2018-07-03cdc_ncm: avoid padding beyond end of skbBjørn Mork
commit 49c2c3f246e2fc3009039e31a826333dcd0283cd upstream. Commit 4a0e3e989d66 ("cdc_ncm: Add support for moving NDP to end of NCM frame") added logic to reserve space for the NDP at the end of the NTB/skb. This reservation did not take the final alignment of the NDP into account, causing us to reserve too little space. Additionally the padding prior to NDP addition did not ensure there was enough space for the NDP. The NTB/skb with the NDP appended would then exceed the configured max size. This caused the final padding of the NTB to use a negative count, padding to almost INT_MAX, and resulting in: [60103.825970] BUG: unable to handle kernel paging request at ffff9641f2004000 [60103.825998] IP: __memset+0x24/0x30 [60103.826001] PGD a6a06067 P4D a6a06067 PUD 4f65a063 PMD 72003063 PTE 0 [60103.826013] Oops: 0002 [#1] SMP NOPTI [60103.826018] Modules linked in: (removed( [60103.826158] CPU: 0 PID: 5990 Comm: Chrome_DevTools Tainted: G O 4.14.0-3-amd64 #1 Debian 4.14.17-1 [60103.826162] Hardware name: LENOVO 20081 BIOS 41CN28WW(V2.04) 05/03/2012 [60103.826166] task: ffff964193484fc0 task.stack: ffffb2890137c000 [60103.826171] RIP: 0010:__memset+0x24/0x30 [60103.826174] RSP: 0000:ffff964316c03b68 EFLAGS: 00010216 [60103.826178] RAX: 0000000000000000 RBX: 00000000fffffffd RCX: 000000001ffa5000 [60103.826181] RDX: 0000000000000005 RSI: 0000000000000000 RDI: ffff9641f2003ffc [60103.826184] RBP: ffff964192f6c800 R08: 00000000304d434e R09: ffff9641f1d2c004 [60103.826187] R10: 0000000000000002 R11: 00000000000005ae R12: ffff9642e6957a80 [60103.826190] R13: ffff964282ff2ee8 R14: 000000000000000d R15: ffff9642e4843900 [60103.826194] FS: 00007f395aaf6700(0000) GS:ffff964316c00000(0000) knlGS:0000000000000000 [60103.826197] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [60103.826200] CR2: ffff9641f2004000 CR3: 0000000013b0c000 CR4: 00000000000006f0 [60103.826204] Call Trace: [60103.826212] <IRQ> [60103.826225] cdc_ncm_fill_tx_frame+0x5e3/0x740 [cdc_ncm] [60103.826236] cdc_ncm_tx_fixup+0x57/0x70 [cdc_ncm] [60103.826246] usbnet_start_xmit+0x5d/0x710 [usbnet] [60103.826254] ? netif_skb_features+0x119/0x250 [60103.826259] dev_hard_start_xmit+0xa1/0x200 [60103.826267] sch_direct_xmit+0xf2/0x1b0 [60103.826273] __dev_queue_xmit+0x5e3/0x7c0 [60103.826280] ? ip_finish_output2+0x263/0x3c0 [60103.826284] ip_finish_output2+0x263/0x3c0 [60103.826289] ? ip_output+0x6c/0xe0 [60103.826293] ip_output+0x6c/0xe0 [60103.826298] ? ip_forward_options+0x1a0/0x1a0 [60103.826303] tcp_transmit_skb+0x516/0x9b0 [60103.826309] tcp_write_xmit+0x1aa/0xee0 [60103.826313] ? sch_direct_xmit+0x71/0x1b0 [60103.826318] tcp_tasklet_func+0x177/0x180 [60103.826325] tasklet_action+0x5f/0x110 [60103.826332] __do_softirq+0xde/0x2b3 [60103.826337] irq_exit+0xae/0xb0 [60103.826342] do_IRQ+0x81/0xd0 [60103.826347] common_interrupt+0x98/0x98 [60103.826351] </IRQ> [60103.826355] RIP: 0033:0x7f397bdf2282 [60103.826358] RSP: 002b:00007f395aaf57d8 EFLAGS: 00000206 ORIG_RAX: ffffffffffffff6e [60103.826362] RAX: 0000000000000000 RBX: 00002f07bc6d0900 RCX: 00007f39752d7fe7 [60103.826365] RDX: 0000000000000022 RSI: 0000000000000147 RDI: 00002f07baea02c0 [60103.826368] RBP: 0000000000000001 R08: 0000000000000000 R09: 0000000000000000 [60103.826371] R10: 00000000ffffffff R11: 0000000000000000 R12: 00002f07baea02c0 [60103.826373] R13: 00002f07bba227a0 R14: 00002f07bc6d090c R15: 0000000000000000 [60103.826377] Code: 90 90 90 90 90 90 90 0f 1f 44 00 00 49 89 f9 48 89 d1 83 e2 07 48 c1 e9 03 40 0f b6 f6 48 b8 01 01 01 01 01 01 01 01 48 0f af c6 <f3> 48 ab 89 d1 f3 aa 4c 89 c8 c3 90 49 89 f9 40 88 f0 48 89 d1 [60103.826442] RIP: __memset+0x24/0x30 RSP: ffff964316c03b68 [60103.826444] CR2: ffff9641f2004000 Commit e1069bbfcf3b ("net: cdc_ncm: Reduce memory use when kernel memory low") made this bug much more likely to trigger by reducing the NTB size under memory pressure. Link: https://bugs.debian.org/893393 Reported-by: Горбешко Богдан <bodqhrohro@gmail.com> Reported-and-tested-by: Dennis Wassenberg <dennis.wassenberg@secunet.com> Cc: Enrico Mioso <mrkiko.rs@gmail.com> Fixes: 4a0e3e989d66 ("cdc_ncm: Add support for moving NDP to end of NCM frame") [ bmork: tx_curr_size => tx_max and context fixup for v4.12 and older ] Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03dm thin: handle running out of data space vs concurrent discardMike Snitzer
commit a685557fbbc3122ed11e8ad3fa63a11ebc5de8c3 upstream. Discards issued to a DM thin device can complete to userspace (via fstrim) _before_ the metadata changes associated with the discards is reflected in the thinp superblock (e.g. free blocks). As such, if a user constructs a test that loops repeatedly over these steps, block allocation can fail due to discards not having completed yet: 1) fill thin device via filesystem file 2) remove file 3) fstrim From initial report, here: https://www.redhat.com/archives/dm-devel/2018-April/msg00022.html "The root cause of this issue is that dm-thin will first remove mapping and increase corresponding blocks' reference count to prevent them from being reused before DISCARD bios get processed by the underlying layers. However. increasing blocks' reference count could also increase the nr_allocated_this_transaction in struct sm_disk which makes smd->old_ll.nr_allocated + smd->nr_allocated_this_transaction bigger than smd->old_ll.nr_blocks. In this case, alloc_data_block() will never commit metadata to reset the begin pointer of struct sm_disk, because sm_disk_get_nr_free() always return an underflow value." While there is room for improvement to the space-map accounting that thinp is making use of: the reality is this test is inherently racey and will result in the previous iteration's fstrim's discard(s) completing vs concurrent block allocation, via dd, in the next iteration of the loop. No amount of space map accounting improvements will be able to allow user's to use a block before a discard of that block has completed. So the best we can really do is allow DM thinp to gracefully handle such aggressive use of all the pool's data by degrading the pool into out-of-data-space (OODS) mode. We _should_ get that behaviour already (if space map accounting didn't falsely cause alloc_data_block() to believe free space was available).. but short of that we handle the current reality that dm_pool_alloc_data_block() can return -ENOSPC. Reported-by: Dennis Yang <dennisyang@qnap.com> Cc: stable@vger.kernel.org Signed-off-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03block: Fix transfer when chunk sectors exceeds maxKeith Busch
