2011-03-30ath9k_hw: replace REG_READ+REG_WRITE with REG_RMWFelix Fietkau
It's easier to read and it slightly decreases code size Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k_hw: add a new register op for read-mask-writeFelix Fietkau
Reduces the number of calls to register ops. On MIPS this reduces the ath9k_hw binary size from 321k down to 310k Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k_hw: embed the ath_ops callbacks in the ath_hw structFelix Fietkau
With this change, loading the address to a register read/write function costs only one pointer dereference instead of two. On MIPS this reduces ath9k_hw binary size from 326k down to 321k. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30cfg80211: Add nl80211 event for deletion of a station entryJouni Malinen
Indicate an NL80211_CMD_DEL_STATION event when a station entry in mac80211 is deleted to match with the NL80211_CMD_NEW_STATION event that is used when the entry was added. This is needed, e.g., to allow user space to remove a peer from RSN IBSS Authenticator state machine to avoid re-authentication and re-keying delays when the peer is not reachable anymore. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k: Support RSN IBSSJouni Malinen
Add support for using RSN IBSS with ath9k. For now, this uses software crypto for group addressed frames in RSN IBSS, but that may be optimized in the future by extending the key cache design to support per-STA RX GTK. Signed-off-by: Jouni Malinen <jouni.malinen@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k: fix stuck beacon detectionFelix Fietkau
Stuck beacon detection is supposed to trigger when 9 consecutive beacons could not be sent by the hardware. When the driver runs only one active AP mode interface, it still configures the hardware beacon timer for 4 (ATH_BCBUF) beacon slots slots, which causes stuck beacon detection to be reset if ath9k_hw_stoptxdma clears the stuck frames between SWBA intervals. Fix this by not resetting the missed beacon count for empty slots and multiplying the threshold not by the maximum number of beacon slots but by the configured number of beacon interfaces. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k: trigger nfcal only after multiple missed beacons in AP modeFelix Fietkau
Single missed (i.e. not transmitted) beacons in AP mode are not very rare and not necessarily an indicator of strong interference, so only trigger noise floor recalibration when multiple consecutive beacons could not be transmitted. Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k: fix beacon timer handling issuesFelix Fietkau
AP mode beacon timers in ath9k are configured in milliseconds, which breaks when increasing ATH_BCBUF to 8 instead of 4 (due to rounding errors). Since the hardware timers are actually configured in microseconds, it's better to let the driver use that unit directly. To be able to do that, the beacon interval parameter abuse for passing certain flags needs to be removed. This is easy to do, because those flags are completely unnecessary anyway. ATH9K_BEACON_ENA is ignored, ATH9K_BEACON_RESET_TSF can be replaced with calling ath9k_hw_reset_tsf from the driver directly. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30libertas_spi: Add support for suspend/resumeVasily Khoruzhick
Add support for suspend/resume in if_spi. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30wireless: mwifiex: initial commit for Marvell mwifiex driverBing Zhao
This driver adds WiFi support for Marvell 802.11n based chipsets with SDIO interface. Currently only SD8787 is supported. More chipsets will be supported later. drivers/net/wireless/mwifiex/ Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Kiran Divekar <dkiran@marvell.com> Signed-off-by: Bing Zhao <bzhao@marvell.com> Signed-off-by: Yogesh Ashok Powar <yogeshp@marvell.com> Signed-off-by: Marc Yang <yangyang@marvell.com> Signed-off-by: Ramesh Radhakrishnan <rramesh@marvell.com> Signed-off-by: Frank Huang <frankh@marvell.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k_hw: remove AR9485 1.0 supportLuis R. Rodriguez
Only AR9485 1.1 was sold. This debloats the driver by ~14 KiB. text data bss dec hex filename 300413 624 1056 302093 49c0d drivers/net/wireless/ath/ath9k/ath9k_hw.ko text data bss dec hex filename 310285 624 1056 311965 4c29d drivers/net/wireless/ath/ath9k/ath9k_hw-old.ko $ du -b ath9k_hw* 6210541 ath9k_hw.ko 6225089 ath9k_hw-old.ko Cc: Bill Wu <bill.wu@atheros.com> Cc: Paul Shaw <paul.shaw@atheros.com> Cc: Forbes Tsai <Forbes.Tsai@Atheros.com> Cc: Jesmine Chen <jesmine.chen@atheros.com> Cc: Marvian Chen <Hou-hua.Chen@Atheros.com> Cc: Vivek Natarajan <vivek.natarajan@atheros.com> Cc: Bernadette Yetso <bernadette.yetso@atheros.com> Cc: Sarvesh Shrivastava <sarvesh.shrivastava@atheros.com> Acked-by: Yi-Chen Su <yi-chen.su@atheros.com> Acked-by: Jeffrey Chung <jeffrey.chung@atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mac80211: Minor optimization in tx status handlingHelmut Schaa
