The aim of last_field_index was to detect the end of the report.
With the introduction of .report(), it is not required anymore to
detect it on the fly as we can put it in the right place during the
.report().
The resulting code path is simpler to read because the terminating
condition is not evaluated after each field.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID subsystem updates from Jiri Kosina:
"HID subsystem and drivers update. Highlights:
- new support of a group of Win7/Win8 multitouch devices, from
Benjamin Tissoires
- fix for compat interface brokenness in uhid, from Dmitry Torokhov
- conversion of drivers to use hid_driver helper, by H Hartley
Sweeten
- HID over I2C transport received ACPI enumeration support, written
by Mika Westerberg
- there is an ongoing effort to make HID sensor hubs independent of
USB transport. The first self-contained part of this work is
provided here, done by Mika Westerberg
- a few smaller fixes here and there, support for a couple new
devices added"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: (43 commits)
HID: Correct Logitech order in hid-ids.h
HID: LG4FF: Remove unnecessary deadzone code
HID: LG: Prevent the Logitech Gaming Wheels deadzone
HID: LG: Fix detection of Logitech Speed Force Wireless (WiiWheel)
HID: LG: Add support for Logitech Momo Force (Red) Wheel
HID: hidraw: print message when succesfully initialized
HID: logitech: split accel, brake for Driving Force wheel
HID: logitech: add report descriptor for Driving Force wheel
HID: add ThingM blink(1) USB RGB LED support
HID: uhid: make creating devices work on 64/32 systems
HID: wiimote: fix nunchuck button parser
HID: blacklist Velleman data acquisition boards
HID: sensor-hub: don't limit the driver only to USB bus
HID: sensor-hub: get rid of unused sensor_hub_grabbed_usages[] table
HID: extend autodetect to handle I2C sensors as well
HID: ntrig: use input_configured() callback to set the name
HID: multitouch: do not use pointers towards hid-core
HID: add missing GENERIC_HARDIRQ dependency
HID: multitouch: make MT_CLS_ALWAYS_TRUE the new default class
HID: multitouch: fix protocol for Elo panels
Pull trivial tree from Jiri Kosina:
"Assorted tiny fixes queued in trivial tree"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (22 commits)
DocBook: update EXPORT_SYMBOL entry to point at export.h
Documentation: update top level 00-INDEX file with new additions
ARM: at91/ide: remove unsused at91-ide Kconfig entry
percpu_counter.h: comment code for better readability
x86, efi: fix comment typo in head_32.S
IB: cxgb3: delay freeing mem untill entirely done with it
net: mvneta: remove unneeded version.h include
time: x86: report_lost_ticks doesn't exist any more
pcmcia: avoid static analysis complaint about use-after-free
fs/jfs: Fix typo in comment : 'how may' -> 'how many'
of: add missing documentation for of_platform_populate()
btrfs: remove unnecessary cur_trans set before goto loop in join_transaction
sound: soc: Fix typo in sound/codecs
treewide: Fix typo in various drivers
btrfs: fix comment typos
Update ibmvscsi module name in Kconfig.
powerpc: fix typo (utilties -> utilities)
of: fix spelling mistake in comment
h8300: Fix home page URL in h8300/README
xtensa: Fix home page URL in Kconfig
Merge misc patches from Andrew Morton:
- Florian has vanished so I appear to have become fbdev maintainer
again :(
- Joel and Mark are distracted to welcome to the new OCFS2 maintainer
- The backlight queue
- Small core kernel changes
- lib/ updates
- The rtc queue
- Various random bits
* akpm: (164 commits)
rtc: rtc-davinci: use devm_*() functions
rtc: rtc-max8997: use devm_request_threaded_irq()
rtc: rtc-max8907: use devm_request_threaded_irq()
rtc: rtc-da9052: use devm_request_threaded_irq()
rtc: rtc-wm831x: use devm_request_threaded_irq()
rtc: rtc-tps80031: use devm_request_threaded_irq()
rtc: rtc-lp8788: use devm_request_threaded_irq()
rtc: rtc-coh901331: use devm_clk_get()
rtc: rtc-vt8500: use devm_*() functions
rtc: rtc-tps6586x: use devm_request_threaded_irq()
rtc: rtc-imxdi: use devm_clk_get()
rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug()
rtc: rtc-pcf8583: use dev_warn() instead of printk()
rtc: rtc-sun4v: use pr_warn() instead of printk()
rtc: rtc-vr41xx: use dev_info() instead of printk()
rtc: rtc-rs5c313: use pr_err() instead of printk()
rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug()
rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug()
rtc: rtc-ds2404: use dev_err() instead of printk()
rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk()
Use devm_*() functions to make cleanup paths more simple.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Use devm_request_threaded_irq() to make cleanup paths more simple.
Use devm_clk_get() to make cleanup paths more simple.
Fix the checkpatch warning as below:
WARNING: Prefer netdev_err(netdev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ...
Fix the checkpatch warnings as below:
WARNING: please, no space before tabs
The original sa1100_rtc_open/sa1100_rtc_release will be called when the
/dev/rtc0 is opened or closed. In fact, these two functions will
enable/disable the clock. Disabling clock will make rtc not work. So
only enable/disable clock when probe/remove the device.
