2013-10-23ARM: mvebu: Add the core-divider clock to Armada 370/XPEzequiel Garcia
The Armada 370/XP SoC has a clock provider called "Core Divider", that is derived from a fixed 2 GHz PLL clock. Reviewed-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-23ARM: mvebu: Add a 2 GHz fixed-clock Armada 370/XPEzequiel Garcia
Armada 370/XP SoCs have a 2 GHz fixed PLL that is used to feed other clocks. This commit adds a DT representation of this clock through a fixed-clock compatible node. Reviewed-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-23ARM: mvebu: Add Core Divider clock device-tree bindingEzequiel Garcia
The Armada 370/XP SoCs have a Core Divider clock providing several clocks. For now, only the NAND clock is supported. Reviewed-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-09ARM: Dove: fix bad properties of the si5351 clkout2 used by Cubox audioJean-Francois Moine
As defined in the DT, clkout2 is not allowed to change the pll inside si5351. This patch extends the properties of clkout2 so that it works as the external clock of the audio device in the Cubox. Also, as the second si5351 clock is not used in the Cubox, its definition is removed. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-09ARM: Dove: Add the audio device to the Cubox DTJean-Francois Moine
This patch activates the audio device of the Cubox. The audio flow (pin mpp_audio1) is output on both I2S and S/PDIF. The third si5351 clock (#2, pin mpp13) is used as the external clock. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-09ARM: Dove: Add the audio devices in DTJean-Francois Moine
This patch adds the nodes to instantiate the audio devices of the Dove boards. Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Acked-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-03arm: mvebu: add support for the Armada XP Matrix boardThomas Petazzoni
The Armada XP Matrix board is the mother board of a more complex system. The mother board uses an Armada XP MV78460, 4 serial ports, 2 SATA ports, one Ethernet connection, a PCIe port and a USB port. All those devices are enabled in the Device Tree added by this patch. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-03ARM: kirkwood: ib62x0: add u-boot environment partitionLuka Perkov
Also, add some trivial whitespace cleanup. Signed-off-by: Luka Perkov <luka@openwrt.org> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-01ARM: kirkwood: Move the nand node under the mbus nodeJason Gunthorpe
There should be no nodes that are not children of the mbus. Move the nand node under the mbus, and rework the board .dts files to use an & reference to the nand node. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-01ARM: kirkwood: Move the crypto node under the mbus nodeJason Gunthorpe
There should be no nodes that are not children of the mbus. Move the crypto node under the mbus. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-10-01ARM: kirkwood: Remove kirkwood_setup_wins and rely on the DT bindingJason Gunthorpe
kirkwood_setup_wins is the last manual caller of mbus in kirkwood, don't call it for DT boards and rely on the DT having a mbus node with a proper ranges property to setup these windows. Move all the mbus ranges properties for all boards into kirkwood.dtsi, since they are currently all the same. This makes the DT self consistent, since the physical address of the NAND and CRYPTO are both referenced internally. The arbitary Linux constants KIRKWOOD_NAND_MEM_PHYS_BASE and KIRKWOOD_SRAM_PHYS_BASE no longer have to match the DT values. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-30ARM: dove: add initial DT file for Globalscale D3PlugSebastian Hesselbarth
This adds an initial DT file for the Globalscale D3Plug with Dove SoC. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-30ARM: dove: add PCIe controllers to SoC DTSebastian Hesselbarth
This adds a node for the pcie controllers found on Dove SoCs to the SoC DT include. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-30ARM: dove: relocate internal registers device nodesSebastian Hesselbarth
