2010-05-06sched: replace migration_thread with cpu_stopTejun Heo
Currently migration_thread is serving three purposes - migration pusher, context to execute active_load_balance() and forced context switcher for expedited RCU synchronize_sched. All three roles are hardcoded into migration_thread() and determining which job is scheduled is slightly messy. This patch kills migration_thread and replaces all three uses with cpu_stop. The three different roles of migration_thread() are splitted into three separate cpu_stop callbacks - migration_cpu_stop(), active_load_balance_cpu_stop() and synchronize_sched_expedited_cpu_stop() - and each use case now simply asks cpu_stop to execute the callback as necessary. synchronize_sched_expedited() was implemented with private preallocated resources and custom multi-cpu queueing and waiting logic, both of which are provided by cpu_stop. synchronize_sched_expedited_count is made atomic and all other shared resources along with the mutex are dropped. synchronize_sched_expedited() also implemented a check to detect cases where not all the callback got executed on their assigned cpus and fall back to synchronize_sched(). If called with cpu hotplug blocked, cpu_stop already guarantees that and the condition cannot happen; otherwise, stop_machine() would break. However, this patch preserves the paranoid check using a cpumask to record on which cpus the stopper ran so that it can serve as a bisection point if something actually goes wrong theree. Because the internal execution state is no longer visible, rcu_expedited_torture_stats() is removed. This patch also renames cpu_stop threads to from "stopper/%d" to "migration/%d". The names of these threads ultimately don't matter and there's no reason to make unnecessary userland visible changes. With this patch applied, stop_machine() and sched now share the same resources. stop_machine() is faster without wasting any resources and sched migration users are much cleaner. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Josh Triplett <josh@freedesktop.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com>
2010-05-06stop_machine: reimplement using cpu_stopTejun Heo
Reimplement stop_machine using cpu_stop. As cpu stoppers are guaranteed to be available for all online cpus, stop_machine_create/destroy() are no longer necessary and removed. With resource management and synchronization handled by cpu_stop, the new implementation is much simpler. Asking the cpu_stop to execute the stop_cpu() state machine on all online cpus with cpu hotplug disabled is enough. stop_machine itself doesn't need to manage any global resources anymore, so all per-instance information is rolled into struct stop_machine_data and the mutex and all static data variables are removed. The previous implementation created and destroyed RT workqueues as necessary which made stop_machine() calls highly expensive on very large machines. According to Dimitri Sivanich, preventing the dynamic creation/destruction makes booting faster more than twice on very large machines. cpu_stop resources are preallocated for all online cpus and should have the same effect. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com>
2010-05-06cpu_stop: implement stop_cpu[s]()Tejun Heo
Implement a simplistic per-cpu maximum priority cpu monopolization mechanism. A non-sleeping callback can be scheduled to run on one or multiple cpus with maximum priority monopolozing those cpus. This is primarily to replace and unify RT workqueue usage in stop_machine and scheduler migration_thread which currently is serving multiple purposes. Four functions are provided - stop_one_cpu(), stop_one_cpu_nowait(), stop_cpus() and try_stop_cpus(). This is to allow clean sharing of resources among stop_cpu and all the migration thread users. One stopper thread per cpu is created which is currently named "stopper/CPU". This will eventually replace the migration thread and take on its name. * This facility was originally named cpuhog and lived in separate files but Peter Zijlstra nacked the name and thus got renamed to cpu_stop and moved into stop_machine.c. * Better reporting of preemption leak as per Peter's suggestion. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com>
2010-04-23sched: Fix select_idle_sibling() logic in select_task_rq_fair()Suresh Siddha
