2013-03-12workqueue: add wokrqueue_struct->maydays list to replace mayday cpu iteratorsTejun Heo
Similar to how pool_workqueue iteration used to be, raising and servicing mayday requests is based on CPU numbers. It's hairy because cpumask_t may not be able to handle WORK_CPU_UNBOUND and cpumasks are assumed to be always set on UP. This is ugly and can't handle multiple unbound pools to be added for unbound workqueues w/ custom attributes. Add workqueue_struct->maydays. When a pool_workqueue needs rescuing, it gets chained on the list through pool_workqueue->mayday_node and rescuer_thread() consumes the list until it's empty. This patch doesn't introduce any visible behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: restructure pool / pool_workqueue iterations in freeze/thaw functionsTejun Heo
The three freeze/thaw related functions - freeze_workqueues_begin(), freeze_workqueues_busy() and thaw_workqueues() - need to iterate through all pool_workqueues of all freezable workqueues. They did it by first iterating pools and then visiting all pwqs (pool_workqueues) of all workqueues and process it if its pwq->pool matches the current pool. This is rather backwards and done this way partly because workqueue didn't have fitting iteration helpers and partly to avoid the number of lock operations on pool->lock. Workqueue now has fitting iterators and the locking operation overhead isn't anything to worry about - those locks are unlikely to be contended and the same CPU visiting the same set of locks multiple times isn't expensive. Restructure the three functions such that the flow better matches the logical steps and pwq iteration is done using for_each_pwq() inside workqueue iteration. * freeze_workqueues_begin(): Setting of FREEZING is moved into a separate for_each_pool() iteration. pwq iteration for clearing max_active is updated as described above. * freeze_workqueues_busy(): pwq iteration updated as described above. * thaw_workqueues(): The single for_each_wq_cpu() iteration is broken into three discrete steps - clearing FREEZING, restoring max_active, and kicking workers. The first and last steps use for_each_pool() and the second step uses pwq iteration described above. This makes the code easier to understand and removes the use of for_each_wq_cpu() for walking pwqs, which can't support multiple unbound pwqs which will be needed to implement unbound workqueues with custom attributes. This patch doesn't introduce any visible behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: introduce for_each_pool()Tejun Heo
With the scheduled unbound pools with custom attributes, there will be multiple unbound pools, so it wouldn't be able to use for_each_wq_cpu() + for_each_std_worker_pool() to iterate through all pools. Introduce for_each_pool() which iterates through all pools using worker_pool_idr and use it instead of for_each_wq_cpu() + for_each_std_worker_pool() combination in freeze_workqueues_begin(). Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: replace for_each_pwq_cpu() with for_each_pwq()Tejun Heo
Introduce for_each_pwq() which iterates all pool_workqueues of a workqueue using the recently added workqueue->pwqs list and replace for_each_pwq_cpu() usages with it. This is primarily to remove the single unbound CPU assumption from pwq iteration for the scheduled unbound pools with custom attributes support which would introduce multiple unbound pwqs per workqueue; however, it also simplifies iterator users. Note that pwq->pool initialization is moved to alloc_and_link_pwqs() as that now is the only place which is explicitly handling the two pwq types. This patch doesn't introduce any visible behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: add workqueue_struct->pwqs listTejun Heo
Add workqueue_struct->pwqs list and chain all pool_workqueues belonging to a workqueue there. This will be used to implement generic pool_workqueue iteration and handle multiple pool_workqueues for the scheduled unbound pools with custom attributes. This patch doesn't introduce any visible behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: introduce kmem_cache for pool_workqueuesTejun Heo