With mbus node in place, now relocate all internal device nodes to internal-regs node with proper address ranges. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-30ARM: dove: add MBus DT nodeSebastian Hesselbarth
This adds a MBus node including ranges and pcie apertures required later. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-30ARM: dove: add MBUS_ID macro to Dove DTSebastian Hesselbarth
This adds a macro used for defining address window's target ID and attribute cells for the MBus ranges entry. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-30ARM: dove: use preprocessor on device tree filesSebastian Hesselbarth
This coverts Dove DT board files to preprocessor includes instead of dtc includes. Signed-off-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-30ARM: mvebu: link PCIe controllers to the MSI controllerThomas Petazzoni
This commit adjusts the Armada 370 and Armada XP PCIe controllers Device Tree informations to reference their MSI controller. In the case of this platform, the MSI controller is implemented by the MPIC. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Daniel Price <daniel.price@gmail.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-30ARM: mvebu: the MPIC now provides MSI controller featuresThomas Petazzoni
Adds the 'msi-controller' property to the main interrupt controller Device Tree node, to indicate that it can now behave as a MSI controller. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Thierry Reding <thierry.reding@gmail.com> Tested-by: Daniel Price <daniel.price@gmail.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-17ARM: dts: mvebu: Update with the new compatible string for mv64xxx-i2cGregory CLEMENT
The mv64xxx-i2c embedded in the Armada XP have a new feature to offload i2c transaction. This new version of the IP come also with some errata. This lead to the introduction to a another compatible string. This commit split the i2c information into armada-370.dtsi and armada-xp.dtsi. Most of the data remains the same and stay in the common file Armada-370-xp.dtsi. With this new feature the size of the registers are bigger for Armada XP and the new compatible string is used. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-09-16Linux 3.12-rc1v3.12-rc1Linus Torvalds
2013-09-16Merge branch 'timers/core' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer code update from Thomas Gleixner: - armada SoC clocksource overhaul with a trivial merge conflict - Minor improvements to various SoC clocksource drivers * 'timers/core' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clocksource: armada-370-xp: Add detailed clock requirements in devicetree binding clocksource: armada-370-xp: Get reference fixed-clock by name clocksource: armada-370-xp: Replace WARN_ON with BUG_ON clocksource: armada-370-xp: Fix device-tree binding clocksource: armada-370-xp: Introduce new compatibles clocksource: armada-370-xp: Use CLOCKSOURCE_OF_DECLARE clocksource: armada-370-xp: Simplify TIMER_CTRL register access clocksource: armada-370-xp: Use BIT() ARM: timer-sp: Set dynamic irq affinity ARM: nomadik: add dynamic irq flag to the timer clocksource: sh_cmt: 32-bit control register support clocksource: em_sti: Convert to devm_* managed helpers
2013-09-16Merge branch 'for-next' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Two minor cifs fixes and a minor documentation cleanup for cifs.txt" * 'for-next' of git://git.samba.org/sfrench/cifs-2.6: cifs: update cifs.txt and remove some outdated infos cifs: Avoid calling unlock_page() twice in cifs_readpage() when using fscache cifs: Do not take a reference to the page in cifs_readpage_worker()
2013-09-16Merge tag 'upstream-3.12-rc1' of git://git.infradead.org/linux-ubiLinus Torvalds
Pull UBI fixes from Artem Bityutskiy: "Just a single fastmap fix plus a regression fix" * tag 'upstream-3.12-rc1' of git://git.infradead.org/linux-ubi: UBI: Fix invalidate_fastmap() UBI: Fix PEB leak in wear_leveling_worker()
2013-09-16Merge tag 'upstream-3.12-rc1' of git://git.infradead.org/linux-ubifsLinus Torvalds
