2010-04-02Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: update to latest upstream Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-01Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (76 commits) drm/radeon/kms: enable ACPI powermanagement mode on radeon gpus. drm/radeon/kms: rs400/480 should set common registers. drm/radeon/kms: add sanity check to wptr. drm/radeon/kms/evergreen: get DP working drm/radeon/kms: add hw_i2c module option drm/radeon/kms: use new pre/post_xfer i2c bit algo hooks drm/radeon/kms: disable MSI on IGP chips drm/radeon/kms: display watermark updates (v2) drm/radeon/kms/dp: disable training pattern on the sink at the end of link training drm/radeon/kms: minor fixes for eDP with LCD* device tags (v2) drm/radeon/kms/dp: remove extraneous training complete call drm/radeon/kms/atom: minor fixes to transmitter setup drm/radeon/kms: Only restrict BO to visible VRAM size when pinning to VRAM. drm: fix build error when SYSRQ is disabled drm/radeon/kms: fix macbookpro connector quirk drm/radeon/r6xx/r7xx: further safe reg clean up drm/radeon: bump the UMS driver version for r6xx/r7xx const buffer support drm/radeon/kms: bump the version for r6xx/r7xx const buffer support drm/radeon/r6xx/r7xx: CS parser fixes drm/radeon/kms: fix some typos in r6xx/r7xx hpd setup ... Fix up MSI-related conflicts in drivers/gpu/drm/radeon/radeon_irq_kms.c
2010-04-01Merge branch 'for-linus' of git://git.monstr.eu/linux-2.6-microblazeLinus Torvalds
* 'for-linus' of git://git.monstr.eu/linux-2.6-microblaze: (35 commits) microblaze: Support word copying in copy_tofrom_user microblaze: Print early printk information to log buffer microblaze: head.S typo fix microblaze: Use MICROBLAZE_TLB_SIZE in asm code microblaze: Kconfig Fix - pci microblaze: Adding likely macros microblaze: Add .type and .size to ASM functions microblaze: Fix TLB macros microblaze: Use instruction with delay slot microblaze: Remove additional resr and rear loading microblaze: Change register usage for ESR and EAR microblaze: Prepare work for optimization in exception code microblaze: Add DEBUG option microblaze: Support systems without lmb bram microblaze: uaccess: Sync strlen, strnlen, copy_to/from_user microblaze: uaccess: Unify __copy_tofrom_user microblaze: uaccess: Move functions to generic location microblaze: uaccess: Fix put_user for noMMU microblaze: uaccess: Fix get_user macro for noMMU microblaze: uaccess: fix clear_user for noMMU kernel ...
2010-04-01Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: eeepc-wmi: new driver for WMI based hotkeys on Eee PC laptops asus-laptop: fix warning in asus_handle_init
2010-04-01oom: fix the unsafe usage of badness() in proc_oom_score()Oleg Nesterov
proc_oom_score(task) has a reference to task_struct, but that is all. If this task was already released before we take tasklist_lock - we can't use task->group_leader, it points to nowhere - it is not safe to call badness() even if this task is ->group_leader, has_intersects_mems_allowed() assumes it is safe to iterate over ->thread_group list. - even worse, badness() can hit ->signal == NULL Add the pid_alive() check to ensure __unhash_process() was not called. Also, use "task" instead of task->group_leader. badness() should return the same result for any sub-thread. Currently this is not true, but this should be changed anyway. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-04-01microblaze: Support word copying in copy_tofrom_userMichal Simek
Word copying is used only for aligned addresses. Here is space for improving to use any better copying technique. Look at memcpy implementation. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Print early printk information to log bufferMichal Simek
If early printk console is not enabled then all messages are written to log buffer. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: head.S typo fixMichal Simek
I forget to change register name in comments. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Use MICROBLAZE_TLB_SIZE in asm codeMichal Simek
TLB size was hardcoded in asm code. This patch brings ability to change TLB size only in one place. (mmu.h). Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Kconfig Fix - pciMichal Simek
I forget to remove pci Kconfig option. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Adding likely macrosMichal Simek
On the base on GCOV analytics is helpful to add likely/unlikely macros. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Add .type and .size to ASM functionsMichal Simek
Cachegrind analysis need this fix to be able to log asm functions. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Fix TLB macrosMichal Simek
To be able to do trace TLB operations. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Use instruction with delay slotMichal Simek
Sync labels. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Remove additional resr and rear loadingMichal Simek
RESR and REAR uses the same regs in whole file. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Change register usage for ESR and EARMichal Simek
This change synchronize register usage in code. ESR = R4 EAR = R3 Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Prepare work for optimization in exception codeMichal Simek
Any sync branch must follow mts instructions not mfs. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Add DEBUG optionMichal Simek
Disable debug option in asm code. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Support systems without lmb bramMichal Simek
When the system has no lmb bram, main memory should be start from zero because of microblaze vectors. DTS fragment could look like: DDR2_SDRAM: memory@0 { device_type = "memory"; reg = < 0x0 0x10000000 >; } ; Then you have to setup CONFIG_KERNEL_BASE_ADDR=0 which caused that kernel physical start address will be zero. On reset vector place will be jump to 0x100 and on 0x100 starts kernel text. You have to solve how to load the kernel before cpu starts. Tested with XMD. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: Sync strlen, strnlen, copy_to/from_userMichal Simek
Last sync. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: Unify __copy_tofrom_userMichal Simek
Move to generic location. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: Move functions to generic locationMichal Simek
noMMU and MMU use them. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: Fix put_user for noMMUMichal Simek
Here is small regression on dhrystone tests and I think that on all benchmarking tests. It is due to better checking mechanism in put_user macro Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: Fix get_user macro for noMMUMichal Simek
