2005-06-23Add missing license texts from Tungsten Graphics.Dave Airlie
From: Alan Hourihane Signed-off-by: David Airlie <airlied@linux.ie>
2005-06-23Currently DRM depends on PCI this will need to change for ffb on Sparc toDave Airlie
be fixed but at the moment it is true. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
2005-06-22Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/driver-2.6Linus Torvalds
2005-06-22Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
2005-06-22[PATCH] driver core: Fix up the device_attach() error handling in ↵Greg Kroah-Hartman
bus_add_device() Don't error out if something "bad" happens when trying to bind a driver to a device. We want the sysfs attributes to be present for later when we try to tear down the device. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-22[PATCH] USB: fix hid core to return proper error code from probeStelian Pop
Drivers need to return -ENODEV when they can't bind to a device. Anything else stops the "bind a device to a driver" search. From: Stelian Pop <stelian@popies.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-22[LTPC]: Replace schedule_timeout() with ssleep()/msleep()Nishanth Aravamudan
Use ssleep() / msleep() [as appropriate] instead of schedule_timeout() to guarantee the task delays as expected. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Arnaldo Carvalho de Melo <acme@conectiva.com.br> Signed-off-by: Maximilian Attems <janitor@sternwelten.at> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[X25]: Fast select with no restriction on responseShaun Pereira
This patch is a follow up to patch 1 regarding "Selective Sub Address matching with call user data". It allows use of the Fast-Select-Acceptance optional user facility for X.25. This patch just implements fast select with no restriction on response (NRR). What this means (according to ITU-T Recomendation 10/96 section 6.16) is that if in an incoming call packet, the relevant facility bits are set for fast-select-NRR, then the called DTE can issue a direct response to the incoming packet using a call-accepted packet that contains call-user-data. This patch allows such a response. The called DTE can also respond with a clear-request packet that contains call-user-data. However, this feature is currently not implemented by the patch. How is Fast Select Acceptance used? By default, the system does not allow fast select acceptance (as before). To enable a response to fast select acceptance, After a listen socket in created and bound as follows socket(AF_X25, SOCK_SEQPACKET, 0); bind(call_soc, (struct sockaddr *)&locl_addr, sizeof(locl_addr)); but before a listen system call is made, the following ioctl should be used. ioctl(call_soc,SIOCX25CALLACCPTAPPRV); Now the listen system call can be made listen(call_soc, 4); After this, an incoming-call packet will be accepted, but no call-accepted packet will be sent back until the following system call is made on the socket that accepts the call ioctl(vc_soc,SIOCX25SENDCALLACCPT); The network (or cisco xot router used for testing here) will allow the application server's call-user-data in the call-accepted packet, provided the call-request was made with Fast-select NRR. Signed-off-by: Shaun Pereira <spereira@tusc.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[X25]: Selective sub-address matching with call user data.Shaun Pereira
From: Shaun Pereira <spereira@tusc.com.au> This is the first (independent of the second) patch of two that I am working on with x25 on linux (tested with xot on a cisco router). Details are as follows. Current state of module: A server using the current implementation (2.6.11.7) of the x25 module will accept a call request/ incoming call packet at the listening x.25 address, from all callers to that address, as long as NO call user data is present in the packet header. If the server needs to choose to accept a particular call request/ incoming call packet arriving at its listening x25 address, then the kernel has to allow a match of call user data present in the call request packet with its own. This is required when multiple servers listen at the same x25 address and device interface. The kernel currently matches ALL call user data, if present. Current Changes: This patch is a follow up to the patch submitted previously by Andrew Hendry, and allows the user to selectively control the number of octets of call user data in the call request packet, that the kernel will match. By default no call user data is matched, even if call user data is present. To allow call user data matching, a cudmatchlength > 0 has to be passed into the kernel after which the passed number of octets will be matched. Otherwise the kernel behavior is exactly as the original implementation. This patch also ensures that as is normally the case, no call user data will be present in the Call accepted / call connected packet sent back to the caller Future Changes on next patch: There are cases however when call user data may be present in the call accepted packet. According to the X.25 recommendation (ITU-T 10/96) section 5.2.3.2 call user data may be present in the call accepted packet provided the fast select facility is used. My next patch will include this fast select utility and the ability to send up to 128 octets call user data in the call accepted packet provided the fast select facility is used. I am currently testing this, again with xot on linux and cisco. Signed-off-by: Shaun Pereira <spereira@tusc.com.au> (With a fix from Alexey Dobriyan <adobriyan@gmail.com>) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[EBTABLES]: vfree() checking cleanupsJames Lamanna
From: jlamanna@gmail.com ebtables.c vfree() checking cleanups. Signed-off by: James Lamanna <jlamanna@gmail.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[ATALK] aarp: replace schedule_timeout() with msleep()Nishanth Aravamudan