Pull ubifs fix from Artem Bityutskiy: "Just one patch which fixes the power-cut recovery testing mode. I'll start using a single UBI/UBIFS tree instead of 2 trees from now on. So in the future you'll get 1 small pull request instead of 2 tiny ones" * tag 'upstream-3.12-rc1' of git://git.infradead.org/linux-ubifs: UBIFS: remove invalid warn msg with tst_recovery enabled
2013-09-15Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "These are four patches for three construction sites: - Fix register decoding for the combination of multi-core processors and multi-threading. - Two more fixes that are part of the ongoing DECstation resurrection work. One of these touches a DECstation-only network driver. - Finally Markos' trivial build fix for the AP/SP support. (With this applied now all MIPS defconfigs are building again)" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: kernel: vpe: Make vpe_attrs an array of pointers. MIPS: Fix SMP core calculations when using MT support. MIPS: DECstation I/O ASIC DMA interrupt handling fix MIPS: DECstation HRT initialization rearrangement
2013-09-15Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform updates from Matthew Garrett: "Nothing amazing here, almost entirely cleanups and minor bugfixes and one bit of hardware enablement in the amilo-rfkill driver" * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: platform/x86: panasonic-laptop: reuse module_acpi_driver samsung-laptop: fix config build error platform: x86: remove unnecessary platform_set_drvdata() amilo-rfkill: Enable using amilo-rfkill with the FSC Amilo L1310. wmi: parse_wdg() should return kernel error codes hp_wmi: Fix unregister order in hp_wmi_rfkill_setup() platform: replace strict_strto*() with kstrto*() x86: irst: use module_acpi_driver to simplify the code x86: smartconnect: use module_acpi_driver to simplify the code platform samsung-q10: use ACPI instead of direct EC calls thinkpad_acpi: add the ability setting TPACPI_LED_NONE by quirk thinkpad_acpi: return -NODEV while operating uninitialized LEDs
2013-09-15Merge tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsiLinus Torvalds
Pull misc SCSI driver updates from James Bottomley: "This patch set is a set of driver updates (megaraid_sas, fnic, lpfc, ufs, hpsa) we also have a couple of bug fixes (sd out of bounds and ibmvfc error handling) and the first round of esas2r checker fixes and finally the much anticipated big endian additions for megaraid_sas" * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (47 commits) [SCSI] fnic: fnic Driver Tuneables Exposed through CLI [SCSI] fnic: Kernel panic while running sh/nosh with max lun cfg [SCSI] fnic: Hitting BUG_ON(io_req->abts_done) in fnic_rport_exch_reset [SCSI] fnic: Remove QUEUE_FULL handling code [SCSI] fnic: On system with >1.1TB RAM, VIC fails multipath after boot up [SCSI] fnic: FC stat param seconds_since_last_reset not getting updated [SCSI] sd: Fix potential out-of-bounds access [SCSI] lpfc 8.3.42: Update lpfc version to driver version 8.3.42 [SCSI] lpfc 8.3.42: Fixed issue of task management commands having a fixed timeout [SCSI] lpfc 8.3.42: Fixed inconsistent spin lock usage. [SCSI] lpfc 8.3.42: Fix driver's abort loop functionality to skip IOs already getting aborted [SCSI] lpfc 8.3.42: Fixed failure to allocate SCSI buffer on PPC64 platform for SLI4 devices [SCSI] lpfc 8.3.42: Fix WARN_ON when driver unloads [SCSI] lpfc 8.3.42: Avoided making pci bar ioremap call during dual-chute WQ/RQ pci bar selection [SCSI] lpfc 8.3.42: Fixed driver iocbq structure's iocb_flag field running out of space [SCSI] lpfc 8.3.42: Fix crash on driver load due to cpu affinity logic [SCSI] lpfc 8.3.42: Fixed logging format of setting driver sysfs attributes hard to interpret [SCSI] lpfc 8.3.42: Fixed back to back RSCNs discovery failure. [SCSI] lpfc 8.3.42: Fixed race condition between BSG I/O dispatch and timeout handling [SCSI] lpfc 8.3.42: Fixed function mode field defined too small for not recognizing dual-chute mode ...