commit 15bfd21fbc5d35834b9ea383dc458a1f0c9e3434 upstream. A device may have boundary restrictions where the number of sectors between boundaries exceeds its max transfer size. In this case, we need to cap the max size to the smaller of the two limits. Reported-by: Jitendra Bhivare <jitendra.bhivare@broadcom.com> Tested-by: Jitendra Bhivare <jitendra.bhivare@broadcom.com> Cc: <stable@vger.kernel.org> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Keith Busch <keith.busch@intel.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03ALSA: hda/realtek - Add a quirk for FSC ESPRIMO U9210Takashi Iwai
commit 275ec0cb946cb75ac8977f662e608fce92f8b8a8 upstream. Fujitsu Seimens ESPRIMO Mobile U9210 requires the same fixup as H270 for the correct pin configs. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=200107 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03ALSA: hda/realtek - Fix pop noise on Lenovo P50 & coTakashi Iwai
commit d5a6cabf02210b896a60eee7c04c670ee9ba6dca upstream. Some Lenovo laptops, e.g. Lenovo P50, showed the pop noise at resume or runtime resume. It turned out to be reduced by applying alc_no_shutup() just like TPT440 quirk does. Since there are many Lenovo models showing the same behavior, put this workaround in ALC269_FIXUP_THINKPAD_ACPI entry so that it's applied commonly to all such Lenovo machines. Reported-by: Hans de Goede <hdegoede@redhat.com> Tested-by: Benjamin Berg <bberg@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03Input: elantech - fix V4 report decoding for module with middle key???
commit e0ae2519ca004a628fa55aeef969c37edce522d3 upstream. Some touchpad has middle key and it will be indicated in bit 2 of packet[0]. We need to fix V4 formation's byte mask to prevent error decoding. Signed-off-by: KT Liao <kt.liao@emc.com.tw> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03Input: elantech - enable middle button of touchpads on ThinkPad P52Aaron Ma
commit 24bb555e6e46d96e2a954aa0295029a81cc9bbaa upstream. PNPID is better way to identify the type of touchpads. Enable middle button support on 2 types of touchpads on Lenovo P52. Cc: stable@vger.kernel.org Signed-off-by: Aaron Ma <aaron.ma@canonical.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03Input: elan_i2c_smbus - fix more potential stack buffer overflowsBen Hutchings
commit 50fc7b61959af4b95fafce7fe5dd565199e0b61a upstream. Commit 40f7090bb1b4 ("Input: elan_i2c_smbus - fix corrupted stack") fixed most of the functions using i2c_smbus_read_block_data() to allocate a buffer with the maximum block size. However three functions were left unchanged: * In elan_smbus_initialize(), increase the buffer size in the same way. * In elan_smbus_calibrate_result(), the buffer is provided by the caller (calibrate_store()), so introduce a bounce buffer. Also name the result buffer size. * In elan_smbus_get_report(), the buffer is provided by the caller but happens to be the right length. Add a compile-time assertion to ensure this remains the case. Cc: <stable@vger.kernel.org> # 3.19+ Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03udf: Detect incorrect directory sizeJan Kara
commit fa65653e575fbd958bdf5fb9c4a71a324e39510d upstream. Detect when a directory entry is (possibly partially) beyond directory size and return EIO in that case since it means the filesystem is corrupted. Otherwise directory operations can further corrupt the directory and possibly also oops the kernel. CC: Anatoly Trosinenko <anatoly.trosinenko@gmail.com> CC: stable@vger.kernel.org Reported-and-tested-by: Anatoly Trosinenko <anatoly.trosinenko@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03xen: Remove unnecessary BUG_ON from __unbind_from_irq()Boris Ostrovsky
commit eef04c7b3786ff0c9cb1019278b6c6c2ea0ad4ff upstream. Commit 910f8befdf5b ("xen/pirq: fix error path cleanup when binding MSIs") fixed a couple of errors in error cleanup path of xen_bind_pirq_msi_to_irq(). This cleanup allowed a call to __unbind_from_irq() with an unbound irq, which would result in triggering the BUG_ON there. Since there is really no reason for the BUG_ON (xen_free_irq() can operate on unbound irqs) we can remove it. Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: stable@vger.kernel.org Reviewed-by: Juergen Gross <jgross@suse.com> Signed-off-by: Juergen Gross <jgross@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03mm: fix devmem_is_allowed() for sub-page System RAM intersectionsDan Williams
commit 2bdce74412c249ac01dfe36b6b0043ffd7a5361e upstream. Hussam reports: I was poking around and for no real reason, I did cat /dev/mem and strings /dev/mem. Then I saw the following warning in dmesg. I saved it and rebooted immediately. memremap attempted on mixed range 0x000000000009c000 size: 0x1000 ------------[ cut here ]------------ WARNING: CPU: 0 PID: 11810 at kernel/memremap.c:98 memremap+0x104/0x170 [..] Call Trace: xlate_dev_mem_ptr+0x25/0x40 read_mem+0x89/0x1a0 __vfs_read+0x36/0x170 The memremap() implementation checks for attempts to remap System RAM with MEMREMAP_WB and instead redirects those mapping attempts to the linear map. However, that only works if the physical address range being remapped is page aligned. In low memory we have situations like the following: 00000000-00000fff : Reserved 00001000-0009fbff : System RAM 0009fc00-0009ffff : Reserved ...where System RAM intersects Reserved ranges on a sub-page page granularity. Given that devmem_is_allowed() special cases any attempt to map System RAM in the first 1MB of memory, replace page_is_ram() with the more precise region_intersects() to trap attempts to map disallowed ranges. Link: https://bugzilla.kernel.org/show_bug.cgi?id=199999 Link: http://lkml.kernel.org/r/152856436164.18127.2847888121707136898.stgit@dwillia2-desk3.amr.corp.intel.com Fixes: 92281dee825f ("arch: introduce memremap()") Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reported-by: Hussam Al-Tayeb <me@hussam.eu.org> Tested-by: Hussam Al-Tayeb <me@hussam.eu.org> Cc: Christoph Hellwig <hch@lst.de> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03rbd: flush rbd_dev->watch_dwork after watch is unregisteredDongsheng Yang
