2012-12-01workqueue: mod_delayed_work_on() shouldn't queue timer on 0 delayTejun Heo
8376fe22c7 ("workqueue: implement mod_delayed_work[_on]()") implemented mod_delayed_work[_on]() using the improved try_to_grab_pending(). The function is later used, among others, to replace [__]candel_delayed_work() + queue_delayed_work() combinations. Unfortunately, a delayed_work item w/ zero @delay is handled slightly differently by mod_delayed_work_on() compared to queue_delayed_work_on(). The latter skips timer altogether and directly queues it using queue_work_on() while the former schedules timer which will expire on the closest tick. This means, when @delay is zero, that [__]cancel_delayed_work() + queue_delayed_work_on() makes the target item immediately executable while mod_delayed_work_on() may induce delay of upto a full tick. This somewhat subtle difference breaks some of the converted users. e.g. block queue plugging uses delayed_work for deferred processing and uses mod_delayed_work_on() when the queue needs to be immediately unplugged. The above problem manifested as noticeably higher number of context switches under certain circumstances. The difference in behavior was caused by missing special case handling for 0 delay in mod_delayed_work_on() compared to queue_delayed_work_on(). Joonsoo Kim posted a patch to add it - ("workqueue: optimize mod_delayed_work_on() when @delay == 0")[1]. The patch was queued for 3.8 but it was described as optimization and I missed that it was a correctness issue. As both queue_delayed_work_on() and mod_delayed_work_on() use __queue_delayed_work() for queueing, it seems that the better approach is to move the 0 delay special handling to the function instead of duplicating it in mod_delayed_work_on(). Fix the problem by moving 0 delay special case handling from queue_delayed_work_on() to __queue_delayed_work(). This replaces Joonsoo's patch. [1] http://thread.gmane.org/gmane.linux.kernel/1379011/focus=1379012 Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-tested-by: Anders Kaseorg <andersk@MIT.EDU> Reported-and-tested-by: Zlatko Calusic <zlatko.calusic@iskon.hr> LKML-Reference: <alpine.DEB.2.00.1211280953350.26602@dr-wily.mit.edu> LKML-Reference: <50A78AA9.5040904@iskon.hr> Cc: Joonsoo Kim <js1304@gmail.com>
2012-12-01workqueue: exit rescuer_thread() as TASK_RUNNINGMike Galbraith
A rescue thread exiting TASK_INTERRUPTIBLE can lead to a task scheduling off, never to be seen again. In the case where this occurred, an exiting thread hit reiserfs homebrew conditional resched while holding a mutex, bringing the box to its knees. PID: 18105 TASK: ffff8807fd412180 CPU: 5 COMMAND: "kdmflush" #0 [ffff8808157e7670] schedule at ffffffff8143f489 #1 [ffff8808157e77b8] reiserfs_get_block at ffffffffa038ab2d [reiserfs] #2 [ffff8808157e79a8] __block_write_begin at ffffffff8117fb14 #3 [ffff8808157e7a98] reiserfs_write_begin at ffffffffa0388695 [reiserfs] #4 [ffff8808157e7ad8] generic_perform_write at ffffffff810ee9e2 #5 [ffff8808157e7b58] generic_file_buffered_write at ffffffff810eeb41 #6 [ffff8808157e7ba8] __generic_file_aio_write at ffffffff810f1a3a #7 [ffff8808157e7c58] generic_file_aio_write at ffffffff810f1c88 #8 [ffff8808157e7cc8] do_sync_write at ffffffff8114f850 #9 [ffff8808157e7dd8] do_acct_process at ffffffff810a268f [exception RIP: kernel_thread_helper] RIP: ffffffff8144a5c0 RSP: ffff8808157e7f58 RFLAGS: 00000202 RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000 RDX: 0000000000000000 RSI: ffffffff8107af60 RDI: ffff8803ee491d18 RBP: 0000000000000000 R8: 0000000000000000 R9: 0000000000000000 R10: 0000000000000000 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018 Signed-off-by: Mike Galbraith <mgalbraith@suse.de> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
2012-12-01Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU fix from Ingo Molnar: "Fix leaking RCU extended quiescent state, which might trigger warnings and mess up the extended quiescent state tracking logic into thinking that we are in "RCU user mode" while we aren't." * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: rcu: Fix unrecovered RCU user mode in syscall_trace_leave()
