For 'perf sched map' output, determine max_cpu automatically,
instead of the static default of 15.
[ v2: use sysconf() pointed out by Arjan van de Ven <arjan@infradead.org> ]
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <new-submission>
I noticed that perf-record continues profiling itself after the
child terminated and we're draining the buffer.
This can cause a _lot_ of overhead with --all recording - we keep
and keep recording, which produces new and new events.
Currently we wake the mmap() consumer once every PAGE_SIZE of data
and/or once event wakeup_events when specified.
For high speed sampling this results in too many wakeups wrt. the
buffer size, hence change this.
We move the default wakeup limit to 1/4-th the buffer size, and
provide for means to manually specify this limit.
We can have swcounter events that contribute more than a single
count per event, when used with a non-zero period, those can
generate multiple events, which is when we need throttling.
However, swcounter that contribute only a single count per event
can only come as fast as we can run code, hence don't throttle
them.
This prints a textual context-switching outline of workload
captured via perf sched record.
For example, on a 16 CPU box it outputs:
N1 O1 . . . S1 . . . B0 . *I0 C1 . M1 . 23002.773423 secs
N1 O1 . *Q0 . S1 . . . B0 . I0 C1 . M1 . 23002.773423 secs
N1 O1 . Q0 . S1 . . . B0 . *R1 C1 . M1 . 23002.773485 secs
N1 O1 . Q0 . S1 . *S0 . B0 . R1 C1 . M1 . 23002.773478 secs
*L0 O1 . Q0 . S1 . S0 . B0 . R1 C1 . M1 . 23002.773523 secs
L0 O1 . *. . S1 . S0 . B0 . R1 C1 . M1 . 23002.773531 secs
L0 O1 . . . S1 . S0 . B0 . R1 C1 *T1 M1 . 23002.773547 secs T1 => irqbalance:2089
L0 O1 . . . S1 . S0 . *P0 . R1 C1 T1 M1 . 23002.773549 secs
*N1 O1 . . . S1 . S0 . P0 . R1 C1 T1 M1 . 23002.773566 secs
N1 O1 . . . *J0 . S0 . P0 . R1 C1 T1 M1 . 23002.773571 secs
N1 O1 . . . J0 . S0 *B0 P0 . R1 C1 T1 M1 . 23002.773592 secs
N1 O1 . . . J0 . *U0 B0 P0 . R1 C1 T1 M1 . 23002.773582 secs
N1 O1 . . . *S1 . U0 B0 P0 . R1 C1 T1 M1 . 23002.773604 secs
N1 O1 . . . S1 . U0 B0 *. . R1 C1 T1 M1 . 23002.773615 secs
N1 O1 . . . S1 . U0 B0 . . *K0 C1 T1 M1 . 23002.773631 secs
N1 O1 . *M0 . S1 . U0 B0 . . K0 C1 T1 M1 . 23002.773624 secs
N1 O1 . M0 . S1 . U0 *. . . K0 C1 T1 M1 . 23002.773644 secs
N1 O1 . M0 . S1 . U0 . . . *R1 C1 T1 M1 . 23002.773662 secs
N1 O1 . M0 . S1 . *. . . . R1 C1 T1 M1 . 23002.773648 secs
N1 O1 . *. . S1 . . . . . R1 C1 T1 M1 . 23002.773680 secs
N1 O1 . . . *L0 . . . . . R1 C1 T1 M1 . 23002.773717 secs
*N0 O1 . . . L0 . . . . . R1 C1 T1 M1 . 23002.773709 secs
*N1 O1 . . . L0 . . . . . R1 C1 T1 M1 . 23002.773747 secs
Columns stand for individual CPUs, from CPU0 to CPU15, and the
two-letter shortcuts stand for tasks that are running on a CPU.
'*' denotes the CPU that had the event.
A dot signals an idle CPU.
New tasks are assigned new two-letter shortcuts - when they occur
first they are printed. In the above example 'T1' stood for irqbalance:
Peter noticed that we have 3 ways of referring to the idle thread:
[idle]:0
swapper:0
swapper-0
Standardize on 'swapper:0'.
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Use 'perf sched latency' to track the current task based on
context-switch events, and flag the cases where there's some
impossible transition: such as a PID being switched out that
was not switched in.
Output such lost event and state machine weirdness stats:
TOTAL: | 14974.910 ms | 46384 |
INFO: 8.865% lost events (19132 out of 215819, in 8 chunks)
INFO: 0.198% state machine bugs (49 out of 24708) (due to lost events?)
And increase buffering to -m 1024 (4 MB) by default. Since we
use output multiplexing that kind of space is needed.
