2008-02-13udf: fix directory offset handlingJan Kara
Patch cleaning up UDF directory offset handling missed modifications in dir.c (because I've submitted an old version :(). Fix it. Signed-off-by: Jan Kara <jack@suse.cz> Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com> Tested-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13Documentation: sysctl/kernel.txt: fix documentation referenceMichael Opdenacker
This patch fixes a reference to Documentation/kmod.txt which was apparently renamed to Documentation/debugging-modules.txt Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13fs/smbfs/inode.c: fix warning message deprecating smbfsSergio Luis
Fix the warning message regarding smbfs to "smbfs is deprecated and will be removed from the 2.6.27 kernel. Please migrate to cifs" instead of "smbfs is deprecated and will be removedfrom the 2.6.27 kernel. Please migrate to cifs" Signed-off-by: Sergio Luis <sergio@uece.br> Screwed-up-by: Andrew Morton <akpm@linux-foundation.org> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13docbook: drop z85230 library from kernel-apiRandy Dunlap
Drop z85230 support library info from kernel-api since it's duplicated in the Z85230 book. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13xfs: convert beX_add to beX_add_cpu (new common API)Marcin Slusarz
remove beX_add functions and replace all uses with beX_add_cpu Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Reviewed-by: Dave Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13moduleparam: fix alpha, ia64 and ppc64 compile failuresIvan Kokshaysky
On alpha, ia64 and ppc64 only relocations to local data can go into read-only sections. The vast majority of module parameters use the global generic param_set_*/param_get_* functions, so the 'const' attribute for struct kernel_param is not only useless, but it also causes compile failures due to 'section type conflict' in those rare cases where param_set/get are local functions. This fixes http://bugzilla.kernel.org/show_bug.cgi?id=8964 Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Anton Blanchard <anton@samba.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13docbook: make a networking book and fix a few errorsRandy Dunlap
Move networking (core and drivers) docbook to its own networking book. Fix a few kernel-doc errors in header and source files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13docbook: sunrpc filenames and notation fixesRandy Dunlap
Use updated file list for docbook files and fix kernel-doc warnings in sunrpc: Warning(linux-2.6.24-git12//net/sunrpc/rpc_pipe.c:689): No description found for parameter 'rpc_client' Warning(linux-2.6.24-git12//net/sunrpc/rpc_pipe.c:765): No description found for parameter 'flags' Warning(linux-2.6.24-git12//net/sunrpc/clnt.c:584): No description found for parameter 'tk_ops' Warning(linux-2.6.24-git12//net/sunrpc/clnt.c:618): No description found for parameter 'bufsize' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13docbook: move pipe and splice to filesystems docbookRandy Dunlap
Move pipes and splice docbook to filesystems book. kernel-api book is huge (10x most other books) & slow to process. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13kernel-doc: fix fs/pipe.c notationRandy Dunlap
Fix several kernel-doc notation errors in fs/pipe.c. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13parport: section fixupDavid Brownell
Fix section warning for parport_ECP_supported(); it's called from a routine exported to modules, so it can't be removed with __devinit section pruning. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13Documentation: prune redundant SubmitChecklist itemsJ. Bruce Fields
Kernel style is mentioned twice, and the git apply trick is a bit redundant given the checkpatch.pl recommendation (which also checks for bad whitespace). Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13hugetlb: fix overcommit lockingNishanth Aravamudan
proc_doulongvec_minmax() calls copy_to_user()/copy_from_user(), so we can't hold hugetlb_lock over the call. Use a dummy variable to store the sysctl result, like in hugetlb_sysctl_handler(), then grab the lock to update nr_overcommit_huge_pages. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Reported-by: Miles Lane <miles.lane@gmail.com> Cc: Adam Litke <agl@us.ibm.com> Cc: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13SC26XX: missing PORT define in serial_core.hThomas Bogendoerfer