2012-12-01Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "This is mostly about unbreaking architectures that took the UAPI changes in the v3.7 cycle, plus misc fixes." * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf kvm: Fix building perf kvm on non x86 arches perf kvm: Rename perf_kvm to perf_kvm_stat perf: Make perf build for x86 with UAPI disintegration applied perf powerpc: Use uapi/unistd.h to fix build error tools: Pass the target in descend tools: Honour the O= flag when tool build called from a higher Makefile tools: Define a Makefile function to do subdir processing x86: Export asm/{svm.h,vmx.h,perf_regs.h} perf tools: Fix strbuf_addf() when the buffer needs to grow perf header: Fix numa topology printing perf, powerpc: Fix hw breakpoints returning -ENOSPC
2012-12-01Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/urgent fixes from Arnaldo Carvalho de Melo: - Don't build 'perf kvm stat" on non-x86 arches, fix from Xiao Guangrong. - UAPI fixes to get perf building again in non-x86 arches, from David Howells. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-11-30Merge branch 'x86/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin. This includes the resume-time FPU corruption fix from the chromeos guys, marked for stable. * 'x86/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, fpu: Avoid FPU lazy restore after suspend x86-32: Unbreak booting on some 486 clones x86, kvm: Remove incorrect redundant assembly constraint
2012-11-30Merge tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreamingLinus Torvalds
Pull C6X fixes from Mark Salter. * tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming: c6x: use generic kvm_para.h c6x: remove internal kernel symbols from exported setup.h c6x: fix misleading comment c6x: run do_notify_resume with interrupts enabled
2012-11-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull assorted signal-related fixes from Al Viro: "uml regression fix (braino in sys_execve() patch) + a bunch of fucked sigaltstack-on-rt_sigreturn uses, similar to sparc64 fix that went in through davem's tree. m32r horrors not included - that one's waiting for maintainer." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: microblaze: rt_sigreturn is too trigger-happy about sigaltstack errors score: do_sigaltstack() expects a userland pointer... sh64: fix altstack switching on sigreturn openrisk: fix altstack switching on sigreturn um: get_safe_registers() should be done in flush_thread(), not start_thread()
2012-11-30Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Two low risk, small fixes, that fix cifs regressions introduced in 3.7." * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: CIFS: Fix wrong buffer pointer usage in smb_set_file_info cifs: fix writeback race with file that is growing
2012-11-30Merge tag 'rproc-3.7-fix' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc Pull remoteproc fix from Ohad Ben-Cohen: "A single remoteproc fix for an error path issue reported by Ido Yariv." * tag 'rproc-3.7-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc: remoteproc: fix error path of ->find_vqs
2012-11-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull target fix from Nicholas Bellinger: "So just a single target fix for v3.7.0 this time around from Roland to address a aborted command bug w/ tcm_qla2xxx fabric ports. Also, there is one outstanding IBLOCK + virtio-blk bug that is still being tracked down effecting v3.6.x, but AFAICT thus far this appears to be a bug outside of target code." * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: target: Fix handling of aborted commands
2012-11-30x86, fpu: Avoid FPU lazy restore after suspendVincent Palatin
When a cpu enters S3 state, the FPU state is lost. After resuming for S3, if we try to lazy restore the FPU for a process running on the same CPU, this will result in a corrupted FPU context. Ensure that "fpu_owner_task" is properly invalided when (re-)initializing a CPU, so nobody will try to lazy restore a state which doesn't exist in the hardware. Tested with a 64-bit kernel on a 4-core Ivybridge CPU with eagerfpu=off, by doing thousands of suspend/resume cycles with 4 processes doing FPU operations running. Without the patch, a process is killed after a few hundreds cycles by a SIGFPE. Cc: Duncan Laurie <dlaurie@chromium.org> Cc: Olof Johansson <olofj@chromium.org> Cc: <stable@kernel.org> v3.4+ # for 3.4 need to replace this_cpu_write by percpu_write Signed-off-by: Vincent Palatin <vpalatin@chromium.org> Link: http://lkml.kernel.org/r/1354306532-1014-1-git-send-email-vpalatin@chromium.