2014-01-29dmaengine: mmp_pdma: fix mismergeArnd Bergmann
The merge between 2b7f65b11d87f "mmp_pdma: Style neatening" and 8010dad55a0ab0 "dma: add dma_get_any_slave_channel(), for use in of_xlate()" caused a build error by leaving obsolete code in place: mmp_pdma.c: In function 'mmp_pdma_dma_xlate': mmp_pdma.c:909:31: error: 'candidate' undeclared mmp_pdma.c:912:3: error: label 'retry' used but not defined mmp_pdma.c:901:24: warning: unused variable 'c' [-Wunused-variable] This removes the extraneous lines. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-28dma: pl08x: Export pl08x_filter_idSachin Kamat
Export the symbol so that it is accessible to modules. Fixes the following error: ERROR: "pl08x_filter_id" [sound/soc/samsung/snd-soc-s3c-dma.ko] undefined! Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-26acpi-dma: align documentation with kernel-doc formatAndy Shevchenko
It mostly fixes the "RETURN" sections in the resulting manual page. There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-26dma: fix vchan_cookie_complete() debug printJonas Jensen
vd->tx.cookie is set zero on dma_cookie_complete(), save to local before printing it. Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20DMA: dmatest: extend the "device" module parameter to 32 charactersGuennadi Liakhovetski
With Device Tree a typical DMA controller device name can look like 10000000.dma-controller, which extends the current size of the string, allocated for this parameter. This patch extends its size from 20 to 32 characters. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20drivers/dma: fix error return codeJulia Lawall
Set the return variable to an error code as done elsewhere in the function. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> ( if@p1 (\(ret < 0\|ret != 0\)) { ... return ret; } | ret@p1 = 0 ) ... when != ret = e1 when != &ret *if(...) { ... when != ret = e2 when forall return ret; } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20dma: omap: Set debug level to debugging messagesEzequiel Garcia
The channel allocated/released messages are just informative and not really interesting to users. Change them to "debug" level. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20dmaengine: fix kernel-doc style typos for few commentsVinod Koul
2014-01-20dma: tegra: add support for Tegra148/124Laxman Dewangan
Tegra148 introduces a few changes to the APB DMA HW registers. Update the driver to cope with them. Tegra124 inherits these changes. * The register address stride between DMA channels increases. * A new per-channel WCOUNT register is introduced. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Kunal Agrawal <kunala@nvidia.com> [swarren, remove .dts file change, rewrote commit description, removed some duplicate/unused code and register IO] Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Tested-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20dma: dw: use %pad instead of casting dma_addr_tAndy Shevchenko
Since we have nice helper to print dma_addr_t values by reference we may use it instead of explicit casting to a longest type. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20dma: dw: join split up messagesAndy Shevchenko
The joined messages are better to grep when debugging. There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20dma: dw: fix style of multiline commentAndy Shevchenko
Simple fix a style of the multiline comment. There is no functional change. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20dmaengine: k3dma: fix sparse warningsZhangfei Gao
Fix sparse warnings: drivers/dma/k3dma.c:480:20: warning: Using plain integer as NULL pointer drivers/dma/k3dma.c:820:1: warning: symbol 'k3_dma_pmops' was not declared. Should it be static? Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20dma: pl330: Use dma_get_slave_channel() in the of xlate callbackLars-Peter Clausen
Currently the driver uses dma_request_channel() with a custom filter function to find the requested channel. This will loop over all available channels until the one we want has been found, but we already know which channel we want to request, so we can dma_get_slave_channel(). This also makes the code a bit shorter cleaner. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20dma: pl330: Differentiate between submitted and issued descriptorsLars-Peter Clausen