pool_workqueues need to be aligned to 1 << WORK_STRUCT_FLAG_BITS as the lower bits of work->data are used for flags when they're pointing to pool_workqueues. Due to historical reasons, unbound pool_workqueues are allocated using kzalloc() with sufficient buffer area for alignment and aligned manually. The original pointer is stored at the end which free_pwqs() retrieves when freeing it. There's no reason for this hackery anymore. Set alignment of struct pool_workqueue to 1 << WORK_STRUCT_FLAG_BITS, add kmem_cache for pool_workqueues with proper alignment and replace the hacky alloc and free implementation with plain kmem_cache_zalloc/free(). In case WORK_STRUCT_FLAG_BITS gets shrunk too much and makes fields of pool_workqueues misaligned, trigger WARN if the alignment of struct pool_workqueue becomes smaller than that of long long. Note that assertion on IS_ALIGNED() is removed from alloc_pwqs(). We already have another one in pwq init loop in __alloc_workqueue_key(). This patch doesn't introduce any visible behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: make workqueue_lock irq-safeTejun Heo
workqueue_lock will be used to synchronize areas which require irq-safety and there isn't much benefit in keeping it not irq-safe. Make it irq-safe. This patch doesn't introduce any visible behavior changes. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-12workqueue: make sanity checks less punshing using WARN_ON[_ONCE]()sTejun Heo
Workqueue has been using mostly BUG_ON()s for sanity checks, which fail unnecessarily harshly when the assertion doesn't hold. Most assertions can converted to be less drastic such that things can limp along instead of dying completely. Convert BUG_ON()s to WARN_ON[_ONCE]()s with softer failure behaviors - e.g. if assertion check fails in destroy_worker(), trigger WARN and silently ignore destruction request. Most conversions are trivial. Note that sanity checks in destroy_workqueue() are moved above removal from workqueues list so that it can bail out without side-effects if assertion checks fail. This patch doesn't introduce any visible behavior changes during normal operation. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2013-03-04workqueue: better define synchronization rule around rescuer->pool updatesLai Jiangshan
Rescuers visit different worker_pools to process work items from pools under pressure. Currently, rescuer->pool is updated outside any locking and when an outsider looks at a rescuer, there's no way to tell when and whether rescuer->pool is gonna change. While this doesn't currently cause any problem, it is nasty. With recent worker_maybe_bind_and_lock() changes, we can move rescuer->pool updates inside pool locks such that if rescuer->pool equals a locked pool, it's guaranteed to stay that way until the pool is unlocked. Move rescuer->pool inside pool->lock. This patch doesn't introduce any visible behavior difference. tj: Updated the description. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-04workqueue: change argument of worker_maybe_bind_and_lock() to @poolLai Jiangshan
worker_maybe_bind_and_lock() currently takes @worker but only cares about @worker->pool. This patch updates worker_maybe_bind_and_lock() to take @pool instead of @worker. This will be used to better define synchronization rules regarding rescuer->pool updates. This doesn't introduce any functional change. tj: Updated the comments and description. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-04workqueue: use %current instead of worker->task in worker_maybe_bind_and_lock()Lai Jiangshan
worker_maybe_bind_and_lock() uses both @worker->task and @current at the same time. As worker_maybe_bind_and_lock() can only be called by the current worker task, they are always the same. Update worker_maybe_bind_and_lock() to use %current consistently. This doesn't introduce any functional change. tj: Massaged the description. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-04workqueue: allow more off-queue flag spaceLai Jiangshan
When a work item is off-queue, its work->data contains WORK_STRUCT_* and WORK_OFFQ_* flags. As WORK_OFFQ_* flags are used only while a work item is off-queue, it can occupy bits of work->data which aren't used while off-queue. WORK_OFFQ_* currently only use bits used by on-queue CWQ pointer. As color bits aren't used while off-queue, there's no reason to not use them. Lower WORK_OFFQ_FLAG_BASE from WORK_STRUCT_FLAG_BITS to WORK_STRUCT_COLOR_SHIFT thus giving 4 more bits to off-queue flag space which is also used to record worker_pool ID while off-queue. This doesn't introduce any visible behavior difference. tj: Rewrote the description. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2013-03-03Linux 3.9-rc1v3.9-rc1Linus Torvalds
2013-03-03Merge tag 'disintegrate-fbdev-20121220' of ↵Linus Torvalds
git://git.infradead.org/users/dhowells/linux-headers Pull fbdev UAPI disintegration from David Howells: "You'll be glad to here that the end is nigh for the UAPI patches. Only the fbdev/framebuffer piece remains now that the SCSI stuff has gone in. Here are the UAPI disintegration bits for the fbdev drivers. It appears that Florian hasn't had time to deal with my patch, but back in December he did say he didn't mind if I pushed it forward." Yay. No more uapi movement. And hopefully no more big header file cleanups coming up either, it just tends to be very painful. * tag 'disintegrate-fbdev-20121220' of git://git.infradead.org/users/dhowells/linux-headers: UAPI: (Scripted) Disintegrate include/video