When submitting the driver for inclusion to 2.6.25 I've missed the change to serial_core.h. This patch fixes this. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13Final removal of FASTCALL()/fastcallHarvey Harrison
All users are gone, remove definitions and comments referring to them. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13remove final fastcall usersHarvey Harrison
fastcall always expands to empty, remove it. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13rcupdate: fix commentPaul E. McKenney
This comment caused some consternation during fastcall removal. Make it truthful. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13include/linux: Remove all users of FASTCALL() macroHarvey Harrison
FASTCALL() is always expanded to empty, remove it. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13xtime_lock vs update_process_timesPeter Zijlstra
Commit d3d74453c34f8fd87674a8cf5b8a327c68f22e99 ("hrtimer: fixup the HRTIMER_CB_IRQSAFE_NO_SOFTIRQ fallback") broke several archs, and since only Russell bothered to merge the fix, and Greg to ACK his arch, I'm sending this for merger. I have confirmation that the Alpha bit results in a booting kernel. That leaves: blackfin, frv, sh and sparc untested. The deadlock in question was found by Russell: IRQ handle -> timer_tick() - xtime seqlock held for write -> update_process_times() -> run_local_timers() -> hrtimer_run_queues() -> hrtimer_get_softirq_time() - tries to get a read lock Now, Thomas assures me the fix is trivial, only do_timer() needs to be done under the xtime_lock, and update_process_times() can savely be removed from under it. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Greg Ungerer <gerg@uclinux.org> CC: Richard Henderson <rth@twiddle.net> CC: Bryan Wu <bryan.wu@analog.com> CC: David Howells <dhowells@redhat.com> CC: Paul Mundt <lethal@linux-sh.org> CC: William Irwin <wli@holomorphy.com> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13acpi: fix acpi_os_read_pci_configuration() misuse of raw_pci_read()Linus Torvalds
The raw_pci_read() interface (as the raw_pci_ops->read() before it) unconditionally fills in a 32-bit integer return value regardless of the size of the operation requested. So claiming to take a "void *" is wrong, as is passing in a pointer to just a byte variable. Noticed by pageexec when enabling -fstack-protector (which needs other patches too to actually work, but that's a separate issue). Acked-by: Len Brown <len.brown@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13FRV: Fix up parse error in linker scriptDavid Howells
Fix up parse error in FRV linker script, presumably introduced through changes to the INIT_TEXT and EXIT_TEXT macros. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-schedLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: sched: rt-group: refure unrunnable tasks sched: rt-group: clean up the ifdeffery sched: rt-group: make rt groups scheduling configurable sched: rt-group: interface sched: rt-group: deal with PI sched: fix incorrect irq lock usage in normalize_rt_tasks() sched: fair-group: separate tg->shares from task_group_lock hrtimer: more hrtimer_init_sleeper() fallout.
2008-02-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: x86: pit_clockevent can be static x86: EFI runtime code mapping enhancement x86: EFI: fix use of unitialized variable and the cache logic x86: CPA: fix gbpages support in try_preserve_large_page xen: unpin initial Xen pagetable once we're finished with it x86/early_ioremap: don't assume we're using swapper_pg_dir x86: fixup machine_ops reboot_{32|64}.c unification fallout x86: fix sigcontext.h user export
2008-02-13drivers/memstick/host/tifm_ms.c breakageAl Viro
writel(sock + ...) that should've been writel(sock->addr + ...) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13dm-raid1 breakage on 64bitAl Viro
test_and_set_bit() on address of uint32_t is a Bad Idea(tm)... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13wmi: (!x & y) strikes againAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13x86: pit_clockevent can be staticHarvey Harrison
