Including linux/jiffies.h was required for calling srandom32(jiffies)
that has already been removed.
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
JFFS2 was designed without thought for OOB bitflips, it seems, but they
can occur and will be reported to JFFS2 via mtd_read_oob()[1]. We don't
want to fail on these transactions, since the data was corrected.
[1] Few drivers report bitflips for OOB-only transactions. With such
drivers, this patch should have no effect.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
Cc: stable@vger.kernel.org
devm free functions should not have to be explicitly used.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Clean-up the driver a bit to make it easier to read and amend the coding style.
Mostly these are changes like:
if (a)
if (a) {
Some extra blank lines were added.
Indentation was changed to use tabs instead of spaces.
This patch revises and fixes error handling in the command line mtd
partitions parser. Namely:
1. we ignored return code of 'mtdpart_setup_real()'.
2. instead of returning 0 for failure and 1 for success, teach
'mtdpart_setup_real()' to return real error codes.
This driver provides parser detecting partitions on BCM47XX flash
memories. It has many differences in comparison to BCM63XX, like:
1) Different CFE with no more trivial MAGICs
2) More partitions types (board_data, ML, POT)
3) Supporting more than 1 flash on a device
which resulted in decision of writing new parser.
It uses generic mtd interface and was successfully tested with Netgear
WNDR4500 router which has 2 flash memories: serial one and NAND one.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
We do not have to initialize variables for .bss to 0 in Linux.
Unloading the omap2 nand driver missed to release the memory region which will
result in not being able to request it again if one want to load the driver
later on.
This patch fixes following error when loading omap2 module after unloading:
---8<---
~ $ rmmod omap2
~ $ modprobe omap2
[ 37.420928] omap2-nand: probe of omap2-nand.0 failed with error -16
--->8---
This error was introduced in 67ce04bf2746f8a1f8c2a104b313d20c63f68378 which
was the first commit of this driver.
Signed-off-by: Andreas Bießmann <andreas@biessmann.de>
Do not kfree() the mtd_info; it is handled in the mtd subsystem and
already freed by nand_release(). Instead kfree() the struct
omap_nand_info allocated in omap_nand_probe which was not freed before.
This patch fixes following error when unloading the omap2 module:
---8<---
~ $ rmmod omap2
kernel BUG at mm/slab.c:3126!
Internal error: Oops - BUG: 0 [#1] PREEMPT ARM
Modules linked in: omap2(-)
CPU: 0 Not tainted (3.6.0-rc3-00230-g155e36d-dirty #3)
PC is at cache_free_debugcheck+0x2d4/0x36c
LR is at kfree+0xc8/0x2ac
pc : [<c01125a0>] lr : [<c0112efc>] psr: 200d0193
sp : c521fe08 ip : c0e8ef90 fp : c521fe5c
r10: bf0001fc r9 : c521e000 r8 : c0d99c8c
r7 : c661ebc0 r6 : c065d5a4 r5 : c65c4060 r4 : c78005c0
r3 : 00000000 r2 : 00001000 r1 : c65c4000 r0 : 00000001
Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5387d Table: 86694019 DAC: 00000015
Process rmmod (pid: 549, stack limit = 0xc521e2f0)
Stack: (0xc521fe08 to 0xc5220000)
fe00: c008a874 c00bf44c c515c6d0 200d0193 c65c4860 c515c240
fe20: c521fe3c c521fe30 c008a9c0 c008a854 c521fe5c c65c4860 c78005c0 bf0001fc
fe40: c780ff40 a00d0113 c521e000 00000000 c521fe84 c521fe60 c0112efc c01122d8
fe60: c65c4860 c0673778 c06737ac 00000000 00070013 00000000 c521fe9c c521fe88
fe80: bf0001fc c0112e40 c0673778 bf001ca8 c521feac c521fea0 c02ca11c bf0001ac
fea0: c521fec4 c521feb0 c02c82c4 c02ca100 c0673778 bf001ca8 c521fee4 c521fec8
fec0: c02c8dd8 c02c8250 00000000 bf001ca8 bf001ca8 c0804ee0 c521ff04 c521fee8