Use unified version. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: fix clear_user for noMMU kernelMichal Simek
Previous patches fixed only MMU version and this is the first patch for noMMU kernel Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: Fix strncpy_from_user functionMichal Simek
Generic implementation for noMMU and MMU version Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: fix copy_from_user macroMichal Simek
copy_from_user macro also use copy_tofrom_user function Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: copy_to_user unificationMichal Simek
noMMU and MMU kernel will use copy copy_tofrom_user asm implementation. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: sync put/get/clear_user macrosMichal Simek
Add macro description and resort. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: fix put_user and get_user macrosMichal Simek
Use FIXUP macros and resort them. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: fix __get_user_asm macroMichal Simek
It is used __FIXUP_SECTION and __EX_TABLE_SECTION macros. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: uaccess: fix clean user macroMichal Simek
This is the first patch which does uaccess unification. I choosed to do several patches to be able to use bisect in future if any fault happens. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: move noMMU __range_ok function to uaccess.hMichal Simek
The same noMMU and MMU functions should be placed in one file. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Move exception_table_entry upwardMichal Simek
Just sort to be able remove whole block. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Remove segment.hMichal Simek
I would like to use asm-generic uaccess.h where are segment macros defined. This is just first step. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Remove memset in free_init_pagesMichal Simek
We don't need to do it. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Makefile cleanupsArun Bhanu
If CONFIG_INITRAMFS_SOURCE is set, "scripts/gen_initramfs_list.sh" checks if the cpio image exists. Remove the duplicate check from the Makefile. Remove the "clean-kernel" variable which is unused in the Makefile and is not used by the Kbuild. Signed-off-by: Arun Bhanu <arun@bhanu.net> Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Fix Makefile to delete build generated filesArun Bhanu
'make clean' does not to delete the following build generated file: arch/microblaze/boot/linux.bin.ub 'make mrproper' does not to delete the following build generated files: arch/microblaze/boot/simpleImage.* Fix the Makefile to delete these build generated files. See [1] for a discussion on why simpleImage.* files are deleted with 'make mrproper' and not with 'make clean'. [1] http://lkml.org/lkml/2010/3/12/96 Signed-off-by: Arun Bhanu <arun@bhanu.net> Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Add a missing single quote to make 'make help' happyArun Bhanu
'make ARCH=microblaze help' fails with the following error due to a missing single quote. /bin/sh: -c: line 0: unexpected EOF while looking for matching `'' /bin/sh: -c: line 1: syntax error: unexpected end of file make: *** [help] Error 2 Signed-off-by: Arun Bhanu <arun@bhanu.net> Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01microblaze: Fix "kstack=" parsingSteven J. Magnani
The "kstack=" command line parameter is not parsed correctly. All proper values are interpreted as zero. Signed-off-by: Steven J. Magnani <steve@digidescorp.com> Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-01drm/radeon/kms: enable ACPI powermanagement mode on radeon gpus.Dave Airlie
Some GPUs have an APM/ACPI PM mode selection switch and some BIOSes set this to APM. We really want this in ACPI mode for Linux. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-01drm/radeon/kms: rs400/480 should set common registers.Dave Airlie
These GPUs should be setting these registers up also. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-01drm/radeon/kms: add sanity check to wptr.Dave Airlie
If we resume in a bad way, we'll get 0xffffffff in wptr, and then oops with no console. This just adds a sanity check so that we can avoid the oops and hopefully get more details out of people's systems. Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-04-01drm/radeon/kms/evergreen: get DP workingAlex Deucher
Need to enable the VID stream after link training Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-31eeepc-wmi: new driver for WMI based hotkeys on Eee PC laptopsYong Wang
Add a WMI driver for Eee PC laptops. Currently it only supports hotkeys. Signed-off-by: Yong Wang <yong.y.wang@intel.com> Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Dmitry Torokhov <dtor@mail.ru>
2010-03-31asus-laptop: fix warning in asus_handle_initCorentin Chary
In function 'asus_laptop_get_info': warning: passing argument 3 of 'asus_handle_init' from incompatible pointer type note: expected 'char **' but argument is of type 'const char **' Introduced by commit c21085108a02e1b838c34f3650c8cc9fbd178615 ("asus-laptop: fix style problems reported by checkpath.pl"). Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-03-31fat: fix buffer overflow in vfat_create_shortname()Nikolaus Schulz
When using the string representation of a random counter as part of the base name, ensure that it is no longer than 4 bytes. Since we are repeatedly decrementing the counter in a loop until we have found a unique base name, the counter may wrap around zero; therefore, it is not enough to mask its higher bits before entering the loop, this must be done inside the loop. [hirofumi@mail.parknet.co.jp: use snprintf()] Signed-off-by: Nikolaus Schulz <microschulz@web.de> Cc: stable@kernel.org Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-31drm/radeon/kms: add hw_i2c module optionAlex Deucher
Turn off hw i2c by default except for mm i2c which is hw only until we sort out the remaining prescale issues on older chips. hw i2c can be enabled with hw_i2c=1. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-31drm/radeon/kms: use new pre/post_xfer i2c bit algo hooksAlex Deucher
This allows us to remove the internal bit algo bus used by the radeon i2c algo. We now register a radeon algo adapter if the gpio line is hw capable and the hw inplementation is available, otherwise we register a bit algo adapter. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2010-03-31Merge branch 'v2.6.34-rc2' into drm-linusDave Airlie
