Not a big deal, but since other __get_key_name() callers
use it lets be consistent.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Link: http://lkml.kernel.org/r/20121020190519.GH25467@moon
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen
Pull xen bug-fixes from Konrad Rzeszutek Wilk:
- Fix mysterious SIGSEGV or SIGKILL in applications due to corrupting
of the %eip when returning from a signal handler.
- Fix various ARM compile issues after the merge fallout.
- Continue on making more of the Xen generic code usable by ARM
platform.
- Fix SR-IOV passthrough to mirror multifunction PCI devices.
- Fix various compile warnings.
- Remove hypercalls that don't exist anymore.
* tag 'stable/for-linus-3.7-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen:
xen: dbgp: Fix warning when CONFIG_PCI is not enabled.
xen: arm: comment on why 64-bit xen_pfn_t is safe even on 32 bit
xen: balloon: use correct type for frame_list
xen/x86: don't corrupt %eip when returning from a signal handler
xen: arm: make p2m operations NOPs
xen: balloon: don't include e820.h
xen: grant: use xen_pfn_t type for frame_list.
xen: events: pirq_check_eoi_map is X86 specific
xen: XENMEM_translate_gpfn_list was remove ages ago and is unused.
xen: sysfs: fix build warning.
xen: sysfs: include err.h for PTR_ERR etc
xen: xenbus: quirk uses x86 specific cpuid
xen PV passthru: assign SR-IOV virtual functions to separate virtual slots
xen/xenbus: Fix compile warning.
xen/x86: remove duplicated include from enlighten.c
... and fix the race in updating unaligned control ones
Pull kvm fixes from Avi Kivity:
"KVM updates for 3.7-rc2"
* tag 'kvm-3.7-2' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM guest: exit idleness when handling KVM_PV_REASON_PAGE_NOT_PRESENT
KVM: apic: fix LDR calculation in x2apic mode
KVM: MMU: fix release noslot pfn
Pull perf fixes from Ingo Molnar:
"Most of these are uprobes race fixes from Oleg, and their preparatory
cleanups. (It's larger than what I'd normally send for an -rc kernel,
but they looked significant enough to not delay them.)
There's also an oprofile fix and an uncore PMU fix."
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits)
perf/x86: Disable uncore on virtualized CPUs
oprofile, x86: Fix wrapping bug in op_x86_get_ctrl()
ring-buffer: Check for uninitialized cpu buffer before resizing
uprobes: Fix the racy uprobe->flags manipulation
uprobes: Fix prepare_uprobe() race with itself
uprobes: Introduce prepare_uprobe()
uprobes: Fix handle_swbp() vs unregister() + register() race
uprobes: Do not delete uprobe if uprobe_unregister() fails
uprobes: Don't return success if alloc_uprobe() fails
uprobes/x86: Only rep+nop can be emulated correctly
uprobes: Simplify is_swbp_at_addr(), remove stale comments
uprobes: Kill set_orig_insn()->is_swbp_at_addr()
uprobes: Introduce copy_opcode(), kill read_opcode()
uprobes: Kill set_swbp()->is_swbp_at_addr()
uprobes: Restrict valid_vma(false) to skip VM_SHARED vmas
uprobes: Change valid_vma() to demand VM_MAYEXEC rather than VM_EXEC
uprobes: Change write_opcode() to use FOLL_FORCE
uprobes: Move clear_thread_flag(TIF_UPROBE) to uprobe_notify_resume()
uprobes: Kill UTASK_BP_HIT state
uprobes: Fix UPROBE_SKIP_SSTEP checks in handle_swbp()
Pull core kernel fixes from Ingo Molnar:
"Two small fixes"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Documentation: Reflect the new location of the NMI watchdog info
nohz: Fix idle ticks in cpu summary line of /proc/stat
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 fixes from Martin Schwidefsky:
"Among the usual minor bug fixes the more interesting patches are the
perf counters for the latest machine, the missing select to enable
transparent huge pages and a build fix for the UAPI rework."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390,uapi: do not use uapi/asm-generic/kvm_para.h
s390/cache: fix data/instruction cache output
s390: fix linker script for 31 bit builds
s390/thp: select HAVE_ARCH_TRANSPARENT_HUGEPAGE
s390/kdump: Use 64 bit mode for 0x10000 entry point
perf_cpum_cf: Add support for counters available with IBM zEC12
s390/css: stop stsch loop after cc 3
s390/cio: use generic bitmap functions
s390/chpid: make headers usable (again)
git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile
Pull tile fixes from Chris Metcalf:
"This fixes one issue with compiler flags that can cause modules not to
load, and cleans up some warnings with ELF_R_xxx defines."