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-11-30Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull DRM fixes from Dave Airlie: "Just driver fixes, nothing major, except maybe the Ironlake rc6 disable: - intel: * revert ironlake rc6 - we still have one ilk regression, but this gets rid of one big one * turn off cloning * a directed fix for Apple edp - radeon: one modesetting fix - exynos: minor fixes" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: radeon: fix pll/ctrc mapping on dce2 and dce3 hardware Revert "drm/i915: enable rc6 on ilk again" drm/i915: do not default to 18 bpp for eDP if missing from VBT drm/exynos: Fix potential NULL pointer dereference in exynos_drm_encoder.c drm/exynos: Make exynos4/5_fimd_driver_data static drm/exynos: fix overlay updating issue drm/exynos: remove unnecessary code. drm/exynos: fix linux framebuffer address setting. drm/i915: disable cloning on sdvo
2012-11-30Merge branch 'akpm' (Fixes from Andrew)Linus Torvalds
Merge misc fixes from Andrew Morton: "Seven fixes, some of them fingers-crossed :(" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (7 patches) drivers/rtc/rtc-tps65910.c: fix invalid pointer access on _remove() mm: soft offline: split thp at the beginning of soft_offline_page() mm: avoid waking kswapd for THP allocations when compaction is deferred or contended revert "Revert "mm: remove __GFP_NO_KSWAPD"" mm: vmscan: fix endless loop in kswapd balancing mm/vmemmap: fix wrong use of virt_to_page mm: compaction: fix return value of capture_free_page()
2012-11-30Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Arnd Bergmann: "These are three fixes for the Marvell EBU family and one for the Samsung s3c platforms. All of them are obvious should still make it into 3.7." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: Kirkwood: Update PCI-E fixup Dove: Fix irq_to_pmu() Dove: Attempt to fix PMU/RTC interrupts ARM: S3C24XX: Fix potential NULL pointer dereference error
2012-11-30Merge tag 'ixp4xx-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM ixp4xx bug fixes from Arnd Bergmann: "These were originally prepared by Krzysztof Halasa but not submitted in time for v3.7 due to some confusion about how ixp4xx patches should be handled. Jason Cooper thankfully offered to help out sending the patches upstream through arm-soc now, but given the timing, we could as well delay them for 3.8." * tag 'ixp4xx-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: IXP4xx: use __iomem for MMIO IXP4xx: map CPU config registers within VMALLOC region. IXP4xx: Always ioremap() Queue Manager MMIO region at boot. ixp4xx: Declare MODULE_FIRMWARE usage IXP4xx crypto: MOD_AES{128,192,256} already include key size. WAN: Remove redundant HDLC info printed by IXP4xx HSS driver. IXP4xx: Remove time limit for PCI TRDY to enable use of slow devices. IXP4xx: ixp4xx_crypto driver requires Queue Manager and NPE drivers. IXP4xx: HW pseudo-random generator is available on IXP45x/46x only. IXP4xx: Fix off-by-one bug in Goramo MultiLink platform. IXP4xx: Fix Goramo MultiLink platform compilation.
2012-11-30Merge branch 'fixes' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull final ARM fix from Russell King: "One final fix, spotted by Will, to do with what happens when we boot a SMP kernel on UP." * 'fixes' of git://git.linaro.org/people/rmk/linux-arm: ARM: 7586/1: sp804: set cpumask to cpu_possible_mask for clock event device
2012-11-30drivers/rtc/rtc-tps65910.c: fix invalid pointer access on _remove()Kim, Milo
The tps65910_rtc data is registered as the platform driver data in _probe(= ). Therefore the tps65910_rtc should be used on unregistering the rtc device. And device pointer should be retrieved from the platform_device structure. This patch fixes the below oops: Unable to handle kernel NULL pointer dereference at virtual address 00000008 Modules linked in: rtc_tps65910(-) CPU: 0 Not tainted (3.7.0-rc7-next-20121128-g6b1f974-dirty #7) PC is at tps65910_rtc_alarm_irq_enable+0x20/0x2c [rtc_tps65910] (tps65910_rtc_alarm_irq_enable+0x20/0x2c [rtc_tps65910]) (tps65910_rtc_remove+0x18/0x28 [rtc_tps65910]) (platform_drv_remove+0x18/0x1c) (__device_release_driver+0x70/0xcc) (driver_detach+0xb4/0xb8) (bus_remove_driver+0x7c/0xc0) (sys_delete_module+0x148/0x21c) Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-30mm: soft offline: split thp at the beginning of soft_offline_page()Naoya Horiguchi
When we try to soft-offline a thp tail page, put_page() is called on the tail page unthinkingly and VM_BUG_ON is triggered in put_compound_page(). This patch splits thp before going into the main body of soft-offlining. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Andi Kleen <andi.kleen@intel.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-30mm: avoid waking kswapd for THP allocations when compaction is deferred or ↵Mel Gorman