This allows more precise 'perf sched latency' output:
Task | Runtime ms | Switches | Average delay ms | Maximum delay ms |
ksoftirqd/0-4 | 0.010 ms | 2 | avg: 2.476 ms | max: 2.977 ms |
perf-12328 | 15.844 ms | 66 | avg: 1.118 ms | max: 9.979 ms |
bdi-default-235 | 0.009 ms | 1 | avg: 0.998 ms | max: 0.998 ms |
events/1-8 | 0.020 ms | 2 | avg: 0.998 ms | max: 0.998 ms |
events/0-7 | 0.018 ms | 2 | avg: 0.992 ms | max: 0.996 ms |
sleep-12329 | 0.742 ms | 3 | avg: 0.906 ms | max: 2.289 ms |
sshd-12122 | 0.163 ms | 2 | avg: 0.283 ms | max: 0.562 ms |
loop-getpid-lon-12322 | 1023.636 ms | 69 | avg: 0.208 ms | max: 5.996 ms |
loop-getpid-lon-12321 | 1038.638 ms | 5 | avg: 0.073 ms | max: 0.171 ms |
migration/1-5 | 0.000 ms | 1 | avg: 0.006 ms | max: 0.006 ms |
TOTAL: | 2079.078 ms | 153 |
Also, streamline the code a bit more, add asserts for various state
machine failures (they should be debugged if they occur) and fix
a few odd ends.
Often it's useful to know the PID of the task as well - print it
out too.
( While at it, reformat the output to be a bit more
paste-into-commit-logs friendly. )
Before:
perf |4853313.251 ms | 10 | avg: 0.046 ms | max: 0.337 ms |
flush-8:0 |2426659.202 ms | 5 | avg: 0.015 ms | max: 0.016 ms |
sleep |485331.966 ms | 1 | avg: 0.012 ms | max: 0.012 ms |
ksoftirqd/1 |485331.320 ms | 1 | avg: 0.005 ms | max: 0.005 ms |
TOTAL: |8250635.739 ms | 17 |
After:
perf | 0.206 ms | 10 | avg: 0.046 ms | max: 0.337 ms |
flush-8:0 | 2.680 ms | 5 | avg: 0.015 ms | max: 0.016 ms |
sleep | 0.662 ms | 1 | avg: 0.012 ms | max: 0.012 ms |
ksoftirqd/1 | 0.015 ms | 1 | avg: 0.005 ms | max: 0.005 ms |
TOTAL: | 3.563 ms | 17 |
Finish the -M/--multiplex option implementation:
- separate it out from group_fd
- correctly set it via the ioctl and dont mmap counters that
are multiplexed
- modify the perf record event loop to deal with buffer-less
counters.
- remove the -g option from perf sched record
- account for unordered events in perf sched latency
- (add -f to perf sched record to ease measurements)
- skip idle threads (pid==0) in latency output
The result is better latency output by 'perf sched latency':
ksoftirqd/8 | 0.071 ms | 2 | avg: 0.458 ms | max: 0.913 ms |
at-spi-registry | 0.609 ms | 19 | avg: 0.013 ms | max: 0.023 ms |
perf | 3.316 ms | 16 | avg: 0.013 ms | max: 0.054 ms |
Xorg | 0.392 ms | 19 | avg: 0.011 ms | max: 0.018 ms |
sleep | 0.537 ms | 2 | avg: 0.009 ms | max: 0.009 ms |
TOTAL: | 4.925 ms | 58 |
Currently it's possible to meet such too high latency results
with 'perf sched latency'.
xfce4-panel | 0.222 ms | 2 | avg: 4718.345 ms | max: 9436.493 ms |
scsi_eh_3 | 3.962 ms | 36 | avg: 55.957 ms | max: 1977.829 ms |
The origin is on traces that are sometimes badly serialized across cpus.
For example the raw traces that raised such results for xfce4-panel:
(1) [init]-0 [000] 1494.663899990: sched_switch: task swapper:0 [140] (R) ==> xfce4-panel:4569 [120]
(2) xfce4-panel-4569 [000] 1494.663928373: sched_switch: task xfce4-panel:4569 [120] (S) ==> swapper:0 [140]
(3) Xorg-4276 [001] 1494.663860125: sched_wakeup: task xfce4-panel:4569 [120] success=1 [000]
(4) Xorg-4276 [001] 1504.098252756: sched_wakeup: task xfce4-panel:4569 [120] success=1 [000]
(5) perf-5219 [000] 1504.100353302: sched_switch: task perf:5219 [120] (S) ==> xfce4-panel:4569 [120]
The traces are processed in the order they arrive. Then in (2),
xfce4-panel sleeps, it is first waken up in (3) and eventually
scheduled in (5).
The latency reported is then 1504 - 1495 = 9 secs, as reported by perf
sched. But this is wrong, we are confident in the fact the traces are
nicely serialized while we should actually more trust the timestamps.
