2013-03-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull userns fixes from Eric W Biederman: "The bulk of the changes are fixing the worst consequences of the user namespace design oversight in not considering what happens when one namespace starts off as a clone of another namespace, as happens with the mount namespace. The rest of the changes are just plain bug fixes. Many thanks to Andy Lutomirski for pointing out many of these issues." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: userns: Restrict when proc and sysfs can be mounted ipc: Restrict mounting the mqueue filesystem vfs: Carefully propogate mounts across user namespaces vfs: Add a mount flag to lock read only bind mounts userns: Don't allow creation if the user is chrooted yama: Better permission check for ptraceme pid: Handle the exit of a multi-threaded init. scm: Require CAP_SYS_ADMIN over the current pidns to spoof pids.
2013-03-27Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sfr/next-fixes Pull powerpc build fixes from Stephen Rothwell: "Just a couple of build fixes for powerpc all{mod,yes}config. Submitted by me since BenH is on vacation." * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sfr/next-fixes: powerpc: define the conditions where the ePAPR idle hcall can be supported powerpc: make additional room in exception vector area
2013-03-27Merge tag 'stable/for-linus-3.9-rc4-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen bug-fixes from Konrad Rzeszutek Wilk: "This is mostly just the last stragglers of the regression bugs that this merge window had. There are also two bug-fixes: one that adds an extra layer of security, and a regression fix for a change that was added in v3.7 (the v1 was faulty, the v2 works). - Regression fixes for C-and-P states not being parsed properly. - Fix possible security issue with guests triggering DoS via non-assigned MSI-Xs. - Fix regression (introduced in v3.7) with raising an event (v2). - Fix hastily introduced band-aid during c0 for the CR3 blowup." * tag 'stable/for-linus-3.9-rc4-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/events: avoid race with raising an event in unmask_evtchn() xen/mmu: Move the setting of pvops.write_cr3 to later phase in bootup. xen/acpi-stub: Disable it b/c the acpi_processor_add is no longer called. xen-pciback: notify hypervisor about devices intended to be assigned to guests xen/acpi-processor: Don't dereference struct acpi_processor on all CPUs.
2013-03-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID fixes from Jiri Kosina: - fix for potential 3.9 regression in handling of buttons for touchpads following HID mt specification; potential because reportedly there is no retail product on the market that would be using this feature, but nevertheless we'd better follow the spec. Fix by Benjamin Tissoires. - support for two quirky devices added by Josh Boyer. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: multitouch: fix touchpad buttons HID: usbhid: fix build problem HID: usbhid: quirk for MSI GX680R led panel HID: usbhid: quirk for Realtek Multi-card reader
2013-03-27Merge tag 'iommu-fixes-v3.9-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU fixes from Joerg Roedel: "Here are some fixes which have collected since Linux v3.9-rc1. The most important one fixes a long-standing regressen which make re-hotplugged devices unusable when AMD IOMMU is used. The other patches fix build issues (build regression on OMAP and a section mismatch). One patch just removes a duplicate header include." * tag 'iommu-fixes-v3.9-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: iommu/amd: Make sure dma_ops are set for hotplug devices x86, io_apic: remove duplicated include from irq_remapping.c iommu: OMAP: build only on OMAP2+ amd_iommu_init: remove __init from amd_iommu_erratum_746_workaround
2013-03-27vfs/splice: Fix missed checks in new __kernel_write() helperAl Viro
Commit 06ae43f34bcc ("Don't bother with redoing rw_verify_area() from default_file_splice_from()") lost the checks to test existence of the write/aio_write methods. My apologies ;-/ Eventually, we want that in fs/splice.c side of things (no point repeating it for every buffer, after all), but for now this is the obvious minimal fix. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-27xen/events: avoid race with raising an event in unmask_evtchn()David Vrabel