2013-03-03Merge tag 'stable/for-linus-3.9-rc1-tag' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Pull Xen bug-fixes from Konrad Rzeszutek Wilk: - Update the Xen ACPI memory and CPU hotplug locking mechanism. - Fix PAT issues wherein various applications would not start - Fix handling of multiple MSI as AHCI now does it. - Fix ARM compile failures. * tag 'stable/for-linus-3.9-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xenbus: fix compile failure on ARM with Xen enabled xen/pci: We don't do multiple MSI's. xen/pat: Disable PAT using pat_enabled value. xen/acpi: xen cpu hotplug minor updates xen/acpi: xen memory hotplug minor updates
2013-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more VFS bits from Al Viro: "Unfortunately, it looks like xattr series will have to wait until the next cycle ;-/ This pile contains 9p cleanups and fixes (races in v9fs_fid_add() etc), fixup for nommu breakage in shmem.c, several cleanups and a bit more file_inode() work" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: constify path_get/path_put and fs_struct.c stuff fix nommu breakage in shmem.c cache the value of file_inode() in struct file 9p: if v9fs_fid_lookup() gets to asking server, it'd better have hashed dentry 9p: make sure ->lookup() adds fid to the right dentry 9p: untangle ->lookup() a bit 9p: double iput() in ->lookup() if d_materialise_unique() fails 9p: v9fs_fid_add() can't fail now v9fs: get rid of v9fs_dentry 9p: turn fid->dlist into hlist 9p: don't bother with private lock in ->d_fsdata; dentry->d_lock will do just fine more file_inode() open-coded instances selinux: opened file can't have NULL or negative ->f_path.dentry (In the meantime, the hlist traversal macros have changed, so this required a semantic conflict fixup for the newly hlistified fid->dlist)
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixup from Chris Mason: "Geert and James both sent this one in, sorry guys" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs/raid56: Add missing #include <linux/vmalloc.h>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull second set of s390 patches from Martin Schwidefsky: "The main part of this merge are Heikos uaccess patches. Together with commit 09884964335e ("mm: do not grow the stack vma just because of an overrun on preceding vma") the user string access is hopefully fixed for good. In addition some bug fixes and two cleanup patches." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/module: fix compile warning qdio: remove unused parameters s390/uaccess: fix kernel ds access for page table walk s390/uaccess: fix strncpy_from_user string length check input: disable i8042 PC Keyboard controller for s390 s390/dis: Fix invalid array size s390/uaccess: remove pointless access_ok() checks s390/uaccess: fix strncpy_from_user/strnlen_user zero maxlen case s390/uaccess: shorten strncpy_from_user/strnlen_user s390/dasd: fix unresponsive device after all channel paths were lost s390/mm: ignore change bit for vmemmap s390/page table dumper: add support for change-recording override bit
2013-03-03Merge branch 'fixes-for-3.9-latest' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull second round of PARISC updates from Helge Deller: "The most important fix in this branch is the switch of io_setup, io_getevents and io_submit syscalls to use the available compat syscalls when running 32bit userspace on 64bit kernel. Other than that it's mostly removal of compile warnings." * 'fixes-for-3.9-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: fix redefinition of SET_PERSONALITY parisc: do not install modules when installing kernel parisc: fix compile warnings triggered by atomic_sub(sizeof(),v) parisc: check return value of down_interruptible() in hp_sdc_rtc.c parisc: avoid unitialized variable warning in pa_memcpy() parisc: remove unused variable 'compat_val' parisc: switch to compat_functions of io_setup, io_getevents and io_submit parisc: select ARCH_WANT_FRAME_POINTERS
