2010-10-11Fix migration.c compilation on s390Andi Kleen
31bit s390 doesn't have huge pages and failed with: > mm/migrate.c: In function 'remove_migration_pte': > mm/migrate.c:143:3: error: implicit declaration of function 'pte_mkhuge' > mm/migrate.c:143:7: error: incompatible types when assigning to type 'pte_t' from type 'int' Put that code into a ifdef. Reported by Heiko Carstens Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08x86: HWPOISON: Report correct address granuality for huge hwpoison faultsAndi Kleen
An earlier patch fixed the hwpoison fault handling to encode the huge page size in the fault code of the page fault handler. This is needed to report this information in SIGBUS to user space. This is a straight forward patch to pass this information through to the signal handling in the x86 specific fault.c Cc: x86@kernel.org Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: fengguang.wu@intel.com Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08Encode huge page size for VM_FAULT_HWPOISON errorsAndi Kleen
This fixes a problem introduced with the hugetlb hwpoison handling The user space SIGBUS signalling wants to know the size of the hugepage that caused a HWPOISON fault. Unfortunately the architecture page fault handlers do not have easy access to the struct page. Pass the information out in the fault error code instead. I added a separate VM_FAULT_HWPOISON_LARGE bit for this case and encode the hpage index in some free upper bits of the fault code. The small page hwpoison keeps stays with the VM_FAULT_HWPOISON name to minimize changes. Also add code to hugetlb.h to convert that index into a page shift. Will be used in a further patch. Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: fengguang.wu@intel.com Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08Fix build error with !CONFIG_MIGRATIONNaoya Horiguchi
migrate_huge_page_move_mapping() is declared as "extern int ..." in include/linux/migrate.h for !CONFIG_MIGRATION, which causes the build error like below: mm/mprotect.o: In function `migrate_huge_page_move_mapping': mprotect.c:(.text+0x0): multiple definition of `migrate_huge_page_move_mapping' mm/shmem.o:shmem.c:(.text+0x0): first defined here mm/rmap.o: In function `migrate_huge_page_move_mapping': rmap.c:(.text+0x0): multiple definition of `migrate_huge_page_move_mapping' mm/shmem.o:shmem.c:(.text+0x0): first defined here Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08hugepage: move is_hugepage_on_freelist inside ifdef to avoid warningAndi Kleen
Fixes warning reported by Stephen Rothwell mm/hugetlb.c:2950: warning: 'is_hugepage_on_freelist' defined but not used for the !CONFIG_MEMORY_FAILURE case. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08Clean up __page_set_anon_rmapAndi Kleen
Linus asked for a cleanup of __page_set_anon_rmap to make it look more like the cleaner huge pages version. Factor out the duplicated PageAnon check into a single check at the beginning of the function. Remove obsolete comments and rewrite them into standard English. No functional changes. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08HWPOISON, hugetlb: fix unpoison for hugepageNaoya Horiguchi
Currently unpoisoning hugepages doesn't work correctly because clearing PG_HWPoison is done outside if (TestClearPageHWPoison). This patch fixes it. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08HWPOISON, hugetlb: soft offlining for hugepageNaoya Horiguchi
This patch extends soft offlining framework to support hugepage. When memory corrected errors occur repeatedly on a hugepage, we can choose to stop using it by migrating data onto another hugepage and disabling the original (maybe half-broken) one. ChangeLog since v4: - branch soft_offline_page() for hugepage ChangeLog since v3: - remove comment about "ToDo: hugepage soft-offline" ChangeLog since v2: - move refcount handling into isolate_lru_page() ChangeLog since v1: - add double check in isolating hwpoisoned hugepage - define free/non-free checker for hugepage - postpone calling put_page() for hugepage in soft_offline_page() Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08HWPOSION, hugetlb: recover from free hugepage error when !MF_COUNT_INCREASEDNaoya Horiguchi
Currently error recovery for free hugepage works only for MF_COUNT_INCREASED. This patch enables !MF_COUNT_INCREASED case. Free hugepages can be handled directly by alloc_huge_page() and dequeue_hwpoisoned_huge_page(), and both of them are protected by hugetlb_lock, so there is no race between them. Note that this patch defines the refcount of HWPoisoned hugepage dequeued from freelist is 1, deviated from present 0, thereby we can avoid race between unpoison and memory failure on free hugepage. This is reasonable because unlikely to free buddy pages, free hugepage is governed by hugetlbfs even after error handling finishes. And it also makes unpoison code added in the later patch cleaner. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08hugetlb: move refcounting in hugepage allocation inside hugetlb_lockNaoya Horiguchi