If we reorder by timestamps we get:
(1) Xorg-4276 [001] 1494.663860125: sched_wakeup: task xfce4-panel:4569 [120] success=1 [000]
(2) [init]-0 [000] 1494.663899990: sched_switch: task swapper:0 [140] (R) ==> xfce4-panel:4569 [120]
(3) xfce4-panel-4569 [000] 1494.663928373: sched_switch: task xfce4-panel:4569 [120] (S) ==> swapper:0 [140]
Now the trace make more sense, xfce4-panel is sleeping. Then it is
woken up in (1), scheduled in (2)
It goes to sleep in (3), woken up in (4) and scheduled in (5).
Now, latency captured between (1) and (2) is of 39 us.
And between (4) and (5) it is 2.1 ms.
Such pattern of bad serializing is the origin of the high latencies
reported by perf sched.
Basically, we need to check whether wake up time is higher than
schedule out time. If it's not the case, we need to tag the current
work atom as invalid.
Beside that, we may need to work later on a better ordering of the
traces given by the kernel.
After this patch:
xfce4-session | 0.221 ms | 1 | avg: 0.538 ms | max: 0.538 ms |
Add an option to multiplex counters output in the channel of
the group leader, ie: the first counter opened:
-M --multiplex
The effect is better serialized samples. This is especially
useful for tracepoint samples that need to be well serialized
for their post-processing.
Also make use of this option in 'perf sched'.
This allows more precise tracking of how the scheduler accounts
(and acts upon) a task having spent N nanoseconds of CPU time.
Alias 'perf sched trace' to 'perf trace', for workflow completeness.
Add a bit of documentation for perf sched.
Before:
$ perf sched record -f sleep 1
Error: failed to mmap with 1 (Operation not permitted)
After:
[ perf record: Captured and wrote 0.095 MB perf.data (~4161 samples) ]
Note, this is only allowed if perfcounter_paranoid is set to
the most permissive (non-default) value of -1.
Implement the 'perf sched record' subcommand that adds a
default list of events, turns on raw sampling and system-wide
tracing and passes off the rest of the command to perf record.
This is more convenient than having to specify the events all
the time.
Before:
$ perf record -a -R -e sched:sched_switch:r -e sched:sched_stat_wait:r -e sched:sched_stat_sleep:r -e sched:sched_stat_iowait:r -e sched:sched_process_exit:r -e sched:sched_process_fork:r -e sched:sched_wakeup:r -e sched:sched_migrate_task:r -c 1 sleep 1
After:
Also fix an assumption in the event string parser that assumed
that strings passed in can be modified. (In this case they wont
be as they come from a readonly constant section.)
Use a sort list for thread atoms insertion as well - instead of
hardcoded for PID.
- Rename 'latency' field/variable names to the better 'atom' ones
- Reduce the number of #include lines and consolidate them
- Gather file scope variables at the top of the file
- Remove unused bits
No change in functionality.
Separate the option parsing cleanly and add two variants:
- 'perf sched latency' (can be abbreviated via 'perf sched lat')
- 'perf sched replay' (can be abbreviated via 'perf sched rep')
Also add a repeat count option to replay and add a separation
set of options for replay.
Do the sorting setup only in the latency sub-command.
Display separate help screens for 'perf sched' and
'perf sched replay -h' - i.e. further separation of the
sub-commands.
Implement multidimensional sorting on perf sched so that
you can sort either by number of switches, latency average,
latency maximum, runtime.
perf sched -l -s avg,max (this is the default)
gnome-power-man | 0.113 ms | 1 | avg: 4998.531 ms | max: 4998.531 ms |
xfdesktop | 1.190 ms | 7 | avg: 136.475 ms | max: 940.933 ms |
xfce-mcs-manage | 2.194 ms | 22 | avg: 38.534 ms | max: 735.174 ms |
notification-da | 2.749 ms | 31 | avg: 27.436 ms | max: 731.791 ms |
xfce4-session | 3.343 ms | 28 | avg: 26.796 ms | max: 734.891 ms |
xfwm4 | 3.159 ms | 22 | avg: 12.406 ms | max: 241.333 ms |
xchat | 42.789 ms | 214 | avg: 11.886 ms | max: 100.349 ms |
xfce4-terminal | 5.386 ms | 22 | avg: 11.414 ms | max: 241.611 ms |
firefox | 151.992 ms | 123 | avg: 9.543 ms | max: 153.717 ms |
xfce4-panel | 24.324 ms | 47 | avg: 8.189 ms | max: 242.352 ms |
:5090 | 6.932 ms | 111 | avg: 8.131 ms | max: 102.665 ms |
events/0 | 0.758 ms | 12 | avg: 1.964 ms | max: 21.879 ms |
Xorg | 280.558 ms | 340 | avg: 1.864 ms | max: 99.526 ms |
geany | 63.391 ms | 295 | avg: 1.099 ms | max: 9.334 ms |
reiserfs/0 | 0.039 ms | 2 | avg: 0.854 ms | max: 1.487 ms |
kondemand/0 | 8.251 ms | 245 | avg: 0.691 ms | max: 34.372 ms |
We are dividing a time in ns by 1e9. This is a nsec to sec
conversion. What we want is msecs. Fix it by dividing by 1e6.
