Based on original implementation from Jiangbi Liu and Maciej Trela.
ATAPI transfers happen in two-to-three stages. The two stage atapi
commands are those that include a dma data transfer. The data transfer
portion of these operations is handled by the hardware packet-dma
acceleration. The three-stage commands do not have a data transfer and
are handled without hardware assistance in raw frame mode.
stage1: transmit host-to-device fis to notify the device of an incoming
atapi cdb. Upon reception of the pio-setup-fis repost the task_context
to perform the dma transfer of the cdb+data (go to stage3), or repost
the task_context to transmit the cdb as a raw frame (go to stage 2).
stage2: wait for hardware notification of the cdb transmission and then
go to stage 3.
stage3: wait for the arrival of the terminating device-to-host fis and
terminate the command.
To keep the implementation simple we only support ATAPI packet-dma
protocol (for commands with data) to avoid needing to handle the data
transfer manually (like we do for SATA-PIO). This may affect
compatibility for a small number of devices (see
ATA_HORKAGE_ATAPI_MOD16_DMA).
If the data-transfer underruns, or encounters an error the
device-to-host fis is expected to arrive in the unsolicited frame queue
to pass to libata for disposition. However, in the DONE_UNEXP_FIS (data
underrun) case it appears we need to craft a response. In the
DONE_REG_ERR case we do receive the UF and propagate it to libsas.
Signed-off-by: Maciej Trela <maciej.trela@intel.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
This will synchronize the version string with internal driver.
Signed-off-by: Xiangliang Yu <yuxiangl@marvell.com>
set SMP link timeout value to maximum.
with 1 expander, connect 8 HDD, the write performance will be
improved by 80%.
-- change connection behavior
-- set bit8 to 1 for performance tuning
-- set bit0 to 0 to enable retry for no_dest reject case.
disable non data frame retry
spin up issue: some direct attached SAS device can't spin up
Add support for Marvell 88SE9480 SAS/SATA HBA
Expanders fail to link when the phy rates are mismatched.
Needed to jump to scic_lock unlock.
Also spotted by coccicheck.
Signed-off-by: Jeff Skirvin <jeffrey.d.skirvin@intel.com>
Cc: <stable@kernel.org>
Kill the local smp response buffer.
Besides being unnecessary, it is too small (currently truncates
responses to 60 bytes). The mid-layer will have already allocated a
sufficiently sized buffer, just kmap and copy into it directly.
Reported-by: Derick Marks <derick.w.marks@intel.com>
Tested-by: Derick Marks <derick.w.marks@intel.com>
Code Inspection: found two missing break directives. First one will
result in not retrying an a task that report
IO_OPEN_CNX_ERROR_HW_RESOURCE_BUSY, the second will result in cosmetic
debug printk conflicting statement stutter. Because checkpatch.pl came
up with a warning regarding unnecessary space before a newline on one of
the fragments associated with the diff context, I took the liberty of
fixing all the cases of this issue in the pair of files touched by this
defect. These cosmetic changes hide the break changes :-(
To help focus, break changes are in pm8001_hwi.c fragment line 1649 for
the IO_OPEN_CNX_ERROR_HW_RESOURCE_BUSY case statement and pm8001_sas.c
line 1000 deals with the conflicting debug print stutter.
Signed-off-by: Mark Salyzyn <mark_salyzyn@us.xyratex.com>
Acked-by: Jack Wang <jack_wang@usish.com>
On the pm8001, when a device is in the process of going away (device
power off or hot plug), depending on the timing, the driver would return
SAS_PHY_DOWN as the return value to the queuecommand DEV_IS_GONE logic.
The net result is an near infinite retry (especially if SAS debugging is
enabled), the logs will fill with:
kernel: mpi_ssp_completion 2119:e21:SSP IO status 0x13 tag 0xcc1c0000
dlen=90 param=0xe
kernel: wwn=5000c50034069e86 cdb=12 00 00 00 5a 00 00 00 00 00 00 00 00
00 00 00
kernel: sas: lldd_execute_task returned: 138
This patch changes to leverage the port_attached logic to complete the
command with a status of PHY_DOWN so that the disposition can be handled
immediately and correctly.
Currently fcoe_ddp_min doesn't have default value
so by default not used, so setting up default value
as 4k as this works better by avoiding overhead
of programing DDP for small IOs.
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
Tested-by: Ross Brattain <ross.b.brattain@intel.com>
Signed-off-by: Yi Zou <yi.zou@intel.com>
Use real dev in case it has HW vlan acceleration
support since in this case the real dev would
do needed vlan processing, this way unnecessary
vlan layer processing avoided and it gives
slightly better IOPS with 512B size IOs.
fix holes and better cache aligned fields.
cache aligned xid and ex_lock beside
removing holes.
Re-arrange its fields to avoid padding and have better
cacheline alignments.
Removed not used start_time, end_time and last_pkt_time
fields.