2013-09-15Merge branch 'slab/next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux Pull SLAB update from Pekka Enberg: "Nothing terribly exciting here apart from Christoph's kmalloc unification patches that brings sl[aou]b implementations closer to each other" * 'slab/next' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/linux: slab: Use correct GFP_DMA constant slub: remove verify_mem_not_deleted() mm/sl[aou]b: Move kmallocXXX functions to common code mm, slab_common: add 'unlikely' to size check of kmalloc_slab() mm/slub.c: beautify code for removing redundancy 'break' statement. slub: Remove unnecessary page NULL check slub: don't use cpu partial pages on UP mm/slub: beautify code for 80 column limitation and tab alignment mm/slub: remove 'per_cpu' which is useless variable
2013-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input update from Dmitry Torokhov: "The only change is David Hermann's new EVIOCREVOKE evdev ioctl that allows safely passing file descriptors to input devices to session processes and later being able to stop delivery of events through these fds so that inactive sessions will no longer receive user input that does not belong to them" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: evdev - add EVIOCREVOKE ioctl
2013-09-15vfs: fix typo in comment in recent dentry workLinus Torvalds
Sedat points out that I transposed some letters in "LRU" and wrote "RLU" instead in one of the new comments explaining the flow. Let's just fix it. Reported-by: Sedat Dilek <sedat.dilek@jpberlin.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-15partitions/efi: loosen check fot pmbr size in lbaDavidlohr Bueso
Matt found that commit 27a7c642174e ("partitions/efi: account for pmbr size in lba") caused his GPT formatted eMMC device not to boot. The reason is that this commit enforced Linux to always check the lesser of the whole disk or 2Tib for the pMBR size in LBA. While most disk partitioning tools out there create a pMBR with these characteristics, Microsoft does not, as it always sets the entry to the maximum 32-bit limitation - even though a drive may be smaller than that[1]. Loosen this check and only verify that the size is either the whole disk or 0xFFFFFFFF. No tool in its right mind would set it to any value other than these. [1] http://thestarman.pcministry.com/asm/mbr/GPT.htm#GPTPT Reported-and-tested-by: Matt Porter <matt.porter@linaro.org> Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-13Merge tag 'writeback-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux Pull writeback fix from Wu Fengguang: "A trivial writeback fix" * tag 'writeback-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: Do not sort b_io list only because of block device inode
2013-09-13vfs: fix dentry LRU list handling and nr_dentry_unused accountingLinus Torvalds
The LRU list changes interacted badly with our nr_dentry_unused accounting, and even worse with the new DCACHE_LRU_LIST bit logic. This introduces helper functions to make sure everything follows the proper dcache d_lru list rules: the dentry cache is complicated by the fact that some of the hotpaths don't even want to look at the LRU list at all, and the fact that we use the same list entry in the dentry for both the LRU list and for our temporary shrinking lists when removing things from the LRU. The helper functions temporarily have some extra sanity checking for the flag bits that have to match the current LRU state of the dentry. We'll remove that before the final 3.12 release, but considering how easy it is to get wrong, this first cleanup version has some very particular sanity checking. Acked-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-13cifs: update cifs.txt and remove some outdated infosBjörn Jacke
Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Björn JACKE <bj@sernet.de> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-13cifs: Avoid calling unlock_page() twice in cifs_readpage() when using fscacheSachin Prabhu
When reading a single page with cifs_readpage(), we make a call to fscache_read_or_alloc_page() which once done, asynchronously calls the completion function cifs_readpage_from_fscache_complete(). This completion function unlocks the page once it has been populated from cache. The module then attempts to unlock the page a second time in cifs_readpage() which leads to warning messages. In case of a successful call to fscache_read_or_alloc_page() we should skip the second unlock_page() since this will be called by the cifs_readpage_from_fscache_complete() once the page has been populated by fscache. With the modifications to cifs_readpage_worker(), we will need to re-grab the page lock in cifs_write_begin(). The problem was first noticed when testing new fscache patches for cifs. https://bugzilla.redhat.com/show_bug.cgi?id=1005737 Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-13cifs: Do not take a reference to the page in cifs_readpage_worker()Sachin Prabhu