commit 23edca864951250af845a11da86bb3ea63522ed2 upstream. There is a problem if we are going to unmap a rbd device and the watch_dwork is going to queue delayed work for watch: unmap Thread watch Thread timer do_rbd_remove cancel_tasks_sync(rbd_dev) queue_delayed_work for watch destroy_workqueue(rbd_dev->task_wq) drain_workqueue(wq) destroy other resources in wq call_timer_fn __queue_work() Then the delayed work escape the cancel_tasks_sync() and destroy_workqueue() and we will get an user-after-free call trace: BUG: unable to handle kernel NULL pointer dereference at 0000000000000000 PGD 0 P4D 0 Oops: 0000 [#1] SMP PTI Modules linked in: CPU: 7 PID: 0 Comm: swapper/7 Tainted: G OE 4.17.0-rc6+ #13 Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011 RIP: 0010:__queue_work+0x6a/0x3b0 RSP: 0018:ffff9427df1c3e90 EFLAGS: 00010086 RAX: ffff9427deca8400 RBX: 0000000000000000 RCX: 0000000000000000 RDX: ffff9427deca8400 RSI: ffff9427df1c3e50 RDI: 0000000000000000 RBP: ffff942783e39e00 R08: ffff9427deca8400 R09: ffff9427df1c3f00 R10: 0000000000000004 R11: 0000000000000005 R12: ffff9427cfb85970 R13: 0000000000002000 R14: 000000000001eca0 R15: 0000000000000007 FS: 0000000000000000(0000) GS:ffff9427df1c0000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 00000004c900a005 CR4: 00000000000206e0 Call Trace: <IRQ> ? __queue_work+0x3b0/0x3b0 call_timer_fn+0x2d/0x130 run_timer_softirq+0x16e/0x430 ? tick_sched_timer+0x37/0x70 __do_softirq+0xd2/0x280 irq_exit+0xd5/0xe0 smp_apic_timer_interrupt+0x6c/0x130 apic_timer_interrupt+0xf/0x20 [ Move rbd_dev->watch_dwork cancellation so that rbd_reregister_watch() either bails out early because the watch is UNREGISTERED at that point or just gets cancelled. ] Cc: stable@vger.kernel.org Fixes: 99d1694310df ("rbd: retry watch re-registration periodically") Signed-off-by: Dongsheng Yang <dongsheng.yang@easystack.cn> Reviewed-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03pwm: lpss: platform: Save/restore the ctrl register over a suspend/resumeHans de Goede
commit 1d375b58c12f08d8570b30b865def4734517f04f upstream. On some devices the contents of the ctrl register get lost over a suspend/resume and the PWM comes back up disabled after the resume. This is seen on some Bay Trail devices with the PWM in ACPI enumerated mode, so it shows up as a platform device instead of a PCI device. If we still think it is enabled and then try to change the duty-cycle after this, we end up with a "PWM_SW_UPDATE was not cleared" error and the PWM is stuck in that state from then on. This commit adds suspend and resume pm callbacks to the pwm-lpss-platform code, which save/restore the ctrl register over a suspend/resume, fixing this. Note that: 1) There is no need to do this over a runtime suspend, since we only runtime suspend when disabled and then we properly set the enable bit and reprogram the timings when we re-enable the PWM. 2) This may be happening on more systems then we realize, but has been covered up sofar by a bug in the acpi-lpss.c code which was save/restoring the regular device registers instead of the lpss private registers due to lpss_device_desc.prv_offset not being set. This is fixed by a later patch in this series. Cc: stable@vger.kernel.org Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03Input: elan_i2c - add ELAN0618 (Lenovo v330 15IKB) ACPI IDAlexandr Savca
commit 8938fc7b8fe9ccfa11751ead502a8d385b607967 upstream. Add ELAN0618 to the list of supported touchpads; this ID is used in Lenovo v330 15IKB devices. Signed-off-by: Alexandr Savca <alexandr.savca@saltedge.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03video: uvesafb: Fix integer overflow in allocationKees Cook
commit 9f645bcc566a1e9f921bdae7528a01ced5bc3713 upstream. cmap->len can get close to INT_MAX/2, allowing for an integer overflow in allocation. This uses kmalloc_array() instead to catch the condition. Reported-by: Dr Silvio Cesare of InfoSect <silvio.cesare@gmail.com> Fixes: 8bdb3a2d7df48 ("uvesafb: the driver core") Cc: stable@vger.kernel.org Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03NFSv4: Revert commit 5f83d86cf531d ("NFSv4.x: Fix wraparound issues..")Trond Myklebust
commit fc40724fc6731d90cc7fb6d62d66135f85a33dd2 upstream. The correct behaviour for NFSv4 sequence IDs is to wrap around to the value 0 after 0xffffffff. See https://tools.ietf.org/html/rfc5661#section-2.10.6.1 Fixes: 5f83d86cf531d ("NFSv4.x: Fix wraparound issues when validing...") Cc: stable@vger.kernel.org # 4.6+ Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03NFSv4: Fix possible 1-byte stack overflow in nfs_idmap_read_and_verify_messageDave Wysochanski
commit d68894800ec5712d7ddf042356f11e36f87d7f78 upstream. In nfs_idmap_read_and_verify_message there is an incorrect sprintf '%d' that converts the __u32 'im_id' from struct idmap_msg to 'id_str', which is a stack char array variable of length NFS_UINT_MAXLEN == 11. If a uid or gid value is > 2147483647 = 0x7fffffff, the conversion overflows into a negative value, for example: crash> p (unsigned) (0x80000000) $1 = 2147483648 crash> p (signed) (0x80000000) $2 = -2147483648 The '-' sign is written to the buffer and this causes a 1 byte overflow when the NULL byte is written, which corrupts kernel stack memory. If CONFIG_CC_STACKPROTECTOR_STRONG is set we see a stack-protector panic: [11558053.616565] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffffa05b8a8c [11558053.639063] CPU: 6 PID: 9423 Comm: rpc.idmapd Tainted: G W ------------ T 3.10.0-514.el7.x86_64 #1 [11558053.641990] Hardware name: Red Hat OpenStack Compute, BIOS 1.10.2-3.el7_4.1 04/01/2014 [11558053.644462] ffffffff818c7bc0 00000000b1f3aec1 ffff880de0f9bd48 ffffffff81685eac [11558053.646430] ffff880de0f9bdc8 ffffffff8167f2b3 ffffffff00000010 ffff880de0f9bdd8 [11558053.648313] ffff880de0f9bd78 00000000b1f3aec1 ffffffff811dcb03 ffffffffa05b8a8c [11558053.650107] Call Trace: [11558053.651347] [<ffffffff81685eac>] dump_stack+0x19/0x1b [11558053.653013] [<ffffffff8167f2b3>] panic+0xe3/0x1f2 [11558053.666240] [<ffffffff811dcb03>] ? kfree+0x103/0x140 [11558053.682589] [<ffffffffa05b8a8c>] ? idmap_pipe_downcall+0x1cc/0x1e0 [nfsv4] [11558053.689710] [<ffffffff810855db>] __stack_chk_fail+0x1b/0x30 [11558053.691619] [<ffffffffa05b8a8c>] idmap_pipe_downcall+0x1cc/0x1e0 [nfsv4] [11558053.693867] [<ffffffffa00209d6>] rpc_pipe_write+0x56/0x70 [sunrpc] [11558053.695763] [<ffffffff811fe12d>] vfs_write+0xbd/0x1e0 [11558053.702236] [<ffffffff810acccc>] ? task_work_run+0xac/0xe0 [11558053.704215] [<ffffffff811fec4f>] SyS_write+0x7f/0xe0 [11558053.709674] [<ffffffff816964c9>] system_call_fastpath+0x16/0x1b Fix this by calling the internally defined nfs_map_numeric_to_string() function which properly uses '%u' to convert this __u32. For consistency, also replace the one other place where snprintf is called. Signed-off-by: Dave Wysochanski <dwysocha@redhat.com> Reported-by: Stephen Johnston <sjohnsto@redhat.com> Fixes: cf4ab538f1516 ("NFSv4: Fix the string length returned by the idmapper") Cc: stable@vger.kernel.org # v3.4+ Signed-off-by: Trond Myklebust <trond.myklebust@hammerspace.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03nfsd: restrict rd_maxcount to svc_max_payload in nfsd_encode_readdirScott Mayhew