contended With "mm: vmscan: scale number of pages reclaimed by reclaim/compaction based on failures" reverted, Zdenek Kabelac reported the following Hmm, so it's just took longer to hit the problem and observe kswapd0 spinning on my CPU again - it's not as endless like before - but still it easily eats minutes - it helps to turn off Firefox or TB (memory hungry apps) so kswapd0 stops soon - and restart those apps again. (And I still have like >1GB of cached memory) kswapd0 R running task 0 30 2 0x00000000 Call Trace: preempt_schedule+0x42/0x60 _raw_spin_unlock+0x55/0x60 put_super+0x31/0x40 drop_super+0x22/0x30 prune_super+0x149/0x1b0 shrink_slab+0xba/0x510 The sysrq+m indicates the system has no swap so it'll never reclaim anonymous pages as part of reclaim/compaction. That is one part of the problem but not the root cause as file-backed pages could also be reclaimed. The likely underlying problem is that kswapd is woken up or kept awake for each THP allocation request in the page allocator slow path. If compaction fails for the requesting process then compaction will be deferred for a time and direct reclaim is avoided. However, if there are a storm of THP requests that are simply rejected, it will still be the the case that kswapd is awake for a prolonged period of time as pgdat->kswapd_max_order is updated each time. This is noticed by the main kswapd() loop and it will not call kswapd_try_to_sleep(). Instead it will loopp, shrinking a small number of pages and calling shrink_slab() on each iteration. This patch defers when kswapd gets woken up for THP allocations. For !THP allocations, kswapd is always woken up. For THP allocations, kswapd is woken up iff the process is willing to enter into direct reclaim/compaction. [akpm@linux-foundation.org: fix typo in comment] Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Zdenek Kabelac <zkabelac@redhat.com> Cc: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Cc: Glauber Costa <glommer@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-30revert "Revert "mm: remove __GFP_NO_KSWAPD""Andrew Morton
It apepars that this patch was innocent, and we hope that "mm: avoid waking kswapd for THP allocations when compaction is deferred or contended" will fix the final kswapd-spinning cause. Cc: Zdenek Kabelac <zkabelac@redhat.com> Cc: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Rik van Riel <riel@redhat.com> Cc: Robert Jennings <rcj@linux.vnet.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-30mm: vmscan: fix endless loop in kswapd balancingJohannes Weiner
Kswapd does not in all places have the same criteria for a balanced zone. Zones are only being reclaimed when their high watermark is breached, but compaction checks loop over the zonelist again when the zone does not meet the low watermark plus two times the size of the allocation. This gets kswapd stuck in an endless loop over a small zone, like the DMA zone, where the high watermark is smaller than the compaction requirement. Add a function, zone_balanced(), that checks the watermark, and, for higher order allocations, if compaction has enough free memory. Then use it uniformly to check for balanced zones. This makes sure that when the compaction watermark is not met, at least reclaim happens and progress is made - or the zone is declared unreclaimable at some point and skipped entirely. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Reported-by: George Spelvin <linux@horizon.com> Reported-by: Johannes Hirte <johannes.hirte@fem.tu-ilmenau.de> Reported-by: Tomas Racek <tracek@redhat.com> Tested-by: Johannes Hirte <johannes.hirte@fem.tu-ilmenau.de> Reviewed-by: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-30mm/vmemmap: fix wrong use of virt_to_pageJianguo Wu
