We have a bug in the calculation of the next jiffie to trigger the RTC
synchronisation. The aim here is to run sync_cmos_clock() as close as
possible to the middle of a second. Which means we want this function to
be called less than or equal to half a jiffie away from when now.tv_nsec
equals 5e8 (500000000).
If this is not the case for a given call to the function, for this purpose
instead of updating the RTC we calculate the offset in nanoseconds to the
next point in time where now.tv_nsec will be equal 5e8. The calculated
offset is then converted to jiffies as these are the unit used by the
timer.
Hovewer timespec_to_jiffies() used here uses a ceil()-type rounding mode,
where the resulting value is rounded up. As a result the range of
now.tv_nsec when the timer will trigger is from 5e8 to 5e8 + TICK_NSEC
rather than the desired 5e8 - TICK_NSEC / 2 to 5e8 + TICK_NSEC / 2.
As a result if for example sync_cmos_clock() happens to be called at the
time when now.tv_nsec is between 5e8 + TICK_NSEC / 2 and 5e8 to 5e8 +
TICK_NSEC, it will simply be rescheduled HZ jiffies later, falling in the
same range of now.tv_nsec again. Similarly for cases offsetted by an
integer multiple of TICK_NSEC.
This change addresses the problem by subtracting TICK_NSEC / 2 from the
nanosecond offset to the next point in time where now.tv_nsec will be
equal 5e8, effectively shifting the following rounding in
timespec_to_jiffies() so that it produces a rounded-to-nearest result.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
After fixing the u32 thinko I sill had occasional hickups on ATI chipsets
with small deltas. There seems to be a delay between writing the compare
register and the transffer to the internal register which triggers the
interrupt. Reading back the value makes sure, that it hit the internal
match register befor we compare against the counter value.
We use the HPET only in 32bit mode because:
1) some HPETs are 32bit only
2) on i386 there is no way to read/write the HPET atomic 64bit wide
The HPET code unification done by the "moron of the year" did
not take into account that unsigned long is different on 32 and
64 bit.
This thinko results in a possible endless loop in the clockevents
code, when the return comparison fails due to the 64bit/332bit
unawareness.
unsigned long cnt = (u32) hpet_read() + delta can wrap over 32bit.
but the final compare will fail and return -ETIME causing endless
loops.
Until the C1E patches arrived there where no users of periodic broadcast
before switching to oneshot mode. Now we need to trigger a possible
waiter for a periodic broadcast when switching to oneshot mode.
Otherwise we can starve them for ever.
The minimum reprogramming delta was hardcoded in HPET ticks,
which is stupid as it does not work with faster running HPETs.
The C1E idle patches made this prominent on AMD/RS690 chipsets,
where the HPET runs with 25MHz. Set it to 5us which seems to be
a reasonable value and fixes the problems on the bug reporters
machines. We have a further sanity check now in the clock events,
which increases the delta when it is not sufficient.
Tested-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
Tested-by: Dmitry Nezhevenko <dion@inhex.net>
The C1E/HPET bug reports on AMDX2/RS690 systems where tracked down to a
too small value of the HPET minumum delta for programming an event.
The clockevents code needs to enforce an interrupt event on the clock event
device in some cases. The enforcement code was stupid and naive, as it just
added the minimum delta to the current time and tried to reprogram the device.
When the minimum delta is too small, then this loops forever.
Add a sanity check. Allow reprogramming to fail 3 times, then print a warning
and double the minimum delta value to make sure, that this does not happen again.
Use the same function for both tick-oneshot and tick-broadcast code.
While chasing the C1E/HPET bugreports I went through the clock events
code inch by inch and found that the broadcast device can be initialized
and shutdown multiple times. Multiple shutdowns are not critical, but
useless waste of time. Multiple initializations are simply broken. Another
CPU might have the device in use already after the first initialization and
the second init could just render it unusable again.