Add a field in the thread atom list that keeps track of the
total and max latencies and also the total runtime. This makes
a faster output and also prepares for sorting.
Currently in perf sched, we are measuring the scheduler wakeup
latencies.
Now we also want measure the time a task wait to be scheduled
after it gets preempted.
To measures the latencies, we capture the sched atoms data into
a specific structure named struct lat_snapshot.
As this structure can be used for other purposes of scheduler
profiling and mirrors what happens in a thread work atom, lets
rename it to struct work_atom and propagate this renaming in
other functions and structures names to keep it coherent.
After:
make | 0.678 ms | 13 | avg: 0.018 ms | max: 0.050 ms |
gcc | 0.014 ms | 2 | avg: 0.320 ms | max: 0.627 ms |
gcc | 0.000 ms | 2 | avg: 0.185 ms | max: 0.369 ms |
TOTAL: | 21.316 ms | 63 |
Extend the latency tracking structure with scheduling atom
runtime info - and sum it up during per task display.
(Also clean up a few details.)
After:
Task | runtime ms | switches | average delay ms | maximum delay ms |
migration/0 | 0.000 ms | 1 | avg: 0.047 ms | max: 0.047 ms |
ksoftirqd/0 | 0.000 ms | 1 | avg: 0.039 ms | max: 0.039 ms |
migration/1 | 0.000 ms | 3 | avg: 0.013 ms | max: 0.016 ms |
migration/3 | 0.000 ms | 2 | avg: 0.003 ms | max: 0.004 ms |
migration/4 | 0.000 ms | 1 | avg: 0.022 ms | max: 0.022 ms |
distccd | 0.000 ms | 1 | avg: 0.004 ms | max: 0.004 ms |
distccd | 0.000 ms | 1 | avg: 0.014 ms | max: 0.014 ms |
distccd | 0.000 ms | 2 | avg: 0.000 ms | max: 0.000 ms |
distccd | 0.000 ms | 2 | avg: 0.012 ms | max: 0.019 ms |
distccd | 0.000 ms | 1 | avg: 0.002 ms | max: 0.002 ms |
as | 0.000 ms | 2 | avg: 0.019 ms | max: 0.019 ms |
as | 0.000 ms | 3 | avg: 0.015 ms | max: 0.017 ms |
as | 0.000 ms | 1 | avg: 0.009 ms | max: 0.009 ms |
perf | 0.000 ms | 1 | avg: 0.001 ms | max: 0.001 ms |
gcc | 0.000 ms | 1 | avg: 0.021 ms | max: 0.021 ms |
run-mozilla.sh | 0.000 ms | 2 | avg: 0.010 ms | max: 0.017 ms |
mozilla-plugin- | 0.000 ms | 1 | avg: 0.006 ms | max: 0.006 ms |
gcc | 0.000 ms | 2 | avg: 0.013 ms | max: 0.013 ms |
(The runtime ms column is not filled in yet.)
- Separate the latency and the replay commands more cleanly
- Use consistent naming
- Display help page on 'perf sched' outlining comments,
instead of aborting
Add the -l --latency option that reports statistics about the
scheduler latencies.
For now, the latencies are measured in the following sequence
scope:
- task A is sleeping (D or S state)
- task B wakes up A
latency timeframe
v
- task A is scheduled in
Start by recording every scheduler events:
perf record -e sched:*
and then fetch the results:
perf sched -l
Tasks count total avg max
migration/0 2 39849 19924 28826
ksoftirqd/0 7 756383 108054 373014
migration/1 5 45391 9078 10452
ksoftirqd/1 2 399055 199527 359130
events/0 8 4780110 597513 4500250
events/1 9 6353057 705895 2986012
kblockd/0 42 37805097 900121 5077684
The snapshot are in nanoseconds.
- Count: number of snapshots taken for the given task
- Total: total latencies in nanosec
- Avg : average of latency between wake up and sched in
- Max : max snapshot latency
Create a sched event structure of handlers in which various
sched events reader can plug their own callbacks.
This makes easier the addition of new perf sched sub commands.
perf sched raises the following error when it meets a sched
switch event:
perf: builtin-sched.c:286: register_pid: Assertion `!(pid >= 65536)' failed.
Abandon
Currently in x86-64, the sched switch events have a hole in the
middle of the structure:
u16 common_type;
u8 common_flags;
u8 common_preempt_count;
u32 common_pid;
u32 common_tgid;
char prev_comm[16];
u32 prev_pid;
u32 prev_prio;
<--- there
u64 prev_state;
char next_comm[16];
u32 next_pid;
u32 next_prio;
Gcc inserts a 4 bytes hole there for prev_state to be u64
aligned. And the events are exported to userspace with this
hole.