fee0: c02c804c c02c8d20 bf001924 00000000 bf001ca8 c521e000 c521ff1c c521ff08
ff00: c02c950c c02c7fbc bf001d48 00000000 c521ff2c c521ff20 c02ca3a4 c02c94b8
ff20: c521ff3c c521ff30 bf001938 c02ca394 c521ffa4 c521ff40 c009beb4 bf001930
ff40: c521ff6c 70616d6f b6fe0032 c0014f84 70616d6f b6fe0032 00000081 60070010
ff60: c521ff84 c521ff70 c008e1f4 c00bf328 0001a004 70616d6f c521ff94 0021ff88
ff80: c008e368 0001a004 70616d6f b6fe0032 00000081 c0015028 00000000 c521ffa8
ffa0: c0014dc0 c009bcd0 0001a004 70616d6f bec2ab38 00000880 bec2ab38 00000880
ffc0: 0001a004 70616d6f b6fe0032 00000081 00000319 00000000 b6fe1000 00000000
ffe0: bec2ab30 bec2ab20 00019f00 b6f539c0 60070010 bec2ab38 aaaaaaaa aaaaaaaa
Backtrace:
[<c01122cc>] (cache_free_debugcheck+0x0/0x36c) from [<c0112efc>] (kfree+0xc8/0x2ac)
[<c0112e34>] (kfree+0x0/0x2ac) from [<bf0001fc>] (omap_nand_remove+0x5c/0x64 [omap2])
[<bf0001a0>] (omap_nand_remove+0x0/0x64 [omap2]) from [<c02ca11c>] (platform_drv_remove+0x28/0x2c)
r5:bf001ca8 r4:c0673778
[<c02ca0f4>] (platform_drv_remove+0x0/0x2c) from [<c02c82c4>] (__device_release_driver+0x80/0xdc)
[<c02c8244>] (__device_release_driver+0x0/0xdc) from [<c02c8dd8>] (driver_detach+0xc4/0xc8)
[<c02c8d14>] (driver_detach+0x0/0xc8) from [<c02c804c>] (bus_remove_driver+0x9c/0x104)
r6:c0804ee0 r5:bf001ca8 r4:bf001ca8 r3:00000000
[<c02c7fb0>] (bus_remove_driver+0x0/0x104) from [<c02c950c>] (driver_unregister+0x60/0x80)
r6:c521e000 r5:bf001ca8 r4:00000000 r3:bf001924
[<c02c94ac>] (driver_unregister+0x0/0x80) from [<c02ca3a4>] (platform_driver_unregister+0x1c/0x20)
r5:00000000 r4:bf001d48
[<c02ca388>] (platform_driver_unregister+0x0/0x20) from [<bf001938>] (omap_nand_driver_exit+0x14/0x1c [omap2])
[<bf001924>] (omap_nand_driver_exit+0x0/0x1c [omap2]) from [<c009beb4>] (sys_delete_module+0x1f0/0x2ec)
[<c009bcc4>] (sys_delete_module+0x0/0x2ec) from [<c0014dc0>] (ret_fast_syscall+0x0/0x48)
r8:c0015028 r7:00000081 r6:b6fe0032 r5:70616d6f r4:0001a004
Code: e1a00005 eb0d9172 e7f001f2 e7f001f2 (e7f001f2)
---[ end trace 6a30b24d8c0cc2ee ]---
Segmentation fault
--->8---
Unlocking may take up to 1.4 seconds on some Intel flashes. So
lets use a max. of 1.5 seconds (1500ms) as timeout.
See "Clear Block Lock-Bits Time" on page 40 in
"3 Volt Intel StrataFlash Memory" 28F128J3,28F640J3,28F320J3 manual
from February 2003
This patch also fixes some other problems with this timeout:
- Don't use HZ in timeout "calculation"!
While testing we noticed that an unlocking timeout occured with
HZ=1000 and didn't occur with HZ=300. This was because the
timeout parameter was calculated differently depending on the
HZ value. Now a fixed value of 1500ms is used.
- The last parameter of WAIT_TIMEOUT (defined to
inval_cache_and_wait_for_operation) has to be passed in
micro-seconds. So multiply the ms value with 1000 and not 100
to calculate this value.
- Use variable name "mdelay" instead of misleading "udelay".
Tested-by: Stephan Gatzka <stephan@gatzka.org>
Added a NAND device flag for subpage read support. Previously this was
hard coded based on large page and soft ECC.
Updated base NAND driver to use the new subpage read flag if the NAND is
Signed-off-by: Jeff Westfahl <jeff.westfahl@ni.com>
Reviewed-by: Brian Norris <computersforpeace@gmail.com>
Commit abcda1dc ('arm: plat-orion: introduce PLAT_ORION_LEGACY hidden
config option') currently pending in linux-next will make the ARCH_MVEBU
platform select PLAT_ORION, which means that now all Orion drivers can
be enabled on ARCH_MVEBU. This works fine for most drivers, except for
orion_nand, because it includes <mach/hardware.h>, but mach-mvebu does
not have a mach/hardware.h header (it is considered as a deprecated
practice).