2013-03-03Merge tag 'metag-v3.9-rc1-v4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag Pull new ImgTec Meta architecture from James Hogan: "This adds core architecture support for Imagination's Meta processor cores, followed by some later miscellaneous arch/metag cleanups and fixes which I kept separate to ease review: - Support for basic Meta 1 (ATP) and Meta 2 (HTP) core architecture - A few fixes all over, particularly for symbol prefixes - A few privilege protection fixes - Several cleanups (setup.c includes, split out a lot of metag_ksyms.c) - Fix some missing exports - Convert hugetlb to use vm_unmapped_area() - Copy device tree to non-init memory - Provide dma_get_sgtable()" * tag 'metag-v3.9-rc1-v4' of git://git.kernel.org/pub/scm/linux/kernel/git/jhogan/metag: (61 commits) metag: Provide dma_get_sgtable() metag: prom.h: remove declaration of metag_dt_memblock_reserve() metag: copy devicetree to non-init memory metag: cleanup metag_ksyms.c includes metag: move mm/init.c exports out of metag_ksyms.c metag: move usercopy.c exports out of metag_ksyms.c metag: move setup.c exports out of metag_ksyms.c metag: move kick.c exports out of metag_ksyms.c metag: move traps.c exports out of metag_ksyms.c metag: move irq enable out of irqflags.h on SMP genksyms: fix metag symbol prefix on crc symbols metag: hugetlb: convert to vm_unmapped_area() metag: export clear_page and copy_page metag: export metag_code_cache_flush_all metag: protect more non-MMU memory regions metag: make TXPRIVEXT bits explicit metag: kernel/setup.c: sort includes perf: Enable building perf tools for Meta metag: add boot time LNKGET/LNKSET check metag: add __init to metag_cache_probe() ...
2013-03-03Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull late ARM updates from Russell King: "Here is the late set of ARM updates for this merge window; in here is: - The ARM parts of the broadcast timer support, core parts merged through tglx's tree. This was left over from the previous merge to allow the dependency on tglx's tree to be resolved. - A fix to the VFP code which shows up on Raspberry Pi's, as well as fixing the fallout from a previous commit in this area. - A number of smaller fixes scattered throughout the ARM tree" * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: ARM: Fix broken commit 0cc41e4a21d43 corrupting kernel messages ARM: fix scheduling while atomic warning in alignment handling code ARM: VFP: fix emulation of second VFP instruction ARM: 7656/1: uImage: Error out on build of multiplatform without LOADADDR ARM: 7640/1: memory: tegra_ahb_enable_smmu() depends on TEGRA_IOMMU_SMMU ARM: 7654/1: Preserve L_PTE_VALID in pte_modify() ARM: 7653/2: do not scale loops_per_jiffy when using a constant delay clock ARM: 7651/1: remove unused smp_timer_broadcast #define
2013-03-03Merge tag 'char-misc-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc patch from Greg Kroah-Hartman: "Here is one remaining patch for 3.9-rc1. It is for the hyper-v drivers, and had to wait until some other patches went in through the x86 tree." Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> * tag 'char-misc-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: Drivers: hv: vmbus: Use the new infrastructure for delivering VMBUS interrupts
2013-03-03Merge tag 'usb-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patch revert from Greg Kroah-Hartman: "Here is one remaining USB patch for 3.9-rc1, it reverts a 3.8 patch that has caused a lot of regressions for some VIA EHCI controllers." * tag 'usb-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: USB: EHCI: revert "remove ASS/PSS polling timeout"
2013-03-03Merge git://www.linux-watchdog.org/linux-watchdogLinus Torvalds
Pull watchdog updates from Wim Van Sebroeck: "This contains: - fixes and improvements - devicetree bindings - conversion to watchdog generic framework of the following drivers: - booke_wdt - bcm47xx_wdt.c - at91sam9_wdt - Removal of old STMP3xxx driver - Addition of following new drivers: - new driver for STMP3xxx and i.MX23/28 - Retu watchdog driver" * git://www.linux-watchdog.org/linux-watchdog: (30 commits) watchdog: sp805_wdt depends on ARM watchdog: davinci_wdt: update to devm_* API watchdog: davinci_wdt: use devm managed clk get watchdog: at91rm9200: add DT support watchdog: add timeout-sec property binding watchdog: at91sam9_wdt: Convert to use the watchdog framework watchdog: omap_wdt: Add option nowayout watchdog: core: dt: add support for the timeout-sec dt property watchdog: bcm47xx_wdt.c: add hard timer watchdog: bcm47xx_wdt.c: rename wdt_time to timeout watchdog: bcm47xx_wdt.c: rename ops methods watchdog: bcm47xx_wdt.c: use platform device watchdog: bcm47xx_wdt.c: convert to watchdog core api watchdog: Convert BookE watchdog driver to watchdog infrastructure watchdog: s3c2410_wdt: Use devm_* functions watchdog: remove old STMP3xxx driver watchdog: add new driver for STMP3xxx and i.MX23/28 rtc: stmp3xxx: add wdt-accessor function watchdog: introduce retu_wdt driver watchdog: intel_scu_watchdog: fix Kconfig dependency ...