In tick_oneshot_setup we program the device to the given next_event,
but we do not check the return value. We need to make sure that the
device is programmed enforced so the interrupt handler engine starts
working. Split out the reprogramming function from tick_program_event()
and call it with the device, which was handed in to tick_setup_oneshot().
Set the force argument, so the devices is firing an interrupt.
The reprogramming of the periodic broadcast handler was broken,
when the first programming returned -ETIME. The clockevents code
stores the new expiry value in the clock events device next_event field
only when the programming time has not been elapsed yet. The loop in
question calculates the new expiry value from the next_event value
and therefor never increases.
There is a ordering related problem with clockevents code, due to which
clockevents_register_device() called after tickless/highres switch
will not work. The new clockevent ends up with clockevents_handle_noop as
event handler, resulting in no timer activity.
The problematic path seems to be
* old device already has hrtimer_interrupt as the event_handler
* new clockevent device registers with a higher rating
* tick_check_new_device() is called
* clockevents_exchange_device() gets called
* old->event_handler is set to clockevents_handle_noop
* tick_setup_device() is called for the new device
* which sets new->event_handler using the old->event_handler which is noop.
Change the ordering so that new device inherits the proper handler.
This does not have any issue in normal case as most likely all the clockevent
devices are setup before the highres switch. But, can potentially be affecting
some corner case where HPET force detect happens after the highres switch.
This was a problem with HPET in MSI mode code that we have been experimenting
with.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
SELinux: memory leak in security_context_to_sid_core
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
powerpc: Fix for getting CPU number in power_save_ppc32_restore()
powerpc: Fix build error with 64K pages and !hugetlbfs
powerpc: Work around gcc's -fno-omit-frame-pointer bug
powerpc: Make sure _etext is after all kernel text
powerpc: Only make kernel text pages of linear mapping executable
powerpc: Fix uninitialised variable in VSX alignment code
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
bnx2x: Accessing un-mapped page
ath9k: Fix TX control flag use for no ACK and RTS/CTS
ath9k: Fix TX status reporting
iwlwifi: fix STATUS_EXIT_PENDING is not set on pci_remove
iwlwifi: call apm stop on exit
iwlwifi: fix Tx cmd memory allocation failure handling
iwlwifi: fix rx_chain computation
iwlwifi: fix station mimo power save values
iwlwifi: remove false rxon if rx chain changes
iwlwifi: fix hidden ssid discovery in passive channels
iwlwifi: W/A for the TSF correction in IBSS
netxen: Remove workaround for chipset quirk
pcnet-cs, axnet_cs: add new IDs, remove dup ID with less info
ixgbe: initialize interrupt throttle rate
net/usb/pegasus: avoid hundreds of diagnostics
tipc: Don't use structure names which easily globally conflict.
Fix a bug and a philosophical decision about who handles errors.
security_context_to_sid_core() was leaking a context in the common case.
This was causing problems on fedora systems which recently have started
making extensive use of this function.
In discussion it was decided that if string_to_context_struct() had an
error it was its own responsibility to clean up any mess it created
along the way.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Signed-off-by: James Morris <jmorris@namei.org>
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
The allocated RX buffer size was 64 bytes bigger than the PCI mapped
size with no good reason. If the packet was actually using the buffer up
to its limit and if the last 64 bytes of the buffer crossed 4KB boundary
then an unmapped PCI page was accessed. The fix is to use only one
parameter for the buffer size - there is no need to differentiate
between the buffer size and the PCI mapping size since the extra 64
bytes can actually be used by the FW to align the Ethernet payload to
64 bytes.
Also updating the driver version and date
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com>
This patch sets STATUS_EXIT_PENDING on pci_remove. Otherwise
iwl4965_down may fail to uninitialize the driver.
