1: tidy up new functions: process_checks and fix_sync_read_error.
md/raid1: split out two sub-functions from sync_request_write
md: make error_handler functions more uniform and correct.
md/multipath: discard ->working_disks in favour of ->degraded
md/raid1: clean up read_balance.
md: simplify raid10 read_balance
md/bitmap: fix saving of events_cleared and other state.
md: reject a re-add request that cannot be honoured.
md: Fix race when creating a new md device.
Fix new kernel-doc Error and Warning in <net/mac80211.h>:
Error(linux-2.6.39-git5/include/net/mac80211.h:550): cannot understand prototype: 'struct ieee80211_sched_scan_ies '
Warning(linux-2.6.39-git5/include/net/mac80211.h:2289): No description found for parameter 'sta'
The setup_smep function gets calle at resume time too, and is thus not a
pure __init function. When marked as __init, it gets thrown out after
the kernel has initialized, and when the kernel is suspended and
resumed, the code will no longer be around, and we'll get a nice "kernel
tried to execute NX-protected page" oops because the page is no longer
marked executable.
Reported-and-tested-by: Parag Warudkar <parag.lkml@gmail.com>
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
Commit e66eed651fd1 ("list: remove prefetching from regular list
iterators") removed the include of prefetch.h from list.h. The skbuff
list traversal still had them.
Quoth David Miller:
"Please just remove the prefetches.
Those are modelled after list.h as I intend to eventually convert
SKB list handling to "struct list_head" but we're not there yet.
Therefore if we kill prefetches from list.h we should kill it from
these things in skbuff.h too."
Requested-by: David Miller <davem@davemloft.net>
After discovering that wide use of prefetch on modern CPUs
could be a net loss instead of a win, net drivers which were
relying on the implicit inclusion of prefetch.h via the list
headers showed up in the resulting cleanup fallout. Give
them an explicit include via the following $0.02 script.
#!/bin/bash
MANUAL=""
for i in `git grep -l 'prefetch(.*)' .` ; do
grep -q '<linux/prefetch.h>' $i
if [ $? = 0 ] ; then
continue
fi
( echo '?^#include <linux/?a'
echo '#include <linux/prefetch.h>'
echo .
echo w
echo q
) | ed -s $i > /dev/null 2>&1
if [ $? != 0 ]; then
echo $i needs manual fixup
MANUAL="$i $MANUAL"
fi
done
echo ------------------- 8\<----------------------
echo vi $MANUAL
Signed-off-by: Paul <paul.gortmaker@windriver.com>
[ Fixed up some incorrect #include placements, and added some
non-network drivers and the fib_trie.c case - Linus ]
Fix following sparc (32 bit) build error:
CC arch/sparc/kernel/asm-offsets.s
In file included from include/linux/seqlock.h:29:0,
from include/linux/time.h:8,
from include/linux/timex.h:56,
from include/linux/sched.h:57,
from arch/sparc/kernel/asm-offsets.c:13:
include/linux/spinlock.h: In function 'spin_unlock_wait':
include/linux/spinlock.h:360:2: error: implicit declaration of function 'cpu_relax'
Most likely caused by commit e66eed651fd1 ("list: remove
prefetching from regular list iterators") due to include
changes.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
I still happen to believe that I$ miss costs are a major thing, but
sadly, -Os doesn't seem to be the solution. With or without it, gcc
will miss some obvious code size improvements, and with it enabled gcc
will sometimes make choices that aren't good even with high I$ miss
ratios.
For example, with -Os, gcc on x86 will turn a 20-byte constant memcpy
into a "rep movsl". While I sincerely hope that x86 CPU's will some day
do a good job at that, they certainly don't do it yet, and the cost is
higher than a L1 I$ miss would be.
Some day I hope we can re-enable this.
* 'viafb-next' of git://github.com/schandinat/linux-2.6: (24 commits)
viafb: Automatic OLPC XO-1.5 configuration
viafb: remove unused CEA mode
viafb: try to map less memory in case of failure
viafb: use write combining for video ram
viafb: add X server compatibility mode
viafb: reduce OLPC refresh a bit
viafb: fix OLPC XO 1.5 device connection
viafb: fix OLPC DCON refresh rate
viafb: delete clock and PLL initialization
viafb: replace custom return values
viafb: some small cleanup for global variables
viafb: gather common good, old VGA initialization in one place
viafb: add engine clock support
viafb: add VIA slapping capability
viafb: split clock and PLL code to an extra file
viafb: add primary/secondary clock on/off switches
viafb: add clock source selection and PLL power management support
viafb: prepare for PLL separation
viafb: call viafb_get_clk_value only in viafb_set_vclock
viafb: remove unused max_hres/vres
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6:
[PARISC] wire up syncfs syscall
[PARISC] wire up the fhandle syscalls
[PARISC] wire up clock_adjtime syscall
[PARISC] wire up fanotify syscalls
[PARISC] prevent speculative re-read on cache flush
[PARISC] only make executable areas executable
[PARISC] fix pacache .size with new binutils
Fixes build errors on s390 and probably other archs as well:
In file included from net/ipv4/ip_forward.c:32:0:
include/net/udp.h: In function 'udp_csum_outgoing':
include/net/udp.h:141:2: error: implicit declaration of function 'prefetch'
Fixes this build error on s390 and probably other archs as well:
fs/inode.c: In function 'new_inode':
fs/inode.c:894:2: error: implicit declaration of function 'spin_lock_prefetch'
[ Happens on architectures that don't define their own prefetch
functions in <asm/processor.h>, and instead rely on the default
ones in <linux/prefetch.h> - Linus]
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
firewire: sbp2: parallelize login, reconnect, logout
firewire: sbp2: octlet AT payloads can be stack-allocated
firewire: sbp2: omit Scsi_Host lock from queuecommand
firewire: core: use non-reentrant workqueue with rescuer
firewire: optimize iso queueing by setting wake only after the last packet
firewire: octlet AT payloads can be stack-allocated
firewire: ohci: optimize find_branch_descriptor()
firewire: ohci: avoid separate DMA mapping for small AT payloads
firewire: ohci: do not start DMA contexts before link is enabled
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
sctp: Fix build failure.