2013-03-03Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull second set of slave-dmaengine updates from Vinod Koul: "Arnd's patch moves the dw_dmac to use generic DMA binding. I agreed to merge this late as it will avoid the conflicts between trees. The second patch from Matt adding a dma_request_slave_channel_compat API was supposed to be picked up, but somehow never got picked up. Some patches dependent on this are already in -next :(" * 'next' of git://git.infradead.org/users/vkoul/slave-dma: dmaengine: dw_dmac: move to generic DMA binding dmaengine: add dma_request_slave_channel_compat()
2013-03-03Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform driver updates from Matthew Garrett: "Mostly relatively small updates, along with some hardware enablement for Sony hardware and a pile of updates to Google's Chromebook driver" * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: (49 commits) ideapad-laptop: Depend on BACKLIGHT_CLASS_DEVICE instead of selecting it ideapad: depends on backlight subsystem and update comment Platform: x86: chromeos_laptop - add i915 gmbuses to adapter names Platform: x86: chromeos_laptop - Add isl light sensor for Pixel Platform: x86: chromeos_laptop - Add a more general add_i2c_device Platform: x86: chromeos_laptop - Add Pixel Touchscreen Platform: x86: chromeos_laptop - Add support for probing devices Platform: x86: chromeos_laptop - Add Pixel Trackpad hp-wmi: fix handling of platform device sony-laptop: leak in error handling sony_nc_lid_resume_setup() hp-wmi: Add support for SMBus hotkeys asus-wmi: Fix unused function build warning acer-wmi: avoid the warning of 'devices' may be used uninitialized drivers/platform/x86/thinkpad_acpi.c: Handle HKEY event 0x6040 Platform: x86: chromeos_laptop - Add HP Pavilion 14 Platform: x86: chromeos_laptop - Add Taos tsl2583 device Platform: x86: chromeos_laptop - Add Taos tsl2563 device Platform: x86: chromeos_laptop - Add Acer C7 trackpad Platform: x86: chromeos_laptop - Rename setup_lumpy_tp to setup_cyapa_smbus_tp asus-laptop: always report brightness key events ...