But in userspace, from perf sched, we fetch it using a
structure that has a new field in the beginning: u32 size. This
is because our trace is exported with its size as a field. But
now that we have this new field, the hole in the middle
disappears because it makes prev_state becoming well aligned.
And since we are using a pointer to the raw trace using this
struct, instead of reading prev_state, we are reading the hole.
We could fix it by keeping the size seperate from the struct
but actually there a lot of other potential problems: some
fields may be saved as long in a 64 bits system and later read
as long in a 32 bits system. Also this direct cast doesn't care
about the endianness differences between the host traced
machine and the machine in which we do the post processing.
So instead of using such dangerous direct casts, fetch the
values using the trace parsing API that already takes care of
all these problems.
Currently, when one wants to activate every tracepoint
counters of a subsystem from perf record, the current sequence
is needed:
perf record -e subsys:ev1 -e subsys:ev2 -e subsys:ev3
This may annoy the most patient of us.
Now we can just do:
perf record -e subsys:*
Various small cleanups - removal of debug printks and dead
functions, etc.
Integrate the schedbench.c bits with the raw trace events
that we get from the perf machinery, and activate the
workload replayer/simulator.
Example of a captured 'make -j' workload:
$ perf sched
run measurement overhead: 90 nsecs
sleep measurement overhead: 2724743 nsecs
the run test took 1000081 nsecs
the sleep test took 2981111 nsecs
version = 0.5
nr_run_events: 70
nr_sleep_events: 66
nr_wakeup_events: 9
target-less wakeups: 71
multi-target wakeups: 47
run events optimized: 139
task 0 ( perf: 6607), nr_events: 2
task 1 ( perf: 6608), nr_events: 6
task 2 ( : 0), nr_events: 1
task 3 ( make: 6609), nr_events: 5
task 4 ( sh: 6610), nr_events: 4
task 5 ( make: 6611), nr_events: 6
task 6 ( sh: 6612), nr_events: 4
task 7 ( make: 6613), nr_events: 5
task 8 ( migration/11: 25), nr_events: 1
task 9 ( migration/13: 29), nr_events: 1
task 10 ( migration/15: 33), nr_events: 1
task 11 ( migration/9: 21), nr_events: 1
task 12 ( sh: 6614), nr_events: 4
task 13 ( make: 6615), nr_events: 5
task 14 ( sh: 6616), nr_events: 4
task 15 ( make: 6617), nr_events: 7
task 16 ( migration/3: 9), nr_events: 1
task 17 ( migration/5: 13), nr_events: 1
task 18 ( migration/7: 17), nr_events: 1
task 19 ( migration/1: 5), nr_events: 1
task 20 ( sh: 6618), nr_events: 4
task 21 ( make: 6619), nr_events: 5
task 22 ( sh: 6620), nr_events: 4
task 23 ( make: 6621), nr_events: 10
task 24 ( sh: 6623), nr_events: 3
task 25 ( gcc: 6624), nr_events: 4
task 26 ( gcc: 6625), nr_events: 4
task 27 ( gcc: 6626), nr_events: 5
task 28 ( collect2: 6627), nr_events: 5
task 29 ( sh: 6622), nr_events: 1
task 30 ( make: 6628), nr_events: 7
task 31 ( sh: 6630), nr_events: 4
task 32 ( gcc: 6631), nr_events: 4
task 33 ( sh: 6629), nr_events: 1
task 34 ( gcc: 6632), nr_events: 4
task 35 ( gcc: 6633), nr_events: 4
task 36 ( collect2: 6634), nr_events: 4
task 37 ( make: 6635), nr_events: 8
task 38 ( sh: 6637), nr_events: 4
task 39 ( sh: 6636), nr_events: 1
task 40 ( gcc: 6638), nr_events: 4
task 41 ( gcc: 6639), nr_events: 4
task 42 ( gcc: 6640), nr_events: 4
task 43 ( collect2: 6641), nr_events: 4
task 44 ( make: 6642), nr_events: 6
task 45 ( sh: 6643), nr_events: 5
task 46 ( sh: 6644), nr_events: 3
task 47 ( sh: 6645), nr_events: 4
task 48 ( make: 6646), nr_events: 6
task 49 ( sh: 6647), nr_events: 3
task 50 ( make: 6648), nr_events: 5
task 51 ( sh: 6649), nr_events: 5
task 52 ( sh: 6650), nr_events: 6
task 53 ( make: 6651), nr_events: 4
task 54 ( make: 6652), nr_events: 5
task 55 ( make: 6653), nr_events: 4
task 56 ( make: 6654), nr_events: 4
task 57 ( make: 6655), nr_events: 5
task 58 ( sh: 6656), nr_events: 4
task 59 ( gcc: 6657), nr_events: 9
task 60 ( ksoftirqd/3: 10), nr_events: 1
task 61 ( gcc: 6658), nr_events: 4
task 62 ( make: 6659), nr_events: 5
task 63 ( sh: 6660), nr_events: 3
task 64 ( gcc: 6661), nr_events: 5
task 65 ( collect2: 6662), nr_events: 4
#1 : 256.745, ravg: 256.74, cpu: 0.00 / 0.00
#2 : 439.372, ravg: 275.01, cpu: 0.00 / 0.00
#3 : 411.971, ravg: 288.70, cpu: 0.00 / 0.00
#4 : 385.500, ravg: 298.38, cpu: 0.00 / 0.00
#5 : 366.526, ravg: 305.20, cpu: 0.00 / 0.00
#6 : 381.281, ravg: 312.81, cpu: 0.00 / 0.00
#7 : 410.756, ravg: 322.60, cpu: 0.00 / 0.00
#8 : 368.009, ravg: 327.14, cpu: 0.00 / 0.00
#9 : 408.098, ravg: 335.24, cpu: 0.00 / 0.00
#10 : 368.582, ravg: 338.57, cpu: 0.00 / 0.00
I.e. we successfully analyzed the trace, replayed it
via real threads and measured the replayed workload's
scheduling properties.