commit 9c2ece6ef67e9d376f32823086169b489c422ed0 upstream. nfsd4_readdir_rsize restricts rd_maxcount to svc_max_payload when estimating the size of the readdir reply, but nfsd_encode_readdir restricts it to INT_MAX when encoding the reply. This can result in log messages like "kernel: RPC request reserved 32896 but used 1049444". Restrict rd_dircount similarly (no reason it should be larger than svc_max_payload). Signed-off-by: Scott Mayhew <smayhew@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03media: dvb_frontend: fix locking issues at dvb_frontend_get_event()Mauro Carvalho Chehab
commit 76d81243a487c09619822ef8e7201a756e58a87d upstream. As warned by smatch: drivers/media/dvb-core/dvb_frontend.c:314 dvb_frontend_get_event() warn: inconsistent returns 'sem:&fepriv->sem'. Locked on: line 288 line 295 line 306 line 314 Unlocked on: line 303 The lock implementation for get event is wrong, as, if an interrupt occurs, down_interruptible() will fail, and the routine will call up() twice when userspace calls the ioctl again. The bad code is there since when Linux migrated to git, in 2005. Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03media: cx231xx: Add support for AverMedia DVD EZMaker 7Kai-Heng Feng
commit 29e61d6ef061b012d320327af7dbb3990e75be45 upstream. User reports AverMedia DVD EZMaker 7 can be driven by VIDEO_GRABBER. Add the device to the id_table to make it work. BugLink: https://bugs.launchpad.net/bugs/1620762 Cc: stable@vger.kernel.org Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com> Signed-off-by: Hans Verkuil <hansverk@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03media: v4l2-compat-ioctl32: prevent go past max sizeMauro Carvalho Chehab
commit ea72fbf588ac9c017224dcdaa2019ff52ca56fee upstream. As warned by smatch: drivers/media/v4l2-core/v4l2-compat-ioctl32.c:879 put_v4l2_ext_controls32() warn: check for integer overflow 'count' The access_ok() logic should check for too big arrays too. Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03perf intel-pt: Fix packet decoding of CYC packetsAdrian Hunter
commit 621a5a327c1e36ffd7bb567f44a559f64f76358f upstream. Use a 64-bit type so that the cycle count is not limited to 32-bits. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1528371002-8862-1-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03perf intel-pt: Fix "Unexpected indirect branch" errorAdrian Hunter
commit 9fb523363f6e3984457fee95bb7019395384ffa7 upstream. Some Atom CPUs can produce FUP packets that contain NLIP (next linear instruction pointer) instead of CLIP (current linear instruction pointer). That will result in "Unexpected indirect branch" errors. Fix by comparing IP to NLIP in that case. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1527762225-26024-5-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03perf intel-pt: Fix MTC timing after overflowAdrian Hunter
commit dd27b87ab5fcf3ea1c060b5e3ab5d31cc78e9f4c upstream. On some platforms, overflows will clear before MTC wraparound, and there is no following TSC/TMA packet. In that case the previous TMA is valid. Since there will be a valid TMA either way, stop setting 'have_tma' to false upon overflow. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1527762225-26024-4-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03perf intel-pt: Fix decoding to accept CBR between FUP and corresponding TIPAdrian Hunter
commit bd2e49ec48feb1855f7624198849eea4610e2286 upstream. It is possible to have a CBR packet between a FUP packet and corresponding TIP packet. Stop treating it as an error. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1527762225-26024-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03perf intel-pt: Fix sync_switch INTEL_PT_SS_NOT_TRACINGAdrian Hunter
commit dbcb82b93f3e8322891e47472c89e63058b81e99 upstream. sync_switch is a facility to synchronize decoding more closely with the point in the kernel when the context actually switched. In one case, INTEL_PT_SS_NOT_TRACING state was not correctly transitioning to INTEL_PT_SS_TRACING state due to a missing case clause. Add it. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1527762225-26024-2-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03perf tools: Fix symbol and object code resolution for vdso32 and vdsox32Adrian Hunter
commit aef4feace285f27c8ed35830a5d575bec7f3e90a upstream. Fix __kmod_path__parse() so that perf tools does not treat vdso32 and vdsox32 as kernel modules and fail to find the object. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Wang Nan <wangnan0@huawei.com> Cc: stable@vger.kernel.org Fixes: 1f121b03d058 ("perf tools: Deal with kernel module names in '[]' correctly") Link: http://lkml.kernel.org/r/1528117014-30032-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03mfd: intel-lpss: Program REMAP register in PIO modeAndy Shevchenko
commit d28b62520830b2d0bffa2d98e81afc9f5e537e8b upstream. According to documentation REMAP register has to be programmed in either DMA or PIO mode of the slice. Move the DMA capability check below to let REMAP register be programmed in PIO mode. Cc: stable@vger.kernel.org # 4.3+ Fixes: 4b45efe85263 ("mfd: Add support for Intel Sunrisepoint LPSS devices") Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03backlight: tps65217_bl: Fix Device Tree node lookupJohan Hovold
commit 2b12dfa124dbadf391cb9a616aaa6b056823bf75 upstream. Fix child-node lookup during probe, which ended up searching the whole device tree depth-first starting at the parent rather than just matching on its children. This would only cause trouble if the child node is missing while there is an unrelated node named "backlight" elsewhere in the tree. Cc: stable <stable@vger.kernel.org> # 3.7 Fixes: eebfdc17cc6c ("backlight: Add TPS65217 WLED driver") Signed-off-by: Johan Hovold <johan@kernel.org> Acked-by: Daniel Thompson <daniel.thompson@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03backlight: max8925_bl: Fix Device Tree node lookupJohan Hovold