I enable CONFIG_DEBUG_VIRTUAL and CONFIG_SPARSEMEM_VMEMMAP, when doing memory hotremove, there is a kernel BUG at arch/x86/mm/physaddr.c:20. It is caused by free_section_usemap()->virt_to_page(), virt_to_page() is only used for kernel direct mapping address, but sparse-vmemmap uses vmemmap address, so it is going wrong here. ------------[ cut here ]------------ kernel BUG at arch/x86/mm/physaddr.c:20! invalid opcode: 0000 [#1] SMP Modules linked in: acpihp_drv acpihp_slot edd cpufreq_conservative cpufreq_userspace cpufreq_powersave acpi_cpufreq mperf fuse vfat fat loop dm_mod coretemp kvm crc32c_intel ipv6 ixgbe igb iTCO_wdt i7core_edac edac_core pcspkr iTCO_vendor_support ioatdma microcode joydev sr_mod i2c_i801 dca lpc_ich mfd_core mdio tpm_tis i2c_core hid_generic tpm cdrom sg tpm_bios rtc_cmos button ext3 jbd mbcache usbhid hid uhci_hcd ehci_hcd usbcore usb_common sd_mod crc_t10dif processor thermal_sys hwmon scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh_emc scsi_dh ata_generic ata_piix libata megaraid_sas scsi_mod CPU 39 Pid: 6454, comm: sh Not tainted 3.7.0-rc1-acpihp-final+ #45 QCI QSSC-S4R/QSSC-S4R RIP: 0010:[<ffffffff8103c908>] [<ffffffff8103c908>] __phys_addr+0x88/0x90 RSP: 0018:ffff8804440d7c08 EFLAGS: 00010006 RAX: 0000000000000006 RBX: ffffea0012000000 RCX: 000000000000002c ... Signed-off-by: Jianguo Wu <wujianguo@huawei.com> Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reviewd-by: Wen Congyang <wency@cn.fujitsu.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Reviewed-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-30mm: compaction: fix return value of capture_free_page()Mel Gorman
Commit ef6c5be658f6 ("fix incorrect NR_FREE_PAGES accounting (appears like memory leak)") fixes a NR_FREE_PAGE accounting leak but missed the return value which was also missed by this reviewer until today. That return value is used by compaction when adding pages to a list of isolated free pages and without this follow-up fix, there is a risk of free list corruption. Signed-off-by: Mel Gorman <mgorman@suse.de> Cc: Dave Hansen <dave@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-29Merge branch 'v3.7-samsung-fixes-4' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into fixes From Kukjin Kim <kgene.kim@samsung.com>: Samsung fixes for v3.7 * 'v3.7-samsung-fixes-4' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: S3C24XX: Fix potential NULL pointer dereference error This would have been ok to delay to 3.8 according to Kukjin, but since it's an obvious bug fix and a potential NULL pointer dereference, it seem appropriate for a late 3.7 submission. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-11-29remoteproc: fix error path of ->find_vqsOhad Ben-Cohen
Eliminate an erroneous invocation of rproc_shutdown inside the error path of rproc_virtio_find_vqs. Reported-by: Ido Yariv <ido@wizery.com> Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
2012-11-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Some more fixes trickled in over the past few days: 1) PIM device names can overflow the IFNAMSIZ buffer unless we properly limit the allowed indexes, fix from Eric Dumazet. 2) Under heavy load we can OOPS in icmp reply processing due to an unchecked inet_putpeer() call. Fix from Neal Cardwell. 3) SCTP round trip calculations need to use 64-bit math to avoid overflows, fix from Schoch Christian. 4) Fix a memory leak and an error return flub in SCTP and IRDA triggerable by userspace. Fix from Tommi Rantala and found by the syscall fuzzer (trinity). 5) MLX4 driver gives bogus size to memcpy() call, fix from Amir Vadai. 6) Fix length calculation in VHOST descriptor translation, from Michael S Tsirkin. 7) Ambassador ATM driver loops forever while loading firmware, fix from Dan Carpenter. 8) Over MTU packets in openvswitch warn about wrong device, fix from Jesse Gross. 9) Netfilter IPSET's netlink code can overrun a string buffer because it's not properly limited to IFNAMSIZ. Fix from Florian Westphal. 10) PCAN USB driver sets wrong timestamp in SKB, from Oliver Hartkopp. 11) Make sure the RX ifindex always has a valid value in the CAN BCM driver, even if we haven't received a frame yet. Fix also from Oliver Hartkopp." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: team: fix hw_features setup atm: forever loop loading ambassador firmware vhost: fix length for cross region descriptor irda: irttp: fix memory leak in irttp_open_tsap() error path net: qmi_wwan: add Huawei E173 net/mlx4_en: Can set maxrate only for TC0 sctp: Error in calculation of RTTvar sctp: fix -ENOMEM result with invalid user space pointer in sendto() syscall sctp: fix memory leak in sctp_datamsg_from_user() when copy from user space fails net: ipmr: limit MRT_TABLE identifiers ipv4: avoid passing NULL to inet_putpeer() in icmpv4_xrlim_allow() can: bcm: initialize ifindex for timeouts without previous frame reception can: peak_usb: fix hwtstamp assignment netfilter: ipset: fix netiface set name overflow openvswitch: Store flow key len if ARP opcode is not request or reply. openvswitch: Print device when warning about over MTU packets.