2013-03-03btrfs/raid56: Add missing #include <linux/vmalloc.h>Geert Uytterhoeven
tilegx_defconfig: fs/btrfs/raid56.c: In function 'btrfs_alloc_stripe_hash_table': fs/btrfs/raid56.c:206:3: error: implicit declaration of function 'vzalloc' [-Werror=implicit-function-declaration] fs/btrfs/raid56.c:206:9: warning: assignment makes pointer from integer without a cast [enabled by default] fs/btrfs/raid56.c:226:4: error: implicit declaration of function 'vfree' [-Werror=implicit-function-declaration] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-03-02Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 bug fixes from Ted Ts'o: "Various bug fixes for ext4. The most important is a fix for the new extent cache's slab shrinker which can cause significant, user-visible pauses when the system is under memory pressure." * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: enable quotas before orphan cleanup ext4: don't allow quota mount options when quota feature enabled ext4: fix a warning from sparse check for ext4_dir_llseek ext4: convert number of blocks to clusters properly ext4: fix possible memory leak in ext4_remount() jbd2: fix ERR_PTR dereference in jbd2__journal_start ext4: use percpu counter for extent cache count ext4: optimize ext4_es_shrink()
2013-03-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull sigprocmask compat fix from Al Viro: "generic compat_sys_rt_sigprocmask() had a very dumb braino; I'd spent quite a while staring at the offending commit before finally managing to spot the idiocy ;-/" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: fix compat_sys_rt_sigprocmask()
2013-03-02fix compat_sys_rt_sigprocmask()Al Viro
Converting bitmask to 32bit granularity is fine, but we'd better _do_ something with the result. Such as "copy it to userland"... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-03-02Merge tag 'nfs-for-3.9-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "We've just concluded another Connectathon interoperability testing week, and so here are the fixes for the bugs that were discovered: - Don't allow NFS silly-renamed files to be deleted - Don't start the retransmission timer when out of socket space - Fix a couple of pnfs-related Oopses. - Fix one more NFSv4 state recovery deadlock - Don't loop forever when LAYOUTGET returns NFS4ERR_LAYOUTTRYLATER" * tag 'nfs-for-3.9-2' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: SUNRPC: One line comment fix NFSv4.1: LAYOUTGET EDELAY loops timeout to the MDS SUNRPC: add call to get configured timeout PNFS: set the default DS timeout to 60 seconds NFSv4: Fix another open/open_recovery deadlock nfs: don't allow nfs_find_actor to match inodes of the wrong type NFSv4.1: Hold reference to layout hdr in layoutget pnfs: fix resend_to_mds for directio SUNRPC: Don't start the retransmission timer when out of socket space NFS: Don't allow NFS silly-renamed files to be deleted, no signal
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs update from Chris Mason: "The biggest feature in the pull is the new (and still experimental) raid56 code that David Woodhouse started long ago. I'm still working on the parity logging setup that will avoid inconsistent parity after a crash, so this is only for testing right now. But, I'd really like to get it out to a broader audience to hammer out any performance issues or other problems. scrub does not yet correct errors on raid5/6 either. Josef has another pass at fsync performance. The big change here is to combine waiting for metadata with waiting for data, which is a big latency win. It is also step one toward using atomics from the hardware during a commit. Mark Fasheh has a new way to use btrfs send/receive to send only the metadata changes. SUSE is using this to make snapper more efficient at finding changes between snapshosts. Snapshot-aware defrag is also included. Otherwise we have a large number of fixes and cleanups. Eric Sandeen wins the award for removing the most lines, and I'm hoping we steal this idea from XFS over and over again." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (118 commits) btrfs: fixup/remove module.h usage as required Btrfs: delete inline extents when we find them during logging btrfs: try harder to allocate raid56 stripe cache Btrfs: cleanup to make the function btrfs_delalloc_reserve_metadata more logic Btrfs: don't call btrfs_qgroup_free if just btrfs_qgroup_reserve fails Btrfs: remove reduplicate check about root in the function btrfs_clean_quota_tree Btrfs: return ENOMEM rather than use BUG_ON when btrfs_alloc_path fails Btrfs: fix missing deleted items in btrfs_clean_quota_tree btrfs: use only inline_pages from extent buffer Btrfs: fix wrong reserved space when deleting a snapshot/subvolume Btrfs: fix wrong reserved space in qgroup during snap/subv creation Btrfs: remove unnecessary dget_parent/dput when creating the pending snapshot btrfs: remove a printk from scan_one_device Btrfs: fix NULL pointer after aborting a transaction Btrfs: fix memory leak of log roots Btrfs: copy everything if we've created an inline extent btrfs: cleanup for open-coded alignment Btrfs: do not change inode flags in rename Btrfs: use reserved space for creating a snapshot clear chunk_alloc flag on retryable failure ...