* 'stable' of git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile: avoid build warnings from duplicate ELF_R_xxx #defines
arch/tile: avoid generating .eh_frame information in modules
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux
Pull ia64 fix from Tony Luck:
"Fix from dhowells for UAPI fallout"
* tag 'please-pull-uapi-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux:
UAPI: Make arch/ia64/include/asm/kvm_para.h generic
These are now provided in <asm-generic/module.h>, so clean up warnings
by not re-defining them in module.c.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
The tile tool chain uses the .eh_frame information for backtracing.
The vmlinux build drops any .eh_frame sections at link time, but when
present in kernel modules, it causes a module load failure due to the
presence of unsupported pc-relative relocations. When compiling to
use compiler feedback support, the compiler by default omits .eh_frame
information, so we don't see this problem. But when not using feedback,
we need to explicitly suppress the .eh_frame.
Cc: stable@vger.kernel.org
Pull drm fixes from Dave Airlie:
"Fixes for intel and nouveau mainly.
- intel: disable HSW by default, sdvo fixes, link train regression
fix
- nouveau: acpi rom loading regression fix, with a few other fixes
from the rework
-core: just other minor fixes and race fixes for ttm."
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (24 commits)
drm/ttm: Fix a theoretical race in ttm_bo_cleanup_refs()
drm: platform: Don't initialize driver-private data
drm/debugfs: remove redundant info from gem_names
drm: fb: cma: Fail gracefully on allocation failure
drm: fb: cma: Fix typo in debug message
drm/nouveau/clock: fix missing pll type/addr when matching default entry
drm/nouveau/fb: fix reporting of memory type on GF8+ IGPs
drm/nv41/vm: don't init hw pciegart on boards with agp bridge
drm/nouveau/bios: fetch full 4KiB block to determine ACPI ROM image size
drm/nouveau: validate vbios size
drm/nouveau: warn when trying to free mm which is still in use
drm/nouveau: fix nouveau_mm/nouveau_mm_node leak
drm/nouveau/bios: improve error handling when reading the vbios from ACPI
drm/nouveau: handle same-fb page flips
drm/i915: Initialize obj->pages before use by i915_gem_object_do_bit17_swizzle()
drm/i915: Add no-lvds quirk for Supermicro X7SPA-H
drm/i915: Insert i915_preliminary_hw_support variable.
drm/i915: shut up spurious WARN in the gtt fault handler
Revert "drm/i915: Try harder to complete DP training pattern 1"
Pull jfs fix from Dave Kleikamp:
"Bug fix: Fix FITRIM argument handling"
* tag 'jfs-3.7-2' of git://github.com/kleikamp/linux-shaggy:
jfs: Fix FITRIM argument handling
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 fixes from Ted Ts'o:
"Various bug fixes for ext4. The most serious of them fixes a security
bug (CVE-2012-4508) which leads to stale data exposure when we have
fallocate racing against writes to files undergoing delayed
allocation. We also have two fixes for the metadata checksum feature,
the most serious of which can cause the superblock to have a invalid
checksum after a power failure."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
ext4: Avoid underflow in ext4_trim_fs()
ext4: Checksum the block bitmap properly with bigalloc enabled
ext4: fix undefined bit shift result in ext4_fill_flex_info
ext4: fix metadata checksum calculation for the superblock
ext4: race-condition protection for ext4_convert_unwritten_extents_endio
ext4: serialize fallocate with ext4_convert_unwritten_extents
Pull NFS client bugfixes from Trond Myklebust:
- Do not call pnfs_return_layout() from an rpciod context
- nfs4_ds_disconnect can cause Oopses. Kill it...