2012-11-28microblaze: rt_sigreturn is too trigger-happy about sigaltstack errorsAl Viro
2012-11-28score: do_sigaltstack() expects a userland pointer...Al Viro
2012-11-28sh64: fix altstack switching on sigreturnAl Viro
incidentally, declaring a local variable as __user (!) to make sparse STFU is really sick. Especially since sparse had been 100% right - it *is* a bug. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28openrisk: fix altstack switching on sigreturnAl Viro
do_sigaltstack() expects _userland_ address, TYVM... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28um: get_safe_registers() should be done in flush_thread(), not start_thread()Al Viro
... or we'll end up buggering the results of ELF_PLAT_INIT() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-11-28Merge branch 'fixes' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jesse/openvswitch Two small openswitch fixes from Jesse Gross. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-28c6x: use generic kvm_para.hMark Salter
Signed-off-by: Mark Salter <msalter@redhat.com>
2012-11-28c6x: remove internal kernel symbols from exported setup.hMark Salter
Some internal kernel symbols were referenced in the exported setup.h. This splits out the internal bits from the exported uapi bits. Signed-off-by: Mark Salter <msalter@redhat.com>
2012-11-28team: fix hw_features setupJiri Pirko
Do this in the same way bonding does. This fixed setup resolves performance issues when using some cards with certain offloading. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-28atm: forever loop loading ambassador firmwareDan Carpenter
There was a forever loop introduced here when we converted this to request_firmware() back in 2008. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Chas Williams <chas@cmf.nrl.navy.mil> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-28Merge branch 'master' of git://1984.lsi.us.es/nfDavid S. Miller
An interface name overflow fix in netfilter via Pablo Neira Ayuso. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-28vhost: fix length for cross region descriptorMichael S. Tsirkin
If a single descriptor crosses a region, the second chunk length should be decremented by size translated so far, instead it includes the full descriptor length. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-28irda: irttp: fix memory leak in irttp_open_tsap() error pathTommi Rantala
Cleanup the memory we allocated earlier in irttp_open_tsap() when we hit this error path. The leak goes back to at least 1da177e4 ("Linux-2.6.12-rc2"). Discovered with Trinity (the syscall fuzzer). Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-28net: qmi_wwan: add Huawei E173Bjørn Mork
The Huawei E173 is a QMI/wwan device which normally appear as 12d1:1436 in Linux. The descriptors displayed in that mode will be picked up by cdc_ether. But the modem has another mode with a different device ID and a slightly different set of descriptors. This is the mode used by Windows like this: 3Modem: USB\VID_12D1&PID_140C&MI_00\6&3A1D2012&0&0000 Networkcard: USB\VID_12D1&PID_140C&MI_01\6&3A1D2012&0&0001 Appli.Inter: USB\VID_12D1&PID_140C&MI_02\6&3A1D2012&0&0002 PC UI Inter: USB\VID_12D1&PID_140C&MI_03\6&3A1D2012&0&0003 Reported-by: Thomas Schäfer <tschaefer@t-online.de> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-28net/mlx4_en: Can set maxrate only for TC0Amir Vadai
Had a typo in memcpy. Signed-off-by: Amir Vadai <amirv@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-28sctp: Error in calculation of RTTvarSchoch Christian
The calculation of RTTVAR involves the subtraction of two unsigned numbers which may causes rollover and results in very high values of RTTVAR when RTT > SRTT. With this patch it is possible to set RTOmin = 1 to get the minimum of RTO at 4 times the clock granularity. Change Notes: v2) *Replaced abs() by abs64() and long by __s64, changed patch description. Signed-off-by: Christian Schoch <e0326715@student.tuwien.ac.at> CC: Vlad Yasevich <vyasevich@gmail.com> CC: Sridhar Samudrala <sri@us.ibm.com> CC: Neil Horman <nhorman@tuxdriver.com> CC: linux-sctp@vger.kernel.org Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-28sctp: fix -ENOMEM result with invalid user space pointer in sendto() syscallTommi Rantala