This is how it looked like in 'top' output:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
7164 mingo 20 0 1434m 8080 888 R 57.0 0.1 0:02.04 :perf
7165 mingo 20 0 1434m 8080 888 R 41.8 0.1 0:01.52 :perf
7228 mingo 20 0 1434m 8080 888 R 39.8 0.1 0:01.44 :gcc
7225 mingo 20 0 1434m 8080 888 R 33.8 0.1 0:01.26 :gcc
7202 mingo 20 0 1434m 8080 888 R 31.2 0.1 0:01.16 :sh
7222 mingo 20 0 1434m 8080 888 R 25.2 0.1 0:00.96 :sh
7211 mingo 20 0 1434m 8080 888 R 21.9 0.1 0:00.82 :sh
7213 mingo 20 0 1434m 8080 888 D 19.2 0.1 0:00.74 :sh
7194 mingo 20 0 1434m 8080 888 D 18.6 0.1 0:00.72 :make
There's still various kinks in it - more patches to come.
Import the schedbench.c tool that i wrote some time ago to
simulate scheduler behavior but never finished. It's a good
basis for perf sched nevertheless.
Most of its guts are not hooked up to the perf event loop
yet - that will be done in the patches to come.
This turn-key tool allows scheduler measurements to be
conducted and the results be displayed numerically.
First baby step towards that goal: clone the new command off of
perf trace.
Fix a few other details along the way:
- add (minimal) perf trace documentation
- reorder a few places
- list perf trace in the mainporcelain list as well
as it's a very useful utility.
* git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (87 commits)
NFSv4: Disallow 'mount -t nfs4 -overs=2' and 'mount -t nfs4 -overs=3'
NFS: Allow the "nfs" file system type to support NFSv4
NFS: Move details of nfs4_get_sb() to a helper
NFS: Refactor NFSv4 text-based mount option validation
NFS: Mount option parser should detect missing "port="
NFS: out of date comment regarding O_EXCL above nfs3_proc_create()
NFS: Handle a zero-length auth flavor list
SUNRPC: Ensure that sunrpc gets initialised before nfs, lockd, etc...
nfs: fix compile error in rpc_pipefs.h
nfs: Remove reference to generic_osync_inode from a comment
SUNRPC: cache must take a reference to the cache detail's module on open()
NFS: Use the DNS resolver in the mount code.
