The dev->sem conforms to mutex style usage. This patch converts it to use
the struct mutex type, and new API.
There is also a small style fix around this comment,
/* unlock here as tower_delete frees dev */
Where I broke the line up to meet the 80 char limit.
Signed-off-by: Daniel Walker <dwalker@mvista.com>
This adds device-tree-aware ehci-ppc-of driver.
The code is based on the ehci-ppc-soc driver by
Stefan Roese <sr@denx.de>.
Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Use debugfs instead of /proc/driver/udc
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Various small at91_udc cleanups:
- Use generic GPIO calls, not older platform-specific ones
- Use gpio_request()/gpio_free()
- Use VERBOSE_DEBUG convention, not older VERBOSE
- Fix sparse complaint about parameter type (changed to gfp_t)
- Add missing newline to some rarely-seen debug messages
- Fix some old cleanup bugs on probe() fault paths
Also add a mechanism whereby rm9200 gpios can drive the D+ pullup
through an inverting transistor, based on a patch from Steve Birtles.
Most UDC drivers supporting a GPIO based pullup should probably have
such an option, but testing it requries such a board in hand!
Cc: Steve Birtles <arm_kernel_development@micromark.net.cn>
Update the ohci-at91 bus glue to start understanding about the per-port
power switch GPIOs it's given (on the sam9263-ek and potentially other
boards). For the moment this just claims them and forces them active
(assuming active-low power enables) whenever the HCD is loaded.
The assumption is still that board setup configures the GPIOs. Using
gpio_request() tracks actual usage and guards against conflict.
This documents two newly created files:
/sys/bus/usb/device/.../power/connected_duration
/sys/bus/usb/device/.../power/active_duration
Documentation was placed in Documentation/ABI/testing, since that's where the
documentation is for the other USB sysfs power files.
Signed-off-by: Sarah Sharp <sarah.a.sharp@intel.com>
This patch exports two statistics to userspace:
connected_duration is the total time (in msec) that the device has
been connected. active_duration is the total time the device has not
been suspended. With these two statistics, tools like PowerTOP can
calculate the percentage time that a device is active, i.e. not
suspended or auto-suspended.
Users can also use the active_duration to check if a device is actually
autosuspended. Currently, they can set power/level to auto and
power/autosuspend to a positive timeout, but there's no way to know from
userspace if a device was actually autosuspended without looking at the
dmesg output. These statistics will be useful in creating an automated
userspace script to test autosuspend for USB devices.
The following improvements were made:
- Fixed control line issue where asserting DTR on ep5 would close ep2
- Added support for calc_num_ports (will help support future composite
devices)
Signed-off-by: Kevin Lloyd <linux@sierrawireless.com>
[PATCH] ftdi_sio: add support for more FTDI based JTAG adaptors
There are more devices similar to the Olimex JTAG adaptor, in that the first
port of the FT2232C is used for JTAG, and only the second port is available as
UART.
I have thus renamed ftdi_olimex_{probe,quirk} to ftdi_jtag_{probe,quirk} and
added vendor/product ID's for the OpenMoko Neo1973 Debug Board as well as the
OOCDlink device.
I've also updated the KERN_INFO message sent to userspace to remove the word
'olimex' and an extra '\n' that was causing an empty line in dmesg.
Signed-off-by: Harald Welte <laforge@openmoko.org>
Don't pass NULL into termios functions when calling them internally
Remove all the crap which then checks for NULL which can't occur now
Clear CMSPAR as it is not supported
Report the baud rate back to the caller properly (See FIXME someone with
the docs)
Signed-off-by: Alan Cox <alan@redhat.com>
Remove internal NULL passing in termios code
Remove all the if checks it causes
Encode the baud rate back properly
Remove lots of NULL checks that can no longer occur
Encode the baud rate back into the termios (again someone with docs see
FIXME to improve this further)
Use gpio_vbus instead of udc_is_connected for udc on tosa.
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Add a missing dependency which goofs up the xconfig display.
Fix a small glitch noted by Yannick Cote. There is no endpoint number
six, so if a (broken) host wrongly tried to change or read status of
that endpoint, the driver could access reserved register space.