- Fix the return value for nfs_callback_start_svc
- Fix a number of compile warnings
* tag 'nfs-for-3.7-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs:
NFSv4: Fix the return value for nfs_callback_start_svc
NFSv4.1: Declare osd_pri_2_pnfs_err(), objio_init_read/write to be static
NFSv4: fs/nfs/nfs4getroot.c needs to include "internal.h"
NFSv4.1: Use kcalloc() to allocate zeroed arrays instead of kzalloc()
NFSv4.1: Do not call pnfs_return_layout() from an rpciod context
NFSv4.1: Kill nfs4_ds_disconnect()
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap
Pull regmap fix from Mark Brown:
"regmap: Fix for dependencies for MMIO
Trivial dependency issue, not noticed before as the only user of MMIO
also needs I2C."
* tag 'regmap-fix-mmio' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regmap:
regmap: select REGMAP if REGMAP_MMIO and REGMAP_IRQ enabled
In theory, that function could release the lru lock between
checking for bo on ddestroy list and a successful reserve if the bo
was already reserved, and the function was called with waiting reserves
allowed.
However, all current reservers of a bo on the ddestroy list would
atomically take the bo off the list after a successful reserve so this
race should not have been hit, so no need to backport for stable.
This patch also fixes a case found by Maarten Lankhorst where
ttm_mem_evict_first called with no_wait_gpu would incorrectly
spin waiting for bo idle if trying to evict a busy buffer that
also sits on the ddestroy list.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
The ttm_mem_evict_first function could theoretically drop the
lru lock without retrying if a reservation from off the LRU list
ended up waiting.
However, since currently there are no users that could cause a wait
in that situation so this is not suitable for stable
Platform device drivers usually use the driver-private data for their
own purposes. Having it overwritten by drm_platform_init() is confusing
and error-prone.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
It's a relic of "drm: Convert proc files to seq_file and introduce debugfs",
which wrongly converted DRM_INFO + sprintf to 2 seq_printfs.
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: Ben Gamari <bgamari@gmail.com>
Cc: Eric Anholt <eric@anholt.net>
The drm_gem_cma_create() function never returns NULL but rather an error
encoded in the return value using the ERR_PTR() macro. Callers therefore
need to check for errors using the IS_ERR() macro. This change allows
drivers to handle contiguous DMA allocation failures gracefully.
Acked-by: Sascha Hauer <s.hauer@pengutronix.de>
The debug message showing the resolution of a framebuffer to be
allocated is missing a closing parenthesis.
Currently if len argument in ext4_trim_fs() is smaller than one block,
the 'end' variable underflow. Avoid that by returning EINVAL if len is
smaller than file system block.
Also remove useless unlikely().
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
KVM_PV_REASON_PAGE_NOT_PRESENT kicks cpu out of idleness, but we haven't
marked that spot as an exit from idleness.
Not doing so can cause RCU warnings such as:
[ 732.788386] ===============================
[ 732.789803] [ INFO: suspicious RCU usage. ]
[ 732.790032] 3.7.0-rc1-next-20121019-sasha-00002-g6d8d02d-dirty #63 Tainted: G W
[ 732.790032] -------------------------------
[ 732.790032] include/linux/rcupdate.h:738 rcu_read_lock() used illegally while idle!
[ 732.790032]
[ 732.790032] other info that might help us debug this:
[ 732.790032]
[ 732.790032]
[ 732.790032] RCU used illegally from idle CPU!
[ 732.790032] rcu_scheduler_active = 1, debug_locks = 1
[ 732.790032] RCU used illegally from extended quiescent state!