NFS: Add a dns resolver for use with NFSv4 referrals and migration
SUNRPC: Fix a typo in cache_pipefs_files
nfs: nfs4xdr: optimize low level decoding
nfs: nfs4xdr: get rid of READ_BUF
nfs: nfs4xdr: simplify decode_exchange_id by reusing decode_opaque_inline
nfs: nfs4xdr: get rid of COPYMEM
nfs: nfs4xdr: introduce decode_sessionid helper
nfs: nfs4xdr: introduce decode_verifier helper
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: (25 commits)
pata_rz1000: use printk_once
ahci: kill @force_restart and refine CLO for ahci_kick_engine()
pata_cs5535: add pci id for AMD based CS5535 controllers
ahci: Add AMD SB900 SATA/IDE controller device IDs
drivers/ata: use resource_size
sata_fsl: Defer non-ncq commands when ncq commands active
libata: add SATA PMP revision information for spec 1.2
libata: fix off-by-one error in ata_tf_read_block()
ahci: Gigabyte GA-MA69VM-S2 can't do 64bit DMA
ahci: make ahci_asus_m2a_vm_32bit_only() quirk more generic
dmi: extend dmi_get_year() to dmi_get_date()
dmi: fix date handling in dmi_get_year()
libata: unbreak TPM filtering by reorganizing ata_scsi_pass_thru()
sata_sis: convert to slave_link
sata_sil24: always set protocol override for non-ATAPI data commands
libata: Export AHCI capabilities
libata: Delegate nonrot flag setting to SCSI
[libata] Add pata_rdc driver for RDC ATA devices
drivers/ata: Remove unnecessary semicolons
libata: remove spindown skipping and warning
* 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (105 commits)
ring-buffer: only enable ring_buffer_swap_cpu when needed
ring-buffer: check for swapped buffers in start of committing
tracing: report error in trace if we fail to swap latency buffer
tracing: add trace_array_printk for internal tracers to use
tracing: pass around ring buffer instead of tracer
tracing: make tracing_reset safe for external use
tracing: use timestamp to determine start of latency traces
tracing: Remove mentioning of legacy latency_trace file from documentation
tracing/filters: Defer pred allocation, fix memory leak
tracing: remove users of tracing_reset
tracing: disable buffers and synchronize_sched before resetting
tracing: disable update max tracer while reading trace
tracing: print out start and stop in latency traces
ring-buffer: disable all cpu buffers when one finds a problem
ring-buffer: do not count discarded events
ring-buffer: remove ring_buffer_event_discard
ring-buffer: fix ring_buffer_read crossing pages
ring-buffer: remove unnecessary cpu_relax
ring-buffer: do not swap buffers during a commit
ring-buffer: do not reset while in a commit
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (64 commits)
sched: Fix sched::sched_stat_wait tracepoint field
sched: Disable NEW_FAIR_SLEEPERS for now
sched: Keep kthreads at default priority
sched: Re-tune the scheduler latency defaults to decrease worst-case latencies
sched: Turn off child_runs_first
sched: Ensure that a child can't gain time over it's parent after fork()
sched: enable SD_WAKE_IDLE
sched: Deal with low-load in wake_affine()
sched: Remove short cut from select_task_rq_fair()
sched: Turn on SD_BALANCE_NEWIDLE
sched: Clean up topology.h
sched: Fix dynamic power-balancing crash
sched: Remove reciprocal for cpu_power
sched: Try to deal with low capacity, fix update_sd_power_savings_stats()
sched: Scale down cpu_power due to RT tasks
sched: Implement dynamic cpu_power
sched: Add smt_gain
sched: Update the cpu_power sum during load-balance
sched: Add SD_PREFER_SIBLING
* 'perfcounters-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (60 commits)
perf tools: Avoid unnecessary work in directory lookups
perf stat: Clean up statistics calculations a bit more
perf stat: More advanced variance computation
perf stat: Use stddev_mean in stead of stddev
perf stat: Remove the limit on repeat
perf stat: Change noise calculation to use stddev
x86, perf_counter, bts: Do not allow kernel BTS tracing for now
x86, perf_counter, bts: Correct pointer-to-u64 casts
x86, perf_counter, bts: Fail if BTS is not available
perf_counter: Fix output-sharing error path
perf trace: Fix read_string()
perf trace: Print out in nanoseconds
perf tools: Seek to the end of the header area
perf trace: Fix parsing of perf.data
perf trace: Sample timestamps as well
perf_counter: Introduce new (non-)paranoia level to allow raw tracepoint access
perf trace: Sample the CPU too
perf tools: Work around strict aliasing related warnings
perf tools: Clean up warnings list in the Makefile
perf tools: Complete support for dynamic strings
* 'oprofile-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (55 commits)
arch/x86/oprofile/op_model_amd.c: fix op_amd_handle_ibs() return type
Revert "x86: oprofile/op_model_amd.c set return values for op_amd_handle_ibs()"
x86/oprofile: Small coding style fixes
x86/oprofile: Add counter reservation check for virtual counters
x86/oprofile: Implement op_x86_virt_to_phys()
oprofile: Adding switch counter to oprofile statistic variables
x86/oprofile: Implement mux_clone()
x86/oprofile: Enable multiplexing only if the model supports it
x86/oprofile: Add function has_mux() to check multiplexing support