Signed-off-by: Gregory Greenman <gregory.greenman@intel.com>
Signed-off-by: Mohamed Abbas <mohamed.abbas@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Signed-off-by: Zhu Yi <yi.zhu@intel.com>
This patch calls apm stop on exit and suspend. Without this patch
hardware consumes power even after driver is removed or suspended.
This patch "iwlwifi: do not use GFP_DMA in iwl_tx_queue_init" removes
GFP_DMA from allocation tx command buffers. GFP_DMA allows allocation
only for memory under 16M which causes allocation problems
suspend/resume flows.
Using kmalloc is temporal solution and some consistent/coherent
allocation schema will be more correct. Since iwlwifi hardware
supports 64bit address this solution should work on x86 (32 and
64bit) for now.
This patch fixes memory freeing problem in the previous patch.
Signed-off-by: Ian Schram <ischram@telenet.be>
This patch fixes rx_chain computation. The code that adjusts number of
rx chains to number supported by HW was missing. Miss configuration
causes firmware error. Note: iwlwifi supports HW with up to 3 RX
chains (2x2, 2x3, 1x2, and 3x3 MIMO). This patch also simplifies the
whole RX chain computation.
This patch fixes the wrong use MIMO power save values. Our TX was
configured with our MIMO power save values instead of peer's MIMO power
save values, this may affect connectivity. The peer STA/AP may not sense
our traffic at all as it doesn't have all RX chains opened.
Signed-off-by: Ron Rindjunsky <ron.rindjunsky@intel.com>
Rx chain might change during power save transitions but it doesn't
require sending Full-ROXN command to the firmware. Full-RXON requires
reconnection to an AP and thus affects user experience. The patch
avoids the Full-RXON by removing the rx_chain modification check in
iwl_full_rxon_required function.
This enables sending of direct probes on passive channels, as long as
traffic was detected on that channel. This enables connectivity to
hidden/non broadcasting SSIDs APs on passive channels. Note 5000 HW
declares all 5.2 spectrum as passive.
Signed-off-by: Cahill Ben <ben.m.cahill@intel.com>
This patch is a W/A for the TSF sync issue in IBSS merging. HW is not
capable to sync TSF (it's constantly little behind). This creates
constant IBSS merging upon reception of each beacon, adding and removing
station which in turn creates above 50% packet loss and thus dramatically
degrade the throughput. The W/A simply stops the driver from declaring it
has a reliable TSF value and thus eliminates IBSS merging.
Signed-off-by: Assaf Krauss <assaf.krauss@intel.com>
The TSC calibration function is still very complicated, but this makes
it at least a little bit less so by moving the PIT part out into a
helper function of its own.
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
Signed-of-by: Linus Torvalds <torvalds@linux-foundation.org>
Remove chipset-specific quirk workaround; the workaround caused
unrecoverable DMA lockups when the driver was loaded following a
PXE boot.
Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com>
Signed-off-by: Michael Brown <mbrown@fensystems.co.uk>
pcnet_cs:
add new ID: "corega Ether PCC-TD".
remove duplicate ID: "IC-CARD".
axnet_cs:
add new ID: "IO DATA ETXPCM".
Signed-off-by: Komuro <komurojun-mbn@nifty.com>
This commit dropped the setting of the default interrupt throttle rate.
commit 021230d40ae0e6508d6c717b6e0d6d81cd77ac25
Author: Ayyappan Veeraiyan <ayyappan.veeraiyan@intel.com>
Date: Mon Mar 3 15:03:45 2008 -0800
ixgbe: Introduce MSI-X queue vector code
The following patch adds it back. Without this the default value of 0
causes the performance of this card to be awful. Restoring these to the
default values yields much better performance.
This regression has been around since 2.6.25.
Signed-off-by: Andy Gospodarek <andy@greyhouse.net>
Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
CC: stable@kernel.org [2.6.25 and later]
Make the "pegasus" driver scream less loudly in the face of
problems as it initializes, avoiding hundreds of messages:
- ratelimit some key error messages
- avoid some spurious diagnostics caused by strange codeflow
And fix one instance of goofy indentation.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
The calculation to get TI_CPU based off of SPRG3 was just plain wrong,
meaning that we were getting garbage for the CPU number on 6xx/G3/G4
based SMP boxes in this code.
