This patch fixes resource reclaim in error path of acm_probe:
1. In the case of "out of memory (read urbs usb_alloc_urb)\n")", there
is no need to call acm_read_buffers_free(acm) here. Fix it by goto
alloc_fail6 instead of alloc_fail7.
2. In the case of "out of memory (write urbs usb_alloc_urb)",
usb_alloc_urb may fail in any iteration of the for loop. Current
implementation does not properly free allocated snd->urb. Fix it by
goto alloc_fail8 instead of alloc_fail7.
3. In the case of device_create_file(&intf->dev,&dev_attr_iCountryCodeRelDate)
fail, acm->country_codes is kfreed. As a result, device_remove_file
for dev_attr_wCountryCodes will not be executed in acm_disconnect.
Fix it by calling device_remove_file for dev_attr_wCountryCodes
before goto skip_countries.
Acked-by: Oliver Neukum <oneukum@suse.de>
Cc: stable <stable@kernel.org>
Call set_mctrl() and clear_mctrl() according to the flow control mode
selected. This makes serial communication for FT232 connected devices
work when CRTSCTS is not set.
This fixes a regression introduced by 4175f3e31 ("tty_port: If we are
opened non blocking we still need to raise the carrier"). This patch
calls the low-level driver's dtr_rts() function which consequently sets
TIOCM_DTR | TIOCM_RTS. A later call to set_termios() without CRTSCTS in
cflags, however, does not reset these bits, and so data is not actually
sent out on the serial wire.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Johan Hovold <jhovold@gmail.com>
Cc: Alan Cox <alan@linux.intel.com>
According to the design guide, if the FIFO layout is changed, then the
FIFOs must be flushed to ensure all FIFO pointers are correct.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
The shortest period SoftDisconnect can be asserted for is 3 milliseconds
according to the V210 datasheet, so ensure that we add an msleep() to
the registration code to enforce this.
Some versions of the S3C HS OtG block startup with overlapping TX FIFO
information, so change the fifo_init code to ensure that known values
are set into the FIFO registers at initialisation/reset time.
This also ensures that the FIFO RAM pointers are in a known state
before use.
The s3c_hsotg driver sets usb_gadget->is_dualspeed to 1, yet it doesn't define
USB_GADGET_DUALSPEED in Kconfig. This triggers a NULL pointer dereference in
the composite driver (which is fixed in another patch).
Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com>
Enable soft disconnect bit the OTG core during initialization. Without this,
the host sees that a gadget is connected and tries to enumerate. The
soft disconnect should be enabled until the USB gadget driver is
registered with this otg driver.
Signed-off-by: Thomas Abraham <thomas.ab@samsung.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
The NEC xHCI host controller firmware version can be found by putting a
vendor-specific command on the command ring and extracting the BCD
encoded-version out of the vendor-specific event TRB.
The firmware version debug line in dmesg will look like:
xhci_hcd 0000:05:00.0: NEC firmware version 30.21
(NEC merged with Renesas Technologies and became Renesas Electronics on
April 1, 2010. I have their OK to merge this vendor-specific code.)
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Satoshi Otani <satoshi.otani.xm@renesas.com>
When the run bit is set in the xHCI command register, it may take a few
microseconds for the host to start running. We cannot ring any doorbells
until the host is actually running, so wait until the status register says
the host is running.
Reported-by: Shinya Saito <shinya.saito.sx@renesas.com>
After software resets an xHCI host controller, it must wait for the
"Controller Not Ready" (CNR) bit in the status register to be cleared.
Software is not supposed to ring any doorbells or write to any registers
except the status register until this bit is cleared.
The Blackfin code is incorrectly casting the argument to inw() to a pointer.