x86/oprofile: Modify initialization of num_virt_counters
x86/oprofile: Remove unused num_virt_controls from struct op_x86_model_spec
x86/oprofile: Remove const qualifier from struct op_x86_model_spec
x86/oprofile: Moving nmi_cpu_switch() in nmi_int.c
x86/oprofile: Moving nmi_cpu_save/restore_mpx_registers() in nmi_int.c
x86/oprofile: Moving nmi_setup_cpu_mux() in nmi_int.c
x86/oprofile: Implement multiplexing setup/shutdown functions
oprofile: Grouping multiplexing code in op_model_amd.c
oprofile: Introduce op_x86_phys_to_virt()
oprofile: Grouping multiplexing code in oprof.c
oprofile: Remove oprofile_multiplexing_init()
* 'irq-threaded-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
genirq: Do not mask oneshot edge type interrupts
genirq: Support nested threaded irq handling
genirq: Add buslock support
genirq: Add oneshot support
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
pci/intr_remapping: Allocate irq_iommu on node
irq: Add irq_node() primitive
irq: Make sure irq_desc for legacy irq get correct node setting
genirq: Add prototype for handle_nested_irq()
irq: Remove superfluous NULL pointer check in check_irq_resend()
irq: Clean up by removing irqfixup MODULE_PARM_DESC()
genirq: Fix comment describing suspend_device_irqs()
genirq: Remove obsolete defines and typedefs
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (28 commits)
rcu: Move end of special early-boot RCU operation earlier
rcu: Changes from reviews: avoid casts, fix/add warnings, improve comments
rcu: Create rcutree plugins to handle hotplug CPU for multi-level trees
rcu: Remove lockdep annotations from RCU's _notrace() API members
rcu: Add #ifdef to suppress __rcu_offline_cpu() warning in !HOTPLUG_CPU builds
rcu: Add CPU-offline processing for single-node configurations
rcu: Add "notrace" to RCU function headers used by ftrace
rcu: Remove CONFIG_PREEMPT_RCU
rcu: Merge preemptable-RCU functionality into hierarchical RCU
rcu: Simplify rcu_pending()/rcu_check_callbacks() API
rcu: Use debugfs_remove_recursive() simplify code.
rcu: Merge per-RCU-flavor initialization into pre-existing macro
rcu: Fix online/offline indication for rcudata.csv trace file
rcu: Consolidate sparse and lockdep declarations in include/linux/rcupdate.h
rcu: Renamings to increase RCU clarity
rcu: Move private definitions from include/linux/rcutree.h to kernel/rcutree.h
rcu: Expunge lingering references to CONFIG_CLASSIC_RCU, optimize on !SMP
rcu: Delay rcu_barrier() wait until beginning of next CPU-hotunplug operation.
rcu: Fix typo in rcu_irq_exit() comment header
rcu: Make rcupreempt_trace.c look at offline CPUs
* 'core-printk-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
printk: Fix "printk: Enable the use of more than one CON_BOOT (early console)"
printk: Restore previous console_loglevel when re-enabling logging
printk: Ensure that "console enabled" messages are printed on the console
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (32 commits)
locking, m68k/asm-offsets: Rename signal defines
locking: Inline spinlock code for all locking variants on s390
locking: Simplify spinlock inlining
locking: Allow arch-inlined spinlocks
locking: Move spinlock function bodies to header file
locking, m68k: Calculate thread_info offset with asm offset
locking, m68k/asm-offsets: Rename pt_regs offset defines
locking, sparc: Rename __spin_try_lock() and friends
locking, powerpc: Rename __spin_try_lock() and friends
lockdep: Remove recursion stattistics
lockdep: Simplify lock_stat seqfile code
lockdep: Simplify lockdep_chains seqfile code
lockdep: Simplify lockdep seqfile code
lockdep: Fix missing entries in /proc/lock_chains
lockdep: Fix missing entry in /proc/lock_stat
lockdep: Fix memory usage info of BFS
lockdep: Reintroduce generation count to make BFS faster
lockdep: Deal with many similar locks
lockdep: Introduce lockdep_assert_held()
lockdep: Fix style nits
* 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (59 commits)
x86/gart: Do not select AGP for GART_IOMMU
x86/amd-iommu: Initialize passthrough mode when requested
x86/amd-iommu: Don't detach device from pt domain on driver unbind
x86/amd-iommu: Make sure a device is assigned in passthrough mode
x86/amd-iommu: Align locking between attach_device and detach_device
x86/amd-iommu: Fix device table write order
x86/amd-iommu: Add passthrough mode initialization functions
x86/amd-iommu: Add core functions for pd allocation/freeing
x86/dma: Mark iommu_pass_through as __read_mostly
x86/amd-iommu: Change iommu_map_page to support multiple page sizes
x86/amd-iommu: Support higher level PTEs in iommu_page_unmap
x86/amd-iommu: Remove old page table handling macros
x86/amd-iommu: Use 2-level page tables for dma_ops domains
x86/amd-iommu: Remove bus_addr check in iommu_map_page
x86/amd-iommu: Remove last usages of IOMMU_PTE_L0_INDEX
x86/amd-iommu: Change alloc_pte to support 64 bit address space
x86/amd-iommu: Introduce increase_address_space function
x86/amd-iommu: Flush domains if address space size was increased
x86/amd-iommu: Introduce set_dte_entry function
x86/amd-iommu: Add a gneric version of amd_iommu_flush_all_devices