In unmask_evtchn(), when the mask bit is cleared after testing for pending and the event becomes pending between the test and clear, then the upcall will not become pending and the event may be lost or delayed. Avoid this by always clearing the mask bit before checking for pending. If a hypercall is needed, remask the event as EVTCHNOP_unmask will only retrigger pending events if they were masked. This fixes a regression introduced in 3.7 by b5e579232d635b79a3da052964cb357ccda8d9ea (xen/events: fix unmask_evtchn for PV on HVM guests) which reordered the clear mask and check pending operations. Changes in v2: - set mask before hypercall. Cc: stable@vger.kernel.org Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-03-27xen/mmu: Move the setting of pvops.write_cr3 to later phase in bootup.Konrad Rzeszutek Wilk
We move the setting of write_cr3 from the early bootup variant (see git commit 0cc9129d75ef8993702d97ab0e49542c15ac6ab9 "x86-64, xen, mmu: Provide an early version of write_cr3.") to a more appropiate location. This new location sets all of the other non-early variants of pvops calls - and most importantly is before the alternative_asm mechanism kicks in. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-03-27xen/acpi-stub: Disable it b/c the acpi_processor_add is no longer called.Konrad Rzeszutek Wilk
With the Xen ACPI stub code (CONFIG_XEN_STUB=y) enabled, the power C and P states are no longer uploaded to the hypervisor. The reason is that the Xen CPU hotplug code: xen-acpi-cpuhotplug.c and the xen-acpi-stub.c register themselves as the "processor" type object. That means the generic processor (processor_driver.c) stops working and it does not call (acpi_processor_add) which populates the per_cpu(processors, pr->id) = pr; structure. The 'pr' is gathered from the acpi_processor_get_info function which does the job of finding the C-states and figuring out PBLK address. The 'processors->pr' is then later used by xen-acpi-processor.c (the one that uploads C and P states to the hypervisor). Since it is NULL, we end skip the gathering of _PSD, _PSS, _PCT, etc and never upload the power management data. The end result is that enabling the CONFIG_XEN_STUB in the build means that xen-acpi-processor is not working anymore. This temporary patch fixes it by marking the XEN_STUB driver as BROKEN until this can be properly fixed. CC: jinsong.liu@intel.com Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2013-03-27userns: Restrict when proc and sysfs can be mountedEric W. Biederman
Only allow unprivileged mounts of proc and sysfs if they are already mounted when the user namespace is created. proc and sysfs are interesting because they have content that is per namespace, and so fresh mounts are needed when new namespaces are created while at the same time proc and sysfs have content that is shared between every instance. Respect the policy of who may see the shared content of proc and sysfs by only allowing new mounts if there was an existing mount at the time the user namespace was created. In practice there are only two interesting cases: proc and sysfs are mounted at their usual places, proc and sysfs are not mounted at all (some form of mount namespace jail). Cc: stable@vger.kernel.org Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-27ipc: Restrict mounting the mqueue filesystemEric W. Biederman
Only allow mounting the mqueue filesystem if the caller has CAP_SYS_ADMIN rights over the ipc namespace. The principle here is if you create or have capabilities over it you can mount it, otherwise you get to live with what other people have mounted. This information is not particularly sensitive and mqueue essentially only reports which posix messages queues exist. Still when creating a restricted environment for an application to live any extra information may be of use to someone with sufficient creativity. The historical if imperfect way this information has been restricted has been not to allow mounts and restricting this to ipc namespace creators maintains the spirit of the historical restriction. Cc: stable@vger.kernel.org Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-27vfs: Carefully propogate mounts across user namespacesEric W. Biederman
As a matter of policy MNT_READONLY should not be changable if the original mounter had more privileges than creator of the mount namespace. Add the flag CL_UNPRIVILEGED to note when we are copying a mount from a mount namespace that requires more privileges to a mount namespace that requires fewer privileges. When the CL_UNPRIVILEGED flag is set cause clone_mnt to set MNT_NO_REMOUNT if any of the mnt flags that should never be changed are set. This protects both mount propagation and the initial creation of a less privileged mount namespace. Cc: stable@vger.kernel.org Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-27vfs: Add a mount flag to lock read only bind mountsEric W. Biederman
