2006-05-06[ARM] rtc-sa1100: fix compiler warnings and error cleanupRussell King
Fix: drivers/rtc/rtc-sa1100.c: In function `sa1100_rtc_proc': drivers/rtc/rtc-sa1100.c:298: warning: unsigned int format, long unsigned int arg (arg 3) and arrange for sa1100_rtc_open() to pass the devid to free_irq() rather than NULL. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-06[ARM] Allow SA1100 RTC alarm to be configured for wakeupRussell King
The SA1100 RTC alarm can be configured to wake up the CPU from sleep mode, and the RTC driver has been using the API to configure this mode. Unfortunately, the code was which sets the required bit in the hardware was missing. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-05[TCP]: Fix snd_cwnd adjustments in tcp_highspeed.cJohn Heffner
Xiaoliang (David) Wei wrote: > Hi gurus, > > I am reading the code of tcp_highspeed.c in the kernel and have a > question on the hstcp_cong_avoid function, specifically the following > AI part (line 136~143 in net/ipv4/tcp_highspeed.c ): > > /* Do additive increase */ > if (tp->snd_cwnd < tp->snd_cwnd_clamp) { > tp->snd_cwnd_cnt += ca->ai; > if (tp->snd_cwnd_cnt >= tp->snd_cwnd) { > tp->snd_cwnd++; > tp->snd_cwnd_cnt -= tp->snd_cwnd; > } > } > > In this part, when (tp->snd_cwnd_cnt == tp->snd_cwnd), > snd_cwnd_cnt will be -1... snd_cwnd_cnt is defined as u16, will this > small chance of getting -1 becomes a problem? > Shall we change it by reversing the order of the cwnd++ and cwnd_cnt -= > cwnd? Absolutely correct. Thanks. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-05[NETROM/ROSE]: Kill module init version kernel log messages.Ralf Baechle
There are out of date and don't tell the user anything useful. The similar messages which IPV4 and the core networking used to output were killed a long time ago. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-05[DCCP]: Fix sock_orphan dead lockHerbert Xu
Calling sock_orphan inside bh_lock_sock in dccp_close can lead to dead locks. For example, the inet_diag code holds sk_callback_lock without disabling BH. If an inbound packet arrives during that admittedly tiny window, it will cause a dead lock on bh_lock_sock. Another possible path would be through sock_wfree if the network device driver frees the tx skb in process context with BH enabled. We can fix this by moving sock_orphan out of bh_lock_sock. The tricky bit is to work out when we need to destroy the socket ourselves and when it has already been destroyed by someone else. By moving sock_orphan before the release_sock we can solve this problem. This is because as long as we own the socket lock its state cannot change. So we simply record the socket state before the release_sock and then check the state again after we regain the socket lock. If the socket state has transitioned to DCCP_CLOSED in the time being, we know that the socket has been destroyed. Otherwise the socket is still ours to keep. This problem was discoverd by Ingo Molnar using his lock validator. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-05[BRIDGE]: keep track of received multicast packetsStephen Hemminger
It makes sense to add this simple statistic to keep track of received multicast packets. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-05[SCTP]: Fix state table entries for chunks received in CLOSED state.Sridhar Samudrala
Discard an unexpected chunk in CLOSED state rather can calling BUG(). Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-05[SCTP]: Fix panic's when receiving fragmented SCTP control chunks.Sridhar Samudrala
Use pskb_pull() to handle incoming COOKIE_ECHO and HEARTBEAT chunks that are received as skb's with fragment list. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-05[SCTP]: Prevent possible infinite recursion with multiple bundled DATA.Vladislav Yasevich
There is a rare situation that causes lksctp to go into infinite recursion and crash the system. The trigger is a packet that contains at least the first two DATA fragments of a message bundled together. The recursion is triggered when the user data buffer is smaller that the full data message. The problem is that we clone the skb for every fragment in the message. When reassembling the full message, we try to link skbs from the "first fragment" clone using the frag_list. However, since the frag_list is shared between two clones in this rare situation, we end up setting the frag_list pointer of the second fragment to point to itself. This causes sctp_skb_pull() to potentially recurse indefinitely. Proposed solution is to make a copy of the skb when attempting to link things using frag_list. Signed-off-by: Vladislav Yasevich <vladsilav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-05[SCTP]: Allow spillover of receive buffer to avoid deadlock.Neil Horman
This patch fixes a deadlock situation in the receive path by allowing temporary spillover of the receive buffer. - If the chunk we receive has a tsn that immediately follows the ctsn, accept it even if we run out of receive buffer space and renege data with higher TSNs. - Once we accept one chunk in a packet, accept all the remaining chunks even if we run out of receive buffer space. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Mark Butler <butlerm@middle.net> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-05Merge master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-mmc: [BLOCK] Fix oops on removal of SD/MMC card