commit d1cc0ec3da23e44c23712579515494b374f111c9 upstream. Fix child-node lookup during probe, which ended up searching the whole device tree depth-first starting at the parent rather than just matching on its children. To make things worse, the parent mfd node was also prematurely freed, while the child backlight node was leaked. Cc: stable <stable@vger.kernel.org> # 3.9 Fixes: 47ec340cb8e2 ("mfd: max8925: Support dt for backlight") Signed-off-by: Johan Hovold <johan@kernel.org> Acked-by: Daniel Thompson <daniel.thompson@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03backlight: as3711_bl: Fix Device Tree node lookupJohan Hovold
commit 4a9c8bb2aca5b5a2a15744333729745dd9903562 upstream. Fix child-node lookup during probe, which ended up searching the whole device tree depth-first starting at the parent rather than just matching on its children. To make things worse, the parent mfd node was also prematurely freed. Cc: stable <stable@vger.kernel.org> # 3.10 Fixes: 59eb2b5e57ea ("drivers/video/backlight/as3711_bl.c: add OF support") Signed-off-by: Johan Hovold <johan@kernel.org> Acked-by: Daniel Thompson <daniel.thompson@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03UBIFS: Fix potential integer overflow in allocationSilvio Cesare
commit 353748a359f1821ee934afc579cf04572406b420 upstream. There is potential for the size and len fields in ubifs_data_node to be too large causing either a negative value for the length fields or an integer overflow leading to an incorrect memory allocation. Likewise, when the len field is small, an integer underflow may occur. Signed-off-by: Silvio Cesare <silvio.cesare@gmail.com> Fixes: 1e51764a3c2ac ("UBIFS: add new flash file system") Cc: stable@vger.kernel.org Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03ubi: fastmap: Correctly handle interrupted erasures in EBARichard Weinberger
commit 781932375ffc6411713ee0926ccae8596ed0261c upstream. Fastmap cannot track the LEB unmap operation, therefore it can happen that after an interrupted erasure the mapping still looks good from Fastmap's point of view, while reading from the PEB will cause an ECC error and confuses the upper layer. Instead of teaching users of UBI how to deal with that, we read back the VID header and check for errors. If the PEB is empty or shows ECC errors we fixup the mapping and schedule the PEB for erasure. Fixes: dbb7d2a88d2a ("UBI: Add fastmap core") Cc: <stable@vger.kernel.org> Reported-by: martin bayern <Martinbayern@outlook.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03ubi: fastmap: Cancel work upon detachRichard Weinberger
commit 6e7d80161066c99d12580d1b985cb1408bb58cf1 upstream. Ben Hutchings pointed out that 29b7a6fa1ec0 ("ubi: fastmap: Don't flush fastmap work on detach") does not really fix the problem, it just reduces the risk to hit the race window where fastmap work races against free()'ing ubi->volumes[]. The correct approach is making sure that no more fastmap work is in progress before we free ubi data structures. So we cancel fastmap work right after the ubi background thread is stopped. By setting ubi->thread_enabled to zero we make sure that no further work tries to wake the thread. Fixes: 29b7a6fa1ec0 ("ubi: fastmap: Don't flush fastmap work on detach") Fixes: 74cdaf24004a ("UBI: Fastmap: Fix memory leaks while closing the WL sub-system") Cc: stable@vger.kernel.org Cc: Ben Hutchings <ben.hutchings@codethink.co.uk> Cc: Martin Townsend <mtownsend1973@gmail.com> Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03rpmsg: smd: do not use mananged resources for endpoints and channelsSrinivas Kandagatla
commit 4a2e84c6ed85434ce7843e4844b4d3263f7e233b upstream. All the managed resources would be freed by the time release function is invoked. Handling such memory in qcom_smd_edge_release() would do bad things. Found this issue while testing Audio usecase where the dsp is started up and shutdown in a loop. This patch fixes this issue by using simple kzalloc for allocating channel->name and channel which is then freed in qcom_smd_edge_release(). Without this patch restarting a remoteproc would crash the system. Fixes: 53e2822e56c7 ("rpmsg: Introduce Qualcomm SMD backend") Cc: <stable@vger.kernel.org> Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03md: fix two problems with setting the "re-add" device state.NeilBrown
commit 011abdc9df559ec75779bb7c53a744c69b2a94c6 upstream. If "re-add" is written to the "state" file for a device which is faulty, this has an effect similar to removing and re-adding the device. It should take up the same slot in the array that it previously had, and an accelerated (e.g. bitmap-based) rebuild should happen. The slot that "it previously had" is determined by rdev->saved_raid_disk. However this is not set when a device fails (only when a device is added), and it is cleared when resync completes. This means that "re-add" will normally work once, but may not work a second time. This patch includes two fixes. 1/ when a device fails, record the ->raid_disk value in ->saved_raid_disk before clearing ->raid_disk 2/ when "re-add" is written to a device for which ->saved_raid_disk is not set, fail. I think this is suitable for stable as it can cause re-adding a device to be forced to do a full resync which takes a lot longer and so puts data at more risk. Cc: <stable@vger.kernel.org> (v4.1) Fixes: 97f6cd39da22 ("md-cluster: re-add capabilities") Signed-off-by: NeilBrown <neilb@suse.com> Reviewed-by: Goldwyn Rodrigues <rgoldwyn@suse.com> Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03clk: at91: PLL recalc_rate() now using cached MUL and DIV valuesMarcin Ziemianowicz
commit a982e45dc150da3a08907b6dd676b735391704b4 upstream. When a USB device is connected to the USB host port on the SAM9N12 then you get "-62" error which seems to indicate USB replies from the device are timing out. Based on a logic sniffer, I saw the USB bus was running at half speed. The PLL code uses cached MUL and DIV values which get set in set_rate() and applied in prepare(), but the recalc_rate() function instead queries the hardware instead of using these cached values. Therefore, if recalc_rate() is called between a set_rate() and prepare(), the wrong frequency is calculated and later the USB clock divider for the SAM9N12 SOC will be configured for an incorrect clock. In my case, the PLL hardware was set to 96 Mhz before the OHCI driver loads, and therefore the usb clock divider was being set to /2 even though the OHCI driver set the PLL to 48 Mhz. As an alternative explanation, I noticed this was fixed in the past by 87e2ed338f1b ("clk: at91: fix recalc_rate implementation of PLL driver") but the bug was later re-introduced by 1bdf02326b71 ("clk: at91: make use of syscon/regmap internally"). Fixes: 1bdf02326b71 ("clk: at91: make use of syscon/regmap internally) Cc: <stable@vger.kernel.org> Signed-off-by: Marcin Ziemianowicz <marcin@ziemianowicz.com> Acked-by: Boris Brezillon <boris.brezillon@bootlin.com> Signed-off-by: Stephen Boyd <sboyd@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03linvdimm, pmem: Preserve read-only setting for pmem devicesRobert Elliott