Issues in the current select_idle_sibling() logic in select_task_rq_fair() in the context of a task wake-up: a) Once we select the idle sibling, we use that domain (spanning the cpu that the task is currently woken-up and the idle sibling that we found) in our wake_affine() decisions. This domain is completely different from the domain(we are supposed to use) that spans the cpu that the task currently woken-up and the cpu where the task previously ran. b) We do select_idle_sibling() check only for the cpu that the task is currently woken-up on. If select_task_rq_fair() selects the previously run cpu for waking the task, doing a select_idle_sibling() check for that cpu also helps and we don't do this currently. c) In the scenarios where the cpu that the task is woken-up is busy but with its HT siblings are idle, we are selecting the task be woken-up on the idle HT sibling instead of a core that it previously ran and currently completely idle. i.e., we are not taking decisions based on wake_affine() but directly selecting an idle sibling that can cause an imbalance at the SMT/MC level which will be later corrected by the periodic load balancer. Fix this by first going through the load imbalance calculations using wake_affine() and once we make a decision of woken-up cpu vs previously-ran cpu, then choose a possible idle sibling for waking up the task on. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1270079265.7835.8.camel@sbs-t61.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-23sched: Pre-compute cpumask_weight(sched_domain_span(sd))Peter Zijlstra
Dave reported that his large SPARC machines spend lots of time in hweight64(), try and optimize some of those needless cpumask_weight() invocations (esp. with the large offstack cpumasks these are very expensive indeed). Reported-by: David Miller <davem@davemloft.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-23sched: Cure load average vs NO_HZ woesPeter Zijlstra
Chase reported that due to us decrementing calc_load_task prematurely (before the next LOAD_FREQ sample), the load average could be scewed by as much as the number of CPUs in the machine. This patch, based on Chase's patch, cures the problem by keeping the delta of the CPU going into NO_HZ idle separately and folding that in on the next LOAD_FREQ update. This restores the balance and we get strict LOAD_FREQ period samples. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chase Douglas <chase.douglas@canonical.com> LKML-Reference: <1271934490.1776.343.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-15sched: Fix UP update_avg() build warningMike Galbraith
update_avg() is only used for SMP builds, move it to the nearest SMP block. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1271309399.14779.17.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-15Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: merge the latest fixes, update to -rc4. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-13Merge branch 'pm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM / Hibernate: user.c, fix SNAPSHOT_SET_SWAP_AREA handling
2010-04-13Merge branch 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'bugfixes' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: NFSv4: fix delegated locking NFS: Ensure that the WRITE and COMMIT RPC calls are always uninterruptible NFS: Fix a race with the new commit code NFS: Ensure that writeback_single_inode() calls write_inode() when syncing NFS: Fix the mode calculation in nfs_find_open_context NFSv4: Fall back to ordinary lookup if nfs4_atomic_open() returns EISDIR
2010-04-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc64: Add some more commentary to __raw_local_irq_save() sparc64: Fix memory leak in pci_register_iommu_region(). sparc64: Add kmemleak annotation to sun4v_build_virq() sparc64: Support kmemleak. sparc64: Add function graph tracer support. sparc64: Give a stack frame to the ftrace call sites. sparc64: Use a seperate counter for timer interrupts and NMI checks, like x86. sparc64: Remove profiling from some low-level bits. sparc64: Kill unnecessary static on local var in ftrace_call_replace(). sparc64: Kill CONFIG_STACK_DEBUG code. sparc64: Add HAVE_FUNCTION_TRACE_MCOUNT_TEST and tidy up. sparc64: Adjust __raw_local_irq_save() to cooperate in NMIs. sparc64: Use kstack_valid() in die_if_kernel().
2010-04-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (25 commits) smc91c92_cs: define multicast_table as unsigned char can: avoids a false warning e1000e: stop cleaning when we reach tx_ring->next_to_use igb: restrict WoL for 82576 ET2 Quad Port Server Adapter virtio_net: missing sg_init_table Revert "tcp: Set CHECKSUM_UNNECESSARY in tcp_init_nondata_skb" iwlwifi: need check for valid qos packet before free tcp: Set CHECKSUM_UNNECESSARY in tcp_init_nondata_skb udp: fix for unicast RX path optimization myri10ge: fix rx_pause in myri10ge_set_pauseparam net: corrected documentation for hardware time stamping stmmac: use resource_size() x.25 attempts to negotiate invalid throughput x25: Patch to fix bug 15678 - x25 accesses fields beyond end of packet. bridge: Fix IGMP3 report parsing cnic: Fix crash during bnx2x MTU change. qlcnic: fix set mac addr r6040: fix r6040_multicast_list vhost-net: fix vq_memory_access_ok error checking ath9k: fix double calls to ath_radio_enable ...