Currently alloc_huge_page() raises page refcount outside hugetlb_lock. but it causes race when dequeue_hwpoison_huge_page() runs concurrently with alloc_huge_page(). To avoid it, this patch moves set_page_refcounted() in hugetlb_lock. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08HWPOISON, hugetlb: add free check to dequeue_hwpoison_huge_page()Naoya Horiguchi
This check is necessary to avoid race between dequeue and allocation, which can cause a free hugepage to be dequeued twice and get kernel unstable. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08hugetlb: hugepage migration coreNaoya Horiguchi
This patch extends page migration code to support hugepage migration. One of the potential users of this feature is soft offlining which is triggered by memory corrected errors (added by the next patch.) Todo: - there are other users of page migration such as memory policy, memory hotplug and memocy compaction. They are not ready for hugepage support for now. ChangeLog since v4: - define migrate_huge_pages() - remove changes on isolation/putback_lru_page() ChangeLog since v2: - refactor isolate/putback_lru_page() to handle hugepage - add comment about race on unmap_and_move_huge_page() ChangeLog since v1: - divide migration code path for hugepage - define routine checking migration swap entry for hugetlb - replace "goto" with "if/else" in remove_migration_pte() Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08hugetlb: redefine hugepage copy functionsNaoya Horiguchi
This patch modifies hugepage copy functions to have only destination and source hugepages as arguments for later use. The old ones are renamed from copy_{gigantic,huge}_page() to copy_user_{gigantic,huge}_page(). This naming convention is consistent with that between copy_highpage() and copy_user_highpage(). ChangeLog since v4: - add blank line between local declaration and code - remove unnecessary might_sleep() ChangeLog since v2: - change copy_huge_page() from macro to inline dummy function to avoid compile warning when !CONFIG_HUGETLB_PAGE. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08hugetlb: add allocate function for hugepage migrationNaoya Horiguchi
We can't use existing hugepage allocation functions to allocate hugepage for page migration, because page migration can happen asynchronously with the running processes and page migration users should call the allocation function with physical addresses (not virtual addresses) as arguments. ChangeLog since v3: - unify alloc_buddy_huge_page() and alloc_buddy_huge_page_node() ChangeLog since v2: - remove unnecessary get/put_mems_allowed() (thanks to David Rientjes) ChangeLog since v1: - add comment on top of alloc_huge_page_no_vma() Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Reviewed-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-08hugetlb: fix metadata corruption in hugetlb_fault()Naoya Horiguchi
Since the PageHWPoison() check is for avoiding hwpoisoned page remained in pagecache mapping to the process, it should be done in "found in pagecache" branch, not in the common path. Otherwise, metadata corruption occurs if memory failure happens between alloc_huge_page() and lock_page() because page fault fails with metadata changes remained (such as refcount, mapcount, etc.) This patch moves the check to "found in pagecache" branch and fix the problem. ChangeLog since v2: - remove retry check in "new allocation" path. - make description more detailed - change patch name from "HWPOISON, hugetlb: move PG_HWPoison bit check" Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Reviewed-by: Christoph Lameter <cl@linux.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-07Merge branch 'hwpoison-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: HWPOISON: Stop shrinking at right page count HWPOISON: Report correct address granuality for AO huge page errors HWPOISON: Copy si_addr_lsb to user page-types.c: fix name of unpoison interface
2010-10-07Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: elevator: fix oops on early call to elevator_change()
2010-10-07Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: check return code of read_sb_page md/raid1: minor bio initialisation improvements. md/raid1: avoid overflow in raid1 resync when bitmap is in use.