[ 732.790032] 2 locks held by trinity-child31/8252:
[ 732.790032] #0: (&rq->lock){-.-.-.}, at: [<ffffffff83a67528>] __schedule+0x178/0x8f0
[ 732.790032] #1: (rcu_read_lock){.+.+..}, at: [<ffffffff81152bde>] cpuacct_charge+0xe/0x200
[ 732.790032]
[ 732.790032] stack backtrace:
[ 732.790032] Pid: 8252, comm: trinity-child31 Tainted: G W 3.7.0-rc1-next-20121019-sasha-00002-g6d8d02d-dirty #63
[ 732.790032] Call Trace:
[ 732.790032] [<ffffffff8118266b>] lockdep_rcu_suspicious+0x10b/0x120
[ 732.790032] [<ffffffff81152c60>] cpuacct_charge+0x90/0x200
[ 732.790032] [<ffffffff81152bde>] ? cpuacct_charge+0xe/0x200
[ 732.790032] [<ffffffff81158093>] update_curr+0x1a3/0x270
[ 732.790032] [<ffffffff81158a6a>] dequeue_entity+0x2a/0x210
[ 732.790032] [<ffffffff81158ea5>] dequeue_task_fair+0x45/0x130
[ 732.790032] [<ffffffff8114ae29>] dequeue_task+0x89/0xa0
[ 732.790032] [<ffffffff8114bb9e>] deactivate_task+0x1e/0x20
[ 732.790032] [<ffffffff83a67c29>] __schedule+0x879/0x8f0
[ 732.790032] [<ffffffff8117e20d>] ? trace_hardirqs_off+0xd/0x10
[ 732.790032] [<ffffffff810a37a5>] ? kvm_async_pf_task_wait+0x1d5/0x2b0
[ 732.790032] [<ffffffff83a67cf5>] schedule+0x55/0x60
[ 732.790032] [<ffffffff810a37c4>] kvm_async_pf_task_wait+0x1f4/0x2b0
[ 732.790032] [<ffffffff81139e50>] ? abort_exclusive_wait+0xb0/0xb0
[ 732.790032] [<ffffffff81139c25>] ? prepare_to_wait+0x25/0x90
[ 732.790032] [<ffffffff810a3a66>] do_async_page_fault+0x56/0xa0
[ 732.790032] [<ffffffff83a6a6e8>] async_page_fault+0x28/0x30
Acked-by: Gleb Natapov <gleb@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Reviewed-by: Chegu Vinod <chegu_vinod@hp.com>
Tested-by: Chegu Vinod <chegu_vinod@hp.com>
We can not directly call kvm_release_pfn_clean to release the pfn
since we can meet noslot pfn which is used to cache mmio info into
spte
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
git://git.freedesktop.org/git/nouveau/linux-2.6 into drm-fixes
Fixes from Ben, off note:
ACPI ROM regression fix,
some IGP and AGP regressions fixes from rework fallout.
* 'drm-nouveau-fixes' of git://git.freedesktop.org/git/nouveau/linux-2.6:
Fix the warning:
kernel/module_signing.c:195:2: warning: format '%lu' expects type 'long unsigned int', but argument 3 has type 'size_t'
by using the proper 'z' modifier for printing a size_t.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
Pull m68k updates from Geert Uytterhoeven:
"Just the expected UAPI disintegration and the "new" kcmp syscall."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k: Wire up kcmp
m68k: Remove empty #ifdef/#else/#endif block
UAPI: (Scripted) Disintegrate arch/m68k/include/asm
Commit 7f8d4cad1e4e ("Input: extend the number of event (and other)
devices") made evdev, joydev and mousedev to embed struct cdev into
their respective structures representing input devices.
Unfortunately character device structure may outlive the parent
structure unless we do not set it up as parent of character device so
that it will stay pinned until character device is freed.
Also, now that parent structure is pinned while character device exists
we do not need to pin and unpin it every time user opens or closes it.
Reported-by: Dave Jones <davej@redhat.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
In certain cases (for example when a cdev structure is embedded into
another object whose lifetime is controlled by a separate kobject) it is
beneficial to tie lifetime of another object to the lifetime of
character device so that related object is not freed until after
char_dev object is freed.
To achieve this let's pin kobject's parent when doing cdev_add() and
unpin when last reference to cdev structure is being released.
This issue is a regression from 70790f4f819875e8f390871fd15bbbf823f28e1b,
and causes us to miss a special-case for C51 (NV4E) chipsets and return
the wrong reference frequency for the VPLLs.
Should fix fdo#56202
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
In mke2fs, we only checksum the whole bitmap block and it is right.
While in the kernel, we use EXT4_BLOCKS_PER_GROUP to indicate the
size of the checksumed bitmap which is wrong when we enable bigalloc.
The right size should be EXT4_CLUSTERS_PER_GROUP and this patch fixes
it.
Also as every caller of ext4_block_bitmap_csum_set and
ext4_block_bitmap_csum_verify pass in EXT4_BLOCKS_PER_GROUP(sb)/8,
we'd better removes this parameter and sets it in the function itself.
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
Purely a cosmetic issue at this point.
Buggy firmware leads to bad things happening otherwise..
Without checking, we could detect vbios size as 0, allocate 0-byte array
(kmalloc returns invalid pointer for such allocation) and crash in
nouveau_bios_score while checking for vbios signature.