2010-04-13smc91c92_cs: define multicast_table as unsigned charKen Kawasaki
smc91c92_cs: * define multicast_table as unsigned char * remove unnecessary "#ifndef final_version" Signed-off-by: Ken Kawasaki <ken_kawasaki@spring.nifty.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13can: avoids a false warningEric Dumazet
At this point optlen == sizeof(sfilter) but some compilers are dumb. Reported-by: Németh Márton <nm127@freemail.h Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Oliver Hartkopp <oliver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13e1000e: stop cleaning when we reach tx_ring->next_to_useTerry Loftin
Tx ring buffers after tx_ring->next_to_use are volatile and could change, possibly causing a crash. Stop cleaning when we hit tx_ring->next_to_use. Signed-off-by: Terry Loftin <terry.loftin@hp.com> Acked-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13igb: restrict WoL for 82576 ET2 Quad Port Server AdapterStefan Assmann
Restrict Wake-on-LAN to first port on 82576 ET2 quad port NICs, as it is only supported there. Signed-off-by: Stefan Assmann <sassmann@redhat.com> Acked-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13sparc64: Add some more commentary to __raw_local_irq_save()David S. Miller
Suggested by Peter Zijlstra Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-13Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: lib/Kconfig.debug
2010-04-12sparc64: Fix memory leak in pci_register_iommu_region().David S. Miller
Found by kmemleak. If request_resource() fails, we leak the struct resource we allocated to represent the IOMMU mapping area. This actually happens on sun4v machines because the IOMEM area is only reported sans the IOMMU region, unlike all previous systems. I'll need to fix that at some point, but for now fix the leak. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Add kmemleak annotation to sun4v_build_virq()David S. Miller
The only reference we store to this memory is in the form of a physical address, so kmemleak can't see it. Add a kmemleak_not_leak() annotation. It's probably useful to be able to look at a dump of these things either via debugfs or similar, and thus we could at some point store them in some kind of table and therefore get rid of this annotation. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Support kmemleak.David S. Miller
Only missing thing was an _sdata marker in vmlinux.lds.S Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Add function graph tracer support.David S. Miller
2010-04-12sparc64: Give a stack frame to the ftrace call sites.David S. Miller
It's the only way we'll be able to implement the function graph tracer properly. A positive is that we no longer have to worry about the linker over-optimizing the tail call, since we don't use a tail call any more. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Use a seperate counter for timer interrupts and NMI checks, like x86.David S. Miller
This keeps us from having to use kstat_irqs_cpu() from the NMI handler, the former of which is a profiled function. Instead we use a currently empty slot in the cpu_data Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Remove profiling from some low-level bits.David S. Miller
These include the timer implementation, perf events support, and the performance counter register (pcr) programming layer. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Kill unnecessary static on local var in ftrace_call_replace().David S. Miller
2010-04-12sparc64: Kill CONFIG_STACK_DEBUG code.David S. Miller
The generic stack tracer does this job just as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Add HAVE_FUNCTION_TRACE_MCOUNT_TEST and tidy up.David S. Miller
Check function_trace_stop at ftrace_caller Toss mcount_call and dummy call of ftrace_stub, unnecessary. Document problems we'll have if the final kernel image link ever turns on relaxation. Properly size 'ftrace_call' so it looks right when inspecting instructions under gdb et al. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Adjust __raw_local_irq_save() to cooperate in NMIs.David S. Miller
If we are in an NMI then doing a plain raw_local_irq_disable() will write PIL_NORMAL_MAX into %pil, which is lower than PIL_NMI, and thus we'll re-enable NMIs and recurse. Doing a simple: %pil = %pil | PIL_NORMAL_MAX does what we want, if we're already at PIL_NMI (15) we leave it at that setting, else we set it to PIL_NORMAL_MAX (14). This should get the function tracer working on sparc64. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12sparc64: Use kstack_valid() in die_if_kernel().David S. Miller
This gets rid of a local function (is_kernel_stack()) which tries to do the same thing, yet poorly in that it doesn't handle IRQ stacks properly. Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12virtio_net: missing sg_init_tableShirley Ma
Add missing sg_init_table for sg_set_buf in virtio_net which induced in defer skb patch. Reported-by: Thomas Müller <thomas@mathtm.de> Tested-by: Thomas Müller <thomas@mathtm.de> Signed-off-by: Shirley Ma <xma@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-12Linux 2.6.34-rc4v2.6.34-rc4Linus Torvalds
2010-04-12Merge branch 'anonvma'Linus Torvalds
* anonvma: anonvma: when setting up page->mapping, we need to pick the _oldest_ anonvma anon_vma: clone the anon_vma chain in the right order vma_adjust: fix the copying of anon_vma chains Simplify and comment on anon_vma re-use for anon_vma_prepare()
2010-04-12Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (21 commits) ARM: Fix ioremap_cached()/ioremap_wc() for SMP platforms ARM: 6043/1: AT91 slow-clock resume: Don't wait for a disabled PLL to lock ARM: 6031/1: fix Thumb-2 decompressor ARM: 6029/1: ep93xx: gpio.c: local functions should be static ARM: 6028/1: ARM: add MAINTAINERS for U300 ARM: 6024/1: bcmring: fix missing down on semaphore in dma.c MXC: mach_armadillo5x0: Add USB Host support. ARM mach-mx3: duplicated include ARM mach-mx3: duplicated include imx31: add watchdog device on litekit board. imx3: Add watchdog platform device support MXC: mach-mx31_3ds: add support for freescale mc13783 power management device. MXC: mach-mx31_3ds: Add SPI1 device support. MXC: mach-mx31_3ds: Add support for on board NAND Flash. MXC: mach-mx31_3ds: Update variable names over recent mach name modification. imx31: fix parent clock for rtc i.MX51: remove NFC AXI static mapping i.MX51: determine silicon revision dynamically i.MX51: map TZIC dynamically i.MX51: Use correct clock for gpt ...