2006-05-05[ARM] 3495/1: EABI: undefine removed syscalls, but...Nicolas Pitre
Patch from Nicolas Pitre ... but only for user space. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-05[ARM] 3500/1: fix PXA27x DMA allocation priorityNicolas Pitre
Patch from Nicolas Pitre Intel PXA27x developers manual section 5.4.1.1 lists a priority distribution for the DMA channels differently than what the code currently assumes. This patch fixes that. Noticed by Simon Vogl <vogl@soft.uni-linz.ac.at> Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-05[ARM] 3499/1: Fix VFP FPSCR corruption for double exception caseGeorge G. Davis
Patch from George G. Davis The ARM VFP FPSCR register is corrupted when a condition flags modifying VFP instruction is followed by a non-condition flags modifying VFP instruction and both instructions raise exceptions. The fix is to read the current FPSCR in between emulation of these two instructions and use the current FPSCR value when handling the second exception. Signed-off-by: George G. Davis <gdavis@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-05[BLOCK] Fix oops on removal of SD/MMC cardRussell King
The block layer keeps a reference (driverfs_dev) to the struct device associated with the block device, and uses it internally for generating uevents in block_uevent. Block device uevents include umounting the partition, which can occur after the backing device has been removed. Unfortunately, this reference is not counted. This means that if the struct device is removed from the device tree, the block layers reference will become stale. Guard against this by holding a reference to the struct device in add_disk(), and only drop the reference when we're releasing the gendisk kobject - in other words when we can be sure that no further uevents will be generated for this block device. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Jens Axboe <axboe@suse.de>
2006-05-05[ARM] 3496/1: more constants for asm-offsets.hUwe Zeisberger
Patch from Uwe Zeisberger added the following constants: - MACHINFO_TYPE - MACHINFO_NAME - MACHINFO_PHYSIO - MACHINFO_PGOFFIO - PROCINFO_INITFUNC - PROCINFO_MMUFLAGS and removed their definition from head.S and head-nommu.S Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-05[ARM] 3494/1: asm-arm/bug.h needs linux/stddef.hNicolas Pitre
Patch from Nicolas Pitre ... for the definition of NULL. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-04Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [PATCH] powerpc: Use the ibm,pa-features property if available powerpc: Fix incorrect might_sleep in __get_user/__put_user on kernel addresses [PATCH] ppc32 CPM_UART: fixes and improvements [PATCH] ppc32 CPM_UART: Fixed break send on SCC [PATCH] powerpc/kprobes: fix singlestep out-of-line [PATCH] powerpc/pseries: avoid crash in PCI code if mem system not up
2006-05-04Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3490/1: i.MX: move uart resources to board files [ARM] 3488/1: make icedcc_putc do the right thing [ARM] 3487/1: IXP4xx: Support non-PCI systems [ARM] 3486/1: Mark memory as clobbered by the ARM _syscallX() macros
2006-05-04Merge master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-mmc: [MMC] Move set_ios debugging into mmc.c [MMC] Correct mmc_request_done comments [MMC] PXA: reduce the number of lines PXAMCI debug uses [MMC] PXA and i.MX: don't avoid sending stop command on error [MMC] extend data timeout for writes [ARM] 3485/1: i.MX: MX1 SD/MMC fix of unintentional double start possibility
2006-05-04Merge branch 'splice' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'splice' of git://brick.kernel.dk/data/git/linux-2.6-block: [PATCH] compat_sys_vmsplice: one-off in UIO_MAXIOV check [PATCH] splice: redo page lookup if add_to_page_cache() returns -EEXIST [PATCH] splice: rename remaining info variables to pipe [PATCH] splice: LRU fixups [PATCH] splice: fix unlocking of page on error ->prepare_write()
2006-05-04Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [DECNET]: Fix level1 router hello [TCP]: Fix sock_orphan dead lock [ROSE]: Eleminate HZ from ROSE kernel interfaces [NETROM]: Eleminate HZ from NET/ROM kernel interfaces [AX.25]: Eleminate HZ from AX.25 kernel interfaces [ROSE]: Fix routing table locking in rose_remove_neigh. [AX.25]: Move AX.25 symbol exports [HAMRADIO]: Remove remaining SET_MODULE_OWNER calls from hamradio drivers. [AX25, ROSE]: Remove useless SET_MODULE_OWNER calls. [AX.25]: Spelling fix [ROSE]: Remove useless prototype for rose_remove_neigh(). [NETFILTER]: x_tables: don't use __copy_{from,to}_user on unchecked memory in compat layer [NETFILTER]: H.323 helper: Change author's email address [NETFILTER]: NAT: silence unused variable warnings with CONFIG_XFRM=n [NETFILTER]: H.323 helper: fix use of uninitialized data [NETFILTER]: H.323 helper: fix endless loop caused by invalid TPKT len
2006-05-04Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC]: Hook up vmsplice into syscall tables.