From: Nishanth Aravamudan <nacc@us.ibm.com> Use msleep() instead of schedule_timeout() to guarantee the task delays as expected. The current code is not wrong, but it does not account for early return due to signals, so I think msleep() should be appropriate. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[IPV4]: Fix route.c gcc4 warningsChuck Short
Signed-off by: Chuck Short <zulcss@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[NETPOLL]: allow multiple netpoll_clients to register against one interfaceJeff Moyer
This patch provides support for registering multiple netpoll clients to the same network device. Only one of these clients may register an rx_hook, however. In practice, this restriction has not been problematic. It is worth mentioning, though, that the current design can be easily extended to allow for the registration of multiple rx_hooks. The basic idea of the patch is that the rx_np pointer in the netpoll_info structure points to the struct netpoll that has rx_hook filled in. Aside from this one case, there is no need for a pointer from the struct net_device to an individual struct netpoll. A lock is introduced to protect the setting and clearing of the np_rx pointer. The pointer will only be cleared upon netpoll client module removal, and the lock should be uncontested. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[NETPOLL]: Introduce a netpoll_info structJeff Moyer
This patch introduces a netpoll_info structure, which the struct net_device will now point to instead of pointing to a struct netpoll. The reason for this is two-fold: 1) fields such as the rx_flags, poll_owner, and poll_lock should be maintained per net_device, not per netpoll; and 2) this is a first step in providing support for multiple netpoll clients to register against the same net_device. The struct netpoll is now pointed to by the netpoll_info structure. As such, the previous behaviour of the code is preserved. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[NETPOLL]: Set poll_owner to -1 before unlocking in netpoll_poll_unlock()Jeff Moyer
This trivial patch moves the assignment of poll_owner to -1 inside of the lock. This fixes a potential SMP race in the code. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[PATCH] boot_pageset must not be freed.Christoph Lameter
The boot_pageset needs to be preserved for hotplugging and for off line processors and nodes. Otherwise pointers will point into memory that has now a different use. /proc/zoneinfo is currently showing strange results if processors / nodes are not present. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-06-22[NET]: dont use strlen() but the result from a prior sprintf()Eric Dumazet
Small patch to save an unecessary call to strlen() : sprintf() gave us the length, just trust it. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22Merge rsync://client.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
2005-06-22[PATCH] ARM: Remove explicit page-alignments in memory initRussell King
Since meminfo.bank[] array contains page-aligned start/size, we no longer need to explicitly round up/down the addresses when converting to PFNs. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-22[PATCH] ARM: Ensure memory information is page alignedRussell King
Ensure that meminfo.bank[] array contains page-aligned start/size information. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-22[CRYPTO]: Use CPU cycle counters in tcryptHerbert Xu
After using this facility for a while to test my changes to the cipher crypt() layer, I realised that I should've listend to Dave and made this thing use CPU cycle counters :) As it is it's too jittery for me to feel safe about relying on the results. So here is a patch to make it use CPU cycles by default but fall back to jiffies if the user specifies a non-zero sec value. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: Use template keys for speed tests if possibleHerbert Xu
The existing keys used in the speed tests do not pass the 3DES quality check. This patch makes it use the template keys instead. Other algorithms can supply template keys through the same interface if needed. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: Add cipher speed testsHarald Welte
From: Reyk Floeter <reyk@vantronix.net> I recently had the requirement to do some benchmarking on cryptoapi, and I found reyk's very useful performance test patch [1]. However, I could not find any discussion on why that extension (or something providing a similar feature but different implementation) was not merged into mainline. If there was such a discussion, can someone please point me to the archive[s]? I've now merged the old patch into 2.6.12-rc1, the result can be found attached to this email. [1] http://lists.logix.cz/pipermail/padlock/2004/000010.html Signed-off-by: Harald Welte <laforge@gnumonks.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: Kill unnecessary strncpy from tcryptHerbert Xu
It seems that bad code tends to get copied (see test_cipher_speed). So let's kill this idiom before it spreads any further. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-22[CRYPTO]: White space and coding style clean up in tcryptHerbert Xu
2005-06-22[PATCH] ARM: Use list_for_each_entry() for dmabounceRussell King
Convert dmabounce.c to use list_for_each_entry() instead of list_for_each() + list_entry(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-22[PATCH] ppc32: Fix building MPC8555 CDSKumar Gala
Adding support for MPC8548 w/o PCI support, broke building MPC8555 CDS by trying to remove a loop variable that was used when PCI is enabled. Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org)
2005-06-22[PATCH] NFS: Add debugging code to NFSv4 readdirTrond Myklebust