We do not need to take a reference to the pagecache in cifs_readpage_worker() since the calling function will have already taken one before passing the pointer to the page as an argument to the function. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-13Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon fixes from Guenter Roeck: "Some more low risk cleanup patches: - Remove unnecessary pci_set_drvdata in k10temp driver from Jingoo Han - Fix return values in several drivers from Sachin Kamat - Remove redundant break in amc6821 driver from Sachin Kamat" * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (k10temp) remove unnecessary pci_set_drvdata() hwmon: (tmp421) Fix return value hwmon: (amc6821) Remove redundant break hwmon: (amc6821) Fix return value hwmon: (ibmaem) Fix return value hwmon: (emc2103) Fix return value
2013-09-13Merge tag 'xtensa-next-20130912' of git://github.com/czankel/xtensa-linuxLinus Torvalds
Pull Xtensa updates from Chris Zankel. * tag 'xtensa-next-20130912' of git://github.com/czankel/xtensa-linux: xtensa: Fix broken allmodconfig build xtensa: remove CCOUNT_PER_JIFFY xtensa: fix !CONFIG_XTENSA_CALIBRATE_CCOUNT build failure xtensa: don't use echo -e needlessly xtensa: new fast_alloca handler xtensa: keep a3 and excsave1 on entry to exception handlers xtensa: enable kernel preemption xtensa: check thread flags atomically on return from user exception
2013-09-13Merge git://git.kvack.org/~bcrl/aio-nextLinus Torvalds
Pull aio changes from Ben LaHaise: "First off, sorry for this pull request being late in the merge window. Al had raised a couple of concerns about 2 items in the series below. I addressed the first issue (the race introduced by Gu's use of mm_populate()), but he has not provided any further details on how he wants to rework the anon_inode.c changes (which were sent out months ago but have yet to be commented on). The bulk of the changes have been sitting in the -next tree for a few months, with all the issues raised being addressed" * git://git.kvack.org/~bcrl/aio-next: (22 commits) aio: rcu_read_lock protection for new rcu_dereference calls aio: fix race in ring buffer page lookup introduced by page migration support aio: fix rcu sparse warnings introduced by ioctx table lookup patch aio: remove unnecessary debugging from aio_free_ring() aio: table lookup: verify ctx pointer staging/lustre: kiocb->ki_left is removed aio: fix error handling and rcu usage in "convert the ioctx list to table lookup v3" aio: be defensive to ensure request batching is non-zero instead of BUG_ON() aio: convert the ioctx list to table lookup v3 aio: double aio_max_nr in calculations aio: Kill ki_dtor aio: Kill ki_users aio: Kill unneeded kiocb members aio: Kill aio_rw_vect_retry() aio: Don't use ctx->tail unnecessarily aio: io_cancel() no longer returns the io_event aio: percpu ioctx refcount aio: percpu reqs_available aio: reqs_active -> reqs_available aio: fix build when migration is disabled ...
2013-09-13Merge branch 'genirq' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull generic hardirq option removal from Martin Schwidefsky: "All architectures now use generic hardirqs, s390 has been last to switch. With that the code under !CONFIG_GENERIC_HARDIRQS and the related HAVE_GENERIC_HARDIRQS and GENERIC_HARDIRQS config options can be removed. Yay!" * 'genirq' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: Remove GENERIC_HARDIRQ config option
2013-09-13Merge branch 'kconfig' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild Pull kconfig fix from Michal Marek: "This is a fix for a regression caused by my previous pull request. A sed command in scripts/config that used colons as separator was accidentally changed to use slashes, which fails when you use slashes in a value. Changing it back to colons is of course not a proper fix, but at least it will be broken in the same way it had been for four years. A proper fix is pending" * 'kconfig' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: scripts/config: fix variable substitution command
2013-09-13Merge tag 'blackfin-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/realmz6/blackfin-linux Pull blackfin updates from Steven Miao. * tag 'blackfin-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/realmz6/blackfin-linux: blackfin: Ignore generated uImages blackfin: Add STMMAC platform data to enable dwmac1000 driver on BF60x. bf609: adv7343: add S-Video and Component output support bf609: add adv7343 video encoder support clock: add stmmac clock for ethernet driver blackfin: scb: Add SCB1 to SCB9 config options and data. blackfin: scb: Add system crossbar init code.