Cc: Yannick Cote <yanick@yanos.org>
Am Sonntag, 16. Dezember 2007 05:23:47 schrieb Andrew Morton:
> On Sat, 15 Dec 2007 07:08:52 -0800 (PST) bugme-daemon@bugzilla.kernel.org wrote:
> > http://bugzilla.kernel.org/show_bug.cgi?id=9573
> > There's a null pointer dereference on drivers/usb/serial/whiteheat.c as
> > follows:
> > (1) line 613: the test "if (port->tty)" implies that null is a legal value
> > for "port->tty" at that point
> > (2) neither firm_open nor firm_purge initialize "port->tty"
drivers/usb/serial/usb-serial::serial_open() sets port->tty
The check for NULL is bogus. This patch removes the check.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Acked-by: Alan Cox <alan@redhat.com>
Fix potential (never-observed) oops on rare error path,
bugzilla #9594. Fix uses the same test as used earlier.
Also make the adjacent "else" block look like an "else" block
instead of hiding like a bug.
Kernel bugzilla entry #9569 reports a potential OOPS in some code
supporting the integrated root hub TT support used on ARC/TDI
derived cores. (This seems to have been a longstanding issue.)
This patch cleans up usage of urb->dev->tt to avoid that potential
oops and also fixes some overly long lines.
Some glue bits for the on-chip USB host controller in the Marvell Orion
family of ARM SoCs, which is basically EHCI compatible.
Signed-off-by: Tzachi Perelstein <tzachi@marvell.com>
Reviewed-by: Lennert Buytenhek <buytenh@marvell.com>
fix warning:
drivers/usb/host/ehci-hcd.c:832:8: warning: symbol 'status' shadows an earlier one
drivers/usb/host/ehci-hcd.c:790:71: originally declared here
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
fix warning:
drivers/usb/core/devio.c:1226:20: warning: incorrect type in assignment (different address spaces)
drivers/usb/core/devio.c:1226:20: expected void *usercontext
drivers/usb/core/devio.c:1226:20: got void [noderef] <asn:1>*
fix warnings:
drivers/usb/storage/initializers.c:83:26: warning: incorrect type in argument 5 (different signedness)
drivers/usb/storage/initializers.c:83:26: expected unsigned int *act_len
drivers/usb/storage/initializers.c:83:26: got int *<noident>
drivers/usb/storage/initializers.c:89:26: warning: incorrect type in argument 5 (different signedness)
drivers/usb/storage/initializers.c:89:26: expected unsigned int *act_len
drivers/usb/storage/initializers.c:89:26: got int *<noident>
This adds a workaround for an issue reported with ISO transfers
on some EHCI controllers, most recently with VIA KT800 and PS3
EHCI silicon.
The issue is that the silicon doesn't necessarily seem to be done
using ISO DMA descriptors (itd, sitd) when it marks them inactive.
(One theory is that the ill-defined mechanism where hardware caches
periodic transfer descriptors isn't invalidating their state...)
With such silicon, quick re-use of those descriptors makes trouble.
Waiting until the next frame seems to be a sufficient workaround.
This patch ensures that the relevant descriptors aren't available
for immediate re-use. It does so by not recycling them until after
issuing the completion callback which would reuse them by enqueueing
an URB and thus (re)allocating ISO DMA descriptors.
Acked-by: Geoff Levand <geoffrey.levand@am.sony.com>
Cc: Masashi Kimoto <Masashi_Kimoto@hq.scei.sony.co.jp>
Some boards (like e.g. Tosa) invert the VBUS-detection signal:
it's low when a host is supplying VBUS, and high otherwise.
Allow specifying whether gpio_vbus value is inverted.
Dopey thing to do and lockdep will (or should) warn.
Spotted by Daniel Walker.
Cc: Matthias Kaehlcke <matthias.kaehlcke@gmail.com>
Cc: Daniel Walker <dwalker@mvista.com>
USB testing driver: convert semaphore dev->sem to the mutex API
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com>
Convert USB mon driver from nopage to fault.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: Pete Zaitcev <zaitcev@redhat.com>
Cc: Pete Zaitcev <zaitcev@redhat.com>
A tester with actual hardware would be useful
Signed-off-by: Sarah Sharp <saharabeara@gmail.com>
Without this fix, the pl2303 usb-serial adapter would not suspend properly
unless it had been opened first. A pl2303 type_1 chip will still break if the
system is hibernated while the RS-232 connector is powered by another system.