commit 254a4cd50b9fe2291a12b8902e08e56dcc4e9b10 upstream. The pmem driver does not honor a forced read-only setting for very long: $ blockdev --setro /dev/pmem0 $ blockdev --getro /dev/pmem0 1 followed by various commands like these: $ blockdev --rereadpt /dev/pmem0 or $ mkfs.ext4 /dev/pmem0 results in this in the kernel serial log: nd_pmem namespace0.0: region0 read-write, marking pmem0 read-write with the read-only setting lost: $ blockdev --getro /dev/pmem0 0 That's from bus.c nvdimm_revalidate_disk(), which always applies the setting from nd_region (which is initially based on the ACPI NFIT NVDIMM state flags not_armed bit). In contrast, commit 20bd1d026aac ("scsi: sd: Keep disk read-only when re-reading partition") fixed this issue for SCSI devices to preserve the previous setting if it was set to read-only. This patch modifies bus.c to preserve any previous read-only setting. It also eliminates the kernel serial log print except for cases where read-write is changed to read-only, so it doesn't print read-only to read-only non-changes. Cc: <stable@vger.kernel.org> Fixes: 581388209405 ("libnvdimm, nfit: handle unarmed dimms, mark namespaces read-only") Signed-off-by: Robert Elliott <elliott@hpe.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03scsi: zfcp: fix missing REC trigger trace on enqueue without ERP threadSteffen Maier
commit 6a76550841d412330bd86aed3238d1888ba70f0e upstream. Example trace record formatted with zfcpdbf from s390-tools: Timestamp : ... Area : REC Subarea : 00 Level : 1 Exception : - CPU ID : .. Caller : 0x... Record ID : 1 ZFCP_DBF_REC_TRIG Tag : ....... LUN : 0x... WWPN : 0x... D_ID : 0x... Adapter status : 0x... Port status : 0x... LUN status : 0x... Ready count : 0x... Running count : 0x... ERP want : 0x0. ZFCP_ERP_ACTION_REOPEN_... ERP need : 0xc0 ZFCP_ERP_ACTION_NONE Signed-off-by: Steffen Maier <maier@linux.ibm.com> Cc: <stable@vger.kernel.org> #2.6.38+ Reviewed-by: Benjamin Block <bblock@linux.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03scsi: zfcp: fix missing REC trigger trace for all objects in ERP_FAILEDSteffen Maier
commit 8c3d20aada70042a39c6a6625be037c1472ca610 upstream. That other commit introduced an inconsistency because it would trace on ERP_FAILED for all callers of port forced reopen triggers (not just terminate_rport_io), but it would not trace on ERP_FAILED for all callers of other ERP triggers such as adapter, port regular, LUN. Therefore, generalize that other commit. zfcp_erp_action_enqueue() already had two early outs which re-used the one zfcp_dbf_rec_trig() call. All ERP trigger functions finally run through zfcp_erp_action_enqueue(). So move the special handling for ZFCP_STATUS_COMMON_ERP_FAILED into zfcp_erp_action_enqueue() and add another early out with new trace marker for pseudo ERP need in this case. This removes all early returns from all ERP trigger functions so we always end up at zfcp_dbf_rec_trig(). Example trace record formatted with zfcpdbf from s390-tools: Timestamp : ... Area : REC Subarea : 00 Level : 1 Exception : - CPU ID : .. Caller : 0x... Record ID : 1 ZFCP_DBF_REC_TRIG Tag : ....... LUN : 0x... WWPN : 0x... D_ID : 0x... Adapter status : 0x... Port status : 0x... LUN status : 0x... Ready count : 0x... Running count : 0x... ERP want : 0x0. ZFCP_ERP_ACTION_REOPEN_... ERP need : 0xe0 ZFCP_ERP_ACTION_FAILED Signed-off-by: Steffen Maier <maier@linux.ibm.com> Cc: <stable@vger.kernel.org> #2.6.38+ Reviewed-by: Benjamin Block <bblock@linux.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03scsi: zfcp: fix missing REC trigger trace on terminate_rport_io for ERP_FAILEDSteffen Maier
commit d70aab55924b44f213fec2b900b095430b33eec6 upstream. For problem determination we always want to see when we were invoked on the terminate_rport_io callback whether we perform something or not. Temporal event sequence of interest with a long fast_io_fail_tmo of 27 sec: loose remote port t workqueue [s] zfcp_q_<dev> IRQ zfcperp<dev> === ================== =================== ============================ 0 recv RSCN q p.test_link_work block rport start fast_io_fail_tmo send ADISC ELS 4 recv ADISC fail block zfcp_port port forced reopen send open port 12 recv open port fail q p.gid_pn_work zfcp_erp_wakeup (zfcp_erp_wait would return) GID_PN fail Before this point, we got a SCSI trace with tag "sctrpi1" on fast_io_fail, e.g. with the typical 5 sec setting. port.status |= ERP_FAILED If fast_io_fail_tmo triggers after this point, we missed a SCSI trace. workqueue fc_dl_<host> ================== 27 fc_timeout_fail_rport_io fc_terminate_rport_io zfcp_scsi_terminate_rport_io zfcp_erp_port_forced_reopen _zfcp_erp_port_forced_reopen if (port.status & ERP_FAILED) return; Therefore, write a trace before above early return. Example trace record formatted with zfcpdbf from s390-tools: Timestamp : ... Area : REC Subarea : 00 Level : 1 Exception : - CPU ID : .. Caller : 0x... Record ID : 1 ZFCP_DBF_REC_TRIG Tag : sctrpi1 SCSI terminate rport I/O LUN : 0xffffffffffffffff none (invalid) WWPN : 0x<wwpn> D_ID : 0x<n_port_id> Adapter status : 0x... Port status : 0x... LUN status : 0x00000000 none (invalid) Ready count : 0x... Running count : 0x... ERP want : 0x03 ZFCP_ERP_ACTION_REOPEN_PORT_FORCED ERP need : 0xe0 ZFCP_ERP_ACTION_FAILED Signed-off-by: Steffen Maier <maier@linux.ibm.com> Cc: <stable@vger.kernel.org> #2.6.38+ Reviewed-by: Benjamin Block <bblock@linux.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03scsi: zfcp: fix missing REC trigger trace on terminate_rport_io early returnSteffen Maier