Just offset off the stack pointer (to get to thread_info) like all the
other references to TI_CPU do.
This was pointed out by Chen Gong <G.Chen@freescale.com>
[paulus@samba.org - use rlwinm r12,r11,... instead of
rlwinm r12,r1,...; tophys()]
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
HAVE_ARCH_UNMAPPED_AREA and HAVE_ARCH_UNMAPPED_AREA_TOPDOWN must
be defined whenever CONFIG_PPC_MM_SLICES is enabled, not just when
CONFIG_HUGETLB_PAGE is. They used to be always defined together but
this is no longer the case since 3a8247cc2c856930f34eafce33f6a039227ee175
("powerpc: Only demote individual slices rather than whole process").
This bug is causing random crashes
(http://bugzilla.kernel.org/show_bug.cgi?id=11414).
-fno-omit-frame-pointer is only needed on powerpc when -pg is also
supplied, and there is a gcc bug that causes incorrect code generation
on 32-bit powerpc when -fno-omit-frame-pointer is used---it uses stack
locations below the stack pointer, which is not allowed by the ABI
because those locations can and sometimes do get corrupted by an
interrupt.
This ensures that CONFIG_FRAME_POINTER is only selected by ftrace.
When CONFIG_FTRACE is enabled we also pass -mno-sched-epilog to work
around the gcc codegen bug.
Patch based on work by:
Andreas Schwab <schwab@suse.de>
Segher Boessenkool <segher@kernel.crashing.org>
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
This makes core_kernel_text() (and therefore kernel_text_address())
return the correct result. Currently all the __devinit routines (at
least) will not be considered to be kernel text.
This is just a quick fix for 2.6.27 - hopefully we will be able to fix
this better in 2.6.28.
Commit bc033b63bbfeb6c4b4eb0a1d083c650e4a0d2af8 ("powerpc/mm: Fix
attribute confusion with htab_bolt_mapping()") moved the check for
whether we should make pages of the linear mapping executable from
htab_bolt_mapping into its callers, including htab_initialize.
A side-effect of this is that the decision is now made once for
each contiguous section in the LMB array rather than for each page
individually. This can often mean that the whole of the linear
mapping ends up being executable.
This reverts to the previous behaviour, where individual pages are
checked for being part of the kernel text or not, by moving the check
back down into htab_bolt_mapping.
This fixes an uninitialised variable in the VSX alignment code. It can
cause warnings from GCC (noticed with gcc-4.1.1). Gcc is actually
correct in this instance, and this bug could cause the alignment
interrupt handler to send a SIGSEGV to the process on a legitimate
access.
Signed-off-by: Michael Neuling <mikey@neuling.org>
Andrew Morton reported a build failure on sparc32, because TIPC
uses names like "struct node" and there is a like named data
structure defined in linux/node.h
This just regexp replaces "struct node*" to "struct tipc_node*"
to avoid this and any future similar problems.
ipsec: Fix deadlock in xfrm_state management.
ipv: Re-enable IP when MTU > 68
net/xfrm: Use an IS_ERR test rather than a NULL test
ath9: Fix ath_rx_flush_tid() for IRQs disabled kernel warning message.
ath9k: Incorrect key used when group and pairwise ciphers are different.