2013-09-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto fixes from Herbert Xu: "This fixes a 7+ year race condition in the crypto API that causes sporadic crashes when multiple threads load the same algorithm. It also fixes the crct10dif algorithm again to prevent boot failures on systems where the initramfs tool ignores module softdeps" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: crct10dif - Add fallback for broken initrds crypto: api - Fix race condition in larval lookup
2013-09-13MIPS: kernel: vpe: Make vpe_attrs an array of pointers.Markos Chandras
Commit 567b21e973ccf5b0d13776e408d7c67099749eb8 "mips: convert vpe_class to use dev_groups" broke the build on MIPS since vpe_attrs should be an array of 'struct device_attribute' pointers. Fixes the following build problem: arch/mips/kernel/vpe.c:1372:2: error: missing braces around initializer [-Werror=missing-braces] arch/mips/kernel/vpe.c:1372:2: error: (near initialization for 'vpe_attrs[0]') [-Werror=missing-braces] Cc: Ralf Baechle <ralf@linux-mips.org> Cc: John Crispin <blogic@openwrt.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5819/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-13scripts/config: fix variable substitution commandClement Chauplannaz
Commit 229455bc02b87f7128f190c4491b4ceffff38648 accidentally changed the separator between sed `s' command and its parameters from ':' to '/'. Revert this change. Reported-and-tested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Clement Chauplannaz <chauplac@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-09-13MIPS: Fix SMP core calculations when using MT support.Leonid Yegoshin
The TCBIND register is only available if the core has MT support. It should not be read otherwise. Secondly, the number of TCs (siblings) are calculated differently depending on if the kernel is configured as SMVP or SMTC. Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com> Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5822/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-09-13MIPS: DECstation I/O ASIC DMA interrupt handling fixMaciej W. Rozycki
This change complements commit d0da7c002f7b2a93582187a9e3f73891a01d8ee4 and brings clear_ioasic_irq back, renaming it to clear_ioasic_dma_irq at the same time, to make I/O ASIC DMA interrupts functional. Unlike ordinary I/O ASIC interrupts DMA interrupts need to be deasserted by software by writing 0 to the respective bit in I/O ASIC's System Interrupt Register (SIR), similarly to how CP0.Cause.IP0 and CP0.Cause.IP1 bits are handled in the CPU (the difference is SIR DMA interrupt bits are R/W0C so there's no need for an RMW cycle). Otherwise the handler is reentered over and over again. The only current user is the DEC LANCE Ethernet driver and its extremely uncommon DMA memory error handler that does not care when exactly the interrupt is cleared. Anticipating the use of DMA interrupts by the Zilog SCC driver this change however exports clear_ioasic_dma_irq for device drivers to choose the right application-specific sequence to clear the request explicitly rather than calling it implicitly in the .irq_eoi handler of `struct irq_chip'. Previously these interrupts were cleared in the .end handler of the said structure, before it was removed. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5826/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-09-13MIPS: DECstation HRT initialization rearrangementMaciej W. Rozycki
Not all I/O ASIC versions have the free-running counter implemented, an early revision used in the 5000/1xx models aka 3MIN and 4MIN did not have it. Therefore we cannot unconditionally use it as a clock source. Fortunately if not implemented its register slot has a fixed value so it is enough if we check for the value at the end of the calibration period being the same as at the beginning. This also means we need to look for another high-precision clock source on the systems affected. The 5000/1xx can have an R4000SC processor installed where the CP0 Count register can be used as a clock source. Unfortunately all the R4k DECstations suffer from the missed timer interrupt on CP0 Count reads erratum, so we cannot use the CP0 timer as a clock source and a clock event both at a time. However we never need an R4k clock event device because all DECstations have a DS1287A RTC chip whose periodic interrupt can be used as a clock source. This gives us the following four configuration possibilities for I/O ASIC DECstations: 1. No I/O ASIC counter and no CP0 timer, e.g. R3k 5000/1xx (3MIN). 2. No I/O ASIC counter but the CP0 timer, i.e. R4k 5000/150 (4MIN). 3. The I/O ASIC counter but no CP0 timer, e.g. R3k 5000/240 (3MAX+). 4. The I/O ASIC counter and the CP0 timer, e.g. R4k 5000/260 (4MAX+). For #1 and #2 this change stops the I/O ASIC free-running counter from being installed as a clock source of a 0Hz frequency. For #2 it also arranges for the CP0 timer to be used as a clock source rather than a clock event device, because having an accurate wall clock is more important than a high-precision interval timer. For #3 there is no change. For #4 the change makes the I/O ASIC free-running counter installed as a clock source so that the CP0 timer can be used as a clock event device. Unfortunately the use of the CP0 timer as a clock event device relies on a succesful completion of c0_compare_interrupt. That never happens, because while waiting for a CP0 Compare interrupt to happen the function spins in a loop reading the CP0 Count register. This makes the CP0 Count erratum trigger reliably causing the interrupt waited for to be lost in all cases. As a result #4 resorts to using the CP0 timer as a clock source as well, just as #2. However we want to keep this separate arrangement in case (hope) c0_compare_interrupt is eventually rewritten such that it avoids the erratum. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5825/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