2006-05-04CREDITS file update (Tristan Greaves)Linus Torvalds
By request from Tristan. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-04[MMC] Move set_ios debugging into mmc.cRussell King
Rather than having every driver duplicate the set_ios debugging, provide a single version in mmc.c which can be expanded as we add additional functionality. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-04[ARM] 3490/1: i.MX: move uart resources to board filesSascha Hauer
Patch from Sascha Hauer This patch moves the i.MX uart resources and the gpio pin setup to the board files. This allows the boards to decide how many internal uarts are connected to the outside world and whether they use rts/cts or not. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-04[MMC] Correct mmc_request_done commentsRussell King
mmc_request_done should be called at the end of handling a request, not between the data and initial command parts of the request. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-05-04[PATCH] compat_sys_vmsplice: one-off in UIO_MAXIOV checkJens Axboe
nr_segs may not be > UIO_MAXIOV, however it may be equal to. This makes the behaviour identical to the real sys_vmsplice(). The other foov syscalls also agree that this is the way to go. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-05-03[DECNET]: Fix level1 router helloPatrick Caulfield
This patch fixes hello messages sent when a node is a level 1 router. Slightly contrary to the spec (maybe) VMS ignores hello messages that do not name level2 routers that it also knows about. So, here we simply name all the routers that the node knows about rather just other level1 routers. (I hope the patch is clearer than the description. sorry). Signed-off-by: Patrick Caulfield <patrick@tykepenguin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[TCP]: Fix sock_orphan dead lockHerbert Xu
Calling sock_orphan inside bh_lock_sock in tcp_close can lead to dead locks. For example, the inet_diag code holds sk_callback_lock without disabling BH. If an inbound packet arrives during that admittedly tiny window, it will cause a dead lock on bh_lock_sock. Another possible path would be through sock_wfree if the network device driver frees the tx skb in process context with BH enabled. We can fix this by moving sock_orphan out of bh_lock_sock. The tricky bit is to work out when we need to destroy the socket ourselves and when it has already been destroyed by someone else. By moving sock_orphan before the release_sock we can solve this problem. This is because as long as we own the socket lock its state cannot change. So we simply record the socket state before the release_sock and then check the state again after we regain the socket lock. If the socket state has transitioned to TCP_CLOSE in the time being, we know that the socket has been destroyed. Otherwise the socket is still ours to keep. Note that I've also moved the increment on the orphan count forward. This may look like a problem as we're increasing it even if the socket is just about to be destroyed where it'll be decreased again. However, this simply enlarges a window that already exists. This also changes the orphan count test by one. Considering what the orphan count is meant to do this is no big deal. This problem was discoverd by Ingo Molnar using his lock validator. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[ROSE]: Eleminate HZ from ROSE kernel interfacesRalf Baechle
Convert all ROSE sysctl time values from jiffies to ms as units. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[NETROM]: Eleminate HZ from NET/ROM kernel interfacesRalf Baechle
Convert all NET/ROM sysctl time values from jiffies to ms as units. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[AX.25]: Eleminate HZ from AX.25 kernel interfacesRalf Baechle
Convert all AX.25 sysctl time values from jiffies to ms as units. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[ROSE]: Fix routing table locking in rose_remove_neigh.Ralf Baechle
The locking rule for rose_remove_neigh() are that the caller needs to hold rose_neigh_list_lock, so we better don't take it yet again in rose_neigh_list_lock. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[AX.25]: Move AX.25 symbol exportsRalf Baechle
Move AX.25 symbol exports to next to their definitions where they're supposed to be these days. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[HAMRADIO]: Remove remaining SET_MODULE_OWNER calls from hamradio drivers.Ralf Baechle DL5RB
Signed-off-by: Ralf Baechle DL5RB <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[AX25, ROSE]: Remove useless SET_MODULE_OWNER calls.Ralf Baechle
2006-05-03[AX.25]: Spelling fixRalf Baechle
2006-05-03[ROSE]: Remove useless prototype for rose_remove_neigh().Ralf Baechle
2006-05-03[NETFILTER]: x_tables: don't use __copy_{from,to}_user on unchecked memory ↵Patrick McHardy