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Map a couple of NFSv4 errors to EINVAL.Manoj Naik
This shows up on running tar over NFSv4. Signed-off-by: Manoj Naik <manoj@almaden.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: add support for rdattr_error in NFSv4 readdir requests.Manoj Naik
Request RDATTR_ERROR as an attribute in readdir to distinguish between a directory being within an absent filesystem or one (or more) of its entries. Signed-off-by: Manoj Naik <manoj@almaden.ibm.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Clean up nfs4 lock state accountingTrond Myklebust
Ensure that lock owner structures are not released prematurely. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NLM: fix a client-side race on blocking locks.Trond Myklebust
If the lock blocks, the server may send us a GRANTED message that races with the reply to our LOCK request. Make sure that we catch the GRANTED by queueing up our request on the nlm_blocked list before we send off the first LOCK rpc call. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NLM: cleanup for blocked locks.Trond Myklebust
2005-06-22[PATCH] VFS: Ensure that all the on-stack struct file_lock call ↵Trond Myklebust
fl_release_private Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Replace nfs_page insertion sort with a radix sortTrond Myklebust
2005-06-22[PATCH] NFS: Make searching and waiting on busy writeback requests more ↵Trond Myklebust
efficient. Basically copies the VFS's method for tracking writebacks and applies it to the struct nfs_page. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Write optimization for short files and small O_SYNC writes.Trond Myklebust
Use stable writes if we can see that we are only going to put a single write on the wire. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Ensure that fstat() always returns the correct mtimeTrond Myklebust
Even if the file is open for writes. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Cleanup of caching code, and slight optimization of writes.Trond Myklebust
Unless we're doing O_APPEND writes, we really don't care about revalidating the file length. Just make sure that we catch any page cache invalidations. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFS: Fix the file size revalidationTrond Myklebust
Instead of looking at whether or not the file is open for writes before we accept to update the length using the server value, we should rather be looking at whether or not we are currently caching any writes. Failure to do so means in particular that we're not updating the file length correctly after obtaining a POSIX or BSD lock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Fix up races in nfs4_proc_setattr()Trond Myklebust
If we do not hold a valid stateid that is open for writes, there is little point in doing an extra open of the file, as the RFC does not appear to mandate this... Make setattr use the correct stateid if we're holding mandatory byte range locks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Ensure that propagate NFSv4 state errors to the reclaim codeTrond Myklebust
2005-06-22[PATCH] NFS: Clean up readdir changes.Trond Myklebust
2005-06-22[PATCH] NFS: Hide NFS server-generated readdir cookies from userlandOlivier Galibert
NFSv3 currently returns the unsigned 64-bit cookie directly to userspace. The following patch causes the kernel to generate loff_t offsets for the benefit of userland. The current server-generated READDIR cookie is cached in the nfs_open_context instead of in filp->f_pos, so we still end up work correctly under directory insertions/deletion. Signed-off-by: Olivier Galibert <galibert@pobox.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: kick off socket connect operations fasterChuck Lever
Make the socket transport kick the event queue to start socket connects immediately. This should improve responsiveness of applications that are sensitive to slow mount operations (like automounters). We are now also careful to cancel the connect worker before destroying the xprt. This eliminates a race where xprt_destroy can finish before the connect worker is even allowed to run. Test-plan: Destructive testing (unplugging the network temporarily). Connectathon with UDP and TCP. Hard-code impossibly small connect timeout. Version: Fri, 29 Apr 2005 15:32:01 -0400 Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: TCP reconnects are too slowChuck Lever
When the network layer reports a connection close, the RPC task waiting to reconnect should be notified so it can retry immediately instead of waiting for the normal connection establishment timeout. This reverts a change made in 2.6.6 as part of adding client support for RPC over TCP socket idle timeouts. Test-plan: Destructive testing with NFS over TCP mounts. Version: Fri, 29 Apr 2005 15:31:46 -0400 Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: Clean up socket autodisconnectTrond Myklebust
Cancel autodisconnect requests inside xprt_transmit() in order to avoid races. Use more efficient del_singleshot_timer_sync() Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] RPC: Ensure rpc calls respects the RPC_NOINTR flagTrond Myklebust
For internal purposes, the rpc_clnt_sigmask() call is replaced by a call to rpc_task_sigmask(), which ensures that the current task sigmask respects both the client cl_intr flag and the per-task NOINTR flag. Problem noted by Jiaying Zhang. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-06-22[PATCH] NFSv4: Fix an Oops in the callback code.Trond Myklebust
The changeset "trond.myklebust@fys.uio.no|ChangeSet|20050322152404|16979" (RPC: Ensure XDR iovec length is initialized correctly in call_header) causes the NFSv4 callback code to BUG() due to an incorrectly initialized scratch buffer. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
