After this the socket creation in it knows the context.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
The existing code adjusted it based on the worst case scenario for the returned
bitmap and the best case scenario for the supported attrs attribute.
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
[bfields@redhat.com: removed likely/unlikely's]
On Wed, 29 Sep 2010 14:02:38 +1000 Stephen Rothwell <sfr@canb.auug.org.au> wrote:
> After merging the final tree, today's linux-next build (powerpc
> ppc44x_defconfig) produced tis warning:
> WARNING: net/sunrpc/sunrpc.o(.init.text+0x110): Section mismatch in reference from the function init_sunrpc() to the function .exit.text:rpcauth_remove_module()
> The function __init init_sunrpc() references
> a function __exit rpcauth_remove_module().
> This is often seen when error handling in the init function
> uses functionality in the exit path.
> The fix is often to remove the __exit annotation of
> rpcauth_remove_module() so it may be used outside an exit section.
> Probably caused by commit 2f72c9b73730c335381b13e2bd221abe1acea394
> ("sunrpc: The per-net skeleton").
This actually causes a build failure on a sparc32 defconfig build:
`rpcauth_remove_module' referenced in section `.init.text' of net/built-in.o: defined in discarded section `.exit.text' of net/built-in.o
I applied the following patch for today:
Fixes:
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Everything that is required for that already exists:
* the per-net cache registration with respective proc entries
* the context (struct net) is available in all the users
Register empty per-net operations for the sunrpc layer.
The transport representation should be per-net of course.
Existing calls do the same, but for the init_net.
There are two calls that operate on ip_map_cache and are
directly called from the nfsd code. Other places will be
handled in a different way.
They do not require the rqst actually and having the xprt simplifies
further patching.
This is done in order to facilitate getting the ip_map_cache from
which to put the ip_map.
The target is to have many ip_map_cache-s in the system. This particular
patch handles its usage by the ip_map_parse callback.
Note with "first" always 0, and "lastflags" initially 0, we always dump
a spurious set of 0 flags at the start, among other problems.
Fix. And attempt to make the code a little more obvious.
The git://linux-nfs.org/~bfields/linux.git nfsd-next branch doesn't
compile when nfsd is a module with the following error:
ERROR: "get_task_comm" [fs/nfsd/nfsd.ko] undefined!
Replace the get_task_comm call with direct comm access, which is
safe for current.
Add CONFIG_NFSD_DEPRECATED, default to y.
Only include deprecated interface if this is defined.
This allows distros to remove this interface before the official
removal, and allows developers to test without it.
Signed-off-by: NeilBrown <neilb@suse.de>
The syscall interface is has been replaced by a more flexible
interface since 2.6.0. It is time to work towards discarding
the old interface.
So add a entry in feature-removal-schedule.txt and print a warning
when the interface is used.
commit 6610f720e9e8103c22d1f1ccf8fbb695550a571f
broke cache_clean_deferred as entries are no longer added to the
pending list for subsequent revisiting.
So put those requests back on the pending list.
This patch removes all but one call to lock_kernel() from the server.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: linux-nfs@vger.kernel.org
Being a hash table, hlist is the best option.
There is currently some ugliness were we treat "->next == NULL" as
a special case to avoid having to initialise the whole array.
This change nicely gets rid of that case.
Code like:
switch(xxx) {
case -error1:
case -error2:
return;
case 0:
stuff;
can more naturally be written:
if (xxx < 0)
return;
stuff;
The idmap code manages request deferal by waiting for a reply from
userspace rather than putting the NFS request on a queue to be retried
from the start.
Now that the common deferal code does this there is no need for the
special code in idmap.
Now that a slight delay in getting a reply to an upcall doesn't
require deferring of requests, request deferral for all NFSv4
requests - the concept doesn't really fit with the v4 model.
If we drop a request in the sunrpc layer, either due kmalloc failure,
or due to a cache miss when we could not queue the request for later
replay, then close the connection to encourage the client to retry sooner.
Note that if the drop happens in the NFS layer, NFSERR_JUKEBOX
(aka NFS4ERR_DELAY) is returned to guide the client concerning
replay.
The last_close field of a cache_detail is initialized to zero, so the
condition
detail->last_close < seconds_since_boot() - 30
may be false even for a cache that was never opened.