arch/x86/kernel/i8253.c:98:27: warning: symbol 'pit_clockevent' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13x86: EFI runtime code mapping enhancementHuang, Ying
This patch enhances EFI runtime code memory mapping as following: - Move __supported_pte_mask & _PAGE_NX checking before invoking runtime_code_page_mkexec(). This makes it possible for compiler to eliminate runtime_code_page_mkexec() on machine without NX support. - Use set_memory_x/nx in early_mapping_set_exec(). This eliminates the duplicated implementation. This patch has been tested on Intel x86_64 platform with EFI64/32 firmware. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13x86: EFI: fix use of unitialized variable and the cache logicThomas Gleixner
Andi Kleen pointed out that the cache attribute logic is reverse in efi_enter_virtual_mode(). This problem alone is harmless as we do not (yet) do cache attribute conflict resolution. (This bug was not present in the original EFI submission - I introduced it while fixing up rejects.) While reviewing this code I noticed a second, worse problem: the use of uninitialized md->virt_addr. Fix both problems. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13x86: CPA: fix gbpages support in try_preserve_large_pageAndi Kleen
[ mingo@elte.hu: while gbpages cannot be enabled on mainline currently, keep the code uptodate and this fix is easy enough. ] Use correct page sizes and masks for GB pages in try_preserve_large_page() This prevents a boot hang on a GB capable system with CONFIG_DIRECT_GBPAGES enabled. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-13xen: unpin initial Xen pagetable once we're finished with itJeremy Fitzhardinge
Unpin the Xen-provided pagetable once we've finished with it, so it doesn't cause stray references which cause later swapper_pg_dir pagetable updates to fail. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Tested-by: Jody Belka <knew-linux@pimb.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13x86/early_ioremap: don't assume we're using swapper_pg_dirJeremy Fitzhardinge
At the early stages of boot, before the kernel pagetable has been fully initialized, a Xen kernel will still be running off the Xen-provided pagetables rather than swapper_pg_dir[]. Therefore, readback cr3 to determine the base of the pagetable rather than assuming swapper_pg_dir[]. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Tested-by: Jody Belka <knew-linux@pimb.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13x86: fixup machine_ops reboot_{32|64}.c unification falloutJody Belka
When reboot_32.c and reboot_64.c were unified (commit 4d022e35fd...), the machine_ops code was broken, leading to xen pvops kernels failing to properly halt/poweroff/reboot etc. This fixes that up. Signed-off-by: Jody Belka <knew-linux@pimb.org> Cc: Miguel Boton <mboton@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13x86: fix sigcontext.h user exportIngo Molnar
Jakub Jelinek reported that some user-space code that relies on kernel headers has built dependency on the sigcontext->eip/rip register names - which have been unified in commit: commit 742fa54a62be6a263df14a553bf832724471dfbe Author: H. Peter Anvin <hpa@zytor.com> Date: Wed Jan 30 13:30:56 2008 +0100 x86: use generic register names in struct sigcontext so give the old layout to user-space. This is not particularly pretty, but it's an ABI so there's no danger of the two definitions getting out of sync. Reported-by: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13sched: rt-group: refure unrunnable tasksPeter Zijlstra
Refuse to accept or create RT tasks in groups that can't run them. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13sched: rt-group: clean up the ifdefferyPeter Zijlstra
Clean up some of the excessive ifdeffery introduces in the last patch. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13sched: rt-group: make rt groups scheduling configurablePeter Zijlstra
Make the rt group scheduler compile time configurable. Keep it experimental for now. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13sched: rt-group: interfacePeter Zijlstra
Change the rt_ratio interface to rt_runtime_us, to match rt_period_us. This avoids picking a granularity for the ratio. Extend the /sys/kernel/uids/<uid>/ interface to allow setting the group's rt_runtime. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13sched: rt-group: deal with PIPeter Zijlstra