2010-10-07Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm: don't drop handle reference on unload drm/ttm: Fix two race conditions + fix busy codepaths
2010-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: wacom - fix runtime PM related deadlock Input: joydev - fix JSIOCSAXMAP ioctl Input: uinput - setup MT usage during device creation
2010-10-07Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: properly account for reclaimed inodes
2010-10-07Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (37 commits) V4L/DVB: v4l: radio: si470x: fix unneeded free_irq() call V4L/DVB: v4l: videobuf: prevent passing a NULL to dma_free_coherent() V4L/DVB: ir-core: Fix null dereferences in the protocols sysfs interface V4L/DVB: v4l: s5p-fimc: Fix 3-planar formats handling and pixel offset error on S5PV210 SoCs V4L/DVB: v4l: s5p-fimc: Fix return value on probe() failure V4L/DVB: uvcvideo: Restrict frame rates for Chicony CNF7129 webcam V4L/DVB: uvcvideo: Fix support for Medion Akoya All-in-one PC integrated webcam V4L/DVB: ivtvfb: prevent reading uninitialized stack memory V4L/DVB: cx25840: Fix typo in volume control initialization: 65335 vs. 65535 V4L/DVB: v4l: mem2mem_testdev: add missing release for video_device V4L/DVB: v4l: mem2mem_testdev: fix errorenous comparison V4L/DVB: mt9v022.c: Fixed compilation warning V4L/DVB: mt9m111: added current colorspace at g_fmt V4L/DVB: mt9m111: cropcap and s_crop check if type is VIDEO_CAPTURE V4L/DVB: mx2_camera: fix a race causing NULL dereference V4L/DVB: tm6000: bugfix data handling V4L/DVB: gspca - sn9c20x: Bad transfer size of Bayer images V4L/DVB: videobuf-dma-sg: set correct size in last sg element V4L/DVB: cx231xx: Avoid an OOPS when card is unknown (card=0) V4L/DVB: dvb: fix smscore_getbuffer() logic ...
2010-10-07Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: of/i2c: Fix module load order issue caused by of_i2c.c i2c: Fix checks which cause legacy suspend to never get called i2c-pca: Fix waitforcompletion() return value i2c: Fix for suspend/resume issue i2c: Remove obsolete cleanup for clientdata
2010-10-07sysctl: fix min/max handling in __do_proc_doulongvec_minmax()Eric Dumazet
When proc_doulongvec_minmax() is used with an array of longs, and no min/max check requested (.extra1 or .extra2 being NULL), we dereference a NULL pointer for the second element of the array. Noticed while doing some changes in network stack for the "16TB problem" Fix is to not change min & max pointers in __do_proc_doulongvec_minmax(), so that all elements of the vector share an unique min/max limit, like proc_dointvec_minmax(). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Americo Wang <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-07MAINTAINERS: add Samsung S5P series FIMC maintainersKyungmin Park
Add Samsung S5P series FIMC(Camera Interface) maintainers. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Sylwester Nawrocki <s.nawrocki@samsung.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-07MAINTAINERS: Haavard has movedAndrew Morton
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-07memcg: fix thresholds with use_hierarchy == 1Kirill A. Shutemov
We need to check parent's thresholds if parent has use_hierarchy == 1 to be sure that parent's threshold events will be triggered even if parent itself is not active (no MEM_CGROUP_EVENTS). Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Reviewed-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-07mm: alloc_large_system_hash() printk overflow on 16TB bootRobin Holt
During boot of a 16TB system, the following is printed: Dentry cache hash table entries: -2147483648 (order: 22, 17179869184 bytes) Signed-off-by: Robin Holt <holt@sgi.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-07HWPOISON: Stop shrinking at right page countAndi Kleen
When we call the slab shrinker to free a page we need to stop at page count one because the caller always holds a single reference, not zero. This avoids useless looping over slab shrinkers and freeing too much memory. Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-07HWPOISON: Report correct address granuality for AO huge page errorsAndi Kleen