When a read-only bind mount is copied from mount namespace in a higher privileged user namespace to a mount namespace in a lesser privileged user namespace, it should not be possible to remove the the read-only restriction. Add a MNT_LOCK_READONLY mount flag to indicate that a mount must remain read-only. CC: stable@vger.kernel.org Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-27userns: Don't allow creation if the user is chrootedEric W. Biederman
Guarantee that the policy of which files may be access that is established by setting the root directory will not be violated by user namespaces by verifying that the root directory points to the root of the mount namespace at the time of user namespace creation. Changing the root is a privileged operation, and as a matter of policy it serves to limit unprivileged processes to files below the current root directory. For reasons of simplicity and comprehensibility the privilege to change the root directory is gated solely on the CAP_SYS_CHROOT capability in the user namespace. Therefore when creating a user namespace we must ensure that the policy of which files may be access can not be violated by changing the root directory. Anyone who runs a processes in a chroot and would like to use user namespace can setup the same view of filesystems with a mount namespace instead. With this result that this is not a practical limitation for using user namespaces. Cc: stable@vger.kernel.org Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-27HID: multitouch: fix touchpad buttonsBenjamin Tissoires
Commit "HID: multitouch: use the callback "report" instead..." breaks the buttons of touchpads following the HID multitouch specification. The buttons were emmitted through hid-input, but as now the events are generated only in hid-multitouch, the buttons are not emmitted anymore. The input_event() call is far much simpler than the hid-input one as many of the different tests do not apply to multitouch touchpads. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-03-27iommu/amd: Make sure dma_ops are set for hotplug devicesJoerg Roedel
There is a bug introduced with commit 27c2127 that causes devices which are hot unplugged and then hot-replugged to not have per-device dma_ops set. This causes these devices to not function correctly. Fixed with this patch. Cc: stable@vger.kernel.org Reported-by: Andreas Degert <andreas.degert@googlemail.com> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-03-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "stable fodder; assorted deadlock fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vt: synchronize_rcu() under spinlock is not nice... Nest rename_lock inside vfsmount_lock Don't bother with redoing rw_verify_area() from default_file_splice_from()
2013-03-26vt: synchronize_rcu() under spinlock is not nice...Al Viro
vcs_poll_data_free() calls unregister_vt_notifier(), which calls atomic_notifier_chain_unregister(), which calls synchronize_rcu(). Do it *after* we'd dropped ->f_lock. Cc: stable@vger.kernel.org (all kernels since 2.6.37) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-03-26Nest rename_lock inside vfsmount_lockAl Viro
... lest we get livelocks between path_is_under() and d_path() and friends. The thing is, wrt fairness lglocks are more similar to rwsems than to rwlocks; it is possible to have thread B spin on attempt to take lock shared while thread A is already holding it shared, if B is on lower-numbered CPU than A and there's a thread C spinning on attempt to take the same lock exclusive. As the result, we need consistent ordering between vfsmount_lock (lglock) and rename_lock (seq_lock), even though everything that takes both is going to take vfsmount_lock only shared. Spotted-by: Brad Spengler <spender@grsecurity.net> Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Always increment IPV4 ID field in encapsulated GSO packets, even when DF is set. Regression fix from Pravin B Shelar. 2) Fix per-net subsystem initialization in netfilter conntrack, otherwise we may access dynamically allocated memory before it is actually allocated. From Gao Feng. 3) Fix DMA buffer lengths in iwl3945 driver, from Stanislaw Gruszka. 4) Fix race between submission of sync vs async commands in mwifiex driver, from Amitkumar Karwar. 5) Add missing cancel of command timer in mwifiex driver, from Bing Zhao. 6) Missing SKB free in rtlwifi USB driver, from Jussi Kivilinna. 7) Thermal layer tries to use a genetlink multicast string that is longer than the 16 character limit. Fix it and add a BUG check to prevent this kind of thing from happening in the future. From Masatake YAMATO. 