Steven mentioned the fun case where a lock holding task will be throttled. Simple fix: allow groups that have boosted tasks to run anyway. If a runnable task in a throttled group gets boosted the dequeue/enqueue done by rt_mutex_setprio() is enough to unthrottle the group. This is ofcourse not quite correct. Two possible ways forward are: - second prio array for boosted tasks - boost to a prio ceiling (this would also work for deadline scheduling) Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13sched: fix incorrect irq lock usage in normalize_rt_tasks()Peter Zijlstra
lockdep spotted this bogus irq locking. normalize_rt_tasks() can be called from hardirq context through sysrq-n Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13sched: fair-group: separate tg->shares from task_group_lockPeter Zijlstra
On Mon, 2008-02-11 at 15:09 +0300, Denis V. Lunev wrote: > BUG: sleeping function called from invalid context > at /home/den/src/linux-netns26/kernel/mutex.c:209 > in_atomic():1, irqs_disabled():0 > no locks held by swapper/0. > Pid: 0, comm: swapper Not tainted 2.6.24 #304 > > Call Trace: > <IRQ> [<ffffffff80252d1e>] ? __debug_show_held_locks+0x15/0x27 > [<ffffffff8022c2a8>] __might_sleep+0xc0/0xdf > [<ffffffff8049f1df>] mutex_lock_nested+0x28/0x2a9 > [<ffffffff80231294>] sched_destroy_group+0x18/0xea > [<ffffffff8023e835>] sched_destroy_user+0xd/0xf > [<ffffffff8023e8c1>] free_uid+0x8a/0xab > [<ffffffff80233e24>] __put_task_struct+0x3f/0xd3 > [<ffffffff80236708>] delayed_put_task_struct+0x23/0x25 > [<ffffffff8026fda7>] __rcu_process_callbacks+0x8d/0x215 > [<ffffffff8026ff52>] rcu_process_callbacks+0x23/0x44 > [<ffffffff8023a2ae>] __do_softirq+0x79/0xf8 > [<ffffffff8020f8c3>] ? profile_pc+0x2a/0x67 > [<ffffffff8020d38c>] call_softirq+0x1c/0x30 > [<ffffffff8020f689>] do_softirq+0x61/0x9c > [<ffffffff8023a233>] irq_exit+0x51/0x53 > [<ffffffff8021bd1a>] smp_apic_timer_interrupt+0x77/0xad > [<ffffffff8020ce3b>] apic_timer_interrupt+0x6b/0x70 > <EOI> [<ffffffff8020b0dd>] ? default_idle+0x43/0x76 > [<ffffffff8020b0db>] ? default_idle+0x41/0x76 > [<ffffffff8020b09a>] ? default_idle+0x0/0x76 > [<ffffffff8020b186>] ? cpu_idle+0x76/0x98 separate the tg->shares protection from the task_group lock. Reported-by: Denis V. Lunev <den@openvz.org> Tested-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-13hrtimer: more hrtimer_init_sleeper() fallout.Peter Zijlstra
Missed an instance... futex_lock_pi() hrtimer_init_sleeper() rt_mutex_timed_lock() rt_mutex_timed_fastlock() rt_mutex_slowlock() hrtimer_start() Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-12timeconst.pl: correct reversal of USEC_TO_HZ and HZ_TO_USECH. Peter Anvin
The USEC_TO_HZ and HZ_TO_USEC constant sets were mislabelled, with seriously incorrect results. This among other things manifested itself as cpufreq not working when a tickless kernel was configured. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Tested-by: Carlos R. Mafra <crmafra@ift.unesp.br> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-11WMI: initialize wmi_blocks.list even if ACPI is disabledLinus Torvalds
Even if we don't want to register the WMI driver, we should initialize the wmi_blocks list to be empty, since we don't want the wmi helper functions to oops just because that basic list has not even been set up. With this, "find_guid()" will happily return "not found" rather than oopsing all over the place, and the callers will then just automatically return false or AE_NOT_FOUND as appropriate. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-11x86: vdso_install fixRoland McGrath
The makefile magic for installing the 32-bit vdso images on disk had a little error. A single-line change would fix that bug, but this does a little more to reduce the error-prone duplication of this bit of makefile variable magic. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-11mempolicy: silently restrict nodemask to allowed nodesKOSAKI Motohiro