2013-03-02Merge tag 'for-linus-20130301' of git://git.infradead.org/linux-mtdLinus Torvalds
Pull MTD update from David Woodhouse: "Fairly unexciting MTD merge for 3.9: - misc clean-ups in the MTD command-line partitioning parser (cmdlinepart) - add flash locking support for STmicro chips serial flash chips, as well as for CFI command set 2 chips. - new driver for the ELM error correction HW module found in various TI chips, enable the OMAP NAND driver to use the ELM HW error correction - added number of new serial flash IDs - various fixes and improvements in the gpmi NAND driver - bcm47xx NAND driver improvements - make the mtdpart module actually removable" * tag 'for-linus-20130301' of git://git.infradead.org/linux-mtd: (45 commits) mtd: map: BUG() in non handled cases mtd: bcm47xxnflash: use pr_fmt for module prefix in messages mtd: davinci_nand: Use managed resources mtd: mtd_torturetest can cause stack overflows mtd: physmap_of: Convert device allocation to managed devm_kzalloc() mtd: at91: atmel_nand: for PMECC, add code to check the ONFI parameter ECC requirement. mtd: atmel_nand: make pmecc-cap, pmecc-sector-size in dts is optional. mtd: atmel_nand: avoid to report an error when lookup table offset is 0. mtd: bcm47xxsflash: adjust names of bus-specific functions mtd: bcm47xxpart: improve probing of nvram partition mtd: bcm47xxpart: add support for other erase sizes mtd: bcm47xxnflash: register this as normal driver mtd: bcm47xxnflash: fix message mtd: bcm47xxsflash: register this as normal driver mtd: bcm47xxsflash: write number of written bytes mtd: gpmi: add sanity check for the ECC mtd: gpmi: set the Golois Field bit for mx6q's BCH mtd: devices: elm: Removes <xx> literals in elm DT node mtd: gpmi: fix a dereferencing freed memory error mtd: fix the wrong timeo for panic_nand_wait() ...
2013-03-03Merge branches 'devel-stable', 'fixes' and 'mmci' into for-linusRussell King
2013-03-02SUNRPC: One line comment fixTrond Myklebust
Reported-by: Weston Andros Adamson <dros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2013-03-02ext4: enable quotas before orphan cleanupJan Kara
When using quota feature we need to enable quotas before orphan cleanup so that changes happening during it are properly reflected in quota accounting. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-03-02ext4: don't allow quota mount options when quota feature enabledJan Kara
So far we silently ignored when quota mount options were set while quota feature was enabled. But this can create confusion in userspace when mount options are set but silently ignored and also creates opportunities for bugs when we don't properly test all quota types. Actually ext4_mark_dquot_dirty() forgets to test for quota feature so it was dependent on journaled quota options being set. OTOH ext4_orphan_cleanup() tries to enable journaled quota when quota options are specified which is wrong when quota feature is enabled. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-03-02ext4: fix a warning from sparse check for ext4_dir_llseekZheng Liu
ext4_dir_llseek is only used as a callback function, and no one calls it directly. So make it as a static function in order to remove a warning message from sparse check. Signed-off-by: Zheng Liu <wenqing.lz@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-03-02ext4: convert number of blocks to clusters properlyLukas Czerner
We're using macro EXT4_B2C() to convert number of blocks to number of clusters for bigalloc file systems. However, we should be using EXT4_NUM_B2C(). Signed-off-by: Lukas Czerner <lczerner@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org
2013-03-02ext4: fix possible memory leak in ext4_remount()Wei Yongjun
'orig_data' is malloced in ext4_remount() and should be freed before leaving from the error handling cases, otherwise it will cause memory leak. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Lukas Czerner <lczerner@redhat.com> Cc: stable@vger.kernel.org
2013-03-02jbd2: fix ERR_PTR dereference in jbd2__journal_startDmitry Monakhov