8) Fix many bugs in the handling of the teardown of L2TP connections, UDP encapsulation instances, and sockets. From Tom Parkin. 9) Missing socket release in IRDA, from Kees Cook. 10) Fix fec driver modular build, from Fabio Estevam. 11) Erroneous use of kfree() instead of free_netdev() in lantiq_etop, from Wei Yongjun. 12) Fix bugs in handling of queue numbers and steering rules in mlx4 driver, from Moshe Lazer, Hadar Hen Zion, and Or Gerlitz. 13) Some FOO_DIAG_MAX constants were defined off by one, fix from Andrey Vagin. 14) TCP segmentation deferral is unintentionally done too strongly, breaking ACK clocking. Fix from Eric Dumazet. 15) net_enable_timestamp() can legitimately be invoked from software interrupts, and in a way that is safe, so remove the WARN_ON(). Also from Eric Dumazet. 16) Fix use after free in VLANs, from Cong Wang. 17) Fix TCP slow start retransmit storms after SACK reneging, from Yuchung Cheng. 18) Unix socket release should mark a socket dead before NULL'ing out sock->sk, otherwise we can race. Fix from Paul Moore. 19) IPV6 addrconf code can try to free static memory, from Hong Zhiguo. 20) Fix register mis-programming, NULL pointer derefs, and wrong PHC clock frequency in IGB driver. From Lior LevyAlex Williamson, Jiri Benc, and Jeff Kirsher. 21) skb->ip_summed logic in pch_gbe driver is reversed, breaking packet forwarding. Fix from Veaceslav Falico. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (65 commits) ipv4: Fix ip-header identification for gso packets. bonding: remove already created master sysfs link on failure af_unix: dont send SCM_CREDENTIAL when dest socket is NULL pch_gbe: fix ip_summed checksum reporting on rx igb: fix PHC stopping on max freq igb: make sensor info static igb: SR-IOV init reordering igb: Fix null pointer dereference igb: fix i350 anti spoofing config ixgbevf: don't release the soft entries ipv6: fix bad free of addrconf_init_net unix: fix a race condition in unix_release() tcp: undo spurious timeout after SACK reneging bnx2x: fix assignment of signed expression to unsigned variable bridge: fix crash when set mac address of br interface 8021q: fix a potential use-after-free net: remove a WARN_ON() in net_enable_timestamp() tcp: preserve ACK clocking in TSO net: fix *_DIAG_MAX constants net/mlx4_core: Disallow releasing VF QPs which have steering rules ...
2013-03-26Merge tag 'nfs-for-3.9-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: - Fix an NFSv4 idmapper regression - Fix an Oops in the pNFS blocks client - Fix up various issues with pNFS layoutcommit - Ensure correct read ordering of variables in rpc_wake_up_task_queue_locked * tag 'nfs-for-3.9-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: SUNRPC: Add barriers to ensure read ordering in rpc_wake_up_task_queue_locked NFSv4.1: Add a helper pnfs_commit_and_return_layout NFSv4.1: Always clear the NFS_INO_LAYOUTCOMMIT in layoutreturn NFSv4.1: Fix a race in pNFS layoutcommit pnfs-block: removing DM device maybe cause oops when call dev_remove NFSv4: Fix the string length returned by the idmapper
2013-03-26yama: Better permission check for ptracemeEric W. Biederman
Change the permission check for yama_ptrace_ptracee to the standard ptrace permission check, testing if the traceer has CAP_SYS_PTRACE in the tracees user namespace. Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-26ipv4: Fix ip-header identification for gso packets.Pravin B Shelar
ip-header id needs to be incremented even if IP_DF flag is set. This behaviour was changed in commit 490ab08127cebc25e3a26 (IP_GRE: Fix IP-Identification). Following patch fixes it so that identification is always incremented. Reported-by: Cong Wang <amwang@redhat.com> Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26bonding: remove already created master sysfs link on failureVeaceslav Falico
If slave sysfs symlink failes to be created - we end up without removing the master sysfs symlink. Remove it in case of failure. Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26af_unix: dont send SCM_CREDENTIAL when dest socket is NULLdingtianhong
SCM_SCREDENTIALS should apply to write() syscalls only either source or destination socket asserted SOCK_PASSCRED. The original implememtation in maybe_add_creds is wrong, and breaks several LSB testcases ( i.e. /tset/LSB.os/netowkr/recvfrom/T.recvfrom). Origionally-authored-by: Karel Srot <ksrot@redhat.com> Signed-off-by: Ding Tianhong <dingtianhong@huawei.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/net Jeff Kirsher says: ==================== This series contains updates to ixgbevf and igb. The ixgbevf calls to pci_disable_msix() and to free the msix_entries memory should not occur if device open fails. Instead they should be called during device driver removal to balance with the call to pci_enable_msix() and the call to allocate msix_entries memory during the device probe and driver load. The remaining 4 of 5 igb patches are simple 1-3 line patches to fix several issues such as possible null pointer dereference, PHC stopping on max frequency, make sensor info static and SR-IOV initialization reordering. The remaining igb patch to fix anti-spoofing config fixes a problem in i350 where anti spoofing configuration was written into a wrong register. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26pch_gbe: fix ip_summed checksum reporting on rxVeaceslav Falico