The pl330 dmaengine driver currently does not differentiate between submitted and issued descriptors. It won't start transferring a newly submitted descriptor until issue_pending() is called, but only if it is idle. If it is active and a new descriptor is submitted before it goes idle it will happily start the newly submitted descriptor once all earlier submitted descriptors have been completed. This is not a 100% correct with regards to the dmaengine interface semantics. A descriptor is not supposed to be started until the next issue_pending() call after the descriptor has been submitted. This patch adds a second per channel list that keeps track of the submitted descriptors. Once issue_pending() is called the submitted descriptors are moved to the working list and only descriptors on the working list are started. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20dmaengine: sirf: Add device_slave_caps interfaceRongjun Ying
this patch adds device_slave_caps() callback as SiRF SoC sound drivers depend on it. Signed-off-by: Rongjun Ying <rongjun.ying@csr.com> Signed-off-by: Barry Song <Barry.Song@csr.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20DMA: Freescale: change BWC from 256 bytes to 1024 bytesHongbo Zhang
Freescale DMA has a feature of BandWidth Control (ab. BWC), which is currently 256 bytes and should be changed to 1024 bytes for best DMA throughput. Changing BWC from 256 to 1024 will improve DMA performance much, in cases whatever one channel is running or multi channels are running simultanously, large or small buffers are copied. And this change doesn't impact memory access performance remarkably, lmbench tests show that for some cases the memory performance are decreased very slightly, while the others are even better. Tested on T4240. Signed-off-by: Hongbo Zhang <hongbo.zhang@freescale.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20dmaengine: Add MOXA ART DMA engine driverJonas Jensen
The MOXA ART SoC has a DMA controller capable of offloading expensive memory operations, such as large copies. This patch adds support for the controller including four channels. Two of these are used to handle MMC copy on the UC-7112-LX hardware. The remaining two can be used in a future audio driver or client application. Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-20dmaengine: Add DMA_PRIVATE to BCM2835 driverFlorian Meier
Without DMA_PRIVATE the driver is not able to allocate more than one channel. Since it uses dma_get_any_slave_channel that calls private_candidate, the second allocation fails at /* some channels are already publicly allocated */ Maybe it should be fixed in the core, but at least this fixes the bug. Signed-off-by: Florian Meier <florian.meier@koalo.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-13dma: imx-sdma: Assign a default script number for ROM firmware casesNicolin Chen
i.MX series have inner firmware in its ROM code: when SDMA isn't provided any firmware from Kernel or rootfs, the default inner ROM firmware will be activated. However the current driver doesn't assign any script number to this situation, and those platform running in this case would be broken. Thus this patch adds a default script number when no external firmware being loaded so that people would continue to be able to use basic scripts to run their platform without any firmware. Reported-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Nicolin Chen <Guangyu.Chen@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-13Revert "ARM: dts: imx: use dual-fifo sdma script for ssi"Nicolin Chen
This reverts commit b1d27c79c8377df1880447375deffa3bb82c7bd3. Previously we switched the SSI scriprt to dual-fifo mode to reduce playback underrun issue, which is only included by SDMA firmware version 2. However, there are quite a lot people still using version 1 or default firmware in the ROM code of SoC while these two kinds of firmwares do not support the dual-fifo script and the audio function on their platform would be broken. Thus this patch provisionally reverts the dual-fifo script to the original single fifo script to meet all kinds of users' requirements, including the version 1/2 or inner ROM firmware. Reported-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Nicolin Chen <Guangyu.Chen@freescale.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-13dma: mv_xor: Cleanup in dma-mv_xor.h headerSachin Kamat