The SIGBUS user space signalling is supposed to report the address granuality of a corruption. Pass this information correctly for huge pages by querying the hpage order. Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-07HWPOISON: Copy si_addr_lsb to userAndi Kleen
The original hwpoison code added a new siginfo field si_addr_lsb to pass the granuality of the fault address to user space. Unfortunately this field was never copied to user space. Fix this here. I added explicit checks for the MCEERR codes to avoid having to patch all potential callers to initialize the field. Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-07page-types.c: fix name of unpoison interfaceNaoya Horiguchi
The page-types utility still uses an out of date name for the unpoison interface: debugfs:hwpoison/renew-pfn This patch renames and fixes it. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2010-10-07elevator: fix oops on early call to elevator_change()Jens Axboe
2.6.36 introduces an API for drivers to switch the IO scheduler instead of manually calling the elevator exit and init functions. This API was added since q->elevator must be cleared in between those two calls. And since we already have this functionality directly from use by the sysfs interface to switch schedulers online, it was prudent to reuse it internally too. But this API needs the queue to be in a fully initialized state before it is called, or it will attempt to unregister elevator kobjects before they have been added. This results in an oops like this: BUG: unable to handle kernel NULL pointer dereference at 0000000000000051 IP: [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0 PGD 47ddfc067 PUD 47c6a1067 PMD 0 Oops: 0000 [#1] PREEMPT SMP last sysfs file: /sys/devices/pci0000:00/0000:00:02.0/0000:04:00.1/irq CPU 2 Modules linked in: t(+) loop hid_apple usbhid ahci ehci_hcd uhci_hcd libahci usbcore nls_base igb Pid: 7319, comm: modprobe Not tainted 2.6.36-rc6+ #132 QSSC-S4R/QSSC-S4R RIP: 0010:[<ffffffff8116f15e>] [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0 RSP: 0018:ffff88027da25d08 EFLAGS: 00010246 RAX: ffff88047c68c528 RBX: 00000000fffffffe RCX: 0000000000000000 RDX: 000000000000002f RSI: 000000000000002f RDI: ffff88047e196c88 RBP: ffff88027da25d38 R08: 0000000000000000 R09: d84156c5635688c0 R10: d84156c5635688c0 R11: 0000000000000000 R12: ffff88047e196c88 R13: 0000000000000000 R14: 0000000000000000 R15: ffff88047c68c528 FS: 00007fcb0b26f6e0(0000) GS:ffff880287400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000000000000051 CR3: 000000047e76e000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process modprobe (pid: 7319, threadinfo ffff88027da24000, task ffff88027d377090) Stack: ffff88027da25d58 ffff88047c68c528 00000000fffffffe ffff88047e196c88 <0> ffff88047c68c528 ffff88047e05bd90 ffff88027da25d78 ffffffff8123fb77 <0> ffff88047e05bd90 0000000000000000 ffff88047e196c88 ffff88047c68c528 Call Trace: [<ffffffff8123fb77>] kobject_add_internal+0xe7/0x1f0 [<ffffffff8123fd98>] kobject_add_varg+0x38/0x60 [<ffffffff8123feb9>] kobject_add+0x69/0x90 [<ffffffff8116efe0>] ? sysfs_remove_dir+0x20/0xa0 [<ffffffff8103d48d>] ? sub_preempt_count+0x9d/0xe0 [<ffffffff8143de20>] ? _raw_spin_unlock+0x30/0x50 [<ffffffff8116efe0>] ? sysfs_remove_dir+0x20/0xa0 [<ffffffff8116eff4>] ? sysfs_remove_dir+0x34/0xa0 [<ffffffff81224204>] elv_register_queue+0x34/0xa0 [<ffffffff81224aad>] elevator_change+0xfd/0x250 [<ffffffffa007e000>] ? t_init+0x0/0x361 [t] [<ffffffffa007e000>] ? t_init+0x0/0x361 [t] [<ffffffffa007e0a8>] t_init+0xa8/0x361 [t] [<ffffffff810001de>] do_one_initcall+0x3e/0x170 [<ffffffff8108c3fd>] sys_init_module+0xbd/0x220 [<ffffffff81002f2b>] system_call_fastpath+0x16/0x1b Code: e5 41 56 41 55 41 54 49 89 fc 53 48 83 ec 10 48 85 ff 74 52 48 8b 47 18 49 c7 c5 00 46 61 81 48 85 c0 74 04 4c 8b 68 30 45 31 f6 <41> 80 7d 51 00 74 0e 49 8b 44 24 28 4c 89 e7 ff 50 20 49 89 c6 RIP [<ffffffff8116f15e>] sysfs_create_dir+0x2e/0xc0 RSP <ffff88027da25d08> CR2: 0000000000000051 ---[ end trace a6541d3bf07945df ]--- Fix this by adding a registered bit to the elevator queue, which is set when the sysfs kobjects have been registered. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-10-07drm: don't drop handle reference on unloadDave Airlie