Fix null-pointer dereference on error path.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
libata: implement on-demand HPA unlocking
libata: use the enlarged capacity after late HPA unlock
SCSI: implement sd_unlock_native_capacity()
libata-sff: trivial corrections to Kconfig help text
sata_nv: don't diddle with nIEN on mcp55
sata_via: magic vt6421 fix for transmission problems w/ WD drives
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
sched, trace: Fix sched_switch() prev_state argument
sched: Fix wake_affine() vs RT tasks
sched: Make sure timers have migrated before killing the migration_thread
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, smpboot: Fix cores per node printing on boot
x86/amd-iommu: Fall back to GART if initialization fails
x86/amd-iommu: Fix crash when request_mem_region fails
x86/mm: Remove unused DBG() macro
arch/x86/kernel: Add missing spin_unlock
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc/macio: Fix probing of macio devices by using the right of match table
agp/uninorth: Fix oops caused by flushing too much
powerpc/pasemi: Update MAINTAINERS file
powerpc/cell: Fix integer constant warning
powerpc/kprobes: Remove resume_execution() in kprobes
powerpc/macio: Don't dereference pointer before null check
git://xenbits.xensource.com/people/ianc/linux-2.6
* 'for-linus/bugfixes' of git://xenbits.xensource.com/people/ianc/linux-2.6:
xen: avoid allocation causing potential swap activity on the resume path
xen: ensure timer tick is resumed even on CPU driving the resume
* 'perf-fixes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
perf: Fix crash in swevents
perf buildid-list: Fix --with-hits event processing
perf scripts python: Give field dict to unhandled callback
perf hist: fix objdump output parsing
perf-record: Check correct pid when forking
perf: Do the comm inheritance per thread in event__process_task
perf: Use event__process_task from perf sched
perf: Process comm events by tid
blktrace: Fix new kernel-doc warnings
perf_events: Fix unincremented buffer base on partial copy
perf_events: Fix event scheduling issues introduced by transactional API
perf_events, trace: Fix perf_trace_destroy(), mutex went missing
perf_events, trace: Fix probe unregister race
perf_events: Fix races in group composition
perf_events: Fix races and clean up perf_event and perf_mmap_data interaction
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus
* 'virtio' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus:
virtio: console: Fix crash when port is unplugged and blocked for write
virtio: console: Fix crash when hot-unplugging a port and read is blocked
virtio-blk: fix minimum number of S/G elements
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c: Remove all i2c_set_clientdata(client, NULL) in drivers
i2c/busses: Move two drivers to embedded section
i2c: Rename i2c_check_addr to i2c_check_addr_busy
i2c: Document reserved I2C addresses
i2c: Check for address validity on client registration
i2c: Share the I2C device presence detection code
Documentation/i2c: Checkpatch cleanup
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: crypto4xx - Fix build breakage
n2_crypto: Plumb fallback ahash requests properly.
n2_crypto: Fix MAU kmem_cache name.
n2_crypto: Fix build after of_device/of_platform_driver changes.
Frederic reported that because swevents handling doesn't disable IRQs
anymore, we can get a recursion of perf_adjust_period(), once from
overflow handling and once from the tick.
If both call ->disable, we get a double hlist_del_rcu() and trigger
a LIST_POISON2 dereference.
Since we don't actually need to stop/start a swevent to re-programm
the hardware (lack of hardware to program), simply nop out these
callbacks for the swevent pmu.
Reported-by: Frederic Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1275557609.27810.35218.camel@twins>
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
cifs: fix page refcount leak
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (41 commits)
drm/radeon/kms: make sure display hw is disabled when suspending
drm/vmwgfx: Allow userspace to change default layout. Bump minor.
drm/vmwgfx: Fix framebuffer modesetting
drm/vmwgfx: Fix vga save / restore with display topology.
vgaarb: use MIT license
vgaarb: convert pr_devel() to pr_debug()
drm: fix typos in Linux DRM Developer's Guide
drm/radeon/kms/pm: voltage fixes
drm/radeon/kms/pm: radeon_set_power_state fixes
drm/radeon/kms/pm: patch default power state with default clocks/voltages on r6xx+
drm/radeon/kms/pm: enable SetVoltage on r7xx/evergreen
drm/radeon/kms/pm: add support for SetVoltage cmd table (V2)
drm/radeon/kms/evergreen: add initial CS parser
drm/kms: disable/enable poll around switcheroo on/off
drm/nouveau: fixup confusion over which handle the DSM is hanging off.
drm/nouveau: attempt to get bios from ACPI v3
drm/nv50: cast IGP memory location to u64 before shifting
drm/ttm: Fix ttm_page_alloc.c
drm/ttm: Fix cached TTM page allocation.
drm/vmwgfx: Remove some leftover debug messages.
* 'merge' of git://git.secretlab.ca/git/linux-2.6:
of/powerpc: fix fsl_msi device node pointer
of/watchdog: gef_wdt.c: fix build breakage
of/edac: fix build breakage in drivers
of/net: fs_enet/mii-bitbang.c: fix build breakage
of/usb: fsl_qe_udc.c: fix build breakage
of/crypto: crypto4xx_core.c: fix build breakage
of/dma: fix build breakage in ppc4xx adma driver
of/mtd: nand: fix build breakage in drivers
of/video: fix build breakage in FB drivers
of/pcmcia: m8xx_pcmcia.c: Fix build failures
of/rtc: rtc-mpc5121.c: Fix build failures
of/dma: mpc512x_dma.c: Fix build failures
of/mtd/nand: mpc5121_nfc.c: Fix build failures
of/spi: mpc512x_psc_spi.c: Fix build failures
watchdog: Fix build failure with OF changes
of/spi: Fix build failure on spi_ppc4xx.c
of/usb: fix build error due to of_node pointer move
of/powerpc: fix 85xx RapidIO device node pointer
When a program that has a virtio port opened and blocked for a write
operation, a port hot-unplug event will later led to a crash when
SIGTERM was sent to the program. Fix that.