It turns out that the <mach/hardware.h> include in orion_nand is not
necessary: the driver builds perfectly fine without it, so we simply
get rid of it.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Tested-by: Andrew Lunn <andrew@lunn.ch>
Return an error code if test fails in order to detect a test case failure
by invoking tests repeatedly like this:
while sudo modprobe mtd_nandecctest; do
sudo modprobe -r mtd_nandecctest
done
It is unnecessary for this driver to call srandom32() in module_init.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
The LPC32xx's DT-only conversion of the MLC NAND driver makes NAND config via
platform_data obsolete. Dropped by this patch.
Further, the driver really needs CONFIG_OF, which is already reflected by the
dependency on ARCH_LPC32XX which depends on CONFIG_OF. So also dropping
CONFIG_OF ifdefs.
There is still platform_data necessary to supply the dma_filter callback for
the dma engine. This is a completely different data structure than the old
platform_data for NAND config, so renaming some old "pdata" variable to "ncfg"
to prevent confusion with the new platform data.
Signed-off-by: Roland Stigge <stigge@antcom.de>
The LPC32xx's DT-only conversion of the SLC NAND driver makes NAND config via
CONFIG_OF ifdefs.
Allow MTD_NAND_GPMI_NAND to be built as module.
When building MTD_NAND_GPMI_NAND as module, the following error shows up:
ERROR: "nand_update_bbt" [drivers/mtd/nand/gpmi-nand/gpmi_nand.ko] undefined!
Export nand_update_bbt to fix it.
Rename 'len' variable of create_bbt/scan_block_fast/scan_block_full to
'numpages', since it really means number of pages to scan when
searching for the BBM (and not the byte length of the scan).
Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
Fixes the following warnings:
‘s3c2410_nand_correct_data’ defined but not used [-Wunused-function]
‘s3c2410_nand_enable_hwecc’ defined but not used [-Wunused-function]
‘s3c2412_nand_enable_hwecc’ defined but not used [-Wunused-function]
‘s3c2440_nand_enable_hwecc’ defined but not used [-Wunused-function]
‘s3c2410_nand_calculate_ecc’ defined but not used [-Wunused-function]
‘s3c2412_nand_calculate_ecc’ defined but not used [-Wunused-function]
‘s3c2440_nand_calculate_ecc’ defined but not used [-Wunused-function]
The above functions are called only when CONFIG_MTD_NAND_S3C2410_HWECC
is defined. Thus making them conditional.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
devm_* functions are device managed functions and make cleanup code
simpler and smaller.
devm_kzalloc, devm_clk_get and devm_request_and_ioremap functions
are used.
Err has only been initialized to 0 at this, so it is not possible that this
test can be true.
Fix kernel-doc warning in <linux/mtd/nand.h>:
Warning(include/linux/mtd/nand.h:659): No description found for parameter 'read_byte'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Brian Norris <computersforpeace@gmail.com>
We may cause a memory leak when the @types has more then one parser.
Take the `default_mtd_part_types` for example. The default_mtd_part_types has
two parsers now: `cmdlinepart` and `ofpart`.
Assume the following case:
The kernel command line sets the partitions like:
#gpmi-nand:20m(boot),20m(kernel),1g(rootfs),-(user)
But the devicetree file(such as arch/arm/boot/dts/imx28-evk.dts) also sets
the same partitions as the kernel command line does.
In the current code, the partitions parsed out by the `ofpart` will
overwrite the @pparts which has already set by the `cmdlinepart` parser,
and the the partitions parsed out by the `cmdlinepart` is missed.
A memory leak occurs.
So we should break the code as soon as we parse out the partitions,
In actually, this patch makes a priority order between the parsers.
If one parser has already parsed out the partitions successfully,
it's no need to use another parser anymore.
Signed-off-by: Huang Shijie <shijie8@gmail.com>
On some platforms (e.g. MPC5200) a direct 1:1 mapping may cause
problems with JFFS2 usage, as the local bus (LPB) doesn't support
unaligned accesses as implemented in the JFFS2 code via memcpy().
By defining "no-unaligned-direct-access", the flash will not be
exposed directly to the MTD users (e.g. JFFS2) any more.
Use devm_kzalloc for all calls to kzalloc and not just the first. Use devm
functions for other allocations as well.
Move the call to platform_get_resource(pdev, IORESOURCE_MEM, 0) closer to
where its result is passed to devm_request_and_ioremap to make the lack of
need for a NULL test more evident.
The semantic match that finds the inconsistency is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
*devm_kzalloc(...)