in compat layer Noticed by Linus Torvalds <torvalds@osdl.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[NETFILTER]: H.323 helper: Change author's email addressJing Min Zhao
Signed-off-by: Jing Min Zhao <zhaojingmin@users.sourceforge.net> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[NETFILTER]: NAT: silence unused variable warnings with CONFIG_XFRM=nPatrick McHardy
net/ipv4/netfilter/ip_nat_standalone.c: In function 'ip_nat_out': net/ipv4/netfilter/ip_nat_standalone.c:223: warning: unused variable 'ctinfo' net/ipv4/netfilter/ip_nat_standalone.c:222: warning: unused variable 'ct' Surprisingly no complaints so far .. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[NETFILTER]: H.323 helper: fix use of uninitialized dataPatrick McHardy
When a Choice element contains an unsupported choice no error is returned and parsing continues normally, but the choice value is not set and contains data from the last parsed message. This may in turn lead to parsing of more stale data and following crashes. Fixes a crash triggered by testcase 0003243 from the PROTOS c07-h2250v4 testsuite following random other testcases: CPU: 0 EIP: 0060:[<c01a9554>] Not tainted VLI EFLAGS: 00210646 (2.6.17-rc2 #3) EIP is at memmove+0x19/0x22 eax: d7be0307 ebx: d7be0307 ecx: e841fcf9 edx: d7be0307 esi: bfffffff edi: bfffffff ebp: da5eb980 esp: c0347e2c ds: 007b es: 007b ss: 0068 Process events/0 (pid: 4, threadinfo=c0347000 task=dff86a90) Stack: <0>00000006 c0347ea6 d7be0301 e09a6b2c 00000006 da5eb980 d7be003e d7be0052 c0347f6c e09a6d9c 00000006 c0347ea6 00000006 00000000 d7b9a548 00000000 c0347f6c d7b9a548 00000004 e0a1a119 0000028f 00000006 c0347ea6 00000006 Call Trace: [<e09a6b2c>] mangle_contents+0x40/0xd8 [ip_nat] [<e09a6d9c>] ip_nat_mangle_tcp_packet+0xa1/0x191 [ip_nat] [<e0a1a119>] set_addr+0x60/0x14d [ip_nat_h323] [<e0ab6e66>] q931_help+0x2da/0x71a [ip_conntrack_h323] [<e0ab6e98>] q931_help+0x30c/0x71a [ip_conntrack_h323] [<e09af242>] ip_conntrack_help+0x22/0x2f [ip_conntrack] [<c022934a>] nf_iterate+0x2e/0x5f [<c025d357>] xfrm4_output_finish+0x0/0x39f [<c02294ce>] nf_hook_slow+0x42/0xb0 [<c025d357>] xfrm4_output_finish+0x0/0x39f [<c025d732>] xfrm4_output+0x3c/0x4e [<c025d357>] xfrm4_output_finish+0x0/0x39f [<c0230370>] ip_forward+0x1c2/0x1fa [<c022f417>] ip_rcv+0x388/0x3b5 [<c02188f9>] netif_receive_skb+0x2bc/0x2ec [<c0218994>] process_backlog+0x6b/0xd0 [<c021675a>] net_rx_action+0x4b/0xb7 [<c0115606>] __do_softirq+0x35/0x7d [<c0104294>] do_softirq+0x38/0x3f Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-03[NETFILTER]: H.323 helper: fix endless loop caused by invalid TPKT lenPatrick McHardy
When the TPKT len included in the packet is below the lowest valid value of 4 an underflow occurs which results in an endless loop. Found by testcase 0000058 from the PROTOS c07-h2250v4 testsuite. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-04[PATCH] splice: redo page lookup if add_to_page_cache() returns -EEXISTJens Axboe
This can happen quite easily, if several processes are trying to splice the same file at the same time. It's not a failure, it just means someone raced with us in allocating this file page. So just dump the allocated page and relookup the original. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-05-04[PATCH] splice: rename remaining info variables to pipeJens Axboe
Same thing was done in fs/pipe.c and most of fs/splice.c, but we had a few missing still. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-05-04[PATCH] splice: LRU fixupsJens Axboe
Nick says that the current construct isn't safe. This goes back to the original, but sets PIPE_BUF_FLAG_LRU on user pages as well as they all seem to be on the LRU in the first place. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-05-04[PATCH] splice: fix unlocking of page on error ->prepare_write()Jens Axboe
Looking at generic_file_buffered_write(), we need to unlock_page() if prepare write fails and it isn't due to racing with truncate(). Also trim the size if ->prepare_write() fails, if we have to. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-05-03[PATCH] ext3: multile block allocate little endian fixesMingming Cao
Some places in ext3 multiple block allocation code (in 2.6.17-rc3) don't handle the little endian well. This was resulting in *wrong* block numbers being assigned to in-memory block variables and then stored on disk eventually. The following patch has been verified to fix an ext3 filesystem failure when run ltp test on a 64 bit machine. Signed-off-by; Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-03[PATCH] Altix: correct ioc4 port orderBrent Casavant
Currently loading the ioc3 as a module will cause the ports to be numbered in reverse order. This mod maintains the proper order of cards for port numbering. Signed-off-by: Brent Casavant <bcasavan@sgi.com> Cc: Pat Gefre <pfg@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