garp: use kfree_rcu()
ipv6: copy prefsrc setting when copying route entry
This solves a serious VFS-level bug in nested_symlink (which was
rewritten from do_follow_link), and follows the order of depth tests
that existed before.
The bug triggers a BUG_ON in fs/namei.c:1381, when running racer with
symlink and rename ops.
Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu>
Acked-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: stable@kernel.org
Commit c182f90bc1f22ce5039b8722e45621d5f96862c2 ("SCTP: fix race
between sctp_bind_addr_free() and sctp_bind_addr_conflict()") and
commit 1231f0baa547a541a7481119323b7f964dda4788 ("net,rcu: convert
call_rcu(sctp_local_addr_free) to kfree_rcu()"), happening in
different trees, introduced a build failure.
Simply make the SCTP race fix use kfree_rcu() too.
Use kfree_rcu() instead of call_rcu(), remove garp_cleanup_module()
commit c3968a857a6b6c3d2ef4ead35776b055fb664d74
('ipv6: RTA_PREFSRC support for ipv6 route source address selection')
added support for ipv6 prefsrc as an alternative to ipv6 addrlabels,
but it did not work because the prefsrc entry was not copied.
Cc: Daniel Walter <sahne@0x90.at>
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (45 commits)
crypto: caam - add support for sha512 variants of existing AEAD algorithms
crypto: caam - remove unused authkeylen from caam_ctx
crypto: caam - fix decryption shared vs. non-shared key setting
crypto: caam - platform_bus_type migration
crypto: aesni-intel - fix aesni build on i386
crypto: aesni-intel - Merge with fpu.ko
crypto: mv_cesa - make count_sgs() null-pointer proof
crypto: mv_cesa - copy remaining bytes to SRAM only when needed
crypto: mv_cesa - move digest state initialisation to a better place
crypto: mv_cesa - fill inner/outer IV fields only in HMAC case
crypto: mv_cesa - refactor copy_src_to_buf()
crypto: mv_cesa - no need to save digest state after the last chunk
crypto: mv_cesa - print a warning when registration of AES algos fail
crypto: mv_cesa - drop this call to mv_hash_final from mv_hash_finup
crypto: mv_cesa - the descriptor pointer register needs to be set just once
crypto: mv_cesa - use ablkcipher_request_cast instead of the manual container_of
crypto: caam - fix printk recursion for long error texts
crypto: caam - remove unused keylen from session context
hwrng: amd - enable AMD hw rnd driver for Maple PPC boards
hwrng: amd - manage resource allocation
As Ben Hutchings discovered [1], the patch for CVE-2011-1017 (buffer
overflow in ldm_frag_add) is not sufficient. The original patch in
commit c340b1d64000 ("fs/partitions/ldm.c: fix oops caused by corrupted
partition table") does not consider that, for subsequent fragments,
previously allocated memory is used.
[1] http://lkml.org/lkml/2011/5/6/407
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Signed-off-by: Timo Warns <warns@pre-sense.de>
Commit 778dd893ae78 ("tmpfs: fix race between umount and swapoff")
forgot the new rules for strict atomic kmap nesting, causing
WARNING: at arch/x86/mm/highmem_32.c:81
from __kunmap_atomic(), then
BUG: unable to handle kernel paging request at fffb9000
from shmem_swp_set() when shmem_unuse_inode() is handling swapoff with
highmem in use. My disgrace again.
See
https://bugzilla.kernel.org/show_bug.cgi?id=35352
Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl>
Commit 69e3cea8d5fd526 ("powerpc/smp: Make start_secondary_resume
available to all CPU variants") introduced start_secondary_resume to
misc_32.S, however it uses a 64-bit instruction which is not valid on
32-bit platforms. Use 'stw' instead.
Reported-by: Richard Cochran <richardcochran@gmail.com>
Tested-by: Richard Cochran <richardcochran@gmail.com>
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