ieee80211_tx_status iterates over all tx rates the driver reports back in order to 1) mark tx rates as invalid if the driver cannot have tried that rate 2) find the actually used tx rate for the final retransmission By leaving the for loop when the first invalid rate index is found we can move the rates_idx assignment after the loop and therefore save a few assignments and conditionals. Signed-off-by: Helmut Schaa <helmut.schaa@googlemail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k: remove the pending frames ath_txq_schedule workaroundFelix Fietkau
This workaround called ath_txq_schedule whenever there were still pending frames for a queue, but the queue depth was zero. Because of its its high false positive probability (e.g. with paused TIDs) and because it is in the way of other pending work (AP powersave fixes), it is better to remove this code entirely. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k_hw: force rx chainmask to 7 on AR9100Felix Fietkau
Most AR9100 devices already have a chainmask of 7 (three antennas), however on the ones that don't (rx and tx chainmask set to 5), problems with IQ mismatch calibration have been observed. This shows up as tx queue hangs (and subsequent hardware resets) if traffic is sent during this type of calibration. Forcing the rx chainmask to 7 fixes the calibration issues with no apparent negative side effects on throughput and stability. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k_hw: enable a BlockAck related fixup specific to AR9100Felix Fietkau
Fixes interop issues with aggregation in combination with multi-BSSID Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k: add support for overriding LED pin and GPIO settings from platform dataFelix Fietkau
2011-03-30ath9k: add support for overriding the MAC address through platform dataFelix Fietkau
On some devices the correct MAC address is not in the EEPROM data, but stored somewhere else. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k: add an interface for overriding the value of specific GPIO pinsFelix Fietkau
Some devices control antenna settings or other things through GPIO pins of the wireless interface. Add a debugfs interface for changing those and keeping them set across card resets. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k: remove unnecessary debugfs return code checksFelix Fietkau
Since the ath9k debugfs directory is cleaned up by debugfs_remove_recursive, there's no point in checking the return code of every single debugfs create line. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30rtlwifi: rtl8192c{e,u}: Remove some extraneous casts on memcpy commandsLarry Finger
Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: Queue ADDBA requests in respective data queuesNishant Sarmukadam
Queue ADDBA requests in respective data queues to avoid ADDBA requests and the the related data packets (to the same ra/tid) queued in the hardware to be sent out asynchronously. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: Check outgoing rate for a station to decide if ampdu can be createdNishant Sarmukadam
If the outgoing packet rate to a particular HT station is <=6.5 Mbps, do not attempt to create an ampdu. Also, if the outgoing rate is legacy rate, do not create an ampdu. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: Handle the watchdog event from the firmwareNishant Sarmukadam
When an ampdu stream is on, if the firmware rate adaptation logic decides that the outgoing packet rate to the station needs to go below 6.5Mbps (non HT rate), it sends an event indicating that the ampdu stream needs to be destroyed. Handle this event in the driver and destroy the ampdu stream so that the rate can go below 6.5Mbps Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: Initiate BA sessionsNishant Sarmukadam
Specifically, handle ampdu_action and attempt to start a BA session on receiving the first qos packet from mac80211 for transmission to a HT sta. While the BA session is being created, all the packets belonging to that stream will be dropped to prevent sequence number mismatch at the recipient. Contains contributions from: Yogesh Powar <yogeshp@marvell.com> Pradeep Nemavat <pnemavat@marvell.com> Brian Cavagnolo <brian@cozybit.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: add internal API for managing AMPDU streamsBrian Cavagnolo
In particular, we can now add, start, lookup, and remove streams. Based on work by Nishant Sarmukadam <nishants@marvell.com> and Pradeep Nemavat <pnemavat@marvell.com>. Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: differentiate between WMM queues and AMPDU queuesBrian Cavagnolo
We now have two different kinds of queues. And the number of AMPDU queues may vary. So we must be clear about which queues we are dealing with. Note that when we report the number of queues to mac80211, we only report the WMM queues. Based on work by Yogesh Powar <yogeshp@marvell.com>. Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: add support for block ack commandsNishant Sarmukadam
Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: update to ap firmware API version 2Brian Cavagnolo
Firmware APIv2 adds the following enhancements: -- capabilities are reported by the firmware -- API supports up to 8 dedicated AMPDU streams -- optional packet timestamping and expiration can be enabled. Specifically, packets that are queued in firmware for longer than 500ms will be dropped if this option is used. Based on work by "Nishant Sarmukadam" <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mwl8k: refactor in preparation for APIv2 updateBrian Cavagnolo
Specifically, APIv2 will specify a variable number of AMPDU queues in the MWL8K_CMD_GET_HW_SPEC. So init the tx queues after MWL8K_CMD_GET_HW_SPEC for ap fw. Also, we make it safe to deinit queues that have not been init'd. This happens if the mwl8k_get_hw_spec_ap routine fails, for example. Signed-off-by: Nishant Sarmukadam <nishants@marvell.com> Signed-off-by: Brian Cavagnolo <brian@cozybit.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30mac80211: add comment about reorderingJohannes Berg
Took me a minute to figure this out, maybe it's better documented... Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k_hw: Speedup register ops for HTC driverRajkumar Manoharan
Fine-tuning register write operation and avoid unnecessay delays for ath9k_htc driver, saves hw reset time which improves scanning time and also solves one of the following scenario. Sometimes the ACK is sent by STA for assoc response is not seen at AP side. So the AP continues to send retry assoc responses. At the STA side, since the assoc response was already forwarded to mac80211, it proceeded to channel change which in turns does chip reset. In most of the cases the chip reset was completed before max retries are reached at AP side. Hence STA can able to ACK the retried frames again. But in clear environment these retries are completed within shortspan of time. Since ath9k_htc consumes more time for hw reset, this latency is causing dissociation by AP due to max reties are reached. This issue was originally reported with Cisco Aironet 1250 AP in HT40 mode in noise free environment. Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath: Speedup key set/reset ops for HTC driverRajkumar Manoharan
By enabling buffered register write for ath9k_htc driver avoids unnecessary dissociation while rekeying phase under heavy traffic exchange. Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k_hw: Fix throughput drops in HT40 mode for AR9287 chipsRajkumar Manoharan
Doing adc gain calibration for AR9287 chips is causing throughput drops in HT40 mode. Remove ADC Gain from supported calibration list. Signed-off-by: Rajkumar Manoharan <rmanoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-30ath9k_htc: Fix LED pin for AR9287 HTC deviceRajkumar Manoharan
2011-03-30iwlwifi: remove duplicate initialization in __iwl_down()Dan Carpenter
We initialize exit_pending twice. It's the second initialization which is correct. That was added in d745d472af "iwlwifi: cancel scan when down the device". Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-03-29Linux 2.6.39-rc1v2.6.39-rc1Linus Torvalds
2011-03-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (26 commits) mmc: SDHI should depend on SUPERH || ARCH_SHMOBILE mmc: tmio_mmc: Move some defines into a shared header mmc: tmio: support aggressive clock gating mmc: tmio: fix power-mode interpretation mmc: tmio: remove work-around for unmasked SDIO interrupts sh: fix SDHI IO address-range ARM: mach-shmobile: fix SDHI IO address-range mmc: tmio: only access registers above 0xff, if available mfd: remove now redundant sh_mobile_sdhi.h header sh: convert boards to use linux/mmc/sh_mobile_sdhi.h ARM: mach-shmobile: convert boards to use linux/mmc/sh_mobile_sdhi.h mmc: tmio: convert the SDHI MMC driver from MFD to a platform driver sh: ecovec: use the CONFIG_MMC_TMIO symbols instead of MFD mmc: tmio: split core functionality, DMA and MFD glue mmc: tmio: use PIO for short transfers mmc: tmio-mmc: Improve DMA stability on sh-mobile mmc: fix mmc_app_send_scr() for dma transfer mmc: sdhci-esdhc: enable esdhc on imx53 mmc: sdhci-esdhc: use writel/readl as general APIs mmc: sdhci: add the abort CMDTYPE bits definition ...
2011-03-29Merge branch 'frv' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-frv * 'frv' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-frv: FRV: Use generic show_interrupts() FRV: Convert genirq namespace frv: Select GENERIC_HARDIRQS_NO_DEPRECATED frv: Convert cpu irq_chip to new functions frv: Convert mb93493 irq_chip to new functions frv: Convert mb93093 irq_chip to new function frv: Convert mb93091 irq_chip to new functions frv: Fix typo from __do_IRQ overhaul frv: Remove stale irq_chip.end FRV: Do some cleanups FRV: Missing node arg in alloc_thread_info_node() macro NOMMU: implement access_remote_vm NOMMU: support SMP dynamic percpu_alloc NOMMU: percpu should use is_vmalloc_addr().