Commit c02cecb92ed4 ("ARM: orion: move platform_data definitions") moved the file to the current location but forgot to remove the pointer to its previous location. Clean it up. While at it also change the header file protection macros appropriately. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-13dma: Cleanup dma-mmp_tdma.h headerSachin Kamat
Commit 293b2da1b611 ("ARM: pxa: move platform_data definitions") moved the file to the current location but forgot to remove the pointer to its previous location. Clean it up. While at it also change the header file protection macros appropriately. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-09dma:mmp_tdma: get sram pool through device treeNenghua Cao
Support to get sram pool from generic device tree binding. The existing way of get sram poll, directly call sram_get_gpool(), still work here. Signed-off-by: Nenghua Cao <nhcao@marvell.com> Acked-by: Zhangfei Gao <zhangfei.gao@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-07dmaengine: Add support for BCM2835Florian Meier
Add support for DMA controller of BCM2835 as used in the Raspberry Pi. Currently it only supports cyclic DMA. Signed-off-by: Florian Meier <florian.meier@koalo.de> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-07Merge branch 'topic/of' into for-linusVinod Koul
Conflicts: drivers/dma/mmp_pdma.c Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2014-01-07Merge branch 'topic/defer_probe' into for-linusVinod Koul
2013-12-18dma: pl08x: allow zero slave channelsLinus Walleij
It might happen that a platform wants to use its DMA engine for memcpy only, and then we have zero slave channels to initialize, so allow the slave initialization to return zero. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-18dma: edma: Set debug level to debugging messagesEzequiel Garcia
The channel allocated/released messages are very spammy and not really interesting to users. Change them to "debug" level. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Matt Porter <mporter@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-18dmaengine: fix incorrect kernel-doc comment for struct dma_slave_configAlexander Popov
The 'direction' member of 'struct dma_slave_config' is of data type 'enum dma_transfer_direction', so update the kernel-doc comment for 'struct dma_slave_config' to refer to appropriate values. Signed-off-by: Alexander Popov <a13xp0p0v88@gmail.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-16dmaengine: mmp: fix uninitialized variableVinod Koul
drivers/dma/mmp_tdma.c:236:8: warning: 'tdcr' may be used uninitialized in this function [-Wuninitialized] Reported-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-16dmaengine: mmp_tdma: fix the 'pointer from integer' warningsVinod Koul
the driver is using unsigned long type for storing the channel register base "reg_base", this leads to bunch of warns when we try to use this as pointer. So better use an iomem pointer type for this variable drivers/dma/mmp_tdma.c: In function 'mmp_tdma_chan_set_desc': drivers/dma/mmp_tdma.c:143: warning: passing argument 2 of '__raw_writel' makes pointer from integer without a cast drivers/dma/mmp_tdma.c:144: warning: passing argument 1 of '__raw_readl' makes pointer from integer without a cast drivers/dma/mmp_tdma.c:144: warning: passing argument 2 of '__raw_writel' makes pointer from integer without a cast drivers/dma/mmp_tdma.c: In function 'mmp_tdma_enable_chan': drivers/dma/mmp_tdma.c:151: warning: passing argument 2 of '__raw_writel' makes pointer from integer without a cast drivers/dma/mmp_tdma.c:153: warning: passing argument 1 of '__raw_readl' makes pointer from integer without a cast drivers/dma/mmp_tdma.c:153: warning: passing argument 2 of '__raw_writel' makes pointer from integer without a cast drivers/dma/mmp_tdma.c: In function 'mmp_tdma_disable_chan': drivers/dma/mmp_tdma.c:160: warning: passing argument 1 of '__raw_readl' makes pointer from integer without a cast drivers/dma/mmp_tdma.c:160: warning: passing argument 2 of '__raw_writel' makes pointer from integer without a cast drivers/dma/mmp_tdma.c:164: warning: passing argument 2 of '__raw_writel' makes pointer from integer without a cast drivers/dma/mmp_tdma.c: In function 