rt2x00: Compiler warning unmasked by fix of BUILD_BUG_ON
mac80211: Fix debugfs union misuse and pointer corruption
wireless/libertas/if_cs.c: fix memory leaks
orinoco: Multicast to the specified addresses
iwlwifi: fix 64bit platform firmware loading
iwlwifi: fix apm_stop (wrong bit polarity for FLAG_INIT_DONE)
iwlwifi: workaround interrupt handling no some platforms
net/wireless/Kconfig: clarify the description for CONFIG_WIRELESS_EXT_SYSFS
net: Unbreak userspace usage of linux/mroute.h
pkt_sched: Fix locking of qdisc_root with qdisc_root_sleeping_lock()
ipv6: When we droped a packet, we should return NET_RX_DROP instead of 0
Larry Finger reported at http://lkml.org/lkml/2008/9/1/90:
An ancient laptop of mine started throwing errors from b43legacy when
I started using 2.6.27 on it. This has been bisected to commit bfc0f59
"x86: merge tsc calibration".
The unification of the TSC code adopted mostly the 64bit code, which
prefers PMTIMER/HPET over the PIT calibration.
Larrys system has an AMD K6 CPU. Such systems are known to have
PMTIMER incarnations which run at double speed. This results in a
miscalibration of the TSC by factor 0.5. So the resulting calibrated
CPU/TSC speed is half of the real CPU speed, which means that the TSC
based delay loop will run half the time it should run. That might
explain why the b43legacy driver went berserk.
On the other hand we know about systems, where the PIT based
calibration results in random crap due to heavy SMI/SMM
disturbance. On those systems the PMTIMER/HPET based calibration logic
with SMI detection shows better results.
According to Alok also virtualized systems suffer from the PIT
calibration method.
The solution is to use a more wreckage aware aproach than the current
either/or decision.
1) reimplement the retry loop which was dropped from the 32bit code
during the merge. It repeats the calibration and selects the lowest
frequency value as this is probably the closest estimate to the real
frequency
2) Monitor the delta of the TSC values in the delay loop which waits
for the PIT counter to reach zero. If the maximum value is
significantly different from the minimum, then we have a pretty safe
indicator that the loop was disturbed by an SMI.
3) keep the pmtimer/hpet reference as a backup solution for systems
where the SMI disturbance is a permanent point of failure for PIT
based calibration
4) do the loop iteration for both methods, record the lowest value and
decide after all iterations finished.
5) Set a clear preference to PIT based calibration when the result
makes sense.
The implementation does the reference calibration based on
HPET/PMTIMER around the delay, which is necessary for the PIT anyway,
but keeps separate TSC values to ensure the "independency" of the
resulting calibration values.
Tested on various 32bit/64bit machines including Geode 266Mhz, AMD K6
(affected machine with a double speed pmtimer which I grabbed out of
the dump), Pentium class machines and AMD/Intel 64 bit boxen.
Bisected-by: Larry Finger <Larry.Finger@lwfinger.net>
Ever since commit 4c563f7669c10a12354b72b518c2287ffc6ebfb3
("[XFRM]: Speed up xfrm_policy and xfrm_state walking") it is
illegal to call __xfrm_state_destroy (and thus xfrm_state_put())
with xfrm_state_lock held. If we do, we'll deadlock since we
have the lock already and __xfrm_state_destroy() tries to take
it again.
Fix this by pushing the xfrm_state_put() calls after the lock
is dropped.
Fix a bug reported by and diagnosed by Aaron Straus.
This is a regression intruduced into 2.6.26 by
commit adc782dae6c4c0f6fb679a48a544cfbcd79ae3dc
Author: Matt Mackall <mpm@selenic.com>
Date: Tue Apr 29 01:03:07 2008 -0700
random: simplify and rename credit_entropy_store
credit_entropy_bits() does:
spin_lock_irqsave(&r->lock, flags);
if (r->entropy_count > r->poolinfo->POOLBITS)
r->entropy_count = r->poolinfo->POOLBITS;
so there is a time window in which this BUG_ON():
static size_t account(struct entropy_store *r, size_t nbytes, int min,
int reserved)
unsigned long flags;
BUG_ON(r->entropy_count > r->poolinfo->POOLBITS);
/* Hold lock while accounting */
can trigger.