commit 96d9270499471545048ed8a6d7f425a49762283d upstream. get_device() and its internally used kobject_get() only return NULL if they get passed NULL as argument. zfcp_get_port_by_wwpn() loops over adapter->port_list so the iteration variable port is always non-NULL. Struct device is embedded in struct zfcp_port so &port->dev is always non-NULL. This is the argument to get_device(). However, if we get an fc_rport in terminate_rport_io() for which we cannot find a match within zfcp_get_port_by_wwpn(), the latter can return NULL. v2.6.30 commit 70932935b61e ("[SCSI] zfcp: Fix oops when port disappears") introduced an early return without adding a trace record for this case. Even if we don't need recovery in this case, for debugging we should still see that our callback was invoked originally by scsi_transport_fc. Example trace record formatted with zfcpdbf from s390-tools: Timestamp : ... Area : REC Subarea : 00 Level : 1 Exception : - CPU ID : .. Caller : 0x... Record ID : 1 Tag : sctrpin SCSI terminate rport I/O, no zfcp port LUN : 0xffffffffffffffff none (invalid) WWPN : 0x<wwpn> WWPN D_ID : 0x<n_port_id> N_Port-ID Adapter status : 0x... Port status : 0xffffffff unknown (-1) LUN status : 0x00000000 none (invalid) Ready count : 0x... Running count : 0x... ERP want : 0x03 ZFCP_ERP_ACTION_REOPEN_PORT_FORCED ERP need : 0xc0 ZFCP_ERP_ACTION_NONE Signed-off-by: Steffen Maier <maier@linux.ibm.com> Fixes: 70932935b61e ("[SCSI] zfcp: Fix oops when port disappears") Cc: <stable@vger.kernel.org> #2.6.38+ Reviewed-by: Benjamin Block <bblock@linux.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03scsi: zfcp: fix misleading REC trigger trace where erp_action setup failedSteffen Maier
commit 512857a795cbbda5980efa4cdb3c0b6602330408 upstream. If a SCSI device is deleted during scsi_eh host reset, we cannot get a reference to the SCSI device anymore since scsi_device_get returns !=0 by design. Assuming the recovery of adapter and port(s) was successful, zfcp_erp_strategy_followup_success() attempts to trigger a LUN reset for the half-gone SCSI device. Unfortunately, it causes the following confusing trace record which states that zfcp will do a LUN recovery as "ERP need" is ZFCP_ERP_ACTION_REOPEN_LUN == 1 and equals "ERP want". Old example trace record formatted with zfcpdbf from s390-tools: Tag: : ersfs_3 ERP, trigger, unit reopen, port reopen succeeded LUN : 0x<FCP_LUN> WWPN : 0x<WWPN> D_ID : 0x<N_Port-ID> Adapter status : 0x5400050b Port status : 0x54000001 LUN status : 0x40000000 ZFCP_STATUS_COMMON_RUNNING but not ZFCP_STATUS_COMMON_UNBLOCKED as it was closed on close part of adapter reopen ERP want : 0x01 ERP need : 0x01 misleading However, zfcp_erp_setup_act() returns NULL as it cannot get the reference. Hence, zfcp_erp_action_enqueue() takes an early goto out and _NO_ recovery actually happens. We always do want the recovery trigger trace record even if no erp_action could be enqueued as in this case. For other cases where we did not enqueue an erp_action, 'need' has always been zero to indicate this. In order to indicate above goto out, introduce an eyecatcher "flag" to mark the "ERP need" as 'not needed' but still keep the information which erp_action type, that zfcp_erp_required_act() had decided upon, is needed. 0xc_ is chosen to be visibly different from 0x0_ in "ERP want". New example trace record formatted with zfcpdbf from s390-tools: Tag: : ersfs_3 ERP, trigger, unit reopen, port reopen succeeded LUN : 0x<FCP_LUN> WWPN : 0x<WWPN> D_ID : 0x<N_Port-ID> Adapter status : 0x5400050b Port status : 0x54000001 LUN status : 0x40000000 ERP want : 0x01 ERP need : 0xc1 would need LUN ERP, but no action set up ^ Before v2.6.38 commit ae0904f60fab ("[SCSI] zfcp: Redesign of the debug tracing for recovery actions.") we could detect this case because the "erp_action" field in the trace was NULL. The rework removed erp_action as argument and field from the trace. This patch here is for tracing. A fix to allow LUN recovery in the case at hand is a topic for a separate patch. See also commit fdbd1c5e27da ("[SCSI] zfcp: Allow running unit/LUN shutdown without acquiring reference") for a similar case and background info. Signed-off-by: Steffen Maier <maier@linux.ibm.com> Fixes: ae0904f60fab ("[SCSI] zfcp: Redesign of the debug tracing for recovery actions.") Cc: <stable@vger.kernel.org> #2.6.38+ Reviewed-by: Benjamin Block <bblock@linux.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03scsi: zfcp: fix missing SCSI trace for retry of abort / scsi_eh TMFSteffen Maier
commit 81979ae63e872ef650a7197f6ce6590059d37172 upstream. We already have a SCSI trace for the end of abort and scsi_eh TMF. Due to zfcp_erp_wait() and fc_block_scsi_eh() time can pass between the start of our eh callback and an actual send/recv of an abort / TMF request. In order to see the temporal sequence including any abort / TMF send retries, add a trace before the above two blocking functions. This supports problem determination with scsi_eh and parallel zfcp ERP. No need to explicitly trace the beginning of our eh callback, since we typically can send an abort / TMF and see its HBA response (in the worst case, it's a pseudo response on dismiss all of adapter recovery, e.g. due to an FSF request timeout [fsrth_1] of the abort / TMF). If we cannot send, we now get a trace record for the first "abrt_wt" or "[lt]r_wait" which denotes almost the beginning of the callback. No need to explicitly trace the wakeup after the above two blocking functions because the next retry loop causes another trace in any case and that is sufficient. Example trace records formatted with zfcpdbf from s390-tools: Timestamp : ... Area : SCSI Subarea : 00 Level : 1 Exception : - CPU ID : .. Caller : 0x... Record ID : 1 Tag : abrt_wt abort, before zfcp_erp_wait() Request ID : 0x0000000000000000 none (invalid) SCSI ID : 0x<scsi_id> SCSI LUN : 0x<scsi_lun> SCSI LUN high : 0x<scsi_lun_high> SCSI result : 0x<scsi_result_of_cmd_to_be_aborted> SCSI retries : 0x<retries_of_cmd_to_be_aborted> SCSI allowed : 0x<allowed_retries_of_cmd_to_be_aborted> SCSI scribble : 0x<req_id_of_cmd_to_be_aborted> SCSI opcode : <CDB_of_cmd_to_be_aborted> FCP rsp inf cod: 0x.. none (invalid) FCP rsp IU : ... none (invalid) Timestamp : ... Area : SCSI Subarea : 00 Level : 1 Exception : - CPU ID : .. Caller : 0x... Record ID : 1 Tag : lr_wait LUN reset, before zfcp_erp_wait() Request ID : 0x0000000000000000 none (invalid) SCSI ID : 0x<scsi_id> SCSI LUN : 0x<scsi_lun> SCSI LUN high : 0x<scsi_lun_high> SCSI result : 0x... unrelated SCSI retries : 0x.. unrelated SCSI allowed : 0x.. unrelated SCSI scribble : 0x... unrelated SCSI opcode : ... unrelated FCP rsp inf cod: 0x.. none (invalid) FCP rsp IU : ... none (invalid) Signed-off-by: Steffen Maier <maier@linux.ibm.com> Fixes: 63caf367e1c9 ("[SCSI] zfcp: Improve reliability of SCSI eh handlers in zfcp") Fixes: af4de36d911a ("[SCSI] zfcp: Block scsi_eh thread for rport state BLOCKED") Cc: <stable@vger.kernel.org> #2.6.38+ Reviewed-by: Benjamin Block <bblock@linux.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03scsi: zfcp: fix missing SCSI trace for result of eh_host_reset_handlerSteffen Maier