Consider the following program, that sets the second argument to the sendto() syscall incorrectly: #include <string.h> #include <arpa/inet.h> #include <sys/socket.h> int main(void) { int fd; struct sockaddr_in sa; fd = socket(AF_INET, SOCK_STREAM, 132 /*IPPROTO_SCTP*/); if (fd < 0) return 1; memset(&sa, 0, sizeof(sa)); sa.sin_family = AF_INET; sa.sin_addr.s_addr = inet_addr("127.0.0.1"); sa.sin_port = htons(11111); sendto(fd, NULL, 1, 0, (struct sockaddr *)&sa, sizeof(sa)); return 0; } We get -ENOMEM: $ strace -e sendto ./demo sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 ENOMEM (Cannot allocate memory) Propagate the error code from sctp_user_addto_chunk(), so that we will tell user space what actually went wrong: $ strace -e sendto ./demo sendto(3, NULL, 1, 0, {sa_family=AF_INET, sin_port=htons(11111), sin_addr=inet_addr("127.0.0.1")}, 16) = -1 EFAULT (Bad address) Noticed while running Trinity (the syscall fuzzer). Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-28sctp: fix memory leak in sctp_datamsg_from_user() when copy from user space ↵Tommi Rantala
fails Trinity (the syscall fuzzer) discovered a memory leak in SCTP, reproducible e.g. with the sendto() syscall by passing invalid user space pointer in the second argument: #include <string.h> #include <arpa/inet.h> #include <sys/socket.h> int main(void) { int fd; struct sockaddr_in sa; fd = socket(AF_INET, SOCK_STREAM, 132 /*IPPROTO_SCTP*/); if (fd < 0) return 1; memset(&sa, 0, sizeof(sa)); sa.sin_family = AF_INET; sa.sin_addr.s_addr = inet_addr("127.0.0.1"); sa.sin_port = htons(11111); sendto(fd, NULL, 1, 0, (struct sockaddr *)&sa, sizeof(sa)); return 0; } As far as I can tell, the leak has been around since ~2003. Signed-off-by: Tommi Rantala <tt.rantala@gmail.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-28CIFS: Fix wrong buffer pointer usage in smb_set_file_infoPavel Shilovsky
Commit 6bdf6dbd662176c0da5c3ac8ed10ac94e7776c85 caused a regression in setattr codepath that leads to files with wrong attributes. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-11-28percpu-rwsem: use synchronize_sched_expeditedMikulas Patocka
Use synchronize_sched_expedited() instead of synchronize_sched() to improve mount speed. This patch improves mount time from 0.500s to 0.013s for Jeff's test-case. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Reported-and-tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-28ARM: 7586/1: sp804: set cpumask to cpu_possible_mask for clock event deviceWill Deacon
The SP804 driver statically initialises the cpumask of the clock event device to be cpu_all_mask, which is derived from the compile-time constant NR_CPUS. This breaks SMP_ON_UP systems where the interrupt controller handling the sp804 doesn't have the irq_set_affinity callback on the irq_chip, because the common timer code fails to identify the device as cpu-local and ends up treating it as a broadcast device instead. This patch fixes the problem by using cpu_possible_mask at runtime, which will correctly represent the possible CPUs when SMP_ON_UP is being used. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-11-28Merge branch 'drm-fixes-3.7' of git://people.freedesktop.org/~agd5f/linuxDave Airlie
Just a single pll/crtc regression fix. * 'drm-fixes-3.7' of git://people.freedesktop.org/~agd5f/linux: radeon: fix pll/ctrc mapping on dce2 and dce3 hardware
2012-11-27radeon: fix pll/ctrc mapping on dce2 and dce3 hardwareJerome Glisse
This fix black screen on resume issue that some people are experiencing. There is a bug in the atombios code regarding pll/crtc mapping. The atombios code reverse the logic for the pll and crtc mapping. agd5f: drop unnecessary crtc id check, cc stable in case we miss 3.7. This fixes the root cause that was worked around by commits: drm/radeon: allocate PPLLs from low to high drm/radeon/dce3: switch back to old pll allocation order for discrete Signed-off-by: Jerome Glisse <jglisse@redhat.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