We could fix this by moving the assertion inside the lock, but it seems
safer and saner to revert to the old behaviour wherein
entropy_store.entropy_count at no time exceeds
entropy_store.poolinfo->POOLBITS.
Reported-by: Aaron Straus <aaron@merfinllc.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: <stable@kernel.org> [2.6.26.x]
Make PM_QOS and CPU_IDLE play nicer when run with the RT-Preempt kernel.
The purpose of the patch is to remove the spin_lock around the read in the
function pm_qos_requirement - since spinlocks can sleep in -rt and this
function is called from idle.
CPU_IDLE polls the target_value's of some of the pm_qos parameters from
the idle loop causing sleeping locking warnings. Changing the
target_value to an atomic avoids this issue.
Remove the spinlock in pm_qos_requirement by making target_value an atomic
type.
Signed-off-by: mark gross <mgross@linux.intel.com>
Signed-off-by: John Kacur <jkacur@gmail.com>
Update rtc-cmos shutdown handling to leave RTC alarms active, resolving
http://bugzilla.kernel.org/show_bug.cgi?id=11411 on several boards. There
are still some systems where the ACPI event handling doesn't cooperate.
(Possibly related to bugid 11312, reporting the spontaneous disabling of
RTC events.)
Bug 11411 reported that changes to work around some ACPI event issues
broke wake-from-S5 handling, as used for DVR applications. (They like to
power off, then wake later to record programs.)
[yakui.zhao@intel.com: add shutdown for PNP devices]
[dbrownell@users.sourceforge.net: update comments]
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Cc: Stefan Bauer <stefan.bauer@cs.tu-chemnitz.de>
Document files in /sys/firmware/sgi_uv/.
Signed-off-by: Russ Anderson <rja@sgi.com>
Cc: Jack Steiner <steiner@sgi.com>
I got this patch through Red Hat's bugzilla from the bug submitter and
patch creator. I have just fixed it up so it applies without fuzz to
upstream kernels.
Original patch and description from Shyam kumar Iyer:
The issue [ibft module not displaying targets with short names] is because
of an offset calculatation error in the iscsi_ibft.c code. Due to this
error directory structure for the target in /sys/firmware/ibft does not
get created and so the initiator is unable to connect to the target.
Note that this bug surfaced only with an name that had a short section at
the end. eg: "iqn.1984-05.com.dell:dell". It did not surface when the
iqn's had a longer section at the end. eg:
"iqn.2001-04.com.example:storage.disk2.sys1.xyz"
So, the eot_offset was calculated such that an extra 48 bytes i.e. the
size of the ibft_header which has already been accounted was subtracted
twice.
This was not evident with longer iqn names because they would overshoot
the total ibft length more than 48 bytes and thus would escape the bug.
Signed-off-by: Shyam Kumar Iyer <shyam_iyer@dell.com>
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Cc: Konrad Rzeszutek <konrad@virtualiron.com>
Cc: Peter Jones <pjones@redhat.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
commit 945185a69daa457c4c5e46e47f4afad7dcea734f ("rtc: rtc_time_to_tm: use
unsigned arithmetic") changed the some types in rtc_time_to_tm() to
unsigned:
void rtc_time_to_tm(unsigned long time, struct rtc_time *tm)
- register int days, month, year;
+ unsigned int days, month, year;
This doesn't work for all cases, because days is checked for < 0 later
on:
if (days < 0) {
year -= 1;
days += 365 + LEAP_YEAR(year);
I think the correct fix would be to keep days signed and do an appropriate
cast later on.
Signed-off-by: Jan Altenberg <jan.altenberg@linutronix.de>
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
Cc: Dmitri Vorobiev <dmitri.vorobiev@gmail.com>
If there are more then one graphics card handled by the tdfxfb driver the
name of the frame buffer overruns reserved size.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Fix memory detection on Voodoo3 cards with SDRAM memory.