commit df30781699f53e4fd4c494c6f7dd16e3d5c21d30 upstream. For problem determination we need to see whether and why we were successful or not. This allows deduction of scsi_eh escalation. Example trace record formatted with zfcpdbf from s390-tools: Timestamp : ... Area : SCSI Subarea : 00 Level : 1 Exception : - CPU ID : .. Caller : 0x... Record ID : 1 Tag : schrh_r SCSI host reset handler result Request ID : 0x0000000000000000 none (invalid) SCSI ID : 0xffffffff none (invalid) SCSI LUN : 0xffffffff none (invalid) SCSI LUN high : 0xffffffff none (invalid) SCSI result : 0x00002002 field re-used for midlayer value: SUCCESS or in other cases: 0x2009 == FAST_IO_FAIL SCSI retries : 0xff none (invalid) SCSI allowed : 0xff none (invalid) SCSI scribble : 0xffffffffffffffff none (invalid) SCSI opcode : ffffffff ffffffff ffffffff ffffffff none (invalid) FCP rsp inf cod: 0xff none (invalid) FCP rsp IU : 00000000 00000000 00000000 00000000 none (invalid) 00000000 00000000 v2.6.35 commit a1dbfddd02d2 ("[SCSI] zfcp: Pass return code from fc_block_scsi_eh to scsi eh") introduced the first return with something other than the previously hardcoded single SUCCESS return path. Signed-off-by: Steffen Maier <maier@linux.ibm.com> Fixes: a1dbfddd02d2 ("[SCSI] zfcp: Pass return code from fc_block_scsi_eh to scsi eh") Cc: <stable@vger.kernel.org> #2.6.38+ Reviewed-by: Jens Remus <jremus@linux.ibm.com> Reviewed-by: Benjamin Block <bblock@linux.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03scsi: qla2xxx: Fix setting lower transfer speed if GPSC failsHimanshu Madhani
commit 413c2f33489b134e3cc65d9c3ff7861e8fdfe899 upstream. This patch prevents driver from setting lower default speed of 1 GB/sec, if the switch does not support Get Port Speed Capabilities (GPSC) command. Setting this default speed results into much lower write performance for large sequential WRITE. This patch modifies driver to check for gpsc_supported flags and prevents driver from issuing MBC_SET_PORT_PARAM (001Ah) to set default speed of 1 GB/sec. If driver does not send this mailbox command, firmware assumes maximum supported link speed and will operate at the max speed. Cc: stable@vger.kernel.org Signed-off-by: Himanshu Madhani <himanshu.madhani@cavium.com> Reported-by: Eda Zhou <ezhou@redhat.com> Reviewed-by: Ewan D. Milne <emilne@redhat.com> Tested-by: Ewan D. Milne <emilne@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03iio:buffer: make length types match kfifo typesMartin Kelly
commit c043ec1ca5baae63726aae32abbe003192bc6eec upstream. Currently, we use int for buffer length and bytes_per_datum. However, kfifo uses unsigned int for length and size_t for element size. We need to make sure these matches or we will have bugs related to overflow (in the range between INT_MAX and UINT_MAX for length, for example). In addition, set_bytes_per_datum uses size_t while bytes_per_datum is an int, which would cause bugs for large values of bytes_per_datum. Change buffer length to use unsigned int and bytes_per_datum to use size_t. Signed-off-by: Martin Kelly <mkelly@xevo.com> Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com> [bwh: Backported to 4.9: - Drop change to iio_dma_buffer_set_length() - Adjust filename, context] Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03Btrfs: fix unexpected cow in run_delalloc_nocowLiu Bo
commit 5811375325420052fcadd944792a416a43072b7f upstream. Fstests generic/475 provides a way to fail metadata reads while checking if checksum exists for the inode inside run_delalloc_nocow(), and csum_exist_in_range() interprets error (-EIO) as inode having checksum and makes its caller enter the cow path. In case of free space inode, this ends up with a warning in cow_file_range(). The same problem applies to btrfs_cross_ref_exist() since it may also read metadata in between. With this, run_delalloc_nocow() bails out when errors occur at the two places. cc: <stable@vger.kernel.org> v2.6.28+ Fixes: 17d217fe970d ("Btrfs: fix nodatasum handling in balancing code") Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: David Sterba <dsterba@suse.com> Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03Btrfs: fix return value on rename exchange failureFilipe Manana
commit c5b4a50b74018b3677098151ec5f4fce07d5e6a0 upstream. If we failed during a rename exchange operation after starting/joining a transaction, we would end up replacing the return value, stored in the local 'ret' variable, with the return value from btrfs_end_transaction(). So this could end up returning 0 (success) to user space despite the operation having failed and aborted the transaction, because if there are multiple tasks having a reference on the transaction at the time btrfs_end_transaction() is called by the rename exchange, that function returns 0 (otherwise it returns -EIO and not the original error value). So fix this by not overwriting the return value on error after getting a transaction handle. Fixes: cdd1fedf8261 ("btrfs: add support for RENAME_EXCHANGE and RENAME_WHITEOUT") CC: stable@vger.kernel.org # 4.9+ Signed-off-by: Filipe Manana <fdmanana@suse.com> Reviewed-by: David Sterba <dsterba@suse.com> Signed-off-by: David Sterba <dsterba@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-07-03X.509: unpack RSA signatureValue field from BIT STRINGMaciej S. Szmigiero
commit b65c32ec5a942ab3ada93a048089a938918aba7f upstream. The signatureValue field of a X.509 certificate is encoded as a BIT STRING. For RSA signatures this BIT STRING is of so-called primitive subtype, which contains a u8 prefix indicating a count of unused bits in the encoding. We have to strip this prefix from signature data, just as we already do for key data in x509_extract_key_data() function. This wasn't noticed earlier because this prefix byte is zero for RSA key sizes divisible by 8. Since BIT STRING is a big-endian encoding adding zero prefixes has no bearing on its value. The signature length, however was incorrect, which is a problem for RSA implementations that need it to be exactly correct (like AMD CCP). Signed-off-by: Maciej S. Szmigiero <mail@maciej.szmigiero.name> Fixes: c26fd69fa009 ("X.509: Add a crypto key parser for binary (DER) X.509 certificates") Cc: stable@vger.kernel.org Signed-off-by: James Morris <james.morris@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