since the handle references are all tied to a file_priv, and when it disappears all the handle refs go with it. The fbcon ones we'd only notice on unload, but the nouveau notifier one would would happen on reboot. nouveau: Reported-by: Marc Dionne <marc.c.dionne@gmail.com> nouveau: Tested-by: Marc Dionne <marc.c.dionne@gmail.com> i915 unload: Reported-by: Keith Packard <keithp@keithp.com> Acked-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-06xfs: properly account for reclaimed inodesJohannes Weiner
When marking an inode reclaimable, a per-AG counter is increased, the inode is tagged reclaimable in its per-AG tree, and, when this is the first reclaimable inode in the AG, the AG entry in the per-mount tree is also tagged. When an inode is finally reclaimed, however, it is only deleted from the per-AG tree. Neither the counter is decreased, nor is the parent tree's AG entry untagged properly. Since the tags in the per-mount tree are not cleared, the inode shrinker iterates over all AGs that have had reclaimable inodes at one point in time. The counters on the other hand signal an increasing amount of slab objects to reclaim. Since "70e60ce xfs: convert inode shrinker to per-filesystem context" this is not a real issue anymore because the shrinker bails out after one iteration. But the problem was observable on a machine running v2.6.34, where the reclaimable work increased and each process going into direct reclaim eventually got stuck on the xfs inode shrinking path, trying to scan several million objects. Fix this by properly unwinding the reclaimable-state tracking of an inode when it is reclaimed. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: stable@kernel.org Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-10-07md: check return code of read_sb_pageVasiliy Kulikov
Function read_sb_page may return ERR_PTR(...). Check for it. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: NeilBrown <neilb@suse.de>
2010-10-07md/raid1: minor bio initialisation improvements.NeilBrown
When performing a resync we pre-allocate some bios and repeatedly use them. This requires us to re-initialise them each time. One field (bi_comp_cpu) and some flags weren't being initiaised reliably. Signed-off-by: NeilBrown <neilb@suse.de>
2010-10-07md/raid1: avoid overflow in raid1 resync when bitmap is in use.NeilBrown
bitmap_start_sync returns - via a pass-by-reference variable - the number of sectors before we need to check with the bitmap again. Since commit ef4256733506f245 this number can be substantially larger, 2^27 is a common value. Unfortunately it is an 'int' and so when raid1.c:sync_request shifts it 9 places to the left it becomes 0. This results in a zero-length read which the scsi layer justifiably complains about. This patch just removes the shift so the common case becomes safe with a trivially-correct patch. In the next merge window we will convert this 'int' to a 'sector_t' Reported-by: "George Spelvin" <linux@horizon.com> Signed-off-by: NeilBrown <neilb@suse.de>
2010-10-06Linux 2.6.36-rc7v2.6.36-rc7Linus Torvalds
2010-10-06Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: MIPS: Octeon: Place cnmips_cu2_setup in __init memory. MIPS: Don't place cu2 notifiers in __cpuinitdata MIPS: Calculate VMLINUZ_LOAD_ADDRESS based on the length of vmlinux.bin MIPS: Alchemy: Resolve prom section mismatches MIPS: Fix syscall 64 bit number comments. MIPS: Hookup fanotify_init, fanotify_mark, and prlimit64 syscalls. MIPS: TX49xx: Rename ARCH_KMALLOC_MINALIGN to ARCH_DMA_MINALIGN MIPS: N32: Fix getdents64 syscall for n32 MIPS: Remove pr_<level> uses of KERN_<level> MIPS: PNX8550: Sort out machine halt, restart and powerdown functions. MIPS: GIC: Remove dependencies from Malta files. MIPS: Kconfig: Fix and clarify kconfig help text for VSMP and SMTC. MIPS: DMA: Fix computation of DMA flags from device's coherent_dma_mask. MIPS: Audit: Fix hang in entry.S. MIPS: Document why RELOC_HIDE is there. MIPS: Octeon: Determine if helper needs to be built MIPS: Use generic atomic64 for 32-bit kernels MIPS: RM7000: Symbol should be static MIPS: kspd: Adjust confusing if indentation MIPS: Fix a typo.