Reported-by: Heinz Diehl <htd@fritha.org>
v2: use already existing parent
Reported-by: Pawel Sikora <pawel.sikora@agmk.net>
Signed-off-by: Martin Peres <martin.peres@labri.fr>
It's questionable use case, but weston/wayland already relies on this
behaviour, and other drivers don't care about it, so it's a matter of
compatibility. Without it, process invoking such page flip hangs in
unkillable state, trying to reserve the same buffer twice.
git://people.freedesktop.org/~danvet/drm-intel into drm-fixes
Daniel writes:
The big thing is the disabling of the hsw support by default, cc: stable.
We've aimed for basic hsw support in 3.6, but due to a few bad
happenstances we've screwed up and only 3.8 will have better modeset
support than vesa. To avoid yet another round of fallout from such a
gaffle on for the next platform we've added a module option to disable
early hw support by default. That should also give us more flexibility in
bring-up.
Otherwise just small fixes:
- 3 fixes from Egbert for sdvo corner cases
- invert-brightness quirk entry from Egbert
- revert a dp link training change, it regresses some setups
- and shut up a spurious WARN in our gem fault handler.
- regression fix for an oops on bit17 swizzling machines, introduce in 3.7
- another no-lvds quirk
* 'drm-intel-fixes' of git://people.freedesktop.org/~danvet/drm-intel:
DRM/i915: Restore sdvo_flags after dtd->mode->dtd Roundrtrip.
DRM/i915: Don't clone SDVO LVDS with analog.
DRM/i915: Add QUIRK_INVERT_BRIGHTNESS for NCR machines.
DRM/i915: Don't delete DPLL Multiplier during DAC init.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/urgent
Pull ftrace ring-buffer resizing fix from Steve Rostedt.
Commit 9919cba7 ("watchdog: Update documentation") moved the
NMI watchdog documentation from nmi_watchdog.txt to
lockup-watchdogs.txt. Update the index file accordingly.
Cc: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/r/20121021120551.4656d99b@endymion.delvare
git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc into perf/urgent
Pull various uprobes bugfixes from Oleg Nesterov - mostly race and
failure path fixes.
git://git.kernel.org/pub/scm/linux/kernel/git/rric/oprofile into perf/urgent
Pull event-wrapping Oprofile fix from Robert Richter.
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64
Pull arm64 fixes from Catalin Marinas:
"Main changes:
- AArch64 Linux compilation fixes following 3.7-rc1 changes
(MODULES_USE_ELF_RELA, update_vsyscall() prototype)
- Unnecessary register setting in start_thread() (thanks to Al Viro)
- ptrace fixes"
* tag 'arm64-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64:
arm64: fix alignment padding in assembly code
arm64: ptrace: use HW_BREAKPOINT_EMPTY type for disabled breakpoints
arm64: ptrace: make structure padding explicit for debug registers
arm64: No need to set the x0-x2 registers in start_thread()
arm64: Ignore memory blocks below PHYS_OFFSET
arm64: Fix the update_vsyscall() prototype
arm64: Select MODULES_USE_ELF_RELA
arm64: Remove duplicate inclusion of mmu_context.h in smp.c
An interesting effect of using the generic version of linkage.h
is that the padding is defined in terms of x86 NOPs, which can have
even more interesting effects when the assembly code looks like this:
ENTRY(func1)
mov x0, xzr
ENDPROC(func1)
// fall through
ENTRY(func2)
mov x0, #1
ret
ENDPROC(func2)
Admittedly, the code is not very nice. But having code from another
architecture doesn't look completely sane either.
The fix is to add arm64's version of linkage.h, which causes the insertion
of proper AArch64 NOPs.
Initializing uncore PMU on virtualized CPU may hang the kernel.
This is because kvm does not emulate the entire hardware. Thers
are lots of uncore related MSRs, making kvm enumerate them all
is a non-trival task. So just disable uncore on virtualized CPU.
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
Tested-by: Pekka Enberg <penberg@kernel.org>
Cc: a.p.zijlstra@chello.nl
Cc: eranian@google.com
Cc: andi@firstfloor.org
Cc: avi@redhat.com
Link: http://lkml.kernel.org/r/1345540117-14164-1-git-send-email-zheng.z.yan@intel.com