This all reduced this struct size to 448 from 480 and
that also reduced one cacheline on x86_64 beside
eliminating 8 pads. However kept logical fields together.
Since fcoe_percpu_thread_create() creates percpu kthread, it makes sense
to use kthread_create_on_node() to get proper NUMA affinity for kthread
stack.
Several sas drivers legitimately check the protocol against the union of
SAS_PROTOCOL_SATA and SAS_PROTOCOL_STP. Provide a SAS_PROTOCOL_STP_ALL
to silence warnings like:
drivers/scsi/pm8001/pm8001_sas.c:438:3: warning: case value ‘5’ not in enumerated type ‘enum sas_protocol’ [-Wswitch]
drivers/scsi/mvsas/mv_sas.c:798:2: warning: case value ‘5’ not in enumerated type ‘enum sas_protocol’ [-Wswitch]
drivers/scsi/mvsas/mv_sas.c:1783:2: warning: case value ‘5’ not in enumerated type ‘enum sas_protocol’ [-Wswitch]
drivers/scsi/mvsas/mv_sas.c:1886:2: warning: case value ‘5’ not in enumerated type ‘enum sas_protocol’ [-Wswitch]
drivers/scsi/isci/request.c:3565:2: warning: case value ‘5’ not in enumerated type ‘enum sas_protocol’ [-Wswitch]
Libsas forget to set the sas_address and device type of rphy lead to file
under /sys/class/sas_x show wrong value, fix that.
Signed-off-by: Jack Wang <jack_wang@usish.com>
Tested-by: Crystal Yu <crystal_yu@usish.com>
Cc: stable@kernel.org
If the user has disabled CONFIG_SCSI_SAS_HOST_SMP then libsas drivers
will not be receiving smp-gpio frames and do not need this lookup code.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Tested-by: Randy Dunlap <rdunlap@xenotime.net>
libsas handles:
1/ limiting ata scanning to lun0
2/ changes to /sys/block/<sdX>/device/queue_depth for ata devices
libata handles turning off ncq globally via kernel command line
(libata.force=noncq) or sysfs (echo 1 >
/sys/block/<sdX>/device/queue_depth). A lldd specific compile option is
not necessary.
Cc: Jack Wang <jack_wang@usish.com>
libsas now handles:
2/ maximizing the queue_depth of sas devices (up to 256, mvsas only
supports 64)
3/ changes to /sys/block/<sdX>/device/queue_depth for ata devices
Acked-by: Xiangliang Yu <yuxiangl@marvell.com>
The queue-depth for libsas-attached devices initializes to 32 and can
only be increased manually via sysfs to a max of 64, while mpt2sas
attached devices initialize to 254 and dynamically float via the
midlayer ->change_queue_depth interface.
No performance regression was observed with this change on the isci
driver.
Tested-by: Dave Jiang <dave.jiang@intel.com>
Pass queue_depth change requests to libata, and prevent queue_type
changes for ATA devices.
Otherwise:
1/ we do not honor the libata specific restrictions on the queue depth
2/ libsas drivers that do not set sdev->tagged_supported are unable to
change the queue_depth of ata devices via sysfs
Acked-by: Jeff Garzik <jgarzik@redhat.com>
Currently mvsas and pm8001 have custom ->slave_alloc implementations to
achieve this. Uplevel it for all libsas drivers as isci encounters problems
with atapi devices when scanning past lun0.
Just do what Darrick suggested [1], and limit the scan for ata devices.
[1] http://marc.info/?l=linux-scsi&m=116604101119861&w=2
Allow expander table-to-table attachments for
expanders that support it.
Signed-off-by: Luben Tuikov <ltuikov@yahoo.com>
When the ipr driver decides to dump the adapter, it changes the
sdt_state to GET_DUMP, then prepares the adapter so that the dump
can be read. However, if the ipr worker thread wakes up for some
reason before the driver has put the adapter in a state where it
can succesfully dump the adapter, the driver will start dumping
the adapter too early, which can potentially trigger a BUG check
in the pci config blocking API. Fix this by adding a new
sdt_state to differentiate between the ipr driver wanting to dump
the adapter in the near future and wanting to dump the adapter now.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: Vijay Chauhan <Vijay.chauhan@netapp.com>
Reviewed-by: Bob Stankey <Robert.stankey@netapp.com>
Reviewed-by: Babu Moger <Babu.moger@netapp.com>
Acked-by: Chandra Seetharaman <sekharan@us.ibm.com>
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com>
Gracefully handle bnx2fc_map_sg failure, so that queuecommand returns host busy
and SCSI-ml can retry the IO.
scsi_dma_map doesn't work for NPIV since vport dev isn't fully initialized.
For more details: http://marc.info/?l=linux-scsi&m=118312448030633&w=2 and
commit - c59fd9ebc46da8d48b76955d4d48e3597f8c8726.
Signed-off-by: Nithin Sujir <nsujir@broadcom.com>
ERRATA
When READ_16 command is issued, the setting of SILI Bit in CDB is confirmed
and if SILI bit is off, the processing of relavent Errata is executed.