'mmp_tdma_resume_chan': drivers/dma/mmp_tdma.c:171: warning: passing argument 1 of '__raw_readl' makes pointer from integer without a cast drivers/dma/mmp_tdma.c:171: warning: passing argument 2 of '__raw_writel' makes pointer from integer without a cast drivers/dma/mmp_tdma.c: In function 'mmp_tdma_pause_chan': drivers/dma/mmp_tdma.c:178: warning: passing argument 1 of '__raw_readl' makes pointer from integer without a cast drivers/dma/mmp_tdma.c:178: warning: passing argument 2 of '__raw_writel' makes pointer from integer without a cast drivers/dma/mmp_tdma.c: In function 'mmp_tdma_config_chan': drivers/dma/mmp_tdma.c:263: warning: passing argument 2 of '__raw_writel' makes pointer from integer without a cast drivers/dma/mmp_tdma.c: In function 'mmp_tdma_clear_chan_irq': drivers/dma/mmp_tdma.c:269: warning: passing argument 1 of '__raw_readl' makes pointer from integer without a cast drivers/dma/mmp_tdma.c:274: warning: passing argument 2 of '__raw_writel' makes pointer from integer without a cast Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-16mmp_pdma: Style neateningJoe Perches
Neaten code used as a template for other drivers. Make the code more consistent with kernel styles. o Convert #defines with (1<<foo) to BIT(foo) o Alignment wrapping o Logic inversions to put return at end of functions o Convert devm_kzalloc with multiply to devm_kcalloc o typo of Peripheral fix Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-16ASoC: fsl_ssi: Add dual fifo mode supportNicolin Chen
By enabling dual fifo mode, it would allow SSI enter a better performance to transimit/receive data without occasional hardware underrun/overrun. Signed-off-by: Nicolin Chen <b42378@freescale.com> Acked-by: Timur Tabi <timur@tabi.org> Acked-by: Mark Brown <broonie@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-16ARM: dts: imx: use dual-fifo sdma script for ssiNicolin Chen
Use dual-fifo sdma scripts instead of shared scripts for ssi on i.MX series. Signed-off-by: Nicolin Chen <b42378@freescale.com> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-16dma: imx-sdma: Add new dma type for ssi dual fifo scriptNicolin Chen
This patch adds a new DMA_TYPE for SSI dual FIFO script, included in SDMA firmware version 2. This script would allow SSI use dual fifo mode to transimit/receive data without occasional hardware underrun/overrun. Signed-off-by: Nicolin Chen <b42378@freescale.com> Acked-by: Kumar Gala <galak@codeaurora.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-16dma: imx-sdma: Add sdma firmware version 2 supportNicolin Chen
On i.MX5/6 series, SDMA is using new version firmware to support SSI dual FIFO feature and HDMI Audio (i.MX6Q/DL only). Thus add it. Signed-off-by: Nicolin Chen <b42378@freescale.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-16dma: pl330: Alloc dma_parms for the dma deviceLars-Peter Clausen
In order to be able to set a maximum segment size for the device we need to allocate a dma_parameters struct for the device first. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Vinod Koul <vinod.koul@intel.com>
2013-12-15Linux 3.13-rc4v3.13-rc4Linus Torvalds
2013-12-15null_blk: mem garbage on NUMA systems during initMatias Bjorling
For NUMA systems, initializing the blk-mq layer and using per node hctx. We initialize submit queues to 1, while blk-mq nr_hw_queues is initialized to the number of NUMA nodes. This makes the null_init_hctx function overwrite memory outside of what it allocated. In my case it lead to writing garbage into struct request_queue's mq_map. Signed-off-by: Matias Bjorling <m@bjorling.me> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-15radeon_pm: fix oops in hwmon_attributes_visible() and ↵Sergey Senozhatsky