2010-04-12Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: make sure the chunk allocator doesn't create zero length chunks Btrfs: fix data enospc check overflow
2010-04-12Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Fix possible dq_flags corruption quota: Hide warnings about writes to the filesystem before quota was turned on ext3: symlink must be handled via filesystem specific operation ext2: symlink must be handled via filesystem specific operation
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-udf-2.6: udf: add speciffic ->setattr callback udf: potential integer overflow
2010-04-12Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (36 commits) MIPS: Calculate proper ebase value for 64-bit kernels MIPS: Alchemy: DB1200: Remove custom wait implementation MIPS: Big Sur: Make defconfig more useful. MIPS: Fix __vmalloc() etc. on MIPS for non-GPL modules MIPS: Sibyte: Fix M3 TLB exception handler workaround. MIPS: BCM63xx: Fix build failure in board_bcm963xx.c MIPS: uasm: Add OR instruction. MIPS: Sibyte: Apply M3 workaround only on affected chip types and versions. MIPS: BCM63xx: Initialize gpio_out_low & out_high to current value at boot. MIPS: BCM63xx: Register SSB SPROM fallback in board's first stage callback MIPS: BCM63xx: Fix typo in cpu-feature-overrides file. MIPS: BCM63xx: Add support for second uart. MIPS: BCM63xx: Fix double gpio registration. MIPS: BCM63xx: Add DWVS0 board MIPS: BCM63xx: Add the RTA1025W-16 BCM6348-based board to suppported boards. MIPS: BCM63xx: Fix BCM6338 and BCM6345 gpio count MIPS: libgcc.h: Checkpatch cleanup MIPS: Loongson-2F: Flush the branch target history in BTB and RAS MIPS: Move signal trampolines off of the stack. MIPS: Preliminary VDSO ...
2010-04-12Merge branch 'for-2.6.34' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.34' of git://linux-nfs.org/~bfields/linux: svcrdma: RDMA support not yet compatible with RPC6
2010-04-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ryusuke/nilfs2: nilfs2: fix typo "numer" -> "number" in alloc.c nilfs2: Remove an uninitialization warning in nilfs_btree_propagate_v() nilfs2: fix a wrong type conversion in nilfs_ioctl()
2010-04-12anonvma: when setting up page->mapping, we need to pick the _oldest_ anonvmaLinus Torvalds
Otherwise we might be mapping in a page in a new mapping, but that page (through the swapcache) would later be mapped into an old mapping too. The page->mapping must be the case that works for everybody, not just the mapping that happened to page it in first. Here's the scenario: - page gets allocated/mapped by process A. Let's call the anon_vma we associate the page with 'A' to keep it easy to track. - Process A forks, creating process B. The anon_vma in B is 'B', and has a chain that looks like 'B' -> 'A'. Everything is fine. - Swapping happens. The page (with mapping pointing to 'A') gets swapped out (perhaps not to disk - it's enough to assume that it's just not mapped any more, and lives entirely in the swap-cache) - Process B pages it in, which goes like this: do_swap_page -> page = lookup_swap_cache(entry); ... set_pte_at(mm, address, page_table, pte); page_add_anon_rmap(page, vma, address); And think about what happens here! In particular, what happens is that this will now be the "first" mapping of that page, so page_add_anon_rmap() used to do if (first) __page_set_anon_rmap(page, vma, address); and notice what anon_vma it will use? It will use the anon_vma for process B! What happens then? Trivial: process 'A' also pages it in (nothing happens, it's not the first mapping), and then process 'B' execve's or exits or unmaps, making anon_vma B go away. End result: process A has a page that points to anon_vma B, but anon_vma B does not exist any more. This can go on forever. Forget about RCU grace periods, forget about locking, forget anything like that. The bug is simply that page->mapping points to an anon_vma that was correct at one point, but was _not_ the one that was shared by all users of that possible mapping. Changing it to always use the deepest anon_vma in the anonvma chain gets us to the safest model. This can be improved in certain cases: if we know the page is private to just this particular mapping (for example, it's a new page, or it is the only swapcache entry), we could pick the top (most specific) anon_vma. But that's a future optimization. Make it _work_ reliably first. Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Tested-by: Borislav Petkov <bp@alien8.de> [ "What do you know, I think you fixed it!" ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-12anon_vma: clone the anon_vma chain in the right orderLinus Torvalds