skb->ip_summed should be CHECKSUM_UNNECESSARY when the driver reports that checksums were correct and CHECKSUM_NONE in any other case. They're currently placed vice versa, which breaks the forwarding scenario. Fix it by placing them as described above. Signed-off-by: Veaceslav Falico <vfalico@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-26x86, io_apic: remove duplicated include from irq_remapping.cWei Yongjun
Remove duplicated include. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Joerg Roedel <joro@8bytes.org>
2013-03-26pid: Handle the exit of a multi-threaded init.Eric W. Biederman
When a multi-threaded init exits and the initial thread is not the last thread to exit the initial thread hangs around as a zombie until the last thread exits. In that case zap_pid_ns_processes needs to wait until there are only 2 hashed pids in the pid namespace not one. v2. Replace thread_pid_vnr(me) == 1 with the test thread_group_leader(me) as suggested by Oleg. Cc: stable@vger.kernel.org Cc: Oleg Nesterov <oleg@redhat.com> Reported-by: Caj Larsson <caj@omnicloud.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-26igb: fix PHC stopping on max freqJiri Benc
For 82576 MAC type, max_adj is reported as 1000000000 ppb. However, if this value is passed to igb_ptp_adjfreq_82576, incvalue overflows out of INCVALUE_82576_MASK, resulting in setting of zero TIMINCA.incvalue, stopping the PHC (instead of going at twice the nominal speed). Fix the advertised max_adj value to the largest value hardware can handle. As there is no min_adj value available (-max_adj is used instead), this will also prevent stopping the clock intentionally. It's probably not a big deal, other igb MAC types don't support stopping the clock, either. Signed-off-by: Jiri Benc <jbenc@redhat.com> Acked-by: Matthew Vick <matthew.vick@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2013-03-26igb: make sensor info staticStephen Hemminger
Trivial sparse warning. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2013-03-26igb: SR-IOV init reorderingAlex Williamson
igb is ineffective at setting a lower total VFs because: int pci_sriov_set_totalvfs(struct pci_dev *dev, u16 numvfs) { ... /* Shouldn't change if VFs already enabled */ if (dev->sriov->ctrl & PCI_SRIOV_CTRL_VFE) return -EBUSY; Swap init ordering. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Greg Rose <gregory.v.rose@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2013-03-26igb: Fix null pointer dereferenceAlex Williamson
The max_vfs= option has always been self limiting to the number of VFs supported by the device. fa44f2f1 added SR-IOV configuration via sysfs, but in the process broke this self correction factor. The failing path is: igb_probe igb_sw_init if (max_vfs > 7) { adapter->vfs_allocated_count = 7; ... igb_probe_vfs igb_enable_sriov(, max_vfs) if (num_vfs > 7) { err = -EPERM; ... This leaves vfs_allocated_count = 7 and vf_data = NULL, so we bomb out when igb_probe finally calls igb_reset. It seems like a really bad idea, and somewhat pointless, to set vfs_allocated_count separate from vf_data, but limiting max_vfs is enough to avoid the null pointer. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Greg Rose <gregory.v.rose@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2013-03-26igb: fix i350 anti spoofing configLior Levy
Fix a problem in i350 where anti spoofing configuration was written into a wrong register. Signed-off-by: Lior Levy <lior.levy@intel.com> Tested-by: Aaron Brown <aaron.f.brown@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2013-03-26ixgbevf: don't release the soft entriesxunleer