radeon_hwmon_show_temp_thresh() Since commit ec39f64bba34 ("drm/radeon/dpm: Convert to use devm_hwmon_register_with_groups") radeon_hwmon_init() is using hwmon_device_register_with_groups(), which sets `rdev' as a device private driver_data, while hwmon_attributes_visible() and radeon_hwmon_show_temp_thresh() are still waiting for `drm_device'. Fix them by using dev_get_drvdata(), in order to avoid this oops: BUG: unable to handle kernel paging request at 0000000000001e28 IP: [<ffffffffa02ae8b4>] hwmon_attributes_visible+0x18/0x3d [radeon] PGD 15057e067 PUD 151a8e067 PMD 0 Oops: 0000 [#1] PREEMPT SMP Call Trace: internal_create_group+0x114/0x1d9 sysfs_create_group+0xe/0x10 sysfs_create_groups+0x22/0x5f device_add+0x34f/0x501 device_register+0x15/0x18 hwmon_device_register_with_groups+0xb5/0xed radeon_hwmon_init+0x56/0x7c [radeon] radeon_pm_init+0x134/0x7e5 [radeon] radeon_modeset_init+0x75f/0x8ed [radeon] radeon_driver_load_kms+0xc6/0x187 [radeon] drm_dev_register+0xf9/0x1b4 [drm] drm_get_pci_dev+0x98/0x129 [drm] radeon_pci_probe+0xa3/0xac [radeon] pci_device_probe+0x6e/0xcf driver_probe_device+0x98/0x1c4 __driver_attach+0x5c/0x7e bus_for_each_dev+0x7b/0x85 driver_attach+0x19/0x1b bus_add_driver+0x104/0x1ce driver_register+0x89/0xc5 __pci_register_driver+0x58/0x5b drm_pci_init+0x86/0xea [drm] radeon_init+0x97/0x1000 [radeon] do_one_initcall+0x7f/0x117 load_module+0x1583/0x1bb4 SyS_init_module+0xa0/0xaf Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Alexander Deucher <Alexander.Deucher@amd.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Revert CHECKSUM_COMPLETE optimization in pskb_trim_rcsum(), I can't figure out why it breaks things. 2) Fix comparison in netfilter ipset's hash_netnet4_data_equal(), it was basically doing "x == x", from Dave Jones. 3) Freescale FEC driver was DMA mapping the wrong number of bytes, from Sebastian Siewior. 4) Blackhole and prohibit routes in ipv6 were not doing the right thing because their ->input and ->output methods were not being assigned correctly. Now they behave properly like their ipv4 counterparts. From Kamala R. 5) Several drivers advertise the NETIF_F_FRAGLIST capability, but really do not support this feature and will send garbage packets if fed fraglist SKBs. From Eric Dumazet. 6) Fix long standing user triggerable BUG_ON over loopback in RDS protocol stack, from Venkat Venkatsubra. 7) Several not so common code paths can potentially try to invoke packet scheduler actions that might be NULL without checking. Shore things up by either 1) defining a method as mandatory and erroring on registration if that method is NULL 2) defininig a method as optional and the registration function hooks up a default implementation when NULL is seen. From Jamal Hadi Salim. 8) Fix fragment detection in xen-natback driver, from Paul Durrant. 9) Kill dangling enter_memory_pressure method in cg_proto ops, from Eric W Biederman. 10) SKBs that traverse namespaces should have their local_df cleared, from Hannes Frederic Sowa. 11) IOCB file position is not being updated by macvtap_aio_read() and tun_chr_aio_read(). From Zhi Yong Wu. 12) Don't free virtio_net netdev before releasing all of the NAPI instances. From Andrey Vagin. 13) Procfs entry leak in xt_hashlimit, from Sergey Popovich. 14) IPv6 routes that are no cached routes should not count against the garbage collection limits. We had this almost right, but were missing handling addrconf generated routes properly. From Hannes Frederic Sowa. 15) fib{4,6}_rule_suppress() have to consider potentially seeing NULL route info when they are called, from Stefan Tomanek. 16) TUN and MACVTAP have had truncated packet signalling for some time, fix from Jason Wang. 17) Fix use after frrr in __udp4_lib_rcv(), from Eric Dumazet. 18) xen-netback does not interpret the NAPI budget properly for TX work, fix from Paul Durrant. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (132 commits) igb: Fix for issue where values could be too high for udelay function. i40e: fix null dereference xen-netback: fix gso_prefix check net: make neigh_priv_len in struct net_device 16bit instead of 8bit drivers: net: cpsw: fix for cpsw crash when build as modules xen-netback: napi: don't prematurely request a tx event xen-netback: napi: fix abuse of budget sch_tbf: use do_div() for 64-bit divide udp: ipv4: must add synchronization in udp_sk_rx_dst_set() net:fec: remove duplicate lines in comment about errata ERR006358 Revert "8390 : Replace ei_debug with msg_enable/NETIF_MSG_* feature" 8390 : Replace ei_debug with msg_enable/NETIF_MSG_* feature xen-netback: make sure skb linear area covers checksum field net: smc91x: Fix device tree based configuration so it's usable udp: ipv4: fix potential use after free in udp_v4_early_demux() macvtap: signal truncated packets tun: unbreak truncated packet signalling net: sched: htb: fix the calculation of quantum net: sched: tbf: fix the calculation of max_size micrel: add support for KSZ8041RNLI ...