Signed-off-by: Chao Xie <chao.xie@marvell.com>
Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com>
Cc: Leo Song <liangs@marvell.com>
Add an rtc driver for Maxim 8997 multifunction chip. Max8997 has rtc
module in it. and it can be used for timekeeping clock and system alarm.
It provide various operational mode those are BCD/binary, 24/12hour,
am/pm. Driver sets binary/24/ for default. Maxim 8997 also supports
SMPL(Sudden Momentary Power Loss), WTSR (Watchdog Timeout and Software
Reset).
Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com>
Cc: Devendra Naga <devendra.aaru@gmail.com>
Use dev_dbg() instaed of pr_debug() to be consistent.
The Armada 370 and Armada XP Socs have the same controller that the one
used in the orion platforms. This patch updates the device tree for
these SoCs.
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Mark the pl031 as wake-up capable so that rtcwake and suspend test can work.
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Torben Hohn <torbenh@linutronix.de>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
All interrupt get disabled during system suspend and enabled during system
resume. The enabling/disabling of interrupt happen in sequence of
interrupt registration with framework.
Therefore, in resume, the parent interrupt of this device enabled before
the RTC irq interrupt enabled. If RTC is enabled for alarm wake and if
system wake by alarm then there is interrupt pending for RTC. In resume,
the parent interrupt get enabled before the rtc interrupt and hence ISR
get served. In ISR, it founds that rtc interrupt is disabled and so it
does not call the rtc isr handler and hence it misses the interrupt.
Setting flag for early resume so that rtc interrupt get enabled before
parent interrupt and so rtc interrupt get enabled when parent interrupt
handler check for interrupt of device and call the rtc handler if it is
there. This way it will not miss the interrupt.
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
suspend/resume callbacks
Use SET_SYSTEM_SLEEP_PM_OPS for setting suspend/resume callbacks for
dev_pm_ops.
The driver stores the interrupt enable register before going to suspend
and restore in resume. Also it enables alarm before going to suspend.
The driver only write the Interrupt enable register for enabling ALARM and
does not enable any other bits. So it is not require to save complete
register and enable ALARM interrupt before suspend and restore in resume.
Also ALARM interrupt already enable if alarm is enabled before going to
suspend and hence it is not require to enable explictly in suspend.
Removing such above code.
Making the rtc driver as wakeup capabale and leaving the wake
enable/disable decision to user space through a sysfs attribute.
In suspend, enable wake if device wakeup enabled. In resume disable wake
again.
This change is inline with the Documentation/power/devices.txt#
/sys/devices/.../power/wakeup files
Add an RTC driver for TPS80031/TPS80032 chips by TI. This driver
supports:
- Setting and getting time and date.
- Setting and reading alarm time.
- Alarm and interrupt functionlity.
[akpm@linux-foundation.org: remove obsolete __devinit/__devexit]
Reviewed-by: Devendra Naga <devendra.aaru@gmail.com>
TI LP8788 PMU supports regulators, battery charger, RTC, ADC, backlight
driver and current sinks. This patch enables LP8788 rtc module.
Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com>
Cc: "devendra.aaru" <devendra.aaru@gmail.com>
Remove removes some code duplication by using module_platform_driver().
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com>
Found by Coccinelle: http://coccinelle.lip6.fr/
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
pxa-rtc is widely used in pxa27x/pxa3xx/pxa93x/pxa95x. Checking cpuid in
pxa-rtc driver is unnecessary since we assign on-chip device in soc files.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
This eliminates having an #ifdef returning NULL for the case when OF is
disabled. Maintains consistency in cases where OF is always selected.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Implement reading of the battery voltage low signal for rtc-pcf8523.
The bit is read-only and cannot be cleared by software, so no
clear function is implemented.
[akpm@linux-foundation.org: omit pcf8563_rtc_ioctl() if CONFIG_RTC_INTF_DEV=n]
Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com>
Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de>
Add a driver to support max77686 rtc. MAX77686 rtc support smpl and wtsr
mode. It has two alarm register which can be used for alarming to wake
system up. This drvier uses regmap to access its register.
[akpm@linux-foundation.org: remove inline, __devinit annotations]
[jg1.han@samsung.com: fix build warnings]
[akpm@linux-foundation.org: simplify code]
Signed-off-by: Chiwoong Byun <woong.byun@samsung.com>
Signed-off-by: Myugnjoo Ham <myungjoo.ham@samsung.com>
Fix alarm can't wake up system issue
Signed-off-by: Leo Song <liangs@marvell.com>
Fix pxa rtc alarm issue by setting week of month and day of week in
rdar/rdcr or it would not match.
We can use user_ns, which is also assigned from task_cred_xxx(tsk,
user_ns), at the beginning of copy_namespaces().
Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
In fill_elf_header(), elf->e_ident[EI_OSABI] is always set to ELF_OSABI,
so remove the unused argument 'osabi'.
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Do not test udelay() for a value less than 10usec when passed a variable
instead of a hard-coded number; there is no way for checkpatch to know the
value of the variable. As it is today, it will complain about variables
with alphanumeric characters plus '_', e.g. foo_bar, but not variables
with other characters, eg. foo->bar.
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
Cc: Andy Whitcroft <apw@canonical.com>
Cc: Joe Perches <joe@perches.com>