2010-10-06Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: writeback: always use sb->s_bdi for writeback purposes
2010-10-06Merge branch 'v2.6.36-rc6-urgent-fixes' of ↵Linus Torvalds
git://xenbits.xen.org/people/sstabellini/linux-pvhvm * 'v2.6.36-rc6-urgent-fixes' of git://xenbits.xen.org/people/sstabellini/linux-pvhvm: xen: do not initialize PV timers on HVM if !xen_have_vector_callback xen: do not set xenstored_ready before xenbus_probe on hvm
2010-10-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/fuse: fuse: Initialize total_len in fuse_retrieve()
2010-10-05powerpc: remove unused variableStephen Rothwell
Since powerpc uses -Werror on arch powerpc, the build was broken like this: cc1: warnings being treated as errors arch/powerpc/kernel/module.c: In function 'module_finalize': arch/powerpc/kernel/module.c:66: error: unused variable 'err' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-06drm/ttm: Fix two race conditions + fix busy codepathsThomas Hellstrom
This fixes a race pointed out by Dave Airlie where we don't take a buffer object about to be destroyed off the LRU lists properly. It also fixes a rare case where a buffer object could be destroyed in the middle of an accelerated eviction. The patch also adds a utility function that can be used to prematurely release GPU memory space usage of an object waiting to be destroyed. For example during eviction or swapout. The above mentioned commit didn't queue the buffer on the delayed destroy list under some rare circumstances. It also didn't completely honor the remove_all parameter. Fixes: https://bugzilla.redhat.com/show_bug.cgi?id=615505 http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=591061 Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-10-05Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: rcu: rcu_read_lock_bh_held(): disabling irqs also disables bh generic-ipi: Fix deadlock in __smp_call_function_single
2010-10-05Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf trace scripting: Fix extern struct definitions perf ui hist browser: Fix segfault on 'a' for annotate perf tools: Fix build breakage perf, x86: Handle in flight NMIs on P4 platform oprofile, ARM: Release resources on failure oprofile: Add Support for Intel CPU Family 6 / Model 29
2010-10-05wait: using uninitialized member of wait queueEvgeny Kuznetsov
The "flags" member of "struct wait_queue_t" is used in several places in the kernel code without beeing initialized by init_wait(). "flags" is used in bitwise operations. If "flags" not initialized then unexpected behaviour may take place. Incorrect flags might used later in code. Added initialization of "wait_queue_t.flags" with zero value into "init_wait". Signed-off-by: Evgeny Kuznetsov <EXT-Eugeny.Kuznetsov@nokia.com> [ The bit we care about does end up being initialized by both prepare_to_wait() and add_to_wait_queue(), so this doesn't seem to cause actual bugs, but is definitely the right thing to do -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-05modules: Fix module_bug_list list corruption raceLinus Torvalds
With all the recent module loading cleanups, we've minimized the code that sits under module_mutex, fixing various deadlocks and making it possible to do most of the module loading in parallel. However, that whole conversion totally missed the rather obscure code that adds a new module to the list for BUG() handling. That code was doubly obscure because (a) the code itself lives in lib/bugs.c (for dubious reasons) and (b) it gets called from the architecture-specific "module_finalize()" rather than from generic code. Calling it from arch-specific code makes no sense what-so-ever to begin with, and is now actively wrong since that code isn't protected by the module loading lock any more. So this commit moves the "module_bug_{finalize,cleanup}()" calls away from the arch-specific code, and into the generic code - and in the process protects it with the module_mutex so that the list operations are now safe. Future fixups: - move the module list handling code into kernel/module.c where it belongs. - get rid of 'module_bug_list' and just use the regular list of modules (called 'modules' - imagine that) that we already create and maintain for other reasons. Reported-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Adrian Bunk <bunk@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-05xen: do not initialize PV timers on HVM if !xen_have_vector_callbackStefano Stabellini
if !xen_have_vector_callback do not initialize PV timer unconditionally because we still don't know how many cpus are available and if there is more than one we won't be able to receive the timer interrupts on cpu > 0. This patch fixes an hang at boot when Xen does not support vector callbacks and the guest has multiple vcpus. Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