When the ixgbevf driver is opened the request to allocate MSIX irq vectors may fail. In that case the driver will call ixgbevf_down() which will call ixgbevf_irq_disable() to clear the HW interrupt registers and calls synchronize_irq() using the msix_entries pointer in the adapter structure. However, when the function to request the MSIX irq vectors failed it had already freed the msix_entries which causes an OOPs from using the NULL pointer in synchronize_irq(). The calls to pci_disable_msix() and to free the msix_entries memory should not occur if device open fails. Instead they should be called during device driver removal to balance with the call to pci_enable_msix() and the call to allocate msix_entries memory during the device probe and driver load. Signed-off-by: Li Xun <xunleer.li@huawei.com> Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Tested-by: Sibai Li <sibai.li@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2013-03-25Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fix from Thomas Gleixner: "A single bugfix which prevents that a non functional timer device is selected to provide the fallback device, which is supposed to serve timer interrupts on behalf of non functional devices ..." * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: clockevents: Don't allow dummy broadcast timers
2013-03-26powerpc: define the conditions where the ePAPR idle hcall can be supportedStuart Yoder
For 32-bit, CONFIG_EPAPR_PARAVIRT pulls in both epapr_paravirt.c and epapr_hcalls.c which contains the 32-bit paravirt idle loop. For 64-bit, the paravirt idle loop is in idle_book3e.S and that source file is included only if CONFIG_PPC_BOOK3E_64 defined. This patch makes that dependency for 64-bit explicit. Fixes these build errors: arch/powerpc/kernel/built-in.o: In function `restore_pblist_ptr': ftrace.c:(.toc+0xdc0): undefined reference to `epapr_ev_idle_start' ftrace.c:(.toc+0xdd0): undefined reference to `epapr_ev_idle' Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2013-03-25ipv6: fix bad free of addrconf_init_netHong Zhiguo
Signed-off-by: Hong Zhiguo <honkiko@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-25unix: fix a race condition in unix_release()Paul Moore
As reported by Jan, and others over the past few years, there is a race condition caused by unix_release setting the sock->sk pointer to NULL before properly marking the socket as dead/orphaned. This can cause a problem with the LSM hook security_unix_may_send() if there is another socket attempting to write to this partially released socket in between when sock->sk is set to NULL and it is marked as dead/orphaned. This patch fixes this by only setting sock->sk to NULL after the socket has been marked as dead; I also take the opportunity to make unix_release_sock() a void function as it only ever returned 0/success. Dave, I think this one should go on the -stable pile. Special thanks to Jan for coming up with a reproducer for this problem. Reported-by: Jan Stancek <jan.stancek@gmail.com> Signed-off-by: Paul Moore <pmoore@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-25Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Pull infiniband/rdma fixes from Roland Dreier: "Small batch of InfiniBand/RDMA fixes for 3.9: - Fix for TX lockup in IPoIB - QLogic -> Intel update for qib driver - Small static checker fix for qib - Fix error path return value in cxgb4" * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/qib: change QLogic to Intel IB/ipath: Silence a static checker warning IPoIB: Fix send lockup due to missed TX completion RDMA/cxgb4: Fix error return code in create_qp()
2013-03-25Merge tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull ARM SoC bug fixes from Arnd Bergmann: "Four patches for arm-soc this week: - Kevin Hilman is no longer reachable under his previous email address. He submitted the patch earlier, but nobody felt responsible to pick it up. - One Tegra fix for an incorect register address in device tree. - IMX multiplatform support exposes a configuration option that leads to unbootable kernels on all other machines and that needs to depend on that platform. - A nontrivial bug fix for the setup of the mxs video output." * tag 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: MAINTAINERS: update email address for Kevin Hilman ARM: tegra: fix register address of slink controller ARM: imx: add dependency check for DEBUG_IMX_UART_PORT ARM: video: mxs: Fix mxsfb misconfiguring VDCTRL0
2013-03-25Merge branch 'for-3.9' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd bugfixes from J Bruce Fields: "Fixes for a couple mistakes in the new DRC code. And thanks to Kent Overstreet for noticing we've been sync'ing the wrong range on stable writes since 3.8." * 'for-3.9' of git://linux-nfs.org/~bfields/linux: nfsd: fix bad offset use nfsd: fix startup order in nfsd_reply_cache_init nfsd: only unhash DRC entries that are in the hashtable
2013-03-25SUNRPC: Add barriers to ensure read ordering in rpc_wake_up_task_queue_lockedTrond Myklebust