Added code for checking SILI bit for READ_16 as described in "SSC-4".
Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com>
Sizeof a pointer-typed expression returns the size of the pointer, not that
of the pointed data.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression *e;
type T;
identifier f;
f(...,(T)e,...,
-sizeof(e)
+sizeof(*e)
// </smpl>
bnx2fc.txt outlines the driver usage model.
Mutual exclusion is redundant here because all the paths in the call graph
leading to esp_driver_ops.send_dma_cmd() happen under spin_lock_irqsave/
spin_lock_irqrestore. Remove it.
Tested on a Mac Quadra 660av and a Mac LC 630.
Signed-off-by: Finn Thain <fthain@telegraphics.com.au>
support of the HBA
Support added for controllers capable of multi reply queues.
The following are the modifications to the driver to support NUMA.
1) Create the new structure adapter_reply_queue to contain the reply queue
info for every msix vector. This object will contain a
reply_post_host_index, reply_post_free for each instance, msix_index, among
other parameters. We will track all the reply queues on a link list called
ioc->reply_queue_list. Each reply queue is aligned with each IRQ, and is
passed to the interrupt via the bus_id parameter.
(2) The driver will figure out the msix_vector_count from the PCIe MSIX
capabilities register instead of the IOC Facts->MaxMSIxVectors. This is
because the firmware is not filling in this field until the driver has
already registered MSIX support.
(3) If the ioc_facts reports that the controller is MSIX compatible in the
capabilities, then the driver will request for multiple irqs. This count
is calculated based on the minimum between the online cpus available and
the ioc->msix_vector_count. This count is reported to firmware in the
ioc_init request.
(4) New routines were added _base_free_irq and _base_request_irq, so
registering and freeing msix vectors were done thru simple function API.
(5) The new routine _base_assign_reply_queues was added to align the msix
indexes across cpus. This will initialize the array called
ioc->cpu_msix_table. This array is looked up on every MPI request so the
MSIxIndex is set appropriately.
(6) A new shost sysfs attribute was added to report the reply_queue_count.
(7) User needs to set the affinity cpu mask, so the interrupts occur on the
same cpu that sent the original request.
This patch adds couple more Vendor/Product IDs for RDAC.. There are no
functional changes.
Signed-off-by: Babu Moger <babu.moger@netapp.com>
Basic support to initialize the gpio unit, accept an incomming
SAS_GPIO_REG_TX_GP bitstream, and translate it to the ODx.n fields in
the hardware registers. If register indexes outside the supported range
are specified in the SMP frame we simply accept the write and return how
many registers (SFF-8485) were written (libsas reports this as residue
in the request).
output_data_select registers are off by one u32
delete the macros we will never use.
Reported-by: Artur Wojcik <artur.wojcik@intel.com>
Add SFF-8485 v0.7 / SAS-1 smp-write-gpio register support to libsas.
Defer SAS-2 support unless/until it defines an sgpio interface.
Minimum implementation needed to get the lights blinking.
try_test_sas_gpio_gp_bit() provides a common method to parse the
incoming write data (raw bitstream), and the to_sas_gpio_gp_bit() helper
routine can be used as a basis for the set/clear operations for the
'read' implementation. Host implementations parse as many bits
(ODx.[012]) as are locally supported and report the number of registers
successfully written. If the submitted data overruns the internal
number of registers available report the write as a success with the
number of bytes remaining reported in ->resid_len.
Example (assuming an active backplane) set the "identify" pattern for
the first 21 devices:
smp_write_gpio --count=2 --data=92,49,24,92,24,92,49,24 -t 4 --index=1 /dev/bsg/sas_hostX
qla4xxx now uses iscsi_boot_sysfs to export the targets used
for boot to sysfs. It needs to select that config option
to make sure that module is also built.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Firmware asserts when the same CQE is armed twice. This scenario happens during
RSCN stress tests as driver incorrects arms the CQ after the session is
offloaded.
create().
Driver incorrectly calls bnx2fc_interface_cleanup() when bnx2fc_if_create fails
which accesses bad pointer. Handle bnx2fc_if_create failure by directly calling
bnx2fc_net_cleanup.
It is not required to hold rtnl_lock and bnx2fc_dev_lock when calling
bnx2fc_if_destroy, as the locking is only required to serialize creation and
deletion of fcoe instances. More importantly, this unnecessary locking causes
deadlock as bnx2fc_if_destroy calls fc_remove_host holding rtnl_lock.
When bnx2fc receives an UNREGISTER event on a vlan interface it calls
destroy on all interfaces that matches the physical interface. Add
vlan_id check to destroy only the vlan interface that generated the
event.
Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com>
ABTS was not issued for timed out REC, as REC completion handler exits out if
the IO completed. Check for timed out REC and issue ABTS before proceeding with
further processing in REC completion handler. Also, initialize rec_retry and
srr_retry before starting the IO.