Signed-off-by: Amit Shah <amit.shah@redhat.com>
When removing a port we don't check if a program was blocked for read.
This leads to a crash when SIGTERM is sent to the program after
hot-unplugging the port.
We need at least one S/G element to operate properly, as does the block
layer which increments it to one anyway. We hit this due to a qemu
bug which advertises a sg_elements of 0 under some circumstances.
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (tweaked logic)
I2C drivers can use the clientdata-pointer to point to private data. As I2C
devices are not really unregistered, but merely detached from their driver, it
used to be the drivers obligation to clear this pointer during remove() or a
failed probe(). As a couple of drivers forgot to do this, it was agreed that it
was cleaner if the i2c-core does this clearance when appropriate, as there is
no guarantee for the lifetime of the clientdata-pointer after remove() anyhow.
This feature was added to the core with commit
e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers.
As there is no need anymore to clear the clientdata-pointer, remove all current
occurrences in the drivers to simplify the code and prevent confusion.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
And fix a typo while we are here
Otherwise it's not clear what it is checking.
Also move the function to save a forward declaration.
Move strict I2C address validity check to a single function, and
document the reserved I2C addresses there.
Cc: Hans Verkuil <hverkuil@xs4all.nl>
Do basic address validity checks when a client is being registered. We
already had checks in place for devices which are being detected, but
not for devices which are simply instantiated.
This is a very basic check. We don't want to do strict checking here
because some devices are known to infringe the I2C address constraints
(e.g. IR receivers at 7-bit address 0x7a while this value is
supposedly reserved for 10-bit addresses.) So we assume the caller
knows what it is doing.
Cc: Matthieu Castet <castet.matthieu@free.fr>
Use the same I2C device presence detection code for legacy and new
device detection functions. This is more consistent and makes the code
smaller.
Remove all trailing whitespace in Documentation/i2c.
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net>
Since the device we are resuming could be the device containing the
swap device we should ensure that the allocation cannot cause
IO.
On resume, this path is triggered when the running system tries to
continue using its devices. If it cannot then the resume will fail;
to try to avoid this we let it dip into the emergency pools.
The majority of these changes were made when linux-2.6.18-xen.hg
changeset e8b49cfbdac0 was ported upstream in
a144ff09bc52ef3f3684ed23eadc9c7c0e57b3aa but somehow this hunk was
dropped.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Acked-by: Jeremy Fitzhardinge <jeremy@goop.org>
Cc: Stable Kernel <stable@kernel.org> # .32.x
The core suspend/resume code is run from stop_machine on CPU0 but
parts of the suspend/resume machinery (including xen_arch_resume) are
run on whichever CPU happened to schedule the xenwatch kernel thread.
As part of the non-core resume code xen_arch_resume is called in order
to restart the timer tick on non-boot processors. The boot processor
itself is taken care of by core timekeeping code.
xen_arch_resume uses smp_call_function which does not call the given
function on the current processor. This means that we can end up with
one CPU not receiving timer ticks if the xenwatch thread happened to
be scheduled on CPU > 0.
Use on_each_cpu instead of smp_call_function to ensure the timer tick
is resumed everywhere.
Fixes build error caused by the OF device_node
pointer being moved into struct device
Disable the display hw when suspending.
Should fix bug:
https://bugzilla.redhat.com/show_bug.cgi?id=522393
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
The host may change the layout and, since the change is
communicated to the master, the master needs a way to
communicate the change to the kernel driver.
The minor version number is bumped to advertize the
availability of this feature.
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com>
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Must set SVGA_NUM_REG_GUEST_DISPLAY before setting up the display information.
vga save / restore previously didn't handle the display topology case.
Signed-off-by: Tiago Vignatti <tiago.vignatti@nokia.com>
Cc: Henry Zhao <Henry.Zhao@Sun.COM>
We want to be able to use CONFIG_DYNAMIC_DEBUG in arbiter code, switch
the few existing pr_devel() calls to pr_debug().
Also, add one more debug information regarding decoding count.
A few typos in the DRM Developer's Guide.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Acked-by: Jesse Barnes <jesse.barnes@intel.com>
- Enable GPIO voltage for non pm modes as well so resetting
the default voltage works.
- wait for vbl for both profile and dynpm
- unify profile and dynpm code paths more
- call pm_misc before of after clocks to make
sure voltage is changed in the proper order.
r6xx+
The default power state does not always match the default clocks and voltage
for a particular card. The information in the firmware info table is correct
and should be used in preference to the info the default power state.
I missed these in the r6xx commit.