We need to be careful when testing task->tk_waitqueue in rpc_wake_up_task_queue_locked, because it can be changed while we are holding the queue->lock. By adding appropriate memory barriers, we can ensure that it is safe to test task->tk_waitqueue for equality if the RPC_TASK_QUEUED bit is set. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: stable@vger.kernel.org
2013-03-25Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Exynos and Intel fixes. The intel fixes are fairly straightforward, mostly reverts due to bugs found. The exynos one is a big larger since they found some issues with the G2D engine and iommu interaction, and needed to verify the operations a lot better than they were previously, otherwise a user app can just crash the kernel with an iommu fault." * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: Revert "drm/i915: write backlight harder" drm/i915: don't disable the power well yet Revert "drm/i915: set TRANSCODER_EDP even earlier" drm/exynos: Check g2d cmd list for g2d restrictions drm/exynos: Add a new function to get gem buffer size drm/exynos: Deal with g2d buffer info more efficiently drm/exynos: Clean up some G2D codes for readability drm/exynos: Fix G2D core malfunctioning issue drm/exynos: clear node object type at gem unmap drm/exynos: Fix error routine to getting dma addr. drm/exynos: Replaced kzalloc & memcpy with kmemdup drm/exynos: fimd: calculate the correct address offset drm/exynos: Make mixer_check_timing static drm/exynos: modify the compatible string for exynos fimd
2013-03-25powerpc: make additional room in exception vector areaChen Gang
The FWNMI region is fixed at 0x7000 and the vector are now overflowing that with allmodconfig. Fix that by moving slb_miss_realmode code out of that region as it doesn't need to be that close to the call sites (it is a _GLOBAL function) Fixes this build error: arch/powerpc/kernel/exceptions-64s.S: Assembler messages: arch/powerpc/kernel/exceptions-64s.S:1304: Error: attempt to move .org backwards Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au>
2013-03-25Merge branch 'drm-intel-fixes' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into HEAD Daniel writes: "Just three revert/disable by default patches, one of them cc: stable (since the offending commit was cc: stable, too)." * 'drm-intel-fixes' of git://people.freedesktop.org/~danvet/drm-intel: Revert "drm/i915: write backlight harder" drm/i915: don't disable the power well yet Revert "drm/i915: set TRANSCODER_EDP even earlier"
2013-03-25Merge branch 'exynos-drm-fixes' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into HEAD Inki writes: Includes bug fixes and code cleanups. And it considers some restrictions to G2D hardware. With this, the malfunction and page fault issues to g2d driver would be fixed. * 'exynos-drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos: drm/exynos: Check g2d cmd list for g2d restrictions drm/exynos: Add a new function to get gem buffer size drm/exynos: Deal with g2d buffer info more efficiently drm/exynos: Clean up some G2D codes for readability drm/exynos: Fix G2D core malfunctioning issue drm/exynos: clear node object type at gem unmap drm/exynos: Fix error routine to getting dma addr. drm/exynos: Replaced kzalloc & memcpy with kmemdup drm/exynos: fimd: calculate the correct address offset drm/exynos: Make mixer_check_timing static drm/exynos: modify the compatible string for exynos fimd
2013-03-24tcp: undo spurious timeout after SACK renegingYuchung Cheng
On SACK reneging the sender immediately retransmits and forces a timeout but disables Eifel (undo). If the (buggy) receiver does not drop any packet this can trigger a false slow-start retransmit storm driven by the ACKs of the original packets. This can be detected with undo and TCP timestamps. Signed-off-by: Yuchung Cheng <ycheng@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-24bnx2x: fix assignment of signed expression to unsigned variableKumar Amit Mehta
fix for incorrect assignment of signed expression to unsigned variable. Signed-off-by: Kumar Amit Mehta <gmate.amit@gmail.com> Acked-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-24bridge: fix crash when set mac address of br interfaceHong zhi guo
When I tried to set mac address of a bridge interface to a mac address which already learned on this bridge, I got system hang. The cause is straight forward: function br_fdb_change_mac_address calls fdb_insert with NULL source nbp. Then an fdb lookup is performed. If an fdb entry is found and it's local, it's OK. But if it's not local, source is dereferenced for printk without NULL check. Signed-off-by: Hong Zhiguo <honkiko@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