However, we want to immediately fail upcalls to caches that were never
opened: in the case of the auth_unix_gid cache, especially, which may
never be opened by mountd (if the --manage-gids option is not set), we
want to fail the upcall immediately. Otherwise client requests will be
dropped unnecessarily on reboot.
Also document these conditions.
Without some client-side fixes, server testing is currently difficult.
The NFSv4 client's callback server calls svc_gss_principal(), which
is defined in the auth_rpcgss.ko
The NFSv4 server has the same dependency, and in addition calls
svcauth_gss_flavor(), gss_mech_get_by_pseudoflavor(),
gss_pseudoflavor_to_service() and gss_mech_put() from the same module.
The module auth_rpcgss itself has no dependencies aside from sunrpc,
so we only need to select RPCSEC_GSS.
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
An NFS client executes a statfs("file", &buff) call.
"file" exists / existed, the client has read / written it,
but it has already closed it.
user_path(pathname, &path) looks up "file" successfully in the
directory-cache and restarts the aging timer of the directory-entry.
Even if "file" has already been removed from the server, because the
lookupcache=positive option I use, keeps the entries valid for a while.
nfs_statfs() returns ESTALE if "file" has already been removed from the
server.
If the user application repeats the statfs("file", &buff) call, we
are stuck: "file" remains young forever in the directory-cache.
Signed-off-by: Zoltan Menyhart <Zoltan.Menyhart@bull.net>
Cc: stable@kernel.org
Reported-by: Ben Greear <greearb@candelatech.com>
The maximum size of the authcache is now set to 1024 (10 bits),
but on our server we need at least 4096 (12 bits). Increase
MAX_HASHTABLE_BITS to 14. This is a maximum of 16384 entries,
each containing a pointer (8 bytes on x86_64). This is
exactly the limit of kmalloc() (128K).
Signed-off-by: Miquel van Smoorenburg <mikevs@xs4all.net>
spkm3 miss returning error to up layer when import security context,
it may be return ok though it has failed to import security context.
Signed-off-by: Bian Naimeng <biannm@cn.fujitsu.com>
krb5 miss returning error to up layer when import security context,
The do_vfs_lock function on fs/nfs/file.c is only called if NLM is
not being used, via the -onolock mount option. Therefore it cannot
really be "out of sync with lock manager" when the local locking
function called returns an error, as there will be no corresponding
call to the NLM. For details, simply check the if/else on do_setlk
and do_unlk on fs/nfs/file.c.
Signed-Off-By: Fabio Olive Leite <fleite@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
This is just a minor cleanup: net/sunrpc/clnt.c clarifies the rpc client
state machine by commenting each state and by laying out the functions
implementing each state in the order that each state is normally
executed (in the absence of errors).
The previous patch "Fix null dereference in call_allocate" changed the
order of the states. Move the functions and update the comments to
reflect the change.
There is a race between rpc_info_open and rpc_release_client()
in that nothing stops a process from opening the file after
the clnt->cl_kref goes to zero.
Fix this by using atomic_inc_unless_zero()...
Reported-by: J. Bruce Fields <bfields@redhat.com>
If rpc_queue_upcall() adds a new upcall to the rpci->pipe list just
after rpc_pipe_release calls rpc_purge_list(), but before it calls
gss_pipe_release (as rpci->ops->release_pipe(inode)), then the latter
will free a message without deleting it from the rpci->pipe list.
We will be left with a freed object on the rpc->pipe list. Most
frequent symptoms are kernel crashes in rpc.gssd system calls on the
pipe in question.
In call_allocate we need to reach the auth in order to factor au_cslack
into the allocation.
As of a17c2153d2e271b0cbacae9bed83b0eaa41db7e1 "SUNRPC: Move the bound
cred to struct rpc_rqst", call_allocate attempts to do this by
dereferencing tk_client->cl_auth, however this is not guaranteed to be
defined--cl_auth can be zero in the case of gss context destruction (see
rpc_free_auth).
Reorder the client state machine to bind credentials before allocating,
so that we can instead reach the auth through the cred.
Fix docbook templates that reference files that do not contain the
expected kernel-doc notation.
Fixes these warnings:
Warning(arch/x86/include/asm/unaligned.h): no structured comments found
Warning(lib/vsprintf.c): no structured comments found
These cause errors in the generated html output, like below, so drop
these lines.