This was broken before, and a reset resume does not fix it. All other suspend
and autosuspend scenarios work with ATEN pl2303 adaptors with HX and type_1 chips.
Replace the FISH and SOUP macros that violated the macro guidelines in CodingStyle.
Turn them into function calls with clearer variable names.
This patch (as1025) changes the default power budget for dummy-hcd to
500 mA and makes it a preprocessor parameter for easier testing.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1028) was mostly written by David Brownell; I made only
a few changes (extra log info and a small bug fix -- which might
account for why David's version had to be reverted). It adds a new
watchdog timer to the ehci-hcd driver to be used exclusively for
detecting lost or missing IAA notifications.
Previously a shared timer had been used, which may have led to some
problems as reported by Christian Hoffmann.
Cc: David Brownell <david-b@pacbell.net>
This patch (as1022b) adds stub methods for suspend and resume to the
usbfs driver. There isn't much they can do since there's no way to
inform a user task about the events. But it's important to have the
stubs, because an upcoming change to usbcore will automatically unbind
drivers that don't have those methods when a suspend occurs.
Edgeport USB Serial Converter: convert semaphore es_sem to the
mutex API
This patch (as1023) updates the code in usb_reset_composite_device():
Some local variable declarations are moved to inner loops.
The interface locks are not acquired. This isn't necessary
any more; its only reason was to prevent an interface from
being suspended or resumed during the reset. But now
interface power management is controlled by the USB device
lock, not by the interface lock.
The check for whether the interface is registered is removed.
There doesn't seem to be any reason for checking; a driver
for a non-registered interface deserves to be informed of
device resets just as much as any other.
For as long as I've known about it, the USBDEVFS_CONNECT ioctl hasn't
done what it's supposed to. The current code reprobes _all_ the
unbound USB interfaces; this patch (as1021) makes it reprobe only the
interface for which it was called.
The OHCI driver's IRQ handler, while processing a WDH interrupt, masks
and unmasks it. I believe this is both broken (the write may still be
posted during the donelist processing it's trying to safeguard) and
useless as this IRQ may not be reissued until it's acked (unless this
legacy code is an uncommented workaround for some chip erratum).
We should not have multiple line files in sysfs, this moves the data to
debugfs instead, like the UHCI driver.
Signed-off-by: Tony Jones <tonyj@suse.de>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Distros (like SuSE) want to know this information, to make it easier
to handle support issues. Might as well let everyone benefit from this.
This is also enabled whenever CONFIG_USB_DEBUG is enabled, to help with
debugging.
This patch (as1017) makes dummy_hcd behave more like the other USB
peripheral controller drivers by no longer registering its
gadget driver on the platform bus. Doing that has always been a
mistake, since a usb_gadget_driver isn't a platform_driver. Instead
the gadget driver is left unregistered in sysfs.
CC: David Brownell <david-b@pacbell.net>
This patch hands over the port to the companion when the
hub_port_connect_change fails.
Signed-off-by: Balaji Rao <balajirrao@gmail.com>
I'm having problem with oopses when rebooting, if I modprobe g_serial
and rmmod g_serial and do a reboot I get an oops in device_shutdown().
The reason seems to be that usb_gadget_unregister_driver() doesn't do
enough cleanup. With this at91_udc patch I don't get the oops.
Signed-off-by: Patrik Sevallius <patrik.sevallius@enea.com>
[ Same bug was in other peripheral controller drivers; fixed ]
This also fixes a sparse warning that symbol 'result' shadows an earlier one.
Signed-off-by: Andre Haupt <andre@bitwigglers.org>
Claim the interface for a USB to serial converter when the tty is open,
and release the interface when the tty is closed.
If a driver doesn't provide a resume function, use the generic resume
instead.
Make sure the generic resume function does not submit the URBs if we're
coming back from autosuspend. On autoresume, we know that the open
function will be called next, which will attempt to submit the URBs. If
we submit them in the resume function, the open will fail.
This works for:
- autosuspend
- suspending with the tty open or closed
- hibernate with the tty closed
A hibernate (or a suspend that causes the USB subsystem to lose power)
has issues. If you have the tty open when you hibernate, a new tty will
be created when the device re-enumerates during resume.
We now have pr_err(), pr_warning(), and friends ... start using
them in the gadget stack instead of printk(KERN_ERR) and friends.
This gives us shorter lines and somewhat increased readability.