If start_this_handle() failed handle will be initialized to ERR_PTR() and can not be dereferenced. paging request at fffffffffffffff6 IP: [<ffffffff813c073f>] jbd2__journal_start+0x18f/0x290 PGD 200e067 PUD 200f067 PMD 0 Oops: 0000 [#1] SMP Modules linked in: cpufreq_ondemand acpi_cpufreq freq_table mperf coretemp kvm_intel kvm crc32c_intel ghash_clmulni_intel microcode sg xhci_hcd button sd_mod crc_t10dif aesni_intel ablk_helper cryptd lrw aes_x86_64 xts gf128mul ahci libahci pata_acpi ata_generic dm_mirror dm_region_hash dm_log dm_mod CPU 0 journal commit I/O error Pid: 2694, comm: fio Not tainted 3.8.0-rc3+ #79 /DQ67SW RIP: 0010:[<ffffffff813c073f>] [<ffffffff813c073f>] jbd2__journal_start+0x18f/0x290 RSP: 0018:ffff880233b8ba58 EFLAGS: 00010292 RAX: 00000000ffffffe2 RBX: ffffffffffffffe2 RCX: 0000000000000006 RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffffffff82128f48 RBP: ffff880233b8ba98 R08: 0000000000000000 R09: ffff88021440a6e0 Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-03-02metag: Provide dma_get_sgtable()James Hogan
metag/allmodconfig: drivers/media/v4l2-core/videobuf2-dma-contig.c: In function 'vb2_dc_get_base_sgt': drivers/media/v4l2-core/videobuf2-dma-contig.c:387: error: implicit declaration of function 'dma_get_sgtable' For architectures using dma_map_ops, dma_get_sgtable() is provided in <asm-generic/dma-mapping-common.h>. Metag does not use dma_map_ops yet, hence it should implement it as an inline stub using dma_common_get_sgtable(). Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
2013-03-02metag: prom.h: remove declaration of metag_dt_memblock_reserve()James Hogan
Metag doesn't have a metag_dt_memblock_reserve() function so remove the declaration from asm/prom.h. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: copy devicetree to non-init memoryJames Hogan
Make a copy of the device tree blob in non-init memory. It is required when using built-in device tree files that the platform code copies the blob to non-init memory prior to calling unflatten_device_tree(), otherwise the strings that the device tree refer to will get poisoned and potentially reused, breaking later reading of the device tree post-init (such as compatible matching in modules, debugfs, and the procfs interface). Signed-off-by: James Hogan <james.hogan@imgtec.com> Reviewed-by: Vineet Gupta <vgupta@synopsys.com>
2013-03-02metag: cleanup metag_ksyms.c includesJames Hogan
Minimise metag_ksyms.c includes to directly include the <asm/*.h> files that declare a particular symbol, and not include any unnecessary ones. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: move mm/init.c exports out of metag_ksyms.cJames Hogan
It's less error prone to have function symbols exported immediately after the function rather than in metag_ksyms.c. Move each EXPORT_SYMBOL in metag_ksyms.c for symbols defined in mm/init.c into mm/init.c. Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: move usercopy.c exports out of metag_ksyms.cJames Hogan
It's less error prone to have function symbols exported immediately after the function rather than in metag_ksyms.c. Move each EXPORT_SYMBOL in metag_ksyms.c for symbols defined in usercopy.c into usercopy.c Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: move setup.c exports out of metag_ksyms.cJames Hogan
It's less error prone to have function symbols exported immediately after the function rather than in metag_ksyms.c. Move each EXPORT_SYMBOL in metag_ksyms.c for symbols defined in setup.c into setup.c Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: move kick.c exports out of metag_ksyms.cJames Hogan
It's less error prone to have function symbols exported immediately after the function rather than in metag_ksyms.c. Move each EXPORT_SYMBOL in metag_ksyms.c for symbols defined in kick.c into kick.c Signed-off-by: James Hogan <james.hogan@imgtec.com>
2013-03-02metag: move traps.c exports out of metag_ksyms.cJames Hogan
It's less error prone to have function symbols exported immediately after the function rather than in metag_ksyms.c. Move each EXPORT_SYMBOL in metag_ksyms.c for symbols defined in traps.c into traps.c Signed-off-by: James Hogan <james.hogan@imgtec.com>