Kosaki Motohito noted that "numactl --interleave=all ..." failed in the presence of memoryless nodes. This patch attempts to fix that problem. Some background: numactl --interleave=all calls set_mempolicy(2) with a fully populated [out to MAXNUMNODES] nodemask. set_mempolicy() [in do_set_mempolicy()] calls contextualize_policy() which requires that the nodemask be a subset of the current task's mems_allowed; else EINVAL will be returned. A task's mems_allowed will always be a subset of node_states[N_HIGH_MEMORY] i.e., nodes with memory. So, a fully populated nodemask will be declared invalid if it includes memoryless nodes. NOTE: the same thing will occur when running in a cpuset with restricted mem_allowed--for the same reason: node mask contains dis-allowed nodes. mbind(2), on the other hand, just masks off any nodes in the nodemask that are not included in the caller's mems_allowed. In each case [mbind() and set_mempolicy()], mpol_check_policy() will complain [again, resulting in EINVAL] if the nodemask contains any memoryless nodes. This is somewhat redundant as mpol_new() will remove memoryless nodes for interleave policy, as will bind_zonelist()--called by mpol_new() for BIND policy. Proposed fix: 1) modify contextualize_policy logic to: a) remember whether the incoming node mask is empty. b) if not, restrict the nodemask to allowed nodes, as is currently done in-line for mbind(). This guarantees that the resulting mask includes only nodes with memory. NOTE: this is a [benign, IMO] change in behavior for set_mempolicy(). Dis-allowed nodes will be silently ignored, rather than returning an error. c) fold this code into mpol_check_policy(), replace 2 calls to contextualize_policy() to call mpol_check_policy() directly and remove contextualize_policy(). 2) In existing mpol_check_policy() logic, after "contextualization": a) MPOL_DEFAULT: require that in coming mask "was_empty" b) MPOL_{BIND|INTERLEAVE}: require that contextualized nodemask contains at least one node. c) add a case for MPOL_PREFERRED: if in coming was not empty and resulting mask IS empty, user specified invalid nodes. Return EINVAL. c) remove the now redundant check for memoryless nodes 3) remove the now redundant masking of policy nodes for interleave policy from mpol_new(). 4) Now that mpol_check_policy() contextualizes the nodemask, remove the in-line nodes_and() from sys_mbind(). I believe that this restores mbind() to the behavior before the memoryless-nodes patch series. E.g., we'll no longer treat an invalid nodemask with MPOL_PREFERRED as local allocation. [ Patch history: v1 -> v2: - Communicate whether or not incoming node mask was empty to mpol_check_policy() for better error checking. - As suggested by David Rientjes, remove the now unused cpuset_nodes_subset_current_mems_allowed() from cpuset.h v2 -> v3: - As suggested by Kosaki Motohito, fold the "contextualization" of policy nodemask into mpol_check_policy(). Looks a little cleaner. ] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-11Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Fix build for sim_defconfig
2008-02-11Be more robust about bad arguments in get_user_pages()Jonathan Corbet
So I spent a while pounding my head against my monitor trying to figure out the vmsplice() vulnerability - how could a failure to check for *read* access turn into a root exploit? It turns out that it's a buffer overflow problem which is made easy by the way get_user_pages() is coded. In particular, "len" is a signed int, and it is only checked at the *end* of a do {} while() loop. So, if it is passed in as zero, the loop will execute once and decrement len to -1. At that point, the loop will proceed until the next invalid address is found; in the process, it will likely overflow the pages array passed in to get_user_pages(). I think that, if get_user_pages() has been asked to grab zero pages, that's what it should do. Thus this patch; it is, among other things, enough to block the (already fixed) root exploit and any others which might be lurking in similar code. I also think that the number of pages should be unsigned, but changing the prototype of this function probably requires some more careful review. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: mlx4_core: Fix build break (missing include)
2008-02-11Add Matt to MAINTAINERS as a SLAB allocator maintainerPekka Enberg
Matt is already the maintainer of SLOB which is one of the "SLAB" allocators in the kernel so add him to MAINTAINERS. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