2011-03-29Merge branch 'stable/bug-fixes-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/bug-fixes-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: Use new irq_move functions xen: Convert genirq namespace xen: fix p2m section mismatches xen/p2m: Allocate p2m tracking pages on override xen-gntdev: unlock on error path in gntdev_mmap() xen-gntdev: return -EFAULT on copy_to_user failure
2011-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: watchdog: softdog.c: enhancement to optionally invoke panic instead of reboot on timer expiry watchdog: fix nv_tco section mismatch watchdog: sp5100_tco.c: Check if firmware has set correct value in tcobase. watchdog: Convert release_resource to release_region/release_mem_region watchdog: s3c2410_wdt.c: Convert release_resource to release_region/release_mem_region
2011-03-29Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bpLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: amd64_edac: Fix potential memleak
2011-03-29Merge branch 'irq-final-for-linus-v2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-final-for-linus-v2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (111 commits) gpio: ab8500: Mark broken genirq: Remove move_*irq leftovers genirq: Remove compat code drivers: Final irq namespace conversion mn10300: Use generic show_interrupts() mn10300: Cleanup irq_desc access mn10300: Convert genirq namespace frv: Use generic show_interrupts() frv: Convert genirq namespace frv: Select GENERIC_HARDIRQS_NO_DEPRECATED frv: Convert cpu irq_chip to new functions frv: Convert mb93493 irq_chip to new functions frv: Convert mb93093 irq_chip to new function frv: Convert mb93091 irq_chip to new functions frv: Fix typo from __do_IRQ overhaul frv: Remove stale irq_chip.end m68k: Convert irq function namespace xen: Use new irq_move functions xen: Cleanup genirq namespace unicore32: Use generic show_interrupts() ...
2011-03-29char/tpm: Fix unitialized usage of data bufferPeter Huewe
This patch fixes information leakage to the userspace by initializing the data buffer to zero. Reported-by: Peter Huewe <huewe.external@infineon.com> Signed-off-by: Peter Huewe <huewe.external@infineon.com> Signed-off-by: Marcel Selhorst <m.selhorst@sirrix.com> [ Also removed the silly "* sizeof(u8)". If that isn't 1, we have way deeper problems than a simple multiplication can fix. - Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-29amd64_edac: Fix potential memleakBorislav Petkov
We check the pointers together but at least one of them could be invalid due to failed allocation. Since we cannot continue if either of the two allocations has failed, exit early by freeing them both. Cc: <stable@kernel.org> # 38.x Reported-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
2011-03-29fs: don't use igrab() while holding i_lockDave Chinner
Fix the incorrect use of igrab() inside the i_lock in NFS and Ceph‥ If we are already holding the i_lock, we have a reference to the inode so we can safely use ihold() to gain an extra reference. This avoids hangs due to lock recursion on the i_lock now that the inode_lock is gone and igrab() uses the i_lock itself. Signed-off-by: Dave Chinner <dchinner@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org Cc: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (30 commits) xfrm: Restrict extended sequence numbers to esp xfrm: Check for esn buffer len in xfrm_new_ae xfrm: Assign esn pointers when cloning a state xfrm: Move the test on replay window size into the replay check functions netdev: bfin_mac: document TE setting in RMII modes drivers net: Fix declaration ordering in inline functions. cxgb3: Apply interrupt coalescing settings to all queues net: Always allocate at least 16 skb frags regardless of page size ipv4: Don't ip_rt_put() an error pointer in RAW sockets. net: fix ethtool->set_flags not intended -EINVAL return value mlx4_en: Fix loss of promiscuity tg3: Fix inline keyword usage tg3: use <linux/io.h> and <linux/uaccess.h> instead <asm/io.h> and <asm/uaccess.h> net: use CHECKSUM_NONE instead of magic number Net / jme: Do not use legacy PCI power management myri10ge: small rx_done refactoring bridge: notify applications if address of bridge device changes ipv4: Fix IP timestamp option (IPOPT_TS_PRESPEC) handling in ip_options_echo() can: c_can: Fix tx_bytes accounting can: c_can_platform: fix irq check in probe ...
2011-03-29xen: Use new irq_move functionsThomas Gleixner
These functions take irq_data as an argument and avoid a redundant lookup in the sparse irq case. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ian Campbell <ian.campbell@citrix.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-29xen: Convert genirq namespaceThomas Gleixner
Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-29xen: fix p2m section mismatchesRandy Dunlap
Fix section mismatch warnings: set_phys_range_identity() is called by __init xen_set_identity(), so also mark set_phys_range_identity() as __init. then: __early_alloc_p2m() is called set_phys_range_identity(), so also mark __early_alloc_p2m() as __init. WARNING: arch/x86/built-in.o(.text+0x7856): Section mismatch in reference from the function __early_alloc_p2m() to the function .init.text:extend_brk() The function __early_alloc_p2m() references the function __init extend_brk(). This is often because __early_alloc_p2m lacks a __init annotation or the annotation of extend_brk is wrong. WARNING: arch/x86/built-in.o(.text+0x7967): Section mismatch in reference from the function set_phys_range_identity() to the function .init.text:extend_brk() The function set_phys_range_identity() references the function __init extend_brk(). This is often because set_phys_range_identity lacks a __init annotation or the annotation of extend_brk is wrong. [v2: Per Stephen Hemming recommonedation made __early_alloc_p2m static] Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-29FRV: Use generic show_interrupts()Thomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Howells <dhowells@redhat.com>