*kzalloc(...)
// </smpl>
The driver uses plat_nand. As the platform_device is loaded from DT, we need
to lookup the node and attach our xway specific "struct platform_nand_data"
to it.
Signed-off-by: John Crispin <blogic@openwrt.org>
If plat_nand loads and the platform_data is not properly set it will segfault.
CONFIG_MTD_NAND_VERIFY_WRITE was killed recently, so remove it from
defconfigs as well.
Signed-off-by: Huang Shijie <b32955@freescale.com>
Just as Artem suggested:
"Both UBI and JFFS2 are able to read verify what they wrote already.
There are also MTD tests which do this verification. So I think there
is no reason to keep this in the NAND layer, let alone wasting RAM in
the driver to support this feature. Besides, it does not work for sub-pages
and many drivers have it broken. It hurts more than it provides benefits."
So kill MTD_NAND_VERIFY_WRITE entirely.
The manufacturer datasheet can be found on the Micron website,
under the name n25q_256mb_3v_65nm.pdf:
http://www.micron.com/search?source=ps&q=n25q_256mb_3v_65nm
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Removes disabled printk (which should be dev_dbg these days) as well
as #if 0 blocks (which are trivial to reimplement if ever needed) to
meet basic CodingStyle guidelines.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
There is new format specified that helps to dump small buffers. It makes the
code simpler and nicer.
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
add OF support for the davinci nand controller.
Acked-by: Sekhar Nori <nsekhar@ti.com>
This patch fixes regression introduced by
"8bdc81c jffs2: get rid of jffs2_sync_super". We submit a delayed work in order
to make sure the write-buffer is synchronized at some point. But we do not
flush it when we unmount, which causes an oops when we unmount the file-system
and then the delayed work is executed.
This patch fixes the issue by adding a "cancel_delayed_work_sync()" infocation
in the '->sync_fs()' handler. This will make sure the delayed work is canceled
on sync, unmount and re-mount. And because VFS always callse 'sync_fs()' before
unmounting or remounting, this fixes the issue.
Reported-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Cc: stable@vger.kernel.org [3.5+]
Tested-by: Ludovic Desroches <ludovic.desroches@atmel.com>
The uclinux.c map driver has traditionally been used only on non-MMU based
systems. But there is no fundamental reason it can't be used on systems
running with virtual memory.
Some ColdFire CPU based systems now have full paged MMU hardware and can use
the uclinux.c mapping driver, so making the uclinux.c driver configuration
depend on !CONFIG_MMU doesn't make sense now. Allow the CONFIG_MTD_UCLINUX
option to be enabled if CONFIG_COLDFIRE is enabled. (I have chosen not to
just more generally allow uclinux.c for any MMU type to keep this option
hidden for most systems that are not interested in setting it).
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
The uclinux.c mapping driver uses ioremap_nocache() to map its physical
mapping address to a system virtual address. Problem is that the region
it is mapping is not device memory. It is ordinary system RAM. On most
non-MMU systems this doesn't matter, and the mapping is always a 1:1
translation of the address. On paged memory systems on some architectures
the page table mappings are not compatible between normal RAM and device
memory.
If we want to use the uclinux.c mapping driver on real MMU enabled systems
we should be using the kernel virtual address that the mapping is at. For
architectures that support the traditional initrd they use phys_to_virt or
__va to convert the physical start initrd address to a kernel usable virtual
address. The uclinux filesystem mapping is even more restrictive than the
typical initrd, it always follows the kernels own bss section (so always in
directly mapped memory). Therefore we can use the usual phys_to_virt to
translate the physical start address to a virtual address.
Fixes the following checkpatch warnings:
WARNING: line over 80 characters
Fixes checkpatch warnings and errors related to whitespaces.
Fixes the following checkpatch errors:
ERROR: do not initialise statics to 0 or NULL
+static int hardware_ecc = 0;
+static const int clock_stop = 0;
Fixes the following checkpatch warning:
WARNING: Use #include <linux/io.h> instead of <asm/io.h>
Use pr_* instead of printk.
This makes the code simpler by eliminating module_init() and
module_exit().
Include IMX6 in the list of supported SoCs.
Because we can have a single kernel to support multiple machines, we
need to make loading specific drivers for the target platform only.
For this, driver is converted to the platform driver.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Update driver autcpu12-nvram.c so it compiles; map_read32/map_write32
no longer exist in the kernel so the driver is totally broken.
Additionally, map_info name passed to simple_map_init is incorrect.
Signed-off-by: Peter Meerwald <p.meerwald@bct-electronic.com>