2013-12-15Merge branch 'x86/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "This is a pretty small batch: The biggest single change is to stop using EFI time services on 32-bit platforms. This matches our current behavior on 64-bit platforms as we already had ruled them out there as being too unreliable. Turns out that affects 32-bit platforms, too. One NULL pointer fix for SGI UV. Two minor build fixes, one of which only affects icc and the other which affects icc and future versions or nonstandard default settings of gcc" * 'x86/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, efi: Don't use (U)EFI time services on 32 bit x86, build, icc: Remove uninitialized_var() from compiler-intel.h x86/UV: Fix NULL pointer dereference in uv_flush_tlb_others() if the 'nobau' boot option is used x86, build: Pass in additional -mno-mmx, -mno-sse options
2013-12-15Merge tag 'pci-v3.13-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI device hotplug - Move device_del() from pci_stop_dev() to pci_destroy_dev() (Rafael Wysocki) Host bridge drivers - Update maintainers for DesignWare, i.MX6, Armada, R-Car (Bjorn Helgaas) - mvebu: Return 'unsupported' for Interrupt Line and Interrupt Pin (Jason Gunthorpe) Miscellaneous - Avoid unnecessary CPU switch when calling .probe() (Alexander Duyck) - Revert "workqueue: allow work_on_cpu() to be called recursively" (Bjorn Helgaas) - Disable Bus Master only on kexec reboot (Khalid Aziz) - Omit PCI ID macro strings to shorten quirk names for LTO (Michal Marek)" * tag 'pci-v3.13-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: MAINTAINERS: Add DesignWare, i.MX6, Armada, R-Car PCI host maintainers PCI: Disable Bus Master only on kexec reboot PCI: mvebu: Return 'unsupported' for Interrupt Line and Interrupt Pin PCI: Omit PCI ID macro strings to shorten quirk names PCI: Move device_del() from pci_stop_dev() to pci_destroy_dev() Revert "workqueue: allow work_on_cpu() to be called recursively" PCI: Avoid unnecessary CPU switch when calling driver .probe() method
2013-12-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull SELinux fixes from James Morris. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: selinux: process labeled IPsec TCP SYN-ACK packets properly in selinux_ip_postroute() selinux: look for IPsec labels on both inbound and outbound packets selinux: handle TCP SYN-ACK packets correctly in selinux_ip_postroute() selinux: handle TCP SYN-ACK packets correctly in selinux_ip_output() selinux: fix possible memory leak
2013-12-15Revert "selinux: consider filesystem subtype in policies"Linus Torvalds
This reverts commit 102aefdda4d8275ce7d7100bc16c88c74272b260. Tom London reports that it causes sync() to hang on Fedora rawhide: https://bugzilla.redhat.com/show_bug.cgi?id=1033965 and Josh Boyer bisected it down to this commit. Reverting the commit in the rawhide kernel fixes the problem. Eric Paris root-caused it to incorrect subtype matching in that commit breaking fuse, and has a tentative patch, but by now we're better off retrying this in 3.14 rather than playing with it any more. Reported-by: Tom London <selinux@gmail.com> Bisected-by: Josh Boyer <jwboyer@fedoraproject.org> Acked-by: Eric Paris <eparis@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Anand Avati <avati@redhat.com> Cc: Paul Moore <paul@paul-moore.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-14igb: Fix for issue where values could be too high for udelay function.Carolyn Wyborny
This patch changes the igb_phy_has_link function to check the value of the parameter before deciding to use udelay or mdelay in order to be sure that the value is not too high for udelay function. CC: stable kernel <stable@vger.kernel.org> # 3.9+ Signed-off-by: Sunil K Pandey <sunil.k.pandey@intel.com> Signed-off-by: Kevin B Smith <kevin.b.smith@intel.com> Signed-off-by: Carolyn Wyborny <carolyn.wyborny@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-14i40e: fix null dereferenceJesse Brandeburg
If the vsi->tx_rings structure is NULL we don't want to panic. Change-Id: Ic694f043701738c434e8ebe0caf0673f4410dc10 Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Tested-by: Kavindya Deegala <kavindya.s.deegala@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-14Merge tag 'edac_fixes_for_3.13' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp Pull EDAC fix from Borislav Petkov: "Silence a compiler warning in sb_edac" * tag 'edac_fixes_for_3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: sb_edac: Shut up compiler warning when EDAC_DEBUG is enabled
2013-12-13Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "This resolves some further issues with the dma mask changes on ARM which have been found by TI and others, and also some corner cases with the updates to the virtual to physical address translations. Konstantin also found some problems with the unwinder, which now performs tighter verification that the stack is valid while unwinding" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: fix asm/memory.h build error ARM: 7917/1: cacheflush: correctly limit range of memory region being flushed ARM: 7913/1: fix framepointer check in unwind_frame ARM: 7912/1: check stack pointer in get_wchan ARM: 7909/1: mm: Call setup_dma_zone() post early_paging_init() ARM: 7908/1: mm: Fix the arm_dma_limit calculation ARM: another fix for the DMA mapping checks