Name
arch/x86/include/asm/unaligned.h - Document generation inconsistency
Oops
Warning
The template for this document tried to insert the structured comment from the file arch/x86/include/asm/unaligned.h at this point, but none was found. This dummy section is inserted to allow generation to continue.
When you don't use !E or !I but only !F, then it's very easy to miss
including some functions, structs etc. in documentation. To help
finding which ones were missed, allow printing out the unused ones as
warnings.
For example, using this on mac80211 yields a lot of warnings like this:
Warning: didn't use docs for DOC: mac80211 workqueue
Warning: didn't use docs for ieee80211_max_queues
Warning: didn't use docs for ieee80211_bss_change
Warning: didn't use docs for ieee80211_bss_conf
when generating the documentation for it.
There are valid attributes that could have upper case letters, but we
still want to remove, like for example
__attribute__((aligned(NETDEV_ALIGN)))
as encountered in the wireless code.
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'pm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
PM / Hibernate: Avoid hitting OOM during preallocation of memory
PM QoS: Correct pr_debug() misuse and improve parameter checks
PM: Prevent waiting forever on asynchronous resume after failing suspend
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] fix use-after-free in scsi_init_io()
[SCSI] sd: fix medium-removal bug
[SCSI] qla2xxx: Update version number to 8.03.04-k0.
[SCSI] qla2xxx: Check for empty slot in request queue before posting Command type 6 request.
[SCSI] qla2xxx: Cover UNDERRUN case where SCSI status is set.
[SCSI] qla2xxx: Correctly set fw hung and complete only waiting mbx.
[SCSI] qla2xxx: Reset seconds_since_last_heartbeat correctly.
[SCSI] qla2xxx: make rport deletions explicit during vport removal
[SCSI] qla2xxx: Fix vport delete issues
[SCSI] sd, sym53c8xx: Remove warnings after vsprintf %pV introducation.
[SCSI] Fix warning: zero-length gnu_printf format string
[SCSI] hpsa: disable doorbell reset on reset_devices
[SCSI] be2iscsi: Fix for Login failure
[SCSI] fix bio.bi_rw handling
There is a problem in hibernate_preallocate_memory() that it calls
preallocate_image_memory() with an argument that may be greater than
the total number of available non-highmem memory pages. If that's
the case, the OOM condition is guaranteed to trigger, which in turn
can cause significant slowdown to occur during hibernation.
To avoid that, make preallocate_image_memory() adjust its argument
before calling preallocate_image_pages(), so that the total number of
saveable non-highem pages left is not less than the minimum size of
a hibernation image. Change hibernate_preallocate_memory() to try to
allocate from highmem if the number of pages allocated by
preallocate_image_memory() is too low.
Modify free_unnecessary_pages() to take all possible memory
allocation patterns into account.
Reported-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Tested-by: M. Vefa Bicakci <bicave@superonline.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (28 commits)
ipheth: remove incorrect devtype to WWAN
MAINTAINERS: Add CAIF
sctp: fix test for end of loop
KS8851: Correct RX packet allocation
udp: add rehash on connect()
net: blackhole route should always be recalculated
ipv4: Suppress lockdep-RCU false positive in FIB trie (3)
niu: Fix kernel buffer overflow for ETHTOOL_GRXCLSRLALL
ipvs: fix active FTP
gro: Re-fix different skb headrooms
via-velocity: Turn scatter-gather support back off.
ipv4: Fix reverse path filtering with multipath routing.
UNIX: Do not loop forever at unix_autobind().
PATCH: b44 Handle RX FIFO overflow better (simplified)
irda: off by one
3c59x: Fix deadlock in vortex_error()
netfilter: discard overlapping IPv6 fragment
ipv6: discard overlapping fragment
net: fix tx queue selection for bridged devices implementing select_queue
bonding: Fix jiffies overflow problems (again)
Fix up trivial conflicts due to the same cgroup API thinko fix going
through both Andrew and the networking tree. However, there were small
differences between the two, with Andrew's version generally being the
nicer one, and the one I merged first. So pick that one.
Conflicts in: include/linux/cgroup.h and kernel/cgroup.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
sparc: Kill all BKL usage.
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, tsc: Fix a preemption leak in restore_sched_clock_state()
sched: Move sched_avg_update() to update_cpu_load()