We want to walk the chain in reverse order when cloning it, so that the order of the result chain will be the same as the order in the source chain. When we add entries to the chain, they go at the head of the chain, so we want to add the source head last. Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Tested-by: Borislav Petkov <bp@alien8.de> [ "No, it still oopses" ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-12vma_adjust: fix the copying of anon_vma chainsLinus Torvalds
When we move the boundaries between two vma's due to things like mprotect, we need to make sure that the anon_vma of the pages that got moved from one vma to another gets properly copied around. And that was not always the case, in this rather hard-to-follow code sequence. Clarify the code, and fix it so that it copies the anon_vma from the right source. Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Tested-by: Borislav Petkov <bp@alien8.de> [ "Yeah, not so much this one either" ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-12Simplify and comment on anon_vma re-use for anon_vma_prepare()Linus Torvalds
This changes the anon_vma reuse case to require that we only reuse simple anon_vma's - ie the case when the vma only has a single anon_vma associated with it. This means that a reuse of an anon_vma from an adjacent vma will always guarantee that both vma's are associated not only with the same anon_vma, they will also have the same anon_vma chain (of just a single entry in this case). And since anon_vma re-use was the only case where the same anon_vma might be associated with different chains of anon_vma's, we now have the case that every vma that shares the same anon_vma will always also have the same chain. That makes it much easier to think about merging vma's that share the same anon_vma's: you can always just drop the other anon_vma chain in anon_vma_merge() since you know that they are always identical. This also splits up the function to validate the anon_vma re-use, and adds a lot of commentary about the possible races. Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Tested-by: Borislav Petkov <bp@alien8.de> [ "That didn't fix it" ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-12quota: Fix possible dq_flags corruptionAndrew Perepechko
dq_flags are modified non-atomically in do_set_dqblk via __set_bit calls and atomically for example in mark_dquot_dirty or clear_dquot_dirty. Hence a change done by an atomic operation can be overwritten by a change done by a non-atomic one. Fix the problem by using atomic bitops even in do_set_dqblk. Signed-off-by: Andrew Perepechko <andrew.perepechko@sun.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-04-12quota: Hide warnings about writes to the filesystem before quota was turned onJan Kara
For a root filesystem write to the filesystem before quota is turned on happens regularly and there's no way around it because of writes to syslog, /etc/mtab, and similar. So the warning is rather pointless for ordinary users. It's still useful during development so we just hide the warning behind __DQUOT_PARANOIA config option. Signed-off-by: Jan Kara <jack@suse.cz>
2010-04-12ext3: symlink must be handled via filesystem specific operationDmitry Monakhov
generic setattr implementation is no longer responsible for quota transfer so synlinks must be handled via ext3_setattr. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-04-12ext2: symlink must be handled via filesystem specific operationDmitry Monakhov
generic setattr implementation is no longer responsible for quota transfer so synlinks must be handled via ext2_setattr. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-04-12MIPS: Calculate proper ebase value for 64-bit kernelsDavid Daney
The ebase is relative to CKSEG0 not CAC_BASE. On a 32-bit kernel they are the same thing, for a 64-bit kernel they are not. It happens to kind of work on a 64-bit kernel as they both reference the same physical memory. However since the CPU uses the CKSEG0 base, determining if a J instruction will reach always gives the wrong result unless we use the same number the CPU uses. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1093/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-12MIPS: Alchemy: DB1200: Remove custom wait implementationManuel Lauss
While playing with the out-of-tree MAE driver module, the system would panic after a while in the db1200 custom wait code after wakeup due to a clobbered k0 register being used as target address of a store op. Remove the custom wait implementation and revert back to the Alchemy- recommended implementation already set as default. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1092/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
